  4. [gelöst} zigbee-adapter will nicht mehr starten
8 Beiträge 6 Kommentatoren 1.2k Aufrufe 6 Beobachtet
    bommelmeier
    schrieb am zuletzt editiert von bommelmeier
    Moin,
    ich habe sämtliche Adapter, die angemeckert wurden, upgedated. Klappte in der grafischen Konsole zunächst perfekt.
    Allerdings will der Zigbee-Adapter nicht starten, fällt immer wieder auf die Nase.
    2024-01-09 12:46:18.157  - info: zigbee.0 (5081) starting. Version 1.9.7 (non-npm: ioBroker/ioBroker.zigbee#ef932ce47a1c5e824031179ce919640a832d1a71) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 4.0.24
    2024-01-09 12:46:18.296  - error: zigbee.0 (5081) Failed to call 'Backup' 'configure' (TypeError: Class extends value undefined is not a constructor or null
        at Object.<anonymous> (/opt/iobroker/node_modules/tar/lib/read-entry.js:97:4)
        at Module._compile (node:internal/modules/cjs/loader:1356:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
        at Module.load (node:internal/modules/cjs/loader:1197:32)
        at Function.Module._load (node:internal/modules/cjs/loader:1013:12)
        at Module.require (node:internal/modules/cjs/loader:1225:19)
        at require (node:internal/modules/helpers:177:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/tar/lib/pack.js:27:19)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10))
    2024-01-09 12:46:18.335  - error: zigbee.0 (5081) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-01-09 12:46:18.337  - error: zigbee.0 (5081) unhandled promise rejection: Class extends value undefined is not a constructor or null
    2024-01-09 12:46:18.340  - error: zigbee.0 (5081) TypeError: Class extends value undefined is not a constructor or null
    2024-01-09 12:46:18.341  - error: zigbee.0 (5081) Class extends value undefined is not a constructor or null
    2024-01-09 12:46:18.367  - info: zigbee.0 (5081) cleaned everything up...
    2024-01-09 12:46:18.814  - warn: zigbee.0 (5081) Failed to stop zigbee during startup
    2024-01-09 12:46:18.816  - info: zigbee.0 (5081) terminating
    2024-01-09 12:46:18.839  - warn: zigbee.0 (5081) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-01-09 12:46:20.163  - warn: zigbee.0 (5081) get state error: DB closed
    2024-01-09 12:46:20.199  - warn: zigbee.0 (5081) get state error: Connection is closed.
    2024-01-09 12:46:20.201  - warn: zigbee.0 (5081) get state error: Connection is closed.
    2024-01-09 12:46:20.723  - error: host.pi3 Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2024-01-09 12:46:20.726  - error: host.pi3 Caught by controller[1]: TypeError: Class extends value undefined is not a constructor or null
    2024-01-09 12:46:20.728  - error: host.pi3 Caught by controller[1]:     at Object.<anonymous> (/opt/iobroker/node_modules/tar/lib/read-entry.js:97:4)
    2024-01-09 12:46:20.730  - error: host.pi3 Caught by controller[1]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-09 12:46:20.732  - error: host.pi3 Caught by controller[1]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-01-09 12:46:20.733  - error: host.pi3 Caught by controller[1]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-01-09 12:46:20.735  - error: host.pi3 Caught by controller[1]:     at Function.Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-01-09 12:46:20.737  - error: host.pi3 Caught by controller[1]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
    2024-01-09 12:46:20.738  - error: host.pi3 Caught by controller[1]:     at require (node:internal/modules/helpers:177:18)
    2024-01-09 12:46:20.740  - error: host.pi3 Caught by controller[1]:     at Object.<anonymous> (/opt/iobroker/node_modules/tar/lib/pack.js:27:19)
    2024-01-09 12:46:20.742  - error: host.pi3 Caught by controller[1]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-09 12:46:20.744  - error: host.pi3 Caught by controller[1]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-01-09 12:46:20.746  - error: host.pi3 Caught by controller[2]: Was not able to detect the Linky linky_mode. Default to historique
    2024-01-09 12:46:20.747  - error: host.pi3 Caught by controller[3]: Was not able to detect the Linky energy_phase. Default to single_phase
    2024-01-09 12:46:20.749  - error: host.pi3 Caught by controller[4]: Not able to detect the current tarif. Not filtering any expose...
    2024-01-09 12:46:20.751  - error: host.pi3 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2024-01-09 12:46:20.754  - info: host.pi3 Restart adapter system.adapter.zigbee.0 because enabled
    2024-01-09 12:46:50.920  - info: host.pi3 instance system.adapter.zigbee.0 started with pid 5125
    2024-01-09 12:46:59.981  - info: zigbee.0 (5125) starting. Version 1.9.7 (non-npm: ioBroker/ioBroker.zigbee#ef932ce47a1c5e824031179ce919640a832d1a71) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 4.0.24
    2024-01-09 12:47:00.097  - error: zigbee.0 (5125) Failed to call 'Backup' 'configure' (TypeError: Class extends value undefined is not a constructor or null
    2024-01-09 12:47:00.130  - error: zigbee.0 (5125) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-01-09 12:47:00.132  - error: zigbee.0 (5125) unhandled promise rejection: Class extends value undefined is not a constructor or null
    2024-01-09 12:47:00.134  - error: zigbee.0 (5125) TypeError: Class extends value undefined is not a constructor or null
    2024-01-09 12:47:00.135  - error: zigbee.0 (5125) Class extends value undefined is not a constructor or null
    2024-01-09 12:47:00.158  - info: zigbee.0 (5125) cleaned everything up...
    2024-01-09 12:47:00.502  - warn: zigbee.0 (5125) Failed to stop zigbee during startup
    2024-01-09 12:47:00.504  - info: zigbee.0 (5125) terminating
    2024-01-09 12:47:00.509  - warn: zigbee.0 (5125) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-01-09 12:47:01.624  - warn: zigbee.0 (5125) get state error: DB closed
    2024-01-09 12:47:01.662  - warn: zigbee.0 (5125) get state error: Connection is closed.
    2024-01-09 12:47:01.664  - warn: zigbee.0 (5125) get state error: Connection is closed.
    2024-01-09 12:47:02.109  - error: host.pi3 Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2024-01-09 12:47:02.112  - error: host.pi3 Caught by controller[1]: TypeError: Class extends value undefined is not a constructor or null
    2024-01-09 12:47:02.113  - error: host.pi3 Caught by controller[1]:     at Object.<anonymous> (/opt/iobroker/node_modules/tar/lib/read-entry.js:97:4)
    2024-01-09 12:47:02.114  - error: host.pi3 Caught by controller[1]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-09 12:47:02.116  - error: host.pi3 Caught by controller[1]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-01-09 12:47:02.117  - error: host.pi3 Caught by controller[1]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-01-09 12:47:02.118  - error: host.pi3 Caught by controller[1]:     at Function.Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-01-09 12:47:02.119  - error: host.pi3 Caught by controller[1]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
    2024-01-09 12:47:02.121  - error: host.pi3 Caught by controller[1]:     at require (node:internal/modules/helpers:177:18)
    2024-01-09 12:47:02.122  - error: host.pi3 Caught by controller[1]:     at Object.<anonymous> (/opt/iobroker/node_modules/tar/lib/pack.js:27:19)
    2024-01-09 12:47:02.123  - error: host.pi3 Caught by controller[1]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-09 12:47:02.124  - error: host.pi3 Caught by controller[1]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-01-09 12:47:02.125  - error: host.pi3 Caught by controller[2]: Was not able to detect the Linky linky_mode. Default to historique
    2024-01-09 12:47:02.126  - error: host.pi3 Caught by controller[3]: Was not able to detect the Linky energy_phase. Default to single_phase
    2024-01-09 12:47:02.127  - error: host.pi3 Caught by controller[4]: Not able to detect the current tarif. Not filtering any expose...
    2024-01-09 12:47:02.128  - error: host.pi3 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2024-01-09 12:47:02.130  - info: host.pi3 Restart adapter system.adapter.zigbee.0 because enabled
    Ich hatte sowohl die originale, als auch die Github-Version versucht - beide Male die selben Fehler.
    Merkwürdigerweise nutzt das zurückspielen eines Backups auch nichts.
    Auffällig ist auch der 4-er js-controller, der sich partout nicht auf die 5-er updaten läßt.
    Der "upgrade self --debug" Aufruf schmeißt auch einen Fehler, der im Startlog vom Zigbee immer wieder auftaucht:
    iobroker upgrade self --debug
    Update js-controller from @4.0.24 to @5.0.17
    Stopped Objects DB
    Stopped States DB
    NPM version: 10.2.5
    Installing iobroker.js-controller@5.0.17... (System call)
    npm WARN cleanup Failed to remove some directories [
    npm WARN cleanup   [
    npm WARN cleanup     '/opt/iobroker/node_modules/diskusage',
    npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/diskusage'] {
    npm WARN cleanup       errno: -39,
    npm WARN cleanup       code: 'ENOTEMPTY',
    npm WARN cleanup       syscall: 'rmdir',
    npm WARN cleanup       path: '/opt/iobroker/node_modules/diskusage'
    npm WARN cleanup     }
    npm WARN cleanup   ]
    npm WARN cleanup ]
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh -c node iobroker.js setup first
    npm ERR! /opt/iobroker/node_modules/tar/lib/read-entry.js:97
    npm ERR!   [SLURP] (ex, global) {
    npm ERR!    ^
    npm ERR!
    npm ERR! TypeError: Class extends value undefined is not a constructor or null
    npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/tar/lib/read-entry.js:97:4)
    npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    npm ERR!     at Module.load (node:internal/modules/cjs/loader:1197:32)
    npm ERR!     at Module._load (node:internal/modules/cjs/loader:1013:12)
    npm ERR!     at Module.require (node:internal/modules/cjs/loader:1225:19)
    npm ERR!     at require (node:internal/modules/helpers:177:18)
    npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/tar/lib/pack.js:27:19)
    npm ERR!
    npm ERR! Node.js v18.19.0
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-09T12_05_48_126Z-debug-0.log
    und die Version bleibt auf 4.0.2.4:
    bede@pi3:/opt/iobroker $ iobroker update
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Controller "js-controller": 5.0.17   , installed 4.0.24 [Updatable]
    Adapter    "zigbee"       : 1.9.7    , installed 1.9.7
    Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
    Wäre für jede Hilfe dankbar...
    Bommel
    diag:
                            v.2023-10-10
       Static hostname: pi3
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Installation:           native
    Kernel:                 aarch64
    Userland:               arm64
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    1
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                            /usr/bin/node           v18.19.0
                            /usr/bin/npm            10.2.5
                            /usr/bin/npx            10.2.5
                            /usr/bin/corepack       0.22.0
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:            909M        115M        190M        0.0K        603M        729M
    Swap:            99M         46M         53M
    Total:          1.0G        162M        243M
    Active iob-Instances:   12
    Active repo(s): stable
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.12.0
    ioBroker Status:        iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : ackermannn                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : ackermannn                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                7802
    States:                 7902
    Size of iob-Database:
    136K    /opt/iobroker/iobroker-data/objects.jsonl
    84K     /opt/iobroker/iobroker-data/states.jsonl
    Some problems detected, please run iob fix and try to have them fixed
    • arteckA Offline
      arteckA Offline
      arteck
      @bommelmeier sagte in zigbee-adapter will nicht mehr starten:
      und was hat das mit zgbee adapter zu utn .. ??? änder bitte den Titel.. zigbee-adapter will nicht mehr starten
      und das ist dein Problem
      #Operating System: Debian GNU/Linux 11 (bullseye)
      bring dein System up to date
      • B bommelmeier
        Moin,
        Stopped Objects DB
        Stopped States DB
        NPM version: 10.2.5
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ]
        npm WARN cleanup ]
        npm ERR! code 1
        npm ERR!    ^
        npm ERR!
        npm ERR!
        Bommel
        diag:
                                v.2023-10-10
                 Icon name: computer
              Architecture: arm64
        Kernel:                 aarch64
        Userland:               arm64
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            10.2.5
                                /usr/bin/npx            10.2.5
        MEMORY:
        Swap:            99M         46M         53M
                                admin                   6.12.0
        Objects type: jsonl
        States  type: jsonl
        Objects:                7802
        States:                 7902
        iob stop
        iob fix
        iob start
        B 1 Antwort Letzte Antwort
          iob stop
          iob fix
          iob start
          bommelmeier
          So, erst mal danke für den Schubser.
          Bin jetzt auf Bookworm, mit taufrischem System.
          Der Zigbee-Adapter will aber immer noch nicht korrekt starten, hab ihn auch schon neu installiert.
          Jetzt ist es aber angeblich der Port - was ich mir nun gar nicht erklären kann:
          2024-01-10 00:03:23.702  - info: zigbee.0 (3076) Starting Zigbee  npm ...
          2024-01-10 00:03:25.653  - info: zigbee.0 (3076) Installed Version: iobroker.zigbee@1.9.7
          2024-01-10 00:03:45.939  - error: zigbee.0 (3076) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
          2024-01-10 00:03:45.942  - error: zigbee.0 (3076) Failed to start Zigbee
          2024-01-10 00:03:45.943  - error: zigbee.0 (3076) Error herdsman start
          2024-01-10 00:03:55.956  - info: zigbee.0 (3076) Try to reconnect. 1 attempts left
          2024-01-10 00:03:55.963  - info: zigbee.0 (3076) Starting Zigbee  npm ...
          2024-01-10 00:03:55.995  - info: zigbee.0 (3076) Installed Version: iobroker.zigbee@1.9.7
          2024-01-10 00:03:56.686  - error: zigbee.0 (3076) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
          2024-01-10 00:03:56.692  - error: zigbee.0 (3076) Failed to start Zigbee
          2024-01-10 00:03:56.693  - error: zigbee.0 (3076) Error herdsman start
          Die Einstellungen sollten aber passen:
          /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220708094955-if00
          als Typ TI Z-Stack/CCxxxx
          Neustart ist auch schon gelaufen.
          Hat noch jemand einen Tip?
          • B bommelmeier
            bommelmeier
            Kommando zurück:
            Nach der ganzen Updaterei mußte nochmal der Typ des Adapters umgestellt werden, jetzt hauts wieder hin.
            Fehlt noch das Update vom hc-controller, aber das erst nach Backup.
            Danke.
            Bommel
            Meister MopperM N 2 Antworten Letzte Antwort
            • B bommelmeier
              Kommando zurück:
              Danke.
              Bommel
              Meister MopperM Offline
              Meister Mopper
              @bommelmeier sagte in [gelöst} zigbee-adapter will nicht mehr starten:
              Was bedeutet Typ des Adapters?
              Proxmox und HA ...
              • B bommelmeier
                Kommando zurück:
                Danke.
                Bommel
                N Offline
                N Offline
                n811e
                @bommelmeier
                wie meinst Du das? Was genau hast Du gemacht?
                  Dave83
                  schrieb am zuletzt editiert von Dave83
                  Ist jemand da, der sich mit Discrod auf meinen Rechner schalten könnte?
                  Ich hab den gleichen Fehler. Nun nach einem neustart, kann ich mich nicht verbinden. -.-
                  Bildschirmfoto 2024-02-29 um 20.31.19.png Bildschirmfoto 2024-02-29 um 20.31.31.png
                  @bommelmeier uns hätte es geholfen, wenn du genau gesagt hättest welcher Eintrag sich zurückgestellt hat udn was dort als richtig anerkannt wird.
                  EDIT. geht wieder. Keine Ahnugn warum.
