  4. Error im admin.0 [Alias subscription error]
17 Beiträge 3 Kommentatoren 1.9k Aufrufe 1 Beobachtet
  • F Offline
    Flopsi
    schrieb am zuletzt editiert von Flopsi
    Systemdata
    Hardwaresystem: PI4
    Arbeitsspeicher: 8GB
    Festplattenart: SSD
    Betriebssystem: Linux
    Node-Version: 18.18.2
    Nodejs-Version: 18.18.2
    NPM-Version: 9.8.1
    Installationsart: -
    Image genutzt: -
    Ort/Name der Imagedatei: -
    Ich habe hin und wieder folgenden ERROR :
    admin.0
    	2023-11-01 09:44:26.972	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Binary_Sensor.motion, sourceObj={"type":"state","common":{"role":"indicator","read":true,"write":false,"name":"Sensor state (Motion)","type":"boolean"},"native":{"nodeId":65,"valueId":{"commandClass":48,"endpoint":0,"property":"Motion"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334268930,"_id":"zwave2.0.Node_065.Binary_Sensor.motion","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    	2023-11-01 09:44:26.973	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Multilevel_Sensor.humidity, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Humidity","type":"number","unit":"%"},"native":{"nodeId":65,"valueId":{"commandClass":49,"endpoint":0,"property":"Humidity"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334270043,"_id":"zwave2.0.Node_065.Multilevel_Sensor.humidity","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    	2023-11-01 09:44:26.974	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Multilevel_Sensor.illuminance, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Illuminance","type":"number","unit":"Lux"},"native":{"nodeId":65,"valueId":{"commandClass":49,"endpoint":0,"property":"Illuminance"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334269984,"_id":"zwave2.0.Node_065.Multilevel_Sensor.illuminance","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    	2023-11-01 09:44:26.975	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Multilevel_Sensor.airTemperature, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Air temperature","type":"number","unit":"°C"},"native":{"nodeId":65,"valueId":{"commandClass":49,"endpoint":0,"property":"Air temperature"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334269209,"_id":"zwave2.0.Node_065.Multilevel_Sensor.airTemperature","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    	2023-11-01 09:44:26.975	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Binary_Sensor.motion, sourceObj={"type":"state","common":{"role":"indicator","read":true,"write":false,"name":"Sensor state (Motion)","type":"boolean"},"native":{"nodeId":64,"valueId":{"commandClass":48,"endpoint":0,"property":"Motion"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1697812897069,"_id":"zwave2.0.Node_064.Binary_Sensor.motion","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    	2023-11-01 09:44:26.976	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Multilevel_Sensor.humidity, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Humidity","type":"number","unit":"%","custom":{"history.0":{"enabled":true,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":31536000,"customRetentionDuration":365,"maxLength":960,"enableDebugLogs":false,"debounce":1000}}},"native":{"nodeId":64,"valueId":{"commandClass":49,"endpoint":0,"property":"Humidity"}},"_id":"zwave2.0.Node_064.Multilevel_Sensor.humidity","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698827722577}
    admin.0
    	2023-11-01 09:44:26.977	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Multilevel_Sensor.illuminance, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Illuminance","type":"number","unit":"Lux","custom":{"history.0":{"enabled":true,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":31536000,"customRetentionDuration":365,"maxLength":960,"enableDebugLogs":false,"debounce":1000}}},"native":{"nodeId":64,"valueId":{"commandClass":49,"endpoint":0,"property":"Illuminance"}},"_id":"zwave2.0.Node_064.Multilevel_Sensor.illuminance","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698827724985}
    admin.0
    	2023-11-01 09:44:26.977	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Multilevel_Sensor.airTemperature, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Air temperature","type":"number","unit":"°C"},"native":{"nodeId":64,"valueId":{"commandClass":49,"endpoint":0,"property":"Air temperature"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1697812898332,"_id":"zwave2.0.Node_064.Multilevel_Sensor.airTemperature","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    Die Fehlermeldungen sind erst seitdem ich meine beiden Multi 7 Sensoren von Aeotec über Zwave 2 eingebunden habe.
    Die Sensoren funktionieren eigentlich so wie sie sollen.
    Weis wer was hier den Fehler verursacht ?
    @AlCalzone evtl. ?
    Thomas BraunT haus-automatisierungH 2 Antworten Letzte Antwort
    • F Flopsi
      Systemdata
      Hardwaresystem: PI4
      Festplattenart: SSD
      NPM-Version: 9.8.1
      Installationsart: -
      Image genutzt: -
      admin.0
      admin.0
      admin.0
      admin.0
      admin.0
      admin.0
      admin.0
      admin.0
      @AlCalzone evtl. ?
      @flopsi
      Nodejs-Version: 18.17.1
      Du stehst offenbar auf dem Abstellgleis, was nodejs angeht
      iob nodejs-update
      ausführen, ggfs. zuvor iob fix
      F 1 Antwort Letzte Antwort
        @flopsi
        iob nodejs-update
        Flopsi
        ioBroker nodejs fixer 2023-10-13
        Recommended nodejs-version is: 18.18.2
        Checking your installation now. Please be patient!
        Your current setup is:
        /usr/bin/nodejs         v18.17.1
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        /usr/bin/corepack       0.18.0
        We found these nodejs versions available for installation:
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main ar                                          m64 Packages
        Nothing to do - Your installation is using the correct paths.
        You are running nodejs v18.17.1. Do you want to install recommended version 18.1                                          8.2?
        Press <y> to continue or any other key to quit
        • F Flopsi
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          @flopsi
          Siehste. 18.18.2 ist aktuell angesagt...
            @flopsi
            Flopsi
            OK bin auf der neusten Version dann schaue ich erstmal ob der Error wieder auftritt ...
            • F Flopsi
              @flopsi
              Nein, der hat damit nix zu tun. War aber dennoch falsch.
                @flopsi
                Flopsi
                Zu meinem eigentlichen Problem hast du keine Idee ?
                • F Flopsi
                  @flopsi
                  Dann hätte ich dazu was geschrieben.
                  • F Flopsi
                    Systemdata
                    Hardwaresystem: PI4
                    Festplattenart: SSD
                    NPM-Version: 9.8.1
                    Installationsart: -
                    Image genutzt: -
                    admin.0
                    admin.0
                    admin.0
                    admin.0
                    admin.0
                    admin.0
                    admin.0
                    admin.0
                    @AlCalzone evtl. ?
                    haus-automatisierungH Offline
                    @flopsi Dann zeig doch mal, wie der Alias definiert ist
                    📚 Meine Dokumentation
                      Flopsi
                      @haus-automatisierung
                      createAlias('zwave2.0.Node_065.Multilevel_Sensor.illuminance','Flur.Multisensor.Aeotec_7.Lux');
                      createAlias('zwave2.0.Node_065.Multilevel_Sensor.airTemperature','Flur.Multisensor.Aeotec_7.Temp');
                      createAlias('zwave2.0.Node_065.Binary_Sensor.motion','Flur.Multisensor.Aeotec_7.Bewegung');
                      createAlias('zwave2.0.Node_065.Multilevel_Sensor.humidity','Flur.Multisensor.Aeotec_7.Luftfeuchtigkeit');
                      createAlias('zwave2.0.Node_064.Multilevel_Sensor.illuminance','Kueche.Multisensor.Aeotec_7.Lux');
                      createAlias('zwave2.0.Node_064.Multilevel_Sensor.airTemperature','Kueche.Multisensor.Aeotec_7.Temp');
                      createAlias('zwave2.0.Node_064.Binary_Sensor.motion','Kueche.Multisensor.Aeotec_7.Bewegung');
                      createAlias('zwave2.0.Node_064.Multilevel_Sensor.humidity','Kueche.Multisensor.Aeotec_7.Luftfeuchtigkeit');
                      • F Flopsi
                        schrieb am zuletzt editiert von haus-automatisierung
                        @flopsi Ich meine die Objekt-Definition vom erstellten Alias
                        EDIT: Du benutzt createAlias falsch. Gerade mal in die Doku geschaut.
                        • name ist die ID des Alias und
                        • alias ist die ID, auf welcher sich dieser bezieht.
                        Also die Parameter einmal umdrehen jeweils.
                          Flopsi
                          @haus-automatisierung sagte in Error im admin.0 [Alias subscription error]:
                          createAlias
                          Versteh nicht was ich umdrehen soll ? Kannst du mir ein Beispiel zeigen ?
                          Ich erstelle all meine Alias nach dem Schema nie probleme gehabt erst seit den neuen Sensoren...
                          Ich nutze das folgendes Skript für:
                          Github - https://github.com/xCruziX/ioBroker-Creating-Alias/blob/master/CreateAlias.js
                          				Changelog
                          Version 1.1.3
                            - use callbacks in alias-path
                          Version 1.1.2
                            - fix log message 'Created Alias-Path '
                          Version 1.1.1
                            - Bugfixing, clean functions
                          Version 1.1.0
                            - added function for cleaning enums
                          Version 1.0.6
                            - use callback functions for safety call
                          Version 1.0.5
                            - decrease timeout assing enum
                          Version 1.0.4
                            - Bugfixing array id lenght
                          Version 1.0.3
                            - Githublink
                          Version 1.0.2
                            - existsObject for Alias in the timeout
                            - remove lowerCase enum
                            - improved logs
                          Version 1.0.1
                            - Rooms and functions casesensitive
                          Version 1.0
                          		Flags /
                          		Variablen
                          // typeAlias = 'boolean'; // oder 'number'
                          // read = "val == 'Ein' ? true : false"; // Erkennung "Aus" --> false erfolgt automatisch
                          // write = "val ? 'Ein' : 'Aus'";
                          // nameAlias = 'Licht Haustür';
                          // role = 'switch';
                          // desc = 'per Script erstellt';
                          // min = 0; // nur Zahlen
                          // max = 100; // nur Zahlen
                          // unit = '%'; // nur für Zahlen
                          // states = {0: 'Aus', 1: 'Auto', 2: 'Ein'}; // Zahlen (Multistate) oder Logikwert (z.B. Aus/Ein)
                          let bCreateAliasPath = false;  // If this flag is true, each folder is created seperately so rooms and functions can be assigned.
                          Requirements: bCreateAliasPath == true
                          If this flag is true, existing folders in the path will be converted so rooms and functions can be assigned.
                          let bConvertExistingPath = false;
                          	Don't change anything from here /
                          	Ab hier nichts verändern
                          let arEnum = [];
                          let arId = [];
                          let timeoutAssignEnum;
                          function createAlias(idSrc, idDst,raum, gewerk,typeAlias, read, write, nameAlias, role, desc, min, max, unit, states) {
                            if(!idDst.includes('alias.0.'))
                                idDst = 'alias.0.' + idDst;
                            if(!existsObject(idSrc))
                                log('Source-Id ' + idSrc +' does not exists.','warn');
                                return;
                            // Create the object Path for alias id,
                            // so you can assign rooms and function to the parents
                            var createAliasPath = (id) => {
                                 if(bCreateAliasPath){
                                      let lisMergedIds = [];
                                      let mergedId = 'alias.0';
                                      id = id.replace(mergedId + '.', ''); // Remove prefix alias so it will not be changed
                                      let split = id.split('.');
                                      for(let i=0;i<split.length-1;i++){
                                          mergedId += '.' + split[i];
                                          lisMergedIds.push(mergedId);
                                      function path(){
                                          if(lisMergedIds.length == 0) {// Zu Ende erstellt
                                              alias();
                                              return;
                                          let tmpId = lisMergedIds[0];
                                          lisMergedIds.splice(0,1); // entferne element
                                          if(!existsObject(tmpId) || bConvertExistingPath){ // not exists
                                              let obj;
                                              if(existsObject(tmpId))
                                                  obj = getObject(tmpId);
                                              else
                                                  obj = {};
                                              if(obj.type == undefined || obj.type != 'meta')
                                                  obj.type = 'meta';
                                              if(obj.common == undefined || obj.common != {})
                                                  obj.common = {};
                                              if(obj.common.type == undefined || obj.common.type != 'meta.folder')
                                                  obj.common.type = 'meta.folder';
                                              if(obj.common.desc == undefined || obj.common.desc != 'createAliasPath')
                                                  obj.common.desc = 'createAliasPath';
                                              if(obj.common.def == undefined || obj.common.def != false)
                                                  obj.common.def = false;
                                              if(obj.native == undefined || obj.native != {})
                                                  obj.native = {};
                                              setObject(tmpId, obj, (err) =>{
                                                  if(!err){
                                                      log('Created Alias-Path ' + tmpId);
                                                      path();
                                                  else
                                                      log('Error creating alias-path','error');
                                      path();
                                 else
                                   alias();
                              //   createAliasPath(idDst);
                            function alias(){
                                // Create alias object
                                  if(!existsObject(idDst)){
                                      let obj = {};
                                      obj.type = 'state';
                                      obj.common = getObject(idSrc).common;
                                      obj.common.alias = {};
                                      obj.common.alias.id = idSrc;
                                      if(typeAlias !== undefined)
                                          obj.common.type = typeAlias;
                                      if(obj.common.read !== undefined)
                                          obj.common.alias.read = read;
                                      if(obj.common.write !== undefined)
                                          obj.common.alias.write = write;
                                      if(nameAlias !== undefined)
                                          obj.common.name = nameAlias;
                                      if(role !== undefined)
                                          obj.common.role = role;
                                      if(desc !== undefined)
                                          obj.common.desc = desc;
                                      if(min !== undefined)
                                          obj.common.min = min;
                                      if(max !== undefined)
                                          obj.common.max = max;
                                      if(unit !== undefined)
                                          obj.common.unit = unit;
                                      if(states !== undefined)
                                          obj.common.states = states;
                                      obj.native = {};
                                      obj.common.custom = []; // Damit die Zuordnung zu iQontrol, Sql etc. nicht übernommen wird
                                      log('Created Alias-State ' + idDst);
                                      setObject(idDst, obj,(err) =>{
                                          if(!err)
                                              startAttach();
                                          else
                                              log('Error creating-alias','error');
                                  else
                                      startAttach();
                            // Save ID and Enum (room or function)
                            var attach = (id, enu,value) => {
                                if(id.length == 0){
                                    log('ID has lenght 0, can not attach to enum','warn');
                                    return;
                                if(value.length == 0){
                                    log('Value has lenght 0','warn');
                                    return;
                                let sEnuId = 'enum.' + enu + '.' + value;
                                if(enu.length > 0 && existsObject(sEnuId))
                                    let obj = getObject(sEnuId)
                                    let members = obj.common.members;
                                    if(!members.includes(id)){
                                        arEnum.push(sEnuId);
                                        arId.push(id);
                                else
                             	      log('Can not find enum ' + sEnuId,'warn');
                           function startAttach(){
                              let bRoom = raum !== undefined && raum.length > 0;
                              let bGewerk = gewerk !== undefined && gewerk.length > 0;
                              if(bRoom)
                                  attach(idDst,'rooms',raum);
                              if(bGewerk)
                                  attach(idDst,'functions',gewerk);
                              if(bRoom || bGewerk){
                                      if(timeoutAssignEnum){
                                          clearTimeout(timeoutAssignEnum);
                                          timeoutAssignEnum = null;
                                      timeoutAssignEnum = setTimeout(finishScript,100);
                          function finishScript(){
                          	assignEnums();
                          // Add the saved IDs to the rooms/functions
                          function assignEnums(){
                           if(arEnum.length == 0 || arId.length == 0){
                                return;
                           if(arEnum.length != arId.length){
                                log('Arrays have different size','error');
                                return;
                           let mapEnumId = new Map();
                           for(let i=0;i < arEnum.length; i++){
                               let enu = arEnum[i];
                               let id = arId[i];
                               if(existsObject(id)){
                              	 let obj = getObject(enu)
                              	 let members;
                              	 if(!mapEnumId.has(enu)){
                              		 mapEnumId.set(enu,members);
                              	 else
                              		 members = mapEnumId.get(enu);
                              		  log("Adding " + id + " to " + enu);
                              		  members.push(id);
                               else
                                   log('Can not find Alias ' + id,'error');
                            function setMembers(members,enu,map){
                                let obj = getObject(enu);
                                obj.common.members = members;
                                setObject(enu,obj);
                            mapEnumId.forEach(setMembers);
                          Hier noch die Objekt-Definition: ( Ich hoffe es ist die richtige das gibt es ja zu jedem Datenpunkt eine ....
                            "type": "channel",
                            "common": {
                              "name": "alias.0.Flur.Multisensor.Aeotec_7"
                            "_id": "alias.0.Flur.Multisensor.Aeotec_7",
                            "native": {},
                            "user": "system.user.admin",
                            "ts": 1698686702683,
                            "acl": {
                              "object": 1636,
                              "owner": "system.user.admin",
                          • F Flopsi
                            createAlias
                            				Changelog
                            Version 1.1.3
                            Version 1.1.2
                            Version 1.1.1
                            Version 1.1.0
                            Version 1.0.6
                            Version 1.0.5
                            Version 1.0.4
                            Version 1.0.3
                              - Githublink
                            Version 1.0.2
                              - improved logs
                            Version 1.0.1
                            Version 1.0
                            		Flags /
                            		Variablen
                            // role = 'switch';
                            let arEnum = [];
                            let arId = [];
                                  return;
                                        function path(){
                                                alias();
                                                return;
                                                let obj;
                                                else
                                                    obj = {};
                                                    obj.type = 'meta';
                                                    obj.common = {};
                                                    obj.native = {};
                                                    if(!err){
                                                        path();
                                                    else
                                        path();
                                   else
                                     alias();
                              function alias(){
                                        let obj = {};
                                        obj.type = 'state';
                                        obj.native = {};
                                            if(!err)
                                                startAttach();
                                            else
                                    else
                                        startAttach();
                                  if(id.length == 0){
                                      return;
                                      return;
                                          arId.push(id);
                                  else
                                if(bRoom)
                                if(bGewerk)
                            	assignEnums();
                                  return;
                                  return;
                                 let id = arId[i];
                                	 let members;
                                	 else
                                		  members.push(id);
                                 else
                                  setObject(enu,obj);
                              "type": "channel",
                              "common": {
                              "native": {},
                              "acl": {
                                "object": 1636,
                            @flopsi sagte in Error im admin.0 [Alias subscription error]:
                            Statt
                            createAlias('zwave2.0.Node_065.Multilevel_Sensor.illuminance', 'Flur.Multisensor.Aeotec_7.Lux');
                            muss es so aussehen:
                            createAlias('Flur.Multisensor.Aeotec_7.Lux', 'zwave2.0.Node_065.Multilevel_Sensor.illuminance');
                            dein Script lese ich mir jetzt nicht komplett durch
                            Ja, und da fehlt die ID, auf welcher sich der Alias beziehen soll. Daher die Fehler.
                            • F Flopsi
                              createAlias
                              				Changelog
                              Version 1.1.3
                              Version 1.1.2
                              Version 1.1.1
                              Version 1.1.0
                              Version 1.0.6
                              Version 1.0.5
                              Version 1.0.4
                              Version 1.0.3
                                - Githublink
                              Version 1.0.2
                                - improved logs
                              Version 1.0.1
                              Version 1.0
                              		Flags /
                              		Variablen
                              // role = 'switch';
                              let arEnum = [];
                              let arId = [];
                                    return;
                                          function path(){
                                                  alias();
                                                  return;
                                                  let obj;
                                                  else
                                                      obj = {};
                                                      obj.type = 'meta';
                                                      obj.common = {};
                                                      obj.native = {};
                                                      if(!err){
                                                          path();
                                                      else
                                          path();
                                     else
                                       alias();
                                function alias(){
                                          let obj = {};
                                          obj.type = 'state';
                                          obj.native = {};
                                              if(!err)
                                                  startAttach();
                                              else
                                      else
                                          startAttach();
                                    if(id.length == 0){
                                        return;
                                        return;
                                            arId.push(id);
                                    else
                                  if(bRoom)
                                  if(bGewerk)
                              	assignEnums();
                                    return;
                                    return;
                                   let id = arId[i];
                                  	 let members;
                                  	 else
                                  		  members.push(id);
                                   else
                                    setObject(enu,obj);
                                "type": "channel",
                                "common": {
                                "native": {},
                                "acl": {
                                  "object": 1636,
                              Okay, ich hab es mir nun doch angeschaut und frage mich, was der Sinn von diesem Script ist. Das kann der JavaScript-Adapter doch von Haus aus?
                              https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#createalias
                              Wenn Du eigene Funktionen definierst (und diese auch noch genauso nennst, wie Standard-Funktionen im JavaScript-Adapter), dann wäre das schon eine Info im Ausgangspost wert :)
                                Flopsi
                                ich habe das Skript einfach nur kopiert .....
                                creates Alias ......
                                die Alias erstellt und mich dann auf die Alias Datenpunkte bezogen.
                                Wie machst du das denn mit den Alias ?
                                • F Flopsi
                                  @flopsi Manuell über den Geräte-Adapter erstellen
                                  Aber das löst ja dein Problem nicht. Jedenfalls erstellt dein Script den Alias Datenpunkt nicht korrekt. Würde ich nicht mehr verwenden, wenn der JavsScript Adapter das direkt mitbringt.
                                    Flopsi
                                    Problem erscheint schon zwei Tage nicht mehr
                                    habe folgendes geändert:
                                    ich habe diesen Texteil gelöscht
                                    .Aeotec_7
                                    so sieht es jetzt aus:
                                    createAlias('Flur.Multisensor.Lux', 'zwave2.0.Node_065.Multilevel_Sensor.illuminance');
                                    jetzt kommen keine Error mehr und die fehlende ID wurde auch erstellt
