  3. Einsteigerfragen
  4. Installation
  5. Update js-controller - "nodejs is NOT correctly installed"
40 Beiträge 3 Kommentatoren 6.1k Aufrufe 2 Beobachtet
  • G George_Best
    @thomas-braun mit
    sudo -H -u iobroker npm install iobroker.js-controller
    @george_best
    Ja, aber im richtigen Verzeichnis.
    Vorher
    cd /opt/iobroker
    G 1 Antwort Letzte Antwort
      @george_best
      Vorher
      cd /opt/iobroker
      George_Best
      @thomas-braun sieht leider nicht so gut as:
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
      npm ERR! dest /opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.js-controller' -> '/opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba'
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-03T10_47_37_114Z-debug-0.log
      Das Log-file: 2023-11-03T10_47_43_654Z-debug-0.log
      • G George_Best
        npm ERR! errno -39
        @george_best
        iob stop
        iob fix
          @george_best
          iob stop
          iob fix
          George_Best
          iob fix:
          library: loaded
          Library version=2023-10-13
              Welcome to the ioBroker installation fixer!
              Script version: 2023-10-13
              You might need to enter your password a couple of times.
              Installing prerequisites (1/5)
          Ign:1 http://security.debian.org/debian-security bullseye/updates InRelease
          OK:2 http://deb.debian.org/debian bullseye InRelease
          Ign:3 http://security.debian.org/debian-security bullseyeupdates InRelease
          OK:4 http://deb.debian.org/debian bullseye-updates InRelease
          OK:5 http://deb.debian.org/debian bullseye-backports InRelease
          Fehl:6 http://security.debian.org/debian-security bullseye/updates Release
            404  Not Found [IP: 199.232.190.132 80]
          Fehl:7 http://security.debian.org/debian-security bullseyeupdates Release
          OK:8 https://deb.nodesource.com/node_18.x nodistro InRelease
          Holen:9 https://packagecloud.io/ookla/speedtest-cli/debian stretch InRelease [24,5 kB]
          Fehl:9 https://packagecloud.io/ookla/speedtest-cli/debian stretch InRelease
            Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 8E61C2AB9A6D1557
          E: Das Depot »http://security.debian.org/debian-security bullseye/updates Release« enthält keine Release-Datei.
          N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
          N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
          E: Das Depot »http://security.debian.org/debian-security bullseyeupdates Release« enthält keine Release-Datei.
          W: GPG-Fehler: https://packagecloud.io/ookla/speedtest-cli/debian stretch InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 8E61C2AB9A6D1557
          E: Das Depot »https://packagecloud.io/ookla/speedtest-cli/debian stretch InRelease« ist nicht signiert.
              Checking ioBroker user and directory permissions (2/5)
              Check and cleanup npm temporary directories (3/5)
          Done.
              Database maintenance (4/5)
          Checking for uncompressed JSONL databases... This might take a while!
          Compressing /opt/iobroker/iobroker-data/states.jsonl
          Compressing /opt/iobroker/iobroker-data/objects.jsonl
          Compressed 2 JSONL files. Done
              Checking autostart (5/5)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          npm WARN skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.esphome.git
          npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
          npm WARN deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
          npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
          npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
          npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
          npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
          npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
          npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
          npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
          npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
          npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
          npm WARN cleanup Failed to remove some directories [
          npm WARN cleanup   [
          npm WARN cleanup     '/opt/iobroker/node_modules/raw-socket',
          npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/raw-socket'] {
          npm WARN cleanup       errno: -39,
          npm WARN cleanup       code: 'ENOTEMPTY',
          npm WARN cleanup       syscall: 'rmdir',
          npm WARN cleanup       path: '/opt/iobroker/node_modules/raw-socket'
          npm WARN cleanup     }
          npm WARN cleanup   ],
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ],
          npm WARN cleanup   [
          npm WARN cleanup     '/opt/iobroker/node_modules/node-snap7',
          npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/node-snap7'] {
          npm WARN cleanup       path: '/opt/iobroker/node_modules/node-snap7'
          npm WARN cleanup     }
          npm WARN cleanup   ],
          npm WARN cleanup   [
          npm WARN cleanup     '/opt/iobroker/node_modules/pcap',
          npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/pcap'] {
          npm WARN cleanup       path: '/opt/iobroker/node_modules/pcap'
          npm WARN cleanup     }
          npm WARN cleanup   ],
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ],
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ]
          npm WARN cleanup ]
          npm ERR! code 1
          npm ERR! path /opt/iobroker/node_modules/node-libcurl
          npm ERR! command failed
          npm ERR! command sh -c node-pre-gyp install --fallback-to-build
          npm ERR! Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v108' (1)
          npm ERR! node-pre-gyp info it worked if it ends with ok
          npm ERR! node-pre-gyp info using node-pre-gyp@1.0.5
          npm ERR! node-pre-gyp info using node@18.18.2 | linux | x64
          npm ERR! node-pre-gyp info check checked for "/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" (not found)
          npm ERR! node-pre-gyp http GET https://github.com/JCMais/node-libcurl/releases/download/v2.3.4/node_libcurl-v2.3.4-node-v108-linux-x64-glibc.tar.gz
          npm ERR! node-pre-gyp ERR! install response status 404 Not Found on https://github.com/JCMais/node-libcurl/releases/download/v2.3.4/node_libcurl-v2.3.4-node-v108-linux-x64-glibc.tar.gz
          npm ERR! node-pre-gyp WARN Pre-built binaries not installable for node-libcurl@2.3.4 and node@18.18.2 (node-v108 ABI, glibc) (falling back to source compile with node-gyp)
          npm ERR! node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/JCMais/node-libcurl/releases/download/v2.3.4/node_libcurl-v2.3.4-node-v108-linux-x64-glibc.tar.gz
          npm ERR! gyp info it worked if it ends with ok
          npm ERR! gyp info using node-gyp@9.4.0
          npm ERR! gyp info using node@18.18.2 | linux | x64
          npm ERR! gyp info ok
          npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
          npm ERR! gyp info spawn /usr/bin/python3
          npm ERR! gyp info spawn args [
          npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
          npm ERR! gyp info spawn args   'binding.gyp',
          npm ERR! gyp info spawn args   '-f',
          npm ERR! gyp info spawn args   'make',
          npm ERR! gyp info spawn args   '-I',
          npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-libcurl/build/config.gypi',
          npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
          npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
          npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
          npm ERR! gyp info spawn args   '-Dvisibility=default',
          npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
          npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
          npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
          npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/node-libcurl',
          npm ERR! gyp info spawn args   '-Dnode_engine=v8',
          npm ERR! gyp info spawn args   '--depth=.',
          npm ERR! gyp info spawn args   '--no-parallel',
          npm ERR! gyp info spawn args   '--generator-output',
          npm ERR! gyp info spawn args   'build',
          npm ERR! gyp info spawn args   '-Goutput_dir=.'
          npm ERR! gyp info spawn args ]
          npm ERR! Could not run curl-config, please make sure libcurl dev package is installed.
          npm ERR! Output: /bin/sh: 1: curl-config: not found
          npm ERR!
          npm ERR! gyp: Call to 'node /opt/iobroker/node_modules/node-libcurl/scripts/curl-config.js --prefix' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
          npm ERR! gyp ERR! configure error
          npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
          npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:325:16)
          npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
          npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
          npm ERR! gyp ERR! System Linux 5.10.0-26-amd64
          npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" "--module_name=node_libcurl" "--module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding" "--napi_version=9" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v108"
          npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/node-libcurl
          npm ERR! gyp ERR! node -v v18.18.2
          npm ERR! gyp ERR! node-gyp -v v9.4.0
          npm ERR! gyp ERR! not ok
          npm ERR! node-pre-gyp ERR! build error
          npm ERR! node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v108' (1)
          npm ERR! node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-libcurl/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
          npm ERR! node-pre-gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
          npm ERR! node-pre-gyp ERR! stack     at maybeClose (node:internal/child_process:1098:16)
          npm ERR! node-pre-gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:303:5)
          npm ERR! node-pre-gyp ERR! System Linux 5.10.0-26-amd64
          npm ERR! node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-libcurl/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
          npm ERR! node-pre-gyp ERR! cwd /opt/iobroker/node_modules/node-libcurl
          npm ERR! node-pre-gyp ERR! node -v v18.18.2
          npm ERR! node-pre-gyp ERR! node-pre-gyp -v v1.0.5
          npm ERR! node-pre-gyp ERR! not ok
          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-03T11_01_57_465Z-debug-0.log
          • G George_Best
            iob fix:
            library: loaded
            Done.
            Autostart enabled!
            npm WARN cleanup   [
            npm WARN cleanup     }
            npm WARN cleanup   ],
            npm WARN cleanup   [
            npm WARN cleanup     }
            npm WARN cleanup   ],
            npm WARN cleanup   [
            npm WARN cleanup     }
            npm WARN cleanup   ],
            npm WARN cleanup   [
            npm WARN cleanup     }
            npm WARN cleanup   ],
            npm WARN cleanup   [
            npm WARN cleanup     }
            npm WARN cleanup   ],
            npm WARN cleanup   [
            npm WARN cleanup     }
            npm WARN cleanup   ]
            npm WARN cleanup ]
            npm ERR! code 1
            npm ERR!
            @george_best
            Du hast auch Chaos in den Repos. Insbesondere im Security-Repo. Und das Speedtest-Rrpo muss auch angepasst werden. Sieht man sowas nicht beim üblichen System-Update?
            sudo apt update
            apt policy libcurl*
            sagt?
              @george_best
              sudo apt update
              apt policy libcurl*
              sagt?
              George_Best
              sudo apt update:
              OK:1 http://deb.debian.org/debian bullseye InRelease
              Ign:2 http://security.debian.org/debian-security bullseye/updates InRelease
              OK:3 http://deb.debian.org/debian bullseye-updates InRelease
              Ign:4 http://security.debian.org/debian-security bullseyeupdates InRelease
              apt policy libcurl*
              libcurl4-openssl-dev:
                Installiert:           (keine)
                Installationskandidat: 7.74.0-1.3+deb11u9
                Versionstabelle:
                   7.88.1-10+deb12u3~bpo11+1 100
                      100 http://deb.debian.org/debian bullseye-backports/main amd64 Packages
                   7.74.0-1.3+deb11u9 500
                      500 http://deb.debian.org/debian bullseye/main amd64 Packages
              libcurl3:
                Installationskandidat: (keine)
                Versionstabelle:
              libcurl4:
                Installiert:           7.74.0-1.3+deb11u9
                Versionstabelle:
               *** 7.74.0-1.3+deb11u9 500
              libcurl3-gnutls:
                Versionstabelle:
              libcurl-ocaml:
                Installationskandidat: 0.9.1-1+b4
                Versionstabelle:
                   0.9.1-1+b4 500
              libcurl3-openssl-dev:
                Versionstabelle:
              libcurl3-gnutls-dev:
                Versionstabelle:
              libcurl4-gnutls-dev:
                Versionstabelle:
              libcurl-dev:
                Versionstabelle:
              libcurlpp0:
                Installationskandidat: 0.8.1-3
                Versionstabelle:
                   0.8.1-3 500
              libcurl-ocaml-dev:
                Versionstabelle:
                   0.9.1-1+b4 500
              libcurl-ocaml-30vr0:
                Versionstabelle:
              libcurlpp-dev:
                Versionstabelle:
                   0.8.1-3 500
              libcurl-ssl-dev:
                Versionstabelle:
              libcurl-ocaml-dev-30vr0:
                Versionstabelle:
              libcurl3-nss-dev:
                Versionstabelle:
              libcurl3-dev:
                Versionstabelle:
              libcurl4-dev:
                Versionstabelle:
              libcurl4-doc:
                Versionstabelle:
              libcurl3-nss:
                Versionstabelle:
              libcurl4-nss-dev:
                Versionstabelle:
              • G George_Best
                sudo apt update:
                apt policy libcurl*
                  Versionstabelle:
                libcurl3:
                  Versionstabelle:
                libcurl4:
                  Versionstabelle:
                libcurl3-gnutls:
                  Versionstabelle:
                libcurl-ocaml:
                  Versionstabelle:
                     0.9.1-1+b4 500
                  Versionstabelle:
                  Versionstabelle:
                  Versionstabelle:
                libcurl-dev:
                  Versionstabelle:
                libcurlpp0:
                  Versionstabelle:
                     0.8.1-3 500
                libcurl-ocaml-dev:
                  Versionstabelle:
                     0.9.1-1+b4 500
                  Versionstabelle:
                libcurlpp-dev:
                  Versionstabelle:
                     0.8.1-3 500
                libcurl-ssl-dev:
                  Versionstabelle:
                  Versionstabelle:
                libcurl3-nss-dev:
                  Versionstabelle:
                libcurl3-dev:
                  Versionstabelle:
                libcurl4-dev:
                  Versionstabelle:
                libcurl4-doc:
                  Versionstabelle:
                libcurl3-nss:
                  Versionstabelle:
                libcurl4-nss-dev:
                  Versionstabelle:
                @george_best
                Joh, ran an die Meldungen.
                Danach:
                sudo apt install libcurl4-gnutls-dev
                • G Offline
                  George_Best
                  jonny@ioBroker-V2:/etc/apt/sources.list.d$ sudo apt update
                  OK:2 http://deb.debian.org/debian bullseye-updates InRelease
                  OK:3 http://deb.debian.org/debian bullseye-backports InRelease
                  OK:4 http://deb.debian.org/debian-security bullseye-security InRelease
                  OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Aktualisierung für 53 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                  jonny@ioBroker-V2:/etc/apt/sources.list.d$ sudo apt install libcurl4-gnutls-dev
                  Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                    aspell-de-alt bsdmainutils cpp-8 dh-python fdisk geoip-database irqbalance libasan5 libbind9-140 libbind9-161
                    libdbus-glib-1-2 libdns-export1104 libdns1104 libdns1110 libdns162 libevent-2.1-6 libgeoip1 libgl1-mesa-glx
                    libicu57 libio-stringy-perl libisc-export1100 libisc1100 libisc1105 libisc160 libisccc140 libisccc161
                    libisccfg140 libisccfg163 libisl19 libjson-c3 libjsoncpp1 liblwres141 liblwres161 libmpdec2 libnftables0 libnuma1
                    libonig4 libperl5.24 libprocps7 libpython3.5 libpython3.5-dev libpython3.5-minimal libpython3.5-stdlib
                    libpython3.7 libpython3.7-dev libpython3.7-minimal libpython3.7-stdlib libxt-dev python3-asn1crypto
                    python3-entrypoints python3-jeepney python3-keyring python3-keyrings.alt python3-pyasn1 python3-pycryptodome
                    python3-secretstorage python3-xdg python3.5 python3.5-dev python3.5-minimal python3.5-venv python3.7-minimal
                    rename sgml-base tcpd usb.ids x11proto-input-dev x11proto-kb-dev xml-core
                  Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                  Die folgenden zusätzlichen Pakete werden installiert:
                    libcurl3-gnutls
                  Vorgeschlagene Pakete:
                    libcurl4-doc libgnutls28-dev libidn11-dev libkrb5-dev libldap2-dev librtmp-dev libssh2-1-dev
                  Die folgenden NEUEN Pakete werden installiert:
                    libcurl4-gnutls-dev
                    libcurl3-gnutls
                  1 aktualisiert, 1 neu installiert, 0 zu entfernen und 52 nicht aktualisiert.
                  Es müssen 778 kB an Archiven heruntergeladen werden.
                  Nach dieser Operation werden 1.619 kB Plattenplatz zusätzlich benutzt.
                  Möchten Sie fortfahren? [J/n] j
                  Holen:1 http://deb.debian.org/debian-security bullseye-security/main amd64 libcurl3-gnutls amd64 7.74.0-1.3+deb11u10 [344 kB]
                  Holen:2 http://deb.debian.org/debian-security bullseye-security/main amd64 libcurl4-gnutls-dev amd64 7.74.0-1.3+deb11u10 [435 kB]
                  Es wurden 778 kB in 0 s geholt (4.014 kB/s).
                  Changelogs werden gelesen... Fertig
                  (Lese Datenbank ... 64938 Dateien und Verzeichnisse sind derzeit installiert.)
                  Vorbereitung zum Entpacken von .../libcurl3-gnutls_7.74.0-1.3+deb11u10_amd64.deb ...
                  Entpacken von libcurl3-gnutls:amd64 (7.74.0-1.3+deb11u10) über (7.74.0-1.3+deb11u9) ...
                  Vormals nicht ausgewähltes Paket libcurl4-gnutls-dev:amd64 wird gewählt.
                  Vorbereitung zum Entpacken von .../libcurl4-gnutls-dev_7.74.0-1.3+deb11u10_amd64.deb ...
                  Entpacken von libcurl4-gnutls-dev:amd64 (7.74.0-1.3+deb11u10) ...
                  libcurl3-gnutls:amd64 (7.74.0-1.3+deb11u10) wird eingerichtet ...
                  libcurl4-gnutls-dev:amd64 (7.74.0-1.3+deb11u10) wird eingerichtet ...
                  Trigger für libc-bin (2.31-13+deb11u6) werden verarbeitet ...
                  Trigger für man-db (2.9.4-2) werden verarbeitet ...
                  • G George_Best
                    sudo apt update:
                    apt policy libcurl*
                      Versionstabelle:
                    libcurl3:
                      Versionstabelle:
                    libcurl4:
                      Versionstabelle:
                    libcurl3-gnutls:
                      Versionstabelle:
                    libcurl-ocaml:
                      Versionstabelle:
                         0.9.1-1+b4 500
                      Versionstabelle:
                      Versionstabelle:
                      Versionstabelle:
                    libcurl-dev:
                      Versionstabelle:
                    libcurlpp0:
                      Versionstabelle:
                         0.8.1-3 500
                    libcurl-ocaml-dev:
                      Versionstabelle:
                         0.9.1-1+b4 500
                      Versionstabelle:
                    libcurlpp-dev:
                      Versionstabelle:
                         0.8.1-3 500
                    libcurl-ssl-dev:
                      Versionstabelle:
                      Versionstabelle:
                    libcurl3-nss-dev:
                      Versionstabelle:
                    libcurl3-dev:
                      Versionstabelle:
                    libcurl4-dev:
                      Versionstabelle:
                    libcurl4-doc:
                      Versionstabelle:
                    libcurl3-nss:
                      Versionstabelle:
                    libcurl4-nss-dev:
                      Versionstabelle:
                    @george_best
                    In der /etc/apt/sources.list muss die Zeile bezüglich Security so aussehen:
                    deb http://deb.debian.org/debian-security/ bullseye-security main contrib non-free non-free-firmware
                    Alle anderen Zeilen mit Security drin müssen raus.
                    Dann die .list-Datei mit den Backports löschen. Liegt vermutlich in /etc/apt/sources.list.d
                    Und die .list-Datei zum Speedtest muss auch auf bullseye statt stretch lauten.
                    • G George_Best
                        libcurl3-gnutls
                        libcurl4-gnutls-dev
                        libcurl3-gnutls
                      @george_best
                      Okay, hat sich überschnitten...
                      Die mehr als 50 Updates reinziehen!
                      sudo apt full-upgrade
                      sudo reboot
                      Vorher die Backports aber ausschalten.
                        @george_best
                        George_Best
                        @thomas-braun sagte in Update js-controller - "nodejs is NOT correctly installed":
                        da liegt nur:
                        nodesource.list
                        ookla_speedtest-cli.list
                        In der sources.list sind diese Einträge drin:
                        deb http://deb.debian.org/debian bullseye-backports main
                        deb-src http://deb.debian.org/debian bullseye-backports main
                        Soll ich diese Einträge aus der sources.list rausnehmen?
                        • G George_Best
                          da liegt nur:
                          nodesource.list
                          @george_best
                          Ja. Backports will man eigentlich nicht verwenden.
                            @george_best
                            George_Best
                            @thomas-braun Ich versuch mich mal nun wieder nach oben zu hangeln..
                            sagt nun:
                            npm ERR! code 6
                            npm ERR! path /opt/iobroker/node_modules/iobroker.vis-google-fonts
                            npm ERR! command sh -c node main.js --install
                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-03T12_24_45_263Z-debug-0.log
                            • G George_Best
                              sagt nun:
                              npm ERR! code 6
                              George_Best
                              sehr seltsam... Beim 2.
                              wurde der js-controller nun installiert...
                              • G George_Best
                                George_Best
                                Was für ein Kampf 😧
                                Aber letztendlich doch erfolgreich - JS-Controller wurde erfolgreich geupdated.
                                @Thomas-Braun Vielen, vielen Dank für deine Hilfe und deine unendliche Geduld 😊
                                • G George_Best
                                  Was für ein Kampf 😧
                                  @george_best
                                  Gut. Dann schau jetzt per
                                  iob diag
                                  über Ganze nochmal drüber.
                                  • G Offline
                                    George_Best
                                    Das sieht es jetzt prinzipiell besser aus...
                                    Errors in npm tree:
                                    npm ERR! code ELSPROBLEMS
                                    npm ERR! invalid: iobroker.vis-materialdesign@0.2.62 /opt/iobroker/node_modules/iobroker.vis-materialdesign
                                    npm ERR! invalid: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
                                    npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
                                    npm ERR! missing: cli@0.4.x, required by ipv6@3.1.1
                                    npm ERR! missing: cliff@0.1.x, required by ipv6@3.1.1
                                    npm ERR! A complete log of this run can be found in: /home/jonny/.npm/_logs/2023-11-03T15_35_17_056Z-debug-0.log
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Core adapters versions
                                    js-controller:  5.0.12
                                    admin:          6.12.0
                                    javascript:     7.1.4
                                    npm ERR! A complete log of this run can be found in: /home/jonny/.npm/_logs/2023-11-03T15_35_25_269Z-debug-0.log
                                    Adapters from github:   1
                                    Aber den iobroker.vis-materialdesign kann ich nicht entfernen, da scheinbar 50% meiner Vis darauf basieren.
                                    • G George_Best
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.12.0
                                      javascript:     7.1.4
                                      @george_best
                                      Dann installiere den nochmal.
                                      iob upgrade vis-materialdesign@0.5.9
                                        @george_best
                                        George_Best
                                        schrieb am zuletzt editiert von George_Best
                                        jonny@ioBroker-V2:~$ iob upgrade vis-materialdesign@0.5.9
                                        Adapter "vis-materialdesign" is not in the repository and cannot be updated.
                                        Der ist (vermutlich) von hier: https://github.com/Scrounger/ioBroker.vis-materialdesign/blob/master/README.md
                                        • G George_Best
                                          @george_best
                                          Dann zieh das aus npm / Beta rein. Der hat es nie nach Stable gebracht:
                                          vis-materialdesign
                                          github:	0.5.94
                                          latest:	0.5.9 for 29 months
                                          stable:	-.-.-
