  5. Einschaltwert über Temperatur erfassen
59 Beiträge 4 Kommentatoren 5.5k Aufrufe 2 Beobachtet
  • S siporax
    @homoran said in Einschaltwert über Temperatur erfassen:
    @siporax sagte in Einschaltwert über Temperatur erfassen:
    hoffe es stimmt so.
    was soll denn aktualisiert werden?
     <variables>
       <variable id="+#q}sbU;cU9]yxO-lDC1">Abweichung</variable>
     </variables>
     <block type="variables_set" id="m?]6iqd-!BOn;lQIEdlV" x="116" y="-652">
       <field name="VAR" id="+#q}sbU;cU9]yxO-lDC1">Abweichung</field>
       <value name="VALUE">
         <block type="math_number" id="rh?cgbnCT3E|rIVaG69W">
           <field name="NUM">1</field>
         </block>
       </value>
       <next>
         <block type="on" id="QaUb7$N.YH1?Iogdb[{W">
           <field name="OID">sonoff.0.Warmwasserspeicher.DS18B20_Temperature</field>
           <statement name="STATEMENT">
             <block type="update" id=".v~P?b)=F~4laQPnl~S.">
                 <block type="logic_compare" id="MgS(TzKR(xPov)|.~;%O">
                   <field name="OP">GTE</field>
                   <value name="A">
                     <block type="on_source" id="J2hqtFqsn6O!pFKR,#H9">
                     </block>
                   </value>
                   <value name="B">
                     <block type="math_arithmetic" id="p?y$yYdJ-URA?~Po4l6(">
                       <field name="OP">ADD</field>
                       <value name="A">
                         <shadow type="math_number" id="M`@JEV9s?e,!JQC4N^GN">
                         </shadow>
                         <block type="on_source" id="A5MDlg,KSM,?lgS9U8ly">
                           <field name="ATTR">oldState.val</field>
                         </block>
                       </value>
                       <value name="B">
                         <shadow type="math_number" id="X~ud,RTMt$ODVg?zw{%Q">
                         </shadow>
                         <block type="variables_get" id="!dtv=owCSg{[DOls3QU/">
                         </block>
                       </value>
                     </block>
                   </value>
                 </block>
               </value>
               <next>
                 <block type="update" id="t#CHnKUJ{C=jXlNVj*Hv">
                     <block type="logic_compare" id="FM*`IS(FeVro?+=h.4r0">
                       <field name="OP">LTE</field>
                       <value name="A">
                         <block type="on_source" id="ALW/S$nM?Eg,o=JYW~@]">
                         </block>
                       </value>
                       <value name="B">
                         <block type="math_arithmetic" id="%iWJES=TpBGg*JbP|-MU">
                           <value name="A">
                             <shadow type="math_number">
                             </shadow>
                             <block type="on_source" id="@GtHbeHU4`@Z[){cYvqW">
                             </block>
                           </value>
                           <value name="B">
                             </shadow>
                             <block type="variables_get" id="?M@%.K3@m]|]Q-R}Yj8q">
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                 </block>
               </next>
             </block>
           </statement>
         </block>
       </next>
     </block>
    </xml>
    @siporax was willst du mir mit einer xml-Datei sagen?
    • T ticaki
      @siporax
      Das geht so eher nicht. Mit Triggern hast du keine feste Zeitvorgabe. Zeitplan alten Wert speichern und mit neuem Vergleichen. Das geht zwar auch mit Triggern aber dann muß du zumindest die alten Werte speichern bis die Abweichung zutrifft und erst dann den alten Wert neu speichern.
      @ticaki sagte in Einschaltwert über Temperatur erfassen:
      wo kommt jetzt dauernd diese Zeit her?
      davon steht nichts im Eröffnungspost
      S T 2 Antworten Letzte Antwort
        siporax
        schrieb am zuletzt editiert von siporax
        Wenn ich das im Intervall laufen lasse hätte ich doch eine Zeitangabe oder nicht?
        Habe die Zeit im Eröffnungspost Nachgetragen
        • T ticaki
          @siporax
          Der DS18B20 sendet den Wert zu oft, so dass die Temperaturdifferenz von 1 K zum vorherigen Wert nie zustande kommt. Deshalb:
          HomoranH S 3 Antworten Letzte Antwort
          • T ticaki
            @siporax
            siporax
            @ticaki Bin schon froh das ich das so hinbekommen haben :) das überfordert meine Kentnisse
              @paul53 sagte in Einschaltwert über Temperatur erfassen:
              dann könnte man mit (Timestamp - last Timestamp) arbeiten und die Entscheidung an der Kürze der Differenz festmachen
                T Nicht stören
                T Nicht stören
                ticaki
                Denke plus 1 °C sollte reichen für den Ein zu Signalisieren zu erfassen.
                Für den Aus Zustande dann minus 0,5°C.
                Also wenn die Temperatur dann nach 30 Minuten um 0,5C° gefallen ist, signalisieren wir aus. :) Daher die Zeitkomponente.
                @siporax
                Schau dir das von Paul an, gut umgesetzt wie immer.
                Spenden
                  siporax
                  @paul53 Danke Paul das muss ich ertmal nachbauen in Blockly und Testen
                  • T ticaki
                    @siporax
                    @ticaki siehe letzten Post von mir.
                    dann arbeitet man eventbasiert und hat trotzdem die Zeit berücksichtigt
                      T Nicht stören
                      T Nicht stören
                      ticaki
                      hehe... Zeiten brauchste dabei aber auch... und das wird imho tatsächlich kompliziert.
                      Spenden
                        siporax
                        @paul53 Kannste mir das script zur verfügung stellen ?
                        Das möchte ich fehlerfrei übernehmen,wenn das geht.
                        • S siporax
                          @siporax sagte: script zur verfügung stellen ?
                           <variables>
                             <variable id="Vn6j?jOO?$kDTnqTWGfU">lastTemp</variable>
                             <variable id="JV,7/}p(l?3Qii59u`wo">temp</variable>
                             <variable id="L:#sVF3F*)ZIZ7+wyOUD">istEin</variable>
                           </variables>
                           <block type="variables_set" id="]!T`lxoBB4d;Cg!NZ]}|" x="-662" y="-1163">
                             <field name="VAR" id="Vn6j?jOO?$kDTnqTWGfU">lastTemp</field>
                               <block type="get_value" id="Iz2p*j8Ax;+XzF=rVKhl">
                                 <field name="OID">0_userdata.0.Blockly.Temperatur</field>
                               </block>
                             </value>
                             <next>
                               <block type="schedule" id="9vy9?l/Ip;~mD-a8NGT4">
                                 <field name="SCHEDULE">*/5 * * * *</field>
                                   <block type="variables_set" id="U2YZi=*EcWMmgr5TH/5B">
                                     <field name="VAR" id="JV,7/}p(l?3Qii59u`wo">temp</field>
                                       <block type="get_value" id="N5#;gX!iV_`9;l3@%8cd">
                                       </block>
                                     </value>
                                     <next>
                                       <block type="controls_if" id="yoQjZl{f2D5XcmPJfuK!">
                                         <value name="IF0">
                                           <block type="logic_compare" id="X9VwCHq$Ikow)bf5R)$P">
                                             <value name="A">
                                               <block type="variables_get" id="4pB((16P$wnIiV:_RW{m">
                                               </block>
                                             </value>
                                             <value name="B">
                                               <block type="math_arithmetic" id="-ypD2~#RlcvCw8G=N2QT">
                                                 <value name="A">
                                                   <shadow type="math_number" id="dDkgt-`Ih))K6]iktTJ$">
                                                   </shadow>
                                                   <block type="variables_get" id="eidIUFk]Uy{qD6:s)P7W">
                                                   </block>
                                                 </value>
                                                 <value name="B">
                                                   <shadow type="math_number" id="m47!La,.3r!*:kGOG:i_">
                                                   </shadow>
                                                 </value>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <statement name="DO0">
                                           <block type="variables_set" id="|;r)}t;NdlJK:U%qf@p@">
                                             <field name="VAR" id="L:#sVF3F*)ZIZ7+wyOUD">istEin</field>
                                               <block type="logic_boolean" id="Lte;~5RI[HxZmV~:9,l?">
                                               </block>
                                             </value>
                                           </block>
                                         </statement>
                                         <value name="IF1">
                                           <block type="logic_compare" id="Q8YL?;2opW^@CduOyRkJ">
                                             <value name="A">
                                               <block type="variables_get" id="-Z_l4#mR/3NfnymU9R+m">
                                               </block>
                                             </value>
                                             <value name="B">
                                               <block type="math_arithmetic" id="egk=Qz=iAzK-r!HiBrNu">
                                                 <value name="A">
                                                   </shadow>
                                                   <block type="variables_get" id="TmLPt[P}QkHvB:Lf*dV}">
                                                   </block>
                                                 </value>
                                                 <value name="B">
                                                   <shadow type="math_number" id="V;G{]7/Ek0s|@*?,($6q">
                                                     <field name="NUM">0.5</field>
                                                   </shadow>
                                                 </value>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <statement name="DO1">
                                           <block type="variables_set" id=",!.Ij;r44xuub.^h%{pf">
                                               <block type="logic_boolean" id="6oVc%{sJAP#|aG2JW;F6">
                                               </block>
                                             </value>
                                           </block>
                                         </statement>
                                         <next>
                                           <block type="update" id="LoMN_Gt.CbXa^4?p?vjq">
                                             <field name="OID">0_userdata.0.Blockly.WP</field>
                                               <block type="variables_get" id="mRHB]k/b2+EI3]6i#%/[">
                                               </block>
                                             </value>
                                             <next>
                                               <block type="variables_set" id="q=1q;b5nA-;`bgbI8z/d">
                                                   <block type="variables_get" id="U!0X(O3pQvmbqtV:lJ]y">
                                                   </block>
                                                 </value>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </statement>
                               </block>
                             </next>
                           </block>
                          </xml>
                             <variables>
                             </variables>
                                 </block>
                               </value>
                               <next>
                                         </block>
                                       </value>
                                       <next>
                                           <value name="IF0">
                                               <value name="A">
                                                 </block>
                                               </value>
                                               <value name="B">
                                                   <value name="A">
                                                     </shadow>
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     </shadow>
                                                   </value>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                                 </block>
                                               </value>
                                             </block>
                                           </statement>
                                           <value name="IF1">
                                               <value name="A">
                                                 </block>
                                               </value>
                                               <value name="B">
                                                   <value name="A">
                                                     </shadow>
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     </shadow>
                                                   </value>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                                 </block>
                                               </value>
                                             </block>
                                           </statement>
                                           <next>
                                                 </block>
                                               </value>
                                               <next>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </statement>
                                 </block>
                               </next>
                             </block>
                            </xml>
                            siporax
                            @paul53 muss den Ordner erstellen ?
                            • S siporax
                              @siporax sagte: muss den Ordner erstellen ?
                              Nein, dort muss die DS18B20-Temperatur zugewiesen werden.
                              Für "WP" muss ein eigener Datenpunkt unter "0_userdata.0" vom Typ "Logikwert" vorhanden sein / erstellt werden.
                                siporax
                                @paul53 Ok Datenpunkt erstellt.
                                Was ich noch nicht verstehe wo wird mein Relais nun geschaltet in dem Script.
                                Das brauche ich um das im Vis darstellen zu können oder bin ich da falsch?
                                Oder kann ich den Datenpunkt direkt dazu verwenden ?
                                • paul53P Offline
                                  @siporax sagte: wo wird mein Relais nun geschaltet in dem Script.
                                  Weshalb ein Relais schalten?
                                  Ja, der eigene Datenpunkt kann in Vis verwendet werden.
                                    siporax
                                    @paul53 said in Einschaltwert über Temperatur erfassen:
                                    Klasse ,Danke ich teste das mal
                                    • S siporax
                                      @siporax sagte: ich teste das mal
                                      Ich habe das Skript noch um die Initialisierung von istEin bei Skriptstart erweitert:
                                        siporax
                                        @paul53 Mache ich gleich.
                                        Habe mal nachgemessen ich habe in 16 Minuten einen Temperaturabfall von 0,1°C im Speicher.
                                        Ist doch lang für das Script.
                                        Denke er Vergleich ja nur 1x oder vergleich er immer wieder bis sich das was ändert und die 5 Minuten stoßen das nur wieder von vorne an?
                                        • S siporax
                                          @siporax sagte: habe in 16 Minuten einen Temperaturabfall von 0,1°C im Speicher.
                                          Dann passen Prüfung alle 5 Minuten und Abfall von 0,5 K nicht.
                                          Es wird alle 5 Minuten verglichen.
