  4. Error im admin.0 [Alias subscription error]
17 Beiträge 3 Kommentatoren 1.9k Aufrufe 1 Beobachtet
  • F Flopsi
    OK bin auf der neusten Version dann schaue ich erstmal ob der Error wieder auftritt ...
    @flopsi
    Nein, der hat damit nix zu tun. War aber dennoch falsch.
    F 1 Antwort Letzte Antwort
      @flopsi
      Flopsi
      Zu meinem eigentlichen Problem hast du keine Idee ?
      • F Flopsi
        @flopsi
        Dann hätte ich dazu was geschrieben.
        • F Flopsi
          Systemdata
          Hardwaresystem: PI4
          Arbeitsspeicher: 8GB
          Festplattenart: SSD
          Betriebssystem: Linux
          Node-Version: 18.18.2
          Nodejs-Version: 18.18.2
          NPM-Version: 9.8.1
          Installationsart: -
          Image genutzt: -
          Ort/Name der Imagedatei: -
          Ich habe hin und wieder folgenden ERROR :
          admin.0
          	2023-11-01 09:44:26.972	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Binary_Sensor.motion, sourceObj={"type":"state","common":{"role":"indicator","read":true,"write":false,"name":"Sensor state (Motion)","type":"boolean"},"native":{"nodeId":65,"valueId":{"commandClass":48,"endpoint":0,"property":"Motion"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334268930,"_id":"zwave2.0.Node_065.Binary_Sensor.motion","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
          admin.0
          	2023-11-01 09:44:26.973	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Multilevel_Sensor.humidity, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Humidity","type":"number","unit":"%"},"native":{"nodeId":65,"valueId":{"commandClass":49,"endpoint":0,"property":"Humidity"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334270043,"_id":"zwave2.0.Node_065.Multilevel_Sensor.humidity","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
          admin.0
          	2023-11-01 09:44:26.974	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Multilevel_Sensor.illuminance, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Illuminance","type":"number","unit":"Lux"},"native":{"nodeId":65,"valueId":{"commandClass":49,"endpoint":0,"property":"Illuminance"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334269984,"_id":"zwave2.0.Node_065.Multilevel_Sensor.illuminance","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
          admin.0
          	2023-11-01 09:44:26.975	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Multilevel_Sensor.airTemperature, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Air temperature","type":"number","unit":"°C"},"native":{"nodeId":65,"valueId":{"commandClass":49,"endpoint":0,"property":"Air temperature"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334269209,"_id":"zwave2.0.Node_065.Multilevel_Sensor.airTemperature","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
          admin.0
          	2023-11-01 09:44:26.975	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Binary_Sensor.motion, sourceObj={"type":"state","common":{"role":"indicator","read":true,"write":false,"name":"Sensor state (Motion)","type":"boolean"},"native":{"nodeId":64,"valueId":{"commandClass":48,"endpoint":0,"property":"Motion"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1697812897069,"_id":"zwave2.0.Node_064.Binary_Sensor.motion","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
          admin.0
          	2023-11-01 09:44:26.976	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Multilevel_Sensor.humidity, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Humidity","type":"number","unit":"%","custom":{"history.0":{"enabled":true,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":31536000,"customRetentionDuration":365,"maxLength":960,"enableDebugLogs":false,"debounce":1000}}},"native":{"nodeId":64,"valueId":{"commandClass":49,"endpoint":0,"property":"Humidity"}},"_id":"zwave2.0.Node_064.Multilevel_Sensor.humidity","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698827722577}
          admin.0
          	2023-11-01 09:44:26.977	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Multilevel_Sensor.illuminance, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Illuminance","type":"number","unit":"Lux","custom":{"history.0":{"enabled":true,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":31536000,"customRetentionDuration":365,"maxLength":960,"enableDebugLogs":false,"debounce":1000}}},"native":{"nodeId":64,"valueId":{"commandClass":49,"endpoint":0,"property":"Illuminance"}},"_id":"zwave2.0.Node_064.Multilevel_Sensor.illuminance","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698827724985}
          admin.0
          	2023-11-01 09:44:26.977	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Multilevel_Sensor.airTemperature, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Air temperature","type":"number","unit":"°C"},"native":{"nodeId":64,"valueId":{"commandClass":49,"endpoint":0,"property":"Air temperature"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1697812898332,"_id":"zwave2.0.Node_064.Multilevel_Sensor.airTemperature","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
          Die Fehlermeldungen sind erst seitdem ich meine beiden Multi 7 Sensoren von Aeotec über Zwave 2 eingebunden habe.
          Die Sensoren funktionieren eigentlich so wie sie sollen.
          Weis wer was hier den Fehler verursacht ?
          @AlCalzone evtl. ?
          haus-automatisierungH Offline
          @flopsi Dann zeig doch mal, wie der Alias definiert ist
          📚 Meine Dokumentation
            Flopsi
            @haus-automatisierung
            createAlias('zwave2.0.Node_065.Multilevel_Sensor.illuminance','Flur.Multisensor.Aeotec_7.Lux');
            createAlias('zwave2.0.Node_065.Multilevel_Sensor.airTemperature','Flur.Multisensor.Aeotec_7.Temp');
            createAlias('zwave2.0.Node_065.Binary_Sensor.motion','Flur.Multisensor.Aeotec_7.Bewegung');
            createAlias('zwave2.0.Node_065.Multilevel_Sensor.humidity','Flur.Multisensor.Aeotec_7.Luftfeuchtigkeit');
            createAlias('zwave2.0.Node_064.Multilevel_Sensor.illuminance','Kueche.Multisensor.Aeotec_7.Lux');
            createAlias('zwave2.0.Node_064.Multilevel_Sensor.airTemperature','Kueche.Multisensor.Aeotec_7.Temp');
            createAlias('zwave2.0.Node_064.Binary_Sensor.motion','Kueche.Multisensor.Aeotec_7.Bewegung');
            createAlias('zwave2.0.Node_064.Multilevel_Sensor.humidity','Kueche.Multisensor.Aeotec_7.Luftfeuchtigkeit');
            • F Flopsi
              @flopsi Ich meine die Objekt-Definition vom erstellten Alias
              EDIT: Du benutzt createAlias falsch. Gerade mal in die Doku geschaut.
              • name ist die ID des Alias und
              • alias ist die ID, auf welcher sich dieser bezieht.
              Also die Parameter einmal umdrehen jeweils.
                Flopsi
                @haus-automatisierung sagte in Error im admin.0 [Alias subscription error]:
                createAlias
                Versteh nicht was ich umdrehen soll ? Kannst du mir ein Beispiel zeigen ?
                Ich erstelle all meine Alias nach dem Schema nie probleme gehabt erst seit den neuen Sensoren...
                Ich nutze das folgendes Skript für:
                Github - https://github.com/xCruziX/ioBroker-Creating-Alias/blob/master/CreateAlias.js
                				Changelog
                Version 1.1.3
                  - use callbacks in alias-path
                Version 1.1.2
                  - fix log message 'Created Alias-Path '
                Version 1.1.1
                  - Bugfixing, clean functions
                Version 1.1.0
                  - added function for cleaning enums
                Version 1.0.6
                  - use callback functions for safety call
                Version 1.0.5
                  - decrease timeout assing enum
                Version 1.0.4
                  - Bugfixing array id lenght
                Version 1.0.3
                  - Githublink
                Version 1.0.2
                  - existsObject for Alias in the timeout
                  - remove lowerCase enum
                  - improved logs
                Version 1.0.1
                  - Rooms and functions casesensitive
                Version 1.0
                		Flags /
                		Variablen
                // typeAlias = 'boolean'; // oder 'number'
                // read = "val == 'Ein' ? true : false"; // Erkennung "Aus" --> false erfolgt automatisch
                // write = "val ? 'Ein' : 'Aus'";
                // nameAlias = 'Licht Haustür';
                // role = 'switch';
                // desc = 'per Script erstellt';
                // min = 0; // nur Zahlen
                // max = 100; // nur Zahlen
                // unit = '%'; // nur für Zahlen
                // states = {0: 'Aus', 1: 'Auto', 2: 'Ein'}; // Zahlen (Multistate) oder Logikwert (z.B. Aus/Ein)
                let bCreateAliasPath = false;  // If this flag is true, each folder is created seperately so rooms and functions can be assigned.
                Requirements: bCreateAliasPath == true
                If this flag is true, existing folders in the path will be converted so rooms and functions can be assigned.
                let bConvertExistingPath = false;
                	Don't change anything from here /
                	Ab hier nichts verändern
                let arEnum = [];
                let arId = [];
                let timeoutAssignEnum;
                function createAlias(idSrc, idDst,raum, gewerk,typeAlias, read, write, nameAlias, role, desc, min, max, unit, states) {
                  if(!idDst.includes('alias.0.'))
                      idDst = 'alias.0.' + idDst;
                  if(!existsObject(idSrc))
                      log('Source-Id ' + idSrc +' does not exists.','warn');
                      return;
                  // Create the object Path for alias id,
                  // so you can assign rooms and function to the parents
                  var createAliasPath = (id) => {
                       if(bCreateAliasPath){
                            let lisMergedIds = [];
                            let mergedId = 'alias.0';
                            id = id.replace(mergedId + '.', ''); // Remove prefix alias so it will not be changed
                            let split = id.split('.');
                            for(let i=0;i<split.length-1;i++){
                                mergedId += '.' + split[i];
                                lisMergedIds.push(mergedId);
                            function path(){
                                if(lisMergedIds.length == 0) {// Zu Ende erstellt
                                    alias();
                                    return;
                                let tmpId = lisMergedIds[0];
                                lisMergedIds.splice(0,1); // entferne element
                                if(!existsObject(tmpId) || bConvertExistingPath){ // not exists
                                    let obj;
                                    if(existsObject(tmpId))
                                        obj = getObject(tmpId);
                                    else
                                        obj = {};
                                    if(obj.type == undefined || obj.type != 'meta')
                                        obj.type = 'meta';
                                    if(obj.common == undefined || obj.common != {})
                                        obj.common = {};
                                    if(obj.common.type == undefined || obj.common.type != 'meta.folder')
                                        obj.common.type = 'meta.folder';
                                    if(obj.common.desc == undefined || obj.common.desc != 'createAliasPath')
                                        obj.common.desc = 'createAliasPath';
                                    if(obj.common.def == undefined || obj.common.def != false)
                                        obj.common.def = false;
                                    if(obj.native == undefined || obj.native != {})
                                        obj.native = {};
                                    setObject(tmpId, obj, (err) =>{
                                        if(!err){
                                            log('Created Alias-Path ' + tmpId);
                                            path();
                                        else
                                            log('Error creating alias-path','error');
                            path();
                       else
                         alias();
                    //   createAliasPath(idDst);
                  function alias(){
                      // Create alias object
                        if(!existsObject(idDst)){
                            let obj = {};
                            obj.type = 'state';
                            obj.common = getObject(idSrc).common;
                            obj.common.alias = {};
                            obj.common.alias.id = idSrc;
                            if(typeAlias !== undefined)
                                obj.common.type = typeAlias;
                            if(obj.common.read !== undefined)
                                obj.common.alias.read = read;
                            if(obj.common.write !== undefined)
                                obj.common.alias.write = write;
                            if(nameAlias !== undefined)
                                obj.common.name = nameAlias;
                            if(role !== undefined)
                                obj.common.role = role;
                            if(desc !== undefined)
                                obj.common.desc = desc;
                            if(min !== undefined)
                                obj.common.min = min;
                            if(max !== undefined)
                                obj.common.max = max;
                            if(unit !== undefined)
                                obj.common.unit = unit;
                            if(states !== undefined)
                                obj.common.states = states;
                            obj.native = {};
                            obj.common.custom = []; // Damit die Zuordnung zu iQontrol, Sql etc. nicht übernommen wird
                            log('Created Alias-State ' + idDst);
                            setObject(idDst, obj,(err) =>{
                                if(!err)
                                    startAttach();
                                else
                                    log('Error creating-alias','error');
                        else
                            startAttach();
                  // Save ID and Enum (room or function)
                  var attach = (id, enu,value) => {
                      if(id.length == 0){
                          log('ID has lenght 0, can not attach to enum','warn');
                          return;
                      if(value.length == 0){
                          log('Value has lenght 0','warn');
                          return;
                      let sEnuId = 'enum.' + enu + '.' + value;
                      if(enu.length > 0 && existsObject(sEnuId))
                          let obj = getObject(sEnuId)
                          let members = obj.common.members;
                          if(!members.includes(id)){
                              arEnum.push(sEnuId);
                              arId.push(id);
                      else
                   	      log('Can not find enum ' + sEnuId,'warn');
                 function startAttach(){
                    let bRoom = raum !== undefined && raum.length > 0;
                    let bGewerk = gewerk !== undefined && gewerk.length > 0;
                    if(bRoom)
                        attach(idDst,'rooms',raum);
                    if(bGewerk)
                        attach(idDst,'functions',gewerk);
                    if(bRoom || bGewerk){
                            if(timeoutAssignEnum){
                                clearTimeout(timeoutAssignEnum);
                                timeoutAssignEnum = null;
                            timeoutAssignEnum = setTimeout(finishScript,100);
                function finishScript(){
                	assignEnums();
                // Add the saved IDs to the rooms/functions
                function assignEnums(){
                 if(arEnum.length == 0 || arId.length == 0){
                      return;
                 if(arEnum.length != arId.length){
                      log('Arrays have different size','error');
                      return;
                 let mapEnumId = new Map();
                 for(let i=0;i < arEnum.length; i++){
                     let enu = arEnum[i];
                     let id = arId[i];
                     if(existsObject(id)){
                    	 let obj = getObject(enu)
                    	 let members;
                    	 if(!mapEnumId.has(enu)){
                    		 mapEnumId.set(enu,members);
                    	 else
                    		 members = mapEnumId.get(enu);
                    		  log("Adding " + id + " to " + enu);
                    		  members.push(id);
                     else
                         log('Can not find Alias ' + id,'error');
                  function setMembers(members,enu,map){
                      let obj = getObject(enu);
                      obj.common.members = members;
                      setObject(enu,obj);
                  mapEnumId.forEach(setMembers);
                Hier noch die Objekt-Definition: ( Ich hoffe es ist die richtige das gibt es ja zu jedem Datenpunkt eine ....
                  "type": "channel",
                  "common": {
                    "name": "alias.0.Flur.Multisensor.Aeotec_7"
                  "_id": "alias.0.Flur.Multisensor.Aeotec_7",
                  "native": {},
                  "user": "system.user.admin",
                  "ts": 1698686702683,
                  "acl": {
                    "object": 1636,
                    "owner": "system.user.admin",
                haus-automatisierungH 2 Antworten Letzte Antwort
                • F Flopsi
                  createAlias
                  				Changelog
                  Version 1.1.3
                  Version 1.1.2
                  Version 1.1.1
                  Version 1.1.0
                  Version 1.0.6
                  Version 1.0.5
                  Version 1.0.4
                  Version 1.0.3
                    - Githublink
                  Version 1.0.2
                    - improved logs
                  Version 1.0.1
                  Version 1.0
                  		Flags /
                  		Variablen
                  // role = 'switch';
                  let arEnum = [];
                  let arId = [];
                        return;
                              function path(){
                                      alias();
                                      return;
                                      let obj;
                                      else
                                          obj = {};
                                          obj.type = 'meta';
                                          obj.common = {};
                                          obj.native = {};
                                          if(!err){
                                              path();
                                          else
                              path();
                         else
                           alias();
                    function alias(){
                              let obj = {};
                              obj.type = 'state';
                              obj.native = {};
                                  if(!err)
                                      startAttach();
                                  else
                          else
                              startAttach();
                        if(id.length == 0){
                            return;
                            return;
                                arId.push(id);
                        else
                      if(bRoom)
                      if(bGewerk)
                  	assignEnums();
                        return;
                        return;
                       let id = arId[i];
                      	 let members;
                      	 else
                      		  members.push(id);
                       else
                        setObject(enu,obj);
                    "type": "channel",
                    "common": {
                    "native": {},
                    "acl": {
                      "object": 1636,
                  @flopsi sagte in Error im admin.0 [Alias subscription error]:
                  Statt
                  createAlias('zwave2.0.Node_065.Multilevel_Sensor.illuminance', 'Flur.Multisensor.Aeotec_7.Lux');
                  muss es so aussehen:
                  createAlias('Flur.Multisensor.Aeotec_7.Lux', 'zwave2.0.Node_065.Multilevel_Sensor.illuminance');
                  dein Script lese ich mir jetzt nicht komplett durch
                  Ja, und da fehlt die ID, auf welcher sich der Alias beziehen soll. Daher die Fehler.
                  • F Flopsi
                    createAlias
                    				Changelog
                    Version 1.1.3
                    Version 1.1.2
                    Version 1.1.1
                    Version 1.1.0
                    Version 1.0.6
                    Version 1.0.5
                    Version 1.0.4
                    Version 1.0.3
                      - Githublink
                    Version 1.0.2
                      - improved logs
                    Version 1.0.1
                    Version 1.0
                    		Flags /
                    		Variablen
                    // role = 'switch';
                    let arEnum = [];
                    let arId = [];
                          return;
                                function path(){
                                        alias();
                                        return;
                                        let obj;
                                        else
                                            obj = {};
                                            obj.type = 'meta';
                                            obj.common = {};
                                            obj.native = {};
                                            if(!err){
                                                path();
                                            else
                                path();
                           else
                             alias();
                      function alias(){
                                let obj = {};
                                obj.type = 'state';
                                obj.native = {};
                                    if(!err)
                                        startAttach();
                                    else
                            else
                                startAttach();
                          if(id.length == 0){
                              return;
                              return;
                                  arId.push(id);
                          else
                        if(bRoom)
                        if(bGewerk)
                    	assignEnums();
                          return;
                          return;
                         let id = arId[i];
                        	 let members;
                        	 else
                        		  members.push(id);
                         else
                          setObject(enu,obj);
                      "type": "channel",
                      "common": {
                      "native": {},
                      "acl": {
                        "object": 1636,
                    Okay, ich hab es mir nun doch angeschaut und frage mich, was der Sinn von diesem Script ist. Das kann der JavaScript-Adapter doch von Haus aus?
                    https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#createalias
                    Wenn Du eigene Funktionen definierst (und diese auch noch genauso nennst, wie Standard-Funktionen im JavaScript-Adapter), dann wäre das schon eine Info im Ausgangspost wert :)
                      Flopsi
                      ich habe das Skript einfach nur kopiert .....
                      creates Alias ......
                      die Alias erstellt und mich dann auf die Alias Datenpunkte bezogen.
                      Wie machst du das denn mit den Alias ?
                      • F Flopsi
                        @flopsi Manuell über den Geräte-Adapter erstellen
                        Aber das löst ja dein Problem nicht. Jedenfalls erstellt dein Script den Alias Datenpunkt nicht korrekt. Würde ich nicht mehr verwenden, wenn der JavsScript Adapter das direkt mitbringt.
                          Flopsi
                          schrieb am zuletzt editiert von Flopsi
                          Problem erscheint schon zwei Tage nicht mehr
                          habe folgendes geändert:
                          ich habe diesen Texteil gelöscht
                          .Aeotec_7
                          so sieht es jetzt aus:
                          createAlias('Flur.Multisensor.Lux', 'zwave2.0.Node_065.Multilevel_Sensor.illuminance');
                          jetzt kommen keine Error mehr und die fehlende ID wurde auch erstellt
