  4. Error im admin.0 [Alias subscription error]
17 Beiträge 3 Kommentatoren 1.9k Aufrufe 1 Beobachtet
  • F Flopsi
    Zu meinem eigentlichen Problem hast du keine Idee ?
    @flopsi
    Dann hätte ich dazu was geschrieben.
    • F Flopsi
      Systemdata
      Hardwaresystem: PI4
      Arbeitsspeicher: 8GB
      Festplattenart: SSD
      Betriebssystem: Linux
      Node-Version: 18.18.2
      Nodejs-Version: 18.18.2
      NPM-Version: 9.8.1
      Installationsart: -
      Image genutzt: -
      Ort/Name der Imagedatei: -
      Ich habe hin und wieder folgenden ERROR :
      admin.0
      	2023-11-01 09:44:26.972	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Binary_Sensor.motion, sourceObj={"type":"state","common":{"role":"indicator","read":true,"write":false,"name":"Sensor state (Motion)","type":"boolean"},"native":{"nodeId":65,"valueId":{"commandClass":48,"endpoint":0,"property":"Motion"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334268930,"_id":"zwave2.0.Node_065.Binary_Sensor.motion","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      admin.0
      	2023-11-01 09:44:26.973	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Multilevel_Sensor.humidity, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Humidity","type":"number","unit":"%"},"native":{"nodeId":65,"valueId":{"commandClass":49,"endpoint":0,"property":"Humidity"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334270043,"_id":"zwave2.0.Node_065.Multilevel_Sensor.humidity","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      admin.0
      	2023-11-01 09:44:26.974	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Multilevel_Sensor.illuminance, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Illuminance","type":"number","unit":"Lux"},"native":{"nodeId":65,"valueId":{"commandClass":49,"endpoint":0,"property":"Illuminance"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334269984,"_id":"zwave2.0.Node_065.Multilevel_Sensor.illuminance","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      admin.0
      	2023-11-01 09:44:26.975	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_065.Multilevel_Sensor.airTemperature, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Air temperature","type":"number","unit":"°C"},"native":{"nodeId":65,"valueId":{"commandClass":49,"endpoint":0,"property":"Air temperature"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698334269209,"_id":"zwave2.0.Node_065.Multilevel_Sensor.airTemperature","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      admin.0
      	2023-11-01 09:44:26.975	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Binary_Sensor.motion, sourceObj={"type":"state","common":{"role":"indicator","read":true,"write":false,"name":"Sensor state (Motion)","type":"boolean"},"native":{"nodeId":64,"valueId":{"commandClass":48,"endpoint":0,"property":"Motion"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1697812897069,"_id":"zwave2.0.Node_064.Binary_Sensor.motion","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      admin.0
      	2023-11-01 09:44:26.976	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Multilevel_Sensor.humidity, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Humidity","type":"number","unit":"%","custom":{"history.0":{"enabled":true,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":31536000,"customRetentionDuration":365,"maxLength":960,"enableDebugLogs":false,"debounce":1000}}},"native":{"nodeId":64,"valueId":{"commandClass":49,"endpoint":0,"property":"Humidity"}},"_id":"zwave2.0.Node_064.Multilevel_Sensor.humidity","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698827722577}
      admin.0
      	2023-11-01 09:44:26.977	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Multilevel_Sensor.illuminance, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Illuminance","type":"number","unit":"Lux","custom":{"history.0":{"enabled":true,"aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":31536000,"customRetentionDuration":365,"maxLength":960,"enableDebugLogs":false,"debounce":1000}}},"native":{"nodeId":64,"valueId":{"commandClass":49,"endpoint":0,"property":"Illuminance"}},"_id":"zwave2.0.Node_064.Multilevel_Sensor.illuminance","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1698827724985}
      admin.0
      	2023-11-01 09:44:26.977	error	Alias subscription error. Please check your alias definitions: sourceId=zwave2.0.Node_064.Multilevel_Sensor.airTemperature, sourceObj={"type":"state","common":{"role":"value","read":true,"write":false,"name":"Air temperature","type":"number","unit":"°C"},"native":{"nodeId":64,"valueId":{"commandClass":49,"endpoint":0,"property":"Air temperature"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1697812898332,"_id":"zwave2.0.Node_064.Multilevel_Sensor.airTemperature","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      Die Fehlermeldungen sind erst seitdem ich meine beiden Multi 7 Sensoren von Aeotec über Zwave 2 eingebunden habe.
      Die Sensoren funktionieren eigentlich so wie sie sollen.
      Weis wer was hier den Fehler verursacht ?
      @AlCalzone evtl. ?
      haus-automatisierungH Offline
      @flopsi Dann zeig doch mal, wie der Alias definiert ist
      📚 Meine Dokumentation
      F 1 Antwort Letzte Antwort
        Flopsi
        @haus-automatisierung
        createAlias('zwave2.0.Node_065.Multilevel_Sensor.illuminance','Flur.Multisensor.Aeotec_7.Lux');
        createAlias('zwave2.0.Node_065.Multilevel_Sensor.airTemperature','Flur.Multisensor.Aeotec_7.Temp');
        createAlias('zwave2.0.Node_065.Binary_Sensor.motion','Flur.Multisensor.Aeotec_7.Bewegung');
        createAlias('zwave2.0.Node_065.Multilevel_Sensor.humidity','Flur.Multisensor.Aeotec_7.Luftfeuchtigkeit');
        createAlias('zwave2.0.Node_064.Multilevel_Sensor.illuminance','Kueche.Multisensor.Aeotec_7.Lux');
        createAlias('zwave2.0.Node_064.Multilevel_Sensor.airTemperature','Kueche.Multisensor.Aeotec_7.Temp');
        createAlias('zwave2.0.Node_064.Binary_Sensor.motion','Kueche.Multisensor.Aeotec_7.Bewegung');
        createAlias('zwave2.0.Node_064.Multilevel_Sensor.humidity','Kueche.Multisensor.Aeotec_7.Luftfeuchtigkeit');
        • F Flopsi
          @flopsi Ich meine die Objekt-Definition vom erstellten Alias
          EDIT: Du benutzt createAlias falsch. Gerade mal in die Doku geschaut.
          • name ist die ID des Alias und
          • alias ist die ID, auf welcher sich dieser bezieht.
          Also die Parameter einmal umdrehen jeweils.
            Flopsi
            @haus-automatisierung sagte in Error im admin.0 [Alias subscription error]:
            createAlias
            Versteh nicht was ich umdrehen soll ? Kannst du mir ein Beispiel zeigen ?
            Ich erstelle all meine Alias nach dem Schema nie probleme gehabt erst seit den neuen Sensoren...
            Ich nutze das folgendes Skript für:
            Github - https://github.com/xCruziX/ioBroker-Creating-Alias/blob/master/CreateAlias.js
            				Changelog
            Version 1.1.3
              - use callbacks in alias-path
            Version 1.1.2
              - fix log message 'Created Alias-Path '
            Version 1.1.1
              - Bugfixing, clean functions
            Version 1.1.0
              - added function for cleaning enums
            Version 1.0.6
              - use callback functions for safety call
            Version 1.0.5
              - decrease timeout assing enum
            Version 1.0.4
              - Bugfixing array id lenght
            Version 1.0.3
              - Githublink
            Version 1.0.2
              - existsObject for Alias in the timeout
              - remove lowerCase enum
              - improved logs
            Version 1.0.1
              - Rooms and functions casesensitive
            Version 1.0
            		Flags /
            		Variablen
            // typeAlias = 'boolean'; // oder 'number'
            // read = "val == 'Ein' ? true : false"; // Erkennung "Aus" --> false erfolgt automatisch
            // write = "val ? 'Ein' : 'Aus'";
            // nameAlias = 'Licht Haustür';
            // role = 'switch';
            // desc = 'per Script erstellt';
            // min = 0; // nur Zahlen
            // max = 100; // nur Zahlen
            // unit = '%'; // nur für Zahlen
            // states = {0: 'Aus', 1: 'Auto', 2: 'Ein'}; // Zahlen (Multistate) oder Logikwert (z.B. Aus/Ein)
            let bCreateAliasPath = false;  // If this flag is true, each folder is created seperately so rooms and functions can be assigned.
            Requirements: bCreateAliasPath == true
            If this flag is true, existing folders in the path will be converted so rooms and functions can be assigned.
            let bConvertExistingPath = false;
            	Don't change anything from here /
            	Ab hier nichts verändern
            let arEnum = [];
            let arId = [];
            let timeoutAssignEnum;
            function createAlias(idSrc, idDst,raum, gewerk,typeAlias, read, write, nameAlias, role, desc, min, max, unit, states) {
              if(!idDst.includes('alias.0.'))
                  idDst = 'alias.0.' + idDst;
              if(!existsObject(idSrc))
                  log('Source-Id ' + idSrc +' does not exists.','warn');
                  return;
              // Create the object Path for alias id,
              // so you can assign rooms and function to the parents
              var createAliasPath = (id) => {
                   if(bCreateAliasPath){
                        let lisMergedIds = [];
                        let mergedId = 'alias.0';
                        id = id.replace(mergedId + '.', ''); // Remove prefix alias so it will not be changed
                        let split = id.split('.');
                        for(let i=0;i<split.length-1;i++){
                            mergedId += '.' + split[i];
                            lisMergedIds.push(mergedId);
                        function path(){
                            if(lisMergedIds.length == 0) {// Zu Ende erstellt
                                alias();
                                return;
                            let tmpId = lisMergedIds[0];
                            lisMergedIds.splice(0,1); // entferne element
                            if(!existsObject(tmpId) || bConvertExistingPath){ // not exists
                                let obj;
                                if(existsObject(tmpId))
                                    obj = getObject(tmpId);
                                else
                                    obj = {};
                                if(obj.type == undefined || obj.type != 'meta')
                                    obj.type = 'meta';
                                if(obj.common == undefined || obj.common != {})
                                    obj.common = {};
                                if(obj.common.type == undefined || obj.common.type != 'meta.folder')
                                    obj.common.type = 'meta.folder';
                                if(obj.common.desc == undefined || obj.common.desc != 'createAliasPath')
                                    obj.common.desc = 'createAliasPath';
                                if(obj.common.def == undefined || obj.common.def != false)
                                    obj.common.def = false;
                                if(obj.native == undefined || obj.native != {})
                                    obj.native = {};
                                setObject(tmpId, obj, (err) =>{
                                    if(!err){
                                        log('Created Alias-Path ' + tmpId);
                                        path();
                                    else
                                        log('Error creating alias-path','error');
                        path();
                   else
                     alias();
                //   createAliasPath(idDst);
              function alias(){
                  // Create alias object
                    if(!existsObject(idDst)){
                        let obj = {};
                        obj.type = 'state';
                        obj.common = getObject(idSrc).common;
                        obj.common.alias = {};
                        obj.common.alias.id = idSrc;
                        if(typeAlias !== undefined)
                            obj.common.type = typeAlias;
                        if(obj.common.read !== undefined)
                            obj.common.alias.read = read;
                        if(obj.common.write !== undefined)
                            obj.common.alias.write = write;
                        if(nameAlias !== undefined)
                            obj.common.name = nameAlias;
                        if(role !== undefined)
                            obj.common.role = role;
                        if(desc !== undefined)
                            obj.common.desc = desc;
                        if(min !== undefined)
                            obj.common.min = min;
                        if(max !== undefined)
                            obj.common.max = max;
                        if(unit !== undefined)
                            obj.common.unit = unit;
                        if(states !== undefined)
                            obj.common.states = states;
                        obj.native = {};
                        obj.common.custom = []; // Damit die Zuordnung zu iQontrol, Sql etc. nicht übernommen wird
                        log('Created Alias-State ' + idDst);
                        setObject(idDst, obj,(err) =>{
                            if(!err)
                                startAttach();
                            else
                                log('Error creating-alias','error');
                    else
                        startAttach();
              // Save ID and Enum (room or function)
              var attach = (id, enu,value) => {
                  if(id.length == 0){
                      log('ID has lenght 0, can not attach to enum','warn');
                      return;
                  if(value.length == 0){
                      log('Value has lenght 0','warn');
                      return;
                  let sEnuId = 'enum.' + enu + '.' + value;
                  if(enu.length > 0 && existsObject(sEnuId))
                      let obj = getObject(sEnuId)
                      let members = obj.common.members;
                      if(!members.includes(id)){
                          arEnum.push(sEnuId);
                          arId.push(id);
                  else
               	      log('Can not find enum ' + sEnuId,'warn');
             function startAttach(){
                let bRoom = raum !== undefined && raum.length > 0;
                let bGewerk = gewerk !== undefined && gewerk.length > 0;
                if(bRoom)
                    attach(idDst,'rooms',raum);
                if(bGewerk)
                    attach(idDst,'functions',gewerk);
                if(bRoom || bGewerk){
                        if(timeoutAssignEnum){
                            clearTimeout(timeoutAssignEnum);
                            timeoutAssignEnum = null;
                        timeoutAssignEnum = setTimeout(finishScript,100);
            function finishScript(){
            	assignEnums();
            // Add the saved IDs to the rooms/functions
            function assignEnums(){
             if(arEnum.length == 0 || arId.length == 0){
                  return;
             if(arEnum.length != arId.length){
                  log('Arrays have different size','error');
                  return;
             let mapEnumId = new Map();
             for(let i=0;i < arEnum.length; i++){
                 let enu = arEnum[i];
                 let id = arId[i];
                 if(existsObject(id)){
                	 let obj = getObject(enu)
                	 let members;
                	 if(!mapEnumId.has(enu)){
                		 mapEnumId.set(enu,members);
                	 else
                		 members = mapEnumId.get(enu);
                		  log("Adding " + id + " to " + enu);
                		  members.push(id);
                 else
                     log('Can not find Alias ' + id,'error');
              function setMembers(members,enu,map){
                  let obj = getObject(enu);
                  obj.common.members = members;
                  setObject(enu,obj);
              mapEnumId.forEach(setMembers);
            Hier noch die Objekt-Definition: ( Ich hoffe es ist die richtige das gibt es ja zu jedem Datenpunkt eine ....
              "type": "channel",
              "common": {
                "name": "alias.0.Flur.Multisensor.Aeotec_7"
              "_id": "alias.0.Flur.Multisensor.Aeotec_7",
              "native": {},
              "user": "system.user.admin",
              "ts": 1698686702683,
              "acl": {
                "object": 1636,
                "owner": "system.user.admin",
            haus-automatisierungH 2 Antworten Letzte Antwort
            • F Flopsi
              createAlias
              				Changelog
              Version 1.1.3
              Version 1.1.2
              Version 1.1.1
              Version 1.1.0
              Version 1.0.6
              Version 1.0.5
              Version 1.0.4
              Version 1.0.3
                - Githublink
              Version 1.0.2
                - improved logs
              Version 1.0.1
              Version 1.0
              		Flags /
              		Variablen
              // role = 'switch';
              let arEnum = [];
              let arId = [];
                    return;
                          function path(){
                                  alias();
                                  return;
                                  let obj;
                                  else
                                      obj = {};
                                      obj.type = 'meta';
                                      obj.common = {};
                                      obj.native = {};
                                      if(!err){
                                          path();
                                      else
                          path();
                     else
                       alias();
                function alias(){
                          let obj = {};
                          obj.type = 'state';
                          obj.native = {};
                              if(!err)
                                  startAttach();
                              else
                      else
                          startAttach();
                    if(id.length == 0){
                        return;
                        return;
                            arId.push(id);
                    else
                  if(bRoom)
                  if(bGewerk)
              	assignEnums();
                    return;
                    return;
                   let id = arId[i];
                  	 let members;
                  	 else
                  		  members.push(id);
                   else
                    setObject(enu,obj);
                "type": "channel",
                "common": {
                "native": {},
                "acl": {
                  "object": 1636,
              @flopsi sagte in Error im admin.0 [Alias subscription error]:
              Statt
              createAlias('zwave2.0.Node_065.Multilevel_Sensor.illuminance', 'Flur.Multisensor.Aeotec_7.Lux');
              muss es so aussehen:
              createAlias('Flur.Multisensor.Aeotec_7.Lux', 'zwave2.0.Node_065.Multilevel_Sensor.illuminance');
              dein Script lese ich mir jetzt nicht komplett durch
              Ja, und da fehlt die ID, auf welcher sich der Alias beziehen soll. Daher die Fehler.
              • F Flopsi
                createAlias
                				Changelog
                Version 1.1.3
                Version 1.1.2
                Version 1.1.1
                Version 1.1.0
                Version 1.0.6
                Version 1.0.5
                Version 1.0.4
                Version 1.0.3
                  - Githublink
                Version 1.0.2
                  - improved logs
                Version 1.0.1
                Version 1.0
                		Flags /
                		Variablen
                // role = 'switch';
                let arEnum = [];
                let arId = [];
                      return;
                            function path(){
                                    alias();
                                    return;
                                    let obj;
                                    else
                                        obj = {};
                                        obj.type = 'meta';
                                        obj.common = {};
                                        obj.native = {};
                                        if(!err){
                                            path();
                                        else
                            path();
                       else
                         alias();
                  function alias(){
                            let obj = {};
                            obj.type = 'state';
                            obj.native = {};
                                if(!err)
                                    startAttach();
                                else
                        else
                            startAttach();
                      if(id.length == 0){
                          return;
                          return;
                              arId.push(id);
                      else
                    if(bRoom)
                    if(bGewerk)
                	assignEnums();
                      return;
                      return;
                     let id = arId[i];
                    	 let members;
                    	 else
                    		  members.push(id);
                     else
                      setObject(enu,obj);
                  "type": "channel",
                  "common": {
                  "native": {},
                  "acl": {
                    "object": 1636,
                Okay, ich hab es mir nun doch angeschaut und frage mich, was der Sinn von diesem Script ist. Das kann der JavaScript-Adapter doch von Haus aus?
                https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#createalias
                Wenn Du eigene Funktionen definierst (und diese auch noch genauso nennst, wie Standard-Funktionen im JavaScript-Adapter), dann wäre das schon eine Info im Ausgangspost wert :)
                  Flopsi
                  ich habe das Skript einfach nur kopiert .....
                  creates Alias ......
                  die Alias erstellt und mich dann auf die Alias Datenpunkte bezogen.
                  Wie machst du das denn mit den Alias ?
                  • F Flopsi
                    @flopsi Manuell über den Geräte-Adapter erstellen
                    Aber das löst ja dein Problem nicht. Jedenfalls erstellt dein Script den Alias Datenpunkt nicht korrekt. Würde ich nicht mehr verwenden, wenn der JavsScript Adapter das direkt mitbringt.
                      Flopsi
                      schrieb am zuletzt editiert von Flopsi
                      Problem erscheint schon zwei Tage nicht mehr
                      habe folgendes geändert:
                      ich habe diesen Texteil gelöscht
                      .Aeotec_7
                      so sieht es jetzt aus:
                      createAlias('Flur.Multisensor.Lux', 'zwave2.0.Node_065.Multilevel_Sensor.illuminance');
                      jetzt kommen keine Error mehr und die fehlende ID wurde auch erstellt
