  3. Einsteigerfragen
  4. Installation
  5. Hilfe! js-controller und javascript Problem
Geplant Angeheftet Gesperrt Verschoben Installation
75 Beiträge 2 Kommentatoren 9.2k Aufrufe 2 Beobachtet
  • I ioNewbie
    @ionewbie
    was ist mit den npm Errors, muss das gefixt werden und wie?
    npm ERR! code ELSPROBLEMS
    npm ERR! missing: @iobroker/types@^5.0.11, required by @iobroker/adapter-core@3.0.3
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-09-17T12_34_24_403Z-debug-0.log
    #41
    @ionewbie sagte in Hilfe! js-controller und javascript Problem:
    Ja. Ich weiß nur noch nicht wie genau.
    iob update
    iob upgrade all
    sagt?
    I 1 Antwort Letzte Antwort
      iob update
      iob upgrade all
      sagt?
      I Offline
      I Offline
      ioNewbie
      #42
      @thomas-braun iob update bringt das hier.
      pi@iobroker:~ $ iob update
      Used repository: stable
      Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
      Adapter    "alexa2"       : 3.24.1   , installed 3.23.2 [Updatable]
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
      Adapter    "daikin-cloud" : 0.3.0    , installed 0.2.3  [Updatable]
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
      Adapter    "history"      : 2.2.6    , installed 2.2.4  [Updatable]
      Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
      Adapter    "knx"          : 2.0.22   , installed 2.0.17 [Updatable]
      Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
      Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
      Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "socketio"     : 6.5.5    , installed 4.2.0  [Updatable]
      Adapter    "sonos"        : 2.3.1    , installed 2.3.1
      Adapter    "synology"     : 2.1.13   , installed 2.1.13
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 6.1.2    , installed 4.3.0  [Updatable]
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "ws"           : 2.5.5    , installed 1.3.0  [Updatable]
      ich gehe gerade den zweiten Befehl durch (upgrade all), muss bei jedem Paket einzeln bestätigen (y).
      Thomas BraunT I 2 Antworten Letzte Antwort
      • I ioNewbie
        #43
        So soll das sein.
        • I ioNewbie
          I Offline
          I Offline
          ioNewbie
          #44
          @ionewbie ok, die sind jetzt alle durch, ohne Fehler, wenn ich das richtig verfolgt habe.
          Willst du den kompletten output von Putty dazu?
          • I ioNewbie
            #45
            Nö. Lieber nochmal
            iob diag
              Nö. Lieber nochmal
              iob diag
              I Offline
              I Offline
              ioNewbie
              #46
              @thomas-braun immer noch die npm Errors. Ist da evtl jetzt erst mal ein Reboot fällig?
              die ganzen Pakete, welche ich mit [y] zum Update bestätigt habe, werden immer noch als alt anzeigt.
              ======== Start marking the full check here =========
              Skript v.2023-06-20
              *** BASE SYSTEM ***
                 Static hostname: iobroker
                       Icon name: computer
                      Machine ID: 68716f4ecfa5426ea966c195a9cf7def
                         Boot ID: 6aefc086b627460e8ca1c41a04001228
                Operating System: Raspbian GNU/Linux 11 (bullseye)
                          Kernel: Linux 6.1.21-v8+
                    Architecture: arm64
              Model           : Raspberry Pi 4 Model B Rev 1.2
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : armhf
              Systemuptime and Load:
               14:55:24 up 31 min,  2 users,  load average: 0.20, 0.67, 0.63
              CPU threads: 4
              Raspberry only:
              throttled=0x0
              Other values than 0x0 hint to temperature/voltage problems
              temp=43.8'C
              volt=0.8625V
              *** Time and Time Zones ***
                             Local time: Sun 2023-09-17 14:55:24 CEST
                         Universal time: Sun 2023-09-17 12:55:24 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:            3.8G        453M        2.6G        0.0K        754M        3.3G
              Swap:            99M          0B         99M
              Total:          3.9G        453M        2.7G
                       3794 M total memory
                        453 M used memory
                        533 M active memory
                        508 M inactive memory
                       2586 M free memory
                         95 M buffer memory
                        658 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              lifetime oom required: 0 Mbytes
              total time in oom handler: 0 ms
              max time spent in oom handler: 0 ms
              *** FILESYSTEM ***
              /dev/root      ext4       59G  7.0G   49G  13% /
              devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
              tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
              tmpfs          tmpfs     759M  836K  759M   1% /run
              /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
              /dev/sda1      exfat     118G  9.3M  118G   1% /media/usbstick
              tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
              [Sun Sep 17 14:23:31 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:F8:36:36 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3f61f07b-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Sun Sep 17 14:23:32 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Sun Sep 17 14:23:32 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Sun Sep 17 14:23:35 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              Show mounted filesystems (real ones only):
              TARGET            SOURCE         FSTYPE OPTIONS
              /                 /dev/mmcblk0p2 ext4   rw,noatime,nodiratime
              |-/boot           /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
              `-/media/usbstick /dev/sda1      exfat  rw,noatime,uid=1001,gid=1001,fmask=0022,dmask=0022,iocharset=utf8,errors=remount-ro
              /var:
              2.4G    /var/
              1.8G    /var/log/journal/68716f4ecfa5426ea966c195a9cf7def
              1.8G    /var/log
              323M    /var/cache
              Archived and active journals take up 1.7G in the file system.
              /opt/iobroker/backups:
              87M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              1.9G    /opt/iobroker/iobroker-data/
              1.7G    /opt/iobroker/iobroker-data/history
              126M    /opt/iobroker/iobroker-data/files
              52M     /opt/iobroker/iobroker-data/files/javascript.admin
              44M     /opt/iobroker/iobroker-data/backup-objects
              7.7M    /opt/iobroker/iobroker-data/objects.jsonl
              7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
              6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
              5.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
              5.3M    /opt/iobroker/iobroker-data/files/knx.admin/static/js/2.00871907.chunk.js.map
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.17.1
              /usr/bin/node           v18.17.1
              /usr/bin/npm            9.6.7
              /usr/bin/npx            9.6.7
              nodejs:
                Installed: 18.17.1-deb-1nodesource1
                Candidate: 18.17.1-deb-1nodesource1
                Version table:
               *** 18.17.1-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                      100 /var/lib/dpkg/status
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
              No problems detected
              npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-09-17T12_55_31_632Z-debug-0.log
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              No configuration change needed.
              Multihost discovery server: disabled
              Discovery authentication:   enabled
              Persistent activation:      disabled
              Objects:                    jsonl on 127.0.0.1
              States:                     jsonl on 127.0.0.1
              Core adapters versions
              js-controller:  4.0.24
              admin:          6.3.5
              javascript:     7.1.4
              Adapters from github:   0
              Adapter State
              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
              + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
                system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker                                 - disabled
              + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
              + system.adapter.history.0                : history               : iobroker                                 -  enabled
                system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.10.190
                system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
                system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                system.adapter.powerfox2.0              : powerfox2             : iobroker                                 -  enabled
              + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                system.adapter.sonos.0                  : sonos                 : iobroker                                 - disabled
                system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5000
                system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
                system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
              + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
              Objects and States
              Objects:        2465
              States:         1871
              Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1872       482/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13925      482/iobroker.js-con
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       14238      834/io.shelly.0
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13899      519/sshd: /usr/sbin
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       32697      5472/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       34383      5658/io.web.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          13901      519/sshd: /usr/sbin
              udp        0      0 0.0.0.0:46199           0.0.0.0:*                           108        1774       393/avahi-daemon: r
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1772       393/avahi-daemon: r
              udp        0      0 192.168.10.190:54580    0.0.0.0:*                           1001       34727      5712/io.knx.0
              udp        0      0 192.168.10.190:34551    0.0.0.0:*                           1001       35645      5712/io.knx.0
              udp        0      0 192.168.10.190:43032    0.0.0.0:*                           1001       34448      5712/io.knx.0
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15138      701/dhcpcd
              udp        0      0 192.168.10.190:57483    0.0.0.0:*                           1001       35376      5712/io.knx.0
              udp6       0      0 :::47730                :::*                                108        1775       393/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                108        1773       393/avahi-daemon: r
              2023-09-17 14:51:57.852  - info: history.0 (5750) enabled logging of shelly.0.SHSW-1#E89F6D85F71E#1.ext.temperatureC2 (Count=43), Alias=false
              2023-09-17 14:51:57.852  - info: history.0 (5750) enabled logging of shelly.0.SHSW-1#E89F6D85F71E#1.ext.temperatureC3 (Count=44), Alias=false
              2023-09-17 14:51:57.853  - info: history.0 (5750) enabled logging of knx.0.Zentral.Daten.Heizkreis_RL (Count=45), Alias=false
              2023-09-17 14:51:57.853  - info: history.0 (5750) enabled logging of knx.0.Zentral.Daten.Heizkreis_VL (Count=46), Alias=false
              2023-09-17 14:52:00.030  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 5765
              2023-09-17 14:52:02.163  - info: powerfox2.0 (5765) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
              2023-09-17 14:52:05.873  - info: powerfox2.0 (5765) Terminated (NO_ERROR): Without reason
              2023-09-17 14:52:06.416  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
              2023-09-17 14:53:00.029  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 5806
              2023-09-17 14:53:01.991  - info: powerfox2.0 (5806) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
              2023-09-17 14:53:04.752  - info: powerfox2.0 (5806) Terminated (NO_ERROR): Without reason
              2023-09-17 14:53:05.282  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
              2023-09-17 14:54:00.068  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 5824
              2023-09-17 14:54:02.011  - info: powerfox2.0 (5824) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
              2023-09-17 14:54:04.541  - info: powerfox2.0 (5824) Terminated (NO_ERROR): Without reason
              2023-09-17 14:54:05.073  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
              2023-09-17 14:54:26.285  - info: admin.0 (5472) ==> Connected system.user.admin from ::ffff:192.168.10.67
              2023-09-17 14:55:00.075  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 5842
              2023-09-17 14:55:02.079  - info: powerfox2.0 (5842) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
              2023-09-17 14:55:06.338  - info: powerfox2.0 (5842) Terminated (NO_ERROR): Without reason
              2023-09-17 14:55:06.873  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
              2023-09-17 14:56:00.035  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 6097
              2023-09-17 14:56:02.166  - info: powerfox2.0 (6097) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
              2023-09-17 14:56:06.098  - info: powerfox2.0 (6097) Terminated (NO_ERROR): Without reason
              2023-09-17 14:56:06.639  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
              • I ioNewbie
                Skript v.2023-06-20
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : armhf
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                temp=43.8'C
                volt=0.8625V
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M          0B         99M
                         3794 M total memory
                          453 M used memory
                          533 M active memory
                         2586 M free memory
                           95 M buffer memory
                          658 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                2.4G    /var/
                1.8G    /var/log
                323M    /var/cache
                /usr/bin/npm            9.6.7
                /usr/bin/npx            9.6.7
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.3.5
                javascript:     7.1.4
                Adapter State
                + instance is alive
                Objects and States
                Objects:        2465
                States:         1871
                Pending Updates: 0
                #47
                Dann schau da mal rein.
                  I Offline
                  I Offline
                  ioNewbie
                  #48
                  @thomas-braun said in Hilfe! js-controller und javascript Problem:
                  dieses Log finde ich nicht. Es gibt nur diese hier:
                  pi@iobroker:~/.npm/_logs $ ls -ali
                  total 188
                  266656 drwxr-xr-x 2 pi pi   4096 Sep 17 14:55 .
                  266426 drwxr-xr-x 5 pi pi   4096 Sep 17 10:41 ..
                  266657 -rw-r--r-- 1 pi pi   2552 Sep  1  2022 2022-09-01T18_04_03_138Z-debug.log
                  266493 -rw-r--r-- 1 pi pi   1451 Sep 17 10:09 2023-09-17T08_09_18_724Z-debug-0.log
                  266498 -rw-r--r-- 1 pi pi   1491 Sep 17 10:09 2023-09-17T08_09_19_852Z-debug-0.log
                  268272 -rw-r--r-- 1 pi pi 142673 Sep 17 10:42 2023-09-17T08_41_41_026Z-debug-0.log
                  269827 -rw-r--r-- 1 pi pi   1548 Sep 17 10:42 2023-09-17T08_42_11_297Z-debug-0.log
                  270742 -rw-r--r-- 1 pi pi   1679 Sep 17 10:42 2023-09-17T08_42_13_793Z-debug-0.log
                  271160 -rw-r--r-- 1 pi pi   4060 Sep 17 10:43 2023-09-17T08_43_06_662Z-debug-0.log
                  268264 -rw-r--r-- 1 pi pi   1519 Sep 17 11:24 2023-09-17T09_24_42_119Z-debug-0.log
                  271161 -rw-r--r-- 1 pi pi   1557 Sep 17 11:24 2023-09-17T09_24_43_276Z-debug-0.log
                  271163 -rw-r--r-- 1 pi pi   1517 Sep 17 11:24 2023-09-17T09_24_44_442Z-debug-0.log
                  262153 -rw-r--r-- 1 pi pi   1818 Sep 17 14:55 2023-09-17T12_55_50_944Z-debug-0.log
                  • I ioNewbie
                    total 188
                    I Offline
                    I Offline
                    ioNewbie
                    #49
                    @ionewbie in dem jüngsten steht das hier drin:
                    pi@iobroker:~/.npm/_logs $ cat 2023-09-17T12_55_50_944Z-debug-0.log
                    0 verbose cli /usr/bin/node /usr/bin/npm
                    1 info using npm@9.6.7
                    2 info using node@v18.17.1
                    3 timing npm:load:whichnode Completed in 4ms
                    4 timing config:load:defaults Completed in 6ms
                    5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 5ms
                    6 timing config:load:builtin Completed in 6ms
                    7 timing config:load:cli Completed in 6ms
                    8 timing config:load:env Completed in 1ms
                    9 timing config:load:file:/opt/iobroker/.npmrc Completed in 5ms
                    10 timing config:load:project Completed in 8ms
                    11 timing config:load:file:/home/pi/.npmrc Completed in 1ms
                    12 timing config:load:user Completed in 2ms
                    13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
                    14 timing config:load:global Completed in 1ms
                    15 timing config:load:setEnvs Completed in 3ms
                    16 timing config:load Completed in 34ms
                    17 timing npm:load:configload Completed in 34ms
                    18 timing npm:load:mkdirpcache Completed in 0ms
                    19 timing npm:load:mkdirplogs Completed in 1ms
                    20 verbose title npm ls
                    21 verbose argv "ls"
                    22 timing npm:load:setTitle Completed in 4ms
                    23 timing config:load:flatten Completed in 10ms
                    24 timing npm:load:display Completed in 13ms
                    25 verbose logfile logs-max:10 dir:/home/pi/.npm/_logs/2023-09-17T12_55_50_944Z-
                    26 verbose logfile /home/pi/.npm/_logs/2023-09-17T12_55_50_944Z-debug-0.log
                    27 timing npm:load:logFile Completed in 30ms
                    28 timing npm:load:timers Completed in 1ms
                    29 timing npm:load:configScope Completed in 0ms
                    30 timing npm:load Completed in 90ms
                    31 timing arborist:ctor Completed in 2ms
                    32 silly logfile start cleaning logs, removing 1 files
                    33 silly logfile done cleaning log files
                    34 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.daikin-cloud
                    35 timing command:ls Completed in 4199ms
                    36 verbose exit 0
                    37 timing npm Completed in 4373ms
                    38 info ok
                    • I ioNewbie
                      36 verbose exit 0
                      38 info ok
                      #50
                      @ionewbie
                      Das log ist mit Sicherheit länger.
                        @ionewbie
                        I Offline
                        I Offline
                        ioNewbie
                        #51
                        @thomas-braun tatsächlich nein. ist ja auch von heute Mittag, die Upgrades sind höchstens eine Stunde her
                        hm.
                        • I ioNewbie
                          hm.
                          #52
                          @ionewbie
                          Dann schau per
                          cd /opt/iobroker && npm ls -a
                          an welcher Stelle im Tree die Meldungen auftauchen.
                            @ionewbie
                            Dann schau per
                            I Offline
                            I Offline
                            ioNewbie
                            #53
                            @thomas-braun nicht sicher ob ich jetzt verstanden habe. Geht es um Identifikation des NPM Ordners? das wäre bei execa@5.1.1
                            pi@iobroker:~ $ cd /opt/iobroker & npm ls -a
                            [1] 2960
                            pi@ /home/pi
                            └─┬ iobroker.js-controller@5.0.12
                              ├─┬ @alcalzone/esbuild-register@2.5.1-1
                              │ ├── esbuild@0.11.23
                              │ └── jsonc-parser@3.2.0
                              ├─┬ @iobroker/db-objects-file@5.0.12
                              │ ├─┬ @iobroker/db-base@5.0.12
                              │ │ ├── @iobroker/js-controller-common@5.0.12 deduped
                              │ │ ├── deep-clone@3.0.3 deduped
                              │ │ ├── fs-extra@11.1.1 deduped
                              │ │ └── respjs@4.2.0
                              │ ├── @iobroker/db-objects-redis@5.0.12 deduped
                              │ └── fs-extra@11.1.1 deduped
                              ├─┬ @iobroker/db-objects-jsonl@5.0.12
                              │ ├─┬ @alcalzone/jsonl-db@3.1.0
                              │ │ ├─┬ @alcalzone/proper-lockfile@4.1.3-0
                              │ │ │ ├── graceful-fs@4.2.11 deduped
                              │ │ │ ├── retry@0.12.0
                              │ │ │ └── signal-exit@3.0.7
                              │ │ ├─┬ alcalzone-shared@4.0.8
                              │ │ │ └── debug@4.3.4 deduped
                              │ │ └─┬ fs-extra@10.1.0
                              │ │   ├── jsonfile@6.1.0 deduped
                              │ │   └── universalify@2.0.0 deduped
                              │ ├── @iobroker/db-base@5.0.12 deduped
                              │ ├── @iobroker/db-objects-file@5.0.12 deduped
                              ├─┬ @iobroker/db-objects-redis@5.0.12
                              │ ├─┬ ioredis@4.28.5
                              │ │ ├── cluster-key-slot@1.1.2
                              │ │ ├── debug@4.3.4 deduped
                              │ │ ├── denque@1.5.1
                              │ │ ├── lodash.defaults@4.2.0
                              │ │ ├── lodash.flatten@4.4.0
                              │ │ ├── lodash.isarguments@3.1.0
                              │ │ ├── p-map@2.1.0
                              │ │ ├── redis-commands@1.7.0
                              │ │ ├── redis-errors@1.2.0
                              │ │ ├─┬ redis-parser@3.0.0
                              │ │ │ └── redis-errors@1.2.0 deduped
                              │ │ └── standard-as-callback@2.1.0
                              │ ├─┬ mime-types@2.1.35
                              │ │ └── mime-db@1.52.0
                              │ ├─┬ node.extend@2.0.2
                              │ │ ├─┬ has@1.0.3
                              │ │ │ └── function-bind@1.1.1
                              │ │ └── is@3.3.0
                              │ └── semver@7.5.4 deduped
                              ├─┬ @iobroker/db-states-file@5.0.12
                              │ └── @iobroker/db-states-redis@5.0.12 deduped
                              ├─┬ @iobroker/db-states-jsonl@5.0.12
                              │ ├── @alcalzone/jsonl-db@3.1.0 deduped
                              │ ├── @iobroker/db-states-file@5.0.12 deduped
                              ├─┬ @iobroker/db-states-redis@5.0.12
                              │ └── ioredis@4.28.5 deduped
                              ├─┬ @iobroker/js-controller-adapter@5.0.12
                              │ ├─┬ @alcalzone/pak@0.8.1
                              │ │ ├─┬ axios@0.26.1
                              │ │ │ └── follow-redirects@1.15.2 deduped
                              │ │ ├─┬ execa@5.1.1
                              │ │ │ ├─┬ cross-spawn@7.0.3
                              │ │ │ │ ├── path-key@3.1.1
                              │ │ │ │ ├─┬ shebang-command@2.0.0
                              │ │ │ │ │ └── shebang-regex@3.0.0
                              │ │ │ │ └─┬ which@2.0.2
                              │ │ │ │   └── isexe@2.0.0
                              │ │ │ ├── get-stream@6.0.1
                              │ │ │ ├── human-signals@2.1.0
                              │ │ │ ├── is-stream@2.0.1 deduped
                              │ │ │ ├── merge-stream@2.0.0
                              │ │ │ ├─┬ npm-run-path@4.0.1
                              │ │ │ │ └── path-key@3.1.1 deduped
                              │ │ │ ├─┬ onetime@5.1.2
                              │ │ │ │ └── mimic-fn@2.1.0
                              │ │ │ ├── signal-exit@3.0.7 deduped
                              │ │ │ └── strip-final-newline@2.0.0
                              │ ├── @iobroker/db-objects-jsonl@5.0.12 deduped
                              │ ├── @iobroker/db-states-jsonl@5.0.12 deduped
                              │ ├── @iobroker/db-states-redis@5.0.12 deduped
                              │ ├── @iobroker/js-controller-common-db@5.0.12 deduped
                              │ ├── @iobroker/plugin-base@1.2.1 deduped
                              │ ├── @iobroker/plugin-sentry@1.2.1 deduped
                              │ ├── jsonwebtoken@9.0.2 deduped
                              │ ├── node-schedule@2.1.1 deduped
                              │ ├── node.extend@2.0.2 deduped
                              │ ├── pidusage@3.0.2 deduped
                              │ ├── readline@1.3.0
                              ├─┬ @iobroker/js-controller-cli@5.0.12
                              │ ├── axios@1.5.0 deduped
                              │ ├─┬ chokidar@3.5.3
                              │ │ ├─┬ anymatch@3.1.3
                              │ │ │ ├── normalize-path@3.0.0 deduped
                              │ │ │ └── picomatch@2.3.1
                              │ │ ├─┬ braces@3.0.2
                              │ │ │ └─┬ fill-range@7.0.1
                              │ │ │   └─┬ to-regex-range@5.0.1
                              │ │ │     └── is-number@7.0.0
                              │ │ ├── UNMET OPTIONAL DEPENDENCY fsevents@~2.3.2
                              │ │ ├─┬ glob-parent@5.1.2
                              │ │ │ └── is-glob@4.0.3 deduped
                              │ │ ├─┬ is-binary-path@2.1.0
                              │ │ │ └── binary-extensions@2.2.0
                              │ │ ├─┬ is-glob@4.0.3
                              │ │ │ └── is-extglob@2.1.1
                              │ │ └─┬ readdirp@3.6.0
                              │ │   └── picomatch@2.3.1 deduped
                              │ ├── daemonize2@0.4.2 deduped
                              │ ├─┬ event-stream@4.0.1
                              │ │ ├── duplexer@0.1.2
                              │ │ ├── from@0.1.7
                              │ │ ├── map-stream@0.0.7
                              │ │ ├─┬ pause-stream@0.0.11
                              │ │ │ └── through@2.3.8 deduped
                              │ │ ├─┬ split@1.0.1
                              │ │ ├─┬ stream-combiner@0.2.2
                              │ │ │ ├── duplexer@0.1.2 deduped
                              │ ├── mime-types@2.1.35 deduped
                              │ ├── readline-sync@1.4.10 deduped
                              │ ├── semver@7.5.4 deduped
                              │ └─┬ yargs@17.7.2
                              │   ├─┬ cliui@8.0.1
                              │   │ ├── string-width@4.2.3 deduped
                              │   │ ├─┬ strip-ansi@6.0.1
                              │   │ │ └── ansi-regex@5.0.1
                              │   │ └─┬ wrap-ansi@7.0.0
                              │   │   ├─┬ ansi-styles@4.3.0
                              │   │   │ └─┬ color-convert@2.0.1
                              │   │   │   └── color-name@1.1.4
                              │   │   └── strip-ansi@6.0.1 deduped
                              │   ├── escalade@3.1.1
                              │   ├── get-caller-file@2.0.5
                              │   ├── require-directory@2.1.1
                              │   ├─┬ string-width@4.2.3
                              │   │ ├── emoji-regex@8.0.0
                              │   │ ├── is-fullwidth-code-point@3.0.0
                              │   ├── y18n@5.0.8
                              │   └── yargs-parser@21.1.1
                              ├─┬ @iobroker/js-controller-common-db@5.0.12
                              │ ├─┬ winston-seq-updated@1.0.4
                              │ │ ├── seq-logging@0.4.6
                              │ │ └── winston-transport@4.5.0 deduped
                              │ └─┬ winston-syslog@2.7.0
                              │   ├── glossy@0.1.7
                              │   ├─┬ unix-dgram@2.0.6
                              │   │ ├─┬ bindings@1.5.0
                              │   │ │ └── file-uri-to-path@1.0.0
                              │   │ └── nan@2.18.0 deduped
                              │   └── winston@3.10.0 deduped
                              ├─┬ @iobroker/js-controller-common@5.0.12
                              │ ├── @alcalzone/pak@0.8.1 deduped
                              │ ├─┬ @datalust/winston-seq@1.0.2
                              │ │ ├── seq-logging@1.1.2
                              │ │ ├── winston-transport@4.5.0 deduped
                              │ │ └── winston@3.10.0 deduped
                              │ ├── ci-info@3.8.0
                              │ ├─┬ diskusage@1.2.0
                              │ │ ├── es6-promise@4.2.8
                              │ │ └── nan@2.18.0
                              │ ├── event-stream@4.0.1 deduped
                              │ ├── node-forge@1.3.1
                              │ ├── promisify-child-process@4.1.2 deduped
                              │ ├── readline@1.3.0 deduped
                              │ ├── triple-beam@1.4.1
                              │ ├─┬ winston-daily-rotate-file@4.7.1
                              │ │ ├─┬ file-stream-rotator@0.6.1
                              │ │ │ └── moment@2.29.4
                              │ │ ├── object-hash@2.2.0
                              │ │ ├── triple-beam@1.4.1 deduped
                              │ ├── winston-syslog@2.7.0 deduped
                              │ ├─┬ winston-transport@4.5.0
                              │ │ ├─┬ logform@2.5.1
                              │ │ │ ├── @colors/colors@1.5.0 deduped
                              │ │ │ ├── @types/triple-beam@1.3.3
                              │ │ │ ├── fecha@4.2.3
                              │ │ │ ├── ms@2.1.2 deduped
                              │ │ │ ├── safe-stable-stringify@2.4.3 deduped
                              │ │ │ └── triple-beam@1.4.1 deduped
                              │ │ ├─┬ readable-stream@3.6.2
                              │ │ │ ├── inherits@2.0.4 deduped
                              │ │ │ ├── string_decoder@1.1.1 deduped
                              │ │ │ └── util-deprecate@1.0.2 deduped
                              │ └─┬ winston@3.10.0
                              │   ├─┬ @dabh/diagnostics@2.0.3
                              │   │ ├─┬ colorspace@1.1.4
                              │   │ │ ├─┬ color@3.2.1
                              │   │ │ │ ├─┬ color-convert@1.9.3
                              │   │ │ │ │ └── color-name@1.1.3
                              │   │ │ │ └─┬ color-string@1.9.1
                              │   │ │ │   ├── color-name@1.1.3 deduped
                              │   │ │ │   └─┬ simple-swizzle@0.2.2
                              │   │ │ │     └── is-arrayish@0.3.2
                              │   │ │ └── text-hex@1.0.0
                              │   │ ├── enabled@2.0.0
                              │   │ └── kuler@2.0.0
                              │   ├── async@3.2.3 deduped
                              │   ├── logform@2.5.1 deduped
                              │   ├─┬ one-time@1.0.0
                              │   │ └── fn.name@1.1.0
                              │   ├── stack-trace@0.0.10
                              ├─┬ @iobroker/plugin-sentry@1.2.1
                              │ ├─┬ @sentry/integrations@7.69.0
                              │ │ ├── @sentry/types@7.69.0
                              │ │ ├─┬ @sentry/utils@7.69.0
                              │ │ │ ├── @sentry/types@7.69.0 deduped
                              │ │ │ └── tslib@2.6.2 deduped
                              │ │ ├─┬ localforage@1.10.0
                              │ │ │ └─┬ lie@3.1.1
                              │ │ │   └── immediate@3.0.6 deduped
                              │ │ └── tslib@2.6.2
                              │ ├─┬ @sentry/node@7.69.0
                              │ │ ├─┬ @sentry-internal/tracing@7.69.0
                              │ │ │ ├── @sentry/core@7.69.0 deduped
                              │ │ │ ├── @sentry/utils@7.69.0 deduped
                              │ │ ├─┬ @sentry/core@7.69.0
                              │ │ ├── cookie@0.4.2
                              │ │ ├─┬ https-proxy-agent@5.0.1
                              │ │ │ ├─┬ agent-base@6.0.2
                              │ │ │ │ └── debug@4.3.4 deduped
                              │ │ ├── lru_map@0.3.3
                              │ └─┬ source-map-support@0.5.21
                              │   ├── buffer-from@1.1.2
                              │   └── source-map@0.6.1
                              ├─┬ axios@1.5.0
                              │ ├── follow-redirects@1.15.2
                              │ ├─┬ form-data@4.0.0
                              │ │ ├── asynckit@0.4.0
                              │ │ ├─┬ combined-stream@1.0.8
                              │ │ │ └── delayed-stream@1.0.0
                              │ │ └── mime-types@2.1.35 deduped
                              │ └── proxy-from-env@1.1.0
                              ├─┬ debug@4.3.4
                              │ └── ms@2.1.2
                              ├─┬ decache@4.6.2
                              │ └── callsite@1.0.0
                              ├─┬ fs-extra@11.1.1
                              │ ├─┬ jsonfile@6.1.0
                              ├─┬ greenlock-express@4.0.3
                              │ ├─┬ @root/greenlock-express@4.0.4
                              │ │ ├── @root/greenlock@4.0.5 deduped
                              │ │ └── redirect-https@1.3.1 deduped
                              │ ├─┬ @root/greenlock@4.0.5
                              │ │ ├── @greenlock/manager@3.1.0 deduped
                              │ │ ├── @root/acme@3.1.0 deduped
                              │ │ ├── @root/csr@0.8.1 deduped
                              │ │ ├─┬ @root/keypairs@0.10.3
                              │ │ │ ├── @root/encoding@1.0.1 deduped
                              │ │ │ ├── @root/pem@1.0.4 deduped
                              │ │ │ └── @root/x509@0.7.2 deduped
                              │ │ ├── @root/mkdirp@1.0.0 deduped
                              │ │ ├── @root/request@1.9.2 deduped
                              │ │ ├── acme-http-01-standalone@3.0.5 deduped
                              │ │ ├── cert-info@1.5.1 deduped
                              │ │ ├── greenlock-store-fs@3.2.2 deduped
                              │ │ └── safe-replace@1.1.0 deduped
                              │ └─┬ redirect-https@1.3.1
                              │   └── escape-html@1.0.3
                              ├─┬ greenlock@4.0.4
                              │ ├─┬ @greenlock/manager@3.1.0
                              │ │ └─┬ greenlock-manager-fs@3.1.1
                              │ ├─┬ @root/acme@3.1.0
                              │ │ └─┬ @root/x509@0.7.2
                              │ │   ├── @root/asn1@1.0.0 deduped
                              │ │   └── @root/encoding@1.0.1 deduped
                              │ ├─┬ @root/csr@0.8.1
                              │ │ ├─┬ @root/asn1@1.0.0
                              │ │ │ └── @root/encoding@1.0.1 deduped
                              │ ├─┬ @root/keypairs@0.9.0
                              │ ├─┬ greenlock-store-fs@3.2.2
                              ├─┬ jsonwebtoken@9.0.2
                              │ ├─┬ jws@3.2.2
                              │ │ ├─┬ jwa@1.4.1
                              │ │ │ ├── buffer-equal-constant-time@1.0.1
                              │ │ │ ├─┬ ecdsa-sig-formatter@1.0.11
                              │ │ │ │ └── safe-buffer@5.2.1 deduped
                              │ ├── lodash.includes@4.3.0
                              │ ├── lodash.isboolean@3.0.3
                              │ ├── lodash.isinteger@4.0.4
                              │ ├── lodash.isnumber@3.0.3
                              │ ├── lodash.isplainobject@4.0.6
                              │ ├── lodash.isstring@4.0.1
                              │ ├── lodash.once@4.1.1
                              ├─┬ jszip@3.10.1
                              │ ├─┬ lie@3.3.0
                              │ ├── pako@1.0.11
                              │ ├─┬ readable-stream@2.3.8
                              │ │ ├── core-util-is@1.0.3
                              │ │ ├── isarray@1.0.0
                              │ │ ├── process-nextick-args@2.0.1
                              │ │ ├── safe-buffer@5.1.2
                              │ │ ├─┬ string_decoder@1.1.1
                              │ │ │ └── safe-buffer@5.1.2
                              │ └── setimmediate@1.0.5
                              ├─┬ le-acme-core@2.1.4
                              │ ├─┬ request@2.88.2
                              │ │ ├── aws-sign2@0.7.0
                              │ │ ├── aws4@1.12.0
                              │ │ ├── caseless@0.12.0
                              │ │ ├── combined-stream@1.0.8 deduped
                              │ │ ├── extend@3.0.2
                              │ │ ├── forever-agent@0.6.1
                              │ │ ├─┬ form-data@2.3.3
                              │ │ │ ├── asynckit@0.4.0 deduped
                              │ │ │ ├── combined-stream@1.0.8 deduped
                              │ │ │ └── mime-types@2.1.35 deduped
                              │ │ ├─┬ har-validator@5.1.5
                              │ │ │ ├─┬ ajv@6.12.6
                              │ │ │ │ ├── fast-deep-equal@3.1.3
                              │ │ │ │ ├── fast-json-stable-stringify@2.1.0
                              │ │ │ │ ├── json-schema-traverse@0.4.1
                              │ │ │ │ └─┬ uri-js@4.4.1
                              │ │ │ │   └── punycode@2.3.0 deduped
                              │ │ │ └── har-schema@2.0.0
                              │ │ ├─┬ http-signature@1.2.0
                              │ │ │ ├── assert-plus@1.0.0
                              │ │ │ ├─┬ jsprim@1.4.2
                              │ │ │ │ ├── assert-plus@1.0.0 deduped
                              │ │ │ │ ├── extsprintf@1.3.0
                              │ │ │ │ ├── json-schema@0.4.0
                              │ │ │ │ └─┬ verror@1.10.0
                              │ │ │ │   ├── core-util-is@1.0.2
                              │ │ │ │   └── extsprintf@1.3.0 deduped
                              │ │ │ └─┬ sshpk@1.17.0
                              │ │ │   ├─┬ asn1@0.2.6
                              │ │ │   │ └── safer-buffer@2.1.2 deduped
                              │ │ │   ├─┬ bcrypt-pbkdf@1.0.2
                              │ │ │   │ └── tweetnacl@0.14.5 deduped
                              │ │ │   ├─┬ dashdash@1.14.1
                              │ │ │   │ └── assert-plus@1.0.0 deduped
                              │ │ │   ├─┬ ecc-jsbn@0.1.2
                              │ │ │   │ ├── jsbn@0.1.1 deduped
                              │ │ │   ├─┬ getpass@0.1.7
                              │ │ │   ├── safer-buffer@2.1.2
                              │ │ ├── is-typedarray@1.0.0
                              │ │ ├── isstream@0.1.2
                              │ │ ├── json-stringify-safe@5.0.1
                              │ │ ├── mime-types@2.1.35 deduped
                              │ │ ├── oauth-sign@0.9.0
                              │ │ ├── performance-now@2.1.0
                              │ │ ├── qs@6.5.3
                              │ │ ├── safe-buffer@5.2.1 deduped
                              │ │ ├─┬ tough-cookie@2.5.0
                              │ │ │ ├── psl@1.9.0
                              │ │ ├─┬ tunnel-agent@0.6.0
                              │ │ └── uuid@3.4.0
                              │ └─┬ rsa-compat@1.9.4
                              │   ├─┬ keypairs@1.2.14
                              │   │ ├── eckles@1.4.1
                              │   │ └── rasha@1.2.5
                              │   ├── node-forge@0.7.6
                              │   └─┬ ursa-optional@0.9.10
                              │     ├── bindings@1.5.0 deduped
                              ├─┬ le-challenge-fs@2.0.9
                              │ └── @root/mkdirp@1.0.0 deduped
                              ├── le-sni-auto@2.1.9
                              ├─┬ loadavg-windows@1.1.1
                              │ └── weak-daemon@1.0.3
                              ├─┬ node-schedule@2.1.1
                              │ ├─┬ cron-parser@4.9.0
                              │ │ └── luxon@3.4.3
                              │ ├── long-timeout@0.1.1
                              │ └── sorted-array-functions@1.3.0
                              ├─┬ pidusage@3.0.2
                              ├─┬ prompt@1.3.0
                              │ ├── async@3.2.3
                              │ ├─┬ read@1.0.7
                              │ │ └── mute-stream@0.0.8
                              │ ├── revalidator@0.1.8
                              │ └─┬ winston@2.4.7
                              │   ├─┬ async@2.6.4
                              │   │ └── lodash@4.17.21
                              │   ├── colors@1.0.3
                              │   ├── cycle@1.0.3
                              │   ├── eyes@0.1.8
                              │   ├── isstream@0.1.2 deduped
                              │   └── stack-trace@0.0.10 deduped
                              ├─┬ semver@7.5.4
                              │ └─┬ lru-cache@6.0.0
                              │   └── yallist@4.0.0 deduped
                              └─┬ tar@6.2.0
                                ├── chownr@2.0.0
                                ├─┬ fs-minipass@2.1.0
                                │ └─┬ minipass@3.3.6
                                ├── minipass@5.0.0
                                ├─┬ minizlib@2.1.2
                                │ ├─┬ minipass@3.3.6
                                │ │ └── yallist@4.0.0 deduped
                                ├── mkdirp@1.0.4
                                └── yallist@4.0.0
                            [1]+  Done                    cd /opt/iobroker
                            • I ioNewbie
                              [1] 2960
                              pi@ /home/pi
                                │ │ ├── p-map@2.1.0
                                │ │ ├─┬ has@1.0.3
                                │ │ └── is@3.3.0
                                │ │ ├─┬ execa@5.1.1
                                │ │ ├── from@0.1.7
                                │ │ ├─┬ split@1.0.1
                                │ └─┬ yargs@17.7.2
                                │   ├─┬ cliui@8.0.1
                                │   ├── y18n@5.0.8
                                │   ├── glossy@0.1.7
                                │ ├── ci-info@3.8.0
                                │ │ └── nan@2.18.0
                                │   │ └── kuler@2.0.0
                                │ │ │ └─┬ lie@3.1.1
                                │ │ └── tslib@2.6.2
                                ├─┬ axios@1.5.0
                                ├─┬ debug@4.3.4
                                │ └── ms@2.1.2
                                ├─┬ decache@4.6.2
                                ├─┬ fs-extra@11.1.1
                                ├─┬ greenlock@4.0.4
                                │ ├─┬ jws@3.2.2
                                │ │ ├─┬ jwa@1.4.1
                                ├─┬ jszip@3.10.1
                                │ ├─┬ lie@3.3.0
                                │ ├── pako@1.0.11
                                │ │ ├── aws4@1.12.0
                                │ │ ├── qs@6.5.3
                                │ │ │ ├── psl@1.9.0
                                │ │ └── uuid@3.4.0
                                │   │ └── rasha@1.2.5
                                │ │ └── luxon@3.4.3
                                ├─┬ pidusage@3.0.2
                                ├─┬ prompt@1.3.0
                                │ ├── async@3.2.3
                                │ ├─┬ read@1.0.7
                                │ └─┬ winston@2.4.7
                                │   ├─┬ async@2.6.4
                                │   ├── colors@1.0.3
                                │   ├── cycle@1.0.3
                                │   ├── eyes@0.1.8
                                ├─┬ semver@7.5.4
                                └─┬ tar@6.2.0
                                  ├── chownr@2.0.0
                                  ├── minipass@5.0.0
                                  ├─┬ minizlib@2.1.2
                                  ├── mkdirp@1.0.4
                                  └── yallist@4.0.0
                              #54
                              @ionewbie
                              Sorry, mein Fehler.
                              Aber dadurch haben wir eine Parallel-Installation in /home/pi gefunden.
                              Du hast also irendwie da was 'daneben' geworfen.
                              In den Heimverzeichnissen der user muss das so aussehen (auf meiner Kiste):
                              echad@chet:~ $ npm ls -a
                              /home/echad
                              └── (empty)
                              echad@chet:~ $ cd /home/iobroker/
                              echad@chet:/home/iobroker $ npm ls -a
                              /home/iobroker
                              └── (empty)
                                @ionewbie
                                Sorry, mein Fehler.
                                /home/echad
                                └── (empty)
                                /home/iobroker
                                └── (empty)
                                I Offline
                                I Offline
                                ioNewbie
                                schrieb am zuletzt editiert von ioNewbie
                                #55
                                @thomas-braun hm, keine Ahnung, zumindest nicht bewußt.
                                Was ist jetzt als nächstes dran? der js-controller ist ja immer noch auf altem Stand
                                • I ioNewbie
                                  #56
                                  @ionewbie
                                  Ich würde das Verzeichnis node_modules aus den Homes der user löschen. Schau bei deinem Standarduser und dem iobroker rein.
                                    @ionewbie
                                    I Offline
                                    I Offline
                                    ioNewbie
                                    #57
                                    @thomas-braun äh... moment.
                                    Standarduser / Normaluser?
                                    Ich habe den PI nur für IOB und das hab ich wohl mal mit dem pi installiert. da mache ich nichts anderes.
                                    Was genau meinst du was ich tun soll?
                                    • I ioNewbie
                                      I Offline
                                      I Offline
                                      ioNewbie
                                      #58
                                      @ionewbie unter /homes habe ich iobroker und pi.
                                      überall klebt das aktuelle Datum dran:
                                      pi@iobroker:/home $ ls -ali
                                      total 16
                                       16385 drwxr-xr-x  4 root     root     4096 Sep  1  2022 .
                                           2 drwxr-xr-x 18 root     root     4096 Sep 17 09:55 ..
                                      131490 drwxr-xr-x  5 iobroker iobroker 4096 Sep 17 11:24 iobroker
                                         873 drwxr-xr-x  9 pi       pi       4096 Sep 17 12:24 pi
                                      In iobroker sieht es so aus:
                                      pi@iobroker:/home/iobroker $ ls -ali
                                      total 76
                                      131490 drwxr-xr-x 5 iobroker iobroker  4096 Sep 17 11:24 .
                                       16385 drwxr-xr-x 4 root     root      4096 Sep  1  2022 ..
                                      131518 -rw-r--r-- 1 iobroker iobroker   220 Jan  3  2021 .bash_logout
                                      131520 -rw-r--r-- 1 iobroker iobroker  3523 Apr  4  2022 .bashrc
                                      131966 drwxr-xr-x 4 iobroker iobroker  4096 Sep 17 08:54 .cache
                                      136594 drwx------ 3 iobroker iobroker  4096 Sep  1  2022 .config
                                      140520 -rw-r--r-- 1 iobroker iobroker 13830 Sep 17 14:55 .diag.sh
                                      140566 -rw-r--r-- 1 iobroker iobroker 18783 Sep 17 14:56 iob_diag.log
                                      131492 -rw-r--r-- 1 iobroker iobroker  1670 Jul 10  2021 .mkshrc
                                      131522 drwxr-xr-x 6 iobroker iobroker  4096 Sep 17 10:12 .npm
                                      131519 -rw-r--r-- 1 iobroker iobroker   807 Jan  3  2021 .profile
                                      • I ioNewbie
                                        total 16
                                        total 76
                                        #59
                                        @ionewbie
                                        cd
                                        ls -lAh
                                          @ionewbie
                                          cd
                                          ls -lAh
                                          I Offline
                                          I Offline
                                          ioNewbie
                                          #60
                                          ls -lAh
                                          pi@iobroker:/home $ ls -lAh
                                          total 8.0K
                                          drwxr-xr-x 5 iobroker iobroker 4.0K Sep 17 11:24 iobroker
                                          drwxr-xr-x 9 pi       pi       4.0K Sep 17 12:24 pi
