  4. [gelöst] Javascript Adapter funktioniert nicht /JS-Controlle
6 Beiträge 2 Kommentatoren 628 Aufrufe 2 Beobachtet
  • I Offline
    I Offline
    Ianig Iro
    schrieb am zuletzt editiert von Ianig Iro
    • Adaptername: Javascript
    • Link zu Adapterrepository: https://github.com/ioBroker/ioBroker.javascript
    • Adapterversion: 7.1.6
    • js-controller Version: 5.0.17
    • Admin Version: 6.12.0
    • Hardwaresystem: Pi4
    • Arbeitsspeicher: 4GB
    • Festplattenart: SSD
    • Betriebssystem: Rasp Pi OS
    • Nodejs-Version: 18.19.0
    • NPM-Version: 10.2.3
    • Installationsart: Skript
    • Image, Docker genutzt: Nein
    • Ort, Name der Imagedatei: ...
    iob diag
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-v8
        Architecture: arm64
    Model		: Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     10:15:27 up 12 days, 15:04,  3 users,  load average: 0.37, 0.45, 0.39
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Fri 2024-01-26 10:15:27 CET
               Universal time: Fri 2024-01-26 09:15:27 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            4.0G        1.6G        998M        1.4M        1.5G        2.4G
    Swap:           104M          0B        104M
    Total:          4.1G        1.6G        1.1G
             3792 M total memory
             1526 M used memory
             1986 M active memory
              657 M inactive memory
              951 M free memory
              139 M buffer memory
             1251 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.3M  379M   1% /run
    /dev/sda2      ext4      110G  7.0G   97G   7% /
    tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   74M  437M  15% /boot/firmware
    tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
    [Sat Jan 13 19:11:13 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:61:2A:FD vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=def89f0e-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=GB
    [Sat Jan 13 19:11:17 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Jan 13 19:11:18 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    725M	/var/
    246M	/var/log/journal/be2ab101d79b4303b4dc531310d8bc39
    246M	/var/log
    191M	/var/lib
    Archived and active journals take up 245.3M in the file system.
    /opt/iobroker/backups:
    73M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    343M	/opt/iobroker/iobroker-data/
    292M	/opt/iobroker/iobroker-data/files
    89M	/opt/iobroker/iobroker-data/files/echarts.admin
    67M	/opt/iobroker/iobroker-data/files/javascript.admin
    57M	/opt/iobroker/iobroker-data/files/echarts
    24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
    21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    17M	/opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2255680-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.19.0
    /usr/bin/node 		v18.19.0
    /usr/bin/npm 		10.2.3
    /usr/bin/npx 		10.2.3
    /usr/bin/corepack 	0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
         18.19.0+dfsg-6~deb12u1 500
     *** 18.19.0-1nodesource1 600
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         18.18.2-1nodesource1 600
         18.18.1-1nodesource1 600
         18.18.0-1nodesource1 600
         18.17.1-1nodesource1 600
         18.17.0-1nodesource1 600
         18.16.1-1nodesource1 600
         18.16.0-1nodesource1 600
         18.15.0-1nodesource1 600
         18.14.2-1nodesource1 600
         18.14.1-1nodesource1 600
         18.14.0-1nodesource1 600
         18.13.0+dfsg1-1 500
         18.13.0-1nodesource1 600
         18.12.0-1nodesource1 600
         18.11.0-1nodesource1 600
         18.10.0-1nodesource1 600
         18.9.1-1nodesource1 600
         18.9.0-1nodesource1 600
         18.8.0-1nodesource1 600
         18.7.0-1nodesource1 600
         18.6.0-1nodesource1 600
         18.5.0-1nodesource1 600
         18.4.0-1nodesource1 600
         18.3.0-1nodesource1 600
         18.2.0-1nodesource1 600
         18.1.0-1nodesource1 600
         18.0.0-1nodesource1 600
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
    npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
    npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
    npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
    npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
    npm ERR! extraneous: typescript@5.2.2 /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
    npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
    npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
    npm ERR! invalid: form-data@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-26T09_15_34_808Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.17
    admin: 		6.12.0
    javascript: 	7.1.6
    Adapters from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      system.adapter.deconz.0                 : deconz                : raspberrypi                              - disabled, port: 80
      system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      system.adapter.echarts.0                : echarts               : raspberrypi                              - disabled
      system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
      system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 192.168.178.21
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sureflap.0               : sureflap              : raspberrypi                              -  enabled
    + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
      system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wolf-smartset.0          : wolf-smartset         : raspberrypi                              -  enabled
      system.adapter.yahka.0                  : yahka                 : raspberrypi                              - disabled
    + system.adapter.yahka.1                  : yahka                 : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "deconz"       : 1.3.23   , installed 1.3.23
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sureflap"     : 1.2.3    , installed 1.2.1  [Updatable]
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.10.1   , installed 1.9.7  [Updatable]
    Objects and States
    Objects: 	3416
    States: 	2681
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 34
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:45127         0.0.0.0:*               LISTEN      1001       3524116    2590/io.yahka.1
    tcp        0      0 127.0.0.1:39037         0.0.0.0:*               LISTEN      1001       1987251    2590/io.yahka.1
    tcp        0      0 127.0.0.1:34867         0.0.0.0:*               LISTEN      1001       2011832    2590/io.yahka.1
    tcp        0      0 127.0.0.1:32813         0.0.0.0:*               LISTEN      1001       4995153    2590/io.yahka.1
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6428985    320870/cupsd
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          13972      767/vncserver-x11-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       25428      2423/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       22407      2423/iobroker.js-co
    tcp        0      0 127.0.0.1:39725         0.0.0.0:*               LISTEN      1001       4090455    2590/io.yahka.1
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17419      772/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:38591         0.0.0.0:*               LISTEN      1001       6656388    2590/io.yahka.1
    tcp        0      0 127.0.0.1:44885         0.0.0.0:*               LISTEN      1001       4718584    2590/io.yahka.1
    tcp        0      0 127.0.0.1:36733         0.0.0.0:*               LISTEN      1001       3118844    2590/io.yahka.1
    tcp        0      0 127.0.0.1:40705         0.0.0.0:*               LISTEN      1001       6655452    2590/io.yahka.1
    tcp        0      0 127.0.0.1:45021         0.0.0.0:*               LISTEN      1001       964360     2590/io.yahka.1
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          13971      767/vncserver-x11-c
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        17528      869/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23450      2441/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17421      772/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6428984    320870/cupsd
    tcp6       0      0 :::46001                :::*                    LISTEN      1001       26737      2590/io.yahka.1
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15817      573/avahi-daemon: r
    udp        0      0 0.0.0.0:56777           0.0.0.0:*                           104        15819      573/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       26109      2759/io.shelly.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          6429833    320872/cups-browsed
    udp6       0      0 :::5353                 :::*                                104        15818      573/avahi-daemon: r
    udp6       0      0 fe80::44e4:421c:c1e:546 :::*                                0          14130      711/NetworkManager
    udp6       0      0 fe80::d890:c26c:38f:546 :::*                                0          16841      711/NetworkManager
    udp6       0      0 :::46009                :::*                                104        15820      573/avahi-daemon: r
    2024-01-26 10:16:29.963  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-01-26 10:16:29.963  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/index.js:143:19)
    2024-01-26 10:16:29.963  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-26 10:16:29.963  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-01-26 10:16:29.963  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-01-26 10:16:29.963  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-01-26 10:16:29.964  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
    2024-01-26 10:16:29.964  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-01-26 10:16:29.964  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:5:18)
    2024-01-26 10:16:29.964  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-26 10:16:29.964  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-01-26 10:16:29.964  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-01-26 10:16:29.964  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-01-26 10:16:29.965  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-01-26 10:16:29.965  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:45:23)
    2024-01-26 10:16:29.965  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-26 10:16:29.965  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-01-26 10:16:29.965  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-01-26 10:16:29.965  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-01-26 10:16:29.966  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    2024-01-26 10:16:29.966  - error: host.raspberrypi Caught by controller[0]:     at node:internal/main/run_main_module:28:49
    2024-01-26 10:16:29.966  - error: host.raspberrypi Caught by controller[0]: Node.js v18.19.0
    2024-01-26 10:16:29.966  - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-26 10:16:29.966  - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
    Moin zusammen,
    ich habe vor kurzem meinen Pi neu aufgesetzt. Soweit hat alles funktioniert. Der Js-Controller auch. Ich habe ein Backup reingezogen, es hat immernoch alles funktioniert.
    Nun habe ich mich an ein paar Skripten versucht (nagut, eher C&P), jetzt ist der Adapter rot und steigt auch sofort wieder aus.
    Was ich vergeblich probiert habe:
    • neue Skripte löschen
    • Adapter neu installiert
    Es scheint ein Problem mit dem JS-Controller zu geben? Kann es daran liegen, dass ich ein veraltetes Backup in den IOB geladen habe? Oder kann ich mir mit dem Skript was zerschossen haben?
    Besten Dank für euren Input und viele Grüße
    • I Ianig Iro
      iob diag
      Skript v.2023-10-10
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:           104M          0B        104M
               3792 M total memory
               1526 M used memory
                951 M free memory
                139 M buffer memory
               1251 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      725M	/var/
      246M	/var/log
      191M	/var/lib
      USB-Devices by-id:
      /usr/bin/npm 		10.2.3
      /usr/bin/npx 		10.2.3
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin: 		6.12.0
      javascript: 	7.1.6
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	3416
      States: 	2681
      Pending Updates: 34
      Moin zusammen,
      @ianig-iro sagte in Javascript Adapter funktioniert nicht /JS-Controller stopped:
      Pending Updates: 34
      Updaten, die iob-Adapter auch.
      Hast du im javaskript-Adapter zusätzliche Module eingetragen? Trag die nochmal ein.
      I 1 Antwort Letzte Antwort
        Pending Updates: 34
        I Offline
        I Offline
        Ianig Iro
        @thomas-braun Oh man, es lag wirklich am Update. Mea Culpa
        • I Ianig Iro
          Da liegt es erstaunlich oft dran...
          Ich weiß... 'Näwah tatsch äh runnink süstäm'...
          iob diag
          sagt nun?
            iob diag
            sagt nun?
            I Offline
            I Offline
            Ianig Iro
            @thomas-braun said in [gelöst] Javascript Adapter funktioniert nicht /JS-Controlle:
            Damit habe ich mir eigtl schon die Finger verbrannt und wollte jetzt alles (halbwegs) aktuell halten.
            Das ganze ist zwei Tage nachdem ich mein System komplett neu aufgezogen habe passiert, deswegen hatte ich das garnicht auf dem Schirm.
            iob diag
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : arm64
             16:14:10 up  4:14,  3 users,  load average: 0.70, 0.56, 0.45
            CPU threads: 4
            Current issues:
                           Local time: Fri 2024-01-26 16:14:10 CET
                       Universal time: Fri 2024-01-26 15:14:10 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server: 	false
            Desktop:
            Terminal: 	tty
            *** MEMORY ***
            Mem:            4.0G        1.2G        2.2G        1.4M        714M        2.8G
            Swap:           104M          0B        104M
            Total:          4.1G        1.2G        2.3G
                     3792 M total memory
                     1101 M used memory
                     1437 M active memory
                      163 M inactive memory
                     2082 M free memory
                       60 M buffer memory
                      620 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /dev/sda2      ext4      110G  6.9G   98G   7% /
            [Fri Jan 26 11:59:45 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:61:2A:FD vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=def89f0e-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=GB
            [Fri Jan 26 11:59:48 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
            [Fri Jan 26 11:59:49 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
            /var:
            733M	/var/
            254M	/var/log/journal/be2ab101d79b4303b4dc531310d8bc39
            254M	/var/log
            191M	/var/lib
            Archived and active journals take up 253.3M in the file system.
            341M	/opt/iobroker/iobroker-data/
            USB-Devices by-id:
            /usr/bin/npm 		10.2.3
            /usr/bin/npx 		10.2.3
            nodejs:
              Version table:
                 18.13.0+dfsg1-1 500
            Errors in npm tree:
            npm ERR! invalid: color-convert@1.9.3 /opt/iobroker/node_modules/color-convert
            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-26T15_14_18_362Z-debug-0.log
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin: 		6.12.0
            javascript: 	7.1.6
            Adapter State
            + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
            + instance is alive
            Adapter    "sureflap"     : 1.2.3    , installed 1.2.3
            Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
            Objects and States
            Objects: 	3450
            States: 	2720
            Pending Updates: 0
            tcp        0      0 127.0.0.1:38299         0.0.0.0:*               LISTEN      1001       114757     1208/io.yahka.1
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13009      746/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          14961      733/vncserver-x11-c
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12992      719/cupsd
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17121      908/iobroker.js-con
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15187      908/iobroker.js-con
            tcp6       0      0 :::22                   :::*                    LISTEN      0          13011      746/sshd: /usr/sbin
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12991      719/cupsd
            tcp6       0      0 :::39177                :::*                    LISTEN      1001       18058      1208/io.yahka.1
            tcp6       0      0 :::5900                 :::*                    LISTEN      0          14960      733/vncserver-x11-c
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13278      1009/io.admin.0
            tcp6       0      0 :::8086                 :::*                    LISTEN      999        13118      842/influxd
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13112      823/cups-browsed
            udp        0      0 0.0.0.0:40066           0.0.0.0:*                           104        12850      558/avahi-daemon: r
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        12848      558/avahi-daemon: r
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       18451      1063/io.shelly.0
            udp6       0      0 fe80::44e4:421c:c1e:546 :::*                                0          13169      684/NetworkManager
            udp6       0      0 fe80::d890:c26c:38f:546 :::*                                0          14997      684/NetworkManager
            udp6       0      0 :::5353                 :::*                                104        12849      558/avahi-daemon: r
            udp6       0      0 :::57318                :::*                                104        12851      558/avahi-daemon: r
            2024-01-26 16:13:00.531  - info: wolf-smartset.0 (5282) terminating
            2024-01-26 16:13:00.704  - info: host.raspberrypi instance system.adapter.wolf-smartset.0 scheduled normal terminated and will be restarted on schedule.
            2024-01-26 16:13:00.705  - info: host.raspberrypi Restart adapter system.adapter.wolf-smartset.0 because enabled
            2024-01-26 16:13:01.766  - info: host.raspberrypi instance system.adapter.wolf-smartset.0 started with pid 5298
            2024-01-26 16:13:04.274  - info: wolf-smartset.0 (5298) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.wolf-smartset, node: v18.19.0, js-controller: 5.0.17
            2024-01-26 16:13:05.255  - info: wolf-smartset.0 (5298) Initialization with Login and new Session done!
            2024-01-26 16:14:00.018  - info: wolf-smartset.0 (5298) Scheduled restart.
            2024-01-26 16:14:00.065  - info: wolf-smartset.0 (5298) terminating
            2024-01-26 16:14:00.067  - info: wolf-smartset.0 (5298) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2024-01-26 16:14:00.525  - info: wolf-smartset.0 (5298) terminating
            2024-01-26 16:14:00.641  - info: host.raspberrypi instance system.adapter.wolf-smartset.0 scheduled normal terminated and will be restarted on schedule.
            2024-01-26 16:14:00.642  - info: host.raspberrypi Restart adapter system.adapter.wolf-smartset.0 because enabled
            2024-01-26 16:14:01.757  - info: host.raspberrypi instance system.adapter.wolf-smartset.0 started with pid 5315
            2024-01-26 16:14:04.201  - info: wolf-smartset.0 (5315) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.wolf-smartset, node: v18.19.0, js-controller: 5.0.17
            2024-01-26 16:14:05.200  - info: wolf-smartset.0 (5315) Initialization with Login and new Session done!
            2024-01-26 16:15:00.024  - info: wolf-smartset.0 (5315) Scheduled restart.
            2024-01-26 16:15:00.073  - info: wolf-smartset.0 (5315) terminating
            2024-01-26 16:15:00.076  - info: wolf-smartset.0 (5315) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2024-01-26 16:15:00.644  - warn: wolf-smartset.0 (5315) get state error: Connection is closed.
            2024-01-26 16:15:00.646  - info: wolf-smartset.0 (5315) terminating
            2024-01-26 16:15:00.734  - info: host.raspberrypi instance system.adapter.wolf-smartset.0 scheduled normal terminated and will be restarted on schedule.
            2024-01-26 16:15:00.736  - info: host.raspberrypi Restart adapter system.adapter.wolf-smartset.0 because enabled
            2024-01-26 16:15:01.790  - info: host.raspberrypi instance system.adapter.wolf-smartset.0 started with pid 5586
            2024-01-26 16:15:04.720  - info: wolf-smartset.0 (5586) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.wolf-smartset, node: v18.19.0, js-controller: 5.0.17
            2024-01-26 16:15:05.895  - info: wolf-smartset.0 (5586) Initialization with Login and new Session done!
            Habe ich mir jetzt ein npm Problem eingefangen?
            Edit: Hatte beim Javascript Adapter Color-Convert drin, bei der Neuinstallation habe ich vergessen, es nachzutragen. Der Fehler ist jetzt auch weg.
            • I Ianig Iro
              iob diag
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server: 	false
              Desktop:
              Terminal: 	tty
              *** MEMORY ***
              Swap:           104M          0B        104M
                       3792 M total memory
                       1101 M used memory
                       2082 M free memory
                         60 M buffer memory
                        620 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              733M	/var/
              254M	/var/log
              191M	/var/lib
              USB-Devices by-id:
              /usr/bin/npm 		10.2.3
              /usr/bin/npx 		10.2.3
              nodejs:
                Version table:
                   18.13.0+dfsg1-1 500
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin: 		6.12.0
              javascript: 	7.1.6
              Adapter State
              + instance is alive
              Objects and States
              Objects: 	3450
              States: 	2720
              Pending Updates: 0
              @ianig-iro sagte in [gelöst] Javascript Adapter funktioniert nicht /JS-Controlle:
              Soweit schaut das gut aus. Ich würde aber im Zigbee-Adapter als COM-Port statt
              • system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/ttyACM0
              besser das eintragen:
