  4. Node-Red
  5. Wie kann ich Zwei Analogwerte vergleichen.
    6.4k
node-red
18 Beiträge 3 Kommentatoren 2.2k Aufrufe 2 Beobachtet
    Armin 2
    Danke für die Mühe, aber das passt so noch nicht.
    Hier nochmal mein Problem.
    Ich möchte einen Wert von IO-Broker mit einem Wert "change" vergleichen und ein Bit z.B. im IOBroker setzen.
    "id": "32ca1d3d3965fa09",
    "type": "tab",
    "label": "Flow 2",
    "disabled": false,
    "info": "",
    "env": []
    "id": "1a1283bbbd4c8410",
    "type": "ioBroker out",
    "z": "32ca1d3d3965fa09",
    "name": "Battery Charging enabled [gridCharge]",
    "topic": "alpha-ess.0.Settings_Charge.Battery_Charging_enabled",
    "ack": "false",
    "autoCreate": "false",
    "stateName": "",
    "role": "",
    "payloadType": "",
    "readonly": "",
    "stateUnit": "",
    "stateMin": "",
    "stateMax": "",
    "x": 1050,
    "y": 340,
    "wires": []
    "id": "a2d7ca6eafbe6e71",
    "type": "ioBroker in",
    "name": " alpha-ess.0.Realtime.Battery_SOC",
    "attrname": "temp1",
    "topic": "alpha-ess.0.Realtime.Battery_SOC",
    "payloadType": "value",
    "onlyack": "",
    "func": "all",
    "gap": "",
    "fireOnStart": "false",
    "outFormat": "MQTT",
    "x": 300,
    "y": 260,
    "wires": [
    "id": "92f11862fdebb1a9",
    "type": "change",
    "name": "SOC 20",
    "rules": [
    "t": "set",
    "p": "payload",
    "pt": "msg",
    "to": "20",
    "tot": "num"
    "action": "",
    "property": "",
    "from": "",
    "to": "",
    "reg": false,
    "x": 380,
    "y": 340,
    "wires": [
    "id": "82df9544976c9930",
    "type": "inject",
    "name": "",
    "props": [
    "p": "payload"
    "p": "topic",
    "vt": "str"
    "repeat": "",
    "crontab": "",
    "once": false,
    "onceDelay": 0.1,
    "topic": "",
    "payload": "",
    "payloadType": "date",
    "x": 160,
    "y": 340,
    "wires": [
    "92f11862fdebb1a9"
    "id": "ba6a0a91683436e9",
    "type": "switch",
    "name": "",
    "property": "temp1 >= temp2",
    "propertyType": "jsonata",
    "rules": [
    "t": "true"
    "t": "false"
    "checkall": "true",
    "repair": false,
    "outputs": 2,
    "x": 750,
    "y": 340,
    "wires": [
    "1a1283bbbd4c8410",
    "33fca06d3914b1cb"
    "id": "33fca06d3914b1cb",
    "type": "debug",
    "name": "Charging Einschalten",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "complete": "payload",
    "targetType": "msg",
    "statusVal": "",
    "statusType": "auto",
    "x": 1000,
    "y": 260,
    "wires": []
    • A Armin 2
      "type": "tab",
      "label": "Flow 2",
      "disabled": false,
      "info": "",
      "env": []
      "ack": "false",
      "stateName": "",
      "role": "",
      "payloadType": "",
      "readonly": "",
      "stateUnit": "",
      "stateMin": "",
      "stateMax": "",
      "x": 1050,
      "y": 340,
      "wires": []
      "onlyack": "",
      "func": "all",
      "gap": "",
      "x": 300,
      "y": 260,
      "wires": [
      "type": "change",
      "name": "SOC 20",
      "rules": [
      "t": "set",
      "p": "payload",
      "pt": "msg",
      "to": "20",
      "tot": "num"
      "action": "",
      "property": "",
      "from": "",
      "to": "",
      "reg": false,
      "x": 380,
      "y": 340,
      "wires": [
      "type": "inject",
      "name": "",
      "props": [
      "p": "payload"
      "p": "topic",
      "vt": "str"
      "repeat": "",
      "crontab": "",
      "once": false,
      "onceDelay": 0.1,
      "topic": "",
      "payload": "",
      "x": 160,
      "y": 340,
      "wires": [
      "92f11862fdebb1a9"
      "type": "switch",
      "name": "",
      "rules": [
      "t": "true"
      "t": "false"
      "checkall": "true",
      "repair": false,
      "outputs": 2,
      "x": 750,
      "y": 340,
      "wires": [
      "1a1283bbbd4c8410",
      "33fca06d3914b1cb"
      "type": "debug",
      "active": true,
      "tosidebar": true,
      "console": false,
      "tostatus": false,
      "statusVal": "",
      "x": 1000,
      "y": 260,
      "wires": []
      mickymM Offline
      mickymM Offline
      mickym
      So korrigiert - siehe nächster Post.
      • mickymM mickym
        Armin 2
        @mickym
        Ich möchte einen Wert von IO-Broker mit einem Wert aus "change" vergleichen, der aus einem andern Flow kommt und ein Bit z.B. im IOBroker setzen, wenn der Wert aus dem IOBroker >= dem Wert aus dem "change" ist.
        • A Armin 2
          @mickym
          mickymM Offline
          mickymM Offline
          mickym
          Mach das mit dem Kontext. Der zweite Wert wird über die Change Node im Flow Kontext gespeichert.
          Wird Batterie_SOC getriggert wird der Kontext wieder in das Nachrichtenobjekt in die Eigenschaft value geladen.
          Hier zum Import:
                 "id": "313b5fce557e4aef",
                 "z": "8cf2ddd0a8460b51",
                 "name": "",
                 "attrname": "payload",
                 "onlyack": "",
                 "func": "all",
                 "gap": "",
                 "x": 360,
                 "y": 480,
                 "wires": [
                         "30bc38cb790891f0"
                 "id": "2ce9c640efa3e18c",
                 "type": "switch",
                 "name": "",
                 "property": "payload > value",
                 "rules": [
                         "t": "true"
                         "t": "false"
                 "checkall": "true",
                 "repair": false,
                 "outputs": 2,
                 "x": 870,
                 "y": 480,
                 "wires": [
                 "id": "3333b79ff893ca32",
                 "type": "change",
                 "name": "zweiter Wert",
                 "rules": [
                         "t": "set",
                         "p": "zweiterWert",
                         "pt": "flow",
                         "to": "payload",
                         "tot": "msg"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 470,
                 "y": 580,
                 "wires": [
                 "id": "a7f2b0a13a124068",
                 "type": "inject",
                 "name": "",
                 "props": [
                         "p": "payload"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "payload": "90",
                 "payloadType": "num",
                 "x": 290,
                 "y": 580,
                 "wires": [
                         "3333b79ff893ca32"
                 "id": "30bc38cb790891f0",
                 "type": "change",
                 "name": "",
                 "rules": [
                         "t": "set",
                         "p": "value",
                         "pt": "msg",
                         "to": "zweiterWert",
                         "tot": "flow"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 640,
                 "y": 480,
                 "wires": [
                         "2ce9c640efa3e18c"
          Bzw. (s. nächster Post) aus dem anderen Flow den Wert direkt im globalen Kontext speichern.
          • A Armin 2
            @mickym
            mickymM Offline
            mickymM Offline
            mickym
            @armin-2 Du kannst es auch aus dem anderen Flow - im globalen Kontext speichern!!! So würde ich es machen. Aber ich kenne ja den anderen Flow nicht.
            In dem anderen Flow speicherst Du im globalen Kontext
            Dann kannst Du den globalen Kontext in der Change Node wieder aus der Variablen einlesen:
            Dann brauchst Du die Flows NICHT zu verlinken, sondern tauscht über den globalen Kontext aus.
              Armin 2
              Das passt immer noch nicht. Hier mein ganzer Flow mit Beschreibung, vielleicht hilft das.
              "id": "93f485839dfa27a8",
              "type": "subflow",
              "name": "Solar forecast",
              "info": "This subflow uses the http request node to fetch solar forecasts for geographical positions, using the API from https://forecast.solar/. Please check their website and consider getting a paid account.\n\nDo note that, on a free account, you are limited in the number of requests to do. Also note that the data only gets updated once every 15 minutes, so there is no reason to query more often. There is rate limiting built in the subflow not to perform requests more than once every 15 minutes.\n\n# Configuration\n\nIt uses the parameters as described on: http://doc.forecast.solar/doku.php\n\n - :apikey - personal API key for registered users\n - :lat - latitude of location, -90 (south) … 90 (north); Internal precission is 0.0001 or abt. 10 m\n - :lon - longitude of location, -180 (west) … 180 (east); Internal precission is 0.0001 or abt. 10 m\n - :dec - plane declination, 0 (horizontal) … 90 (vertical); Internal precission is integer\n - :az - plane azimuth, -180 … 180 (-180 = north, -90 = east, 0 = south, 90 = west, 180 = north); Internal precission is integer\n - :kwp - installed modules power in kilo watt peak (kWp)\n\nYou can choose between 3 different type of requests. Note that only estimate is available on the free plan.\n\n- estimate - this is the forecasted estimate that your panels should produce (given the right parameter settings)\n- history - historical data showing the long term averages for the days to come. See https://joint-research-centre.ec.europa.eu/pvgis-online-tool/pvgis-data-download/cm-saf-solar-radiation_en for where the data is fetched from.\n- clear sky - estimate given if there would be a clear sky tomorrow\n\nIn case of estimates, one of the following options can be selected:\n- watts - Watts (power) average for the period\n- watt_hours_period - Watt hours (energy) for the period\n- watt_hours - Watt hours (energy) summarized over the day\n- watt_hours_day - Watt hours (energy) summarized for each day\n\nFor the graph output there are some extra settings available:\n\n- Output in kWh - when checked output can be set to kWh instead of Wh\n- Show todays forecast - whether or not to include todays forecast\n- Days to forecast - the number of days to forecast (excluding today). Note that you can not get more days forecasted than your API key allows.\n- Widen graph - widen the graph to only show non-zero values\n\n# Input \n\nThe input is for triggering the solar forecast request. \nIt triggers when injecting a message into the node.\n\n# Output\n\nThere are two outputs. The first output is an object with the result and a status message stored into the msg.payload.\n\nMost important is the msg.payload.result, which contains the estimated production of the panels. E.g.:\n\n\npayload: object\n result: object\n 2022-11-28: 23\n 2022-11-29: 35\n\n\nThe msg.payload.message gives information on how successful the query was, the exitcode of the query and the status of the rate limit (how many queries you have left).\n\nThe second output can be directly linked to a line or a bar chart, quickly giving a once-glance overview for the predicted forecast.\n\n# Status\n\nInitially the status of the note will be a blue dot, showing "Unknown limit", as it is unaware of the set ratelmits. After the first request, the returned ratelimit will be put in the text in the form of remaining/limit. If more than half the limit is remaining, the dot will be green. If less then half the limit is remaining, the dot will be yellow. If no limit is left, the dot will turn red.\nPlease keep in mind that the ratelimit will be reset after one hour, so you can send a new request after that hour.\n\nIf something is wrong in the API request, the dot will turn red\nand the message will contain the msg.payload with the error. This\nhappens typically when the API is temporally down for maintenance.",
              "category": "",
              "in": [
              "x": 240,
              "y": 100,
              "wires": [
              "id": "c8dc6aa14b9f3e92"
              "out": [
              "x": 760,
              "y": 260,
              "wires": [
              "id": "2f42837904c91d73",
              "port": 0
              "id": "fcc8d69a3ab88e6d",
              "port": 0
              "x": 770,
              "y": 340,
              "wires": [
              "id": "5b0a430fb61e70e7",
              "port": 0
              "env": [
              "name": "latitude",
              "type": "num",
              "value": "51.3",
              "ui": {
              "icon": "font-awesome/fa-location-arrow",
              "type": "input",
              "opts": {
              "types": [
              "num"
              "name": "longitude",
              "type": "num",
              "value": "5.6",
              "ui": {
              "type": "input",
              "opts": {
              "types": [
              "num"
              "name": "declination",
              "type": "num",
              "value": "37",
              "ui": {
              "icon": "font-awesome/fa-chevron-up",
              "type": "input",
              "opts": {
              "types": [
              "num"
              "name": "azimuth",
              "type": "num",
              "value": "0",
              "ui": {
              "icon": "font-awesome/fa-compass",
              "type": "spinner",
              "opts": {
              "min": -180,
              "max": 180
              "name": "modules power",
              "type": "num",
              "value": "1",
              "ui": {
              "icon": "font-awesome/fa-power-off",
              "type": "input",
              "opts": {
              "types": [
              "num"
              "name": "apikey",
              "type": "cred",
              "ui": {
              "icon": "font-awesome/fa-key",
              "type": "input",
              "opts": {
              "types": [
              "cred"
              "name": "type",
              "type": "str",
              "value": "estimate",
              "ui": {
              "label": {
              "en-US": "type"
              "type": "select",
              "opts": {
              "opts": [
              "l": {
              "en-US": "Estimate"
              "v": "estimate"
              "l": {
              "en-US": "History"
              "v": "history"
              "l": {
              "en-US": "Clear sky"
              "v": "clearsky"
              "name": "watt",
              "type": "str",
              "value": "watts",
              "ui": {
              "icon": "font-awesome/fa-question-circle-o",
              "type": "select",
              "opts": {
              "opts": [
              "l": {
              "en-US": "Watts (power) average for the period"
              "v": "watts"
              "l": {
              "en-US": "Watt hours (energy) for the period"
              "v": "watt_hours_period"
              "l": {
              "en-US": "Watt hours (energy) summarized over the day"
              "v": "watt_hours"
              "l": {
              "en-US": "Watt hours (energy) summarized for each day"
              "v": "watt_hours_day"
              "name": "kwhoutput",
              "type": "bool",
              "value": "false",
              "ui": {
              "label": {
              "en-US": "Output in kWh (in the graph)"
              "type": "checkbox"
              "name": "showtoday",
              "type": "bool",
              "value": "true",
              "ui": {
              "label": {
              "en-US": "Show todays forecast"
              "type": "checkbox"
              "name": "daystoforecast",
              "type": "str",
              "value": "-1",
              "ui": {
              "label": {
              "en-US": "Days to forecast"
              "type": "select",
              "opts": {
              "opts": [
              "l": {
              "en-US": "Max"
              "v": "-1"
              "l": {
              "en-US": "0"
              "v": "0"
              "l": {
              "en-US": "1"
              "v": "1"
              "l": {
              "en-US": "2"
              "v": "2"
              "l": {
              "en-US": "3"
              "v": "3"
              "l": {
              "en-US": "4"
              "v": "4"
              "l": {
              "en-US": "5"
              "v": "5"
              "l": {
              "en-US": "6"
              "v": "6"
              "name": "widengraph",
              "type": "bool",
              "value": "true",
              "ui": {
              "label": {
              "en-US": "Widen graph"
              "type": "checkbox"
              "meta": {
              "module": "Solar Forecast",
              "version": "0.0.9",
              "author": "dfaber@victronenergy.com",
              "desc": "Get solar forecasting per location",
              "keywords": "solar,forecast,api",
              "license": "GPL-3.0"
              "color": "#FFCC66",
              "inputLabels": [
              "trigger"
              "outputLabels": [
              "output",
              "graph"
              "icon": "font-awesome/fa-sun-o",
              "status": {
              "x": 680,
              "y": 560,
              "wires": [
              "id": "1bfc1cde3ee94e4b",
              "port": 0
              "id": "a798fbe66cf133d5",
              "port": 0
              "id": "c706820c0d61f023",
              "type": "http request",
              "z": "93f485839dfa27a8",
              "name": "",
              "method": "GET",
              "ret": "txt",
              "paytoqs": "ignore",
              "url": "",
              "tls": "",
              "persist": false,
              "proxy": "",
              "insecureHTTPParser": false,
              "authType": "",
              "senderr": false,
              "headers": [],
              "x": 390,
              "y": 180,
              "wires": [
              "1b5ccaa05d54f7c3"
              "id": "b9488734852cd0ca",
              "type": "function",
              "name": "create forecast.solar url",
              "func": "msg.url = 'https://api.forecast.solar/';\n\nif (env.get('apikey')) {\n msg.url += env.get('apikey') + '/';\n }\n\nmsg.url += env.get('type') + '/';\n\nmsg.url += env.get('watt') + '/';\n\nmsg.url += env.get('latitude') + '/' +\n env.get('longitude') + '/' +\n env.get('declination') + '/' +\n env.get('azimuth') + '/' +\n env.get('modules power');\n\nmsg.topic = 'solar forecast: '+(env.get('type') || '');\nmsg.topic += (' '+env.get('watt') || '');\nif (env.get('kwhoutput')) {\n msg.topic += ' (kWh)';\n}\nreturn msg;",
              "outputs": 1,
              "timeout": "",
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 630,
              "y": 100,
              "wires": [
              "975daf96f15cfb61"
              "id": "1b5ccaa05d54f7c3",
              "type": "json",
              "name": "Convert to json",
              "property": "payload",
              "action": "",
              "pretty": false,
              "x": 680,
              "y": 180,
              "wires": [
              "e718a22973cc2864"
              "id": "559391d1288f762a",
              "type": "function",
              "name": "update ratelimit",
              "func": "var remaining = msg.payload.message.ratelimit.remaining || 0;\nvar limit = msg.payload.message.ratelimit.limit;\n\nflow.set('forecast.solar.ratelimit.remaining', remaining)\nflow.set('forecast.solar.ratelimit.limit', limit)\n\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 520,
              "y": 480,
              "wires": [
              "e56826252134b93a"
              "id": "e718a22973cc2864",
              "type": "link out",
              "name": "link out 1",
              "mode": "link",
              "links": [
              "3fa24f2d08195961",
              "0a20e852662c8cec"
              "x": 815,
              "y": 180,
              "wires": []
              "id": "3fa24f2d08195961",
              "type": "link in",
              "name": "link in 1",
              "links": [
              "e718a22973cc2864"
              "x": 385,
              "y": 480,
              "wires": [
              "559391d1288f762a"
              "id": "0a20e852662c8cec",
              "type": "link in",
              "name": "link in 2",
              "links": [
              "e718a22973cc2864"
              "x": 225,
              "y": 260,
              "wires": [
              "fcc8d69a3ab88e6d"
              "id": "4734b6f403e1f03e",
              "type": "inject",
              "name": "",
              "props": [
              "p": "payload"
              "p": "topic",
              "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": true,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "",
              "x": 530,
              "y": 440,
              "wires": [
              "e56826252134b93a"
              "type": "function",
              "name": "update status",
              "func": "var remaining = flow.get('forecast.solar.ratelimit.remaining') || -1;\nvar limit = flow.get('forecast.solar.ratelimit.limit') || -1\n\nvar text = remaining.toString() + '/' + limit.toString();\nvar fill = "green";\n\nif (remaining == 0) {\n fill = "red";\n text = "Limit used";\n}\n\nif (remaining > 0 && remaining < limit / 2) {\n fill = "yellow"\n}\n\nif (remaining == -1 ) {\n fill = "blue"\n text = "Limits unknown"\n}\n\nmsg.payload = ({ fill: fill, text: text });\n\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 520,
              "y": 580,
              "wires": [
              "id": "a18e96179ec2d987",
              "type": "function",
              "name": "Create graph output",
              "func": "var m = {};\nm.labels = [];\nm.data = [];\n\nm.series = [];\nm.data = [];\nm.labels = [];\n\nfor (let j = 0; j <= msg.days; j++) {\n m.data[j] = [];\n}\n\nif (msg.watt === 'watt_hours_day') {\n var i = 0;\n m.series.push("Watt hours per day");\n for (const key in msg.payload.result) {\n m.labels.push(key);\n if (msg.kwhoutput) {\n m.data[i] = +(Math.round(msg.payload.result[key]/100).1).toFixed(1);\n } else {\n m.data[i] = msg.payload.result[key];\n }\n i++;\n }\n m.data = [m.data];\n return { payload: [m] };\n}\n\nfor (let i = 0; i <= 23; i++) {\n\n m.labels.push(i.toString()+':00');\n if (msg.resolution === 4) {\n m.labels.push(i.toString()+':15');\n }\n if (msg.resolution === 2 || msg.resolution == 4) {\n m.labels.push(i.toString()+':30');\n }\n if (msg.resolution === 4) {\n m.labels.push(i.toString()+':45');\n }\n\n for (let j = 0; j <= msg.days; j++) {\n m.data[j].push(0);\n if (msg.resolution === 4) {\n m.data[j].push(0)\n }\n if (msg.resolution === 2 || msg.resolution == 4) {\n m.data[j].push(0)\n }\n if (msg.resolution === 4) {\n m.data[j].push(0)\n }\n\n }\n}\n\nvar offset = 0;\nfor (const key in msg.payload.result) {\n var d = new Date(key)\n if (m.series.indexOf(d.toISOString().split('T')[0]) === -1) {\n m.series.push(d.toISOString().split('T')[0])\n }\n\n var h = d.getHours();\n var minutes = d.getMinutes();\n\n if (minutes === 0 ) {\n offset = 0;\n } else {\n offset++;\n }\n\n if (msg.kwhoutput) {\n m.data[m.series.length - 1][hmsg.resolution+offset] = +(Math.round(msg.payload.result[key]/100).1).toFixed(1);\n } else {\n m.data[m.series.length - 1][hmsg.resolution+offset] = msg.payload.result[key];\n }\n}\n\nreturn { payload: [m] };\n",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 360,
              "y": 340,
              "wires": [
              "5b0a430fb61e70e7"
              "id": "975daf96f15cfb61",
              "type": "link out",
              "name": "link out 7",
              "mode": "link",
              "links": [
              "14f2e68e572f4ef8"
              "x": 805,
              "y": 100,
              "wires": []
              "id": "14f2e68e572f4ef8",
              "type": "link in",
              "name": "link in 18",
              "links": [
              "975daf96f15cfb61"
              "x": 245,
              "y": 180,
              "wires": [
              "c706820c0d61f023"
              "id": "c4307905e114824f",
              "type": "catch",
              "name": "",
              "scope": null,
              "uncaught": false,
              "x": 260,
              "y": 440,
              "wires": [
              "f427f19392c399ce"
              "id": "e56826252134b93a",
              "type": "link out",
              "name": "link out 8",
              "mode": "link",
              "links": [
              "dbaf8f5f5a920686"
              "x": 685,
              "y": 480,
              "wires": []
              "id": "dbaf8f5f5a920686",
              "type": "link in",
              "name": "link in 19",
              "links": [
              "e56826252134b93a"
              "x": 385,
              "y": 580,
              "wires": [
              "1bfc1cde3ee94e4b"
              "id": "f427f19392c399ce",
              "type": "link out",
              "name": "link out 9",
              "mode": "link",
              "links": [
              "2ded0c14a222b4d9",
              "2f42837904c91d73"
              "x": 375,
              "y": 440,
              "wires": []
              "id": "2ded0c14a222b4d9",
              "type": "link in",
              "name": "link in 20",
              "links": [
              "f427f19392c399ce"
              "x": 385,
              "y": 540,
              "wires": [
              "a798fbe66cf133d5"
              "type": "function",
              "name": "Set error status",
              "func": "node.warn(msg.payload)\nmsg.payload = ({ fill: "red", text: msg.payload });\n\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 520,
              "y": 540,
              "wires": [
              "type": "link in",
              "name": "link in 21",
              "links": [
              "f427f19392c399ce"
              "x": 665,
              "y": 280,
              "wires": [
              "type": "function",
              "name": "Processed info",
              "func": "msg.resolution = 60;\nmsg.days = 1;\nmsg.type = env.get('type');\nmsg.watt = env.get('watt');\nmsg.kwhoutput = env.get('kwhoutput');\n\nvar key1 = Object.keys(msg.payload.result)[1];\nvar key2 = Object.keys(msg.payload.result)[2];\nvar key3 = Object.keys(msg.payload.result)[Object.keys(msg.payload.result).length-1];\n\nvar d1 = new Date(key1);\nvar d2 = new Date(key2); \nvar d3 = new Date(key3);\nmsg.resolution = 3600000 / (d2.getTime() - d1.getTime());\n\nmsg.days = Math.floor((d3.getTime() - d1.getTime()) / (1000 * 3600 * 24));\n\nif (msg.watt === 'watt_hours_day') {\n msg.resolution = null;\n}\n\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 360,
              "y": 260,
              "wires": [
              "a18e96179ec2d987"
              "info": "Function to process the result from forecast.solar to add\nextra information, which is handy for either graphing or\nto store in a database.\n\n\nThe extra values added:\n- msg.resolution - The number of measurements per hour. If\nno API key is used, this will be 1. Other values may be 2 or 4.\n- msg.days - The number of days in the forcast. If no API\n- key is used this will be 1. Other values may be 3 or 6."
              "type": "function",
              "name": "Filter graph",
              > 0) {\n remove = false;\n }\n }\n if (remove) {\n msg.payload[0].labels.splice(x, 1);\n for (d = 0; d < msg.payload[0].data.length; d++) {\n msg.payload[0].data[d].splice(x, 1);\n }\n x--;\n }\n x++;\n }\n // Still the first and last datapoints should be zero, so\n // add those again\n msg.payload[0].labels.unshift('');\n msg.payload[0].labels.push('');\n for (d = 0; d < msg.payload[0].data.length; d++) {\n msg.payload[0].data[d].unshift(0);\n msg.payload[0].data[d].push(0);\n } \n}\n\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 590,
              "y": 340,
              "wires": [
              "id": "c8dc6aa14b9f3e92",
              "type": "delay",
              "name": "5 msg/15 minutes",
              "pauseType": "rate",
              "timeout": "5",
              "timeoutUnits": "seconds",
              "rate": "5",
              "nbRateUnits": "15",
              "rateUnits": "minute",
              "randomFirst": "1",
              "randomLast": "5",
              "randomUnits": "seconds",
              "drop": false,
              "allowrate": false,
              "outputs": 1,
              "x": 390,
              "y": 100,
              "wires": [
              "b9488734852cd0ca"
              "type": "tab",
              "label": "Flow 2",
              "disabled": false,
              "info": "",
              "env": []
              "id": "93511f47e1f57f02",
              "type": "group",
              "name": "Sammeln der Daten in JOIN Node",
              "style": {
              "fill": "#d1d1d1",
              "label": true,
              "color": "#000000"
              "nodes": [
              "9aecc09bd88aa42a",
              "5dc336ee1d2a02da",
              "008ab1d49e4bb116"
              "x": 154,
              "y": 99,
              "w": 672,
              "h": 82
              "id": "47a4cf54866c5a93",
              "type": "inject",
              "name": "",
              "props": [
              "p": "payload"
              "p": "topic",
              "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "",
              "x": 120,
              "y": 460,
              "wires": [
              "206c8fbe5daa2c1e"
              "id": "206c8fbe5daa2c1e",
              "type": "subflow:93f485839dfa27a8",
              "name": "Süd",
              "env": [
              "name": "latitude",
              "value": "51.0618535",
              "type": "num"
              "value": "7.376629",
              "type": "num"
              "value": "40",
              "type": "num"
              "name": "azimuth",
              "value": "182",
              "type": "num"
              "value": "9",
              "type": "num"
              "name": "apikey",
              "type": "cred"
              "name": "watt",
              "value": "watt_hours_day",
              "type": "str"
              "type": "bool",
              "value": "false"
              "value": "1",
              "type": "str"
              "type": "bool",
              "value": "false"
              "x": 310,
              "y": 460,
              "wires": [
              "57dc8d4b5bbeaa7f"
              "id": "57dc8d4b5bbeaa7f",
              "type": "function",
              "name": "function 16",
              "func": "var pvf = msg.payload;\nvar date = moment().tz("Europe/Berlin");\nvar today = date.format('YYYY-MM-DD');\nvar hourEntries = Object.keys(pvf.result);\nvar todaysEntries = hourEntries.filter(x => x.startsWith(today));\nvar expectedEarning = pvf.result[todaysEntries[todaysEntries.length -1]];\nmsg.payload = expectedEarning;\nreturn msg;",
              "outputs": 1,
              "timeout": "",
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [
              "var": "moment",
              "module": "moment"
              "x": 530,
              "y": 460,
              "wires": [
              "15b38fae77d09de8"
              "id": "15b38fae77d09de8",
              "type": "switch",
              "name": "",
              "propertyType": "msg",
              "rules": [
              "t": "lt",
              "v": "2000",
              "vt": "str"
              "t": "btwn",
              "v": "2000",
              "vt": "num",
              "v2": "5000",
              "v2t": "num"
              "t": "btwn",
              "v": "5000",
              "vt": "num",
              "v2": "8000",
              "v2t": "num"
              "t": "gt",
              "v": "8000",
              "vt": "str"
              "checkall": "true",
              "repair": false,
              "outputs": 4,
              "x": 690,
              "y": 460,
              "wires": [
              "d05020b1296929fc"
              "6109976a13173762"
              "7b0b92dc28fd1808"
              "0aaf3b0d4e58724e"
              "id": "d05020b1296929fc",
              "type": "change",
              "name": "SOC 100",
              "rules": [
              "t": "set",
              "p": "payload",
              "pt": "msg",
              "to": "100",
              "tot": "num"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 860,
              "y": 400,
              "wires": [
              "236747505d6180f7",
              "5f11d27a7408ff35",
              "5dc336ee1d2a02da"
              "id": "6109976a13173762",
              "type": "change",
              "name": "SOC 60",
              "rules": [
              "t": "set",
              "p": "payload",
              "pt": "msg",
              "to": "60",
              "tot": "num"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 860,
              "y": 440,
              "wires": [
              "236747505d6180f7",
              "5f11d27a7408ff35",
              "5dc336ee1d2a02da"
              "id": "7b0b92dc28fd1808",
              "type": "change",
              "name": "SOC 40",
              "rules": [
              "t": "set",
              "p": "payload",
              "pt": "msg",
              "to": "40",
              "tot": "num"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 860,
              "y": 480,
              "wires": [
              "236747505d6180f7",
              "5f11d27a7408ff35",
              "5dc336ee1d2a02da"
              "id": "0aaf3b0d4e58724e",
              "type": "change",
              "name": "SOC 20",
              "rules": [
              "t": "set",
              "p": "payload",
              "pt": "msg",
              "to": "20",
              "tot": "num"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 860,
              "y": 520,
              "wires": [
              "236747505d6180f7",
              "5f11d27a7408ff35",
              "5dc336ee1d2a02da"
              "id": "9aecc09bd88aa42a",
              "g": "93511f47e1f57f02",
              "name": "temperature von sensor1",
              "topic": "0_userdata.0.Test.sensor1.temperature",
              "onlyack": "",
              "func": "all",
              "gap": "",
              "fireOnStart": "true",
              "x": 290,
              "y": 140,
              "wires": [
              "5dc336ee1d2a02da"
              "id": "5dc336ee1d2a02da",
              "type": "join",
              "name": "",
              "mode": "custom",
              "build": "object",
              "key": "topic",
              "joiner": "\n",
              "joinerType": "str",
              "accumulate": true,
              "timeout": "",
              "count": "2",
              "reduceRight": false,
              "reduceExp": "",
              "reduceInit": "",
              "reduceInitType": "",
              "reduceFixup": "",
              "x": 590,
              "y": 140,
              "wires": [
              "008ab1d49e4bb116"
              "id": "008ab1d49e4bb116",
              "type": "switch",
              "name": "",
              "property": "payload.'0_userdata/0/Test/sensor1/temperature' >= payload.'0_userdata/0/Test/sensor2/temperature'",
              "rules": [
              "t": "true"
              "t": "false"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 750,
              "y": 140,
              "wires": [
              "b4c362324a598e06",
              "0e44e66f0eb20551"
              "id": "32a2eb3db62922d1",
              "type": "comment",
              "name": "solar forecast lesen",
              "info": "",
              "x": 330,
              "y": 400,
              "wires": []
              "id": "f8f09c0fbe1d0129",
              "type": "comment",
              "name": "daten für den Tag aufbereiten",
              "info": "",
              "x": 540,
              "y": 400,
              "wires": []
              "id": "2560460ee7ece326",
              "type": "comment",
              "name": "Daten jede Stunde lesen",
              "info": "",
              "x": 130,
              "y": 400,
              "wires": []
              "id": "92f7dcf1abe763bc",
              "type": "comment",
              "name": "je nach Leistung SOC für Batterie festlegen",
              "info": "",
              "x": 820,
              "y": 580,
              "wires": []
              "id": "236747505d6180f7",
              "name": "Discharging Cutoff SOC [batUseCap]",
              "topic": "alpha-ess.0.Settings_Discharge.Discharging_Cutoff_SOC",
              "ack": "false",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 1170,
              "y": 400,
              "wires": []
              "id": "5f11d27a7408ff35",
              "type": "ioBroker get",
              "payloadType": "object",
              "errOnInvalidState": "nothing",
              "x": 1170,
              "y": 480,
              "wires": [
              "id": "4036c9e7d228d42d",
              "type": "comment",
              "name": "Wert an IOBroker geben",
              "info": "",
              "x": 1150,
              "y": 580,
              "wires": []
              "id": "280378479ef948d1",
              "type": "comment",
              "name": "vergleichen ob Batterieladung größe als berechneter Wert Ist",
              "info": "",
              "x": 640,
              "y": 220,
              "wires": []
              "id": "55de461857057e67",
              "type": "comment",
              "name": "SOC Wert von Batterie",
              "info": "",
              "x": 280,
              "y": 220,
              "wires": []
              "id": "b4c362324a598e06",
              "ack": "false",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 1110,
              "y": 60,
              "wires": []
              "id": "0e44e66f0eb20551",
              "x": 1110,
              "y": 120,
              "wires": [
              "id": "199bac5fd12314a5",
              "type": "comment",
              "name": "Batterie laden EIN/Aus",
              "info": "",
              "x": 1060,
              "y": 220,
              "wires": []
              • mickymM Offline
                mickymM Offline
                mickym
                Ja ich könnte mir das Anschauen, wenn Du Deinen Flow in ein Code-Tags packst - sowas ist nutzlos !!!
                  Armin 2
                  Ist das so Richtig?
                          "type": "subflow",
                          "info": "This subflow uses the http request node to fetch solar forecasts for geographical positions, using the API from https://forecast.solar/. Please check their website and consider getting a paid account.\n\nDo note that, on a free account, you are limited in the number of requests to do. Also note that the data only gets updated once every 15 minutes, so there is no reason to query more often. There is rate limiting built in the subflow not to perform requests more than once every 15 minutes.\n\n# Configuration\n\nIt uses the parameters as described on: http://doc.forecast.solar/doku.php\n\n - `:apikey` - personal API key for registered users\n - `:lat` - latitude of location, -90 (south) … 90 (north); Internal precission is 0.0001 or abt. 10 m\n - `:lon` - longitude of location, -180 (west) … 180 (east); Internal precission is 0.0001 or abt. 10 m\n - `:dec` - plane declination, 0 (horizontal) … 90 (vertical); Internal precission is integer\n - `:az` - plane azimuth, -180 … 180 (-180 = north, -90 = east, 0 = south, 90 = west, 180 = north); Internal precission is integer\n - `:kwp` - installed modules power in kilo watt peak (kWp)\n\nYou can choose between 3 different type of requests. Note that only `estimate` is available on the free plan.\n\n- `estimate` - this is the forecasted estimate that your panels should produce (given the right parameter settings)\n- `history` - historical data showing the long term averages for the days to come. See [https://joint-research-centre.ec.europa.eu/pvgis-online-tool/pvgis-data-download/cm-saf-solar-radiation_en](https://joint-research-centre.ec.europa.eu/pvgis-online-tool/pvgis-data-download/cm-saf-solar-radiation_en) for where the data is fetched from.\n- `clear sky` - estimate given if there would be a clear sky tomorrow\n\nIn case of estimates, one of the following options can be selected:\n- `watts` - Watts (power) average for the period\n- `watt_hours_period` - Watt hours (energy) for the period\n- `watt_hours` - Watt hours (energy) summarized over the day\n- `watt_hours_day` - Watt hours (energy) summarized for each day\n\nFor the graph output there are some extra settings available:\n\n- _Output in kWh_ - when checked output can be set to kWh instead of Wh\n- _Show todays forecast_ - whether or not to include todays forecast\n- _Days to forecast_ - the number of days to forecast (excluding today). Note that you can not get more days forecasted than your API key allows.\n- _Widen graph_ - widen the graph to only show non-zero values\n\n# Input \n\nThe input is for triggering the solar forecast request. \nIt triggers when injecting a message into the node.\n\n# Output\n\nThere are two outputs. The first output is an object with the result and a status message stored into the `msg.payload`.\n\nMost important is the `msg.payload.result`, which contains the estimated production of the panels. E.g.:\n\n```\npayload: object\n  result: object\n    2022-11-28: 23\n    2022-11-29: 35\n```\n\nThe `msg.payload.message` gives information on how successful the query was, the exitcode of the query and the status of the rate limit (how many queries you have left).\n\nThe **second** output can be directly linked to a line or a bar chart, quickly giving a once-glance overview for the predicted forecast.\n\n# Status\n\nInitially the status of the note will be a blue dot, showing \"_Unknown limit_\", as it is unaware of the set ratelmits. After the first request, the returned ratelimit will be put in the text in the form of `remaining/limit`. If more than half the limit is remaining, the dot will be green. If less then half the limit is remaining, the dot will be yellow. If no limit is left, the dot will turn red.\nPlease keep in mind that the ratelimit will be reset after one hour, so you can send a new request after that hour.\n\nIf something is wrong in the API request, the dot will turn red\nand the message will contain the msg.payload with the error. This\nhappens typically when the API is temporally down for maintenance.",
                          "category": "",
                          "in": [
                                  "x": 240,
                                  "y": 100,
                                  "wires": [
                          "out": [
                                  "x": 760,
                                  "y": 260,
                                  "wires": [
                                          "port": 0
                                          "port": 0
                                  "x": 770,
                                  "y": 340,
                                  "wires": [
                                          "port": 0
                          "env": [
                                  "name": "latitude",
                                  "type": "num",
                                  "value": "51.3",
                                  "ui": {
                                      "type": "input",
                                      "opts": {
                                          "types": [
                                              "num"
                                  "type": "num",
                                  "value": "5.6",
                                  "ui": {
                                      "type": "input",
                                      "opts": {
                                          "types": [
                                              "num"
                                  "type": "num",
                                  "value": "37",
                                  "ui": {
                                      "type": "input",
                                      "opts": {
                                          "types": [
                                              "num"
                                  "name": "azimuth",
                                  "type": "num",
                                  "value": "0",
                                  "ui": {
                                      "type": "spinner",
                                      "opts": {
                                          "min": -180,
                                          "max": 180
                                  "type": "num",
                                  "value": "1",
                                  "ui": {
                                      "type": "input",
                                      "opts": {
                                          "types": [
                                              "num"
                                  "name": "apikey",
                                  "type": "cred",
                                  "ui": {
                                      "type": "input",
                                      "opts": {
                                          "types": [
                                              "cred"
                                  "name": "type",
                                  "type": "str",
                                  "ui": {
                                      "label": {
                                          "en-US": "type"
                                      "type": "select",
                                      "opts": {
                                          "opts": [
                                                  "l": {
                                                      "en-US": "Estimate"
                                                  "v": "estimate"
                                                  "l": {
                                                      "en-US": "History"
                                                  "v": "history"
                                                  "l": {
                                                  "v": "clearsky"
                                  "name": "watt",
                                  "type": "str",
                                  "value": "watts",
                                  "ui": {
                                      "type": "select",
                                      "opts": {
                                          "opts": [
                                                  "l": {
                                                  "v": "watts"
                                                  "l": {
                                                  "l": {
                                                  "v": "watt_hours"
                                                  "l": {
                                  "type": "bool",
                                  "value": "false",
                                  "ui": {
                                      "label": {
                                      "type": "checkbox"
                                  "type": "bool",
                                  "value": "true",
                                  "ui": {
                                      "label": {
                                      "type": "checkbox"
                                  "type": "str",
                                  "value": "-1",
                                  "ui": {
                                      "label": {
                                      "type": "select",
                                      "opts": {
                                          "opts": [
                                                  "l": {
                                                      "en-US": "Max"
                                                  "v": "-1"
                                                  "l": {
                                                      "en-US": "0"
                                                  "v": "0"
                                                  "l": {
                                                      "en-US": "1"
                                                  "v": "1"
                                                  "l": {
                                                      "en-US": "2"
                                                  "v": "2"
                                                  "l": {
                                                      "en-US": "3"
                                                  "v": "3"
                                                  "l": {
                                                      "en-US": "4"
                                                  "v": "4"
                                                  "l": {
                                                      "en-US": "5"
                                                  "v": "5"
                                                  "l": {
                                                      "en-US": "6"
                                                  "v": "6"
                                  "type": "bool",
                                  "value": "true",
                                  "ui": {
                                      "label": {
                                      "type": "checkbox"
                          "meta": {
                              "version": "0.0.9",
                          "color": "#FFCC66",
                          "inputLabels": [
                              "trigger"
                          "outputLabels": [
                              "output",
                              "graph"
                          "status": {
                              "x": 680,
                              "y": 560,
                              "wires": [
                                      "port": 0
                                      "port": 0
                          "name": "",
                          "method": "GET",
                          "ret": "txt",
                          "url": "",
                          "tls": "",
                          "persist": false,
                          "proxy": "",
                          "authType": "",
                          "senderr": false,
                          "headers": [],
                          "x": 390,
                          "y": 180,
                          "wires": [
                                  "1b5ccaa05d54f7c3"
                          "type": "function",
                          "outputs": 1,
                          "timeout": "",
                          "noerr": 0,
                          "initialize": "",
                          "finalize": "",
                          "libs": [],
                          "x": 630,
                          "y": 100,
                          "wires": [
                                  "975daf96f15cfb61"
                          "type": "json",
                          "action": "",
                          "pretty": false,
                          "x": 680,
                          "y": 180,
                          "wires": [
                                  "e718a22973cc2864"
                          "type": "function",
                          "outputs": 1,
                          "noerr": 0,
                          "initialize": "",
                          "finalize": "",
                          "libs": [],
                          "x": 520,
                          "y": 480,
                          "wires": [
                                  "e56826252134b93a"
                          "type": "link out",
                          "mode": "link",
                          "links": [
                              "3fa24f2d08195961",
                              "0a20e852662c8cec"
                          "x": 815,
                          "y": 180,
                          "wires": []
                          "type": "link in",
                          "links": [
                              "e718a22973cc2864"
                          "x": 385,
                          "y": 480,
                          "wires": [
                                  "559391d1288f762a"
                          "type": "link in",
                          "links": [
                              "e718a22973cc2864"
                          "x": 225,
                          "y": 260,
                          "wires": [
                                  "fcc8d69a3ab88e6d"
                          "type": "inject",
                          "name": "",
                          "props": [
                                  "p": "payload"
                                  "p": "topic",
                                  "vt": "str"
                          "repeat": "",
                          "crontab": "",
                          "once": true,
                          "onceDelay": 0.1,
                          "topic": "",
                          "payload": "",
                          "x": 530,
                          "y": 440,
                          "wires": [
                                  "e56826252134b93a"
                          "type": "function",
                          "func": "var remaining = flow.get('forecast.solar.ratelimit.remaining') || -1;\nvar limit = flow.get('forecast.solar.ratelimit.limit') || -1\n\nvar text = remaining.toString() + '/' + limit.toString();\nvar fill = \"green\";\n\nif (remaining == 0) {\n    fill = \"red\";\n    text = \"Limit used\";\n}\n\nif (remaining > 0 && remaining < limit / 2) {\n    fill = \"yellow\"\n}\n\nif (remaining == -1 ) {\n    fill = \"blue\"\n    text = \"Limits unknown\"\n}\n\nmsg.payload = ({ fill: fill, text: text });\n\nreturn msg;",
                          "outputs": 1,
                          "noerr": 0,
                          "initialize": "",
                          "finalize": "",
                          "libs": [],
                          "x": 520,
                          "y": 580,
                          "wires": [
                          "type": "function",
                          "func": "var m = {};\nm.labels = [];\nm.data = [];\n\nm.series = [];\nm.data = [];\nm.labels = [];\n\nfor (let j = 0; j <= msg.days; j++) {\n    m.data[j] = [];\n}\n\nif (msg.watt === 'watt_hours_day') {\n    var i = 0;\n    m.series.push(\"Watt hours per day\");\n    for (const key in msg.payload.result) {\n        m.labels.push(key);\n        if (msg.kwhoutput) {\n            m.data[i] = +(Math.round(msg.payload.result[key]/100)*.1).toFixed(1);\n        } else {\n            m.data[i] = msg.payload.result[key];\n        }\n        i++;\n    }\n    m.data = [m.data];\n    return { payload: [m] };\n}\n\nfor (let i = 0; i <= 23; i++) {\n\n    m.labels.push(i.toString()+':00');\n    if (msg.resolution === 4) {\n       m.labels.push(i.toString()+':15');\n    }\n    if (msg.resolution === 2 || msg.resolution == 4) {\n       m.labels.push(i.toString()+':30');\n    }\n    if (msg.resolution === 4) {\n       m.labels.push(i.toString()+':45');\n    }\n\n    for (let j = 0; j <= msg.days; j++) {\n        m.data[j].push(0);\n        if (msg.resolution === 4) {\n           m.data[j].push(0)\n        }\n        if (msg.resolution === 2 || msg.resolution == 4) {\n           m.data[j].push(0)\n        }\n        if (msg.resolution === 4) {\n           m.data[j].push(0)\n        }\n\n    }\n}\n\nvar offset = 0;\nfor (const key in msg.payload.result) {\n    var d = new Date(key)\n    if (m.series.indexOf(d.toISOString().split('T')[0]) === -1) {\n        m.series.push(d.toISOString().split('T')[0])\n    }\n\n    var h = d.getHours();\n    var minutes = d.getMinutes();\n\n    if (minutes === 0 ) {\n        offset = 0;\n    } else {\n        offset++;\n    }\n\n    if (msg.kwhoutput) {\n        m.data[m.series.length - 1][h*msg.resolution+offset] = +(Math.round(msg.payload.result[key]/100)*.1).toFixed(1);\n    } else {\n        m.data[m.series.length - 1][h*msg.resolution+offset] = msg.payload.result[key];\n    }\n}\n\nreturn { payload: [m] };\n",
                          "outputs": 1,
                          "noerr": 0,
                          "initialize": "",
                          "finalize": "",
                          "libs": [],
                          "x": 360,
                          "y": 340,
                          "wires": [
                                  "5b0a430fb61e70e7"
                          "type": "link out",
                          "mode": "link",
                          "links": [
                              "14f2e68e572f4ef8"
                          "x": 805,
                          "y": 100,
                          "wires": []
                          "type": "link in",
                          "links": [
                              "975daf96f15cfb61"
                          "x": 245,
                          "y": 180,
                          "wires": [
                                  "c706820c0d61f023"
                          "type": "catch",
                          "name": "",
                          "scope": null,
                          "uncaught": false,
                          "x": 260,
                          "y": 440,
                          "wires": [
                                  "f427f19392c399ce"
                          "type": "link out",
                          "mode": "link",
                          "links": [
                              "dbaf8f5f5a920686"
                          "x": 685,
                          "y": 480,
                          "wires": []
                          "type": "link in",
                          "links": [
                              "e56826252134b93a"
                          "x": 385,
                          "y": 580,
                          "wires": [
                                  "1bfc1cde3ee94e4b"
                          "type": "link out",
                          "mode": "link",
                          "links": [
                              "2ded0c14a222b4d9",
                              "2f42837904c91d73"
                          "x": 375,
                          "y": 440,
                          "wires": []
                          "type": "link in",
                          "links": [
                              "f427f19392c399ce"
                          "x": 385,
                          "y": 540,
                          "wires": [
                                  "a798fbe66cf133d5"
                          "type": "function",
                          "func": "node.warn(msg.payload)\nmsg.payload = ({ fill: \"red\", text: msg.payload });\n\nreturn msg;",
                          "outputs": 1,
                          "noerr": 0,
                          "initialize": "",
                          "finalize": "",
                          "libs": [],
                          "x": 520,
                          "y": 540,
                          "wires": [
                          "type": "link in",
                          "links": [
                              "f427f19392c399ce"
                          "x": 665,
                          "y": 280,
                          "wires": [
                          "type": "function",
                          "outputs": 1,
                          "noerr": 0,
                          "initialize": "",
                          "finalize": "",
                          "libs": [],
                          "x": 360,
                          "y": 260,
                          "wires": [
                                  "a18e96179ec2d987"
                          "info": "Function to process the result from forecast.solar to add\nextra information, which is handy for either graphing or\nto store in a database.\n\n\nThe extra values added:\n- `msg.resolution` - The number of measurements per hour. If\nno API key is used, this will be 1. Other values may be 2 or 4.\n- `msg.days` - The number of days in the forcast. If no API\n- key is used this will be 1. Other values may be 3 or 6."
                          "type": "function",
                          "func": "var forecasted = msg.payload[0].series.length;\n\nif ((env.get('daystoforecast') > -1) && (env.get('daystoforecast') < forecasted)) {\n    for (i = 1; i < (forecasted - env.get('daystoforecast')); i++ ) {\n        msg.payload[0].data.pop();\n        msg.payload[0].series.pop();\n    }\n}\n\nif (env.get('watt') === 'watt_hours_day' ) {\n    forecasted = msg.payload[0].labels.length;\n    for (i = 1; i < (forecasted - env.get('daystoforecast')); i++ ) {\n        msg.payload[0].labels.pop();\n        msg.payload[0].data[0].pop();\n    }\n}\n\nif (!env.get('showtoday')) {\n    msg.payload[0].data.shift();\n    msg.payload[0].series.shift();\n}\n\nif (env.get('widengraph')) {\n    var c = msg.payload[0].labels.length;\n    var x = 0;\n    for (i = 0; i < c; i++) {\n        var remove = true;\n        for (d = 0; d < msg.payload[0].data.length; d++) {\n            if (msg.payload[0].data[d][x] > 0) {\n                remove = false;\n            }\n        }\n        if (remove) {\n            msg.payload[0].labels.splice(x, 1);\n            for (d = 0; d < msg.payload[0].data.length; d++) {\n                 msg.payload[0].data[d].splice(x, 1);\n            }\n            x--;\n        }\n        x++;\n    }\n    // Still the first and last datapoints should be zero, so\n    // add those again\n    msg.payload[0].labels.unshift('');\n    msg.payload[0].labels.push('');\n    for (d = 0; d < msg.payload[0].data.length; d++) {\n         msg.payload[0].data[d].unshift(0);\n         msg.payload[0].data[d].push(0);\n    }   \n}\n\nreturn msg;",
                          "outputs": 1,
                          "noerr": 0,
                          "initialize": "",
                          "finalize": "",
                          "libs": [],
                          "x": 590,
                          "y": 340,
                          "wires": [
                          "type": "delay",
                          "timeout": "5",
                          "rate": "5",
                          "randomFirst": "1",
                          "randomLast": "5",
                          "drop": false,
                          "allowrate": false,
                          "outputs": 1,
                          "x": 390,
                          "y": 100,
                          "wires": [
                                  "b9488734852cd0ca"
                          "type": "tab",
                          "label": "an foren",
                          "disabled": false,
                          "info": "",
                          "env": []
                          "type": "group",
                          "style": {
                              "fill": "#d1d1d1",
                              "label": true,
                              "color": "#000000"
                          "nodes": [
                              "9aecc09bd88aa42a",
                              "5dc336ee1d2a02da",
                              "008ab1d49e4bb116"
                          "x": 154,
                          "y": 99,
                          "w": 672,
                          "h": 82
                          "type": "inject",
                          "name": "",
                          "props": [
                                  "p": "payload"
                                  "p": "topic",
                                  "vt": "str"
                          "repeat": "",
                          "crontab": "",
                          "once": false,
                          "onceDelay": 0.1,
                          "topic": "",
                          "payload": "",
                          "x": 120,
                          "y": 460,
                          "wires": [
                                  "206c8fbe5daa2c1e"
                          "name": "Süd",
                          "env": [
                                  "name": "latitude",
                                  "type": "num"
                                  "type": "num"
                                  "value": "40",
                                  "type": "num"
                                  "name": "azimuth",
                                  "value": "182",
                                  "type": "num"
                                  "value": "9",
                                  "type": "num"
                                  "name": "apikey",
                                  "type": "cred"
                                  "name": "watt",
                                  "type": "str"
                                  "type": "bool",
                                  "value": "false"
                                  "value": "1",
                                  "type": "str"
                                  "type": "bool",
                                  "value": "false"
                          "x": 310,
                          "y": 460,
                          "wires": [
                                  "57dc8d4b5bbeaa7f"
                          "type": "function",
                          "func": "var pvf = msg.payload;\nvar date = moment().tz(\"Europe/Berlin\");\nvar today = date.format('YYYY-MM-DD');\nvar hourEntries = Object.keys(pvf.result);\nvar todaysEntries = hourEntries.filter(x => x.startsWith(today));\nvar expectedEarning = pvf.result[todaysEntries[todaysEntries.length -1]];\nmsg.payload = expectedEarning;\nreturn msg;",
                          "outputs": 1,
                          "timeout": "",
                          "noerr": 0,
                          "initialize": "",
                          "finalize": "",
                          "libs": [
                                  "var": "moment",
                                  "module": "moment"
                          "x": 530,
                          "y": 460,
                          "wires": [
                                  "15b38fae77d09de8"
                          "type": "switch",
                          "name": "",
                          "rules": [
                                  "t": "lt",
                                  "v": "2000",
                                  "vt": "str"
                                  "t": "btwn",
                                  "v": "2000",
                                  "vt": "num",
                                  "v2": "5000",
                                  "v2t": "num"
                                  "t": "btwn",
                                  "v": "5000",
                                  "vt": "num",
                                  "v2": "8000",
                                  "v2t": "num"
                                  "t": "gt",
                                  "v": "8000",
                                  "vt": "str"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 4,
                          "x": 690,
                          "y": 460,
                          "wires": [
                                  "d05020b1296929fc"
                                  "6109976a13173762"
                                  "7b0b92dc28fd1808"
                                  "0aaf3b0d4e58724e"
                          "type": "change",
                          "name": "SOC 100",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "100",
                                  "tot": "num"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 860,
                          "y": 400,
                          "wires": [
                                  "236747505d6180f7",
                                  "5f11d27a7408ff35",
                                  "5dc336ee1d2a02da"
                          "type": "change",
                          "name": "SOC 60",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "60",
                                  "tot": "num"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 860,
                          "y": 440,
                          "wires": [
                                  "236747505d6180f7",
                                  "5f11d27a7408ff35",
                                  "5dc336ee1d2a02da"
                          "type": "change",
                          "name": "SOC 40",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "40",
                                  "tot": "num"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 860,
                          "y": 480,
                          "wires": [
                                  "236747505d6180f7",
                                  "5f11d27a7408ff35",
                                  "5dc336ee1d2a02da"
                          "type": "change",
                          "name": "SOC 20",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "20",
                                  "tot": "num"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 860,
                          "y": 520,
                          "wires": [
                                  "236747505d6180f7",
                                  "5f11d27a7408ff35",
                                  "5dc336ee1d2a02da"
                          "onlyack": "",
                          "func": "all",
                          "gap": "",
                          "x": 290,
                          "y": 140,
                          "wires": [
                                  "5dc336ee1d2a02da"
                          "type": "join",
                          "name": "",
                          "mode": "custom",
                          "build": "object",
                          "key": "topic",
                          "joiner": "\\n",
                          "accumulate": true,
                          "timeout": "",
                          "count": "2",
                          "reduceExp": "",
                          "reduceInit": "",
                          "reduceFixup": "",
                          "x": 590,
                          "y": 140,
                          "wires": [
                                  "008ab1d49e4bb116"
                          "type": "switch",
                          "name": "",
                          "rules": [
                                  "t": "true"
                                  "t": "false"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 2,
                          "x": 750,
                          "y": 140,
                          "wires": [
                                  "b4c362324a598e06",
                                  "0e44e66f0eb20551"
                          "type": "comment",
                          "info": "",
                          "x": 330,
                          "y": 400,
                          "wires": []
                          "type": "comment",
                          "info": "",
                          "x": 540,
                          "y": 400,
                          "wires": []
                          "type": "comment",
                          "info": "",
                          "x": 130,
                          "y": 400,
                          "wires": []
                          "type": "comment",
                          "info": "",
                          "x": 820,
                          "y": 580,
                          "wires": []
                          "ack": "false",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 1170,
                          "y": 400,
                          "wires": []
                          "x": 1170,
                          "y": 480,
                          "wires": [
                          "type": "comment",
                          "info": "",
                          "x": 1150,
                          "y": 580,
                          "wires": []
                          "type": "comment",
                          "info": "",
                          "x": 640,
                          "y": 220,
                          "wires": []
                          "type": "comment",
                          "info": "",
                          "x": 280,
                          "y": 220,
                          "wires": []
                          "ack": "false",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 1110,
                          "y": 60,
                          "wires": []
                          "x": 1110,
                          "y": 120,
                          "wires": [
                          "type": "comment",
                          "info": "",
                          "x": 1060,
                          "y": 220,
                          "wires": []
                  • mickymM Offline
                    mickymM Offline
                    mickym
                    Ja jetzt kann ich damit was anfangen.
                    • mickymM Offline
                      mickymM Offline
                      mickym
                      So ich habs mal so geändert wie ich es für sinnvoll halte - was Deine getNodes da sollen weiß ich nicht. Du kannst die Debug node (check) bei Bedarf auch aktivieren, um die Werte zu sehen:
                      Hier zum Import:
                             "id": "9ff1adc1f1d7f345",
                             "type": "group",
                             "name": "Batterie laden",
                             "style": {
                                 "fill": "#e3f3d3",
                                 "label": true
                             "nodes": [
                                 "9aecc09bd88aa42a",
                                 "5dc336ee1d2a02da",
                                 "008ab1d49e4bb116",
                                 "280378479ef948d1",
                                 "55de461857057e67",
                                 "b4c362324a598e06",
                                 "199bac5fd12314a5",
                                 "a0eb0619db94c4eb",
                                 "d9b7d0cba2770204",
                                 "9007e4e2286d3099",
                                 "d5fdbbd7c183f956"
                             "x": 54,
                             "y": 39,
                             "w": 1412,
                             "h": 202
                             "g": "9ff1adc1f1d7f345",
                             "name": "SOC von Batterie",
                             "onlyack": "",
                             "func": "all",
                             "gap": "",
                             "x": 160,
                             "y": 120,
                             "wires": [
                                     "a0eb0619db94c4eb"
                             "type": "join",
                             "name": "",
                             "mode": "custom",
                             "build": "object",
                             "key": "topic",
                             "joiner": "\\n",
                             "accumulate": true,
                             "timeout": "",
                             "count": "2",
                             "reduceExp": "",
                             "reduceInit": "",
                             "reduceFixup": "",
                             "x": 590,
                             "y": 120,
                             "wires": [
                                     "008ab1d49e4bb116",
                                     "d9b7d0cba2770204"
                             "type": "switch",
                             "name": "",
                             "rules": [
                                     "t": "jsonata_exp",
                                     "v": "payload.batterie < payload.soll",
                                     "vt": "jsonata"
                                     "t": "jsonata_exp",
                                     "v": "payload.batterie >= payload.soll",
                                     "vt": "jsonata"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 2,
                             "x": 750,
                             "y": 120,
                             "wires": [
                                     "9007e4e2286d3099"
                                     "d5fdbbd7c183f956"
                             "type": "comment",
                             "info": "",
                             "x": 600,
                             "y": 200,
                             "wires": []
                             "type": "comment",
                             "info": "",
                             "x": 240,
                             "y": 200,
                             "wires": []
                             "ack": "false",
                             "stateName": "",
                             "role": "",
                             "payloadType": "",
                             "readonly": "",
                             "stateUnit": "",
                             "stateMin": "",
                             "stateMax": "",
                             "x": 1290,
                             "y": 120,
                             "wires": []
                             "type": "comment",
                             "info": "",
                             "x": 1060,
                             "y": 200,
                             "wires": []
                             "id": "a0eb0619db94c4eb",
                             "type": "change",
                             "name": "topic = batterie",
                             "rules": [
                                     "t": "set",
                                     "p": "topic",
                                     "pt": "msg",
                                     "to": "batterie",
                                     "tot": "str"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 380,
                             "y": 120,
                             "wires": [
                                     "5dc336ee1d2a02da"
                             "id": "d9b7d0cba2770204",
                             "type": "debug",
                             "name": "check",
                             "active": false,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 750,
                             "y": 80,
                             "wires": []
                             "id": "9007e4e2286d3099",
                             "type": "change",
                             "name": "Enable battery charge",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "true",
                                     "tot": "bool"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 980,
                             "y": 100,
                             "wires": [
                                     "b4c362324a598e06"
                             "id": "d5fdbbd7c183f956",
                             "type": "change",
                             "name": "Disable battery charge",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "false",
                                     "tot": "bool"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 980,
                             "y": 140,
                             "wires": [
                                     "b4c362324a598e06"
                             "id": "d7e7bb5a646b4ae4",
                             "type": "group",
                             "name": "Batterie SOC festlegen",
                             "style": {
                                 "fill": "#ffffbf",
                                 "label": true
                             "nodes": [
                                 "47a4cf54866c5a93",
                                 "206c8fbe5daa2c1e",
                                 "57dc8d4b5bbeaa7f",
                                 "15b38fae77d09de8",
                                 "d05020b1296929fc",
                                 "6109976a13173762",
                                 "7b0b92dc28fd1808",
                                 "0aaf3b0d4e58724e",
                                 "32a2eb3db62922d1",
                                 "f8f09c0fbe1d0129",
                                 "2560460ee7ece326",
                                 "92f7dcf1abe763bc",
                                 "236747505d6180f7",
                                 "4036c9e7d228d42d",
                                 "c1bbed615c6ed975",
                                 "5a7dd1be9fc513dc"
                             "x": 54,
                             "y": 359,
                             "w": 1412,
                             "h": 262
                             "type": "subflow",
                             "category": "",
                             "in": [
                                     "x": 240,
                                     "y": 100,
                                     "wires": [
                             "out": [
                                     "x": 760,
                                     "y": 260,
                                     "wires": [
                                             "port": 0
                                             "port": 0
                                     "x": 770,
                                     "y": 340,
                                     "wires": [
                                             "port": 0
                             "env": [
                                     "name": "latitude",
                                     "type": "num",
                                     "value": "51.3",
                                     "ui": {
                                         "type": "input",
                                         "opts": {
                                             "types": [
                                                 "num"
                                     "type": "num",
                                     "value": "5.6",
                                     "ui": {
                                         "type": "input",
                                         "opts": {
                                             "types": [
                                                 "num"
                                     "type": "num",
                                     "value": "37",
                                     "ui": {
                                         "type": "input",
                                         "opts": {
                                             "types": [
                                                 "num"
                                     "name": "azimuth",
                                     "type": "num",
                                     "value": "0",
                                     "ui": {
                                         "type": "spinner",
                                         "opts": {
                                             "min": -180,
                                             "max": 180
                                     "type": "num",
                                     "value": "1",
                                     "ui": {
                                         "type": "input",
                                         "opts": {
                                             "types": [
                                                 "num"
                                     "name": "apikey",
                                     "type": "cred",
                                     "ui": {
                                         "type": "input",
                                         "opts": {
                                             "types": [
                                                 "cred"
                                     "name": "type",
                                     "type": "str",
                                     "ui": {
                                         "label": {
                                             "en-US": "type"
                                         "type": "select",
                                         "opts": {
                                             "opts": [
                                                     "l": {
                                                         "en-US": "Estimate"
                                                     "v": "estimate"
                                                     "l": {
                                                         "en-US": "History"
                                                     "v": "history"
                                                     "l": {
                                                     "v": "clearsky"
                                     "name": "watt",
                                     "type": "str",
                                     "value": "watts",
                                     "ui": {
                                         "type": "select",
                                         "opts": {
                                             "opts": [
                                                     "l": {
                                                     "v": "watts"
                                                     "l": {
                                                     "l": {
                                                     "v": "watt_hours"
                                                     "l": {
                                     "type": "bool",
                                     "value": "false",
                                     "ui": {
                                         "label": {
                                         "type": "checkbox"
                                     "type": "bool",
                                     "value": "true",
                                     "ui": {
                                         "label": {
                                         "type": "checkbox"
                                     "type": "str",
                                     "value": "-1",
                                     "ui": {
                                         "label": {
                                         "type": "select",
                                         "opts": {
                                             "opts": [
                                                     "l": {
                                                         "en-US": "Max"
                                                     "v": "-1"
                                                     "l": {
                                                         "en-US": "0"
                                                     "v": "0"
                                                     "l": {
                                                         "en-US": "1"
                                                     "v": "1"
                                                     "l": {
                                                         "en-US": "2"
                                                     "v": "2"
                                                     "l": {
                                                         "en-US": "3"
                                                     "v": "3"
                                                     "l": {
                                                         "en-US": "4"
                                                     "v": "4"
                                                     "l": {
                                                         "en-US": "5"
                                                     "v": "5"
                                                     "l": {
                                                         "en-US": "6"
                                                     "v": "6"
                                     "type": "bool",
                                     "value": "true",
                                     "ui": {
                                         "label": {
                                         "type": "checkbox"
                             "meta": {
                                 "version": "0.0.9",
                             "color": "#FFCC66",
                             "inputLabels": [
                                 "trigger"
                             "outputLabels": [
                                 "output",
                                 "graph"
                             "status": {
                                 "x": 680,
                                 "y": 560,
                                 "wires": [
                                         "port": 0
                                         "port": 0
                             "name": "",
                             "method": "GET",
                             "ret": "txt",
                             "url": "",
                             "tls": "",
                             "persist": false,
                             "proxy": "",
                             "authType": "",
                             "senderr": false,
                             "headers": [],
                             "x": 390,
                             "y": 180,
                             "wires": [
                                     "1b5ccaa05d54f7c3"
                             "type": "function",
                             "outputs": 1,
                             "timeout": "",
                             "noerr": 0,
                             "initialize": "",
                             "finalize": "",
                             "libs": [],
                             "x": 630,
                             "y": 100,
                             "wires": [
                                     "975daf96f15cfb61"
                             "type": "json",
                             "action": "",
                             "pretty": false,
                             "x": 680,
                             "y": 180,
                             "wires": [
                                     "e718a22973cc2864"
                             "type": "function",
                             "outputs": 1,
                             "noerr": 0,
                             "initialize": "",
                             "finalize": "",
                             "libs": [],
                             "x": 520,
                             "y": 480,
                             "wires": [
                                     "e56826252134b93a"
                             "type": "link out",
                             "mode": "link",
                             "links": [
                                 "3fa24f2d08195961",
                                 "0a20e852662c8cec"
                             "x": 815,
                             "y": 180,
                             "wires": []
                             "type": "link in",
                             "links": [
                                 "e718a22973cc2864"
                             "x": 385,
                             "y": 480,
                             "wires": [
                                     "559391d1288f762a"
                             "type": "link in",
                             "links": [
                                 "e718a22973cc2864"
                             "x": 225,
                             "y": 260,
                             "wires": [
                                     "fcc8d69a3ab88e6d"
                             "type": "inject",
                             "name": "",
                             "props": [
                                     "p": "payload"
                                     "p": "topic",
                                     "vt": "str"
                             "repeat": "",
                             "crontab": "",
                             "once": true,
                             "onceDelay": 0.1,
                             "topic": "",
                             "payload": "",
                             "x": 530,
                             "y": 440,
                             "wires": [
                                     "e56826252134b93a"
                             "type": "function",
                             "outputs": 1,
                             "noerr": 0,
                             "initialize": "",
                             "finalize": "",
                             "libs": [],
                             "x": 520,
                             "y": 580,
                             "wires": [
                             "type": "function",
                             "outputs": 1,
                             "noerr": 0,
                             "initialize": "",
                             "finalize": "",
                             "libs": [],
                             "x": 360,
                             "y": 340,
                             "wires": [
                                     "5b0a430fb61e70e7"
                             "type": "link out",
                             "mode": "link",
                             "links": [
                                 "14f2e68e572f4ef8"
                             "x": 805,
                             "y": 100,
                             "wires": []
                             "type": "link in",
                             "links": [
                                 "975daf96f15cfb61"
                             "x": 245,
                             "y": 180,
                             "wires": [
                                     "c706820c0d61f023"
                             "type": "catch",
                             "name": "",
                             "scope": null,
                             "uncaught": false,
                             "x": 260,
                             "y": 440,
                             "wires": [
                                     "f427f19392c399ce"
                             "type": "link out",
                             "mode": "link",
                             "links": [
                                 "dbaf8f5f5a920686"
                             "x": 685,
                             "y": 480,
                             "wires": []
                             "type": "link in",
                             "links": [
                                 "e56826252134b93a"
                             "x": 385,
                             "y": 580,
                             "wires": [
                                     "1bfc1cde3ee94e4b"
                             "type": "link out",
                             "mode": "link",
                             "links": [
                                 "2ded0c14a222b4d9",
                                 "2f42837904c91d73"
                             "x": 375,
                             "y": 440,
                             "wires": []
                             "type": "link in",
                             "links": [
                                 "f427f19392c399ce"
                             "x": 385,
                             "y": 540,
                             "wires": [
                                     "a798fbe66cf133d5"
                             "type": "function",
                             "outputs": 1,
                             "noerr": 0,
                             "initialize": "",
                             "finalize": "",
                             "libs": [],
                             "x": 520,
                             "y": 540,
                             "wires": [
                             "type": "link in",
                             "links": [
                                 "f427f19392c399ce"
                             "x": 665,
                             "y": 280,
                             "wires": [
                             "type": "function",
                             "outputs": 1,
                             "noerr": 0,
                             "initialize": "",
                             "finalize": "",
                             "libs": [],
                             "x": 360,
                             "y": 260,
                             "wires": [
                                     "a18e96179ec2d987"
                             "type": "function",
                             "outputs": 1,
                             "noerr": 0,
                             "initialize": "",
                             "finalize": "",
                             "libs": [],
                             "x": 590,
                             "y": 340,
                             "wires": [
                             "type": "delay",
                             "timeout": "5",
                             "rate": "5",
                             "randomFirst": "1",
                             "randomLast": "5",
                             "drop": false,
                             "allowrate": false,
                             "outputs": 1,
                             "x": 390,
                             "y": 100,
                             "wires": [
                                     "b9488734852cd0ca"
                             "type": "inject",
                             "g": "d7e7bb5a646b4ae4",
                             "name": "",
                             "props": [
                                     "p": "payload"
                                     "p": "topic",
                                     "vt": "str"
                             "repeat": "",
                             "crontab": "",
                             "once": false,
                             "onceDelay": 0.1,
                             "topic": "",
                             "payload": "",
                             "x": 180,
                             "y": 460,
                             "wires": [
                                     "206c8fbe5daa2c1e"
                             "name": "Süd",
                             "env": [
                                     "name": "latitude",
                                     "type": "num"
                                     "type": "num"
                                     "value": "40",
                                     "type": "num"
                                     "name": "azimuth",
                                     "value": "182",
                                     "type": "num"
                                     "value": "9",
                                     "type": "num"
                                     "name": "apikey",
                                     "type": "cred"
                                     "name": "watt",
                                     "type": "str"
                                     "type": "bool",
                                     "value": "false"
                                     "value": "1",
                                     "type": "str"
                                     "type": "bool",
                                     "value": "false"
                             "x": 370,
                             "y": 460,
                             "wires": [
                                     "57dc8d4b5bbeaa7f"
                             "type": "function",
                             "outputs": 1,
                             "timeout": "",
                             "noerr": 0,
                             "initialize": "",
                             "finalize": "",
                             "libs": [
                                     "var": "moment",
                                     "module": "moment"
                             "x": 590,
                             "y": 460,
                             "wires": [
                                     "15b38fae77d09de8"
                             "type": "switch",
                             "name": "",
                             "rules": [
                                     "t": "lt",
                                     "v": "2000",
                                     "vt": "str"
                                     "t": "btwn",
                                     "v": "2000",
                                     "vt": "num",
                                     "v2": "5000",
                                     "v2t": "num"
                                     "t": "btwn",
                                     "v": "5000",
                                     "vt": "num",
                                     "v2": "8000",
                                     "v2t": "num"
                                     "t": "gt",
                                     "v": "8000",
                                     "vt": "str"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 4,
                             "x": 750,
                             "y": 460,
                             "wires": [
                                     "d05020b1296929fc"
                                     "6109976a13173762"
                                     "7b0b92dc28fd1808"
                                     "0aaf3b0d4e58724e"
                             "type": "change",
                             "name": "SOC 100",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "100",
                                     "tot": "num"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 920,
                             "y": 400,
                             "wires": [
                                     "5a7dd1be9fc513dc"
                             "type": "change",
                             "name": "SOC 60",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "60",
                                     "tot": "num"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 920,
                             "y": 440,
                             "wires": [
                                     "5a7dd1be9fc513dc"
                             "type": "change",
                             "name": "SOC 40",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "40",
                                     "tot": "num"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 920,
                             "y": 480,
                             "wires": [
                                     "5a7dd1be9fc513dc"
                             "type": "change",
                             "name": "SOC 20",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "20",
                                     "tot": "num"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 920,
                             "y": 520,
                             "wires": [
                                     "5a7dd1be9fc513dc"
                             "type": "comment",
                             "info": "",
                             "x": 390,
                             "y": 400,
                             "wires": []
                             "type": "comment",
                             "info": "",
                             "x": 600,
                             "y": 400,
                             "wires": []
                             "type": "comment",
                             "info": "",
                             "x": 190,
                             "y": 400,
                             "wires": []
                             "type": "comment",
                             "info": "",
                             "x": 880,
                             "y": 580,
                             "wires": []
                             "ack": "false",
                             "stateName": "",
                             "role": "",
                             "payloadType": "",
                             "readonly": "",
                             "stateUnit": "",
                             "stateMin": "",
                             "stateMax": "",
                             "x": 1290,
                             "y": 460,
                             "wires": []
                             "type": "comment",
                             "info": "",
                             "x": 1210,
                             "y": 580,
                             "wires": []
                             "id": "c1bbed615c6ed975",
                             "type": "change",
                             "name": "topic = soll",
                             "rules": [
                                     "t": "set",
                                     "p": "topic",
                                     "pt": "msg",
                                     "to": "soll",
                                     "tot": "str"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 1170,
                             "y": 400,
                             "wires": [
                                     "5dc336ee1d2a02da"
                             "id": "5a7dd1be9fc513dc",
                             "type": "junction",
                             "x": 1060,
                             "y": 460,
                             "wires": [
                                     "c1bbed615c6ed975",
                                     "236747505d6180f7"
                      Im Übrigen, WENN das so klappt - warum postest Du eigentlich nicht von Anfang an Deinen Flow und wir mühen uns ab, weil wir nicht wissen, was Du machen willst?
                        Armin 2
                        Vielen Dank , So klappt es.
                        Ich bin neue hier, und wusste nicht genau was Ihr braucht.
                        Bei der nächsten Frage klappt es hoffentlich besser.
                        Aber jetzt haben wir es ja.
                        Das zweite Schreiben an den IOBroker, ist zum Setzen des Bestätigung Bits auf true.
                        Sonst wird der Wert nicht verschickt.
                        Nochmal vielen Dank, wieder viel dazu gelernt.
                        Armin
                        • A Armin 2
                          Armin
                          Armin 2
                          @armin-2
                          Hallo hier doch nochmal eine Frage, welcher Fehler ist in dem Teil Werte addieren, den ich dazwichen geschoben habe?
                          Ich habe drei verschiedene Solarausrichtungen.
                                  "type": "subflow",
                                  "category": "",
                                  "in": [
                                          "x": 240,
                                          "y": 100,
                                          "wires": [
                                  "out": [
                                          "x": 760,
                                          "y": 260,
                                          "wires": [
                                                  "port": 0
                                                  "port": 0
                                          "x": 770,
                                          "y": 340,
                                          "wires": [
                                                  "port": 0
                                  "env": [
                                          "name": "latitude",
                                          "type": "num",
                                          "value": "51.3",
                                          "ui": {
                                              "type": "input",
                                              "opts": {
                                                  "types": [
                                                      "num"
                                          "type": "num",
                                          "value": "5.6",
                                          "ui": {
                                              "type": "input",
                                              "opts": {
                                                  "types": [
                                                      "num"
                                          "type": "num",
                                          "value": "37",
                                          "ui": {
                                              "type": "input",
                                              "opts": {
                                                  "types": [
                                                      "num"
                                          "name": "azimuth",
                                          "type": "num",
                                          "value": "0",
                                          "ui": {
                                              "type": "spinner",
                                              "opts": {
                                                  "min": -180,
                                                  "max": 180
                                          "type": "num",
                                          "value": "1",
                                          "ui": {
                                              "type": "input",
                                              "opts": {
                                                  "types": [
                                                      "num"
                                          "name": "apikey",
                                          "type": "cred",
                                          "ui": {
                                              "type": "input",
                                              "opts": {
                                                  "types": [
                                                      "cred"
                                          "name": "type",
                                          "type": "str",
                                          "ui": {
                                              "label": {
                                                  "en-US": "type"
                                              "type": "select",
                                              "opts": {
                                                  "opts": [
                                                          "l": {
                                                              "en-US": "Estimate"
                                                          "v": "estimate"
                                                          "l": {
                                                              "en-US": "History"
                                                          "v": "history"
                                                          "l": {
                                                          "v": "clearsky"
                                          "name": "watt",
                                          "type": "str",
                                          "value": "watts",
                                          "ui": {
                                              "type": "select",
                                              "opts": {
                                                  "opts": [
                                                          "l": {
                                                          "v": "watts"
                                                          "l": {
                                                          "l": {
                                                          "v": "watt_hours"
                                                          "l": {
                                          "type": "bool",
                                          "value": "false",
                                          "ui": {
                                              "label": {
                                              "type": "checkbox"
                                          "type": "bool",
                                          "value": "true",
                                          "ui": {
                                              "label": {
                                              "type": "checkbox"
                                          "type": "str",
                                          "value": "-1",
                                          "ui": {
                                              "label": {
                                              "type": "select",
                                              "opts": {
                                                  "opts": [
                                                          "l": {
                                                              "en-US": "Max"
                                                          "v": "-1"
                                                          "l": {
                                                              "en-US": "0"
                                                          "v": "0"
                                                          "l": {
                                                              "en-US": "1"
                                                          "v": "1"
                                                          "l": {
                                                              "en-US": "2"
                                                          "v": "2"
                                                          "l": {
                                                              "en-US": "3"
                                                          "v": "3"
                                                          "l": {
                                                              "en-US": "4"
                                                          "v": "4"
                                                          "l": {
                                                              "en-US": "5"
                                                          "v": "5"
                                                          "l": {
                                                              "en-US": "6"
                                                          "v": "6"
                                          "type": "bool",
                                          "value": "true",
                                          "ui": {
                                              "label": {
                                              "type": "checkbox"
                                  "meta": {
                                      "version": "0.0.9",
                                  "color": "#FFCC66",
                                  "inputLabels": [
                                      "trigger"
                                  "outputLabels": [
                                      "output",
                                      "graph"
                                  "status": {
                                      "x": 680,
                                      "y": 560,
                                      "wires": [
                                              "port": 0
                                              "port": 0
                                  "name": "",
                                  "method": "GET",
                                  "ret": "txt",
                                  "url": "",
                                  "tls": "",
                                  "persist": false,
                                  "proxy": "",
                                  "authType": "",
                                  "senderr": false,
                                  "headers": [],
                                  "x": 390,
                                  "y": 180,
                                  "wires": [
                                          "1b5ccaa05d54f7c3"
                                  "type": "function",
                                  "outputs": 1,
                                  "timeout": "",
                                  "noerr": 0,
                                  "initialize": "",
                                  "finalize": "",
                                  "libs": [],
                                  "x": 630,
                                  "y": 100,
                                  "wires": [
                                          "975daf96f15cfb61"
                                  "type": "json",
                                  "action": "",
                                  "pretty": false,
                                  "x": 680,
                                  "y": 180,
                                  "wires": [
                                          "e718a22973cc2864"
                                  "type": "function",
                                  "outputs": 1,
                                  "noerr": 0,
                                  "initialize": "",
                                  "finalize": "",
                                  "libs": [],
                                  "x": 520,
                                  "y": 480,
                                  "wires": [
                                          "e56826252134b93a"
                                  "type": "link out",
                                  "mode": "link",
                                  "links": [
                                      "3fa24f2d08195961",
                                      "0a20e852662c8cec"
                                  "x": 815,
                                  "y": 180,
                                  "wires": []
                                  "type": "link in",
                                  "links": [
                                      "e718a22973cc2864"
                                  "x": 385,
                                  "y": 480,
                                  "wires": [
                                          "559391d1288f762a"
                                  "type": "link in",
                                  "links": [
                                      "e718a22973cc2864"
                                  "x": 225,
                                  "y": 260,
                                  "wires": [
                                          "fcc8d69a3ab88e6d"
                                  "type": "inject",
                                  "name": "",
                                  "props": [
                                          "p": "payload"
                                          "p": "topic",
                                          "vt": "str"
                                  "repeat": "",
                                  "crontab": "",
                                  "once": true,
                                  "onceDelay": 0.1,
                                  "topic": "",
                                  "payload": "",
                                  "x": 530,
                                  "y": 440,
                                  "wires": [
                                          "e56826252134b93a"
                                  "type": "function",
                                  "outputs": 1,
                                  "noerr": 0,
                                  "initialize": "",
                                  "finalize": "",
                                  "libs": [],
                                  "x": 520,
                                  "y": 580,
                                  "wires": [
                                  "type": "function",
                                  "outputs": 1,
                                  "noerr": 0,
                                  "initialize": "",
                                  "finalize": "",
                                  "libs": [],
                                  "x": 360,
                                  "y": 340,
                                  "wires": [
                                          "5b0a430fb61e70e7"
                                  "type": "link out",
                                  "mode": "link",
                                  "links": [
                                      "14f2e68e572f4ef8"
                                  "x": 805,
                                  "y": 100,
                                  "wires": []
                                  "type": "link in",
                                  "links": [
                                      "975daf96f15cfb61"
                                  "x": 245,
                                  "y": 180,
                                  "wires": [
                                          "c706820c0d61f023"
                                  "type": "catch",
                                  "name": "",
                                  "scope": null,
                                  "uncaught": false,
                                  "x": 260,
                                  "y": 440,
                                  "wires": [
                                          "f427f19392c399ce"
                                  "type": "link out",
                                  "mode": "link",
                                  "links": [
                                      "dbaf8f5f5a920686"
                                  "x": 685,
                                  "y": 480,
                                  "wires": []
                                  "type": "link in",
                                  "links": [
                                      "e56826252134b93a"
                                  "x": 385,
                                  "y": 580,
                                  "wires": [
                                          "1bfc1cde3ee94e4b"
                                  "type": "link out",
                                  "mode": "link",
                                  "links": [
                                      "2ded0c14a222b4d9",
                                      "2f42837904c91d73"
                                  "x": 375,
                                  "y": 440,
                                  "wires": []
                                  "type": "link in",
                                  "links": [
                                      "f427f19392c399ce"
                                  "x": 385,
                                  "y": 540,
                                  "wires": [
                                          "a798fbe66cf133d5"
                                  "type": "function",
                                  "outputs": 1,
                                  "noerr": 0,
                                  "initialize": "",
                                  "finalize": "",
                                  "libs": [],
                                  "x": 520,
                                  "y": 540,
                                  "wires": [
                                  "type": "link in",
                                  "links": [
                                      "f427f19392c399ce"
                                  "x": 665,
                                  "y": 280,
                                  "wires": [
                                  "type": "function",
                                  "outputs": 1,
                                  "noerr": 0,
                                  "initialize": "",
                                  "finalize": "",
                                  "libs": [],
                                  "x": 360,
                                  "y": 260,
                                  "wires": [
                                          "a18e96179ec2d987"
                                  "type": "function",
                                  "outputs": 1,
                                  "noerr": 0,
                                  "initialize": "",
                                  "finalize": "",
                                  "libs": [],
                                  "x": 590,
                                  "y": 340,
                                  "wires": [
                                  "type": "delay",
                                  "timeout": "5",
                                  "rate": "5",
                                  "randomFirst": "1",
                                  "randomLast": "5",
                                  "drop": false,
                                  "allowrate": false,
                                  "outputs": 1,
                                  "x": 390,
                                  "y": 100,
                                  "wires": [
                                          "b9488734852cd0ca"
                                  "id": "11da2ee7fe92bba9",
                                  "type": "tab",
                                  "label": "Batterie Laden",
                                  "disabled": false,
                                  "info": "",
                                  "env": []
                                  "id": "882f920692db15ac",
                                  "type": "group",
                                  "z": "11da2ee7fe92bba9",
                                  "style": {
                                      "fill": "#d1d1d1",
                                      "label": true,
                                      "color": "#0070c0"
                                  "nodes": [
                                      "d2960c5258a6aa87",
                                      "0e02a8c5b8713878",
                                      "a556e20d6775b89e",
                                      "eaa7a8710b8bd555",
                                      "5dd7f104e86726b9",
                                      "87926d98a6caa2b7",
                                      "86a568bb366b5a53",
                                      "4951b0f4623d4bba",
                                      "d9368294d9621a30",
                                      "6c3cb62857c3f0cc",
                                      "3ccafa7058527caf",
                                      "b99a5fcf56fa30db"
                                  "x": 14,
                                  "y": 39,
                                  "w": 1532,
                                  "h": 222
                                  "id": "8885f238d46c98d4",
                                  "type": "group",
                                  "style": {
                                      "fill": "#d1d1d1",
                                      "label": true,
                                      "color": "#0070c0"
                                  "nodes": [
                                      "cc1bdb4e806c49d3",
                                      "08f1fa9012a05ea5",
                                      "c4d7dd8d06fa28f9",
                                      "0e39db21507d2496",
                                      "db9a8c492c1eacbf",
                                      "af5c4e99e154bf35",
                                      "0d520e8869dda085",
                                      "162844c501bda2cb",
                                      "29adc486d67dc5b4",
                                      "70bc14a931ad4c71",
                                      "df70959a7049e70c",
                                      "0740f2f6d8be4dc3",
                                      "c0f098512f61f09e",
                                      "db2f79c5ba46ec03",
                                      "8cdb8e157b315411",
                                      "3d56edb712404a94",
                                      "7dcab65894d85d27",
                                      "805b9497e42fd964",
                                      "af50b69abaa6e3f2",
                                      "0217fa6ea639b794",
                                      "6def2e19d5482654",
                                      "a3feba0d2f7707c9",
                                      "1d46f7e375b6f7e2",
                                      "043c5238cb193231",
                                      "98639d190c555169",
                                      "bb6880f6962e941b"
                                  "x": 14,
                                  "y": 379,
                                  "w": 1532,
                                  "h": 302
                                  "id": "3d56edb712404a94",
                                  "type": "junction",
                                  "g": "8885f238d46c98d4",
                                  "x": 1140,
                                  "y": 480,
                                  "wires": [
                                          "8cdb8e157b315411"
                                  "id": "d2960c5258a6aa87",
                                  "type": "ioBroker in",
                                  "g": "882f920692db15ac",
                                  "topic": "alpha-ess.0.Realtime.Battery_SOC",
                                  "payloadType": "value",
                                  "onlyack": "",
                                  "func": "all",
                                  "gap": "",
                                  "outFormat": "MQTT",
                                  "x": 120,
                                  "y": 140,
                                  "wires": [
                                          "4951b0f4623d4bba"
                                  "id": "0e02a8c5b8713878",
                                  "type": "join",
                                  "name": "",
                                  "mode": "custom",
                                  "build": "object",
                                  "key": "topic",
                                  "joiner": "\\n",
                                  "accumulate": true,
                                  "timeout": "",
                                  "count": "2",
                                  "reduceExp": "",
                                  "reduceInit": "",
                                  "reduceFixup": "",
                                  "x": 490,
                                  "y": 140,
                                  "wires": [
                                          "a556e20d6775b89e"
                                  "id": "a556e20d6775b89e",
                                  "type": "switch",
                                  "name": "",
                                  "rules": [
                                          "t": "jsonata_exp",
                                          "vt": "jsonata"
                                          "t": "jsonata_exp",
                                          "vt": "jsonata"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 630,
                                  "y": 140,
                                  "wires": [
                                          "d9368294d9621a30"
                                          "6c3cb62857c3f0cc"
                                  "id": "eaa7a8710b8bd555",
                                  "type": "comment",
                                  "info": "",
                                  "x": 560,
                                  "y": 220,
                                  "wires": []
                                  "id": "5dd7f104e86726b9",
                                  "type": "comment",
                                  "info": "",
                                  "x": 200,
                                  "y": 220,
                                  "wires": []
                                  "id": "87926d98a6caa2b7",
                                  "type": "ioBroker out",
                                  "name": "Battery Charging enabled [gridCharge]",
                                  "topic": "alpha-ess.0.Settings_Charge.Battery_Charging_enabled",
                                  "ack": "false",
                                  "autoCreate": "false",
                                  "stateName": "",
                                  "role": "",
                                  "payloadType": "",
                                  "readonly": "",
                                  "stateUnit": "",
                                  "stateMin": "",
                                  "stateMax": "",
                                  "x": 1330,
                                  "y": 140,
                                  "wires": []
                                  "id": "86a568bb366b5a53",
                                  "type": "comment",
                                  "info": "",
                                  "x": 1020,
                                  "y": 220,
                                  "wires": []
                                  "id": "4951b0f4623d4bba",
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "topic",
                                          "pt": "msg",
                                          "to": "batterie",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 320,
                                  "y": 140,
                                  "wires": [
                                          "0e02a8c5b8713878"
                                  "id": "d9368294d9621a30",
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "true",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 820,
                                  "y": 120,
                                  "wires": [
                                          "b99a5fcf56fa30db"
                                  "id": "6c3cb62857c3f0cc",
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 820,
                                  "y": 160,
                                  "wires": [
                                          "b99a5fcf56fa30db"
                                  "id": "cc1bdb4e806c49d3",
                                  "type": "inject",
                                  "name": "Set",
                                  "props": [
                                          "p": "payload"
                                          "p": "topic",
                                          "vt": "str"
                                  "repeat": "",
                                  "crontab": "",
                                  "once": false,
                                  "onceDelay": 0.1,
                                  "topic": "",
                                  "payload": "",
                                  "payloadType": "date",
                                  "x": 110,
                                  "y": 480,
                                  "wires": [
                                          "08f1fa9012a05ea5",
                                          "7dcab65894d85d27",
                                          "805b9497e42fd964"
                                  "id": "08f1fa9012a05ea5",
                                  "name": "Süd",
                                  "env": [
                                          "name": "latitude",
                                          "type": "num"
                                          "type": "num"
                                          "value": "40",
                                          "type": "num"
                                          "name": "azimuth",
                                          "value": "182",
                                          "type": "num"
                                          "value": "9",
                                          "type": "num"
                                          "name": "apikey",
                                          "type": "cred"
                                          "name": "watt",
                                          "type": "str"
                                          "type": "bool",
                                          "value": "false"
                                          "value": "1",
                                          "type": "str"
                                          "type": "bool",
                                          "value": "false"
                                  "x": 230,
                                  "y": 480,
                                  "wires": [
                                          "c4d7dd8d06fa28f9"
                                  "id": "c4d7dd8d06fa28f9",
                                  "type": "function",
                                  "name": "f1",
                                  "outputs": 1,
                                  "timeout": "",
                                  "noerr": 0,
                                  "initialize": "",
                                  "finalize": "",
                                  "libs": [
                                          "var": "moment",
                                          "module": "moment"
                                  "x": 390,
                                  "y": 460,
                                  "wires": [
                                          "1d46f7e375b6f7e2"
                                  "id": "0e39db21507d2496",
                                  "type": "switch",
                                  "name": "",
                                  "rules": [
                                          "t": "lt",
                                          "v": "2000",
                                          "vt": "str"
                                          "t": "btwn",
                                          "v": "2000",
                                          "vt": "num",
                                          "v2": "5000",
                                          "v2t": "num"
                                          "t": "btwn",
                                          "v": "5000",
                                          "vt": "num",
                                          "v2": "8000",
                                          "v2t": "num"
                                          "t": "gt",
                                          "v": "8000",
                                          "vt": "str"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 4,
                                  "x": 890,
                                  "y": 480,
                                  "wires": [
                                          "db9a8c492c1eacbf"
                                          "af5c4e99e154bf35"
                                          "0d520e8869dda085"
                                          "162844c501bda2cb"
                                  "id": "db9a8c492c1eacbf",
                                  "type": "change",
                                  "name": "SOC 100",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "100",
                                          "tot": "num"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 1040,
                                  "y": 420,
                                  "wires": [
                                          "3d56edb712404a94"
                                  "id": "af5c4e99e154bf35",
                                  "type": "change",
                                  "name": "SOC 60",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "60",
                                          "tot": "num"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 1040,
                                  "y": 460,
                                  "wires": [
                                          "3d56edb712404a94"
                                  "id": "0d520e8869dda085",
                                  "type": "change",
                                  "name": "SOC 40",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "40",
                                          "tot": "num"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 1040,
                                  "y": 500,
                                  "wires": [
                                          "3d56edb712404a94"
                                  "id": "162844c501bda2cb",
                                  "type": "change",
                                  "name": "SOC 20",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "20",
                                          "tot": "num"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 1040,
                                  "y": 540,
                                  "wires": [
                                          "3d56edb712404a94"
                                  "id": "29adc486d67dc5b4",
                                  "type": "comment",
                                  "info": "",
                                  "x": 230,
                                  "y": 420,
                                  "wires": []
                                  "id": "70bc14a931ad4c71",
                                  "type": "comment",
                                  "info": "",
                                  "x": 460,
                                  "y": 640,
                                  "wires": []
                                  "id": "df70959a7049e70c",
                                  "type": "comment",
                                  "info": "",
                                  "x": 170,
                                  "y": 640,
                                  "wires": []
                                  "id": "0740f2f6d8be4dc3",
                                  "type": "comment",
                                  "info": "",
                                  "x": 1020,
                                  "y": 620,
                                  "wires": []
                                  "id": "c0f098512f61f09e",
                                  "ack": "false",
                                  "stateName": "",
                                  "role": "",
                                  "payloadType": "",
                                  "readonly": "",
                                  "stateUnit": "",
                                  "stateMin": "",
                                  "stateMax": "",
                                  "x": 1330,
                                  "y": 480,
                                  "wires": []
                                  "id": "db2f79c5ba46ec03",
                                  "type": "comment",
                                  "info": "",
                                  "x": 1310,
                                  "y": 620,
                                  "wires": []
                                  "id": "8cdb8e157b315411",
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "topic",
                                          "pt": "msg",
                                          "to": "soll",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 1250,
                                  "y": 420,
                                  "wires": [
                                          "0e02a8c5b8713878",
                                          "bb6880f6962e941b"
                                  "id": "3ccafa7058527caf",
                                  "type": "debug",
                                  "name": "Charging",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "complete": "payload",
                                  "targetType": "msg",
                                  "statusVal": "",
                                  "statusType": "auto",
                                  "x": 1440,
                                  "y": 80,
                                  "wires": []
                                  "id": "bb6880f6962e941b",
                                  "type": "debug",
                                  "name": "Cutoff",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "statusVal": "",
                                  "x": 1450,
                                  "y": 420,
                                  "wires": []
                                  "id": "b99a5fcf56fa30db",
                                  "type": "rbe",
                                  "name": "Nur einmal",
                                  "func": "rbe",
                                  "gap": "",
                                  "start": "",
                                  "inout": "out",
                                  "septopics": true,
                                  "topi": "topic",
                                  "x": 1030,
                                  "y": 120,
                                  "wires": [
                                          "3ccafa7058527caf"
                                  "id": "7dcab65894d85d27",
                                  "name": "Ost",
                                  "env": [
                                          "name": "latitude",
                                          "type": "num"
                                          "type": "num"
                                          "value": "45",
                                          "type": "num"
                                          "name": "azimuth",
                                          "value": "90",
                                          "type": "num"
                                          "value": "2",
                                          "type": "num"
                                          "name": "apikey",
                                          "type": "cred"
                                          "name": "watt",
                                          "type": "str"
                                          "type": "bool",
                                          "value": "false"
                                          "value": "1",
                                          "type": "str"
                                          "type": "bool",
                                          "value": "false"
                                  "x": 230,
                                  "y": 540,
                                  "wires": [
                                          "af50b69abaa6e3f2"
                                  "id": "805b9497e42fd964",
                                  "name": "West",
                                  "env": [
                                          "name": "latitude",
                                          "type": "num"
                                          "type": "num"
                                          "value": "45",
                                          "type": "num"
                                          "name": "azimuth",
                                          "value": "270",
                                          "type": "num"
                                          "value": "3",
                                          "type": "num"
                                          "name": "apikey",
                                          "type": "cred"
                                          "name": "watt",
                                          "type": "str"
                                          "type": "bool",
                                          "value": "false"
                                          "value": "1",
                                          "type": "str"
                                          "type": "bool",
                                          "value": "false"
                                  "x": 230,
                                  "y": 600,
                                  "wires": [
                                          "0217fa6ea639b794"
                                  "id": "af50b69abaa6e3f2",
                                  "type": "function",
                                  "name": "f2",
                                  "func": "var pvf = msg.payload;\nvar date = moment().tz(\"Europe/Berlin\");\nvar today = date.format('YYYY-MM-DD');\nvar hourEntries = Object.keys(pvf.result);\nvar todaysEntries = hourEntries.filter(x => x.startsWith(today));\nvar expectedEarning = pvf.result[todaysEntries[todaysEntries.length -1]];\nmsg.payload = expectedEarning;\nmsg.topic = expectedEarning;\nreturn msg;",
                                  "outputs": 1,
                                  "timeout": "",
                                  "noerr": 0,
                                  "initialize": "",
                                  "finalize": "",
                                  "libs": [
                                          "var": "moment",
                                          "module": "moment"
                                  "x": 390,
                                  "y": 520,
                                  "wires": [
                                          "6def2e19d5482654"
                                  "id": "0217fa6ea639b794",
                                  "type": "function",
                                  "name": "f3",
                                  "outputs": 1,
                                  "timeout": "",
                                  "noerr": 0,
                                  "initialize": "",
                                  "finalize": "",
                                  "libs": [
                                          "var": "moment",
                                          "module": "moment"
                                  "x": 390,
                                  "y": 580,
                                  "wires": [
                                          "a3feba0d2f7707c9"
                                  "id": "a3feba0d2f7707c9",
                                  "type": "change",
                                  "name": "L3",
                                  "rules": [
                                          "t": "set",
                                          "p": "topic",
                                          "pt": "msg",
                                          "to": "L3",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 550,
                                  "y": 580,
                                  "wires": [
                                          "043c5238cb193231"
                                  "id": "6def2e19d5482654",
                                  "type": "change",
                                  "name": " L2",
                                  "rules": [
                                          "t": "set",
                                          "p": "topic",
                                          "pt": "msg",
                                          "to": "L2",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 550,
                                  "y": 520,
                                  "wires": [
                                          "043c5238cb193231"
                                  "id": "1d46f7e375b6f7e2",
                                  "type": "change",
                                  "name": "L1",
                                  "rules": [
                                          "t": "set",
                                          "p": "topic",
                                          "pt": "msg",
                                          "to": "L1",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 550,
                                  "y": 460,
                                  "wires": [
                                          "043c5238cb193231"
                                  "id": "043c5238cb193231",
                                  "type": "join",
                                  "name": "",
                                  "mode": "custom",
                                  "build": "object",
                                  "key": "topic",
                                  "joiner": "\\n",
                                  "accumulate": true,
                                  "timeout": "",
                                  "count": "3",
                                  "reduceExp": "",
                                  "reduceInit": "",
                                  "reduceFixup": "",
                                  "x": 730,
                                  "y": 480,
                                  "wires": [
                                          "0e39db21507d2496"
                                  "id": "98639d190c555169",
                                  "type": "comment",
                                  "name": "werte addieren",
                                  "info": "",
                                  "x": 620,
                                  "y": 420,
                                  "wires": []
                          • A Armin 2
                            @armin-2
                                    "id": "93f485839dfa27a8",
                                    "type": "subflow",
                                    "name": "Solar forecast",
                                    "category": "",
                                    "in": [
                                            "x": 240,
                                            "y": 100,
                                            "wires": [
                                    "out": [
                                            "x": 760,
                                            "y": 260,
                                            "wires": [
                                                    "id": "2f42837904c91d73",
                                                    "port": 0
                                                    "id": "fcc8d69a3ab88e6d",
                                                    "port": 0
                                            "x": 770,
                                            "y": 340,
                                            "wires": [
                                                    "id": "5b0a430fb61e70e7",
                                                    "port": 0
                                    "env": [
                                            "name": "latitude",
                                            "type": "num",
                                            "value": "51.3",
                                            "ui": {
                                                "icon": "font-awesome/fa-location-arrow",
                                                "type": "input",
                                                "opts": {
                                                    "types": [
                                                        "num"
                                            "name": "longitude",
                                            "type": "num",
                                            "value": "5.6",
                                            "ui": {
                                                "type": "input",
                                                "opts": {
                                                    "types": [
                                                        "num"
                                            "name": "declination",
                                            "type": "num",
                                            "value": "37",
                                            "ui": {
                                                "icon": "font-awesome/fa-chevron-up",
                                                "type": "input",
                                                "opts": {
                                                    "types": [
                                                        "num"
                                            "name": "azimuth",
                                            "type": "num",
                                            "value": "0",
                                            "ui": {
                                                "icon": "font-awesome/fa-compass",
                                                "type": "spinner",
                                                "opts": {
                                                    "min": -180,
                                                    "max": 180
                                            "name": "modules power",
                                            "type": "num",
                                            "value": "1",
                                            "ui": {
                                                "icon": "font-awesome/fa-power-off",
                                                "type": "input",
                                                "opts": {
                                                    "types": [
                                                        "num"
                                            "name": "apikey",
                                            "type": "cred",
                                            "ui": {
                                                "icon": "font-awesome/fa-key",
                                                "type": "input",
                                                "opts": {
                                                    "types": [
                                                        "cred"
                                            "name": "type",
                                            "type": "str",
                                            "value": "estimate",
                                            "ui": {
                                                "label": {
                                                    "en-US": "type"
                                                "type": "select",
                                                "opts": {
                                                    "opts": [
                                                            "l": {
        "en-US": "Estimate"
                                                            "v": "estimate"
                                                            "l": {
        "en-US": "History"
                                                            "v": "history"
                                                            "l": {
        "en-US": "Clear sky"
                                                            "v": "clearsky"
                                            "name": "watt",
                                            "type": "str",
                                            "value": "watts",
                                            "ui": {
                                                "icon": "font-awesome/fa-question-circle-o",
                                                "type": "select",
                                                "opts": {
                                                    "opts": [
                                                            "l": {
        "en-US": "Watts (power) average for the period"
                                                            "v": "watts"
                                                            "l": {
        "en-US": "Watt hours (energy) for the period"
                                                            "v": "watt_hours_period"
                                                            "l": {
        "en-US": "Watt hours (energy) summarized over the day"
                                                            "v": "watt_hours"
                                                            "l": {
        "en-US": "Watt hours (energy) summarized for each day"
                                                            "v": "watt_hours_day"
                                            "name": "kwhoutput",
                                            "type": "bool",
                                            "value": "false",
                                            "ui": {
                                                "label": {
                                                    "en-US": "Output in kWh (in the graph)"
                                                "type": "checkbox"
                                            "name": "showtoday",
                                            "type": "bool",
                                            "value": "true",
                                            "ui": {
                                                "label": {
                                                    "en-US": "Show todays forecast"
                                                "type": "checkbox"
                                            "name": "daystoforecast",
                                            "type": "str",
                                            "value": "-1",
                                            "ui": {
                                                "label": {
                                                    "en-US": "Days to forecast"
                                                "type": "select",
                                                "opts": {
                                                    "opts": [
                                                            "l": {
        "en-US": "Max"
                                                            "v": "-1"
                                                            "l": {
        "en-US": "0"
                                                            "v": "0"
                                                            "l": {
        "en-US": "1"
                                                            "v": "1"
                                                            "l": {
        "en-US": "2"
                                                            "v": "2"
                                                            "l": {
        "en-US": "3"
                                                            "v": "3"
                                                            "l": {
        "en-US": "4"
                                                            "v": "4"
                                                            "l": {
        "en-US": "5"
                                                            "v": "5"
                                                            "l": {
        "en-US": "6"
                                                            "v": "6"
                                            "name": "widengraph",
                                            "type": "bool",
                                            "value": "true",
                                            "ui": {
                                                "label": {
                                                    "en-US": "Widen graph"
                                                "type": "checkbox"
                                    "meta": {
                                        "module": "Solar Forecast",
                                        "version": "0.0.9",
                                        "author": "dfaber@victronenergy.com",
                                        "desc": "Get solar forecasting per location",
                                        "keywords": "solar,forecast,api",
                                        "license": "GPL-3.0"
                                    "color": "#FFCC66",
                                    "inputLabels": [
                                        "trigger"
                                    "outputLabels": [
                                        "output",
                                        "graph"
                                    "icon": "font-awesome/fa-sun-o",
                                    "status": {
                                        "x": 680,
                                        "y": 560,
                                        "wires": [
                                                "id": "1bfc1cde3ee94e4b",
                                                "port": 0
                                                "id": "a798fbe66cf133d5",
                                                "port": 0
                                    "id": "c706820c0d61f023",
                                    "type": "http request",
                                    "z": "93f485839dfa27a8",
                                    "name": "",
                                    "method": "GET",
                                    "ret": "txt",
                                    "paytoqs": "ignore",
                                    "url": "",
                                    "tls": "",
                                    "persist": false,
                                    "proxy": "",
                                    "insecureHTTPParser": false,
                                    "authType": "",
                                    "senderr": false,
                                    "headers": [],
                                    "x": 390,
                                    "y": 180,
                                    "wires": [
                                            "1b5ccaa05d54f7c3"
                                    "id": "b9488734852cd0ca",
                                    "type": "function",
                                    "name": "create forecast.solar url",
                                    "func": "msg.url = 'https://api.forecast.solar/';\n\nif (env.get('apikey')) {\n    msg.url += env.get('apikey') + '/';\n    }\n\nmsg.url += env.get('type') + '/';\n\nmsg.url += env.get('watt') + '/';\n\nmsg.url += env.get('latitude') + '/' +\n           env.get('longitude') + '/' +\n           env.get('declination') + '/' +\n           env.get('azimuth') + '/' +\n           env.get('modules power');\n\nmsg.topic = 'solar forecast: '+(env.get('type') || '');\nmsg.topic += (' '+env.get('watt') || '');\nif (env.get('kwhoutput')) {\n    msg.topic += ' (kWh)';\n}\nreturn msg;",
                                    "outputs": 1,
                                    "timeout": "",
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 630,
                                    "y": 100,
                                    "wires": [
                                            "975daf96f15cfb61"
                                    "id": "1b5ccaa05d54f7c3",
                                    "type": "json",
                                    "name": "Convert to json",
                                    "property": "payload",
                                    "action": "",
                                    "pretty": false,
                                    "x": 680,
                                    "y": 180,
                                    "wires": [
                                            "e718a22973cc2864"
                                    "id": "559391d1288f762a",
                                    "type": "function",
                                    "name": "update ratelimit",
                                    "func": "var remaining = msg.payload.message.ratelimit.remaining || 0;\nvar limit = msg.payload.message.ratelimit.limit;\n\nflow.set('forecast.solar.ratelimit.remaining', remaining)\nflow.set('forecast.solar.ratelimit.limit', limit)\n\nreturn msg;",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 520,
                                    "y": 480,
                                    "wires": [
                                            "e56826252134b93a"
                                    "id": "e718a22973cc2864",
                                    "type": "link out",
                                    "name": "link out 1",
                                    "mode": "link",
                                    "links": [
                                        "3fa24f2d08195961",
                                        "0a20e852662c8cec"
                                    "x": 815,
                                    "y": 180,
                                    "wires": []
                                    "id": "3fa24f2d08195961",
                                    "type": "link in",
                                    "name": "link in 1",
                                    "links": [
                                        "e718a22973cc2864"
                                    "x": 385,
                                    "y": 480,
                                    "wires": [
                                            "559391d1288f762a"
                                    "id": "0a20e852662c8cec",
                                    "type": "link in",
                                    "name": "link in 2",
                                    "links": [
                                        "e718a22973cc2864"
                                    "x": 225,
                                    "y": 260,
                                    "wires": [
                                            "fcc8d69a3ab88e6d"
                                    "id": "4734b6f403e1f03e",
                                    "type": "inject",
                                    "name": "",
                                    "props": [
                                            "p": "payload"
                                            "p": "topic",
                                            "vt": "str"
                                    "repeat": "",
                                    "crontab": "",
                                    "once": true,
                                    "onceDelay": 0.1,
                                    "topic": "",
                                    "payload": "",
                                    "x": 530,
                                    "y": 440,
                                    "wires": [
                                            "e56826252134b93a"
                                    "type": "function",
                                    "name": "update status",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 520,
                                    "y": 580,
                                    "wires": [
                                    "id": "a18e96179ec2d987",
                                    "type": "function",
                                    "name": "Create graph output",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 360,
                                    "y": 340,
                                    "wires": [
                                            "5b0a430fb61e70e7"
                                    "type": "link out",
                                    "mode": "link",
                                    "links": [
                                        "14f2e68e572f4ef8"
                                    "x": 805,
                                    "y": 100,
                                    "wires": []
                                    "type": "link in",
                                    "links": [
                                        "975daf96f15cfb61"
                                    "x": 245,
                                    "y": 180,
                                    "wires": [
                                            "c706820c0d61f023"
                                    "type": "catch",
                                    "name": "",
                                    "scope": null,
                                    "uncaught": false,
                                    "x": 260,
                                    "y": 440,
                                    "wires": [
                                            "f427f19392c399ce"
                                    "type": "link out",
                                    "mode": "link",
                                    "links": [
                                        "dbaf8f5f5a920686"
                                    "x": 685,
                                    "y": 480,
                                    "wires": []
                                    "type": "link in",
                                    "links": [
                                        "e56826252134b93a"
                                    "x": 385,
                                    "y": 580,
                                    "wires": [
                                            "1bfc1cde3ee94e4b"
                                    "type": "link out",
                                    "mode": "link",
                                    "links": [
                                        "2ded0c14a222b4d9",
                                        "2f42837904c91d73"
                                    "x": 375,
                                    "y": 440,
                                    "wires": []
                                    "type": "link in",
                                    "links": [
                                        "f427f19392c399ce"
                                    "x": 385,
                                    "y": 540,
                                    "wires": [
                                            "a798fbe66cf133d5"
                                    "type": "function",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 520,
                                    "y": 540,
                                    "wires": [
                                    "type": "link in",
                                    "links": [
                                        "f427f19392c399ce"
                                    "x": 665,
                                    "y": 280,
                                    "wires": [
                                    "type": "function",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 360,
                                    "y": 260,
                                    "wires": [
                                            "a18e96179ec2d987"
                                    "type": "function",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 590,
                                    "y": 340,
                                    "wires": [
                                    "type": "delay",
                                    "timeout": "5",
                                    "rate": "5",
                                    "randomFirst": "1",
                                    "randomLast": "5",
                                    "drop": false,
                                    "allowrate": false,
                                    "outputs": 1,
                                    "x": 390,
                                    "y": 100,
                                    "wires": [
                                            "b9488734852cd0ca"
                                    "type": "tab",
                                    "disabled": false,
                                    "info": "",
                                    "env": []
                                    "type": "group",
                                    "style": {
                                        "fill": "#d1d1d1",
                                        "label": true,
                                        "color": "#0070c0"
                                    "nodes": [
                                        "d2960c5258a6aa87",
                                        "0e02a8c5b8713878",
                                        "a556e20d6775b89e",
                                        "eaa7a8710b8bd555",
                                        "5dd7f104e86726b9",
                                        "87926d98a6caa2b7",
                                        "86a568bb366b5a53",
                                        "4951b0f4623d4bba",
                                        "d9368294d9621a30",
                                        "6c3cb62857c3f0cc",
                                        "3ccafa7058527caf",
                                        "b99a5fcf56fa30db"
                                    "x": 14,
                                    "y": 39,
                                    "w": 1532,
                                    "h": 222
                                    "type": "group",
                                    "style": {
                                        "fill": "#d1d1d1",
                                        "label": true,
                                        "color": "#0070c0"
                                    "nodes": [
                                        "cc1bdb4e806c49d3",
                                        "08f1fa9012a05ea5",
                                        "c4d7dd8d06fa28f9",
                                        "0e39db21507d2496",
                                        "db9a8c492c1eacbf",
                                        "af5c4e99e154bf35",
                                        "0d520e8869dda085",
                                        "162844c501bda2cb",
                                        "29adc486d67dc5b4",
                                        "70bc14a931ad4c71",
                                        "df70959a7049e70c",
                                        "0740f2f6d8be4dc3",
                                        "c0f098512f61f09e",
                                        "db2f79c5ba46ec03",
                                        "8cdb8e157b315411",
                                        "3d56edb712404a94",
                                        "7dcab65894d85d27",
                                        "805b9497e42fd964",
                                        "af50b69abaa6e3f2",
                                        "0217fa6ea639b794",
                                        "6def2e19d5482654",
                                        "a3feba0d2f7707c9",
                                        "1d46f7e375b6f7e2",
                                        "043c5238cb193231",
                                        "98639d190c555169",
                                        "bb6880f6962e941b"
                                    "x": 14,
                                    "y": 379,
                                    "w": 1532,
                                    "h": 302
                                    "type": "junction",
                                    "x": 1140,
                                    "y": 480,
                                    "wires": [
                                            "8cdb8e157b315411"
                                    "attrname": "payload",
                                    "onlyack": "",
                                    "func": "all",
                                    "gap": "",
                                    "x": 120,
                                    "y": 140,
                                    "wires": [
                                            "4951b0f4623d4bba"
                                    "type": "join",
                                    "name": "",
                                    "mode": "custom",
                                    "build": "object",
                                    "key": "topic",
                                    "joiner": "\\n",
                                    "accumulate": true,
                                    "timeout": "",
                                    "count": "2",
                                    "reduceExp": "",
                                    "reduceInit": "",
                                    "reduceFixup": "",
                                    "x": 490,
                                    "y": 140,
                                    "wires": [
                                            "a556e20d6775b89e"
                                    "type": "switch",
                                    "name": "",
                                    "rules": [
                                            "t": "jsonata_exp",
                                            "vt": "jsonata"
                                            "t": "jsonata_exp",
                                            "vt": "jsonata"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 2,
                                    "x": 630,
                                    "y": 140,
                                    "wires": [
                                            "d9368294d9621a30"
                                            "6c3cb62857c3f0cc"
                                    "type": "comment",
                                    "info": "",
                                    "x": 560,
                                    "y": 220,
                                    "wires": []
                                    "type": "comment",
                                    "info": "",
                                    "x": 200,
                                    "y": 220,
                                    "wires": []
                                    "ack": "false",
                                    "stateName": "",
                                    "role": "",
                                    "payloadType": "",
                                    "readonly": "",
                                    "stateUnit": "",
                                    "stateMin": "",
                                    "stateMax": "",
                                    "x": 1330,
                                    "y": 140,
                                    "wires": []
                                    "type": "comment",
                                    "info": "",
                                    "x": 1020,
                                    "y": 220,
                                    "wires": []
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "topic",
                                            "pt": "msg",
                                            "to": "batterie",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 320,
                                    "y": 140,
                                    "wires": [
                                            "0e02a8c5b8713878"
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "true",
                                            "tot": "bool"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 820,
                                    "y": 120,
                                    "wires": [
                                            "b99a5fcf56fa30db"
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "false",
                                            "tot": "bool"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 820,
                                    "y": 160,
                                    "wires": [
                                            "b99a5fcf56fa30db"
                                    "type": "inject",
                                    "name": "Set",
                                    "props": [
                                            "p": "payload"
                                            "p": "topic",
                                            "vt": "str"
                                    "repeat": "",
                                    "crontab": "",
                                    "once": false,
                                    "onceDelay": 0.1,
                                    "topic": "",
                                    "payload": "",
                                    "x": 110,
                                    "y": 480,
                                    "wires": [
                                            "08f1fa9012a05ea5",
                                            "7dcab65894d85d27",
                                            "805b9497e42fd964"
                                    "name": "Süd",
                                    "env": [
                                            "name": "latitude",
                                            "type": "num"
                                            "type": "num"
                                            "value": "40",
                                            "type": "num"
                                            "name": "azimuth",
                                            "value": "182",
                                            "type": "num"
                                            "value": "9",
                                            "type": "num"
                                            "name": "apikey",
                                            "type": "cred"
                                            "name": "watt",
                                            "type": "str"
                                            "type": "bool",
                                            "value": "false"
                                            "value": "1",
                                            "type": "str"
                                            "type": "bool",
                                            "value": "false"
                                    "x": 230,
                                    "y": 480,
                                    "wires": [
                                            "c4d7dd8d06fa28f9"
                                    "type": "function",
                                    "name": "f1",
                                    "outputs": 1,
                                    "timeout": "",
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [
                                            "var": "moment",
                                            "module": "moment"
                                    "x": 390,
                                    "y": 460,
                                    "wires": [
                                            "1d46f7e375b6f7e2"
                                    "type": "switch",
                                    "name": "",
                                    "rules": [
                                            "t": "lt",
                                            "v": "2000",
                                            "vt": "str"
                                            "t": "btwn",
                                            "v": "2000",
                                            "vt": "num",
                                            "v2": "5000",
                                            "v2t": "num"
                                            "t": "btwn",
                                            "v": "5000",
                                            "vt": "num",
                                            "v2": "8000",
                                            "v2t": "num"
                                            "t": "gt",
                                            "v": "8000",
                                            "vt": "str"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 4,
                                    "x": 890,
                                    "y": 480,
                                    "wires": [
                                            "db9a8c492c1eacbf"
                                            "af5c4e99e154bf35"
                                            "0d520e8869dda085"
                                            "162844c501bda2cb"
                                    "type": "change",
                                    "name": "SOC 100",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "100",
                                            "tot": "num"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1040,
                                    "y": 420,
                                    "wires": [
                                            "3d56edb712404a94"
                                    "type": "change",
                                    "name": "SOC 60",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "60",
                                            "tot": "num"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1040,
                                    "y": 460,
                                    "wires": [
                                            "3d56edb712404a94"
                                    "type": "change",
                                    "name": "SOC 40",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "40",
                                            "tot": "num"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1040,
                                    "y": 500,
                                    "wires": [
                                            "3d56edb712404a94"
                                    "type": "change",
                                    "name": "SOC 20",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "20",
                                            "tot": "num"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1040,
                                    "y": 540,
                                    "wires": [
                                            "3d56edb712404a94"
                                    "type": "comment",
                                    "info": "",
                                    "x": 230,
                                    "y": 420,
                                    "wires": []
                                    "type": "comment",
                                    "info": "",
                                    "x": 460,
                                    "y": 640,
                                    "wires": []
                                    "type": "comment",
                                    "info": "",
                                    "x": 170,
                                    "y": 640,
                                    "wires": []
                                    "type": "comment",
                                    "info": "",
                                    "x": 1020,
                                    "y": 620,
                                    "wires": []
                                    "ack": "false",
                                    "stateName": "",
                                    "role": "",
                                    "payloadType": "",
                                    "readonly": "",
                                    "stateUnit": "",
                                    "stateMin": "",
                                    "stateMax": "",
                                    "x": 1330,
                                    "y": 480,
                                    "wires": []
                                    "type": "comment",
                                    "info": "",
                                    "x": 1310,
                                    "y": 620,
                                    "wires": []
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "topic",
                                            "pt": "msg",
                                            "to": "soll",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1250,
                                    "y": 420,
                                    "wires": [
                                            "0e02a8c5b8713878",
                                            "bb6880f6962e941b"
                                    "type": "debug",
                                    "name": "Charging",
                                    "active": true,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 1440,
                                    "y": 80,
                                    "wires": []
                                    "type": "debug",
                                    "name": "Cutoff",
                                    "active": true,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 1450,
                                    "y": 420,
                                    "wires": []
                                    "type": "rbe",
                                    "func": "rbe",
                                    "gap": "",
                                    "start": "",
                                    "inout": "out",
                                    "septopics": true,
                                    "topi": "topic",
                                    "x": 1030,
                                    "y": 120,
                                    "wires": [
                                            "3ccafa7058527caf"
                                    "type": "subflow:93f485839dfa27a8",
                                    "name": "Ost",
                                    "env": [
                                            "name": "latitude",
                                            "value": "51.0618535",
                                            "type": "num"
                                            "value": "7.376629",
                                            "type": "num"
                                            "value": "45",
                                            "type": "num"
                                            "name": "azimuth",
                                            "value": "90",
                                            "type": "num"
                                            "value": "2",
                                            "type": "num"
                                            "name": "apikey",
                                            "type": "cred"
                                            "name": "watt",
                                            "value": "watt_hours_day",
                                            "type": "str"
                                            "type": "bool",
                                            "value": "false"
                                            "value": "1",
                                            "type": "str"
                                            "type": "bool",
                                            "value": "false"
                                    "x": 230,
                                    "y": 540,
                                    "wires": [
                                            "af50b69abaa6e3f2"
                                    "name": "West",
                                    "env": [
                                            "name": "latitude",
                                            "type": "num"
                                            "type": "num"
                                            "value": "45",
                                            "type": "num"
                                            "name": "azimuth",
                                            "value": "270",
                                            "type": "num"
                                            "value": "3",
                                            "type": "num"
                                            "name": "apikey",
                                            "type": "cred"
                                            "name": "watt",
                                            "type": "str"
                                            "type": "bool",
                                            "value": "false"
                                            "value": "1",
                                            "type": "str"
                                            "type": "bool",
                                            "value": "false"
                                    "x": 230,
                                    "y": 600,
                                    "wires": [
                                            "0217fa6ea639b794"
                                    "type": "function",
                                    "name": "f2",
                                    "outputs": 1,
                                    "timeout": "",
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [
                                            "var": "moment",
                                            "module": "moment"
                                    "x": 390,
                                    "y": 520,
                                    "wires": [
                                            "6def2e19d5482654"
                                    "type": "function",
                                    "name": "f3",
                                    "outputs": 1,
                                    "timeout": "",
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [
                                            "var": "moment",
                                            "module": "moment"
                                    "x": 390,
                                    "y": 580,
                                    "wires": [
                                            "a3feba0d2f7707c9"
                                    "type": "change",
                                    "name": "L3",
                                    "rules": [
                                            "t": "set",
                                            "p": "topic",
                                            "pt": "msg",
                                            "to": "L3",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 550,
                                    "y": 580,
                                    "wires": [
                                            "043c5238cb193231"
                                    "type": "change",
                                    "name": " L2",
                                    "rules": [
                                            "t": "set",
                                            "p": "topic",
                                            "pt": "msg",
                                            "to": "L2",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 550,
                                    "y": 520,
                                    "wires": [
                                            "043c5238cb193231"
                                    "type": "change",
                                    "name": "L1",
                                    "rules": [
                                            "t": "set",
                                            "p": "topic",
                                            "pt": "msg",
                                            "to": "L1",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 550,
                                    "y": 460,
                                    "wires": [
                                            "043c5238cb193231"
                                    "type": "join",
                                    "name": "",
                                    "mode": "custom",
                                    "build": "object",
                                    "propertyType": "msg",
                                    "key": "topic",
                                    "joiner": "\\n",
                                    "joinerType": "str",
                                    "accumulate": true,
                                    "timeout": "",
                                    "count": "3",
                                    "reduceRight": false,
                                    "reduceExp": "",
                                    "reduceInit": "",
                                    "reduceInitType": "",
                                    "reduceFixup": "",
                                    "x": 730,
                                    "y": 480,
                                    "wires": [
                                            "0e39db21507d2496"
                                    "type": "comment",
                                    "info": "",
                                    "x": 620,
                                    "y": 420,
                                    "wires": []
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @armin-2
                            Also Du fügst in der JOIN Node ja nur die 3 Werte in ein Objekt zusammen. Wenn Du eine DebugNode hinter die JOIN Node machen würdest würdest Du sehen, wie das Objekt zusammengesetzt wird.
                            Also die Verwendung von Debug Nodes hilft in der Regel immer.
                            Die JOIN Node setzt also die topics nur zusammen, addiert diese aber nicht, dass musst Du mit einer anschliessenden ChangeNode noch machen.
                            das kannst Du entweder in diesem Fall mit der Summenfunktion von JSONATA machen:
                            oder in dem Du die Werte einzeln mit JSONATA addierst:
                            Also in JSONATA in der ChangeNode entweder:
                            payload.L1 + payload.L2 +payload.L3
                            oder
                            $sum(payload.*)
                            hier die Change node
                                   "id": "0eeff7bfe9f566bd",
                                   "type": "change",
                                   "z": "c38a1eccc4954015",
                                   "g": "f6a3a84cec843ef8",
                                   "name": "summieren",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "$sum(payload.*)",
                                           "tot": "jsonata"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 890,
                                   "y": 480,
                                   "wires": [
                                           "bc12eec763ba10c2",
                                           "2942bca022679e0e"
