  4. Test Adapter Weather-Warnings
1.1k Beiträge 36 Kommentatoren 497.1k Aufrufe 41 Beobachtet
    @ticaki
    Du bist gerade hier auf Sendung, daher kein Issue:
    2023-10-28 21:02:31.214  - info: weather-warnings.0 (579449) starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.weather-warnings, node: v18.18.2, js-controller: 5.0.15
    2023-10-28 21:02:35.570  - info: weather-warnings.0 (579449) Refresh Interval: 15 minutes
    2023-10-28 21:02:35.714  - info: weather-warnings.0 (579449) DWD activated. Retrieve data.
    2023-10-28 21:02:35.720  - info: weather-warnings.0 (579449) UWZ activated. Retrieve data.
    2023-10-28 21:02:36.022  - error: weather-warnings.0 (579449) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-10-28 21:02:36.023  - error: weather-warnings.0 (579449) unhandled promise rejection: this.silentTime.profil[profil] is not iterable
    2023-10-28 21:02:36.147  - error: weather-warnings.0 (579449) TypeError: this.silentTime.profil[profil] is not iterable
        at ProviderController.setSpeakAllowed (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:898:49)
        at ProviderController.updateAlertEndless (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:763:20)
        at /opt/iobroker/node_modules/iobroker.weather-warnings/src/main.ts:505:41
    2023-10-28 21:02:36.148  - error: weather-warnings.0 (579449) this.silentTime.profil[profil] is not iterable
    2023-10-28 21:02:36.161  - info: weather-warnings.0 (579449) terminating
    2023-10-28 21:02:36.164  - warn: weather-warnings.0 (579449) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-10-28 21:02:36.357  - warn: weather-warnings.0 (579449) setTimeout called, but adapter is shutting down
    2023-10-28 21:02:36.667  - info: weather-warnings.0 (579449) terminating
    2023-10-28 21:02:36.790  - error: host.chet instance system.adapter.weather-warnings.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    iobroker.weather-warnings@0.4.5 mag nicht. :-)
    ticaki
    #501
    Versuche github, sollte gefixt sein.
    Spenden
    • T ticaki
      @chris76e
      Danke, das war tatsächlich nicht ok wenn keine Einträge da sind. Versuche es jetzt nochmal. Da gibts doch ein schönes Bild für:2023-10-28 21.00.49.jpg
      Ab jetzt warte ich einen Tag bevor ich npm anstoße. gibt dann wohl ne v0.4.6... obwohl v0.5.0 Ist ja fast alles drin
      Chris76eC Offline
      Chris76eC Offline
      Chris76e
      schrieb am zuletzt editiert von Chris76e
      #502
      @ticaki
      funktioniert jetzt
      Vieleiocht noch ein default Profilname nehemen. Wenn man kein Name vergibt so der DP so aus
      • T ticaki
        #503
        @ticaki sagte in Test Adapter Weather-Warnings:
        Stimmt, GitHub-Version funkt wieder.
        iobroker.weather-warnings@0.4.5 (git+ssh://git@github.com/ticaki/ioBroker.weather-warnings.git#95898bc58c60a0547ffb7e96156ef5891449f7dd)
        • Chris76eC Chris76e
          @ticaki
          funktioniert jetzt
          ticaki
          #504
          @chris76e
          Angenommen
          "Default": "fill me"
          Spenden
          Chris76eC 1 Antwort Letzte Antwort
          • F Offline
            Flugschüler
            #505
            Bei mir funktioniert die 0.4.5 nicht. Startet nicht einmal.
            Thomas BraunT T 2 Antworten Letzte Antwort
            • F Flugschüler
              #506
              @flugschüler sagte in Test Adapter Weather-Warnings:
              Siehe oben. Die GitHub-Version startet wieder.
              • F Flugschüler
                ticaki
                #507
                @flugschüler
                Sry da ist ein Fehler, wenn die Ruhezeiten leer sind und da bei jedem Tester die Ruhezeiten schon befüllt waren ist das nicht aufgefallen.
                Außerdem soll das Repo um 14:00 und 2:00 aktualisiert werden, wo kommt ihr jetzt schon an den Adapter? :)
                v0.4.6 ist auf dem Weg
                EDIT: die Test bevor das auf npm landet können zwischen 6-20 Minuten dauern.
                Spenden
                F Thomas BraunT 2 Antworten Letzte Antwort
                • T ticaki
                  @flugschüler
                  Flugschüler
                  schrieb am zuletzt editiert von Flugschüler
                  #508
                  @ticaki 0.4.6 geil.
                  • T ticaki
                    @flugschüler
                    #509
                    Wir haben einen minütlichen cronjob auf iob update laufen. :-)
                    • T ticaki
                      @chris76e
                      Angenommen
                      Chris76eC Offline
                      Chris76eC Offline
                      Chris76e
                      #510
                      @chris76e
                      Angenommen
                      hast du das in der 0.4.6 eingebaut, wenn ja, funktioniert noch nicht
                        @chris76e
                        Angenommen
                        ticaki
                        #511
                        @chris76e
                        Ja hab ich. Geht vielleicht kein Default bei Textfeldern. Kann ich mir morgen anschauen.
                        v0.4.6 ist auf npm, also kann man es auch von dort installieren.
                        Quark:
                        "default": "fill me"
                        geht. War vorhin zusehr im "mist, warum ist die kaputte Version schon im Repo" modus.
                        update
                        Spenden
                        • F Offline
                          Flugschüler
                          #512
                          @ticaki Wenn das einer wüsste.😊
                          • T ticaki
                            @chris76e
                            Quark:
                            update
                            Chris76eC Offline
                            Chris76eC Offline
                            Chris76e
                            #513
                            @ticaki
                            Habe eine Warnung im DWD Adapter, erscheint aber nicht in diesem Adapter....
                            DWD
                            {"state":"Nordrhein-Westfalen","type":1,"level":2,"start":1698523200000,"end":1698606000000,"regionName":"Kreis Heinsberg","event":"WINDBÖEN","headline":"Amtliche WARNUNG vor WINDBÖEN","instruction":"","description":"Es treten Windböen mit Geschwindigkeiten zwischen 50 km/h (14 m/s, 28 kn, Bft 7) und 60 km/h (17 m/s, 33 kn, Bft 7) aus südwestlicher Richtung auf. In exponierten Lagen muss mit Sturmböen um 65 km/h (18 m/s, 35 kn, Bft 8) gerechnet werden.","stateShort":"NRW","altitudeStart":null,"altitudeEnd":null}
                              @ticaki
                              DWD
                              ticaki
                              #514
                              @chris76e
                              Das ist so richtig.
                              Der DWD Adapter kennt nur Kreise, dieser hier auch Ortsteile. Du bekommst nur Warnung die auch wirklich zutreffen. Wenn du lieber das gleiche möchtest, stelle deine Warnzelle auf deinen Kreis ein. Da steht dann i.d.R. Kreis und nicht Gemeinde oder Stadt davor.
                              EDIT: jup 105370000;Kreis Heinsberg;Heinsberg;HSX;NW
                              Spenden
                              • T ticaki
                                @chris76e
                                Das ist so richtig.
                                Chris76eC Offline
                                Chris76eC Offline
                                Chris76e
                                #515
                                @ticaki
                                hmm, kann hier aber nur den Kreis Auswählen, habe den Stadt Name nur für mich eingegeben.....
                                  @ticaki
                                  ticaki
                                  #516
                                  @chris76e
                                  805370016;Stadt Heinsberg;Heinsberg;;NW
                                  Wie tausendmal geschrieben. DWD sind 10000 Orte das übersteigt die möglichkeiten des aktuell Admins daher, namen schreiben, hin und her klicken damit sich die liste aktualisiert und dann wird die auswahl soweit eingeschränkt das man den Ort findet.
                                  Spenden
                                  • T ticaki
                                    @chris76e
                                    Chris76eC Offline
                                    Chris76eC Offline
                                    Chris76e
                                    #517
                                    @ticaki
                                    Aber mir gibt es nur den Kreis Heinsberg, habe nie andere Namen aus dem Kreis gefunden.
                                      @ticaki
                                      ticaki
                                      #518
                                      @chris76e
                                      Erstmal die Warnung ist tatsächlich nicht auf der Kreisebene verfügbar.
                                      Tipp mal Heinsberg ein. dann klicke in Placename oder wechsel das Tab, dann zurück auf den Pfeil nach unten klicken und es sind 3 Namen auswählbar.
                                      Nochmal ich schicke die Liste an den Admin, der schneidet die bei 700 einträgen ca. ab. Deshalb mußt du den Namen eingeben, dann den Focus wechseln und wieder zurück gehen. Das aktualisiert die Liste im Hintergrund und der Adapter schickt aufgrund deiner Eingabe einen gefiltere Liste an den Admin. Ist nicht schön aber geht. Ich stelle mal ne Request für mehr mögliche Einträge.
                                      Falls gewünscht kann ich aber auch die gleiche Bezugsquelle wie der DWD Adapter einbauen, hatte die ja lange genug im Script in Betrieb (für Kreis)
                                      Spenden
                                      • T ticaki
                                        @chris76e
                                        Chris76eC Offline
                                        Chris76eC Offline
                                        Chris76e
                                        #519
                                        @ticaki
                                        Jetzt ist alles klar, war nur was verwirrt vom DWD-Adapter......
                                        Kann jetzt wenn ich mit "Stadt XXX" suche auch direkt meine Stadt auswählen, ist gut so. Man muss es nur ersteinmal verstehen ;-)
                                          @ticaki
                                          ticaki
                                          #520
                                          @chris76e
                                          Kannst ja ne Request beim Admin Adapter erstellen dass der mehr Einträge im selectSendTo erlaubt. :)
                                          Bei Kreisen stimmt bei dem DWD Dienst was nicht
                                          Kreise:
                                          https://maps.dwd.de/geoserver/dwd/wms?service=WMS&version=1.1.0&request=GetMap&layers=dwd%3AWarnungen_Landkreise&bbox=5.0%2C47.0%2C16.0%2C55.25&width=768&height=576&srs=EPSG%3A4326&styles=&format=image%2Fpng
                                          Gemeinden:
                                          https://maps.dwd.de/geoserver/dwd/wms?service=WMS&version=1.1.0&request=GetMap&layers=dwd%3AWarnungen_Gemeinden&bbox=5.87691362426438%2C47.2703623257608%2C15.0375065863599%2C55.0443808252149&width=768&height=651&srs=EPSG%3A4326&styles=&format=application/openlayers#toggle
                                          Spenden
