  4. Nichts geht mehr, was tun?
    5.1k
29 Beiträge 5 Kommentatoren 3.0k Aufrufe 5 Beobachtet
  • C Creatorhs
    Das kam dabei raus:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     16:05:36 up 3 min,  1 user,  load average: 1.95, 1.80, 0.80
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Fri 2023-10-20 16:05:36 CEST
               Universal time: Fri 2023-10-20 14:05:36 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        1.3G        1.9G        1.0M        604M        2.4G
    Swap:            99M          0B         99M
    Total:          3.9G        1.3G        2.0G
             3838 M total memory
             1348 M used memory
              198 M active memory
             1653 M inactive memory
             1885 M free memory
               98 M buffer memory
              505 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
      UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
    * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
    * ifup@wlan0.service    loaded failed failed ifup for wlan0
    2 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       59G   54G  2.0G  97% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     768M  1.1M  767M   1% /run
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M   32K  384M   1% /run/user/1000
    [Fri Oct 20 16:01:55 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:A5:B1:55 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=7c6bc8cd-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Fri Oct 20 16:01:56 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Fri Oct 20 16:01:56 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Fri Oct 20 16:02:00 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Fri Oct 20 16:02:00 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Oct 20 16:02:00 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Fri Oct 20 16:02:02 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Show mounted filesystems \(real ones only\):
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    5.6G    /var/
    3.4G    /var/log
    2.1G    /var/lib
    2.0G    /var/lib/influxdb
    1.9G    /var/lib/influxdb/data/iobroker/autogen
    Archived and active journals take up 816.3M in the file system.
    /opt/iobroker/backups:
    37G     /opt/iobroker/backups/
    254M    /opt/iobroker/backups/influxDB_2023_09_30-02_40_21_backupiobroker
    119M    /opt/iobroker/backups/influxDB_2023_10_10-02_40_21_backupiobroker
    /opt/iobroker/iobroker-data:
    636M    /opt/iobroker/iobroker-data/
    379M    /opt/iobroker/iobroker-data/files
    144M    /opt/iobroker/iobroker-data/history
    87M     /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    9.9M    /opt/iobroker/iobroker-data/objects.jsonl
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    /usr/bin/corepack       0.18.0
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u4 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
    + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              - disabled
    + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
      system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
      system.adapter.habpanel.0               : habpanel              : raspberrypi                              - disabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
      system.adapter.panasonic-viera.0        : panasonic-viera       : raspberrypi                              - disabled
    + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
      system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.statistics.0             : statistics            : raspberrypi                              - disabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
    + system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
    + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
    + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "ble"          : 0.13.4   , installed 0.13.4
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "history"      : 2.2.6    , installed 2.2.6
    Adapter    "hs100"        : 2.1.2    , installed 2.1.2
    Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
    Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "scenes"       : 2.3.9    , installed 2.3.9
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects:        6461
    States:         5223
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://apt.grafana.com stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Failed to fetch https://apt.grafana.com/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:3 https://apt.grafana.com stable InRelease [5984 B]
    Get:4 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
    Err:3 https://apt.grafana.com stable InRelease
    Fetched 4586 B in 21s (221 B/s)
    Reading package lists...
    Pending Updates: 112
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      0          13851      357/connmand
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          10191      547/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          10895      507/cupsd
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        14356      512/influxd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14228      999/io.sonoff.0
    tcp        0      0 127.0.0.1:40989         0.0.0.0:*               LISTEN      1001       20422      1842/io.yahka.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14505      513/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11074      513/iobroker.js-con
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15568      834/io.admin.0
    tcp6       0      0 :::4369                 :::*                    LISTEN      0          10610      1/init
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20110      1814/io.web.0
    tcp6       0      0 :::36979                :::*                    LISTEN      1001       21083      1842/io.yahka.0
    tcp6       0      0 ::1:53                  :::*                    LISTEN      0          13855      357/connmand
    tcp6       0      0 :::8086                 :::*                    LISTEN      110        14008      512/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          10193      547/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       22627      1866/io.simple-api.
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          10894      507/cupsd
    tcp6       0      0 :::3000                 :::*                    LISTEN      111        15585      587/grafana
    udp        0      0 0.0.0.0:48669           0.0.0.0:*                           108        10126      353/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       14204      984/io.shelly.0
    udp        0      0 127.0.0.1:53            0.0.0.0:*                           0          13843      357/connmand
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14366      491/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          10923      565/cups-browsed
    udp        0      0 0.0.0.0:37503           0.0.0.0:*                           0          15454      357/connmand
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       16511      969/io.mihome-vacuu
    udp        0      0 192.168.178.24:5353     0.0.0.0:*                           1001       15067      1014/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10124      353/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          14378      491/dhcpcd
    udp6       0      0 ::1:53                  :::*                                0          13847      357/connmand
    udp6       0      0 :::5353                 :::*                                108        10125      353/avahi-daemon: r
    udp6       0      0 :::33606                :::*                                108        10127      353/avahi-daemon: r
    2023-10-20 16:07:34.423  - warn: influxdb.0 (879) Error on writePoint("{"value":7.42,"time":"2023-10-20T14:07:24.409Z","from":"system.adapter.shelly.0","q":0,"ack":true}): Error: {"error":"timeout"}
     / "{\"error\":\"timeout\"}\n""
    2023-10-20 16:07:34.423  - info: influxdb.0 (879) Add point that had error for Shelly3EM-L2 to buffer again, error-count=2
    2023-10-20 16:07:34.433  - warn: influxdb.0 (879) Error on writePoint("{"value":13.52,"time":"2023-10-20T14:07:24.410Z","from":"system.adapter.shelly.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2023-10-20 16:07:34.434  - info: influxdb.0 (879) Add point that had error for Shelly3EM-L3 to buffer again, error-count=2
    2023-10-20 16:07:30.009  - warn: javascript.0 (907)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
    2023-10-20 16:07:30.009  - warn: javascript.0 (907)     at Object.<anonymous> (script.js.common.SolarLeistungsberechnungen.Berechnung_Ertraege:6:3)
    2023-10-20 16:07:30.009  - warn: javascript.0 (907)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1617:34)
    2023-10-20 16:07:30.010  - warn: javascript.0 (907)     at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15)
    2023-10-20 16:07:30.010  - warn: javascript.0 (907)     at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28
    2023-10-20 16:07:30.010  - warn: javascript.0 (907)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7)
    2023-10-20 16:07:30.010  - warn: javascript.0 (907)     at listOnTimeout (node:internal/timers:569:17)
    2023-10-20 16:07:30.011  - warn: javascript.0 (907)     at processTimers (node:internal/timers:512:7)
    2023-10-20 16:07:30.011  - warn: javascript.0 (907) You are assigning a number to the state "0_userdata.0.HaushaltsverbrauchSeit20230510" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
    2023-10-20 16:07:30.014  - warn: javascript.0 (907)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
    2023-10-20 16:07:30.015  - warn: javascript.0 (907)     at Object.<anonymous> (script.js.common.SolarLeistungsberechnungen.Berechnung_Ertraege:8:3)
    2023-10-20 16:07:30.015  - warn: javascript.0 (907)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1617:34)
    2023-10-20 16:07:30.015  - warn: javascript.0 (907)     at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15)
    2023-10-20 16:07:30.015  - warn: javascript.0 (907)     at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28
    2023-10-20 16:07:30.015  - warn: javascript.0 (907)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7)
    2023-10-20 16:07:30.016  - warn: javascript.0 (907)     at listOnTimeout (node:internal/timers:569:17)
    2023-10-20 16:07:30.016  - warn: javascript.0 (907)     at processTimers (node:internal/timers:512:7)
    2023-10-20 16:07:30.035  - info: javascript.0 (907) State value to set for "0_userdata.0.TagesverbrauchSeit20230510" has to be type "string" but received type "number"
    2023-10-20 16:07:30.037  - info: javascript.0 (907) State value to set for "0_userdata.0.HaushaltsverbrauchSeit20230510" has to be type "string" but received type "number"
    @creatorhs sagte in Nichts geht mehr, was tun?:
    Moin,
    ob das gerade damit zu tun hat, dass Du kein Plattenplatz mehr hast, kann ich nicht sagen, aber zwei Services starten nicht korrekt
    Dann sind die Repositorien nicht gepflegt, da gab es auch vor ein paar Wochen Änderungen, die Du noch nicht nachgezogen hast
    Solange das nicht gerade gezogen ist, kannst Du keine Updates/Upgrades machen.
    VG
    Bernd
    • R reutli
      @dp20eic sagte in Nichts geht mehr, was tun?:
      Dann nutz die Coursortasten und geh mal in /opt rein.
      und, was kommt?
      Creatorhs
      @reutli
      --- /opt ----------------------------------------------------------------------------------------------------------------------------------------------------
         37,8 GiB [##########] /iobroker
          3,1 GiB [          ] /Wolfram
          4,2 MiB [          ] /minecraft-pi
          8,0 KiB [          ] /pigpio
      ? Thomas BraunT 2 Antworten Letzte Antwort
      • C Creatorhs
        @reutli
            8,0 KiB [          ] /pigpio
        @creatorhs
        Moin
        und weiter, bis es nicht mehr tiefer geht
        VG
        Bernd
        C 1 Antwort Letzte Antwort
        • C Creatorhs
          @reutli
              8,0 KiB [          ] /pigpio
          @creatorhs
          Wie schafft man es den iobroker auf 37GB zu blasen?
          Und Wolfram Alpha wird wohl auch nicht verwendet.
          Verschenkter Platz.
            @creatorhs
            Moin
            VG
            Bernd
            Creatorhs
            @dp20eic
            es sind die backups:
               36,0 GiB [##########] /backups
                1,0 GiB [          ] /node_modules
              637,0 MiB [          ] /iobroker-data
               57,9 MiB [          ]  grafana-enterprise_8.1.5_amd64.deb
               54,2 MiB [          ]  grafana-enterprise-rpi_8.1.5_armhf.deb
               28,6 MiB [          ] /log
              752,0 KiB [          ]  package-lock.json
               56,0 KiB [          ] /lib
               24,0 KiB [          ]  fix_installation.sh
               24,0 KiB [          ] /install
                8,0 KiB [          ]  README.md
                8,0 KiB [          ]  reinstall.js
                4,0 KiB [          ]  CHANGELOG_INSTALLER_LINUX.md
                4,0 KiB [          ]  package.json
                4,0 KiB [          ]  INSTALLER_INFO.txt
                4,0 KiB [          ]  LICENSE
                4,0 KiB [          ]  CHANGELOG_FIXER_LINUX.md
                4,0 KiB [          ]  iobroker
                4,0 KiB [          ]  .npmrc
            @   0,0   B [          ]  iob
            --- /opt/iobroker/backups -----------------------------------------------------------------------------------------------------------------------------------
                1,0 GiB [##########]  influxDB_2023_09_18-02_40_21_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_09_17-02_40_22_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_09_16-02_40_21_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_09_15-02_40_21_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_09_14-02_40_22_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_09_13-02_40_21_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_09_12-02_40_21_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_09_11-02_40_25_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_09_10-02_40_21_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_09_09-02_40_23_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_09_08-02_40_26_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_09_07-02_40_24_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_09_06-02_40_20_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_09_05-02_40_21_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_09_04-02_40_21_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_09_03-02_40_23_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_09_02-02_40_21_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_09_01-02_40_21_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_08_31-02_40_29_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_08_30-02_40_28_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_08_29-02_40_26_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_08_28-02_40_24_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_08_27-02_40_21_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_08_26-02_40_21_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_08_25-02_40_27_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_08_24-02_40_31_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_08_23-02_40_24_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_08_22-02_40_23_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_08_21-02_40_21_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_08_20-02_40_21_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_08_18-02_40_24_backupiobroker.tar.gz
                1,0 GiB [######### ]  influxDB_2023_08_19-02_40_24_backupiobroker.tar.gz
              967,5 MiB [######### ]  influxDB_2023_08_16-02_40_20_backupiobroker.tar.gz
              966,3 MiB [######### ]  influxDB_2023_08_15-02_40_20_backupiobroker.tar.gz
              608,3 MiB [#####     ]  influxDB_2023_09_19-02_40_21_backupiobroker.tar.gz
              606,2 MiB [#####     ]  influxDB_2023_09_24-02_40_21_backupiobroker.tar.gz
              432,5 MiB [####      ]  influxDB_2023_10_01-02_40_22_backupiobroker.tar.gz
              253,1 MiB [##        ] /influxDB_2023_09_30-02_40_21_backupiobroker
              118,7 MiB [#         ] /influxDB_2023_10_10-02_40_21_backupiobroker
                7,4 MiB [          ]  iobroker_2023_10_20-02_40_10_backupiobroker.tar.gz
            ? 1 Antwort Letzte Antwort
            • C Creatorhs
              @dp20eic
                 28,6 MiB [          ] /log
                 56,0 KiB [          ] /lib
                  4,0 KiB [          ]  LICENSE
                  4,0 KiB [          ]  .npmrc
              @   0,0   B [          ]  iob
              Moin,
              da sind ja die Speicherfresser, wie hast Du denn den Adapter BackitUP eingerichtet, machst Du nur lokal die Backups?
              Zieh Dir die mal mit sftp/scp auf einen anderen Rechner und lösche die dann auf dem RasPI.
              VG
              Bernd
              C 2 Antworten Letzte Antwort
                Moin,
                VG
                Bernd
                Creatorhs
                @dp20eic ich habe den Adapter so eingerichtet, dass die Backups auf googledrive hochgeladen werden und nicht lokal. Evtl sollte ich nachschauen, warum das scheinbar nicht mehr klappt. ich sehe gerade, dass auf googledrive das letzte backup am 18.9. hochgeladen worden ist, seitdem nicht mehr.
                  Moin,
                  VG
                  Bernd
                  Creatorhs
                  schrieb am zuletzt editiert von Creatorhs
                  @dp20eic habe jetzt einige gelöscht und es läuft alles sofort wieder.
                  komme wieder auf die grafana oberfläche als auch auf die iobroker-grafik-oberfläche.
                  Danke für eure schnelle Hilfe!
                  Ich mache mich jetzt noch an die Updates und an den BackitUp-Adapter...
                  edit: der Zugangstocken von google war weg. keine Ahnung, ob durch ein Update des Adapters oder irgendwie anders...
                  • C Creatorhs
                    @creatorhs
                    Moin,
                    Du musst dich auch um die Repositorys kümmern, https://forum.iobroker.net/topic/69333/nichts-geht-mehr-was-tun/21?_=1697810535691, denn sonst kannst du die pending updates nicht einspielen.
                    Siehe hier -> https://forum.iobroker.net/topic/67822/grafana-repo-braucht-neuen-schlüssel, ist von @Thomas-Braun gut beschrieben wie das zu machen ist.
                    VG
                    Bernd
