  3. Einsteigerfragen
  4. Installation
  5. Hilfe! js-controller und javascript Problem
Geplant Angeheftet Gesperrt Verschoben Installation
75 Beiträge 2 Kommentatoren 9.2k Aufrufe 2 Beobachtet
    @ionewbie
    Dann kannst du direkt hier weiterlesen:
    https://forum.iobroker.net/topic/65017/zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev/
    Insbesondere die letzte Ergänzung ist für dein 32Bit-System wichtig.
    Wenn das alles richtig drin ist:
    iob diag
    in der Langfassung.
    I Offline
    I Offline
    ioNewbie
    schrieb am zuletzt editiert von ioNewbie
    @thomas-braun said in Hilfe! js-controller und javascript Problem:
    klappt nicht, "Repository is not signed"
    pi@iobroker:/etc/apt/sources.list.d $ sudo nano bullseye-proposed-updates.list
    pi@iobroker:/etc/apt/sources.list.d $ sudo apt update
    Get:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54.0 kB]
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Err:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
      The following signatures couldn't be verified because the public key is not av                    ailable: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
    Reading package lists... Done
    W: GPG error: http://deb.debian.org/debian bullseye-proposed-updates InRelease:                     The following signatures couldn't be verified because the public key is not avai                    lable: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
    E: The repository 'http://deb.debian.org/debian bullseye-proposed-updates InRele                    ase' is not signed.
    N: Updating from such a repository can't be done securely, and is therefore disa                    bled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration deta                    ils.
    pi@iobroker:/etc/apt/sources.list.d $ sudo apt -t bullseye-proposed-updates install udev
    E: The value 'bullseye-proposed-updates' is invalid for APT::Default-Release as such a release is not available in the sources
    In die Datei hatte ich gemäß dem verlinkten Artikel geschrieben:
    deb http://deb.debian.org/debian bullseye-proposed-updates main
    • I ioNewbie
      @ionewbie sagte in Hilfe! js-controller und javascript Problem:
      Die keys sind glaube ich auch genannt.
      I 1 Antwort Letzte Antwort
        I Offline
        I Offline
        ioNewbie
        @thomas-braun sorry, was genau soll ich jetzt tun?
        Aus dieser Anleitung alle Schritte im Kapitel "TEIL 1 Installation und Update von nodejs" durchgehen, angefangen bei Löschen der alten Installiation?
        Also ab hier?
        sudo apt purge --autoremove nodejs* npm node-* libnode*
        • I ioNewbie
          Also ab hier?
          @ionewbie
          Nein.
          Erst udev richtig installieren.
          Keys reinholen:
          EDIT 09.06.2023
          Wenn beim Udate festgestellt wird, dass keys - Schlüssel fehlen, dann bitte folgende Befehle eingeben:
          sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 648ACFD622F3D138
          sudo apt update
            @ionewbie
            Nein.
            Keys reinholen:
            EDIT 09.06.2023
            sudo apt update
            I Offline
            I Offline
            ioNewbie
            sieht nach demselben Fehler aus:
            pi@iobroker:/etc/apt/sources.list.d $ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 648ACFD622F3D138
            Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
            Executing: /tmp/apt-key-gpghome.KIQN2h7mCD/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 648ACFD622F3D138
            gpg: key DC30D7C23CBBABEE: public key "Debian Archive Automatic Signing Key (10/buster) <ftpmaster@debian.org>" imported
            gpg: Total number processed: 1
            gpg:               imported: 1
            Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
              The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
            W: GPG error: http://deb.debian.org/debian bullseye-proposed-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
            E: The repository 'http://deb.debian.org/debian bullseye-proposed-updates InRelease' is not signed.
            N: Updating from such a repository can't be done securely, and is therefore disabled by default.
            N: See apt-secure(8) manpage for repository creation and user configuration details.
            • I ioNewbie
              gpg:               imported: 1
              6ED0E7B82643E131
              Transferleistung gefragt...
              Der fehlende Key heißt 6ED0E7B82643E131...
                6ED0E7B82643E131
                I Offline
                I Offline
                ioNewbie
                6ED0E7B82643E131
                omg, ja verstehe. habe nur die 314 Postings in dem von dir verlinkten Thread gesehen und Textsuche auf keys gemacht und als ich nichts gefunden habe, bin ich ausgestiegen, weil Wald und Bäume und so...
                Also der Schlüssel ist jetzt drin, und sudo apt update ergab folgendes Ergebnis:
                Get:5 http://deb.debian.org/debian bullseye-proposed-updates/main armhf Packages [152 kB]
                Get:6 http://deb.debian.org/debian bullseye-proposed-updates/main Translation-en [94.8 kB]
                Fetched 247 kB in 1s (212 kB/s)
                Building dependency tree... Done
                23 packages can be upgraded. Run 'apt list --upgradable' to see them.
                pi@iobroker:/etc/apt/sources.list.d $ apt list --upgradable
                Ich nehme an, die 23 Pakete ziehe ich jetzt mal mit dem dort angegebenen Befehl herein?
                • I ioNewbie
                  6ED0E7B82643E131
                  Nein, nur das udev-Paket.
                  Und dann löschst du die gerade angelegte .list-Datei auch wieder.
                    I Offline
                    I Offline
                    ioNewbie
                    ok, das udev war wohl vorher schon drin? und die bullseye Datei darf ich nicht löschen.
                    udev is already the newest version (247.3-7+rpi1+deb11u2).
                    The following package was automatically installed and is no longer required:
                      raspinfo
                    Use 'sudo apt autoremove' to remove it.
                    0 upgraded, 0 newly installed, 0 to remove and 33 not upgraded.
                    pi@iobroker:/etc/apt/sources.list.d $ ls
                    bullseye-proposed-updates.list  nodesource.list  raspi.list
                    pi@iobroker:/etc/apt/sources.list.d $ rm bullseye-proposed-updates.list
                    rm: remove write-protected regular file 'bullseye-proposed-updates.list'? y
                    rm: cannot remove 'bullseye-proposed-updates.list': Permission denied
                    • I ioNewbie
                        raspinfo
                      @ionewbie
                      sudo apt update
                      apt policy udev
                        @ionewbie
                        sudo apt update
                        apt policy udev
                        I Offline
                        I Offline
                        ioNewbie
                        @thomas-braun es bleibt bei u2
                        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:2 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                        Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        pi@iobroker:/etc/apt/sources.list.d $ apt policy udev
                        udev:
                          Installed: 247.3-7+rpi1+deb11u2
                          Candidate: 247.3-7+rpi1+deb11u2
                          Version table:
                         *** 247.3-7+rpi1+deb11u2 500
                                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                100 /var/lib/dpkg/status
                             247.3-7+deb11u4 500
                                500 http://deb.debian.org/debian bullseye-proposed-updates/main armhf Packages
                        • I ioNewbie
                          udev:
                            Version table:
                               247.3-7+deb11u4 500
                          @ionewbie
                          Dann wie in der Anleitung beschrieben:
                          sudo apt install udev=247.3-7+deb11u4 libudev1=247.3-7+deb11u4
                          sudo apt-mark hold udev
                          sudo rm /etc/apt/sources.list.d/bullseye-proposed-updates.list
                          sudo apt update
                            @ionewbie
                            sudo apt update
                            I Offline
                            I Offline
                            ioNewbie
                            das kam jetzt dabei heraus:
                            pi@iobroker:~ $ sudo apt install udev=247.3-7+deb11u4 libudev1=247.3-7+deb11u4
                              raspinfo
                            The following packages will be REMOVED:
                              libudev-dev
                            The following held packages will be changed:
                              udev
                            The following packages will be DOWNGRADED:
                              libudev1 udev
                            0 upgraded, 0 newly installed, 2 downgraded, 1 to remove and 23 not upgraded.
                            Need to get 1,602 kB of archives.
                            After this operation, 573 kB disk space will be freed.
                            Do you want to continue? [Y/n] y
                            Get:1 http://deb.debian.org/debian bullseye-proposed-updates/main armhf udev armhf 247.3-7+deb11u4 [1,440 kB]
                            Get:2 http://deb.debian.org/debian bullseye-proposed-updates/main armhf libudev1 armhf 247.3-7+deb11u4 [162 kB]
                            Fetched 1,602 kB in 0s (9,808 kB/s)
                            (Reading database ... 55082 files and directories currently installed.)
                            Removing libudev-dev:armhf (247.3-7+rpi1+deb11u2) ...
                            dpkg: warning: downgrading udev from 247.3-7+rpi1+deb11u2 to 247.3-7+deb11u4
                            (Reading database ... 55007 files and directories currently installed.)
                            Preparing to unpack .../udev_247.3-7+deb11u4_armhf.deb ...
                            Unpacking udev (247.3-7+deb11u4) over (247.3-7+rpi1+deb11u2) ...
                            dpkg: warning: downgrading libudev1:armhf from 247.3-7+rpi1+deb11u2 to 247.3-7+deb11u4
                            Preparing to unpack .../libudev1_247.3-7+deb11u4_armhf.deb ...
                            Unpacking libudev1:armhf (247.3-7+deb11u4) over (247.3-7+rpi1+deb11u2) ...
                            Setting up libudev1:armhf (247.3-7+deb11u4) ...
                            Setting up udev (247.3-7+deb11u4) ...
                            Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
                            Processing triggers for man-db (2.9.4-2) ...
                            Processing triggers for initramfs-tools (0.140) ...
                            pi@iobroker:~ $ sudo apt-mark hold udev
                            udev set on hold.
                            pi@iobroker:~ $ sudo rm /etc/apt/sources.list.d/bullseye-proposed-updates.list
                            pi@iobroker:~ $ sudo apt update
                            Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                            2 packages can be upgraded. Run 'apt list --upgradable' to see them.
                            pi@iobroker:~ $ apt policy udev
                            udev:
                              Installed: 247.3-7+deb11u4
                              Version table:
                             *** **247.3-7+deb11u4** 100
                            • I ioNewbie
                                raspinfo
                                libudev-dev
                                udev
                                libudev1 udev
                              udev set on hold.
                              udev:
                                Version table:
                              @ionewbie
                              Jetzt passt es.
                                @ionewbie
                                Jetzt passt es.
                                I Offline
                                I Offline
                                ioNewbie
                                @thomas-braun und diese Schritte als nächstes? der JSController ist ja immer noch der alte
                                Diese hier?
                                cd /opt/iobroker/
                                sudo iobroker stop
                                sudo iobroker update
                                sudo iobroker upgrade self
                                sudo iobroker start
                                • I ioNewbie
                                  Diese hier?
                                  cd /opt/iobroker/
                                  sudo iobroker stop
                                  sudo iobroker start
                                  @ionewbie
                                  NEIN!
                                  iobroker wird NIE mit sudo angepackt.
                                    @ionewbie
                                    NEIN!
                                    I Offline
                                    I Offline
                                    ioNewbie
                                    @thomas-braun sorry. Also diese hier:
                                    iobroker stop
                                    iobroker update
                                    iobroker fix oder wenn das nicht funktioniert: curl -sL https://iobroker.net/fix.sh | bash -
                                    iobroker start
                                    • I ioNewbie
                                      iobroker stop
                                      iobroker update
                                      iobroker start
                                      @ionewbie
                                      Gib mir nochmal die aktuelle Langfassung vom
                                      iob diag
                                        @ionewbie
                                        iob diag
                                        I Offline
                                        I Offline
                                        ioNewbie
                                        @thomas-braun hier:
                                        ======== Start marking the full check here =========
                                        Skript v.2023-06-20
                                        *** BASE SYSTEM ***
                                           Static hostname: iobroker
                                                 Icon name: computer
                                                Machine ID: 68716f4ecfa5426ea966c195a9cf7def
                                                   Boot ID: 6aefc086b627460e8ca1c41a04001228
                                          Operating System: Raspbian GNU/Linux 11 (bullseye)
                                                    Kernel: Linux 6.1.21-v8+
                                              Architecture: arm64
                                        Model           : Raspberry Pi 4 Model B Rev 1.2
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : aarch64
                                        Userland        : armhf
                                        Systemuptime and Load:
                                         14:34:11 up 10 min,  2 users,  load average: 0.12, 0.48, 0.45
                                        CPU threads: 4
                                        Raspberry only:
                                        throttled=0x0
                                        Other values than 0x0 hint to temperature/voltage problems
                                        temp=42.8'C
                                        volt=0.8625V
                                        *** Time and Time Zones ***
                                                       Local time: Sun 2023-09-17 14:34:11 CEST
                                                   Universal time: Sun 2023-09-17 12:34:11 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** User and Groups ***
                                        pi
                                        /home/pi
                                        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                        *** X-Server-Setup ***
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        Boot Target:    multi-user.target
                                        *** MEMORY ***
                                        Mem:            3.8G        441M        2.8G        0.0K        524M        3.3G
                                        Swap:            99M          0B         99M
                                        Total:          3.9G        441M        2.9G
                                                 3794 M total memory
                                                  441 M used memory
                                                  519 M active memory
                                                  327 M inactive memory
                                                 2828 M free memory
                                                   54 M buffer memory
                                                  470 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        lifetime oom required: 0 Mbytes
                                        total time in oom handler: 0 ms
                                        max time spent in oom handler: 0 ms
                                        *** FILESYSTEM ***
                                        /dev/root      ext4       59G  7.0G   49G  13% /
                                        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                        tmpfs          tmpfs     759M  836K  759M   1% /run
                                        /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                                        /dev/sda1      exfat     118G  9.3M  118G   1% /media/usbstick
                                        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                        [Sun Sep 17 14:23:31 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:F8:36:36 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3f61f07b-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Sun Sep 17 14:23:32 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Sun Sep 17 14:23:32 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                        [Sun Sep 17 14:23:35 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                        Show mounted filesystems (real ones only):
                                        TARGET            SOURCE         FSTYPE OPTIONS
                                        /                 /dev/mmcblk0p2 ext4   rw,noatime,nodiratime
                                        |-/boot           /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                        `-/media/usbstick /dev/sda1      exfat  rw,noatime,uid=1001,gid=1001,fmask=0022,dmask=0022,iocharset=utf8,errors=remount-ro
                                        /var:
                                        2.4G    /var/
                                        1.8G    /var/log/journal/68716f4ecfa5426ea966c195a9cf7def
                                        1.8G    /var/log
                                        323M    /var/cache
                                        Archived and active journals take up 1.7G in the file system.
                                        /opt/iobroker/backups:
                                        87M     /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        1.9G    /opt/iobroker/iobroker-data/
                                        1.7G    /opt/iobroker/iobroker-data/history
                                        126M    /opt/iobroker/iobroker-data/files
                                        52M     /opt/iobroker/iobroker-data/files/javascript.admin
                                        44M     /opt/iobroker/iobroker-data/backup-objects
                                        7.1M    /opt/iobroker/iobroker-data/objects.jsonl
                                        7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
                                        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                        5.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
                                        5.3M    /opt/iobroker/iobroker-data/files/knx.admin/static/js/2.00871907.chunk.js.map
                                        *** NodeJS-Installation ***
                                        /usr/bin/nodejs         v18.17.1
                                        /usr/bin/node           v18.17.1
                                        /usr/bin/npm            9.6.7
                                        /usr/bin/npx            9.6.7
                                        nodejs:
                                          Installed: 18.17.1-deb-1nodesource1
                                          Candidate: 18.17.1-deb-1nodesource1
                                          Version table:
                                         *** 18.17.1-deb-1nodesource1 500
                                                500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                                             12.22.12~dfsg-1~deb11u4 500
                                        No problems detected
                                        npm ERR! code ELSPROBLEMS
                                        npm ERR! missing: @iobroker/types@^5.0.11, required by @iobroker/adapter-core@3.0.3
                                        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-09-17T12_34_24_403Z-debug-0.log
                                        Errors in npm tree: 0
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        No configuration change needed.
                                        Multihost discovery server: disabled
                                        Discovery authentication:   enabled
                                        Persistent activation:      disabled
                                        Objects:                    jsonl on 127.0.0.1
                                        States:                     jsonl on 127.0.0.1
                                        Core adapters versions
                                        js-controller:  4.0.24
                                        admin:          6.3.5
                                        javascript:     7.1.4
                                        Adapters from github:   0
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                          system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
                                          system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker                                 - disabled
                                        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                          system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                                          system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
                                        + system.adapter.history.0                : history               : iobroker                                 -  enabled
                                          system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                                          system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                        + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.10.190
                                          system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
                                          system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                                          system.adapter.powerfox2.0              : powerfox2             : iobroker                                 -  enabled
                                        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                          system.adapter.sonos.0                  : sonos                 : iobroker                                 - disabled
                                          system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5000
                                          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                                          system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                                          system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
                                          system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                                          system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                                          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
                                        + instance is alive
                                        ioBroker-Repositories
                                        Active repo(s): stable
                                        Installed ioBroker-Instances
                                        Used repository: stable
                                        Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
                                        Adapter    "alexa2"       : 3.24.1   , installed 3.23.2 [Updatable]
                                        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                                        Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                                        Adapter    "daikin-cloud" : 0.3.0    , installed 0.2.3  [Updatable]
                                        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                        Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                                        Adapter    "history"      : 2.2.6    , installed 2.2.4  [Updatable]
                                        Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
                                        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                                        Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
                                        Adapter    "knx"          : 2.0.22   , installed 2.0.17 [Updatable]
                                        Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                                        Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
                                        Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
                                        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                                        Adapter    "socketio"     : 6.5.5    , installed 4.2.0  [Updatable]
                                        Adapter    "sonos"        : 2.3.1    , installed 2.3.1
                                        Adapter    "synology"     : 2.1.13   , installed 2.1.13
                                        Adapter    "vis"          : 1.4.16   , installed 1.4.16
                                        Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
                                        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                                        Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
                                        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                        Adapter    "web"          : 6.1.2    , installed 4.3.0  [Updatable]
                                        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                        Adapter    "ws"           : 2.5.5    , installed 1.3.0  [Updatable]
                                        Objects and States
                                        Objects:        2461
                                        States:         1869
                                        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1872       482/iobroker.js-con
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13925      482/iobroker.js-con
                                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       14238      834/io.shelly.0
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13899      519/sshd: /usr/sbin
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14173      598/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17582      1027/io.web.0
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          13901      519/sshd: /usr/sbin
                                        udp        0      0 0.0.0.0:46199           0.0.0.0:*                           108        1774       393/avahi-daemon: r
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1772       393/avahi-daemon: r
                                        udp        0      0 192.168.10.190:52781    0.0.0.0:*                           1001       16090      1296/io.knx.0
                                        udp        0      0 192.168.10.190:56912    0.0.0.0:*                           1001       23788      1296/io.knx.0
                                        udp        0      0 192.168.10.190:50885    0.0.0.0:*                           1001       16873      1296/io.knx.0
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15138      701/dhcpcd
                                        udp6       0      0 :::47730                :::*                                108        1775       393/avahi-daemon: r
                                        udp6       0      0 :::5353                 :::*                                108        1773       393/avahi-daemon: r
                                        2023-09-17 14:29:06.350  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                                        2023-09-17 14:30:00.117  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 3666
                                        2023-09-17 14:30:02.100  - info: powerfox2.0 (3666) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
                                        2023-09-17 14:30:05.431  - info: powerfox2.0 (3666) Terminated (NO_ERROR): Without reason
                                        2023-09-17 14:30:05.987  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                                        2023-09-17 14:31:00.148  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 3683
                                        2023-09-17 14:31:02.155  - info: powerfox2.0 (3683) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
                                        2023-09-17 14:31:05.186  - info: powerfox2.0 (3683) Terminated (NO_ERROR): Without reason
                                        2023-09-17 14:31:05.763  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                                        2023-09-17 14:32:00.093  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 3700
                                        2023-09-17 14:32:02.065  - info: powerfox2.0 (3700) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
                                        2023-09-17 14:32:05.411  - info: powerfox2.0 (3700) Terminated (NO_ERROR): Without reason
                                        2023-09-17 14:32:05.943  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                                        2023-09-17 14:33:00.123  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 3715
                                        2023-09-17 14:33:02.072  - info: powerfox2.0 (3715) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
                                        2023-09-17 14:33:06.034  - info: powerfox2.0 (3715) Terminated (NO_ERROR): Without reason
                                        2023-09-17 14:33:06.565  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                                        2023-09-17 14:34:00.133  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 3733
                                        2023-09-17 14:34:02.101  - info: powerfox2.0 (3733) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
                                        2023-09-17 14:34:05.015  - info: powerfox2.0 (3733) Terminated (NO_ERROR): Without reason
                                        2023-09-17 14:34:05.576  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                                        2023-09-17 14:35:00.112  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 4007
                                        2023-09-17 14:35:02.218  - info: powerfox2.0 (4007) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
                                        2023-09-17 14:35:06.498  - info: powerfox2.0 (4007) Terminated (NO_ERROR): Without reason
                                        2023-09-17 14:35:07.028  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                                        • I ioNewbie
                                          @thomas-braun hier:
                                          Skript v.2023-06-20
                                          *** BASE SYSTEM ***
                                                   Icon name: computer
                                                Architecture: arm64
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : armhf
                                          CPU threads: 4
                                          Raspberry only:
                                          throttled=0x0
                                          temp=42.8'C
                                          volt=0.8625V
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pi
                                          /home/pi
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:            99M          0B         99M
                                                   3794 M total memory
                                                    441 M used memory
                                                    519 M active memory
                                                   2828 M free memory
                                                     54 M buffer memory
                                                    470 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          /var:
                                          2.4G    /var/
                                          1.8G    /var/log
                                          323M    /var/cache
                                          /usr/bin/npm            9.6.7
                                          /usr/bin/npx            9.6.7
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.3.5
                                          javascript:     7.1.4
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        2461
                                          States:         1869
                                          Pending Updates: 0
                                          I Offline
                                          I Offline
                                          ioNewbie
                                          @ionewbie
                                          was ist mit den npm Errors, muss das gefixt werden und wie?
