  4. <gelöst> Serieller Port defekt
    6.8k
362 Beiträge 11 Kommentatoren 87.5k Aufrufe 9 Beobachtet
    ich bekomme die Daten als User nicht auf den Pi5
    pi@ioBrokerpi5:~ $ groups
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    pi@ioBrokerpi5:~ $ ls -la /media/usbplatte/backups
    total 77732
    drwxr-xr-x 2 iobroker iobroker    4096 Apr 11 04:22 .
    drwxr-xr-x 4 root     root        4096 Dec 25 13:08 ..
    -rw-r--r-- 1 iobroker iobroker 4680106 Mar 16 01:36 homematic_2024_03_16-01_36_12_3.71.12_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 4813226 Mar 19 01:36 homematic_2024_03_19-01_36_12_3.73.9_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 4813226 Mar 22 01:36 homematic_2024_03_22-01_36_12_3.73.9_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 4813226 Mar 25 01:36 homematic_2024_03_25-01_36_11_3.73.9_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 4813226 Mar 28 01:36 homematic_2024_03_28-01_36_11_3.73.9_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 4813226 Mar 31 01:36 homematic_2024_03_31-01_36_11_3.73.9_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 4813226 Apr  1 01:36 homematic_2024_04_01-01_36_11_3.73.9_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 4813226 Apr  4 01:36 homematic_2024_04_04-01_36_11_3.73.9_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 4813226 Apr  7 01:36 homematic_2024_04_07-01_36_11_3.73.9_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 4813226 Apr 10 01:36 homematic_2024_04_10-01_36_11_3.73.9_backupiobroker.tar.sbk
    -rw-r--r-- 1 iobroker iobroker 3148949 Apr  2 04:22 iobroker_2024_04_02-04_22_10_backupiobroker.tar.gz
    -rw-r--r-- 1 iobroker iobroker 3154652 Apr  3 04:22 iobroker_2024_04_03-04_22_10_backupiobroker.tar.gz
    -rw-r--r-- 1 iobroker iobroker 3154705 Apr  4 04:22 iobroker_2024_04_04-04_22_10_backupiobroker.tar.gz
    -rw-r--r-- 1 iobroker iobroker 3155077 Apr  5 04:22 iobroker_2024_04_05-04_22_10_backupiobroker.tar.gz
    -rw-r--r-- 1 iobroker iobroker 3153078 Apr  6 04:22 iobroker_2024_04_06-04_22_10_backupiobroker.tar.gz
    -rw-r--r-- 1 iobroker iobroker 3152355 Apr  7 04:22 iobroker_2024_04_07-04_22_10_backupiobroker.tar.gz
    -rw-r--r-- 1 iobroker iobroker 3153662 Apr  8 04:22 iobroker_2024_04_08-04_22_10_backupiobroker.tar.gz
    -rw-r--r-- 1 iobroker iobroker 3153630 Apr  9 04:22 iobroker_2024_04_09-04_22_10_backupiobroker.tar.gz
    -rw-r--r-- 1 iobroker iobroker 3157581 Apr 10 04:22 iobroker_2024_04_10-04_22_10_backupiobroker.tar.gz
    -rw-r--r-- 1 iobroker iobroker 3157378 Apr 11 04:22 iobroker_2024_04_11-04_22_10_backupiobroker.tar.gz
    pi@ioBrokerpi5:~ $
    searcher57
    schrieb am zuletzt editiert von searcher57
    #177
    @homoran said in Meldungen beim/nach Upgrade:
    total 77732
    pi@ioBrokerpi5:~ $
    Entschuldigung, ich weiß nicht, ob ich hier mit meinem Problem im richtigen Thred bin?
    Ich habe das gleiche Problem, dass ich nach Umstellung auf Raspi5 die Instanz smartmeter nicht mehr gestartet bekomme. Der Stromzähler ISKRA liefert laut Handykamera noch Daten und beim Raspi4 sind die auch erkannt worden. Beim Raspi5 kann man nicht mehr "/dev/tty0/" aktivieren. Die Auswahl "/dev/ttyAM0/" und "/dev/ttyAM10/" funktionieren auch nicht.
    Hängt das mit meinem Problem zusammen, dass die GPIO Eingänge für die Gaszählerauslesung per Reed-Kontakt nicht mehr funktionieren?
    Thomas BraunT HomoranH 3 Antworten Letzte Antwort
    • S searcher57
      total 77732
      pi@ioBrokerpi5:~ $
      #178
      @searcher57
      Hängt der Lesekopf denn an den GPIOs dran oder wie ist der an den RPi angebunden?
      Wenn USB, dann verwende die 'by-id'-Links zu dem Gerät.
      Finden sich in der Langfassung von
      iob diag
      HomoranH S 2 Antworten Letzte Antwort
        @searcher57
        iob diag
        #179
        @thomas-braun sagte in Meldungen beim/nach Upgrade:
        an den GPIOs dran
        hat er in dem anderen Thread gesagt.
        • S searcher57
          total 77732
          pi@ioBrokerpi5:~ $
          #180
          @searcher57 sagte in Meldungen beim/nach Upgrade:
          woher weisst du das?
          es flackert etwas. oder kannst du mit dem Auge den Code erkennen?
          • S searcher57
            total 77732
            pi@ioBrokerpi5:~ $
            #181
            @searcher57 sagte in <gelöst> Serieller Port defekt:
            jetzt bist du es
              @searcher57
              iob diag
              searcher57
              #182
              @thomas-braun said in <gelöst> Serieller Port defekt:
              @searcher57
              iob diag
              Ja, der Lesekopf hängt direkt an GPIO 14/15 und 3,3V/GND. Und ich lese ihn über bisher erfolgreich über smartmeter aus.
                an den GPIOs dran
                searcher57
                #183
                @homoran said in <gelöst> Serieller Port defekt:
                an den GPIOs dran
                Danke, dass du mir auch sonst folgst!
                  searcher57
                  #184
                  Natürlich nicht, aber ich deute das Flackern auf einen funktionsfähigen Stromzähler incl. IR Schnittstelle, oder...?
                  S HomoranH 2 Antworten Letzte Antwort
                  • S searcher57
                    searcher57
                    #185
                    @searcher57 said in <gelöst> Serieller Port defekt:
                    Screen hat ja auch vorher gefunzt!
                    • S searcher57
                      #186
                      @searcher57 oder!
                      das Flackern könnte zu schwach geworden sein, vorübergehend aussetzen u.a.
                      Aber ISKRA (welcher auch immer) ist mMn nicht einer der üblichen Verdächtigen bei schnell alternder IR LED.
                      Hatces denn auf dem Pi5 jemals geklappt?
                        @searcher57 oder!
                        searcher57
                        #187
                        @searcher57 oder!
                        Eben nicht!
                          @searcher57 oder!
                          searcher57
                          #188
                          @searcher57 oder!
                          1 ISK00 7652 0745!
                          • S searcher57
                            @searcher57 oder!
                            Eben nicht!
                            #189
                            @searcher57 hast du die gpios in der raspi-config freigegeben?
                            Ich weiß allerdings nicht ob das auch die serielle Schnittstelle betrifft. ( @thomas-braun ?)
                            vor was?
                              vor was?
                              searcher57
                              #190
                              vor was?
                              Vor der Umstellung von Raspi 4 auf 5.
                              • S searcher57
                                @searcher57 oder!
                                1 ISK00 7652 0745!
                                #191
                                1 ISK00 7652 0745!
                                heiist was?
                                bei der Suche
                                https://forum.iobroker.net/search?term=iskra Lesekopf &in=titlesposts
                                gibt es Modellbezeichnungen
                                  1 ISK00 7652 0745!
                                  heiist was?
                                  bei der Suche
                                  searcher57
                                  #192
                                  1 ISK00 7652 0745!
                                  heiist was?
                                  bei der Suche
                                  Vielleicht hilft dir das, sonst sag mir bitte, was du benötigst.
                                  ![dbcef135-7db7-4b97-bdb7-4b97-b118-50ced08b0637-iskra-resized.jpg)
                                  • S searcher57
                                    1 ISK00 7652 0745!
                                    heiist was?
                                    bei der Suche
                                    #193
                                    was du benötigst.
                                    mt681 steht da.
                                    Die privaten Daten musst du nicht zeigen, hab das Bild entfernt
                                      was du benötigst.
                                      mt681 steht da.
                                      searcher57
                                      #194
                                      was du benötigst.
                                      mt681 steht da.
                                      Ok, tut mir leid. Unkenntnis!
                                        1 ISK00 7652 0745!
                                        heiist was?
                                        bei der Suche
                                        searcher57
                                        #195
                                        1 ISK00 7652 0745!
                                        heiist was?
                                        bei der Suche
                                        Das ist der Lesekopf.
                                        https://www.ebay.de/itm/353940190755?chn=ps&_ul=DE&_trkparms=ispr%3D1&amdata=enc%3A1n5znC_DWSPyLz0b7QABA8Q6&norover=1&mkevt=1&mkrid=707-134425-41852-0&mkcid=2&mkscid=101&itemid=353940190755&targetid=1716911581159&device=c&mktype=pla&googleloc=9044695&poi=&campaignid=17943303986&mkgroupid=140642150118&rlsatarget=pla-1716911581159&abcId=9301060&merchantid=7364532&gad_source=1&gclid=Cj0KCQjw2uiwBhCXARIsACMvIU1Z0kavXWY8vOFHKHIE93k8DNIswS5wKNf2-8lKhjPm3DexnRb-gTcaAr1eEALw_wcB
                                        • S searcher57
                                          1 ISK00 7652 0745!
                                          heiist was?
                                          bei der Suche
                                          #196
                                          der dürfte IMHO nicht der Übeltäter sein, wenn er am pi4 funktionierte.
