  4. iob stürzt ab und startet dann neu
absturzerror
87 Beiträge 6 Kommentatoren 5.5k Aufrufe 7 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    ist mir jetzt schon öfters aufgefallen, dass iob abstürzt und dann neu startet.
    Gefühlt so 1 x täglich.
    Heute Nacht um ca. 00:17 wieder, log hab ich mal dazu gelegt.
    (log gekürzt, weil länger als 10.000 Zeichen)
    2023-10-23 00:17:08.837  - info: web.0 (1427) <== Disconnect system.user.admin from ::ffff:192.168.243.102 vis.0
    2023-10-23 00:17:09.046  - info: admin.0 (564) <== Disconnect system.user.admin from ::ffff:192.168.243.100 admin
    2023-10-23 00:17:09.056  - info: mqtt.2 (886) Client [Wemos_Sauna_Klima] reconnected. Old secret 1698012110123_9718. New secret 1698013028211_1856
    2023-10-23 00:17:09.189  - info: mqtt.2 (886) Client [Wemos_Kueche_Klima] reconnected. Old secret 1698012110123_7633. New secret 1698013028540_3060
    2023-10-23 00:17:09.189  - info: mqtt.2 (886) Client [Wemos_Wohnzimmer_Klima] reconnected. Old secret 1698012111414_7033. New secret 1698013028540_8286
    2023-10-23 00:17:09.191  - info: mqtt.2 (886) Client [Wemos_Wohnzimmer_Klima] connection closed: closed
    2023-10-23 00:17:09.191  - info: mqtt.2 (886) Client [Wemos_Kueche_Klima] connection closed: closed
    2023-10-23 00:17:09.191  - info: mqtt.2 (886) Client [Wemos_Sauna_Klima] connection closed: closed
    2023-10-23 00:17:50.526  - info: admin.0 (564) <== Disconnect system.user.admin from ::ffff:192.168.243.102 admin
    2023-10-23 00:17:09.120  - info: web.0 (1427) <== Disconnect system.user.admin from ::ffff:192.168.243.109 vis.0
    2023-10-23 00:17:09.121  - info: web.0 (1427) <== Disconnect system.user.admin from ::ffff:192.168.243.100 vis.0
    2023-10-23 00:17:09.121  - info: web.0 (1427) <== Disconnect system.user.admin from ::ffff:192.168.243.122 vis.0
    2023-10-23 00:41:19.302  - error: influxdb.0 (718) States database error: read ECONNRESET
    2023-10-23 00:41:19.580  - warn: javascript.0 (602) script.js.Scripte.Geraete.Huawei: Error received reading address 37700 from id: 1 with error: undefined
    2023-10-23 00:41:19.943  - error: sql.0 (613) States database error: read ECONNRESET
    2023-10-23 00:41:20.051  - error: contact.0 (1107) States database error: write ECONNRESET
    2023-10-23 00:41:19.317  - error: imap.0 (1575) States database error: read ECONNRESET
    2023-10-23 00:41:20.876  - error: musiccast.0 (1207) States database error: write ECONNRESET
    2023-10-23 00:41:21.546  - error: web.0 (1427) States database error: write ECONNRESET
    2023-10-23 00:41:21.595  - error: admin.0 (564) States database error: write EPIPE
    2023-10-23 00:41:21.922  - error: wled.0 (50353) States database error: write ECONNRESET
    2023-10-23 00:41:21.921  - error: mihome-vacuum.0 (833) States database error: write ECONNRESET
    2023-10-23 00:41:22.018  - error: zigbee.0 (977) Objects database error: write ECONNRESET
    2023-10-23 00:41:22.557  - error: zigbee.0 (977) States database error: write EPIPE
    2023-10-23 00:41:22.730  - error: octoprint.0 (1260) States database error: write EPIPE
    2023-10-23 00:41:20.397  - error: telegram.1 (647) States database error: read ECONNRESET
    2023-10-23 00:41:21.074  - error: vis-inventwo.0 (1397) States database error: write ECONNRESET
    2023-10-23 00:41:22.834  - error: octoprint.0 (1260) Objects database error: read ECONNRESET
    2023-10-23 00:41:20.671  - error: asterisk.0 (1019) States database error: write ECONNRESET
    2023-10-23 00:41:20.296  - error: telegram.0 (632) States database error: read ECONNRESET
    2023-10-23 00:41:21.458  - error: proxmox.0 (1600) States database error: write EPIPE
    2023-10-23 00:41:20.827  - error: simple-api.0 (1334) States database error: read ECONNRESET
    2023-10-23 00:41:21.778  - error: rssfeed.0 (1457) States database error: write ECONNRESET
    2023-10-23 00:41:21.895  - error: tankerkoenig.0 (1351) States database error: write ECONNRESET
    2023-10-23 00:41:20.999  - error: openligadb.0 (1281) States database error: write ECONNRESET
    2023-10-23 00:41:23.404  - error: fritzbox.0 (736) States database error: write ECONNRESET
    2023-10-23 00:41:23.804  - error: sourceanalytix.0 (1474) States database error: write ECONNRESET
    2023-10-23 00:41:23.944  - info: sourceanalytix.0 (1474) SourceAnalytix stopped, now you have to calculate by yourself :'( ...
    2023-10-23 00:41:23.952  - error: tuya.0 (50983) States database error: write EPIPE
    2023-10-23 00:41:23.496  - error: bmw.0 (1046) States database error: write ECONNRESET
    2023-10-23 00:41:24.168  - error: hm-rega.0 (751) States database error: write ECONNRESET
    2023-10-23 00:41:24.205  - error: hm-rega.0 (751) Objects database error: read ECONNRESET
    2023-10-23 00:41:23.283  - error: parser.0 (1299) States database error: write ECONNRESET
    2023-10-23 00:41:24.021  - error: ws.0 (1442) States database error: write ECONNRESET
    2023-10-23 00:41:23.856  - error: sql.1 (681) States database error: write ECONNRESET
    2023-10-23 00:41:23.726  - error: logparser.0 (1179) States database error: write ECONNRESET
    2023-10-23 00:41:23.695  - error: mqtt.0 (871) States database error: write ECONNRESET
    2023-10-23 00:41:24.487  - info: mqtt.0 (871) Client [ROBONECT081603] connection closed: timeout
    2023-10-23 00:41:23.804  - error: libre.0 (1166) States database error: write ECONNRESET
    2023-10-23 00:41:24.620  - error: modbus.0 (856) Objects database error: write ECONNRESET
    2023-10-23 00:41:24.173  - error: bosch-ebike.0 (1073) States database error: write ECONNRESET
    2023-10-23 00:41:24.078  - error: email.0 (571) States database error: write ECONNRESET
    2023-10-23 00:41:24.379  - error: ping.0 (901) States database error: write ECONNRESET
    2023-10-23 00:41:24.913  - error: mqtt.2 (886) Objects database error: write EPIPE
    2023-10-23 00:41:24.215  - error: hm-rpc.2 (796) States database error: write ECONNRESET
    2023-10-23 00:41:24.635  - warn: modbus.0 (856) Poll error count: 1 code: "App Timeout"
    2023-10-23 00:41:24.939  - error: modbus.0 (856) States database error: write ECONNRESET
    2023-10-23 00:41:24.944  - error: modbus.0 (856) Socket Error
    2023-10-23 00:41:24.945  - error: modbus.0 (856) Client in error state.
    2023-10-23 00:41:24.945  - warn: modbus.0 (856) On error: {"errno":-104,"code":"ECONNRESET","syscall":"read"}
    2023-10-23 00:41:23.781  - error: fritzdect.0 (1160) States database error: write ECONNRESET
    2023-10-23 00:41:24.745  - error: javascript.1 (666) States database error: write ECONNRESET
    2023-10-23 00:41:25.097  - error: mqtt.2 (886) States database error: write ECONNRESET
    2023-10-23 00:41:24.443  - error: tr-064.0 (923) States database error: write ECONNRESET
    2023-10-23 00:41:25.060  - error: hm-rpc.0 (766) Objects database error: write ECONNRESET
    2023-10-23 00:41:25.428  - error: hm-rpc.0 (766) States database error: write ECONNRESET
    2023-10-23 00:41:25.193  - error: backitup.0 (990) States database error: write ECONNRESET
    2023-10-23 00:41:25.720  - error: pollenflug.0 (1316) States database error: write ECONNRESET
    2023-10-23 00:41:25.746  - error: sayit.4 (1557) States database error: write ECONNRESET
    2023-10-23 00:41:24.326  - error: yamaha.0 (959) Objects database error: write EPIPE
    2023-10-23 00:41:25.808  - error: yamaha.0 (959) States database error: write ECONNRESET
    2023-10-23 00:41:20.872  - error: viessmann.0 (1366) Timeout connection error!
    2023-10-23 00:41:25.286  - warn: viessmann.0 (1366) Reconnect time is wrong
    2023-10-23 00:41:25.824  - error: viessmann.0 (1366) States database error: write ECONNRESET
    2023-10-23 00:41:25.834  - error: sayit.3 (1535) States database error: write ECONNRESET
    2023-10-23 00:41:21.917  - info: cloud.0 (1092) Connection changed: disconnect
    2023-10-23 00:41:26.527  - error: cloud.0 (1092) States database error: write ECONNRESET
    2023-10-23 00:41:27.752  - error: sayit.2 (1492) States database error: write ECONNRESET
    2023-10-23 00:41:38.401  - info: host.iobroker iobroker.js-controller version 5.0.12 js-controller starting
    2023-10-23 00:41:38.403  - info: host.iobroker Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2023-10-23 00:41:38.403  - info: host.iobroker hostname: iobroker, node: v18.18.2
    2023-10-23 00:41:38.404  - info: host.iobroker ip addresses: 192.168.243.15 2a03:93e0:200:b70:8891:b1ff:fea3:66d8 fe80::8891:b1ff:fea3:66d8
    2023-10-23 00:41:46.928  - info: host.iobroker connected to Objects and States
    2023-10-23 00:41:46.985  - info: host.iobroker added notifications configuration of host
    2023-10-23 00:41:48.061  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
    2023-10-23 00:41:48.062  - info: host.iobroker 88 instances found
    2023-10-23 00:41:48.208  - info: host.iobroker starting 72 instances
    2023-10-23 00:41:48.370  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
    2023-10-23 00:41:48.378  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
    2023-10-23 00:41:48.437  - info: host.iobroker instance system.adapter.admin.0 started with pid 143921
    2023-10-23 00:41:48.441  - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
    2023-10-23 00:41:48.487  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
    2023-10-23 00:41:48.531  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
    2023-10-23 00:41:48.575  - info: host.iobroker Some obsolete host states deleted.
    2023-10-23 00:41:52.274  - error: admin.0 (143921) admin.0 already running
    2023-10-23 00:41:52.276  - warn: admin.0 (143921) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-10-23 00:41:52.294  - info: host.iobroker instance system.adapter.email.0 started with pid 143932
    2023-10-23 00:41:52.955  - error: host.iobroker instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-10-23 00:41:52.955  - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
    2023-10-23 00:41:53.097  - error: email.0 (143932) email.0 already running
    2023-10-23 00:41:53.098  - warn: email.0 (143932) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-10-23 00:41:53.663  - error: host.iobroker instance system.adapter.email.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-10-23 00:41:53.663  - info: host.iobroker Restart adapter system.adapter.email.0 because enabled
    2023-10-23 00:41:56.427  - info: host.iobroker instance system.adapter.javascript.0 started with pid 143943
    2023-10-23 00:42:00.355  - info: host.iobroker instance system.adapter.sql.0 started with pid 143950
    2023-10-23 00:42:02.610  - error: javascript.0 (143943) javascript.0 already running
    2023-10-23 00:42:02.611  - warn: javascript.0 (143943) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-10-23 00:42:03.105  - error: sql.0 (143950) sql.0 already running
    2023-10-23 00:42:03.106  - warn: sql.0 (143950) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-10-23 00:42:03.181  - error: host.iobroker instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-10-23 00:42:03.181  - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
    2023-10-23 00:42:03.674  - error: host.iobroker instance system.adapter.sql.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-10-23 00:42:03.674  - info: host.iobroker Restart adapter system.adapter.sql.0 because enabled
    2023-10-23 00:42:04.286  - info: host.iobroker instance system.adapter.telegram.0 started with pid 143965
    2023-10-23 00:42:08.303  - info: host.iobroker instance system.adapter.telegram.1 started with pid 143972
    2023-10-23 00:42:09.140  - error: telegram.0 (143965) telegram.0 already running
    2023-10-23 00:42:09.142  - warn: telegram.0 (143965) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-10-23 00:42:09.277  - error: telegram.1 (143972) telegram.1 already running
    2023-10-23 00:42:09.279  - warn: telegram.1 (143972) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-10-23 00:42:09.711  - error: host.iobroker instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-10-23 00:42:09.711  - info: host.iobroker Restart adapter system.adapter.telegram.0 because enabled
    2023-10-23 00:42:09.847  - error: host.iobroker instance system.adapter.telegram.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-10-23 00:42:09.848  - info: host.iobroker Restart adapter system.adapter.telegram.1 because enabled
    2023-10-23 00:42:12.279  - info: host.iobroker instance system.adapter.javascript.1 started with pid 143987
    2023-10-23 00:42:13.378  - error: javascript.1 (143987) javascript.1 already running
    2023-10-23 00:42:13.379  - warn: javascript.1 (143987) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-10-23 00:42:13.951  - error: host.iobroker instance system.adapter.javascript.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-10-23 00:42:13.951  - info: host.iobroker Restart adapter system.adapter.javascript.1 because enabled
    2023-10-23 00:42:16.281  - info: host.iobroker instance system.adapter.sql.1 started with pid 143998
    2023-10-23 00:42:17.045  - error: sql.1 (143998) sql.1 already running
    2023-10-23 00:42:17.046  - warn: sql.1 (143998) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-10-23 00:42:17.620  - error: host.iobroker instance system.adapter.sql.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-10-23 00:42:17.620  - info: host.iobroker Restart adapter system.adapter.sql.1 because enabled
    2023-10-23 00:42:20.285  - info: host.iobroker instance system.adapter.influxdb.0 started with pid 144009
    2023-10-23 00:42:21.854  - error: influxdb.0 (144009) influxdb.0 already running
    2023-10-23 00:42:21.856  - warn: influxdb.0 (144009) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-10-23 00:42:22.430  - error: host.iobroker instance system.adapter.influxdb.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-10-23 00:42:22.431  - info: host.iobroker Restart adapter system.adapter.influxdb.0 because enabled
    2023-10-23 00:42:23.026  - info: host.iobroker instance system.adapter.admin.0 started with pid 144020
    2023-10-23 00:42:23.773  - info: host.iobroker instance system.adapter.email.0 started with pid 144031
    2023-10-23 00:42:24.382  - info: host.iobroker instance system.adapter.fritzbox.0 started with pid 144042
    2023-10-23 00:42:24.603  - info: admin.0 (144020) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.12
    2023-10-23 00:42:24.625  - info: admin.0 (144020) requesting all objects
    2023-10-23 00:42:24.789  - info: email.0 (144031) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.email, node: v18.18.2, js-controller: 5.0.12
    2023-10-23 00:42:25.823  - info: admin.0 (144020) received all objects
    2023-10-23 00:42:26.778  - error: fritzbox.0 (144042) fritzbox.0 already running
    2023-10-23 00:42:26.779  - warn: fritzbox.0 (144042) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-10-23 00:42:26.903  - info: admin.0 (144020) Request actual repository...
    2023-10-23 00:42:26.912  - info: admin.0 (144020) socket.io server listening on port 8081
    2023-10-23 00:42:26.913  - info: admin.0 (144020) http server listening on port 8081
    2023-10-23 00:42:26.914  - info: admin.0 (144020) Use link "http://127.0.0.1:8081" to configure.
    2023-10-23 00:42:27.169  - error: admin.0 (144020) Cannot update news: TypeError: newNews.forEach is not a function
    2023-10-23 00:42:27.218  - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.102
    2023-10-23 00:42:29.462  - error: host.iobroker instance system.adapter.fritzbox.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-10-23 00:42:29.463  - info: host.iobroker Restart adapter system.adapter.fritzbox.0 because enabled
    2023-10-23 00:42:29.486  - info: host.iobroker instance system.adapter.hm-rega.0 started with pid 144069
    2023-10-23 00:42:29.995  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-10-23 00:42:30.835  - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.100
    2023-10-23 00:42:31.603  - error: hm-rega.0 (144069) hm-rega.0 already running
    2023-10-23 00:42:31.605  - warn: hm-rega.0 (144069) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-10-23 00:42:31.860  - info: admin.0 (144020) Repository received successfully.
    2023-10-23 00:42:32.179  - error: host.iobroker instance system.adapter.hm-rega.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-10-23 00:42:32.179  - info: host.iobroker Restart adapter system.adapter.hm-rega.0 because enabled
    2023-10-23 00:42:32.300  - info: host.iobroker instance system.adapter.hm-rpc.0 started with pid 144084
    2023-10-23 00:42:33.298  - info: host.iobroker instance system.adapter.javascript.0 started with pid 144096
    2023-10-23 00:42:33.541  - error: hm-rpc.0 (144084) hm-rpc.0 already running
    2023-10-23 00:42:33.542  - warn: hm-rpc.0 (144084) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-10-23 00:42:33.761  - info: host.iobroker instance system.adapter.sql.0 started with pid 144103
    2023-10-23 00:42:34.153  - error: host.iobroker instance system.adapter.hm-rpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-10-23 00:42:34.153  - info: host.iobroker Restart adapter system.adapter.hm-rpc.0 because enabled
    2023-10-23 00:42:35.024  - info: javascript.0 (144096) starting. Version 7.1.4 (non-npm: ioBroker/ioBroker.javascript) in /opt/iobroker/node_modules/iobroker.javascript, node: v18.18.2, js-controller: 5.0.12
    2023-10-23 00:42:35.086  - info: sql.0 (144103) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.sql, node: v18.18.2, js-controller: 5.0.12
    2023-10-23 00:42:36.289  - info: host.iobroker instance system.adapter.hm-rpc.1 started with pid 144126
    2023-10-23 00:42:37.002  - error: hm-rpc.1 (144126) hm-rpc.1 already running
    2023-10-23 00:42:37.003  - warn: hm-rpc.1 (144126) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-10-23 00:42:37.584  - error: host.iobroker instance system.adapter.hm-rpc.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-10-23 00:42:37.585  - info: host.iobroker Restart adapter system.adapter.hm-rpc.1 because enabled
    ... hier zahlreiche sql Einträge ...
    2023-10-23 00:42:38.329  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.Meter_eingespeist, Alias=false, 354 points now activated
    2023-10-23 00:42:38.329  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.Haus_Verbrauch, Alias=false, 355 points now activated
    2023-10-23 00:42:38.329  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.seit_Anfang.Leistung_alt, Alias=false, 356 points now activated
    2023-10-23 00:42:38.329  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.seit_Anfang.Leistung_neu, Alias=false, 357 points now activated
    2023-10-23 00:42:38.329  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.seit_Anfang.Leistung_alt_neu, Alias=false, 358 points now activated
    2023-10-23 00:42:38.329  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.seit_Anfang.Meter_bezogen, Alias=false, 359 points now activated
    2023-10-23 00:42:38.330  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.seit_Anfang.Meter_eingespeist, Alias=false, 360 points now activated
    2023-10-23 00:42:38.330  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.seit_Anfang.Haus_Verbrauch, Alias=false, 361 points now activated
    2023-10-23 00:42:38.855  - info: javascript.0 (144096) requesting all states
    2023-10-23 00:42:38.856  - info: javascript.0 (144096) requesting all objects
    2023-10-23 00:42:39.791  - info: host.iobroker instance system.adapter.telegram.0 started with pid 144137
    2023-10-23 00:42:40.063  - info: javascript.0 (144096) received all objects
    2023-10-23 00:42:40.079  - info: host.iobroker instance system.adapter.telegram.1 started with pid 144144
    2023-10-23 00:42:40.608  - info: javascript.0 (144096) received all states
    2023-10-23 00:42:40.649  - info: host.iobroker instance system.adapter.hm-rpc.2 started with pid 144155
    2023-10-23 00:42:41.765  - error: hm-rpc.2 (144155) hm-rpc.2 already running
    2023-10-23 00:42:41.767  - warn: hm-rpc.2 (144155) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-10-23 00:42:41.850  - info: telegram.0 (144137) starting. Version 1.16.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.18.2, js-controller: 5.0.12
    2023-10-23 00:42:42.739  - error: host.iobroker instance system.adapter.hm-rpc.2 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-10-23 00:42:42.739  - info: host.iobroker Restart adapter system.adapter.hm-rpc.2 because enabled
    2023-10-23 00:42:42.903  - info: telegram.1 (144144) starting. Version 1.16.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.18.2, js-controller: 5.0.12
    2023-10-23 00:42:44.026  - info: host.iobroker instance system.adapter.javascript.1 started with pid 144178
    2023-10-23 00:42:44.328  - info: host.iobroker instance scheduled system.adapter.ical.0 0,15,30,45 * * * *
    2023-10-23 00:42:44.358  - info: host.iobroker instance system.adapter.ical.0 started with pid 144185
    2023-10-23 00:42:45.762  - info: javascript.1 (144178) starting. Version 7.1.4 (non-npm: ioBroker/ioBroker.javascript) in /opt/iobroker/node_modules/iobroker.javascript, node: v18.18.2, js-controller: 5.0.12
    2023-10-23 00:42:46.177  - info: ical.0 (144185) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.12
    2023-10-23 00:42:46.424  - info: javascript.1 (144178) requesting all states
    2023-10-23 00:42:46.425  - info: javascript.1 (144178) requesting all objects
    2023-10-23 00:42:46.938  - info: ical.0 (144185) processing URL: Märkte https://calendar.google.com/calendar/ical/mn7fmslmdftdee289a43jfk2p4%40group.calendar.google.com/private-a1b9d16955e1b026c97c9163f08d34a9/basic.ics
    2023-10-23 00:42:47.310  - info: javascript.0 (144096) Start javascript script.js.Scripte.Countdown.Countdown_-_Boost-Arbeitszimmer
    2023-10-23 00:42:47.524  - info: ical.0 (144185) processing URL: Müll https://calendar.google.com/calendar/ical/4v99ckgc7cn8ds7lifi58gq97o%40group.calendar.google.com/private-3fcd3288d403e0dd210afc8b4eec7699/basic.ics
    2023-10-23 00:42:47.641  - info: javascript.1 (144178) received all objects
    2023-10-23 00:42:47.940  - info: host.iobroker instance system.adapter.sql.1 started with pid 144208
    2023-10-23 00:42:48.031  - info: javascript.1 (144178) received all states
    2023-10-23 00:42:48.074  - info: ical.0 (144185) processing URL: Google https://calendar.google.com/calendar/ical/d.mueller3005%40googlemail.com/private-068d61660f2427d2f71024c407325b7c/basic.ics
    2023-10-23 00:42:48.306  - info: host.iobroker instance system.adapter.komoot.0 started with pid 144215
    2023-10-23 00:42:49.421  - info: sql.1 (144208) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.sql, node: v18.18.2, js-controller: 5.0.12
    2023-10-23 00:42:49.669  - info: sql.1 (144208) Connected to sqlite
    2023-10-23 00:42:52.298  - info: host.iobroker instance system.adapter.mihome-vacuum.0 started with pid 144230
    2023-10-23 00:42:52.565  - info: host.iobroker instance system.adapter.influxdb.0 started with pid 144244
    ca. 00:17, es kommt dann "disconnect system.user.admin"
    von 00:17 bis 00:41 keine Einträge im log
    ab 00:41; jede Menge error von den versch. Adaptern
    dann werden die Instanzen neu gestartet (wo aber immer steht: already running)
    ab 00:42 die ganzen sql Einträge, zigbee, etc.
    dann läuft es wieder.
    Anbei auch mal ein iob diag
    Skript v.2023-10-10
    *** BASE SYSTEM ***
    Static hostname: iobroker
    Icon name: computer-vm
    Chassis: vm
    Virtualization: kvm
    Operating System: Debian GNU/Linux 11 (bullseye)
    Kernel: Linux 5.10.0-25-amd64
    Architecture: x86-64
    model name : Common KVM processor
    Docker : false
    Virtualization : kvm
    Kernel : x86_64
    Userland : amd64
    Systemuptime and Load:
    08:18:12 up 2 days, 5:07, 1 user, load average: 2.33, 2.25, 2.17
    CPU threads: 8
    *** Time and Time Zones ***
    Local time: Mon 2023-10-23 08:18:12 CEST
    Universal time: Mon 2023-10-23 06:18:12 UTC
    RTC time: Mon 2023-10-23 06:18:13
    NTP service: active
    RTC in local TZ: no
    *** User and Groups ***
    dieter
    /home/dieter
    dieter cdrom floppy sudo audio dip video plugdev netdev iobroker
    *** X-Server-Setup ***
    X-Server: false
    Desktop:
    Terminal: tty
    Boot Target: graphical.target
    *** MEMORY ***
    total used free shared buff/cache available
    Mem: 5.9G 4.7G 556M 0.0K 632M 956M
    Swap: 974M 36M 938M
    Total: 6.9G 4.8G 1.5G
         5928 M total memory
         4740 M used memory
          262 M active memory
         4805 M inactive memory
          556 M free memory
           89 M buffer memory
          542 M swap cache
          974 M total swap
           36 M used swap
          938 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    Filesystem Type Size Used Avail Use% Mounted on
    udev devtmpfs 2.9G 0 2.9G 0% /dev
    tmpfs tmpfs 593M 524K 593M 1% /run
    /dev/sda1 ext4 31G 14G 16G 46% /
    tmpfs tmpfs 2.9G 0 2.9G 0% /dev/shm
    tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock
    //192.168.243.100/1_Sound cifs 238G 124G 115G 52% /mnt
    tmpfs tmpfs 593M 0 593M 0% /run/user/1000
    [Sat Oct 21 03:10:38 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Oct 21 03:10:45 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    [Mon Oct 23 00:41:14 2023] ext4_filemap_fault+0x2d/0x50 [ext4]
    Show mounted filesystems (real ones only):
    TARGET SOURCE FSTYPE OPTIONS
    / /dev/sda1 ext4 rw,relatime,errors=remount-ro
    `-/mnt //192.168.243.100/1_Sound cifs rw,relatime,vers=3.1.1,cache=strict,username=dieter,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.243.100,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
    /var:
    1.5G /var/
    874M /var/log
    857M /var/log/journal/dd59139b4ae040898d227e04f86103f0
    443M /var/cache
    Archived and active journals take up 152.0M in the file system.
    /opt/iobroker/backups:
    2.9G /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    3.3G /opt/iobroker/iobroker-data/
    2.5G /opt/iobroker/iobroker-data/sqlite
    624M /opt/iobroker/iobroker-data/files
    303M /opt/iobroker/iobroker-data/files/vis.0
    248M /opt/iobroker/iobroker-data/files/vis.0/wav
    1.1G /opt/iobroker/iobroker-data/sqlite/sqlite202301.db
    948M /opt/iobroker/iobroker-data/sqlite/sqlitealt202207.db
    235M /opt/iobroker/iobroker-data/sqlite/sqlite.db
    201M /opt/iobroker/iobroker-data/sqlite/sqlite202303.db
    154M /opt/iobroker/iobroker-data/files/vis.0/wav/starker-regen-mit-gewitter-im.wav
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs v18.18.2
    /usr/bin/node v18.18.2
    /usr/bin/npm 9.8.1
    /usr/bin/npx 9.8.1
    /usr/bin/corepack 0.19.0
    nodejs:
    Installed: 18.18.2-1nodesource1
    Candidate: 18.18.2-1nodesource1
    Version table:
    *** 18.18.2-1nodesource1 1001
    500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
    100 /var/lib/dpkg/status
    18.18.1-1nodesource1 1001
    18.18.0-1nodesource1 1001
    18.17.1-1nodesource1 1001
    18.17.0-1nodesource1 1001
    18.16.1-1nodesource1 1001
    18.16.0-1nodesource1 1001
    18.15.0-1nodesource1 1001
    18.14.2-1nodesource1 1001
    18.14.1-1nodesource1 1001
    18.14.0-1nodesource1 1001
    18.13.0-1nodesource1 1001
    18.12.0-1nodesource1 1001
    18.11.0-1nodesource1 1001
    18.10.0-1nodesource1 1001
    18.9.1-1nodesource1 1001
    18.9.0-1nodesource1 1001
    18.8.0-1nodesource1 1001
    18.7.0-1nodesource1 1001
    18.6.0-1nodesource1 1001
    18.5.0-1nodesource1 1001
    18.4.0-1nodesource1 1001
    18.3.0-1nodesource1 1001
    18.2.0-1nodesource1 1001
    18.1.0-1nodesource1 1001
    18.0.0-1nodesource1 1001
    12.22.12~dfsg-1~deb11u4 500
    500 http://deb.debian.org/debian bullseye/main amd64 Packages
    500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States type: jsonl
    Core adapters versions
    admin: 6.10.1
    javascript: 7.1.4
    Adapters from github: 13
    Adapter State
    • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0 : alias-manager : iobroker - disabled
    • system.adapter.asterisk.0 : asterisk : iobroker - enabled, port: 5038
    • system.adapter.backitup.0 : backitup : iobroker - enabled
    • system.adapter.bmw.0 : bmw : iobroker - enabled
    • system.adapter.bosch-ebike.0 : bosch-ebike : iobroker - enabled
    • system.adapter.cloud.0 : cloud : iobroker - enabled
    • system.adapter.contact.0 : contact : iobroker - enabled, port: 8096
      system.adapter.daswetter.0 : daswetter : iobroker - enabled
      system.adapter.doorio.0 : doorio : iobroker - disabled, port: 4444
      system.adapter.dwd.0 : dwd : iobroker - enabled
    • system.adapter.email.0 : email : iobroker - enabled
      system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker - disabled
      system.adapter.feiertage.0 : feiertage : iobroker - enabled
      system.adapter.flot.0 : flot : iobroker - disabled
    • system.adapter.fritzbox.0 : fritzbox : iobroker - enabled
    • system.adapter.fritzdect.0 : fritzdect : iobroker - enabled
    • system.adapter.hm-rega.0 : hm-rega : iobroker - enabled
    • system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 0
    • system.adapter.hm-rpc.1 : hm-rpc : iobroker - enabled, port: 0
    • system.adapter.hm-rpc.2 : hm-rpc : iobroker - enabled, port: 0
      system.adapter.ical.0 : ical : iobroker - enabled
      system.adapter.icons-material-png.0 : icons-material-png : iobroker - disabled
      system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker - disabled
    • system.adapter.imap.0 : imap : iobroker - enabled
    • system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086
    • system.adapter.javascript.0 : javascript : iobroker - enabled
    • system.adapter.javascript.1 : javascript : iobroker - enabled
    • system.adapter.komoot.0 : komoot : iobroker - enabled
    • system.adapter.libre.0 : libre : iobroker - enabled
      system.adapter.linux-control.0 : linux-control : iobroker - disabled
    • system.adapter.logparser.0 : logparser : iobroker - enabled
    • system.adapter.mbus.0 : mbus : Pi-Strom-Wasser - enabled, port: 3493
    • system.adapter.mihome-vacuum.0 : mihome-vacuum : iobroker - enabled, port: 54321
      system.adapter.mihome.0 : mihome : iobroker - disabled, port: 9898, bind: 192.168.243.12
    • system.adapter.modbus.0 : modbus : iobroker - enabled
      system.adapter.modbus.1 : modbus : iobroker - disabled
    • system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 0.0.0.0
    • system.adapter.mqtt.2 : mqtt : iobroker - enabled, port: 1885, bind: 0.0.0.0
    • system.adapter.musiccast.0 : musiccast : iobroker - enabled
    • system.adapter.octoprint.0 : octoprint : iobroker - enabled
    • system.adapter.openligadb.0 : openligadb : iobroker - enabled
    • system.adapter.parser.0 : parser : iobroker - enabled
    • system.adapter.ping.0 : ping : iobroker - enabled
    • system.adapter.pollenflug.0 : pollenflug : iobroker - enabled
    • system.adapter.proxmox.0 : proxmox : iobroker - enabled, port: 8006
      system.adapter.rest-api.0 : rest-api : iobroker - disabled, port: 8093, bind: 0.0.0.0, run as: admin
    • system.adapter.rssfeed.0 : rssfeed : iobroker - enabled
    • system.adapter.sayit.2 : sayit : iobroker - enabled
    • system.adapter.sayit.3 : sayit : iobroker - enabled
    • system.adapter.sayit.4 : sayit : iobroker - enabled
      system.adapter.shelly.0 : shelly : iobroker - disabled, port: 1882, bind: 0.0.0.0
    • system.adapter.simple-api.0 : simple-api : iobroker - enabled, port: 8087, bind: 0.0.0.0, run as: admin
    • system.adapter.smartmeter.0 : smartmeter : Pi-Strom-Wasser - enabled
    • system.adapter.smartmeter.1 : smartmeter : Pi-Strom-Wasser - enabled
    • system.adapter.sourceanalytix.0 : sourceanalytix : iobroker - enabled
    • system.adapter.sql.0 : sql : iobroker - enabled, port: 3306
    • system.adapter.sql.1 : sql : iobroker - enabled
    • system.adapter.tankerkoenig.0 : tankerkoenig : iobroker - enabled
    • system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0
    • system.adapter.telegram.1 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0
    • system.adapter.tr-064.0 : tr-064 : iobroker - enabled
    • system.adapter.tuya.0 : tuya : iobroker - enabled
    • system.adapter.viessmann.0 : viessmann : iobroker - enabled, port: 3002
      system.adapter.vis-bars.0 : vis-bars : iobroker - enabled
      system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobroker - enabled
      system.adapter.vis-colorpicker.0 : vis-colorpicker : iobroker - enabled
      system.adapter.vis-google-fonts.0 : vis-google-fonts : iobroker - enabled
      system.adapter.vis-history.0 : vis-history : iobroker - enabled
      system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker - enabled
    • system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - enabled
      system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobroker - enabled
      system.adapter.vis-justgage.0 : vis-justgage : iobroker - enabled
      system.adapter.vis-map.0 : vis-map : iobroker - enabled
      system.adapter.vis-metro.0 : vis-metro : iobroker - enabled
      system.adapter.vis-players.0 : vis-players : iobroker - enabled
      system.adapter.vis-plumb.0 : vis-plumb : iobroker - enabled
      system.adapter.vis-rgraph.0 : vis-rgraph : iobroker - enabled
      system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - enabled
      system.adapter.vis-weather.0 : vis-weather : iobroker - enabled
      system.adapter.vis.0 : vis : iobroker - enabled
    • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.wiobrowser.0 : wiobrowser : iobroker - disabled, port: 5000
    • system.adapter.wled.0 : wled : iobroker - enabled
    • system.adapter.ws.0 : ws : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin
    • system.adapter.yamaha.0 : yamaha : iobroker - enabled
    • system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: tcp://192.168.243.114:6638
    • instance is alive
    ioBroker-Repositories
    stable : http://download.iobroker.net/sources-dist.json
    beta : http://download.iobroker.net/sources-dist-latest.json
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter "admin" : 6.10.1 , installed 6.10.1
    Adapter "alias-manager": 1.2.6 , installed 1.2.6
    Adapter "asterisk" : 1.0.6 , installed 1.0.6
    Adapter "backitup" : 2.8.1 , installed 2.8.1
    Adapter "bmw" : 2.5.7 , installed 2.6.1
    Adapter "bosch-ebike" : 0.0.3 , installed 0.0.3
    Adapter "cloud" : 4.4.1 , installed 4.4.1
    Adapter "daswetter" : 3.1.10 , installed 3.1.10
    Adapter "doorio" : 2.1.4 , installed 2.1.4
    Adapter "dwd" : 2.8.5 , installed 2.8.5
    Adapter "email" : 1.2.0 , installed 1.2.0
    Adapter "feiertage" : 1.1.4 , installed 1.1.4
    Adapter "flot" : 1.12.0 , installed 1.12.0
    Adapter "fritzbox" : 0.5.0 , installed 0.5.0
    Adapter "fritzdect" : 2.3.1 , installed 2.3.1
    Adapter "hm-rega" : 3.0.47 , installed 3.0.47
    Adapter "hm-rpc" : 1.15.19 , installed 1.15.19
    Adapter "ical" : 1.13.3 , installed 1.13.3
    Adapter "icons-material-png": 0.1.0, installed 0.1.0
    Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0
    Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter "imap" : 0.1.1 , installed 0.1.1
    Adapter "influxdb" : 3.2.0 , installed 3.2.0
    Adapter "javascript" : 7.1.4 , installed 7.1.4
    Controller "js-controller": 5.0.12 , installed 5.0.12
    Adapter "libre" : 0.0.4 , installed 0.0.5
    Adapter "linux-control": 1.1.5 , installed 1.1.5
    Adapter "logparser" : 2.2.0 , installed 2.2.0
    Adapter "mihome" : 1.4.0 , installed 1.4.0
    Adapter "mihome-vacuum": 4.0.0 , installed 4.0.0
    Adapter "modbus" : 5.0.11 , installed 5.0.11
    Adapter "mqtt" : 4.1.1 , installed 4.1.1
    Adapter "musiccast" : 1.1.3 , installed 1.1.3
    Adapter "octoprint" : 4.0.0 , installed 4.0.0
    Adapter "openligadb" : 1.2.4 , installed 1.3.4
    Adapter "parser" : 1.3.2 , installed 1.3.2
    Adapter "ping" : 1.6.2 , installed 1.6.2
    Adapter "pollenflug" : 1.0.6 , installed 1.0.6
    Adapter "proxmox" : 1.3.5 , installed 1.3.5
    Adapter "rest-api" : 1.1.0 , installed 1.1.0
    Adapter "rssfeed" : 2.6.1 , installed 2.6.1
    Adapter "sayit" : 3.0.5 , installed 3.0.5
    Adapter "shelly" : 6.4.1 , installed 6.4.1
    Adapter "simple-api" : 2.7.2 , installed 2.7.2
    Adapter "socketio" : 6.5.5 , installed 6.5.5
    Adapter "sql" : 2.2.0 , installed 2.2.0
    Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7
    Adapter "telegram" : 1.16.0 , installed 1.16.0
    Adapter "tr-064" : 4.2.18 , installed 4.2.18
    Adapter "tuya" : 3.14.2 , installed 3.14.2
    Adapter "viessmann" : 1.4.4 , installed 1.4.4
    Adapter "vis" : 1.4.16 , installed 1.4.16
    Adapter "vis-bars" : 0.1.4 , installed 0.1.4
    Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1
    Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3
    Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4
    Adapter "vis-history" : 1.0.0 , installed 1.0.0
    Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0
    Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3
    Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
    Adapter "vis-justgage" : 1.0.2 , installed 1.0.2
    Adapter "vis-map" : 1.0.4 , installed 1.0.4
    Adapter "vis-metro" : 1.2.0 , installed 1.2.0
    Adapter "vis-players" : 0.1.6 , installed 0.1.6
    Adapter "vis-plumb" : 1.0.2 , installed 1.0.2
    Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2
    Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
    Adapter "vis-weather" : 2.5.6 , installed 2.5.6
    Adapter "web" : 6.1.2 , installed 6.1.10
    Adapter "wiobrowser" : 2.0.2 , installed 2.0.2
    Adapter "wled" : 0.7.1 , installed 0.7.1
    Adapter "ws" : 2.5.5 , installed 2.5.8
    Adapter "yamaha" : 0.5.3 , installed 0.5.3
    Adapter "zigbee" : 1.8.23 , installed 1.8.23
    Objects and States
    Objects: 24077
    States: 19957
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
    tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 12649 428/sshd: /usr/sbin
    tcp 0 0 192.168.243.15:2010 0.0.0.0:* LISTEN 1001 2957748 144381/io.hm-rpc.2
    tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 2957903 144489/io.mqtt.0
    tcp 0 0 0.0.0.0:1885 0.0.0.0:* LISTEN 1001 2958840 144522/io.mqtt.2
    tcp 0 0 192.168.243.15:8701 0.0.0.0:* LISTEN 1001 2957707 144348/io.hm-rpc.1
    tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1001 2952129 143903/iobroker.js-
    tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 2952108 143903/iobroker.js-
    tcp 0 0 0.0.0.0:5038 0.0.0.0:* LISTEN 108 11887 404/asterisk
    tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 2992 1/init
    tcp 0 0 192.168.243.15:2001 0.0.0.0:* LISTEN 1001 2957697 144322/io.hm-rpc.0
    tcp6 0 0 :::8084 :::* LISTEN 1001 2961066 145385/io.ws.0
    tcp6 0 0 :::22 :::* LISTEN 0 12651 428/sshd: /usr/sbin
    tcp6 0 0 :::8087 :::* LISTEN 1001 2962915 145245/io.simple-ap
    tcp6 0 0 :::111 :::* LISTEN 0 12368 1/init
    tcp6 0 0 :::8081 :::* LISTEN 1001 2957336 144020/io.admin.0
    tcp6 0 0 :::8082 :::* LISTEN 1001 2961012 145364/io.web.0
    udp 0 0 0.0.0.0:68 0.0.0.0:* 0 11706 356/dhclient
    udp 0 0 0.0.0.0:111 0.0.0.0:* 0 11535 1/init
    udp 0 0 0.0.0.0:41100 0.0.0.0:* 1001 2962835 145013/io.musiccast
    udp 0 0 0.0.0.0:53421 0.0.0.0:* 1001 2957823 144429/io.mihome-va
    udp 0 0 0.0.0.0:4569 0.0.0.0:* 108 11896 404/asterisk
    udp 0 0 0.0.0.0:5060 0.0.0.0:* 108 11897 404/asterisk
    udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 2963619 145563/io.wled.0
    udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 2956072 144612/io.tuya.0
    udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 2956073 144612/io.tuya.0
    udp 0 0 0.0.0.0:57049 0.0.0.0:* 108 14033 404/asterisk
    udp6 0 0 :::111 :::* 0 230 1/init
    udp6 0 0 :::55284 :::* 108 14034 404/asterisk
    2023-10-23 08:18:51.849 - info: javascript.0 (144096) script.js.Scripte.Geraete.Kombisensor: Auslöser Duration geändert
    2023-10-23 08:19:05.002 - info: javascript.0 (144096) script.js.Scripte.Geraete.Photovoltaik_2012: Auslöser: Schedule
    2023-10-23 08:19:05.003 - info: javascript.0 (144096) script.js.Scripte.Geraete.Photovoltaik_2012: Piko 5.5 auslesen
    2023-10-23 08:19:05.515 - info: javascript.0 (144096) script.js.Scripte.Geraete.Photovoltaik_2012: Leistung aktuell= 53 W // Tagesleistung= 0.01 kWh // Leistung alt gesamt= 56011 kWh // Leistung Strang 1= 36 W // Leistung Strang 2= 17 W
    2023-10-23 08:19:06.003 - info: javascript.0 (144096) script.js.Scripte.Geraete.Photovoltaik_2023: Leistung: alt = 53 W ; neu = 98 W ; alt+neu = 151 W
    2023-10-23 08:19:06.003 - info: javascript.0 (144096) script.js.Scripte.Geraete.Photovoltaik_2023: Batterie: 113 W ; Netz: -912 W ; Haus-Verbrauch: -950 W
    2023-10-23 08:19:06.003 - info: javascript.0 (144096) script.js.Scripte.Geraete.Photovoltaik_2023: Tagesleistung Heute: alt = 0.01 kWh ; neu = 0.04 kWh ; alt+neu = 0.05 kWh
    2023-10-23 08:19:09.294 - warn: modbus.0 (144459) Poll error count: 1 code: "App Timeout"
    2023-10-23 08:19:15.479 - info: admin.0 (144020) <== Disconnect system.user.admin from ::ffff:192.168.243.100 admin
    2023-10-23 08:19:15.551 - info: admin.0 (144020) <== Disconnect system.user.admin from ::ffff:192.168.243.100 admin
    2023-10-23 08:19:15.560 - info: admin.0 (144020) <== Disconnect system.user.admin from ::ffff:192.168.243.100 admin
    2023-10-23 08:19:15.564 - info: admin.0 (144020) <== Disconnect system.user.admin from ::ffff:192.168.243.102 admin
    2023-10-23 08:19:15.564 - info: admin.0 (144020) <== Disconnect system.user.admin from ::ffff:192.168.243.100 javascript
    2023-10-23 08:19:15.724 - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.100
    2023-10-23 08:19:17.576 - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.100
    2023-10-23 08:19:18.177 - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.100
    2023-10-23 08:19:18.178 - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.102
    2023-10-23 08:19:18.195 - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.100
    2023-10-23 08:19:20.348 - info: javascript.0 (144096) script.js.Scripte.Licht.Flur1_EG: Helligkeit = 34; Dimmer Flur 1 EG auf 40% eingeschaltet.
    2023-10-23 08:19:20.468 - info: javascript.0 (144096) script.js.Scripte.Licht.Kueche_Vorratsraum: Helligkeit = 34; Licht Küche Vorratsraum eingeschaltet.
    2023-10-23 08:19:21.160 - info: javascript.0 (144096) script.js.Scripte.Geraete.Wemos: Auslöser: SV Homeduino Barometer Tränke geändert
    2023-10-23 08:19:32.286 - info: octoprint.0 (145079) error EHOSTUNREACH from /api/version: connect EHOSTUNREACH 192.168.243.139:80
    2023-10-23 08:19:41.084 - info: mihome-vacuum.0 (144429) trigger cleaning segment 17
    2023-10-23 08:19:41.512 - info: javascript.0 (144096) script.js.Scripte.Licht.Bad_EG: Licht Bad EG nicht ausgeschaltet. Erneute Prüfung nach 2 min.
    2023-10-23 08:19:44.163 - info: octoprint.0 (145079) error ECONNABORTED from /api/version: timeout of 2000ms exceeded
    [/s]
    und summary
    [s=]
    v.2023-10-10
    Chassis: vm
    Virtualization: kvm
    Installation: kvm
    Kernel: x86_64
    Userland: amd64
    Timezone: Europe/Berlin (CEST, +0200)
    User-ID: 1000
    X-Server: false
    Pending OS-Updates: 0
    Pending iob updates: 0
    Nodejs-Installation: /usr/bin/nodejs v18.18.2
    /usr/bin/npm 9.8.1
    /usr/bin/npx 9.8.1
    Recommended versions are nodejs 18.18.2 and npm 9.8.1
    MEMORY:
    Mem: 5.9G 4.8G 588M 0.0K 543M 881M
    Swap: 974M 202M 772M
    Total: 6.9G 5.0G 1.4G
    Active iob-Instances: 56
    ioBroker Core: js-controller 5.0.12
    admin 6.10.1
    ioBroker Status: iobroker is running on this host.
    Objects type: jsonl
    States type: jsonl
    Objects: 24077
    States: 19957
    Size of iob-Database:
    51M /opt/iobroker/iobroker-data/objects.jsonl
    28M /opt/iobroker/iobroker-data/states.jsonl
    [/s]
    Hat jemand ne Idee ?
    mfg
    Dieter
    Danke.
    arteckA ? ? 4 Antworten Letzte Antwort
    • bahnuhrB bahnuhr
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Chassis: vm
      Virtualization: kvm
      Docker : false
      Kernel : x86_64
      Userland : amd64
      CPU threads: 8
      NTP service: active
      RTC in local TZ: no
      dieter
      /home/dieter
      X-Server: false
      Desktop:
      Terminal: tty
      *** MEMORY ***
      Swap: 974M 36M 938M
           5928 M total memory
           4740 M used memory
            262 M active memory
            556 M free memory
             89 M buffer memory
            542 M swap cache
            974 M total swap
             36 M used swap
            938 M free swap
      *** FILESYSTEM ***
      /var:
      1.5G /var/
      874M /var/log
      443M /var/cache
      USB-Devices by-id:
      /usr/bin/npm 9.8.1
      /usr/bin/npx 9.8.1
      nodejs:
      Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States type: jsonl
      admin: 6.10.1
      javascript: 7.1.4
      Adapter State
      • instance is alive
      Objects and States
      Objects: 24077
      States: 19957
      Pending Updates: 0
      [/s]
      und summary
      [s=]
      v.2023-10-10
      Chassis: vm
      Virtualization: kvm
      Installation: kvm
      Kernel: x86_64
      Userland: amd64
      User-ID: 1000
      X-Server: false
      /usr/bin/npm 9.8.1
      /usr/bin/npx 9.8.1
      MEMORY:
      admin 6.10.1
      Objects type: jsonl
      States type: jsonl
      Objects: 24077
      States: 19957
      [/s]
      mfg
      Dieter
      arteckA Offline
      arteckA Offline
      arteck
      @bahnuhr das log ist nach dem neustart.. was ist davor ??? das wird gebraucht
      • arteckA arteck
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        @arteck sagte in iob stürzt ab und startet dann neu:
        00:17 ist doch dabei.
        davor normale log Einträge
        Nun mal seit 00:10 bis 00:17
        2023-10-23 00:10:00.036  - info: javascript.0 (602) script.js.Scripte.System.Drucker_3D: 3D Drucker ist per Ping nicht erreichbar !
        2023-10-23 00:10:00.040  - info: javascript.0 (602) script.js.Scripte.Sonstige.Diabetes: Diabetes: Sensor seit und noch ermittelt.
        2023-10-23 00:10:00.060  - info: javascript.0 (602) script.js.Scripte.Geraete.Maehroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "distance": 0, "stopped": false, "dooropen": false, "duration": 19659, "mode": 0, "battery": 100, "hours": 1154}, "timer": {"status": 2, "next": {"date": "2023-10-24", "time": "10:00:00", "unix": 1698141600}}, "blades": {"quality": 0, "hours": 365, "days": 208}, "wlan": {"signal": -75}, "health": {"temperature": 22, "humidity": 27}, "clock": {"date": "2023-10-23", "time": "00:09:59", "unix": 1698019799}, "successful": true}
        2023-10-23 00:10:00.091  - info: host.iobroker instance system.adapter.dwd.0 started with pid 143502
        2023-10-23 00:10:00.150  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Lautstärke ist: 80 %.
        2023-10-23 00:10:00.156  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Helligkeit ist: 100 %.
        2023-10-23 00:10:00.314  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktueller Akkustand ist: 100 %.
        2023-10-23 00:10:00.383  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Lautstärke ist: 100 %.
        2023-10-23 00:10:00.416  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Helligkeit ist: 50 %.
        2023-10-23 00:10:00.516  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktueller Akkustand ist: 23 %.
        2023-10-23 00:10:02.095  - info: dwd.0 (143502) starting. Version 2.8.5 (non-npm: ioBroker/ioBroker.dwd) in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
        2023-10-23 00:10:03.765  - info: dwd.0 (143502) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-10-23 00:10:04.985  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-10-23 00:10:05.003  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Auslöser: Schedule
        2023-10-23 00:10:05.003  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Piko 5.5 auslesen
        2023-10-23 00:10:05.339  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Leistung aktuell= 0 W // Tagesleistung= 0 kWh // Leistung alt gesamt= 56011 kWh // Leistung Strang 1= 0 W // Leistung Strang 2= 0 W
        2023-10-23 00:10:05.361  - info: javascript.0 (602) script.js.Scripte.Geraete.Kombisensor_-_Windrose: Auslöser Windrichtung
        2023-10-23 00:10:06.004  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Leistung: alt = 0 W ; neu = 0 W ; alt+neu = 0 W
        2023-10-23 00:10:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Batterie: 0 W ; Netz: -656 W ; Haus-Verbrauch: -656 W
        2023-10-23 00:10:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Tagesleistung Heute: alt = 0 kWh ; neu = 0 kWh ; alt+neu = 0 kWh
        2023-10-23 00:11:00.020  - info: javascript.0 (602) script.js.Scripte.Geraete.Maehroboter: Auto_nachts ist: false
        2023-10-23 00:11:00.029  - info: javascript.0 (602) script.js.Scripte.Geraete.Shelly: Shellyflood-Heizung: letzte Abfrage war vor : 17 Tage / 1 Std. / 48 Min. / 6 Sek.
        2023-10-23 00:11:00.029  - info: javascript.0 (602) script.js.Scripte.Geraete.Shelly: Shellyflood-Kueche: letzte Abfrage war vor : 0 Tage / 6 Std. / 35 Min. / 5 Sek.
        2023-10-23 00:11:00.040  - info: javascript.0 (602) script.js.Scripte.System.CCU-Firmware_und_Lan-Gateway: Auslöser CCU-Firmware Schedule
        2023-10-23 00:11:00.147  - info: javascript.0 (602) script.js.Scripte.System.CCU-Firmware_und_Lan-Gateway: Installierte Firmware 3.65.11.20221005 der CCU ist nicht aktuell. Aktuell verfügbare Version: 3.71.12.20231020
        2023-10-23 00:11:05.002  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Auslöser: Schedule
        2023-10-23 00:11:05.002  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Piko 5.5 auslesen
        2023-10-23 00:11:05.330  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Leistung aktuell= 0 W // Tagesleistung= 0 kWh // Leistung alt gesamt= 56011 kWh // Leistung Strang 1= 0 W // Leistung Strang 2= 0 W
        2023-10-23 00:11:06.004  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Leistung: alt = 0 W ; neu = 0 W ; alt+neu = 0 W
        2023-10-23 00:11:06.004  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Batterie: 0 W ; Netz: -814 W ; Haus-Verbrauch: -814 W
        2023-10-23 00:11:06.004  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Tagesleistung Heute: alt = 0 kWh ; neu = 0 kWh ; alt+neu = 0 kWh
        2023-10-23 00:11:19.388  - info: javascript.0 (602) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Barometer Heizoel geändert
        2023-10-23 00:11:19.395  - info: javascript.0 (602) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Heizöl geändert
        2023-10-23 00:11:19.397  - info: javascript.0 (602) script.js.Scripte.Heizoel_Traenke_Zisterne_Brunnen.Heizoel_-_aktuell_Liter: Heizöl: 13.6 cm = aktuelle Liter = 4223
        2023-10-23 00:11:36.924  - info: javascript.0 (602) script.js.Scripte.Geraete.Waschmaschine: Auslöser Waschmaschine
        2023-10-23 00:12:00.061  - info: javascript.0 (602) script.js.Scripte.Geraete.Maehroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "distance": 0, "stopped": false, "dooropen": false, "duration": 19779, "mode": 0, "battery": 100, "hours": 1154}, "timer": {"status": 2, "next": {"date": "2023-10-24", "time": "10:00:00", "unix": 1698141600}}, "blades": {"quality": 0, "hours": 365, "days": 208}, "wlan": {"signal": -75}, "health": {"temperature": 22, "humidity": 27}, "clock": {"date": "2023-10-23", "time": "00:11:59", "unix": 1698019919}, "successful": true}
        2023-10-23 00:12:05.007  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Auslöser: Schedule
        2023-10-23 00:12:05.007  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Piko 5.5 auslesen
        2023-10-23 00:12:05.103  - info: javascript.0 (602) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Barometer Zisterne geändert
        2023-10-23 00:12:05.108  - info: javascript.0 (602) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Zisterne geändert
        2023-10-23 00:12:05.345  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Leistung aktuell= 0 W // Tagesleistung= 0 kWh // Leistung alt gesamt= 56011 kWh // Leistung Strang 1= 0 W // Leistung Strang 2= 0 W
        2023-10-23 00:12:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Leistung: alt = 0 W ; neu = 0 W ; alt+neu = 0 W
        2023-10-23 00:12:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Batterie: 0 W ; Netz: -814 W ; Haus-Verbrauch: -814 W
        2023-10-23 00:12:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Tagesleistung Heute: alt = 0 kWh ; neu = 0 kWh ; alt+neu = 0 kWh
        2023-10-23 00:12:23.003  - info: javascript.0 (602) script.js.Scripte.System.Sonne_Mond: Sonne: Azimut: 340° / Sonne: Elevation: -49.1° / Mond: Azimut: 232° / Mond: Elevation: 1.1°
        2023-10-23 00:12:27.052  - info: javascript.0 (602) script.js.Scripte.Geraete.Kombisensor_-_Windrose: Auslöser Windrichtung
        2023-10-23 00:13:03.751  - info: javascript.0 (602) script.js.Scripte.Geraete.Wemos: Auslöser: SV Homeduino Barometer Tränke geändert
        2023-10-23 00:13:05.003  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Auslöser: Schedule
        2023-10-23 00:13:05.003  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Piko 5.5 auslesen
        2023-10-23 00:13:05.330  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Leistung aktuell= 0 W // Tagesleistung= 0 kWh // Leistung alt gesamt= 56011 kWh // Leistung Strang 1= 0 W // Leistung Strang 2= 0 W
        2023-10-23 00:13:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Leistung: alt = 0 W ; neu = 0 W ; alt+neu = 0 W
        2023-10-23 00:13:06.006  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Batterie: 0 W ; Netz: -737 W ; Haus-Verbrauch: -737 W
        2023-10-23 00:13:06.006  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Tagesleistung Heute: alt = 0 kWh ; neu = 0 kWh ; alt+neu = 0 kWh
        2023-10-23 00:14:00.051  - info: javascript.0 (602) script.js.Scripte.Geraete.Maehroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "distance": 0, "stopped": false, "dooropen": false, "duration": 19899, "mode": 0, "battery": 100, "hours": 1154}, "timer": {"status": 2, "next": {"date": "2023-10-24", "time": "10:00:00", "unix": 1698141600}}, "blades": {"quality": 0, "hours": 365, "days": 208}, "wlan": {"signal": -75}, "health": {"temperature": 22, "humidity": 27}, "clock": {"date": "2023-10-23", "time": "00:13:59", "unix": 1698020039}, "successful": true}
        2023-10-23 00:14:05.009  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Auslöser: Schedule
        2023-10-23 00:14:05.010  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Piko 5.5 auslesen
        2023-10-23 00:14:05.437  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Leistung aktuell= 0 W // Tagesleistung= 0 kWh // Leistung alt gesamt= 56011 kWh // Leistung Strang 1= 0 W // Leistung Strang 2= 0 W
        2023-10-23 00:14:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Leistung: alt = 0 W ; neu = 0 W ; alt+neu = 0 W
        2023-10-23 00:14:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Batterie: 0 W ; Netz: -737 W ; Haus-Verbrauch: -737 W
        2023-10-23 00:14:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Tagesleistung Heute: alt = 0 kWh ; neu = 0 kWh ; alt+neu = 0 kWh
        2023-10-23 00:14:13.486  - info: javascript.0 (602) script.js.Scripte.Geraete.Drucksensor: Heizung: 10544 , 1.86
        2023-10-23 00:14:13.486  - info: javascript.0 (602) script.js.Scripte.Geraete.Drucksensor: FB-Heizung: 9936 , 1.72
        2023-10-23 00:14:13.486  - info: javascript.0 (602) script.js.Scripte.Geraete.Drucksensor: Wasser: 8848 , 3.51
        2023-10-23 00:14:34.914  - info: javascript.0 (602) script.js.Scripte.Geraete.Kombisensor_-_Windrose: Auslöser Windrichtung
        2023-10-23 00:15:00.035  - info: javascript.0 (602) script.js.Scripte.Sonstige.Diabetes: Diabetes: Sensor seit und noch ermittelt.
        2023-10-23 00:15:00.039  - info: javascript.0 (602) script.js.Scripte.System.Drucker_3D: 3D Drucker ist per Ping nicht erreichbar !
        2023-10-23 00:15:00.062  - info: javascript.0 (602) script.js.Scripte.System.View_wechseln: View auf 'Uhr' gewechselt.
        2023-10-23 00:15:00.077  - info: javascript.0 (602) script.js.Scripte.Haus.Dachfenster: Auslöser Dachfenster: 0:15 Uhr
        2023-10-23 00:15:00.078  - info: javascript.0 (602) script.js.Scripte.Haus.Dachfenster: Es ist 0 Uhr 15.: Alle Fenster im Dachgeschoss sind geschlossen.
        2023-10-23 00:15:00.090  - info: host.iobroker instance system.adapter.dwd.0 started with pid 143755
        2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ0574459.4 Fitnessraum false
        2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ0574613.4 Philipp L false
        2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ0574642.4 Rebecca L false
        2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ0576469.4 Philipp R false
        2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ0653104.4 Wohnzimmer false
        2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ0724743.4 Bad_OG false
        2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ1040434.4 Arbeitszimmer false
        2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ1040443.4 Schlafzimmer false
        2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ1040517.4 Hobbyraum false
        2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.KEQ1040651.4 Büro false
        2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.LEQ0107637.4 Bad_EG - Handtuch false
        2023-10-23 00:15:00.096  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.LEQ0782624.4 Rebecca R false
        2023-10-23 00:15:00.097  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.LEQ0783942.4 Bad_OG - Handtuch false
        2023-10-23 00:15:00.097  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.LEQ0784844.4 Sauna false
        2023-10-23 00:15:00.097  - info: javascript.0 (602) script.js.Scripte.Heizung.Heizung_nachts_auto_pruefen: hm-rpc.0.OEQ2092890.4 Bad_EG false
        2023-10-23 00:15:00.135  - info: javascript.0 (602) script.js.Scripte.System.Batterie: Auslöser: Schedule
        2023-10-23 00:15:00.139  - warn: javascript.0 (602) getState "hm-rpc.0.MEQ0675420.0.LOWBAT" not found (3)
        2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at Ermittlung (script.js.Scripte.System.Batterie:18:22)
        2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at Array.forEach (<anonymous>)
        2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at weiter (script.js.Scripte.System.Batterie:15:13)
        2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at Object.<anonymous> (script.js.Scripte.System.Batterie:70:5)
        2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1617:34)
        2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15)
        2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28
        2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7)
        2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at listOnTimeout (node:internal/timers:569:17)
        2023-10-23 00:15:00.141  - warn: javascript.0 (602)     at processTimers (node:internal/timers:512:7)
        2023-10-23 00:15:00.141  - warn: javascript.0 (602) script.js.Scripte.System.Batterie: Object "hm-rpc.0.MEQ0675420.0.LOWBAT" does not exist
        2023-10-23 00:15:00.142  - error: javascript.0 (602) Error in callback: TypeError: Cannot read properties of null (reading 'common')
        2023-10-23 00:15:00.143  - error: javascript.0 (602)     at Ermittlung (script.js.Scripte.System.Batterie:20:34)
        2023-10-23 00:15:00.143  - error: javascript.0 (602)     at Array.forEach (<anonymous>)
        2023-10-23 00:15:00.143  - error: javascript.0 (602)     at weiter (script.js.Scripte.System.Batterie:15:13)
        2023-10-23 00:15:00.143  - error: javascript.0 (602)     at Object.<anonymous> (script.js.Scripte.System.Batterie:70:5)
        2023-10-23 00:15:00.143  - error: javascript.0 (602)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1617:34)
        2023-10-23 00:15:00.143  - error: javascript.0 (602)     at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15)
        2023-10-23 00:15:00.143  - error: javascript.0 (602)     at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28
        2023-10-23 00:15:00.143  - error: javascript.0 (602)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7)
        2023-10-23 00:15:00.143  - error: javascript.0 (602)     at listOnTimeout (node:internal/timers:569:17)
        2023-10-23 00:15:00.143  - error: javascript.0 (602)     at processTimers (node:internal/timers:512:7)
        2023-10-23 00:15:00.159  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Helligkeit ist: 100 %.
        2023-10-23 00:15:00.190  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Lautstärke ist: 80 %.
        2023-10-23 00:15:00.286  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Lautstärke ist: 100 %.
        2023-10-23 00:15:00.321  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktueller Akkustand ist: 100 %.
        2023-10-23 00:15:00.339  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Helligkeit ist: 50 %.
        2023-10-23 00:15:00.371  - info: javascript.0 (602) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktueller Akkustand ist: 21 %.
        2023-10-23 00:15:01.950  - info: dwd.0 (143755) starting. Version 2.8.5 (non-npm: ioBroker/ioBroker.dwd) in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
        2023-10-23 00:15:03.579  - info: dwd.0 (143755) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-10-23 00:15:04.977  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 143780
        2023-10-23 00:15:05.002  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Auslöser: Schedule
        2023-10-23 00:15:05.002  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Piko 5.5 auslesen
        2023-10-23 00:15:05.238  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-10-23 00:15:05.427  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Leistung aktuell= 0 W // Tagesleistung= 0 kWh // Leistung alt gesamt= 56011 kWh // Leistung Strang 1= 0 W // Leistung Strang 2= 0 W
        2023-10-23 00:15:06.002  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Leistung: alt = 0 W ; neu = 0 W ; alt+neu = 0 W
        2023-10-23 00:15:06.003  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Batterie: 0 W ; Netz: -651 W ; Haus-Verbrauch: -651 W
        2023-10-23 00:15:06.003  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Tagesleistung Heute: alt = 0 kWh ; neu = 0 kWh ; alt+neu = 0 kWh
        2023-10-23 00:15:07.343  - info: daswetter.0 (143780) starting. Version 3.1.10 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.18.2, js-controller: 5.0.12
        2023-10-23 00:15:07.666  - info: javascript.0 (602) script.js.Scripte.Sonstige.Wetter: /vis.0/main/img/Wetter/3f.png
        2023-10-23 00:15:09.077  - info: host.iobroker instance system.adapter.ical.0 started with pid 143797
        2023-10-23 00:15:11.401  - info: ical.0 (143797) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.12
        2023-10-23 00:15:12.218  - info: ical.0 (143797) processing URL: Märkte https://calendar.google.com/calendar/ical/mn7fmslmdftdee289a43jfk2p4%40group.calendar.google.com/private-a1b9dd34a9/basic.ics
        2023-10-23 00:15:12.864  - info: ical.0 (143797) processing URL: Müll https://calendar.google.com/calendar/ical/4v99ckgoup.calendar.google.com/private-3fc7699/basic.ics
        2023-10-23 00:15:13.375  - info: ical.0 (143797) processing URL: Google https://calendar.google.com/calendar/ical/d.mueller3005%40googlemail.com/private-068d7325b7c/basic.ics
        2023-10-23 00:15:19.828  - info: ical.0 (143797) Terminated (NO_ERROR): Without reason
        2023-10-23 00:15:20.604  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2023-10-23 00:16:00.056  - info: javascript.0 (602) script.js.Scripte.Geraete.Maehroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "distance": 0, "stopped": false, "dooropen": false, "duration": 20019, "mode": 0, "battery": 100, "hours": 1154}, "timer": {"status": 2, "next": {"date": "2023-10-24", "time": "10:00:00", "unix": 1698141600}}, "blades": {"quality": 0, "hours": 365, "days": 208}, "wlan": {"signal": -75}, "health": {"temperature": 22, "humidity": 27}, "clock": {"date": "2023-10-23", "time": "00:15:59", "unix": 1698020159}, "successful": true}
        2023-10-23 00:16:05.006  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Auslöser: Schedule
        2023-10-23 00:16:05.006  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Piko 5.5 auslesen
        2023-10-23 00:16:05.434  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2012: Leistung aktuell= 0 W // Tagesleistung= 0 kWh // Leistung alt gesamt= 56011 kWh // Leistung Strang 1= 0 W // Leistung Strang 2= 0 W
        2023-10-23 00:16:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Leistung: alt = 0 W ; neu = 0 W ; alt+neu = 0 W
        2023-10-23 00:16:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Batterie: 0 W ; Netz: -679 W ; Haus-Verbrauch: -679 W
        2023-10-23 00:16:06.005  - info: javascript.0 (602) script.js.Scripte.Geraete.Photovoltaik_2023: Tagesleistung Heute: alt = 0 kWh ; neu = 0 kWh ; alt+neu = 0 kWh
        2023-10-23 00:16:15.175  - info: javascript.0 (602) script.js.Scripte.Geraete.Waschmaschine: Auslöser Waschmaschine
        2023-10-23 00:16:15.952  - error: sql.0 (613) Cannot insert INSERT INTO `iob_mariadb`.ts_number (id, ts, val, ack, _from, q) VALUES (379, 1698012975933, 48.25137083719676, 1, 28, 0);: Error: Duplicate entry '379-1698012975933' for key 'PRIMARY' (id: sourceanalytix.0.javascript__0__Geräte__Stromzähler_SDM72__Leistung_bezogen.cumulativeReading)
        2023-10-23 00:16:15.958  - error: sql.0 (613) Cannot insert INSERT INTO `iob_mariadb`.ts_number (id, ts, val, ack, _from, q) VALUES (379, 1698012975934, 48.25138052218287, 1, 28, 0);: Error: Duplicate entry '379-1698012975934' for key 'PRIMARY' (id: sourceanalytix.0.javascript__0__Geräte__Stromzähler_SDM72__Leistung_bezogen.cumulativeReading)
        2023-10-23 00:16:16.196  - error: sql.0 (613) Cannot insert INSERT INTO `iob_mariadb`.ts_number (id, ts, val, ack, _from, q) VALUES (380, 1698012976188, 0.165, 1, 28, 0);: Error: Duplicate entry '380-1698012976188' for key 'PRIMARY' (id: sourceanalytix.0.javascript__0__Geräte__Stromzähler_SDM72__Leistung_bezogen.currentYear.consumed.01_currentDay)
        2023-10-23 00:16:16.201  - error: sql.0 (613) Cannot insert INSERT INTO `iob_mariadb`.ts_number (id, ts, val, ack, _from, q) VALUES (380, 1698012976189, 0.165, 1, 28, 0);: Error: Duplicate entry '380-1698012976189' for key 'PRIMARY' (id: sourceanalytix.0.javascript__0__Geräte__Stromzähler_SDM72__Leistung_bezogen.currentYear.consumed.01_currentDay)
        2023-10-23 00:16:16.670  - info: daswetter.0 (143780) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2023-10-23 00:16:18.872  - info: javascript.0 (602) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Barometer Heizoel geändert
        2023-10-23 00:16:18.880  - info: javascript.0 (602) script.js.Scripte.Geraete.Wemos: Auslöser: Wemos Heizöl geändert
        2023-10-23 00:16:18.880  - info: javascript.0 (602) script.js.Scripte.Heizoel_Traenke_Zisterne_Brunnen.Heizoel_-_aktuell_Liter: Heizöl: 14.1 cm = aktuelle Liter = 4207
        2023-10-23 00:16:20.575  - info: daswetter.0 (143780) cleaned everything up...
        2023-10-23 00:16:23.127  - info: javascript.0 (602) script.js.Scripte.System.Sonne_Mond: Sonne: Azimut: 341° / Sonne: Elevation: -49.3° / Mond: Azimut: 233° / Mond: Elevation: 0.7°
        2023-10-23 00:16:24.590  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-10-23 00:17:08.837  - info: web.0 (1427) <== Disconnect system.user.admin from ::ffff:192.168.243.102 vis.0
        2023-10-23 00:17:09.046  - info: admin.0 (564) <== Disconnect system.user.admin from ::ffff:192.168.243.100 admin
        2023-10-23 00:17:09.056  - info: mqtt.2 (886) Client [Wemos_Sauna_Klima] reconnected. Old secret 1698012110123_9718. New secret 1698013028211_1856
        2023-10-23 00:17:09.189  - info: mqtt.2 (886) Client [Wemos_Kueche_Klima] reconnected. Old secret 1698012110123_7633. New secret 1698013028540_3060
        2023-10-23 00:17:09.189  - info: mqtt.2 (886) Client [Wemos_Wohnzimmer_Klima] reconnected. Old secret 1698012111414_7033. New secret 1698013028540_8286
        2023-10-23 00:17:09.191  - info: mqtt.2 (886) Client [Wemos_Wohnzimmer_Klima] connection closed: closed
        2023-10-23 00:17:09.191  - info: mqtt.2 (886) Client [Wemos_Kueche_Klima] connection closed: closed
        2023-10-23 00:17:09.191  - info: mqtt.2 (886) Client [Wemos_Sauna_Klima] connection closed: closed
        2023-10-23 00:17:50.526  - info: admin.0 (564) <== Disconnect system.user.admin from ::ffff:192.168.243.102 admin
        2023-10-23 00:17:09.120  - info: web.0 (1427) <== Disconnect system.user.admin from ::ffff:192.168.243.109 vis.0
        2023-10-23 00:17:09.121  - info: web.0 (1427) <== Disconnect system.user.admin from ::ffff:192.168.243.100 vis.0
        2023-10-23 00:17:09.121  - info: web.0 (1427) <== Disconnect system.user.admin from ::ffff:192.168.243.122 vis.0
        Danke.
        • bahnuhrB bahnuhr
          arteckA Offline
          arteckA Offline
          arteck
          @bahnuhr die jsonl ist wech... warum auch immer.. machst du ne sicherung ?? davon manuell ??
          • arteckA arteck
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            jsonl
            was ist weg ?
            Ich mache täglich:
            proxmox backup Sicherung
            wöchentlich iob komplett copy auf nas
            täglich scripte sichern
            Danke.
            • bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              der letzte copy war am 21.10.
              Danke.
              • arteckA Offline
                arteckA Offline
                arteck
                @bahnuhr sagte in iob stürzt ab und startet dann neu:
                Objects type: jsonl
                States type: jsonl
                ist weg... da liegen die states und objekte .... und die sind weg..
                • arteckA arteck
                  Objects type: jsonl
                  States type: jsonl
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  @arteck
                  meinst du diese ?
                  Die sind da.
                  Oder meinst du was anderes ?
                  Danke.
                  • bahnuhrB bahnuhr
                    @arteck
                    meinst du diese ?
                    Die sind da.
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @bahnuhr die meine ich .. die Fehlermeldung besagt dass iobroker da nix reinschreiben kann.. also knallt der.. und startet neu
                    machmal bitte
                    iob fix
                    die sind relativ gross .. sollten dann komprimiert sein
                    • bahnuhrB bahnuhr
                      ist mir jetzt schon öfters aufgefallen, dass iob abstürzt und dann neu startet.
                      Gefühlt so 1 x täglich.
                      Heute Nacht um ca. 00:17 wieder, log hab ich mal dazu gelegt.
                      (log gekürzt, weil länger als 10.000 Zeichen)
                      2023-10-23 00:41:19.302  - error: influxdb.0 (718) States database error: read ECONNRESET
                      2023-10-23 00:41:19.580  - warn: javascript.0 (602) script.js.Scripte.Geraete.Huawei: Error received reading address 37700 from id: 1 with error: undefined
                      2023-10-23 00:41:19.943  - error: sql.0 (613) States database error: read ECONNRESET
                      2023-10-23 00:41:20.051  - error: contact.0 (1107) States database error: write ECONNRESET
                      2023-10-23 00:41:19.317  - error: imap.0 (1575) States database error: read ECONNRESET
                      2023-10-23 00:41:20.876  - error: musiccast.0 (1207) States database error: write ECONNRESET
                      2023-10-23 00:41:21.546  - error: web.0 (1427) States database error: write ECONNRESET
                      2023-10-23 00:41:21.595  - error: admin.0 (564) States database error: write EPIPE
                      2023-10-23 00:41:21.922  - error: wled.0 (50353) States database error: write ECONNRESET
                      2023-10-23 00:41:21.921  - error: mihome-vacuum.0 (833) States database error: write ECONNRESET
                      2023-10-23 00:41:22.018  - error: zigbee.0 (977) Objects database error: write ECONNRESET
                      2023-10-23 00:41:22.557  - error: zigbee.0 (977) States database error: write EPIPE
                      2023-10-23 00:41:22.730  - error: octoprint.0 (1260) States database error: write EPIPE
                      2023-10-23 00:41:20.397  - error: telegram.1 (647) States database error: read ECONNRESET
                      2023-10-23 00:41:21.074  - error: vis-inventwo.0 (1397) States database error: write ECONNRESET
                      2023-10-23 00:41:22.834  - error: octoprint.0 (1260) Objects database error: read ECONNRESET
                      2023-10-23 00:41:20.671  - error: asterisk.0 (1019) States database error: write ECONNRESET
                      2023-10-23 00:41:20.296  - error: telegram.0 (632) States database error: read ECONNRESET
                      2023-10-23 00:41:21.458  - error: proxmox.0 (1600) States database error: write EPIPE
                      2023-10-23 00:41:20.827  - error: simple-api.0 (1334) States database error: read ECONNRESET
                      2023-10-23 00:41:21.778  - error: rssfeed.0 (1457) States database error: write ECONNRESET
                      2023-10-23 00:41:21.895  - error: tankerkoenig.0 (1351) States database error: write ECONNRESET
                      2023-10-23 00:41:20.999  - error: openligadb.0 (1281) States database error: write ECONNRESET
                      2023-10-23 00:41:23.404  - error: fritzbox.0 (736) States database error: write ECONNRESET
                      2023-10-23 00:41:23.804  - error: sourceanalytix.0 (1474) States database error: write ECONNRESET
                      2023-10-23 00:41:23.944  - info: sourceanalytix.0 (1474) SourceAnalytix stopped, now you have to calculate by yourself :'( ...
                      2023-10-23 00:41:23.952  - error: tuya.0 (50983) States database error: write EPIPE
                      2023-10-23 00:41:23.496  - error: bmw.0 (1046) States database error: write ECONNRESET
                      2023-10-23 00:41:24.168  - error: hm-rega.0 (751) States database error: write ECONNRESET
                      2023-10-23 00:41:24.205  - error: hm-rega.0 (751) Objects database error: read ECONNRESET
                      2023-10-23 00:41:23.283  - error: parser.0 (1299) States database error: write ECONNRESET
                      2023-10-23 00:41:24.021  - error: ws.0 (1442) States database error: write ECONNRESET
                      2023-10-23 00:41:23.856  - error: sql.1 (681) States database error: write ECONNRESET
                      2023-10-23 00:41:23.726  - error: logparser.0 (1179) States database error: write ECONNRESET
                      2023-10-23 00:41:23.695  - error: mqtt.0 (871) States database error: write ECONNRESET
                      2023-10-23 00:41:24.487  - info: mqtt.0 (871) Client [ROBONECT081603] connection closed: timeout
                      2023-10-23 00:41:23.804  - error: libre.0 (1166) States database error: write ECONNRESET
                      2023-10-23 00:41:24.620  - error: modbus.0 (856) Objects database error: write ECONNRESET
                      2023-10-23 00:41:24.173  - error: bosch-ebike.0 (1073) States database error: write ECONNRESET
                      2023-10-23 00:41:24.078  - error: email.0 (571) States database error: write ECONNRESET
                      2023-10-23 00:41:24.379  - error: ping.0 (901) States database error: write ECONNRESET
                      2023-10-23 00:41:24.913  - error: mqtt.2 (886) Objects database error: write EPIPE
                      2023-10-23 00:41:24.215  - error: hm-rpc.2 (796) States database error: write ECONNRESET
                      2023-10-23 00:41:24.635  - warn: modbus.0 (856) Poll error count: 1 code: "App Timeout"
                      2023-10-23 00:41:24.939  - error: modbus.0 (856) States database error: write ECONNRESET
                      2023-10-23 00:41:24.944  - error: modbus.0 (856) Socket Error
                      2023-10-23 00:41:24.945  - error: modbus.0 (856) Client in error state.
                      2023-10-23 00:41:24.945  - warn: modbus.0 (856) On error: {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                      2023-10-23 00:41:23.781  - error: fritzdect.0 (1160) States database error: write ECONNRESET
                      2023-10-23 00:41:24.745  - error: javascript.1 (666) States database error: write ECONNRESET
                      2023-10-23 00:41:25.097  - error: mqtt.2 (886) States database error: write ECONNRESET
                      2023-10-23 00:41:24.443  - error: tr-064.0 (923) States database error: write ECONNRESET
                      2023-10-23 00:41:25.060  - error: hm-rpc.0 (766) Objects database error: write ECONNRESET
                      2023-10-23 00:41:25.428  - error: hm-rpc.0 (766) States database error: write ECONNRESET
                      2023-10-23 00:41:25.193  - error: backitup.0 (990) States database error: write ECONNRESET
                      2023-10-23 00:41:25.720  - error: pollenflug.0 (1316) States database error: write ECONNRESET
                      2023-10-23 00:41:25.746  - error: sayit.4 (1557) States database error: write ECONNRESET
                      2023-10-23 00:41:24.326  - error: yamaha.0 (959) Objects database error: write EPIPE
                      2023-10-23 00:41:25.808  - error: yamaha.0 (959) States database error: write ECONNRESET
                      2023-10-23 00:41:20.872  - error: viessmann.0 (1366) Timeout connection error!
                      2023-10-23 00:41:25.286  - warn: viessmann.0 (1366) Reconnect time is wrong
                      2023-10-23 00:41:25.824  - error: viessmann.0 (1366) States database error: write ECONNRESET
                      2023-10-23 00:41:25.834  - error: sayit.3 (1535) States database error: write ECONNRESET
                      2023-10-23 00:41:21.917  - info: cloud.0 (1092) Connection changed: disconnect
                      2023-10-23 00:41:26.527  - error: cloud.0 (1092) States database error: write ECONNRESET
                      2023-10-23 00:41:27.752  - error: sayit.2 (1492) States database error: write ECONNRESET
                      2023-10-23 00:41:38.401  - info: host.iobroker iobroker.js-controller version 5.0.12 js-controller starting
                      2023-10-23 00:41:38.403  - info: host.iobroker Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                      2023-10-23 00:41:38.403  - info: host.iobroker hostname: iobroker, node: v18.18.2
                      2023-10-23 00:41:38.404  - info: host.iobroker ip addresses: 192.168.243.15 2a03:93e0:200:b70:8891:b1ff:fea3:66d8 fe80::8891:b1ff:fea3:66d8
                      2023-10-23 00:41:46.928  - info: host.iobroker connected to Objects and States
                      2023-10-23 00:41:46.985  - info: host.iobroker added notifications configuration of host
                      2023-10-23 00:41:48.061  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
                      2023-10-23 00:41:48.062  - info: host.iobroker 88 instances found
                      2023-10-23 00:41:48.208  - info: host.iobroker starting 72 instances
                      2023-10-23 00:41:48.370  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
                      2023-10-23 00:41:48.378  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
                      2023-10-23 00:41:48.437  - info: host.iobroker instance system.adapter.admin.0 started with pid 143921
                      2023-10-23 00:41:48.441  - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
                      2023-10-23 00:41:48.487  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
                      2023-10-23 00:41:48.531  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
                      2023-10-23 00:41:48.575  - info: host.iobroker Some obsolete host states deleted.
                      2023-10-23 00:41:52.274  - error: admin.0 (143921) admin.0 already running
                      2023-10-23 00:41:52.276  - warn: admin.0 (143921) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-23 00:41:52.294  - info: host.iobroker instance system.adapter.email.0 started with pid 143932
                      2023-10-23 00:41:52.955  - error: host.iobroker instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-23 00:41:52.955  - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
                      2023-10-23 00:41:53.097  - error: email.0 (143932) email.0 already running
                      2023-10-23 00:41:53.098  - warn: email.0 (143932) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-23 00:41:53.663  - error: host.iobroker instance system.adapter.email.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-23 00:41:53.663  - info: host.iobroker Restart adapter system.adapter.email.0 because enabled
                      2023-10-23 00:41:56.427  - info: host.iobroker instance system.adapter.javascript.0 started with pid 143943
                      2023-10-23 00:42:00.355  - info: host.iobroker instance system.adapter.sql.0 started with pid 143950
                      2023-10-23 00:42:02.610  - error: javascript.0 (143943) javascript.0 already running
                      2023-10-23 00:42:02.611  - warn: javascript.0 (143943) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-23 00:42:03.105  - error: sql.0 (143950) sql.0 already running
                      2023-10-23 00:42:03.106  - warn: sql.0 (143950) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-23 00:42:03.181  - error: host.iobroker instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-23 00:42:03.181  - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
                      2023-10-23 00:42:03.674  - error: host.iobroker instance system.adapter.sql.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-23 00:42:03.674  - info: host.iobroker Restart adapter system.adapter.sql.0 because enabled
                      2023-10-23 00:42:04.286  - info: host.iobroker instance system.adapter.telegram.0 started with pid 143965
                      2023-10-23 00:42:08.303  - info: host.iobroker instance system.adapter.telegram.1 started with pid 143972
                      2023-10-23 00:42:09.140  - error: telegram.0 (143965) telegram.0 already running
                      2023-10-23 00:42:09.142  - warn: telegram.0 (143965) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-23 00:42:09.277  - error: telegram.1 (143972) telegram.1 already running
                      2023-10-23 00:42:09.279  - warn: telegram.1 (143972) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-23 00:42:09.711  - error: host.iobroker instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-23 00:42:09.711  - info: host.iobroker Restart adapter system.adapter.telegram.0 because enabled
                      2023-10-23 00:42:09.847  - error: host.iobroker instance system.adapter.telegram.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-23 00:42:09.848  - info: host.iobroker Restart adapter system.adapter.telegram.1 because enabled
                      2023-10-23 00:42:12.279  - info: host.iobroker instance system.adapter.javascript.1 started with pid 143987
                      2023-10-23 00:42:13.378  - error: javascript.1 (143987) javascript.1 already running
                      2023-10-23 00:42:13.379  - warn: javascript.1 (143987) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-23 00:42:13.951  - error: host.iobroker instance system.adapter.javascript.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-23 00:42:13.951  - info: host.iobroker Restart adapter system.adapter.javascript.1 because enabled
                      2023-10-23 00:42:16.281  - info: host.iobroker instance system.adapter.sql.1 started with pid 143998
                      2023-10-23 00:42:17.045  - error: sql.1 (143998) sql.1 already running
                      2023-10-23 00:42:17.046  - warn: sql.1 (143998) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-23 00:42:17.620  - error: host.iobroker instance system.adapter.sql.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-23 00:42:17.620  - info: host.iobroker Restart adapter system.adapter.sql.1 because enabled
                      2023-10-23 00:42:20.285  - info: host.iobroker instance system.adapter.influxdb.0 started with pid 144009
                      2023-10-23 00:42:21.854  - error: influxdb.0 (144009) influxdb.0 already running
                      2023-10-23 00:42:21.856  - warn: influxdb.0 (144009) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-23 00:42:22.430  - error: host.iobroker instance system.adapter.influxdb.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-23 00:42:22.431  - info: host.iobroker Restart adapter system.adapter.influxdb.0 because enabled
                      2023-10-23 00:42:23.026  - info: host.iobroker instance system.adapter.admin.0 started with pid 144020
                      2023-10-23 00:42:23.773  - info: host.iobroker instance system.adapter.email.0 started with pid 144031
                      2023-10-23 00:42:24.382  - info: host.iobroker instance system.adapter.fritzbox.0 started with pid 144042
                      2023-10-23 00:42:24.603  - info: admin.0 (144020) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.12
                      2023-10-23 00:42:24.625  - info: admin.0 (144020) requesting all objects
                      2023-10-23 00:42:24.789  - info: email.0 (144031) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.email, node: v18.18.2, js-controller: 5.0.12
                      2023-10-23 00:42:25.823  - info: admin.0 (144020) received all objects
                      2023-10-23 00:42:26.778  - error: fritzbox.0 (144042) fritzbox.0 already running
                      2023-10-23 00:42:26.779  - warn: fritzbox.0 (144042) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-23 00:42:26.903  - info: admin.0 (144020) Request actual repository...
                      2023-10-23 00:42:26.912  - info: admin.0 (144020) socket.io server listening on port 8081
                      2023-10-23 00:42:26.913  - info: admin.0 (144020) http server listening on port 8081
                      2023-10-23 00:42:26.914  - info: admin.0 (144020) Use link "http://127.0.0.1:8081" to configure.
                      2023-10-23 00:42:27.169  - error: admin.0 (144020) Cannot update news: TypeError: newNews.forEach is not a function
                      2023-10-23 00:42:27.218  - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.102
                      2023-10-23 00:42:29.462  - error: host.iobroker instance system.adapter.fritzbox.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-23 00:42:29.463  - info: host.iobroker Restart adapter system.adapter.fritzbox.0 because enabled
                      2023-10-23 00:42:29.486  - info: host.iobroker instance system.adapter.hm-rega.0 started with pid 144069
                      2023-10-23 00:42:29.995  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                      2023-10-23 00:42:30.835  - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.100
                      2023-10-23 00:42:31.603  - error: hm-rega.0 (144069) hm-rega.0 already running
                      2023-10-23 00:42:31.605  - warn: hm-rega.0 (144069) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-23 00:42:31.860  - info: admin.0 (144020) Repository received successfully.
                      2023-10-23 00:42:32.179  - error: host.iobroker instance system.adapter.hm-rega.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-23 00:42:32.179  - info: host.iobroker Restart adapter system.adapter.hm-rega.0 because enabled
                      2023-10-23 00:42:32.300  - info: host.iobroker instance system.adapter.hm-rpc.0 started with pid 144084
                      2023-10-23 00:42:33.298  - info: host.iobroker instance system.adapter.javascript.0 started with pid 144096
                      2023-10-23 00:42:33.541  - error: hm-rpc.0 (144084) hm-rpc.0 already running
                      2023-10-23 00:42:33.542  - warn: hm-rpc.0 (144084) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-23 00:42:33.761  - info: host.iobroker instance system.adapter.sql.0 started with pid 144103
                      2023-10-23 00:42:34.153  - error: host.iobroker instance system.adapter.hm-rpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-23 00:42:34.153  - info: host.iobroker Restart adapter system.adapter.hm-rpc.0 because enabled
                      2023-10-23 00:42:35.024  - info: javascript.0 (144096) starting. Version 7.1.4 (non-npm: ioBroker/ioBroker.javascript) in /opt/iobroker/node_modules/iobroker.javascript, node: v18.18.2, js-controller: 5.0.12
                      2023-10-23 00:42:35.086  - info: sql.0 (144103) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.sql, node: v18.18.2, js-controller: 5.0.12
                      2023-10-23 00:42:36.289  - info: host.iobroker instance system.adapter.hm-rpc.1 started with pid 144126
                      2023-10-23 00:42:37.002  - error: hm-rpc.1 (144126) hm-rpc.1 already running
                      2023-10-23 00:42:37.003  - warn: hm-rpc.1 (144126) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-23 00:42:37.584  - error: host.iobroker instance system.adapter.hm-rpc.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-23 00:42:37.585  - info: host.iobroker Restart adapter system.adapter.hm-rpc.1 because enabled
                      ... hier zahlreiche sql Einträge ...
                      2023-10-23 00:42:38.329  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.Meter_eingespeist, Alias=false, 354 points now activated
                      2023-10-23 00:42:38.329  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.Haus_Verbrauch, Alias=false, 355 points now activated
                      2023-10-23 00:42:38.329  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.seit_Anfang.Leistung_alt, Alias=false, 356 points now activated
                      2023-10-23 00:42:38.329  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.seit_Anfang.Leistung_neu, Alias=false, 357 points now activated
                      2023-10-23 00:42:38.329  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.seit_Anfang.Leistung_alt_neu, Alias=false, 358 points now activated
                      2023-10-23 00:42:38.329  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.seit_Anfang.Meter_bezogen, Alias=false, 359 points now activated
                      2023-10-23 00:42:38.330  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.seit_Anfang.Meter_eingespeist, Alias=false, 360 points now activated
                      2023-10-23 00:42:38.330  - info: sql.0 (144103) enabled logging of javascript.0.Geräte.Photovoltaik.Auswertung.Jahr_Hochrechnung.seit_Anfang.Haus_Verbrauch, Alias=false, 361 points now activated
                      2023-10-23 00:42:38.855  - info: javascript.0 (144096) requesting all states
                      2023-10-23 00:42:38.856  - info: javascript.0 (144096) requesting all objects
                      2023-10-23 00:42:39.791  - info: host.iobroker instance system.adapter.telegram.0 started with pid 144137
                      2023-10-23 00:42:40.063  - info: javascript.0 (144096) received all objects
                      2023-10-23 00:42:40.079  - info: host.iobroker instance system.adapter.telegram.1 started with pid 144144
                      2023-10-23 00:42:40.608  - info: javascript.0 (144096) received all states
                      2023-10-23 00:42:40.649  - info: host.iobroker instance system.adapter.hm-rpc.2 started with pid 144155
                      2023-10-23 00:42:41.765  - error: hm-rpc.2 (144155) hm-rpc.2 already running
                      2023-10-23 00:42:41.767  - warn: hm-rpc.2 (144155) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2023-10-23 00:42:41.850  - info: telegram.0 (144137) starting. Version 1.16.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.18.2, js-controller: 5.0.12
                      2023-10-23 00:42:42.739  - error: host.iobroker instance system.adapter.hm-rpc.2 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2023-10-23 00:42:42.739  - info: host.iobroker Restart adapter system.adapter.hm-rpc.2 because enabled
                      2023-10-23 00:42:42.903  - info: telegram.1 (144144) starting. Version 1.16.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.18.2, js-controller: 5.0.12
                      2023-10-23 00:42:44.026  - info: host.iobroker instance system.adapter.javascript.1 started with pid 144178
                      2023-10-23 00:42:44.328  - info: host.iobroker instance scheduled system.adapter.ical.0 0,15,30,45 * * * *
                      2023-10-23 00:42:44.358  - info: host.iobroker instance system.adapter.ical.0 started with pid 144185
                      2023-10-23 00:42:45.762  - info: javascript.1 (144178) starting. Version 7.1.4 (non-npm: ioBroker/ioBroker.javascript) in /opt/iobroker/node_modules/iobroker.javascript, node: v18.18.2, js-controller: 5.0.12
                      2023-10-23 00:42:46.177  - info: ical.0 (144185) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.12
                      2023-10-23 00:42:46.424  - info: javascript.1 (144178) requesting all states
                      2023-10-23 00:42:46.425  - info: javascript.1 (144178) requesting all objects
                      2023-10-23 00:42:46.938  - info: ical.0 (144185) processing URL: Märkte https://calendar.google.com/calendar/ical/mn7fmslmdftdee289a43jfk2p4%40group.calendar.google.com/private-a1b9d16955e1b026c97c9163f08d34a9/basic.ics
                      2023-10-23 00:42:47.310  - info: javascript.0 (144096) Start javascript script.js.Scripte.Countdown.Countdown_-_Boost-Arbeitszimmer
                      2023-10-23 00:42:47.524  - info: ical.0 (144185) processing URL: Müll https://calendar.google.com/calendar/ical/4v99ckgc7cn8ds7lifi58gq97o%40group.calendar.google.com/private-3fcd3288d403e0dd210afc8b4eec7699/basic.ics
                      2023-10-23 00:42:47.641  - info: javascript.1 (144178) received all objects
                      2023-10-23 00:42:47.940  - info: host.iobroker instance system.adapter.sql.1 started with pid 144208
                      2023-10-23 00:42:48.031  - info: javascript.1 (144178) received all states
                      2023-10-23 00:42:48.074  - info: ical.0 (144185) processing URL: Google https://calendar.google.com/calendar/ical/d.mueller3005%40googlemail.com/private-068d61660f2427d2f71024c407325b7c/basic.ics
                      2023-10-23 00:42:48.306  - info: host.iobroker instance system.adapter.komoot.0 started with pid 144215
                      2023-10-23 00:42:49.421  - info: sql.1 (144208) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.sql, node: v18.18.2, js-controller: 5.0.12
                      2023-10-23 00:42:49.669  - info: sql.1 (144208) Connected to sqlite
                      2023-10-23 00:42:52.298  - info: host.iobroker instance system.adapter.mihome-vacuum.0 started with pid 144230
                      2023-10-23 00:42:52.565  - info: host.iobroker instance system.adapter.influxdb.0 started with pid 144244
                      ca. 00:17, es kommt dann "disconnect system.user.admin"
                      von 00:17 bis 00:41 keine Einträge im log
                      ab 00:41; jede Menge error von den versch. Adaptern
                      dann werden die Instanzen neu gestartet (wo aber immer steht: already running)
                      ab 00:42 die ganzen sql Einträge, zigbee, etc.
                      dann läuft es wieder.
                      Anbei auch mal ein iob diag
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                      Static hostname: iobroker
                      Icon name: computer-vm
                      Chassis: vm
                      Virtualization: kvm
                      Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 5.10.0-25-amd64
                      Architecture: x86-64
                      model name : Common KVM processor
                      Docker : false
                      Virtualization : kvm
                      Kernel : x86_64
                      Userland : amd64
                      Systemuptime and Load:
                      08:18:12 up 2 days, 5:07, 1 user, load average: 2.33, 2.25, 2.17
                      CPU threads: 8
                      *** Time and Time Zones ***
                      Local time: Mon 2023-10-23 08:18:12 CEST
                      Universal time: Mon 2023-10-23 06:18:12 UTC
                      RTC time: Mon 2023-10-23 06:18:13
                      NTP service: active
                      RTC in local TZ: no
                      *** User and Groups ***
                      dieter
                      /home/dieter
                      dieter cdrom floppy sudo audio dip video plugdev netdev iobroker
                      *** X-Server-Setup ***
                      X-Server: false
                      Desktop:
                      Terminal: tty
                      Boot Target: graphical.target
                      *** MEMORY ***
                      total used free shared buff/cache available
                      Mem: 5.9G 4.7G 556M 0.0K 632M 956M
                      Swap: 974M 36M 938M
                      Total: 6.9G 4.8G 1.5G
                           5928 M total memory
                           4740 M used memory
                            262 M active memory
                           4805 M inactive memory
                            556 M free memory
                             89 M buffer memory
                            542 M swap cache
                            974 M total swap
                             36 M used swap
                            938 M free swap
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** FILESYSTEM ***
                      Filesystem Type Size Used Avail Use% Mounted on
                      udev devtmpfs 2.9G 0 2.9G 0% /dev
                      tmpfs tmpfs 593M 524K 593M 1% /run
                      /dev/sda1 ext4 31G 14G 16G 46% /
                      tmpfs tmpfs 2.9G 0 2.9G 0% /dev/shm
                      tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock
                      //192.168.243.100/1_Sound cifs 238G 124G 115G 52% /mnt
                      tmpfs tmpfs 593M 0 593M 0% /run/user/1000
                      [Sat Oct 21 03:10:38 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                      [Sat Oct 21 03:10:45 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                      [Mon Oct 23 00:41:14 2023] ext4_filemap_fault+0x2d/0x50 [ext4]
                      Show mounted filesystems (real ones only):
                      TARGET SOURCE FSTYPE OPTIONS
                      / /dev/sda1 ext4 rw,relatime,errors=remount-ro
                      `-/mnt //192.168.243.100/1_Sound cifs rw,relatime,vers=3.1.1,cache=strict,username=dieter,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.243.100,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
                      /var:
                      1.5G /var/
                      874M /var/log
                      857M /var/log/journal/dd59139b4ae040898d227e04f86103f0
                      443M /var/cache
                      Archived and active journals take up 152.0M in the file system.
                      /opt/iobroker/backups:
                      2.9G /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      3.3G /opt/iobroker/iobroker-data/
                      2.5G /opt/iobroker/iobroker-data/sqlite
                      624M /opt/iobroker/iobroker-data/files
                      303M /opt/iobroker/iobroker-data/files/vis.0
                      248M /opt/iobroker/iobroker-data/files/vis.0/wav
                      1.1G /opt/iobroker/iobroker-data/sqlite/sqlite202301.db
                      948M /opt/iobroker/iobroker-data/sqlite/sqlitealt202207.db
                      235M /opt/iobroker/iobroker-data/sqlite/sqlite.db
                      201M /opt/iobroker/iobroker-data/sqlite/sqlite202303.db
                      154M /opt/iobroker/iobroker-data/files/vis.0/wav/starker-regen-mit-gewitter-im.wav
                      USB-Devices by-id:
                      USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
                      find: '/dev/serial/by-id/': No such file or directory
                      *** NodeJS-Installation ***
                      /usr/bin/node v18.18.2
                      /usr/bin/npm 9.8.1
                      /usr/bin/npx 9.8.1
                      /usr/bin/corepack 0.19.0
                      nodejs:
                      Installed: 18.18.2-1nodesource1
                      Candidate: 18.18.2-1nodesource1
                      Version table:
                      *** 18.18.2-1nodesource1 1001
                      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                      100 /var/lib/dpkg/status
                      18.18.1-1nodesource1 1001
                      18.18.0-1nodesource1 1001
                      18.17.1-1nodesource1 1001
                      18.17.0-1nodesource1 1001
                      18.16.1-1nodesource1 1001
                      18.16.0-1nodesource1 1001
                      18.15.0-1nodesource1 1001
                      18.14.2-1nodesource1 1001
                      18.14.1-1nodesource1 1001
                      18.14.0-1nodesource1 1001
                      18.13.0-1nodesource1 1001
                      18.12.0-1nodesource1 1001
                      18.11.0-1nodesource1 1001
                      18.10.0-1nodesource1 1001
                      18.9.1-1nodesource1 1001
                      18.9.0-1nodesource1 1001
                      18.8.0-1nodesource1 1001
                      18.7.0-1nodesource1 1001
                      18.6.0-1nodesource1 1001
                      18.5.0-1nodesource1 1001
                      18.4.0-1nodesource1 1001
                      18.3.0-1nodesource1 1001
                      18.2.0-1nodesource1 1001
                      18.1.0-1nodesource1 1001
                      18.0.0-1nodesource1 1001
                      12.22.12~dfsg-1~deb11u4 500
                      500 http://deb.debian.org/debian bullseye/main amd64 Packages
                      500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                      No problems detected
                      Errors in npm tree:
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States type: jsonl
                      Core adapters versions
                      admin: 6.10.1
                      javascript: 7.1.4
                      Adapters from github: 13
                      Adapter State
                      • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        system.adapter.alias-manager.0 : alias-manager : iobroker - disabled
                      • system.adapter.asterisk.0 : asterisk : iobroker - enabled, port: 5038
                      • system.adapter.backitup.0 : backitup : iobroker - enabled
                      • system.adapter.bmw.0 : bmw : iobroker - enabled
                      • system.adapter.bosch-ebike.0 : bosch-ebike : iobroker - enabled
                      • system.adapter.cloud.0 : cloud : iobroker - enabled
                      • system.adapter.contact.0 : contact : iobroker - enabled, port: 8096
                        system.adapter.daswetter.0 : daswetter : iobroker - enabled
                        system.adapter.doorio.0 : doorio : iobroker - disabled, port: 4444
                        system.adapter.dwd.0 : dwd : iobroker - enabled
                      • system.adapter.email.0 : email : iobroker - enabled
                        system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker - disabled
                        system.adapter.feiertage.0 : feiertage : iobroker - enabled
                        system.adapter.flot.0 : flot : iobroker - disabled
                      • system.adapter.fritzbox.0 : fritzbox : iobroker - enabled
                      • system.adapter.fritzdect.0 : fritzdect : iobroker - enabled
                      • system.adapter.hm-rega.0 : hm-rega : iobroker - enabled
                      • system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 0
                      • system.adapter.hm-rpc.1 : hm-rpc : iobroker - enabled, port: 0
                      • system.adapter.hm-rpc.2 : hm-rpc : iobroker - enabled, port: 0
                        system.adapter.ical.0 : ical : iobroker - enabled
                        system.adapter.icons-material-png.0 : icons-material-png : iobroker - disabled
                        system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker - disabled
                        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker - disabled
                      • system.adapter.imap.0 : imap : iobroker - enabled
                      • system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086
                      • system.adapter.javascript.0 : javascript : iobroker - enabled
                      • system.adapter.javascript.1 : javascript : iobroker - enabled
                      • system.adapter.komoot.0 : komoot : iobroker - enabled
                      • system.adapter.libre.0 : libre : iobroker - enabled
                        system.adapter.linux-control.0 : linux-control : iobroker - disabled
                      • system.adapter.logparser.0 : logparser : iobroker - enabled
                      • system.adapter.mbus.0 : mbus : Pi-Strom-Wasser - enabled, port: 3493
                      • system.adapter.mihome-vacuum.0 : mihome-vacuum : iobroker - enabled, port: 54321
                        system.adapter.mihome.0 : mihome : iobroker - disabled, port: 9898, bind: 192.168.243.12
                      • system.adapter.modbus.0 : modbus : iobroker - enabled
                        system.adapter.modbus.1 : modbus : iobroker - disabled
                      • system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 0.0.0.0
                      • system.adapter.mqtt.2 : mqtt : iobroker - enabled, port: 1885, bind: 0.0.0.0
                      • system.adapter.musiccast.0 : musiccast : iobroker - enabled
                      • system.adapter.octoprint.0 : octoprint : iobroker - enabled
                      • system.adapter.openligadb.0 : openligadb : iobroker - enabled
                      • system.adapter.parser.0 : parser : iobroker - enabled
                      • system.adapter.ping.0 : ping : iobroker - enabled
                      • system.adapter.pollenflug.0 : pollenflug : iobroker - enabled
                      • system.adapter.proxmox.0 : proxmox : iobroker - enabled, port: 8006
                        system.adapter.rest-api.0 : rest-api : iobroker - disabled, port: 8093, bind: 0.0.0.0, run as: admin
                      • system.adapter.rssfeed.0 : rssfeed : iobroker - enabled
                      • system.adapter.sayit.2 : sayit : iobroker - enabled
                      • system.adapter.sayit.3 : sayit : iobroker - enabled
                      • system.adapter.sayit.4 : sayit : iobroker - enabled
                        system.adapter.shelly.0 : shelly : iobroker - disabled, port: 1882, bind: 0.0.0.0
                      • system.adapter.simple-api.0 : simple-api : iobroker - enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      • system.adapter.smartmeter.0 : smartmeter : Pi-Strom-Wasser - enabled
                      • system.adapter.smartmeter.1 : smartmeter : Pi-Strom-Wasser - enabled
                      • system.adapter.sourceanalytix.0 : sourceanalytix : iobroker - enabled
                      • system.adapter.sql.0 : sql : iobroker - enabled, port: 3306
                      • system.adapter.sql.1 : sql : iobroker - enabled
                      • system.adapter.tankerkoenig.0 : tankerkoenig : iobroker - enabled
                      • system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0
                      • system.adapter.telegram.1 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0
                      • system.adapter.tr-064.0 : tr-064 : iobroker - enabled
                      • system.adapter.tuya.0 : tuya : iobroker - enabled
                      • system.adapter.viessmann.0 : viessmann : iobroker - enabled, port: 3002
                        system.adapter.vis-bars.0 : vis-bars : iobroker - enabled
                        system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobroker - enabled
                        system.adapter.vis-colorpicker.0 : vis-colorpicker : iobroker - enabled
                        system.adapter.vis-google-fonts.0 : vis-google-fonts : iobroker - enabled
                        system.adapter.vis-history.0 : vis-history : iobroker - enabled
                        system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker - enabled
                      • system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - enabled
                        system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobroker - enabled
                        system.adapter.vis-justgage.0 : vis-justgage : iobroker - enabled
                        system.adapter.vis-map.0 : vis-map : iobroker - enabled
                        system.adapter.vis-metro.0 : vis-metro : iobroker - enabled
                        system.adapter.vis-players.0 : vis-players : iobroker - enabled
                        system.adapter.vis-plumb.0 : vis-plumb : iobroker - enabled
                        system.adapter.vis-rgraph.0 : vis-rgraph : iobroker - enabled
                        system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - enabled
                        system.adapter.vis-weather.0 : vis-weather : iobroker - enabled
                        system.adapter.vis.0 : vis : iobroker - enabled
                      • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        system.adapter.wiobrowser.0 : wiobrowser : iobroker - disabled, port: 5000
                      • system.adapter.wled.0 : wled : iobroker - enabled
                      • system.adapter.ws.0 : ws : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin
                      • system.adapter.yamaha.0 : yamaha : iobroker - enabled
                      • system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: tcp://192.168.243.114:6638
                      • instance is alive
                      ioBroker-Repositories
                      stable : http://download.iobroker.net/sources-dist.json
                      beta : http://download.iobroker.net/sources-dist-latest.json
                      Active repo(s): stable
                      Installed ioBroker-Instances
                      Used repository: stable
                      Adapter "admin" : 6.10.1 , installed 6.10.1
                      Adapter "alias-manager": 1.2.6 , installed 1.2.6
                      Adapter "asterisk" : 1.0.6 , installed 1.0.6
                      Adapter "backitup" : 2.8.1 , installed 2.8.1
                      Adapter "bmw" : 2.5.7 , installed 2.6.1
                      Adapter "bosch-ebike" : 0.0.3 , installed 0.0.3
                      Adapter "cloud" : 4.4.1 , installed 4.4.1
                      Adapter "daswetter" : 3.1.10 , installed 3.1.10
                      Adapter "doorio" : 2.1.4 , installed 2.1.4
                      Adapter "dwd" : 2.8.5 , installed 2.8.5
                      Adapter "email" : 1.2.0 , installed 1.2.0
                      Adapter "feiertage" : 1.1.4 , installed 1.1.4
                      Adapter "flot" : 1.12.0 , installed 1.12.0
                      Adapter "fritzbox" : 0.5.0 , installed 0.5.0
                      Adapter "fritzdect" : 2.3.1 , installed 2.3.1
                      Adapter "hm-rega" : 3.0.47 , installed 3.0.47
                      Adapter "hm-rpc" : 1.15.19 , installed 1.15.19
                      Adapter "ical" : 1.13.3 , installed 1.13.3
                      Adapter "icons-material-png": 0.1.0, installed 0.1.0
                      Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0
                      Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                      Adapter "imap" : 0.1.1 , installed 0.1.1
                      Adapter "influxdb" : 3.2.0 , installed 3.2.0
                      Adapter "javascript" : 7.1.4 , installed 7.1.4
                      Controller "js-controller": 5.0.12 , installed 5.0.12
                      Adapter "libre" : 0.0.4 , installed 0.0.5
                      Adapter "linux-control": 1.1.5 , installed 1.1.5
                      Adapter "logparser" : 2.2.0 , installed 2.2.0
                      Adapter "mihome" : 1.4.0 , installed 1.4.0
                      Adapter "mihome-vacuum": 4.0.0 , installed 4.0.0
                      Adapter "modbus" : 5.0.11 , installed 5.0.11
                      Adapter "mqtt" : 4.1.1 , installed 4.1.1
                      Adapter "musiccast" : 1.1.3 , installed 1.1.3
                      Adapter "octoprint" : 4.0.0 , installed 4.0.0
                      Adapter "openligadb" : 1.2.4 , installed 1.3.4
                      Adapter "parser" : 1.3.2 , installed 1.3.2
                      Adapter "ping" : 1.6.2 , installed 1.6.2
                      Adapter "pollenflug" : 1.0.6 , installed 1.0.6
                      Adapter "proxmox" : 1.3.5 , installed 1.3.5
                      Adapter "rest-api" : 1.1.0 , installed 1.1.0
                      Adapter "rssfeed" : 2.6.1 , installed 2.6.1
                      Adapter "sayit" : 3.0.5 , installed 3.0.5
                      Adapter "shelly" : 6.4.1 , installed 6.4.1
                      Adapter "simple-api" : 2.7.2 , installed 2.7.2
                      Adapter "socketio" : 6.5.5 , installed 6.5.5
                      Adapter "sql" : 2.2.0 , installed 2.2.0
                      Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7
                      Adapter "telegram" : 1.16.0 , installed 1.16.0
                      Adapter "tr-064" : 4.2.18 , installed 4.2.18
                      Adapter "tuya" : 3.14.2 , installed 3.14.2
                      Adapter "viessmann" : 1.4.4 , installed 1.4.4
                      Adapter "vis" : 1.4.16 , installed 1.4.16
                      Adapter "vis-bars" : 0.1.4 , installed 0.1.4
                      Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1
                      Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3
                      Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4
                      Adapter "vis-history" : 1.0.0 , installed 1.0.0
                      Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0
                      Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3
                      Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
                      Adapter "vis-justgage" : 1.0.2 , installed 1.0.2
                      Adapter "vis-map" : 1.0.4 , installed 1.0.4
                      Adapter "vis-metro" : 1.2.0 , installed 1.2.0
                      Adapter "vis-players" : 0.1.6 , installed 0.1.6
                      Adapter "vis-plumb" : 1.0.2 , installed 1.0.2
                      Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2
                      Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
                      Adapter "vis-weather" : 2.5.6 , installed 2.5.6
                      Adapter "web" : 6.1.2 , installed 6.1.10
                      Adapter "wiobrowser" : 2.0.2 , installed 2.0.2
                      Adapter "wled" : 0.7.1 , installed 0.7.1
                      Adapter "ws" : 2.5.5 , installed 2.5.8
                      Adapter "yamaha" : 0.5.3 , installed 0.5.3
                      Adapter "zigbee" : 1.8.23 , installed 1.8.23
                      Objects and States
                      Objects: 24077
                      States: 19957
                      Hit:1 http://deb.debian.org/debian bullseye InRelease
                      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 0
                      *** Listening Ports ***
                      Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
                      tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 12649 428/sshd: /usr/sbin
                      tcp 0 0 192.168.243.15:2010 0.0.0.0:* LISTEN 1001 2957748 144381/io.hm-rpc.2
                      tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 2957903 144489/io.mqtt.0
                      tcp 0 0 0.0.0.0:1885 0.0.0.0:* LISTEN 1001 2958840 144522/io.mqtt.2
                      tcp 0 0 192.168.243.15:8701 0.0.0.0:* LISTEN 1001 2957707 144348/io.hm-rpc.1
                      tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1001 2952129 143903/iobroker.js-
                      tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 2952108 143903/iobroker.js-
                      tcp 0 0 0.0.0.0:5038 0.0.0.0:* LISTEN 108 11887 404/asterisk
                      tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 2992 1/init
                      tcp 0 0 192.168.243.15:2001 0.0.0.0:* LISTEN 1001 2957697 144322/io.hm-rpc.0
                      tcp6 0 0 :::8084 :::* LISTEN 1001 2961066 145385/io.ws.0
                      tcp6 0 0 :::22 :::* LISTEN 0 12651 428/sshd: /usr/sbin
                      tcp6 0 0 :::8087 :::* LISTEN 1001 2962915 145245/io.simple-ap
                      tcp6 0 0 :::111 :::* LISTEN 0 12368 1/init
                      tcp6 0 0 :::8081 :::* LISTEN 1001 2957336 144020/io.admin.0
                      tcp6 0 0 :::8082 :::* LISTEN 1001 2961012 145364/io.web.0
                      udp 0 0 0.0.0.0:68 0.0.0.0:* 0 11706 356/dhclient
                      udp 0 0 0.0.0.0:111 0.0.0.0:* 0 11535 1/init
                      udp 0 0 0.0.0.0:41100 0.0.0.0:* 1001 2962835 145013/io.musiccast
                      udp 0 0 0.0.0.0:53421 0.0.0.0:* 1001 2957823 144429/io.mihome-va
                      udp 0 0 0.0.0.0:4569 0.0.0.0:* 108 11896 404/asterisk
                      udp 0 0 0.0.0.0:5060 0.0.0.0:* 108 11897 404/asterisk
                      udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 2963619 145563/io.wled.0
                      udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 2956072 144612/io.tuya.0
                      udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 2956073 144612/io.tuya.0
                      udp 0 0 0.0.0.0:57049 0.0.0.0:* 108 14033 404/asterisk
                      udp6 0 0 :::111 :::* 0 230 1/init
                      udp6 0 0 :::55284 :::* 108 14034 404/asterisk
                      2023-10-23 08:18:51.849 - info: javascript.0 (144096) script.js.Scripte.Geraete.Kombisensor: Auslöser Duration geändert
                      2023-10-23 08:19:05.002 - info: javascript.0 (144096) script.js.Scripte.Geraete.Photovoltaik_2012: Auslöser: Schedule
                      2023-10-23 08:19:05.003 - info: javascript.0 (144096) script.js.Scripte.Geraete.Photovoltaik_2012: Piko 5.5 auslesen
                      2023-10-23 08:19:05.515 - info: javascript.0 (144096) script.js.Scripte.Geraete.Photovoltaik_2012: Leistung aktuell= 53 W // Tagesleistung= 0.01 kWh // Leistung alt gesamt= 56011 kWh // Leistung Strang 1= 36 W // Leistung Strang 2= 17 W
                      2023-10-23 08:19:06.003 - info: javascript.0 (144096) script.js.Scripte.Geraete.Photovoltaik_2023: Leistung: alt = 53 W ; neu = 98 W ; alt+neu = 151 W
                      2023-10-23 08:19:06.003 - info: javascript.0 (144096) script.js.Scripte.Geraete.Photovoltaik_2023: Batterie: 113 W ; Netz: -912 W ; Haus-Verbrauch: -950 W
                      2023-10-23 08:19:06.003 - info: javascript.0 (144096) script.js.Scripte.Geraete.Photovoltaik_2023: Tagesleistung Heute: alt = 0.01 kWh ; neu = 0.04 kWh ; alt+neu = 0.05 kWh
                      2023-10-23 08:19:09.294 - warn: modbus.0 (144459) Poll error count: 1 code: "App Timeout"
                      2023-10-23 08:19:15.479 - info: admin.0 (144020) <== Disconnect system.user.admin from ::ffff:192.168.243.100 admin
                      2023-10-23 08:19:15.551 - info: admin.0 (144020) <== Disconnect system.user.admin from ::ffff:192.168.243.100 admin
                      2023-10-23 08:19:15.560 - info: admin.0 (144020) <== Disconnect system.user.admin from ::ffff:192.168.243.100 admin
                      2023-10-23 08:19:15.564 - info: admin.0 (144020) <== Disconnect system.user.admin from ::ffff:192.168.243.102 admin
                      2023-10-23 08:19:15.564 - info: admin.0 (144020) <== Disconnect system.user.admin from ::ffff:192.168.243.100 javascript
                      2023-10-23 08:19:15.724 - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.100
                      2023-10-23 08:19:17.576 - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.100
                      2023-10-23 08:19:18.177 - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.100
                      2023-10-23 08:19:18.178 - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.102
                      2023-10-23 08:19:18.195 - info: admin.0 (144020) ==> Connected system.user.admin from ::ffff:192.168.243.100
                      2023-10-23 08:19:20.348 - info: javascript.0 (144096) script.js.Scripte.Licht.Flur1_EG: Helligkeit = 34; Dimmer Flur 1 EG auf 40% eingeschaltet.
                      2023-10-23 08:19:20.468 - info: javascript.0 (144096) script.js.Scripte.Licht.Kueche_Vorratsraum: Helligkeit = 34; Licht Küche Vorratsraum eingeschaltet.
                      2023-10-23 08:19:21.160 - info: javascript.0 (144096) script.js.Scripte.Geraete.Wemos: Auslöser: SV Homeduino Barometer Tränke geändert
                      2023-10-23 08:19:32.286 - info: octoprint.0 (145079) error EHOSTUNREACH from /api/version: connect EHOSTUNREACH 192.168.243.139:80
                      2023-10-23 08:19:41.084 - info: mihome-vacuum.0 (144429) trigger cleaning segment 17
                      2023-10-23 08:19:41.512 - info: javascript.0 (144096) script.js.Scripte.Licht.Bad_EG: Licht Bad EG nicht ausgeschaltet. Erneute Prüfung nach 2 min.
                      2023-10-23 08:19:44.163 - info: octoprint.0 (145079) error ECONNABORTED from /api/version: timeout of 2000ms exceeded
                      [/s]
                      und summary
                      [s=]
                      v.2023-10-10
                      Chassis: vm
                      Virtualization: kvm
                      Installation: kvm
                      Kernel: x86_64
                      Userland: amd64
                      Timezone: Europe/Berlin (CEST, +0200)
                      User-ID: 1000
                      X-Server: false
                      Pending OS-Updates: 0
                      Pending iob updates: 0
                      Nodejs-Installation: /usr/bin/nodejs v18.18.2
                      /usr/bin/npm 9.8.1
                      /usr/bin/npx 9.8.1
                      Recommended versions are nodejs 18.18.2 and npm 9.8.1
                      MEMORY:
                      Mem: 5.9G 4.8G 588M 0.0K 543M 881M
                      Swap: 974M 202M 772M
                      Total: 6.9G 5.0G 1.4G
                      Active iob-Instances: 56
                      ioBroker Core: js-controller 5.0.12
                      admin 6.10.1
                      ioBroker Status: iobroker is running on this host.
                      Objects type: jsonl
                      States type: jsonl
                      Objects: 24077
                      States: 19957
                      Size of iob-Database:
                      51M /opt/iobroker/iobroker-data/objects.jsonl
                      28M /opt/iobroker/iobroker-data/states.jsonl
                      [/s]
                      Hat jemand ne Idee ?
                      mfg
                      Dieter
                      @bahnuhr
                      kann das sein, dass du um diese Uhrzeit ein Backup machst, und daher die Dateien nicht geschrieben werden koennen?
                        @bahnuhr
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        @ilovegym sagte in iob stürzt ab und startet dann neu:
                        ja, backitup macht da backup.
                        Kann aber doch eigentlich nicht sein, dass backitup das System zum Absturz bringt, oder doch ?
                        Danke.
                        arteckA Thomas BraunT 2 Antworten Letzte Antwort
                        • arteckA arteck
                          machmal bitte
                          iob fix
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          @arteck sagte in iob stürzt ab und startet dann neu:
                          erledigt.
                          Sind jetzt erheblich kleiner.
                          Danke.
                          • bahnuhrB bahnuhr
                            arteckA Offline
                            arteckA Offline
                            arteck
                            druckmal und schaun nach
                            bahnuhrB 2 Antworten Letzte Antwort
                            • bahnuhrB bahnuhr
                              Hängt halt davon ab, wieviele Ressourcen da zur Verfügung stehen und wie fett das Backup ist.
                                bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                @thomas-braun sagte in iob stürzt ab und startet dann neu:
                                proxmox VM
                                32 GB bootdisk-Größe
                                6 GB Ram zugewiesen.
                                Müsste doch eigentlich reichen, oder ?
                                Danke.
                                Thomas BraunT ? ? 3 Antworten Letzte Antwort
                                • arteckA arteck
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  @arteck
                                  gestartet,
                                  schaun wir mal.
                                  Danke.
                                  • bahnuhrB bahnuhr
                                    proxmox VM
                                    Kann man so pauschal nicht sagen.
                                    Wenn ich mir die Frequenz anschaue, mit der da z. B. irgendwelche Logs gespeichert werden...
                                      bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      Was meinst du damit?
                                      Achte eigentlich immer darauf, nicht irgendwas im Sekundentakt zu machen.
                                      Danke.
                                      • arteckA arteck
                                        bahnuhrB Online
                                        bahnuhrB Online
                                        bahnuhr
                                        @arteck
                                        backitup einwandfrei durchgelaufen.
                                        Dateien sind erzeugt.
                                        Danke.
                                        • bahnuhrB bahnuhr
                                          Skript v.2023-10-10
                                          *** BASE SYSTEM ***
                                          Chassis: vm
                                          Virtualization: kvm
                                          Docker : false
                                          Kernel : x86_64
                                          Userland : amd64
                                          CPU threads: 8
                                          NTP service: active
                                          RTC in local TZ: no
                                          dieter
                                          /home/dieter
                                          X-Server: false
                                          Desktop:
                                          Terminal: tty
                                          *** MEMORY ***
                                          Swap: 974M 36M 938M
                                               5928 M total memory
                                               4740 M used memory
                                                262 M active memory
                                                556 M free memory
                                                 89 M buffer memory
                                                542 M swap cache
                                                974 M total swap
                                                 36 M used swap
                                                938 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          1.5G /var/
                                          874M /var/log
                                          443M /var/cache
                                          USB-Devices by-id:
                                          /usr/bin/npm 9.8.1
                                          /usr/bin/npx 9.8.1
                                          nodejs:
                                          Version table:
                                          Errors in npm tree:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States type: jsonl
                                          admin: 6.10.1
                                          javascript: 7.1.4
                                          Adapter State
                                          • instance is alive
                                          Objects and States
                                          Objects: 24077
                                          States: 19957
                                          Pending Updates: 0
                                          [/s]
                                          und summary
                                          [s=]
                                          v.2023-10-10
                                          Chassis: vm
                                          Virtualization: kvm
                                          Installation: kvm
                                          Kernel: x86_64
                                          Userland: amd64
                                          User-ID: 1000
                                          X-Server: false
                                          /usr/bin/npm 9.8.1
                                          /usr/bin/npx 9.8.1
                                          MEMORY:
                                          admin 6.10.1
                                          Objects type: jsonl
                                          States type: jsonl
                                          Objects: 24077
                                          States: 19957
                                          [/s]
                                          mfg
                                          Dieter
                                          Moin,
                                          zu dem Zeitpunkt, an dem Du das iob diag durchgeführt hast, standen nur ~650 MB freier Speicher zur Verfügung, wenn das auch zu den Zeiten des Backups passiert, kann es sein, dass alle Dateien, die das Backup einsammelt, nicht in den freien Speicher passen und etwas geht krachen, dass der kernel etwas aus dem Speicher kickt.
                                          Wenn Du ein Monitoring am Laufen hast, dann beobachte mal den Speicherverbrauch zu den Zeiten des Backups und wie @arteck schon anmerkte, die Objekte und States mal komprimieren lassen iob fix
                                              Database maintenance (4/5)
                                          Checking for uncompressed JSONL databases... This might take a while!
                                          Compressing /opt/iobroker/iobroker-data/states.jsonl
                                          Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                          Compressed 2 JSONL files. Done
                                          VG
                                          Bernd
