  4. VIS fehlt
VIS fehlt
10 Beiträge 4 Kommentatoren 670 Aufrufe 3 Beobachtet
    toki1973
    Nun ist der Umzug auf ein neues System fast abgeschlossen, aber scheinbar fehlt die VIS. Als Instanz ist sie angelegt kann aber nicht gestartet werden.
    vis.0
    86380	2023-11-20 12:31:06.178	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    vis.0
    86380	2023-11-20 12:31:06.177	info	terminating
    vis.0
    86380	2023-11-20 12:31:05.658	error	Not exists
    vis.0
    86380	2023-11-20 12:31:05.658	error	Error: Not exists at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:854:19) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:891:59) at process.processImmediate (node:internal/timers:478:21)
    vis.0
    86380	2023-11-20 12:31:05.656	error	unhandled promise rejection: Not exists
    vis.0
    86380	2023-11-20 12:31:05.655	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    vis.0
    86380	2023-11-20 12:31:04.311	info	starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.vis, node: v18.18.2, js-controller: 5.0.16
    Nachinstallieren über NPM des Adapters ergibt folgendes
    $ iobroker url iobroker.vis@latest --host iobroker --debug
    install iobroker.vis@latest
    NPM version: 9.8.1Installing iobroker.vis@latest... (System call)
    npm ERR! code 6
    npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --install
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-20T11_39_41_160Z-debug-0.log
    npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-20T11_39_41_160Z-debug-0.log
    host.iobroker Cannot install iobroker.vis@latest: 6
    ERROR: Process exited with code 25
    NUC, PROXMOX, Grafana, Influx, Unify
    CodierknechtC HomoranH 2 Antworten Letzte Antwort
    • T toki1973
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      npm ERR! code 6
      CodierknechtC Offline
      Codierknecht
      @toki1973
      Hast Du vor dem Restore des Backup auch Vis manuell installiert?
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      • T toki1973
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        vis.0
        npm ERR! code 6
        @toki1973 Backup wiederhergestellt??
        vis vorher manuell installiert gehabt?
          toki1973
          Hm das kann ich nicht mehr sagen ob ich vis manuell installiert hatte. Normalerweise nicht. Aber den Adapter selbst finde ich nicht unter den Adaptern. Das war ein Versuch ihn wieder zu bekommen.
          Was kann ich noch versuchen?
          Das Backup habe ich wieder hergestellt. Aber im Backup Adapter gibt es kein Häkchen für VIS Backup. Ich kann auch notfalls die VIS manuell vom alten System rüber kopieren.
          • T toki1973
            @toki1973 vis ist im Backup drin!!
            AAABER
            du musst es auf dem neuen System vor dem Restore manuell installiert gehabt habrn.
            ist leider ein Bug
              AAABER
              ist leider ein Bug
              toki1973
              @homoran Und wie bekomme ich es nun? Und was ist mit den vis-projekten?
              • T toki1973
                @toki1973 sagte in VIS fehlt:
                sollten alle da sein!
                iob install vis@1.4.10 dann iob upload vis
                danach vis auf aktuellen Stand updaten
                  toki1973
                  @homoran said in VIS fehlt:
                  iob upload vis
                  Super alles wieder da :)
                  • T toki1973
                    iob upload vis
                    Natürlich!
                    mit vorheriger Installation wäre alles sofort da gewesen.
                    • arteckA Offline
                      arteckA Offline
                      arteck
                      @toki1973 nochmal...
