  4. npm nach "apt upgrade" zerschossen?
12 Beiträge 4 Kommentatoren 1.7k Aufrufe 3 Beobachtet
  • M Meckii
    Nach einem "apt upgrade" bekomme ich bei der Installation eines Adapters folgenden fehler.
    $ iobroker add trashschedule --host miniserver
    /bin/sh: 1: npm: not found
    Error trying to check npm version: Command failed: npm -v/bin/sh: 1: npm: not found
    !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Aborting install because the npm version could not be checked!Please check that npm is installed correctly.
    Use "npm install -g npm@8" or "npm install -g npm@latest" to install a supported version.You need to make sure to repeat this step after installing an update to NodeJS and/or npm!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    ERROR: Process exited with code 30
    Lässt sich das wieder beheben?
    Edit:
    Die genanneten Befehle funktionieren leider nicht...
    install: missing file operand
    Try 'install --help' for more information.
    @meckii sagte in npm nach "apt upgrade" zerschossen?:
    iob nodejs-update
    Und Finger weg von den 'npm'-Kommandos!
    • M Meckii
      Edit:
      @meckii bitte iob diag in der Langfassung!
      wie alt ist die Installation? und mach das "empfohlene" bloß nicht!
        iob nodejs-update
        Meckii
        Das hat leider nicht funktioniert
        Fixing your nodejs setup
        *** Deleting  ***
        rm: cannot remove '': No such file or directory
        *** Deleting  ***
        Wrong paths have been fixed. Run 'iob diag' or 'iob node-fix' again to check if your installation is fine now
        Nothing to do - Your version is the recommended one.
        You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
        Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
        iob diag gibt folgendes aus:
        2023-12-29 17:41:36.802  - error: host.raspberry iobroker !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Aborting install because the npm version could not be checked!Please check that npm is installed correctly.Use "npm install -g npm@8" or "npm install -g npm@latest" to install a supported version.You need to make sure to repeat this step after installing an update to NodeJS and/or npm!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
        2023-12-29 17:41:37.835  - info: host.raspberry iobroker exit 30
        2023-12-29 17:45:00.019  - info: host.raspberry instance system.adapter.dwd.0 started with pid 84504
        2023-12-29 17:45:01.054  - info: dwd.0 (84504) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
        2023-12-29 17:45:01.970  - info: dwd.0 (84504) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-12-29 17:45:02.484  - info: host.raspberry instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-12-29 17:45:30.814  - info: host.raspberry iobroker add trashschedule --host raspberry
        2023-12-29 17:45:32.015  - error: host.raspberry iobroker /bin/sh: 1: npm: not found
        2023-12-29 17:45:32.017  - error: host.raspberry iobroker Error trying to check npm version: Command failed: npm -v/bin/sh: 1: npm: not found
        2023-12-29 17:45:32.018  - error: host.raspberry iobroker !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Aborting install because the npm version could not be checked!Please check that npm is installed correctly.
        2023-12-29 17:45:32.018  - error: host.raspberry iobroker Use "npm install -g npm@8" or "npm install -g npm@latest" to install a supported version.You need to make sure to repeat this step after installing an update to NodeJS and/or npm!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
        2023-12-29 17:45:33.045  - info: host.raspberry iobroker exit 30
        2023-12-29 17:48:43.084  - info: host.raspberry iobroker add trashschedule --host raspberry
        2023-12-29 17:48:44.208  - error: host.raspberry iobroker /bin/sh: 1: npm: not found
        2023-12-29 17:48:44.211  - error: host.raspberry iobroker Error trying to check npm version: Command failed: npm -v/bin/sh: 1: npm: not found
        2023-12-29 17:48:44.213  - error: host.raspberry iobroker !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
        2023-12-29 17:48:44.214  - error: host.raspberry iobroker Aborting install because the npm version could not be checked!
        2023-12-29 17:48:44.215  - error: host.raspberry iobroker Please check that npm is installed correctly.
        2023-12-29 17:48:44.216  - error: host.raspberry iobroker Use "npm install -g npm@8" or "npm install -g npm@latest" to install a supported version.
        2023-12-29 17:48:44.219  - error: host.raspberry iobroker You need to make sure to repeat this step after installing an update to NodeJS and/or npm!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
        2023-12-29 17:48:45.243  - info: host.raspberry iobroker exit 30
        2023-12-29 17:50:00.021  - info: host.raspberry instance system.adapter.dwd.0 started with pid 84758
        2023-12-29 17:50:01.084  - info: dwd.0 (84758) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
        2023-12-29 17:50:02.354  - info: dwd.0 (84758) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-12-29 17:50:02.872  - info: host.raspberry instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        M HomoranH 2 Antworten Letzte Antwort
        • M Meckii
          *** Deleting  ***
          *** Deleting  ***
          Meckii
          @meckii
          Recommended versions are nodejs 18.19.0 and npm 10.2.3
          *** nodejs is NOT correctly installed ***
          Wrong installation path detected. This needs to be fixed.
          • M Meckii
            *** Deleting  ***
            *** Deleting  ***
            nee, das ist der log!
            iob diag ist viel länger
              Meckii
              schrieb am zuletzt editiert von Meckii
              @homoran sagte in npm nach "apt upgrade" zerschossen?:
              iob diag
              Sorry
              Skript v.2023-10-10
              *** BASE SYSTEM ***
               Static hostname: raspberry
                     Icon name: computer
                        Kernel: Linux 6.1.0-rpi7-rpi-2712
                  Architecture: arm64
              Model           : Raspberry Pi 5 Model B Rev 1.0
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : arm64
              Systemuptime and Load:
               18:00:09 up 2 days, 10:14,  2 users,  load average: 0.42, 0.36, 0.16
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                             Local time: Fri 2023-12-29 18:00:09 CET
                         Universal time: Fri 2023-12-29 17:00:09 UTC
                               RTC time: Fri 2023-12-29 17:00:09
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              buehst
              /home/buehst
              buehst adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:            8.4G        1.0G        6.5G        5.3M        1.0G        7.4G
              Swap:           104M          0B        104M
              Total:          8.5G        1.0G        6.6G
                       8053 M total memory
                        975 M used memory
                        860 M active memory
                        761 M inactive memory
                       6180 M free memory
                        118 M buffer memory
                        880 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              vc_gencmd_read_response returned -1
              error=1 error_msg="Command not registered"
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              udev           devtmpfs  3.8G     0  3.8G   0% /dev
              tmpfs          tmpfs     806M  5.1M  801M   1% /run
              /dev/mmcblk0p2 ext4       59G   18G   38G  33% /
              tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
              tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
              /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
              tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
              [Wed Dec 27 07:45:34 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:DA:0C:1A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=04071584-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Wed Dec 27 07:45:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Wed Dec 27 07:45:38 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              TARGET           SOURCE         FSTYPE OPTIONS
              /                /dev/mmcblk0p2 ext4   rw,noatime
              `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              532M    /var/
              218M    /var/cache
              212M    /var/cache/apt
              161M    /var/lib
              132M    /var/lib/apt/lists
              Archived and active journals take up 53.1M in the file system.
              /opt/iobroker/backups:
              4.0K    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              146M    /opt/iobroker/iobroker-data/
              89M     /opt/iobroker/iobroker-data/files
              67M     /opt/iobroker/iobroker-data/files/javascript.admin
              48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
              47M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              16M     /opt/iobroker/iobroker-data/objects.jsonl
              7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
              7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
              7.0M    /opt/iobroker/iobroker-data/states.jsonl
              6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
              USB-Devices by-id:
              /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231008111815-if00
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.19.0
              /usr/bin/node           v18.19.0
              /home/iobroker/.diag.sh: line 279: npm: command not found
              /home/iobroker/.diag.sh: line 280: npx: command not found
              /home/iobroker/.diag.sh: line 281: corepack: command not found
              /home/iobroker/.diag.sh: line 290: npm: command not found
              /home/iobroker/.diag.sh: line 291: npx: command not found
              nodejs:
                Installed: 18.19.0+dfsg-6~deb12u1
                Candidate: 18.19.0+dfsg-6~deb12u1
                Version table:
               *** 18.19.0+dfsg-6~deb12u1 500
                      500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                   18.19.0-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                   18.18.2-1nodesource1 500
                   18.18.1-1nodesource1 500
                   18.18.0-1nodesource1 500
                   18.17.1-1nodesource1 500
                   18.17.0-1nodesource1 500
                   18.16.1-1nodesource1 500
                   18.16.0-1nodesource1 500
                   18.15.0-1nodesource1 500
                   18.14.2-1nodesource1 500
                   18.14.1-1nodesource1 500
                   18.14.0-1nodesource1 500
                   18.13.0+dfsg1-1 500
                      500 http://deb.debian.org/debian bookworm/main arm64 Packages
                   18.13.0-1nodesource1 500
                   18.12.0-1nodesource1 500
                   18.11.0-1nodesource1 500
                   18.10.0-1nodesource1 500
                   18.9.1-1nodesource1 500
                   18.9.0-1nodesource1 500
                   18.8.0-1nodesource1 500
                   18.7.0-1nodesource1 500
                   18.6.0-1nodesource1 500
                   18.5.0-1nodesource1 500
                   18.4.0-1nodesource1 500
                   18.3.0-1nodesource1 500
                   18.2.0-1nodesource1 500
                   18.1.0-1nodesource1 500
                   18.0.0-1nodesource1 500
              No problems detected
              Errors in npm tree:
              /home/iobroker/.diag.sh: line 360: npm: command not found
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              admin:          6.12.0
              javascript:     7.1.6
              /home/iobroker/.diag.sh: line 375: npm: command not found
              Adapters from github:   0
              Adapter State
              + system.adapter.admin.0                  : admin                 : raspberry                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.backitup.0               : backitup              : raspberry                               - disabled
              + system.adapter.discovery.0              : discovery             : raspberry                               -  enabled
                system.adapter.dwd.0                    : dwd                   : raspberry                               -  enabled
              + system.adapter.javascript.0             : javascript            : raspberry                               -  enabled
              + system.adapter.lametric.0               : lametric              : raspberry                               -  enabled
              + system.adapter.ping.0                   : ping                  : raspberry                               -  enabled
              + system.adapter.pushsafer.0              : pushsafer             : raspberry                               -  enabled
              + system.adapter.shelly.0                 : shelly                : raspberry                               -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.zigbee.0                 : zigbee                : raspberry                               -  enabled, port: /dev/ttyACM0
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "backitup"     : 2.9.8    , installed 2.9.8
              Adapter    "discovery"    : 4.2.0    , installed 4.2.0
              Adapter    "javascript"   : 7.1.6    , installed 7.1.6
              Controller "js-controller": 5.0.17   , installed 5.0.17
              Adapter    "lametric"     : 3.1.1    , installed 3.1.2
              Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
              Adapter    "shelly"       : 6.6.1    , installed 6.6.1
              Adapter    "socketio"     : 6.6.0    , installed 6.6.0
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Adapter    "zigbee"       : 1.8.25   , installed 1.9.3
              Objects and States
              Objects:        820
              States:         565
              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1158090    87024/iobroker.js-c
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1158083    87024/iobroker.js-c
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14940      791/sshd: /usr/sbin
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1159786    87042/io.admin.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          14942      791/sshd: /usr/sbin
              udp        0      0 0.0.0.0:49602           0.0.0.0:*                           104        14860      676/avahi-daemon: r
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14858      676/avahi-daemon: r
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       1160569    87075/io.shelly.0
              udp6       0      0 fe80::8025:66f6:35d:546 :::*                                0          16215      756/NetworkManager
              udp6       0      0 :::41903                :::*                                104        14861      676/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                104        14859      676/avahi-daemon: r
              2023-12-29 17:57:44.293  - info: zigbee.0 (87116) 0xbc026efffe5ecfc7 (addr 56408): LED2003G10 - IKEA TRADFRI LED bulb E26/27 1100/1055/1160 lumen, dimmable, white spectrum, opal white (Router)
              2023-12-29 17:57:44.294  - info: zigbee.0 (87116) 0x0ceff6fffedc04d6 (addr 53326): SNZB-02D - SONOFF Temperature and humidity sensor with screen (EndDevice)
              2023-12-29 17:57:44.295  - info: zigbee.0 (87116) 0x287681fffe1bf3ff (addr 26190): E2213 - IKEA SOMRIG shortcut button (EndDevice)
              2023-12-29 17:57:44.295  - info: zigbee.0 (87116) 0x287681fffe4a0732 (addr 41650): E2213 - IKEA SOMRIG shortcut button (EndDevice)
              2023-12-29 17:57:44.295  - info: zigbee.0 (87116) Zigbee started
              2023-12-29 17:57:44.321  - info: zigbee.0 (87116) debug devices set to []
              2023-12-29 17:57:44.447  - info: host.raspberry instance scheduled system.adapter.dwd.0 */5 * * * *
              2023-12-29 17:57:44.451  - info: host.raspberry instance system.adapter.dwd.0 started with pid 87154
              2023-12-29 17:57:44.465  - info: shelly.0 (87075) [CoAP] Device 192.168.7.22 (shelly1pm / shelly1pm-8CAAB57780EB / SHSW-PM#8CAAB57780EB#1) connected! Polltime set to 15 sec.
              2023-12-29 17:57:45.920  - info: dwd.0 (87154) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
              2023-12-29 17:57:46.229  - info: dwd.0 (87154) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-12-29 17:57:46.753  - info: host.raspberry instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-12-29 17:57:48.423  - info: host.raspberry instance system.adapter.pushsafer.0 started with pid 87171
              2023-12-29 17:57:49.258  - info: pushsafer.0 (87171) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.pushsafer, node: v18.19.0, js-controller: 5.0.17
              2023-12-29 17:57:52.428  - info: host.raspberry instance system.adapter.lametric.0 started with pid 87188
              2023-12-29 17:57:53.601  - info: lametric.0 (87188) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.lametric, node: v18.19.0, js-controller: 5.0.17
              2023-12-29 17:57:53.622  - info: lametric.0 (87188) Starting - connecting to http://192.168.7.20:8080
              2023-12-29 17:58:14.583  - warn: zigbee.0 (87116) DeviceAvailability:Failed to ping 0xa4c138a49d0cd3db TS011F
              2023-12-29 17:58:14.771  - warn: zigbee.0 (87116) DeviceAvailability:Failed to ping 0xf082c0fffe008e6e TRADFRI bulb E14 WS globe 470lm
              2023-12-29 17:58:14.967  - warn: zigbee.0 (87116) DeviceAvailability:Failed to ping 0xbc026efffe5ecfc7 TRADFRIbulbE27WSglobeopal1055lm
              2023-12-29 17:59:47.161  - info: admin.0 (87042) ==> Connected system.user.admin from ::ffff:192.168.7.31
              2023-12-29 18:00:00.030  - info: host.raspberry instance system.adapter.dwd.0 started with pid 88367
              2023-12-29 18:00:01.146  - info: dwd.0 (88367) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
              2023-12-29 18:00:02.504  - info: dwd.0 (88367) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-12-29 18:00:03.020  - info: host.raspberry instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              iob diag has finished.
              Press any key for a summary
                Meckii
                Copy text starting here:
                                        v.2023-10-10
                       Icon name: computer
                    Architecture: arm64
                Kernel:                 aarch64
                Userland:               arm64
                Timezone:               Europe/Berlin (CET, +0100)
                User-ID:                1000
                X-Server:               false
                Pending OS-Updates:     0
                Pending iob updates:    0
                Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                /home/iobroker/.diag.sh: line 488: npm: command not found
                /home/iobroker/.diag.sh: line 489: npx: command not found
                /home/iobroker/.diag.sh: line 490: corepack: command not found
                Please check
                https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                for more information on how to fix these errors.
                MEMORY:
                Mem:            8.4G        1.1G        6.5G        5.4M        1.0G        7.4G
                Swap:           104M          0B        104M
                Total:          8.5G        1.1G        6.6G
                Active iob-Instances:   9
                ioBroker Core:          js-controller           5.0.17
                                        admin                   6.12.0
                Objects type: jsonl
                States  type: jsonl
                Objects:                820
                States:                 565
                Size of iob-Database:
                === Mark text until here for copying ===
                • M Meckii
                  iob diag
                  Sorry
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                  CPU threads: 4
                  Current issues:
                                NTP service: active
                            RTC in local TZ: no
                  buehst
                  /home/buehst
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:           104M          0B        104M
                           8053 M total memory
                            975 M used memory
                            860 M active memory
                           6180 M free memory
                            118 M buffer memory
                            880 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  *** FILESYSTEM ***
                  /var:
                  532M    /var/
                  218M    /var/cache
                  212M    /var/cache/apt
                  161M    /var/lib
                  USB-Devices by-id:
                  nodejs:
                    Version table:
                       18.13.0+dfsg1-1 500
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.0
                  javascript:     7.1.6
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        820
                  States:         565
                  Pending Updates: 0
                  @Thomas-Braun hat dazu einen Thread eröffnet
                  https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur/1
                    Meckii
                    Das hat funktioniert! Vielen Dank!
                    Ich dachte schon ich müsste den rpi schon wieder neu aufsetzen ;-)
                    Dieses Forum ist echt spitze!
                    Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
                    • M Meckii
                      Meister MopperM Online
                      Meister Mopper
                      schrieb am zuletzt editiert von Meister Mopper
                      @meckii
                      Das hatte ich vor 2 Tagen auch, und es war ein sudo apt update && sudo apt full-upgrade, das mir ein "neues" nodejs 18.19.0 angeboten hat.
                      Ich habe es ausgeführt, und danach war npm nicht mehr vorhanden.
                      iob nodejs-update hat mir anschließend den Arsch gerettet.
                      Proxmox und HA ...
                      • M Meckii
                        Das muss man eigentlich nie. Außer beim Upgrade auf 'Bookworm', da sollte man es schon frisch neu aufsetzen.
