  4. npm nach "apt upgrade" zerschossen?
12 Beiträge 4 Kommentatoren 1.7k Aufrufe 3 Beobachtet
    Meckii
    schrieb am zuletzt editiert von Meckii
    Nach einem "apt upgrade" bekomme ich bei der Installation eines Adapters folgenden fehler.
    $ iobroker add trashschedule --host miniserver
    /bin/sh: 1: npm: not found
    Error trying to check npm version: Command failed: npm -v/bin/sh: 1: npm: not found
    !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Aborting install because the npm version could not be checked!Please check that npm is installed correctly.
    Use "npm install -g npm@8" or "npm install -g npm@latest" to install a supported version.You need to make sure to repeat this step after installing an update to NodeJS and/or npm!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    ERROR: Process exited with code 30
    Lässt sich das wieder beheben?
    Edit:
    Die genanneten Befehle funktionieren leider nicht...
    install: missing file operand
    Try 'install --help' for more information.
    • M Meckii
      Edit:
      @meckii sagte in npm nach "apt upgrade" zerschossen?:
      iob nodejs-update
      Und Finger weg von den 'npm'-Kommandos!
      • M Meckii
        Edit:
        @meckii bitte iob diag in der Langfassung!
        wie alt ist die Installation? und mach das "empfohlene" bloß nicht!
          iob nodejs-update
          Meckii
          Das hat leider nicht funktioniert
          Fixing your nodejs setup
          *** Deleting  ***
          rm: cannot remove '': No such file or directory
          *** Deleting  ***
          Wrong paths have been fixed. Run 'iob diag' or 'iob node-fix' again to check if your installation is fine now
          Nothing to do - Your version is the recommended one.
          You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
          Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
          iob diag gibt folgendes aus:
          2023-12-29 17:41:36.802  - error: host.raspberry iobroker !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Aborting install because the npm version could not be checked!Please check that npm is installed correctly.Use "npm install -g npm@8" or "npm install -g npm@latest" to install a supported version.You need to make sure to repeat this step after installing an update to NodeJS and/or npm!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          2023-12-29 17:41:37.835  - info: host.raspberry iobroker exit 30
          2023-12-29 17:45:00.019  - info: host.raspberry instance system.adapter.dwd.0 started with pid 84504
          2023-12-29 17:45:01.054  - info: dwd.0 (84504) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
          2023-12-29 17:45:01.970  - info: dwd.0 (84504) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-12-29 17:45:02.484  - info: host.raspberry instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-12-29 17:45:30.814  - info: host.raspberry iobroker add trashschedule --host raspberry
          2023-12-29 17:45:32.015  - error: host.raspberry iobroker /bin/sh: 1: npm: not found
          2023-12-29 17:45:32.017  - error: host.raspberry iobroker Error trying to check npm version: Command failed: npm -v/bin/sh: 1: npm: not found
          2023-12-29 17:45:32.018  - error: host.raspberry iobroker !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Aborting install because the npm version could not be checked!Please check that npm is installed correctly.
          2023-12-29 17:45:32.018  - error: host.raspberry iobroker Use "npm install -g npm@8" or "npm install -g npm@latest" to install a supported version.You need to make sure to repeat this step after installing an update to NodeJS and/or npm!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          2023-12-29 17:45:33.045  - info: host.raspberry iobroker exit 30
          2023-12-29 17:48:43.084  - info: host.raspberry iobroker add trashschedule --host raspberry
          2023-12-29 17:48:44.208  - error: host.raspberry iobroker /bin/sh: 1: npm: not found
          2023-12-29 17:48:44.211  - error: host.raspberry iobroker Error trying to check npm version: Command failed: npm -v/bin/sh: 1: npm: not found
          2023-12-29 17:48:44.213  - error: host.raspberry iobroker !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          2023-12-29 17:48:44.214  - error: host.raspberry iobroker Aborting install because the npm version could not be checked!
          2023-12-29 17:48:44.215  - error: host.raspberry iobroker Please check that npm is installed correctly.
          2023-12-29 17:48:44.216  - error: host.raspberry iobroker Use "npm install -g npm@8" or "npm install -g npm@latest" to install a supported version.
          2023-12-29 17:48:44.219  - error: host.raspberry iobroker You need to make sure to repeat this step after installing an update to NodeJS and/or npm!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          2023-12-29 17:48:45.243  - info: host.raspberry iobroker exit 30
          2023-12-29 17:50:00.021  - info: host.raspberry instance system.adapter.dwd.0 started with pid 84758
          2023-12-29 17:50:01.084  - info: dwd.0 (84758) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
          2023-12-29 17:50:02.354  - info: dwd.0 (84758) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-12-29 17:50:02.872  - info: host.raspberry instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          M HomoranH 2 Antworten Letzte Antwort
          • M Meckii
            *** Deleting  ***
            *** Deleting  ***
            Meckii
            @meckii
            Recommended versions are nodejs 18.19.0 and npm 10.2.3
            *** nodejs is NOT correctly installed ***
            Wrong installation path detected. This needs to be fixed.
            • M Meckii
              *** Deleting  ***
              *** Deleting  ***
              nee, das ist der log!
              iob diag ist viel länger
                Meckii
                @homoran sagte in npm nach "apt upgrade" zerschossen?:
                iob diag
                Sorry
                ======== Start marking the full check here =========
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                 Static hostname: raspberry
                       Icon name: computer
                          Kernel: Linux 6.1.0-rpi7-rpi-2712
                    Architecture: arm64
                Model           : Raspberry Pi 5 Model B Rev 1.0
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : arm64
                Systemuptime and Load:
                 18:00:09 up 2 days, 10:14,  2 users,  load average: 0.42, 0.36, 0.16
                CPU threads: 4
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** Time and Time Zones ***
                               Local time: Fri 2023-12-29 18:00:09 CET
                           Universal time: Fri 2023-12-29 17:00:09 UTC
                                 RTC time: Fri 2023-12-29 17:00:09
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                buehst
                /home/buehst
                buehst adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:       tty
                Boot Target:    multi-user.target
                *** MEMORY ***
                Mem:            8.4G        1.0G        6.5G        5.3M        1.0G        7.4G
                Swap:           104M          0B        104M
                Total:          8.5G        1.0G        6.6G
                         8053 M total memory
                          975 M used memory
                          860 M active memory
                          761 M inactive memory
                         6180 M free memory
                          118 M buffer memory
                          880 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                vc_gencmd_read_response returned -1
                error=1 error_msg="Command not registered"
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** FILESYSTEM ***
                udev           devtmpfs  3.8G     0  3.8G   0% /dev
                tmpfs          tmpfs     806M  5.1M  801M   1% /run
                /dev/mmcblk0p2 ext4       59G   18G   38G  33% /
                tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
                tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
                [Wed Dec 27 07:45:34 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:DA:0C:1A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=04071584-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Wed Dec 27 07:45:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                [Wed Dec 27 07:45:38 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                Show mounted filesystems \(real ones only\):
                TARGET           SOURCE         FSTYPE OPTIONS
                /                /dev/mmcblk0p2 ext4   rw,noatime
                `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                532M    /var/
                218M    /var/cache
                212M    /var/cache/apt
                161M    /var/lib
                132M    /var/lib/apt/lists
                Archived and active journals take up 53.1M in the file system.
                /opt/iobroker/backups:
                4.0K    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                146M    /opt/iobroker/iobroker-data/
                89M     /opt/iobroker/iobroker-data/files
                67M     /opt/iobroker/iobroker-data/files/javascript.admin
                48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                47M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                16M     /opt/iobroker/iobroker-data/objects.jsonl
                7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
                7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
                7.0M    /opt/iobroker/iobroker-data/states.jsonl
                6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                USB-Devices by-id:
                USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
                /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231008111815-if00
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v18.19.0
                /usr/bin/node           v18.19.0
                /home/iobroker/.diag.sh: line 279: npm: command not found
                /home/iobroker/.diag.sh: line 280: npx: command not found
                /home/iobroker/.diag.sh: line 281: corepack: command not found
                /home/iobroker/.diag.sh: line 290: npm: command not found
                /home/iobroker/.diag.sh: line 291: npx: command not found
                nodejs:
                  Installed: 18.19.0+dfsg-6~deb12u1
                  Candidate: 18.19.0+dfsg-6~deb12u1
                  Version table:
                 *** 18.19.0+dfsg-6~deb12u1 500
                        100 /var/lib/dpkg/status
                     18.19.0-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                     18.18.2-1nodesource1 500
                     18.18.1-1nodesource1 500
                     18.18.0-1nodesource1 500
                     18.17.1-1nodesource1 500
                     18.17.0-1nodesource1 500
                     18.16.1-1nodesource1 500
                     18.16.0-1nodesource1 500
                     18.15.0-1nodesource1 500
                     18.14.2-1nodesource1 500
                     18.14.1-1nodesource1 500
                     18.14.0-1nodesource1 500
                     18.13.0+dfsg1-1 500
                     18.13.0-1nodesource1 500
                     18.12.0-1nodesource1 500
                     18.11.0-1nodesource1 500
                     18.10.0-1nodesource1 500
                     18.9.1-1nodesource1 500
                     18.9.0-1nodesource1 500
                     18.8.0-1nodesource1 500
                     18.7.0-1nodesource1 500
                     18.6.0-1nodesource1 500
                     18.5.0-1nodesource1 500
                     18.4.0-1nodesource1 500
                     18.3.0-1nodesource1 500
                     18.2.0-1nodesource1 500
                     18.1.0-1nodesource1 500
                     18.0.0-1nodesource1 500
                No problems detected
                Errors in npm tree:
                /home/iobroker/.diag.sh: line 360: npm: command not found
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                admin:          6.12.0
                javascript:     7.1.6
                /home/iobroker/.diag.sh: line 375: npm: command not found
                Adapters from github:   0
                Adapter State
                + system.adapter.admin.0                  : admin                 : raspberry                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.backitup.0               : backitup              : raspberry                               - disabled
                + system.adapter.discovery.0              : discovery             : raspberry                               -  enabled
                  system.adapter.dwd.0                    : dwd                   : raspberry                               -  enabled
                + system.adapter.javascript.0             : javascript            : raspberry                               -  enabled
                + system.adapter.lametric.0               : lametric              : raspberry                               -  enabled
                + system.adapter.ping.0                   : ping                  : raspberry                               -  enabled
                + system.adapter.pushsafer.0              : pushsafer             : raspberry                               -  enabled
                + system.adapter.shelly.0                 : shelly                : raspberry                               -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.zigbee.0                 : zigbee                : raspberry                               -  enabled, port: /dev/ttyACM0
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "admin"        : 6.12.0   , installed 6.12.0
                Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                Controller "js-controller": 5.0.17   , installed 5.0.17
                Adapter    "lametric"     : 3.1.1    , installed 3.1.2
                Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
                Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                Adapter    "web"          : 6.1.10   , installed 6.1.10
                Adapter    "ws"           : 2.5.8    , installed 2.5.8
                Adapter    "zigbee"       : 1.8.25   , installed 1.9.3
                Objects and States
                Objects:        820
                States:         565
                Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1158090    87024/iobroker.js-c
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1158083    87024/iobroker.js-c
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14940      791/sshd: /usr/sbin
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1159786    87042/io.admin.0
                tcp6       0      0 :::22                   :::*                    LISTEN      0          14942      791/sshd: /usr/sbin
                udp        0      0 0.0.0.0:49602           0.0.0.0:*                           104        14860      676/avahi-daemon: r
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14858      676/avahi-daemon: r
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       1160569    87075/io.shelly.0
                udp6       0      0 fe80::8025:66f6:35d:546 :::*                                0          16215      756/NetworkManager
                udp6       0      0 :::41903                :::*                                104        14861      676/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                104        14859      676/avahi-daemon: r
                2023-12-29 17:57:44.293  - info: zigbee.0 (87116) 0xbc026efffe5ecfc7 (addr 56408): LED2003G10 - IKEA TRADFRI LED bulb E26/27 1100/1055/1160 lumen, dimmable, white spectrum, opal white (Router)
                2023-12-29 17:57:44.294  - info: zigbee.0 (87116) 0x0ceff6fffedc04d6 (addr 53326): SNZB-02D - SONOFF Temperature and humidity sensor with screen (EndDevice)
                2023-12-29 17:57:44.295  - info: zigbee.0 (87116) 0x287681fffe1bf3ff (addr 26190): E2213 - IKEA SOMRIG shortcut button (EndDevice)
                2023-12-29 17:57:44.295  - info: zigbee.0 (87116) 0x287681fffe4a0732 (addr 41650): E2213 - IKEA SOMRIG shortcut button (EndDevice)
                2023-12-29 17:57:44.295  - info: zigbee.0 (87116) Zigbee started
                2023-12-29 17:57:44.321  - info: zigbee.0 (87116) debug devices set to []
                2023-12-29 17:57:44.447  - info: host.raspberry instance scheduled system.adapter.dwd.0 */5 * * * *
                2023-12-29 17:57:44.451  - info: host.raspberry instance system.adapter.dwd.0 started with pid 87154
                2023-12-29 17:57:44.465  - info: shelly.0 (87075) [CoAP] Device 192.168.7.22 (shelly1pm / shelly1pm-8CAAB57780EB / SHSW-PM#8CAAB57780EB#1) connected! Polltime set to 15 sec.
                2023-12-29 17:57:45.920  - info: dwd.0 (87154) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
                2023-12-29 17:57:46.229  - info: dwd.0 (87154) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2023-12-29 17:57:46.753  - info: host.raspberry instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-12-29 17:57:48.423  - info: host.raspberry instance system.adapter.pushsafer.0 started with pid 87171
                2023-12-29 17:57:49.258  - info: pushsafer.0 (87171) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.pushsafer, node: v18.19.0, js-controller: 5.0.17
                2023-12-29 17:57:52.428  - info: host.raspberry instance system.adapter.lametric.0 started with pid 87188
                2023-12-29 17:57:53.601  - info: lametric.0 (87188) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.lametric, node: v18.19.0, js-controller: 5.0.17
                2023-12-29 17:57:53.622  - info: lametric.0 (87188) Starting - connecting to http://192.168.7.20:8080
                2023-12-29 17:58:14.583  - warn: zigbee.0 (87116) DeviceAvailability:Failed to ping 0xa4c138a49d0cd3db TS011F
                2023-12-29 17:58:14.771  - warn: zigbee.0 (87116) DeviceAvailability:Failed to ping 0xf082c0fffe008e6e TRADFRI bulb E14 WS globe 470lm
                2023-12-29 17:58:14.967  - warn: zigbee.0 (87116) DeviceAvailability:Failed to ping 0xbc026efffe5ecfc7 TRADFRIbulbE27WSglobeopal1055lm
                2023-12-29 17:59:47.161  - info: admin.0 (87042) ==> Connected system.user.admin from ::ffff:192.168.7.31
                2023-12-29 18:00:00.030  - info: host.raspberry instance system.adapter.dwd.0 started with pid 88367
                2023-12-29 18:00:01.146  - info: dwd.0 (88367) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
                2023-12-29 18:00:02.504  - info: dwd.0 (88367) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2023-12-29 18:00:03.020  - info: host.raspberry instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                iob diag has finished.
                Press any key for a summary
                  Meckii
                  Copy text starting here:
                                          v.2023-10-10
                         Icon name: computer
                      Architecture: arm64
                  Installation:           native
                  Kernel:                 aarch64
                  Userland:               arm64
                  Timezone:               Europe/Berlin (CET, +0100)
                  User-ID:                1000
                  X-Server:               false
                  Pending OS-Updates:     0
                  Pending iob updates:    0
                  Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                  /home/iobroker/.diag.sh: line 488: npm: command not found
                  /home/iobroker/.diag.sh: line 489: npx: command not found
                  /home/iobroker/.diag.sh: line 490: corepack: command not found
                  Please check
                  for more information on how to fix these errors.
                  MEMORY:
                  Mem:            8.4G        1.1G        6.5G        5.4M        1.0G        7.4G
                  Swap:           104M          0B        104M
                  Total:          8.5G        1.1G        6.6G
                  Active iob-Instances:   9
                  ioBroker Core:          js-controller           5.0.17
                                          admin                   6.12.0
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                820
                  States:                 565
                  Size of iob-Database:
                  === Mark text until here for copying ===
                  • M Meckii
                    iob diag
                    Sorry
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                    CPU threads: 4
                    Current issues:
                                  NTP service: active
                              RTC in local TZ: no
                    buehst
                    /home/buehst
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:           104M          0B        104M
                             8053 M total memory
                              975 M used memory
                              860 M active memory
                             6180 M free memory
                              118 M buffer memory
                              880 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    *** FILESYSTEM ***
                    /var:
                    532M    /var/
                    218M    /var/cache
                    212M    /var/cache/apt
                    161M    /var/lib
                    USB-Devices by-id:
                    nodejs:
                      Version table:
                         18.13.0+dfsg1-1 500
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        820
                    States:         565
                    Pending Updates: 0
                    @Thomas-Braun hat dazu einen Thread eröffnet
                    https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur/1
                      Meckii
                      Das hat funktioniert! Vielen Dank!
                      Ich dachte schon ich müsste den rpi schon wieder neu aufsetzen ;-)
                      Dieses Forum ist echt spitze!
                      Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
                      • M Meckii
                        Meister MopperM Online
                        Meister Mopper
                        schrieb am zuletzt editiert von Meister Mopper
                        @meckii
                        Das hatte ich vor 2 Tagen auch, und es war ein sudo apt update && sudo apt full-upgrade, das mir ein "neues" nodejs 18.19.0 angeboten hat.
                        Ich habe es ausgeführt, und danach war npm nicht mehr vorhanden.
                        iob nodejs-update hat mir anschließend den Arsch gerettet.
                        Proxmox und HA ...
                        • M Meckii
                          Das muss man eigentlich nie. Außer beim Upgrade auf 'Bookworm', da sollte man es schon frisch neu aufsetzen.
