  4. [gelöst] Installationsproblem bei node-sonos-http-api
sonos http api
11 Beiträge 2 Kommentatoren 1.3k Aufrufe 2 Beobachtet
  • H Offline
    Heinz53
    schrieb am zuletzt editiert von Heinz53
    Ich versuche auf meinem Raspi4 das sonos-http-api zu installieren.
    npm audit zeigt nach der Installation und sudo npm audit fix --force noch einige Fehlermeldungen:
    pi@iobroker:~/node-sonos-http-api $ npm audit
    # npm audit report
    minimist  <=0.2.3
    Severity: critical
    Prototype Pollution in minimist - https://github.com/advisories/GHSA-vh95-rmgr-6w4m
    Prototype Pollution in minimist - https://github.com/advisories/GHSA-xvch-5gv4-984h
    fix available via `npm audit fix`
    node_modules/minimist
      optimist  >=0.6.0
      Depends on vulnerable versions of minimist
      node_modules/optimist
    node-static  *
    Severity: high
    Denial of Service in node-static - https://github.com/advisories/GHSA-8r4g-cg4m-x23c
    node-static and @nubosoftware/node-static vulnerable to Directory Traversal - https://github.com/advisories/GHSA-5g97-whc9-8g7j
    No fix available
    node_modules/node-static
    request  *
    Severity: moderate
    Server-Side Request Forgery in Request - https://github.com/advisories/GHSA-p8p7-x288-28g6
    Depends on vulnerable versions of tough-cookie
    No fix available
    node_modules/request
      anesidora  *
      Depends on vulnerable versions of request
      node_modules/anesidora
    tough-cookie  <4.1.3
    Severity: moderate
    tough-cookie Prototype Pollution vulnerability - https://github.com/advisories/GHSA-72xf-g2v4-qvf3
    No fix available
    node_modules/tough-cookie
    6 vulnerabilities (3 moderate, 1 high, 2 critical)
    To address issues that do not require attention, run:
      npm audit fix
    Some issues need review, and may require choosing
    a different dependency.
    Nach einem reboot versuche ich: sudo npm start
    pi@iobroker:~/node-sonos-http-api $ sudo npm start
    > sonos-http-api@1.6.9 start
    > node server.js
    2023-11-22T13:54:24.718Z INFO Could not find file /home/pi/node-sonos-http-api/settings.json
    2023-11-22T13:54:25.212Z INFO Presets loaded: {
      example: {
        players: [
          { roomName: 'Bathroom', volume: 10 },
          { roomName: 'Kitchen', volume: 10 },
          { roomName: 'Office', volume: 10 },
          { roomName: 'Bedroom', volume: 10 },
          { roomName: 'TV Room', volume: 15 }
        playMode: { shuffle: true, repeat: 'all', crossfade: false },
        pauseOthers: false
    node:internal/modules/cjs/loader:446
          throw err;
    Error: Cannot find module '/home/pi/node-sonos-http-api/node_modules/request-promise/lib/tp.js'. Please verify that the package.json has a valid "main" entry
        at tryPackage (node:internal/modules/cjs/loader:438:19)
        at Module._findPath (node:internal/modules/cjs/loader:680:18)
        at Module._resolveFilename (node:internal/modules/cjs/loader:1063:27)
        at Module._load (node:internal/modules/cjs/loader:922:27)
        at Module.require (node:internal/modules/cjs/loader:1143:19)
        at require (node:internal/modules/cjs/helpers:119:18)
        at Object.<anonymous> (/home/pi/node-sonos-http-api/lib/actions/musicSearch.js:2:17)
        at Module._compile (node:internal/modules/cjs/loader:1256:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        at Module.load (node:internal/modules/cjs/loader:1119:32)
        at Module._load (node:internal/modules/cjs/loader:960:12)
        at /home/pi/node-sonos-http-api/lib/helpers/require-dir.js:18:8
        at Array.forEach (<anonymous>)
        at module.exports (/home/pi/node-sonos-http-api/lib/helpers/require-dir.js:17:6) {
      code: 'MODULE_NOT_FOUND',
      path: '/home/pi/node-sonos-http-api/node_modules/request-promise/package.json',
      requestPath: 'request-promise'
    Node.js v18.18.2
    Mit meinen Linux Kenntnissen kann ich das Problem nicht lösen.
    Kann mir jemand weiterhelfen?
    • Thomas BraunT Online
      @heinz53
      Recht viel Chaos...
      Und gewöhn dir die Verwendung von sudo ab. Das macht alles kaputt.
      Und auch von npm audit fix lässt man die Finger, insbesondere von --force.
      Was soll das Ziel der Installation sein? Ein Integration in den ioBroker?
      • H Offline
        Heinz53
        Danke für die schnelle Antwort. Ich hatte die Installion bereits vorher ohne sudo mit den gleichen Fehlern versucht. Daher dachte ich sudo könnte helfen...
        Das Ziel ist, die Integration der SONOS in den ioBroker.
          @heinz53
          Das würde ich anders anfangen.
          Das entsprechende nodemodul würde ich in /usr/local/bin platzieren und das dann per Skript als Service starten lassen. Hier hab mal was sehr ähnliches mit solix2mqtt gemacht:
          https://forum.iobroker.net/topic/69229/anker-adapter/18?_=1700666385246
          • H Offline
            Heinz53
            Dann versuche ich es mal in dem Verzeichnis /usr/local/bin und zwar ohne sudo
            Die Vorlage für die Installation ist auf folgendem link: https://github.com/jishi/node-sonos-http-api/wiki/Step-by-Step---RPi3-Install-of-Sonos-http-api
            pi@iobroker:/usr/local/bin $ git clone https://github.com/jishi/node-sonos-http-api.git
            fatal: could not create work tree dir 'node-sonos-http-api': Permission denied
            Was nun???
            • H Heinz53
              Was nun???
              @heinz53 sagte in Installationsproblem bei node-sonos-http-api:
              Was nun???
              :-) An DER Stelle brauchst du doch sudo, der pi darf da nämlich nicht reinschreiben. Wenn du magst installier ich das heute Abend mal bei mir und schreib es dann hier auf, wie das geht.
              • H Offline
                Heinz53
                Das finde ich super! DANKE erst mal....
                • H Heinz53
                  @heinz53
                  Los geht's.
                  In deinem Heimverzeichnis:
                  Mit
                  mkdir sonoshttp
                  ein Arbeitsverzeichnis anlegen.
                  cd sonoshttp/
                  cd node-sonos-http-api/
                  npm install --omit=dev
                  cd ..
                  sudo mv node-sonos-http-api /usr/local/bin
                  Startskript anlegen:
                  sudo nano /usr/local/bin/node-sonos-http-api/sonoshttp.sh
                  mit dem Inhalt:
                  #!/bin/bash
                  cd /usr/local/bin/node-sonos-http-api/;
                  npm start;
                  Owner ändern:
                  sudo chown -R iobroker:iobroker /usr/local/bin/node-sonos-http-api
                  sudo chmod 744 /usr/local/bin/node-sonos-http-api/sonoshttp.sh
                  Jetzt per
                  sudo nano /usr/lib/systemd/system/sonoshttp.service
                  eine Datei mit diesem Inhalt anlegen:
                  [Unit]
                  Description=Sonos http API
                  Before=iobroker.service
                  [Service]
                  User=iobroker
                  Group=iobroker
                  ExecStart=/usr/local/bin/node-sonos-http-api/sonoshttp.sh
                  Type=simple
                  # Restart=always
                  [Install]
                  WantedBy=multi-user.target
                  #RequiredBy=network.target
                  Mit
                  sudo systemctl daemon-reload
                  die Service-Datei bekannt machen.
                  Ab jetzt dürfte das Ding beim Systemstart automatisch gestartet werden.
                  Mit
                  sudo systemctl start sonoshttp.service
                  systemctl status sonoshttp.service
                  schauen was da los ist. Sollte dann ungefähr so aussehen:
                  ● sonoshttp.service - Sonos http API
                       Loaded: loaded (/lib/systemd/system/sonoshttp.service; enabled; preset: enabled)
                       Active: active (running) since Thu 2023-11-23 18:37:00 CET; 29min ago
                     Main PID: 269613 (sonoshttp.sh)
                        Tasks: 27 (limit: 8752)
                          CPU: 4.519s
                       CGroup: /system.slice/sonoshttp.service
                               ├─269613 /bin/bash /usr/local/bin/node-sonos-http-api/sonoshttp.sh
                               ├─269614 "npm start"
                               ├─269630 sh -c "node server.js"
                               └─269631 node server.js
                  Individuelle Einstellungen müssen dann lt. readme wohl noch angelegt werden. Es sollte aber unter
                  die.IP.des.hosts.:5005/
                  die Startseite zu sehen sein:
                  • H Offline
                    Heinz53
                    Hallo Thomas, ich bin begeistert!
                    Mit deiner Anleitung konnte ich die api aktivieren.
                    In der Anleitung hat sich an zwei Stellen ein Schreibfehler (...apt statt ...api) eingeschlichen
                    1. in Block Arbeitsverzeichnis anlegen
                      sudo mv node-sonos-http-apt /usr/local/bin
                    2. im Block Owner ändern
                      sudo chown -R iobroker:iobroker /usr/local/bin/node-sonos-http-apt
                    Dann hatte ich noch die Fehlermeldung.
                    pi@iobroker:~/sonoshttp $ sudo systemctl start sonoshttp.service
                    pi@iobroker:~/sonoshttp $ systemctl status sonoshttp.service
                         Loaded: loaded (/lib/systemd/system/sonoshttp.service; disabled; vendor preset: enabled)
                         Active: failed (Result: exit-code) since Thu 2023-11-23 23:13:29 CET; 3s ago
                        Process: 3655161 ExecStart=/usr/local/bin/node-sonos-http-api/sonoshttp.sh (code=exited, status=1/FAILURE)
                       Main PID: 3655161 (code=exited, status=1/FAILURE)
                            CPU: 3.965s
                    Nov 23 23:13:28 iobroker sonoshttp.sh[3655369]:     playMode: { shuffle: true, repeat: 'all', crossfade: false },
                    Nov 23 23:13:28 iobroker sonoshttp.sh[3655369]:     pauseOthers: false
                    Nov 23 23:13:28 iobroker sonoshttp.sh[3655369]:   }
                    Nov 23 23:13:29 iobroker sonoshttp.sh[3655369]: 2023-11-23T22:13:29.588Z ERROR Port 5005 seems to be in use already. Make sure the sonos->
                    Nov 23 23:13:29 iobroker sonoshttp.sh[3655369]:     already running, or that no other server uses that port. You can specify an alternati>
                    Nov 23 23:13:29 iobroker sonoshttp.sh[3655369]:     with property "port" in settings.json
                    Nov 23 23:13:29 iobroker systemd[1]: sonoshttp.service: Main process exited, code=exited, status=1/FAILURE
                    Nov 23 23:13:29 iobroker systemd[1]: sonoshttp.service: Failed with result 'exit-code'.
                    Nach der Änderung des Ports in der settings.js auf den Port 5015 war der Aufruf erfolgreich.
                    pi@iobroker:/usr/local/bin/node-sonos-http-api $ sudo nano settings.js
                    pi@iobroker:/usr/local/bin/node-sonos-http-api $ sudo systemctl start sonoshttp.service
                    pi@iobroker:/usr/local/bin/node-sonos-http-api $ systemctl status sonoshttp.service
                         Active: active (running) since Thu 2023-11-23 23:21:47 CET; 25s ago
                       Main PID: 3671575 (sonoshttp.sh)
                          Tasks: 24 (limit: 3933)
                            CPU: 4.416s
                                 ├─3671575 /bin/bash /usr/local/bin/node-sonos-http-api/sonoshttp.sh
                                 ├─3671576 npm start
                                 ├─3671610 sh -c node server.js
                                 └─3671611 node server.js
                    Nov 23 23:21:49 iobroker sonoshttp.sh[3671611]:       { roomName: 'Kitchen', volume: 10 },
                    Nov 23 23:21:49 iobroker sonoshttp.sh[3671611]:       { roomName: 'Office', volume: 10 },
                    Nov 23 23:21:49 iobroker sonoshttp.sh[3671611]:       { roomName: 'Bedroom', volume: 10 },
                    Nov 23 23:21:49 iobroker sonoshttp.sh[3671611]:       { roomName: 'TV Room', volume: 15 }
                    Nov 23 23:21:49 iobroker sonoshttp.sh[3671611]:     ],
                    Nov 23 23:21:49 iobroker sonoshttp.sh[3671611]:     playMode: { shuffle: true, repeat: 'all', crossfade: false },
                    Nov 23 23:21:49 iobroker sonoshttp.sh[3671611]:     pauseOthers: false
                    Nov 23 23:21:49 iobroker sonoshttp.sh[3671611]:   }
                    Nov 23 23:21:51 iobroker sonoshttp.sh[3671611]: 2023-11-23T22:21:51.011Z INFO http server listening on 0.0.0.0 port 5015
                    Hast du vielleicht noch einen Vorschlag wie ich feststellen kann was den Port 5005 belegt? Vielleicht habe ich mit meinen vorherigen Versuchen hier etwas durcheinandergebracht.
                    Nochmals: Herzlichen Dank für deine Unterstützung!
                    • H Heinz53
                              CPU: 3.965s
                              CPU: 4.416s
                                   ├─3671576 npm start
                      Vermutlich. Im
                      iob diag
                      sind die Serverdienste und deren Ports aber auch drin.
                      • H Offline
                        Heinz53
                        Danke!
                        Die simple-api.0 ist zugeordnet.
                        Ich lerne dazu, auch Dank deines Werkzeugkastens 👏 👏 👏
