  3. Einsteigerfragen
  4. Installation
  5. Update js-controller - "nodejs is NOT correctly installed"
Geplant Angeheftet Gesperrt Verschoben Installation
40 Beiträge 3 Kommentatoren 6.1k Aufrufe 2 Beobachtet
  • G George_Best
    @thomas-braun sieht leider nicht so gut as:
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! dest /opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.js-controller' -> '/opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba'
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-03T10_47_37_114Z-debug-0.log
    Das Log-file: 2023-11-03T10_47_43_654Z-debug-0.log
    @george_best
    iob stop
    iob fix
    G 1 Antwort Letzte Antwort
      @george_best
      iob stop
      iob fix
      George_Best
      iob fix:
      library: loaded
      Library version=2023-10-13
          Welcome to the ioBroker installation fixer!
          Script version: 2023-10-13
          You might need to enter your password a couple of times.
          Installing prerequisites (1/5)
      Ign:1 http://security.debian.org/debian-security bullseye/updates InRelease
      OK:2 http://deb.debian.org/debian bullseye InRelease
      Ign:3 http://security.debian.org/debian-security bullseyeupdates InRelease
      OK:4 http://deb.debian.org/debian bullseye-updates InRelease
      OK:5 http://deb.debian.org/debian bullseye-backports InRelease
      Fehl:6 http://security.debian.org/debian-security bullseye/updates Release
        404  Not Found [IP: 199.232.190.132 80]
      Fehl:7 http://security.debian.org/debian-security bullseyeupdates Release
      OK:8 https://deb.nodesource.com/node_18.x nodistro InRelease
      Holen:9 https://packagecloud.io/ookla/speedtest-cli/debian stretch InRelease [24,5 kB]
      Fehl:9 https://packagecloud.io/ookla/speedtest-cli/debian stretch InRelease
        Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 8E61C2AB9A6D1557
      E: Das Depot »http://security.debian.org/debian-security bullseye/updates Release« enthält keine Release-Datei.
      N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
      N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
      E: Das Depot »http://security.debian.org/debian-security bullseyeupdates Release« enthält keine Release-Datei.
      W: GPG-Fehler: https://packagecloud.io/ookla/speedtest-cli/debian stretch InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 8E61C2AB9A6D1557
      E: Das Depot »https://packagecloud.io/ookla/speedtest-cli/debian stretch InRelease« ist nicht signiert.
          Checking ioBroker user and directory permissions (2/5)
      Created /etc/sudoers.d/iobroker
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Compressed 2 JSONL files. Done
          Checking autostart (5/5)
      Enabling autostart...
      Autostart enabled!
      sudo -H -u iobroker npm install iobroker.js-controller
      npm WARN skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.esphome.git
      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
      npm WARN deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
      npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
      npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
      npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
      npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
      npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
      npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
      npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
      npm WARN cleanup Failed to remove some directories [
      npm WARN cleanup   [
      npm WARN cleanup     '/opt/iobroker/node_modules/raw-socket',
      npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/raw-socket'] {
      npm WARN cleanup       errno: -39,
      npm WARN cleanup       code: 'ENOTEMPTY',
      npm WARN cleanup       syscall: 'rmdir',
      npm WARN cleanup       path: '/opt/iobroker/node_modules/raw-socket'
      npm WARN cleanup     }
      npm WARN cleanup   ],
      npm WARN cleanup   [
      npm WARN cleanup     }
      npm WARN cleanup   ],
      npm WARN cleanup   [
      npm WARN cleanup     '/opt/iobroker/node_modules/node-snap7',
      npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/node-snap7'] {
      npm WARN cleanup       path: '/opt/iobroker/node_modules/node-snap7'
      npm WARN cleanup     }
      npm WARN cleanup   ],
      npm WARN cleanup   [
      npm WARN cleanup     '/opt/iobroker/node_modules/pcap',
      npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/pcap'] {
      npm WARN cleanup       path: '/opt/iobroker/node_modules/pcap'
      npm WARN cleanup     }
      npm WARN cleanup   ],
      npm WARN cleanup   [
      npm WARN cleanup     }
      npm WARN cleanup   ],
      npm WARN cleanup   [
      npm WARN cleanup     }
      npm WARN cleanup   ]
      npm WARN cleanup ]
      npm ERR! code 1
      npm ERR! path /opt/iobroker/node_modules/node-libcurl
      npm ERR! command failed
      npm ERR! command sh -c node-pre-gyp install --fallback-to-build
      npm ERR! Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v108' (1)
      npm ERR! node-pre-gyp info it worked if it ends with ok
      npm ERR! node-pre-gyp info using node-pre-gyp@1.0.5
      npm ERR! node-pre-gyp info using node@18.18.2 | linux | x64
      npm ERR! node-pre-gyp info check checked for "/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" (not found)
      npm ERR! node-pre-gyp http GET https://github.com/JCMais/node-libcurl/releases/download/v2.3.4/node_libcurl-v2.3.4-node-v108-linux-x64-glibc.tar.gz
      npm ERR! node-pre-gyp ERR! install response status 404 Not Found on https://github.com/JCMais/node-libcurl/releases/download/v2.3.4/node_libcurl-v2.3.4-node-v108-linux-x64-glibc.tar.gz
      npm ERR! node-pre-gyp WARN Pre-built binaries not installable for node-libcurl@2.3.4 and node@18.18.2 (node-v108 ABI, glibc) (falling back to source compile with node-gyp)
      npm ERR! node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/JCMais/node-libcurl/releases/download/v2.3.4/node_libcurl-v2.3.4-node-v108-linux-x64-glibc.tar.gz
      npm ERR! gyp info it worked if it ends with ok
      npm ERR! gyp info using node-gyp@9.4.0
      npm ERR! gyp info using node@18.18.2 | linux | x64
      npm ERR! gyp info ok
      npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
      npm ERR! gyp info spawn /usr/bin/python3
      npm ERR! gyp info spawn args [
      npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
      npm ERR! gyp info spawn args   'binding.gyp',
      npm ERR! gyp info spawn args   '-f',
      npm ERR! gyp info spawn args   'make',
      npm ERR! gyp info spawn args   '-I',
      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-libcurl/build/config.gypi',
      npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
      npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
      npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
      npm ERR! gyp info spawn args   '-Dvisibility=default',
      npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
      npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
      npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
      npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/node-libcurl',
      npm ERR! gyp info spawn args   '-Dnode_engine=v8',
      npm ERR! gyp info spawn args   '--depth=.',
      npm ERR! gyp info spawn args   '--no-parallel',
      npm ERR! gyp info spawn args   '--generator-output',
      npm ERR! gyp info spawn args   'build',
      npm ERR! gyp info spawn args   '-Goutput_dir=.'
      npm ERR! gyp info spawn args ]
      npm ERR! Could not run curl-config, please make sure libcurl dev package is installed.
      npm ERR! Output: /bin/sh: 1: curl-config: not found
      npm ERR!
      npm ERR! gyp: Call to 'node /opt/iobroker/node_modules/node-libcurl/scripts/curl-config.js --prefix' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
      npm ERR! gyp ERR! configure error
      npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
      npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:325:16)
      npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
      npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
      npm ERR! gyp ERR! System Linux 5.10.0-26-amd64
      npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" "--module_name=node_libcurl" "--module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding" "--napi_version=9" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v108"
      npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/node-libcurl
      npm ERR! gyp ERR! node -v v18.18.2
      npm ERR! gyp ERR! node-gyp -v v9.4.0
      npm ERR! gyp ERR! not ok
      npm ERR! node-pre-gyp ERR! build error
      npm ERR! node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v108' (1)
      npm ERR! node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-libcurl/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
      npm ERR! node-pre-gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
      npm ERR! node-pre-gyp ERR! stack     at maybeClose (node:internal/child_process:1098:16)
      npm ERR! node-pre-gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:303:5)
      npm ERR! node-pre-gyp ERR! System Linux 5.10.0-26-amd64
      npm ERR! node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-libcurl/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      npm ERR! node-pre-gyp ERR! cwd /opt/iobroker/node_modules/node-libcurl
      npm ERR! node-pre-gyp ERR! node -v v18.18.2
      npm ERR! node-pre-gyp ERR! node-pre-gyp -v v1.0.5
      npm ERR! node-pre-gyp ERR! not ok
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-03T11_01_57_465Z-debug-0.log
      • G George_Best
        iob fix:
        library: loaded
        Done.
        Autostart enabled!
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ]
        npm WARN cleanup ]
        npm ERR! code 1
        npm ERR!
        @george_best
        Du hast auch Chaos in den Repos. Insbesondere im Security-Repo. Und das Speedtest-Rrpo muss auch angepasst werden. Sieht man sowas nicht beim üblichen System-Update?
        sudo apt update
        apt policy libcurl*
        sagt?
          @george_best
          sudo apt update
          apt policy libcurl*
          sagt?
          George_Best
          sudo apt update:
          OK:1 http://deb.debian.org/debian bullseye InRelease
          Ign:2 http://security.debian.org/debian-security bullseye/updates InRelease
          OK:3 http://deb.debian.org/debian bullseye-updates InRelease
          Ign:4 http://security.debian.org/debian-security bullseyeupdates InRelease
          apt policy libcurl*
          libcurl4-openssl-dev:
            Installiert:           (keine)
            Installationskandidat: 7.74.0-1.3+deb11u9
            Versionstabelle:
               7.88.1-10+deb12u3~bpo11+1 100
                  100 http://deb.debian.org/debian bullseye-backports/main amd64 Packages
               7.74.0-1.3+deb11u9 500
                  500 http://deb.debian.org/debian bullseye/main amd64 Packages
          libcurl3:
            Installationskandidat: (keine)
            Versionstabelle:
          libcurl4:
            Installiert:           7.74.0-1.3+deb11u9
            Versionstabelle:
           *** 7.74.0-1.3+deb11u9 500
                  100 /var/lib/dpkg/status
          libcurl3-gnutls:
            Versionstabelle:
          libcurl-ocaml:
            Installationskandidat: 0.9.1-1+b4
            Versionstabelle:
               0.9.1-1+b4 500
          libcurl3-openssl-dev:
            Versionstabelle:
          libcurl3-gnutls-dev:
            Versionstabelle:
          libcurl4-gnutls-dev:
            Versionstabelle:
          libcurl-dev:
            Versionstabelle:
          libcurlpp0:
            Installationskandidat: 0.8.1-3
            Versionstabelle:
               0.8.1-3 500
          libcurl-ocaml-dev:
            Versionstabelle:
               0.9.1-1+b4 500
          libcurl-ocaml-30vr0:
            Versionstabelle:
          libcurlpp-dev:
            Versionstabelle:
               0.8.1-3 500
          libcurl-ssl-dev:
            Versionstabelle:
          libcurl-ocaml-dev-30vr0:
            Versionstabelle:
          libcurl3-nss-dev:
            Versionstabelle:
          libcurl3-dev:
            Versionstabelle:
          libcurl4-dev:
            Versionstabelle:
          libcurl4-doc:
            Versionstabelle:
          libcurl3-nss:
            Versionstabelle:
          libcurl4-nss-dev:
            Versionstabelle:
          • G George_Best
            sudo apt update:
            apt policy libcurl*
              Versionstabelle:
            libcurl3:
              Versionstabelle:
            libcurl4:
              Versionstabelle:
            libcurl3-gnutls:
              Versionstabelle:
            libcurl-ocaml:
              Versionstabelle:
                 0.9.1-1+b4 500
              Versionstabelle:
              Versionstabelle:
              Versionstabelle:
            libcurl-dev:
              Versionstabelle:
            libcurlpp0:
              Versionstabelle:
                 0.8.1-3 500
            libcurl-ocaml-dev:
              Versionstabelle:
                 0.9.1-1+b4 500
              Versionstabelle:
            libcurlpp-dev:
              Versionstabelle:
                 0.8.1-3 500
            libcurl-ssl-dev:
              Versionstabelle:
              Versionstabelle:
            libcurl3-nss-dev:
              Versionstabelle:
            libcurl3-dev:
              Versionstabelle:
            libcurl4-dev:
              Versionstabelle:
            libcurl4-doc:
              Versionstabelle:
            libcurl3-nss:
              Versionstabelle:
            libcurl4-nss-dev:
              Versionstabelle:
            @george_best
            Joh, ran an die Meldungen.
            Danach:
            sudo apt install libcurl4-gnutls-dev
            • G Offline
              George_Best
              jonny@ioBroker-V2:/etc/apt/sources.list.d$ sudo apt update
              OK:2 http://deb.debian.org/debian bullseye-updates InRelease
              OK:3 http://deb.debian.org/debian bullseye-backports InRelease
              OK:4 http://deb.debian.org/debian-security bullseye-security InRelease
              OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
              Aktualisierung für 53 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
              jonny@ioBroker-V2:/etc/apt/sources.list.d$ sudo apt install libcurl4-gnutls-dev
              Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                aspell-de-alt bsdmainutils cpp-8 dh-python fdisk geoip-database irqbalance libasan5 libbind9-140 libbind9-161
                libdbus-glib-1-2 libdns-export1104 libdns1104 libdns1110 libdns162 libevent-2.1-6 libgeoip1 libgl1-mesa-glx
                libicu57 libio-stringy-perl libisc-export1100 libisc1100 libisc1105 libisc160 libisccc140 libisccc161
                libisccfg140 libisccfg163 libisl19 libjson-c3 libjsoncpp1 liblwres141 liblwres161 libmpdec2 libnftables0 libnuma1
                libonig4 libperl5.24 libprocps7 libpython3.5 libpython3.5-dev libpython3.5-minimal libpython3.5-stdlib
                libpython3.7 libpython3.7-dev libpython3.7-minimal libpython3.7-stdlib libxt-dev python3-asn1crypto
                python3-entrypoints python3-jeepney python3-keyring python3-keyrings.alt python3-pyasn1 python3-pycryptodome
                python3-secretstorage python3-xdg python3.5 python3.5-dev python3.5-minimal python3.5-venv python3.7-minimal
                rename sgml-base tcpd usb.ids x11proto-input-dev x11proto-kb-dev xml-core
              Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
              Die folgenden zusätzlichen Pakete werden installiert:
                libcurl3-gnutls
              Vorgeschlagene Pakete:
                libcurl4-doc libgnutls28-dev libidn11-dev libkrb5-dev libldap2-dev librtmp-dev libssh2-1-dev
              Die folgenden NEUEN Pakete werden installiert:
                libcurl4-gnutls-dev
              Die folgenden Pakete werden aktualisiert (Upgrade):
                libcurl3-gnutls
              1 aktualisiert, 1 neu installiert, 0 zu entfernen und 52 nicht aktualisiert.
              Es müssen 778 kB an Archiven heruntergeladen werden.
              Nach dieser Operation werden 1.619 kB Plattenplatz zusätzlich benutzt.
              Möchten Sie fortfahren? [J/n] j
              Holen:1 http://deb.debian.org/debian-security bullseye-security/main amd64 libcurl3-gnutls amd64 7.74.0-1.3+deb11u10 [344 kB]
              Holen:2 http://deb.debian.org/debian-security bullseye-security/main amd64 libcurl4-gnutls-dev amd64 7.74.0-1.3+deb11u10 [435 kB]
              Es wurden 778 kB in 0 s geholt (4.014 kB/s).
              Changelogs werden gelesen... Fertig
              (Lese Datenbank ... 64938 Dateien und Verzeichnisse sind derzeit installiert.)
              Vorbereitung zum Entpacken von .../libcurl3-gnutls_7.74.0-1.3+deb11u10_amd64.deb ...
              Entpacken von libcurl3-gnutls:amd64 (7.74.0-1.3+deb11u10) über (7.74.0-1.3+deb11u9) ...
              Vormals nicht ausgewähltes Paket libcurl4-gnutls-dev:amd64 wird gewählt.
              Vorbereitung zum Entpacken von .../libcurl4-gnutls-dev_7.74.0-1.3+deb11u10_amd64.deb ...
              Entpacken von libcurl4-gnutls-dev:amd64 (7.74.0-1.3+deb11u10) ...
              libcurl3-gnutls:amd64 (7.74.0-1.3+deb11u10) wird eingerichtet ...
              libcurl4-gnutls-dev:amd64 (7.74.0-1.3+deb11u10) wird eingerichtet ...
              Trigger für libc-bin (2.31-13+deb11u6) werden verarbeitet ...
              Trigger für man-db (2.9.4-2) werden verarbeitet ...
              • G George_Best
                sudo apt update:
                apt policy libcurl*
                  Versionstabelle:
                libcurl3:
                  Versionstabelle:
                libcurl4:
                  Versionstabelle:
                libcurl3-gnutls:
                  Versionstabelle:
                libcurl-ocaml:
                  Versionstabelle:
                     0.9.1-1+b4 500
                  Versionstabelle:
                  Versionstabelle:
                  Versionstabelle:
                libcurl-dev:
                  Versionstabelle:
                libcurlpp0:
                  Versionstabelle:
                     0.8.1-3 500
                libcurl-ocaml-dev:
                  Versionstabelle:
                     0.9.1-1+b4 500
                  Versionstabelle:
                libcurlpp-dev:
                  Versionstabelle:
                     0.8.1-3 500
                libcurl-ssl-dev:
                  Versionstabelle:
                  Versionstabelle:
                libcurl3-nss-dev:
                  Versionstabelle:
                libcurl3-dev:
                  Versionstabelle:
                libcurl4-dev:
                  Versionstabelle:
                libcurl4-doc:
                  Versionstabelle:
                libcurl3-nss:
                  Versionstabelle:
                libcurl4-nss-dev:
                  Versionstabelle:
                @george_best
                In der /etc/apt/sources.list muss die Zeile bezüglich Security so aussehen:
                deb http://deb.debian.org/debian-security/ bullseye-security main contrib non-free non-free-firmware
                Alle anderen Zeilen mit Security drin müssen raus.
                Dann die .list-Datei mit den Backports löschen. Liegt vermutlich in /etc/apt/sources.list.d
                Und die .list-Datei zum Speedtest muss auch auf bullseye statt stretch lauten.
                • G George_Best
                    libcurl3-gnutls
                    libcurl4-gnutls-dev
                    libcurl3-gnutls
                  @george_best
                  Okay, hat sich überschnitten...
                  Die mehr als 50 Updates reinziehen!
                  sudo apt full-upgrade
                  sudo reboot
                  Vorher die Backports aber ausschalten.
                    @george_best
                    George_Best
                    @thomas-braun sagte in Update js-controller - "nodejs is NOT correctly installed":
                    da liegt nur:
                    nodesource.list
                    ookla_speedtest-cli.list
                    In der sources.list sind diese Einträge drin:
                    deb http://deb.debian.org/debian bullseye-backports main
                    deb-src http://deb.debian.org/debian bullseye-backports main
                    Soll ich diese Einträge aus der sources.list rausnehmen?
                    • G George_Best
                      da liegt nur:
                      nodesource.list
                      @george_best
                      Ja. Backports will man eigentlich nicht verwenden.
                        @george_best
                        George_Best
                        @thomas-braun Ich versuch mich mal nun wieder nach oben zu hangeln..
                        sagt nun:
                        npm ERR! code 6
                        npm ERR! path /opt/iobroker/node_modules/iobroker.vis-google-fonts
                        npm ERR! command sh -c node main.js --install
                        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-03T12_24_45_263Z-debug-0.log
                        • G George_Best
                          sagt nun:
                          npm ERR! code 6
                          George_Best
                          sehr seltsam... Beim 2.
                          wurde der js-controller nun installiert...
                          • G George_Best
                            George_Best
                            Was für ein Kampf 😧
                            Aber letztendlich doch erfolgreich - JS-Controller wurde erfolgreich geupdated.
                            @Thomas-Braun Vielen, vielen Dank für deine Hilfe und deine unendliche Geduld 😊
                            • G George_Best
                              Was für ein Kampf 😧
                              @george_best
                              Gut. Dann schau jetzt per
                              iob diag
                              über Ganze nochmal drüber.
                              • G Offline
                                George_Best
                                Das sieht es jetzt prinzipiell besser aus...
                                Errors in npm tree:
                                npm ERR! code ELSPROBLEMS
                                npm ERR! invalid: iobroker.vis-materialdesign@0.2.62 /opt/iobroker/node_modules/iobroker.vis-materialdesign
                                npm ERR! invalid: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
                                npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
                                npm ERR! missing: cli@0.4.x, required by ipv6@3.1.1
                                npm ERR! missing: cliff@0.1.x, required by ipv6@3.1.1
                                npm ERR! A complete log of this run can be found in: /home/jonny/.npm/_logs/2023-11-03T15_35_17_056Z-debug-0.log
                                *** ioBroker-Installation ***
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Core adapters versions
                                js-controller:  5.0.12
                                admin:          6.12.0
                                javascript:     7.1.4
                                npm ERR! A complete log of this run can be found in: /home/jonny/.npm/_logs/2023-11-03T15_35_25_269Z-debug-0.log
                                Adapters from github:   1
                                Aber den iobroker.vis-materialdesign kann ich nicht entfernen, da scheinbar 50% meiner Vis darauf basieren.
                                • G George_Best
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.12.0
                                  javascript:     7.1.4
                                  @george_best
                                  Dann installiere den nochmal.
                                  iob upgrade vis-materialdesign@0.5.9
                                    @george_best
                                    George_Best
                                    schrieb am zuletzt editiert von George_Best
                                    jonny@ioBroker-V2:~$ iob upgrade vis-materialdesign@0.5.9
                                    Adapter "vis-materialdesign" is not in the repository and cannot be updated.
                                    Der ist (vermutlich) von hier: https://github.com/Scrounger/ioBroker.vis-materialdesign/blob/master/README.md
                                    • G George_Best
                                      @george_best
                                      Dann zieh das aus npm / Beta rein. Der hat es nie nach Stable gebracht:
                                      vis-materialdesign
                                      github:	0.5.94
                                      latest:	0.5.9 for 29 months
                                      stable:	-.-.-
                                      • G George_Best
                                        @george_best
                                        socksv5, ipv6 usw wirst du vermultich nicht gefixt bekommen, das ist alles zu alt und ungewartet.
                                        cd /opt/iobroker && npm ls xmlbuilder
                                        kann man vielleicht noch angehen.
                                          @george_best
                                          mcm1957M Offline
                                          mcm1957M Offline
                                          mcm1957
                                          @thomas-braun said in Update js-controller - "nodejs is NOT correctly installed":
                                          @george_best
                                          socksv5 und ipv6 kommen wahrscheinlich via Telegram Adapter rein.
                                          Da ist was im Anmarsch. Wir haben heute entschieden den socks Proxy support aus dem Telegram Adapter rauszuschmeißen da die entsprechenden Module total veraltet sind und kein 1:1 Ersatz existiert. Falls ggF ein zu großer Aufschrei kommt müssen wir Aifwand setzen um eine Ersatzlösung zu implementieren - aber derzeit sind Resoiurcen eher knapp ...
                                          Support Repositoryverwaltung.
                                          LESEN - gute Forenbeitrage
