  4. Test Adapter Weather-Warnings
    2.6k
    4.6k
    4.0k
1.1k Beiträge 35 Kommentatoren 453.2k Aufrufe 40 Beobachtet
  • sigi234S sigi234
    @ticaki sagte in Test Adapter Weather-Warnings:
    Liegts vielleicht daran?
    Kein Haken bei mir gesetzt.
    Das drücken auf Vorlagen wiederherstellen ändert ebenfalls die Keys damit müsst ihr in allen Diensten die Vorlagen neu auswählen
    Das hatte ich mal gemacht, aber nicht neu gesetzt.
    Edit:
    Leider Nein. Ev. geht es bei einer Testwarnungen nicht?
    weather-warnings.0
    2023-10-11 18:24:23.613	debug	notificationService: [{"label":"none","value":"none"},{"label":"email.0","value":"email.0"}]
    weather-warnings.0
    2023-10-11 18:24:23.570	debug	notificationService: [{"label":"none","value":"none"},{"label":"email.0","value":"email.0"}]
    weather-warnings.0
    2023-10-11 18:24:23.542	debug	Messages: [{"label":"none","value":"none"},{"label":"addedPush","value":"addedPush"},{"label":"removePush","value":"removePush"},{"label":"removeAllPush","value":"removeAllPush"},{"label":"tableNew","value":"tableNew"},{"label":"tableRemove","value":"tableRemove"},{"label":"tableAllRemove","value":"tableAllRemove"},{"label":"addedPushSpecial","value":"addedPushSpecial"},{"label":"Test","value":"Test"}]
    weather-warnings.0
    2023-10-11 18:24:23.542	debug	Retrieve Messages from system.adapter.admin.0 message: {"command":"Messages","message":{"service":"email"},"from":"system.adapter.admin.0","callback":{"message":{"service":"email"},"id":453,"ack":false,"time":1697041463521},"_id":80207604}
    weather-warnings.0
    2023-10-11 18:24:23.541	debug	Messages: [{"label":"none","value":"none"},{"label":"addedPush","value":"addedPush"},{"label":"removePush","value":"removePush"},{"label":"removeAllPush","value":"removeAllPush"},{"label":"tableNew","value":"tableNew"},{"label":"tableRemove","value":"tableRemove"},{"label":"tableAllRemove","value":"tableAllRemove"},{"label":"addedPushSpecial","value":"addedPushSpecial"},{"label":"Test","value":"Test"}]
    Edit2
    Ich installiere mal neu
    T Nicht stören
    T Nicht stören
    ticaki
    #161
    @sigi234 sagte in Test Adapter Weather-Warnings:
    Doch auch meine sind von den Testwarnungen.
    Versuchs mal hiermit - erstmal auf info und wenn da keine neuen Ausgaben erscheinen nochmal auf Debug. Wenn dann auch nix erhellendes kommt baue ich immer mehr logs ein, bis wir wissen wo es nicht so will wie wir wollen :)
    https://github.com/ticaki/ioBroker.weather-warnings/tree/testing
    KAnnst aber auch den Email Adapter auf debug stellen und schauen obs vielleicht da klemmt
    Spenden
    • T ticaki
      sigi234S Online
      sigi234S Online
      sigi234
      #162
      @ticaki
      Instanz gelöscht, neu installiert.
      javascript.0
      2023-10-11 18:48:43.510	info	script.js.Alexa.Welcher_Dot: angesprocherner ECHO: Dot Buero
      javascript.0
      2023-10-11 18:48:41.052	info	script.js.Alexa.Welcher_Dot: angesprocherner ECHO: Dot Buero
      email.0
      2023-10-11 18:48:39.496	info	sent to xxxxxxxx@xxxxx.at
      email.0
      2023-10-11 18:48:38.481	info	Send email: {"text":"template.NewMessage","from":"xxxxxx@gmail.com","to":"xxxxxxxxxx@liwest.at","subject":"ioBroker"}
      weather-warnings.0
      2023-10-11 18:48:37.323	info	ZAMG activated. Retrieve data.
      weather-warnings.0
      2023-10-11 18:48:37.223	info	Refresh Interval: 15 minutes
      weather-warnings.0
      2023-10-11 18:48:33.124	info	starting. Version 0.3.2 (non-npm: ticaki/ioBroker.weather-warnings#a1669ccd3030d07eb7ab8a84018f7d92a78077a4) in C:/ioBroker/_iob_Test/node_modules/iobroker.weather-warnings, node: v18.18.1, js-controller: 5.0.13
      host.Test
      2023-10-11 18:48:31.411	info	instance system.adapter.weather-warnings.0 started with pid 13932
      host.Test
      2023-10-11 18:48:28.509	info	instance system.adapter.weather-warnings.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      weather-warnings.0
      2023-10-11 18:48:28.426	info	terminating
      host.Test
      2023-10-11 18:48:28.132	info	stopInstance system.adapter.weather-warnings.0 send kill signal
      Immer Daten sichern!
      • sigi234S sigi234
        @ticaki
        javascript.0
        javascript.0
        email.0
        email.0
        weather-warnings.0
        weather-warnings.0
        weather-warnings.0
        host.Test
        host.Test
        weather-warnings.0
        host.Test
        T Nicht stören
        T Nicht stören
        ticaki
        #163
        @sigi234
        1 Mal auf Vorlagen wiederherstellen klicken. Beim ersten Start stehen da die Übersetzungstokens und um diese Aufzulösen muß man einmal die Vorlagen wiederherstellen. Der Adapter läd dann zu diesen Tokens die entsprechenden Übersetzungen in eingesteller iobroker sprache.
        Spenden
        • T ticaki
          @sigi234
          sigi234S Online
          sigi234S Online
          sigi234
          #164
          @sigi234
          Ok, teste nächste Woche weiter muss Morgen ins Krankenhaus.
          • sigi234S sigi234
            @sigi234
            T Nicht stören
            T Nicht stören
            ticaki
            #165
            @sigi234
            Hoffe nichts schlimmes - gutes Gelingen und gute Besserung anschließend.
            und der Admin sieht bei der ersten Installation in Zukunft so aus:
            Spenden
            • T Nicht stören
              T Nicht stören
              ticaki
              #166
              Gibt immer wieder undokumentierte Updates - Vorallem weil ich das auf meinem produktiven System testen will, auch mit "scheinbar" sinnlosen Logausgaben.
              Änderungen unvollständig:
              • Installation verbessert. Adminkonfigurationsseite muß jetzt reloaded oder per Vorlagen zurücksetzen aktualisiert werden, jedoch sind die richtigen Vorlagen im Hintergrund schon geladen. Solange kein Reload der Seite stattgefunden hat, wird ein Hilfstext und keine Tabelle oder Hilfe zur Tabelle angezeigt.
              • Rohdaten können nach Startzeitpunkt gefiltert werden - dann werden sie sofort nach dem Eintreffen aussortiert und werden komplett ignoriert.
              Ich nähere mich der 0.4 - heißt ich ich beschäftige mich jetzt mehr mit den latest Voraussetzungen als mit dem Code. Außer es kommt schlechtes Wetter. :)
              EDIT: Könnte mal jemand die Readme gegenlesen, ob sie verständlich ist: https://github.com/ticaki/ioBroker.weather-warnings/blob/main/README.md Rechtschreibefehler hab ich schon 3 gefunden, aber das ist nur die Vorlage für die englische version.
              Spenden
              rtwlR 1 Antwort Letzte Antwort
              • T ticaki
                rtwlR Offline
                rtwlR Offline
                rtwl
                #167
                Incoming warnings...: Nach dem Adapterstart werden die beim ersten Datenabruf erhaltenen Warnungen als bekannt und lösen keine Benachrichtigung aus.
                hier stimmt der Satzbau noch nicht wirklich. Beispiel: "... als bekannt angesehen und..."
                der Rest liest sich gut und ist mMn verständlich.
                -Peter
                • Chris76eC Offline
                  Chris76eC Offline
                  Chris76e
                  #168
                  Hi, habe eine "echte" Warnung von DWD, hier wird alle 15min gewarnt und entwarnt.......
                  Kann man irgendwo was einstellen?
                  Adapter wurde eben neuinstalliert
                  T 2 Antworten Letzte Antwort
                  • Chris76eC Chris76e
                    T Nicht stören
                    T Nicht stören
                    ticaki
                    #169
                    @chris76e
                    Danke fürs benachrichtigen, ich hatte noch nicht eine echte Warnung mit dem Adapter - teste es gerade.
                    Spenden
                    • T Nicht stören
                      T Nicht stören
                      ticaki
                      #170
                      Kann es leider nicht nachvollziehen, kannst du mir mal deinen Ort übermitteln, in Kiel passiert das mit dem wiederholten benachrichten nicht. Gerne per PM, wenns geht den Ort aus den Einstellungen kopiert. Oder die Zahl... aber die kommt glaube ich nur bei Fehler und Debug im log
                      Was auch noch geht... hab ich aber noch nciht getestet, den Hacken bei Raw data oder so unten rechts bei Basiskonfiguration rein machen, 35 Minuten laufen lassen und den Inhalt des States posten. Danach wieder aus machen, das braucht mit der Zeit richtig Speicherplatz.
                      Spenden
                      Chris76eC 1 Antwort Letzte Antwort
                      • T ticaki
                        Chris76eC Offline
                        Chris76eC Offline
                        Chris76e
                        #171
                        @ticaki Kreis Heinsberg
                          T Nicht stören
                          T Nicht stören
                          ticaki
                          #172
                          @chris76e sagte in Test Adapter Weather-Warnings:
                          Aha, wollte gerade schreiben dass ich es nicht nachvollziehen und da fängt er an zu quatschen. Schaue ich mir an, in 1 h wird das wohl gefixt sein... Wäre auch zu schön wenn sich DWD an die eigenen Dokumentation hält :)
                          EDIT: Dauert etwas länger, hab mit dem Admin Update den dev-server zerschossen muß erstmal wieder alles einrichten :)
                          Spenden
                          Chris76eC 2 Antworten Letzte Antwort
                          • T ticaki
                            Chris76eC Offline
                            Chris76eC Offline
                            Chris76e
                            #173
                            @ticaki 😊
                            • T ticaki
                              Chris76eC Offline
                              Chris76eC Offline
                              Chris76e
                              #174
                              Hat eh noch Zeit, die Warnung ist ja Fr. 10:00 - Sa. 06:00
                                T Nicht stören
                                T Nicht stören
                                ticaki
                                #175
                                @chris76e
                                Wie ich es mir gedacht habe... lt Doku ist ein Update ein Update... tja nö ein Update ist einfach nur ne Meldung in der alles was zum Erkennen eines Updates herhalten könnte geändert wurde.
                                Spenden
                                • T Nicht stören
                                  T Nicht stören
                                  ticaki
                                  #176
                                  Update
                                  Doppelte Meldungen - da gehe ich sehr zurückhalten ran. Bei DWD werden jetzt alle alten Warnungen mit gleicher EC ausgefiltert und die eine neue wird still aktualisiert. Falls es also wiederholt mehrere neue mit gleicher EC gibt, sollten das wieder doppelte Meldungen ergeben, die ich dann angehe, wenn ich es auch testen kann. :)
                                  Spenden
                                  • T ticaki
                                    Update
                                    Chris76eC Offline
                                    Chris76eC Offline
                                    Chris76e
                                    #177
                                    @ticaki scheint zufunktionieren, bekomme jetzt keine neue warnungen
                                    • T Nicht stören
                                      T Nicht stören
                                      ticaki
                                      #178
                                      Kurzer Hinweis: Hab gerade rausgefunden dass das hier geht:
                                      https://github.com/ticaki/ioBroker.weather-warnings/issues/28#issuecomment-1761158794
                                      echt schön wenn was geht was nichtmal beabsichtigt war. :D
                                      Spenden
                                      • T Nicht stören
                                        T Nicht stören
                                        ticaki
                                        #179
                                        Update
                                        Vorweg scheint soweit zu laufen.
                                        • States sind nun Mehrsprachig und hab die Beschreibung verbessert. Bei einer Handvoll hab ich keine Ahnung, das steht teils da oder ich hab die Datenpunkt ID als Name drin gelassen.
                                        Auffälligkeiten:
                                        • hatte heute mit DWD 7:00 Uhr eine Entwarnungen und 10:00 Uhr einmal "removeAll" aber nur um 3:27 Uhr 1 Warnung - da muß ich mal genauer rein schauen.
                                        • Mein "Debug Datenpunkt" scheint 2. mal mit unterschiedlichen Namen zu erscheinen. Das ist so auch nicht gewollt. Ha bin auf einen falsche Beschreibung rein gefallen, das eine ist mein Debug Datenpunkt, das andere was dieses Mal an Daten von DWD gekommen ist.
                                        Spenden
                                        • T Nicht stören
                                          T Nicht stören
                                          ticaki
                                          #180
                                          Update
                                          • gibt jetzt states um Benachrichtigungen manuell auszulösen
                                          • hab im Code etwas aufgeräumt
                                          Spenden
                                          LatziL 1 Antwort Letzte Antwort
