Test Adapter Weather-Warnings
Du bist gerade hier auf Sendung, daher kein Issue:
2023-10-28 21:02:31.214 - info: weather-warnings.0 (579449) starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.weather-warnings, node: v18.18.2, js-controller: 5.0.15 2023-10-28 21:02:35.570 - info: weather-warnings.0 (579449) Refresh Interval: 15 minutes 2023-10-28 21:02:35.714 - info: weather-warnings.0 (579449) DWD activated. Retrieve data. 2023-10-28 21:02:35.720 - info: weather-warnings.0 (579449) UWZ activated. Retrieve data. 2023-10-28 21:02:36.022 - error: weather-warnings.0 (579449) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-10-28 21:02:36.023 - error: weather-warnings.0 (579449) unhandled promise rejection: this.silentTime.profil[profil] is not iterable 2023-10-28 21:02:36.147 - error: weather-warnings.0 (579449) TypeError: this.silentTime.profil[profil] is not iterable at ProviderController.setSpeakAllowed (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:898:49) at ProviderController.updateAlertEndless (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:763:20) at /opt/iobroker/node_modules/iobroker.weather-warnings/src/main.ts:505:41 2023-10-28 21:02:36.148 - error: weather-warnings.0 (579449) this.silentTime.profil[profil] is not iterable 2023-10-28 21:02:36.161 - info: weather-warnings.0 (579449) terminating 2023-10-28 21:02:36.164 - warn: weather-warnings.0 (579449) Terminated (UNCAUGHT_EXCEPTION): Without reason 2023-10-28 21:02:36.357 - warn: weather-warnings.0 (579449) setTimeout called, but adapter is shutting down 2023-10-28 21:02:36.667 - info: weather-warnings.0 (579449) terminating 2023-10-28 21:02:36.790 - error: host.chet instance system.adapter.weather-warnings.0 terminated with code 6 (UNCAUGHT_EXCEPTION)iobroker.weather-warnings@0.4.5 mag nicht. :-)
Versuche github, sollte gefixt sein. -
@chris76e
Danke, das war tatsächlich nicht ok wenn keine Einträge da sind. Versuche es jetzt nochmal. Da gibts doch ein schönes Bild für:
Ab jetzt warte ich einen Tag bevor ich npm anstoße. gibt dann wohl ne v0.4.6... obwohl v0.5.0 Ist ja fast alles drin -
Versuche github, sollte gefixt sein.@ticaki sagte in Test Adapter Weather-Warnings:
Stimmt, GitHub-Version funkt wieder.
iobroker.weather-warnings@0.4.5 (git+ssh://git@github.com/ticaki/ioBroker.weather-warnings.git#95898bc58c60a0547ffb7e96156ef5891449f7dd) -
funktioniert jetzt
Vieleiocht noch ein default Profilname nehemen. Wenn man kein Name vergibt so der DP so aus
Bei mir funktioniert die 0.4.5 nicht. Startet nicht einmal.
@flugschüler sagte in Test Adapter Weather-Warnings:
Siehe oben. Die GitHub-Version startet wieder.
@flugschüler
Sry da ist ein Fehler, wenn die Ruhezeiten leer sind und da bei jedem Tester die Ruhezeiten schon befüllt waren ist das nicht aufgefallen.Außerdem soll das Repo um 14:00 und 2:00 aktualisiert werden, wo kommt ihr jetzt schon an den Adapter? :)
v0.4.6 ist auf dem Weg
EDIT: die Test bevor das auf npm landet können zwischen 6-20 Minuten dauern.
@flugschüler
@ticaki 0.4.6 geil.
@flugschüler
Wir haben einen minütlichen cronjob auf
iob updatelaufen. :-) -
@chris76e
Angenommen"Default": "fill me"hast du das in der 0.4.6 eingebaut, wenn ja, funktioniert noch nicht
@chris76e
Ja hab ich. Geht vielleicht kein Default bei Textfeldern. Kann ich mir morgen anschauen.v0.4.6 ist auf npm, also kann man es auch von dort installieren.
Quark:
"default": "fill me"geht. War vorhin zusehr im "mist, warum ist die kaputte Version schon im Repo" modus.
update
@ticaki Wenn das einer wüsste.
@chris76e
Quark:
update
Habe eine Warnung im DWD Adapter, erscheint aber nicht in diesem Adapter....
DWD
{"state":"Nordrhein-Westfalen","type":1,"level":2,"start":1698523200000,"end":1698606000000,"regionName":"Kreis Heinsberg","event":"WINDBÖEN","headline":"Amtliche WARNUNG vor WINDBÖEN","instruction":"","description":"Es treten Windböen mit Geschwindigkeiten zwischen 50 km/h (14 m/s, 28 kn, Bft 7) und 60 km/h (17 m/s, 33 kn, Bft 7) aus südwestlicher Richtung auf. In exponierten Lagen muss mit Sturmböen um 65 km/h (18 m/s, 35 kn, Bft 8) gerechnet werden.","stateShort":"NRW","altitudeStart":null,"altitudeEnd":null} -
DWD
{"state":"Nordrhein-Westfalen","type":1,"level":2,"start":1698523200000,"end":1698606000000,"regionName":"Kreis Heinsberg","event":"WINDBÖEN","headline":"Amtliche WARNUNG vor WINDBÖEN","instruction":"","description":"Es treten Windböen mit Geschwindigkeiten zwischen 50 km/h (14 m/s, 28 kn, Bft 7) und 60 km/h (17 m/s, 33 kn, Bft 7) aus südwestlicher Richtung auf. In exponierten Lagen muss mit Sturmböen um 65 km/h (18 m/s, 35 kn, Bft 8) gerechnet werden.","stateShort":"NRW","altitudeStart":null,"altitudeEnd":null}@chris76e
Das ist so richtig.Der DWD Adapter kennt nur Kreise, dieser hier auch Ortsteile. Du bekommst nur Warnung die auch wirklich zutreffen. Wenn du lieber das gleiche möchtest, stelle deine Warnzelle auf deinen Kreis ein. Da steht dann i.d.R. Kreis und nicht Gemeinde oder Stadt davor.
EDIT: jup 105370000;Kreis Heinsberg;Heinsberg;HSX;NW
@chris76e
hmm, kann hier aber nur den Kreis Auswählen, habe den Stadt Name nur für mich eingegeben.....
@chris76e
805370016;Stadt Heinsberg;Heinsberg;;NWWie tausendmal geschrieben. DWD sind 10000 Orte das übersteigt die möglichkeiten des aktuell Admins daher, namen schreiben, hin und her klicken damit sich die liste aktualisiert und dann wird die auswahl soweit eingeschränkt das man den Ort findet.
@chris76e
Erstmal die Warnung ist tatsächlich nicht auf der Kreisebene verfügbar.
Tipp mal Heinsberg ein. dann klicke in Placename oder wechsel das Tab, dann zurück auf den Pfeil nach unten klicken und es sind 3 Namen auswählbar.
Nochmal ich schicke die Liste an den Admin, der schneidet die bei 700 einträgen ca. ab. Deshalb mußt du den Namen eingeben, dann den Focus wechseln und wieder zurück gehen. Das aktualisiert die Liste im Hintergrund und der Adapter schickt aufgrund deiner Eingabe einen gefiltere Liste an den Admin. Ist nicht schön aber geht. Ich stelle mal ne Request für mehr mögliche Einträge.
Falls gewünscht kann ich aber auch die gleiche Bezugsquelle wie der DWD Adapter einbauen, hatte die ja lange genug im Script in Betrieb (für Kreis)
Jetzt ist alles klar, war nur was verwirrt vom DWD-Adapter......
Kann jetzt wenn ich mit "Stadt XXX" suche auch direkt meine Stadt auswählen, ist gut so. Man muss es nur ersteinmal verstehen ;-)
Kannst ja ne Request beim Admin Adapter erstellen dass der mehr Einträge im selectSendTo erlaubt. :)
Bei Kreisen stimmt bei dem DWD Dienst was nicht
