  4. <gelöst> Serieller Port defekt
    6.8k
362 Beiträge 11 Kommentatoren 87.5k Aufrufe 9 Beobachtet
  • S searcher57
    @homoran said in Meldungen beim/nach Upgrade:
    ich bekomme die Daten als User nicht auf den Pi5
    pi@ioBrokerpi5:~ $ groups
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    pi@ioBrokerpi5:~ $ ls -la /media/usbplatte/backups
    total 77732
    drwxr-xr-x 2 iobroker iobroker    4096 Apr 11 04:22 .
    drwxr-xr-x 4 root     root        4096 Dec 25 13:08 ..
    -rw-r--r-- 1 iobroker iobroker 4680106 Mar 16 01:36 homematic_2024_03_16-01_36_12_3.71.12_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 4813226 Mar 19 01:36 homematic_2024_03_19-01_36_12_3.73.9_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 4813226 Mar 22 01:36 homematic_2024_03_22-01_36_12_3.73.9_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 4813226 Mar 25 01:36 homematic_2024_03_25-01_36_11_3.73.9_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 4813226 Mar 28 01:36 homematic_2024_03_28-01_36_11_3.73.9_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 4813226 Mar 31 01:36 homematic_2024_03_31-01_36_11_3.73.9_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 4813226 Apr  1 01:36 homematic_2024_04_01-01_36_11_3.73.9_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 4813226 Apr  4 01:36 homematic_2024_04_04-01_36_11_3.73.9_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 4813226 Apr  7 01:36 homematic_2024_04_07-01_36_11_3.73.9_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 4813226 Apr 10 01:36 homematic_2024_04_10-01_36_11_3.73.9_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 3148949 Apr  2 04:22 iobroker_2024_04_02-04_22_10_backupiobroker.tar.gz
    -rw-r--r-- 1 iobroker iobroker 3154652 Apr  3 04:22 iobroker_2024_04_03-04_22_10_backupiobroker.tar.gz
    -rw-r--r-- 1 iobroker iobroker 3154705 Apr  4 04:22 iobroker_2024_04_04-04_22_10_backupiobroker.tar.gz
    -rw-r--r-- 1 iobroker iobroker 3155077 Apr  5 04:22 iobroker_2024_04_05-04_22_10_backupiobroker.tar.gz
    -rw-r--r-- 1 iobroker iobroker 3153078 Apr  6 04:22 iobroker_2024_04_06-04_22_10_backupiobroker.tar.gz
    -rw-r--r-- 1 iobroker iobroker 3152355 Apr  7 04:22 iobroker_2024_04_07-04_22_10_backupiobroker.tar.gz
    -rw-r--r-- 1 iobroker iobroker 3153662 Apr  8 04:22 iobroker_2024_04_08-04_22_10_backupiobroker.tar.gz
    -rw-r--r-- 1 iobroker iobroker 3153630 Apr  9 04:22 iobroker_2024_04_09-04_22_10_backupiobroker.tar.gz
    -rw-r--r-- 1 iobroker iobroker 3157581 Apr 10 04:22 iobroker_2024_04_10-04_22_10_backupiobroker.tar.gz
    -rw-r--r-- 1 iobroker iobroker 3157378 Apr 11 04:22 iobroker_2024_04_11-04_22_10_backupiobroker.tar.gz
    pi@ioBrokerpi5:~ $
    Entschuldigung, ich weiß nicht, ob ich hier mit meinem Problem im richtigen Thred bin?
    Ich habe das gleiche Problem, dass ich nach Umstellung auf Raspi5 die Instanz smartmeter nicht mehr gestartet bekomme. Der Stromzähler ISKRA liefert laut Handykamera noch Daten und beim Raspi4 sind die auch erkannt worden. Beim Raspi5 kann man nicht mehr "/dev/tty0/" aktivieren. Die Auswahl "/dev/ttyAM0/" und "/dev/ttyAM10/" funktionieren auch nicht.
    Hängt das mit meinem Problem zusammen, dass die GPIO Eingänge für die Gaszählerauslesung per Reed-Kontakt nicht mehr funktionieren?
    #181
    @searcher57 sagte in <gelöst> Serieller Port defekt:
    jetzt bist du es
      @searcher57
      Hängt der Lesekopf denn an den GPIOs dran oder wie ist der an den RPi angebunden?
      Wenn USB, dann verwende die 'by-id'-Links zu dem Gerät.
      Finden sich in der Langfassung von
      iob diag
      searcher57
      #182
      @thomas-braun said in <gelöst> Serieller Port defekt:
      @searcher57
      iob diag
      Ja, der Lesekopf hängt direkt an GPIO 14/15 und 3,3V/GND. Und ich lese ihn über bisher erfolgreich über smartmeter aus.
        @thomas-braun sagte in Meldungen beim/nach Upgrade:
        an den GPIOs dran
        hat er in dem anderen Thread gesagt.
        searcher57
        #183
        @homoran said in <gelöst> Serieller Port defekt:
        an den GPIOs dran
        Danke, dass du mir auch sonst folgst!
          @searcher57 sagte in Meldungen beim/nach Upgrade:
          woher weisst du das?
          es flackert etwas. oder kannst du mit dem Auge den Code erkennen?
          searcher57
          #184
          Natürlich nicht, aber ich deute das Flackern auf einen funktionsfähigen Stromzähler incl. IR Schnittstelle, oder...?
          S HomoranH 2 Antworten Letzte Antwort
          • S searcher57
            searcher57
            #185
            @searcher57 said in <gelöst> Serieller Port defekt:
            Screen hat ja auch vorher gefunzt!
            • S searcher57
              #186
              @searcher57 oder!
              das Flackern könnte zu schwach geworden sein, vorübergehend aussetzen u.a.
              Aber ISKRA (welcher auch immer) ist mMn nicht einer der üblichen Verdächtigen bei schnell alternder IR LED.
              Hatces denn auf dem Pi5 jemals geklappt?
              S 2 Antworten Letzte Antwort
                @searcher57 oder!
                searcher57
                #187
                @searcher57 oder!
                Eben nicht!
                  @searcher57 oder!
                  searcher57
                  #188
                  @searcher57 oder!
                  1 ISK00 7652 0745!
                  • S searcher57
                    @searcher57 oder!
                    Eben nicht!
                    #189
                    @searcher57 hast du die gpios in der raspi-config freigegeben?
                    Ich weiß allerdings nicht ob das auch die serielle Schnittstelle betrifft. ( @thomas-braun ?)
                    vor was?
                      vor was?
                      searcher57
                      #190
                      vor was?
                      Vor der Umstellung von Raspi 4 auf 5.
                      • S searcher57
                        @searcher57 oder!
                        1 ISK00 7652 0745!
                        #191
                        1 ISK00 7652 0745!
                        heiist was?
                        bei der Suche
                        https://forum.iobroker.net/search?term=iskra Lesekopf &in=titlesposts
                        gibt es Modellbezeichnungen
                          1 ISK00 7652 0745!
                          heiist was?
                          bei der Suche
                          searcher57
                          #192
                          1 ISK00 7652 0745!
                          heiist was?
                          bei der Suche
                          Vielleicht hilft dir das, sonst sag mir bitte, was du benötigst.
                          ![dbcef135-7db7-4b97-bdb7-4b97-b118-50ced08b0637-iskra-resized.jpg)
                          • S searcher57
                            1 ISK00 7652 0745!
                            heiist was?
                            bei der Suche
                            #193
                            was du benötigst.
                            mt681 steht da.
                            Die privaten Daten musst du nicht zeigen, hab das Bild entfernt
                              was du benötigst.
                              mt681 steht da.
                              searcher57
                              #194
                              was du benötigst.
                              mt681 steht da.
                              Ok, tut mir leid. Unkenntnis!
                                1 ISK00 7652 0745!
                                heiist was?
                                bei der Suche
                                searcher57
                                #195
                                1 ISK00 7652 0745!
                                heiist was?
                                bei der Suche
                                Das ist der Lesekopf.
                                https://www.ebay.de/itm/353940190755?chn=ps&_ul=DE&_trkparms=ispr%3D1&amdata=enc%3A1n5znC_DWSPyLz0b7QABA8Q6&norover=1&mkevt=1&mkrid=707-134425-41852-0&mkcid=2&mkscid=101&itemid=353940190755&targetid=1716911581159&device=c&mktype=pla&googleloc=9044695&poi=&campaignid=17943303986&mkgroupid=140642150118&rlsatarget=pla-1716911581159&abcId=9301060&merchantid=7364532&gad_source=1&gclid=Cj0KCQjw2uiwBhCXARIsACMvIU1Z0kavXWY8vOFHKHIE93k8DNIswS5wKNf2-8lKhjPm3DexnRb-gTcaAr1eEALw_wcB
                                • S searcher57
                                  1 ISK00 7652 0745!
                                  heiist was?
                                  bei der Suche
                                  #196
                                  der dürfte IMHO nicht der Übeltäter sein, wenn er am pi4 funktionierte.
                                    searcher57
                                    #197
                                    Sondern? Ich bin doch mit meinem Latein am Ende.
                                    • S searcher57
                                      #198
                                      Sondern
                                      entweder der Zähler oder die Anbindung an den GPIOs statt an USB.
                                      • S searcher57
                                        #199
                                        Hab nicht tiefer gebuddelt, aber in
                                        sudo raspi-config
                                        ist die Serielle Schnittstelle aktiviert?
                                          Sondern
                                          searcher57
                                          #200
                                          Sondern
                                          Sorry, aber genau die Anbindung hat an Raspi4 funktioniert! Über GPIo14 und 15 und der Versorgung 3,3V! Die Aktivierung über sudo raspi-config habe ich auch vorgenommen.
