  4. Fire TV Adapter
Fire TV Adapter
181 Beiträge 41 Kommentatoren 68.6k Aufrufe 29 Beobachtet
  • J JoergH
    @joergh ...und hier noch der Adapter....
    Er findet kein FireTV, obwohl ich zwei Stück im Netz habe.
    Manuell lässt sich das adb aber mit dem FireTV verbinden...
    #141
    @joergh Schau in das richtige log file, z. B. mit
    tail -f /opt/iobroker/log/iobroker.current.log
    Aus der Konsole bitte keine Screenshots posten. Als Text in CodeTags eingebettet hier rein.
    Ein mehr oder weniger sauberer Start des Adapters sieht dann so aus:
    2021-05-11 21:30:22.752  - info: host.chet instance system.adapter.firetv.0 started with pid 2517
    2021-05-11 21:30:24.374  - info: firetv.0 (2517) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.firetv, node: v14.16.1, js-controller: 3.3.8
    2021-05-11 21:30:24.545  - error: firetv.0 (2517) ID: 192.168.178.38 Error=Failure: 'device unauthorized.
    This adb server's $ADB_VENDOR_KEYS is not set
    Try 'adb kill-server' if that seems wrong.
    Otherwise check for a confirmation dialog on your device.'
    2021-05-11 21:30:24.546  - error: firetv.0 (2517) ID: 192.168.178.38 Error=Failure: 'device unauthorized.
    2021-05-11 21:30:24.656  - info: firetv.0 (2517) 192.168.178.38: ADB version: 39, Android Version: , API Level:
    2021-05-11 21:31:08.957  - info: host.chet stopInstance system.adapter.firetv.0 (force=false, process=true)
    2021-05-11 21:31:08.965  - info: host.chet stopInstance system.adapter.firetv.0 send kill signal
    2021-05-11 21:31:08.967  - info: firetv.0 (2517) Got terminate signal TERMINATE_YOURSELF
    2021-05-11 21:31:08.971  - info: firetv.0 (2517) terminating
    2021-05-11 21:31:08.973  - info: firetv.0 (2517) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-05-11 21:31:09.554  - info: host.chet instance system.adapter.firetv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-05-11 21:31:12.010  - info: host.chet instance system.adapter.firetv.0 started with pid 2555
    2021-05-11 21:31:13.700  - info: firetv.0 (2555) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.firetv, node: v14.16.1, js-controller: 3.3.8
    2021-05-11 21:31:13.962  - info: firetv.0 (2555) 192.168.178.38: ADB version: 39, Android Version: , API Level:
    • J JoergH
      #142
      @joergh
      Der im Adapter-Setup erwähnte +-Button findet sich ganz unten etwas versteckt. Füge die Sticks manuell hinzu.
      J 1 Antwort Letzte Antwort
        @joergh
        JoergH
        schrieb am zuletzt editiert von JoergH
        #143
        Ok, habe ich gemacht und die Verbindung nun bestätigt. Scheint zu gehen. Vielen Dank!
        Leider zu früh gefreut. Er erkennt nun einen von den beiden, den anderen meldet er als "Offline", was aber nicht stimmt, da er an und im Netz ist. Beide werden also "aktiviert - false" im Adapter angezeigt...
        Bei mir laufen eine Menge Cronjobs, wie kann ich das Logfile denn filtern, ansonsten wird es unübersichtlich...?
        • J JoergH
          #144
          @joergh
          Das log file kannst du bezüglich des Adapters / adb gar nicht gut filtern, weil du keinen Begriff 'greppen' kannst.
          Wie eng getaktete crons haste denn da laufen? O-O
            @joergh
            JoergH
            #145
            2 Skripte jede Minute, die mir einige Debugs auswerfen...dazu kommen Routineabfragen einiger Adapter, z.B. ZOE2.0, der eine Seite dicht gepackt auswirft...über die Oberfläche vom ioBroker kann man das gut filtern, deshalb dachte ich das sei günstiger, da übersichtlicher...
            ich kann nochmal versuchen einen günstigen Moment zu erwischen...
            • J JoergH
              #146
              @joergh sagte in Fire TV Adapter:
              Stell das log level für die Dinger auf Error, dann hast du etwas Ruhe.
                JoergH
                #147
                Hab was:
                2021-05-11 22:16:03.753  - debug: firetv.0 (32055) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2021-05-11 22:16:03.795  - debug: firetv.0 (32055) Objects client ready ... initialize now
                2021-05-11 22:16:03.798  - debug: firetv.0 (32055) Objects create System PubSub Client
                2021-05-11 22:16:03.799  - debug: firetv.0 (32055) Objects create User PubSub Client
                2021-05-11 22:16:03.801  - debug: firetv.0 (32055) Objects client initialize lua scripts
                2021-05-11 22:16:03.830  - debug: firetv.0 (32055) Objects connected to redis: 127.0.0.1:9001
                2021-05-11 22:16:03.833  - silly: firetv.0 (32055) redis psubscribe cfg.o.system.user.*
                2021-05-11 22:16:03.840  - debug: firetv.0 (32055) objectDB connected
                2021-05-11 22:16:03.843  - debug: firetv.0 (32055) Redis States: Use Redis connection: 127.0.0.1:9000
                2021-05-11 22:16:03.855  - debug: firetv.0 (32055) States create System PubSub Client
                2021-05-11 22:16:03.856  - debug: firetv.0 (32055) States create User PubSub Client
                2021-05-11 22:16:03.870  - debug: firetv.0 (32055) States connected to redis: 127.0.0.1:9000
                2021-05-11 22:16:03.871  - debug: firetv.0 (32055) statesDB connected
                2021-05-11 22:16:04.696  - info: firetv.0 (32055) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.firetv, node: v12.22.1, js-controller: 3.2.16
                2021-05-11 22:16:04.756  - silly: firetv.0 (32055) States system redis pmessage system.adapter.firetv.0.logLevel/system.adapter.firetv.0.logLevel:{"val":"silly","ack":true,"ts":1620764164732,"q":0,"from":"system.adapter.firetv.0","lc":1620762006338}
                2021-05-11 22:16:04.918  - debug: firetv.0 (32055) FireTV: 192.168.178.27
                2021-05-11 22:16:04.921  - debug: firetv.0 (32055) FireTV: 192.168.178.128
                2021-05-11 22:16:04.963  - debug: firetv.0 (32055) Device 192.168.178.27:5555 + type=device was plugged in
                2021-05-11 22:16:04.965  - debug: firetv.0 (32055) Device 192.168.178.128:5555 + type=device was plugged in
                2021-05-11 22:16:04.981  - debug: firetv.0 (32055) Connected to 192.168.178.128 id=192.168.178.128:5555 state=device
                2021-05-11 22:16:05.029  - debug: firetv.0 (32055) 5.1.1
                2021-05-11 22:16:05.044  - debug: firetv.0 (32055) Connected to 192.168.178.27 id=192.168.178.27:5555 state=device
                2021-05-11 22:16:05.046  - silly: firetv.0 (32055) States user redis pmessage firetv.0.*/firetv.0.192_168_178_128.on:{"val":false,"ack":true,"ts":1620764165037,"q":0,"from":"system.adapter.firetv.0","user":"system.user.admin","lc":1620764165037}
                2021-05-11 22:16:05.057  - debug: firetv.0 (32055) 22
                2021-05-11 22:16:05.060  - info: firetv.0 (32055) 192.168.178.128: ADB version: 39, Android Version: 5.1.1, API Level: 22
                2021-05-11 22:16:05.065  - silly: firetv.0 (32055) States user redis pmessage firetv.0.*/firetv.0.192_168_178_128.result:{"val":"5.1.1","ack":true,"ts":1620764165063,"q":0,"from":"system.adapter.firetv.0","user":"system.user.admin","lc":1620764165063}
                2021-05-11 22:16:05.106  - silly: firetv.0 (32055) States user redis pmessage firetv.0.*/firetv.0.192_168_178_128.result:{"val":"22","ack":true,"ts":1620764165103,"q":0,"from":"system.adapter.firetv.0","user":"system.user.admin","lc":1620764165103}
                2021-05-11 22:16:05.198  - info: firetv.0 (32055) 192.168.178.27: ADB version: 39, Android Version: , API Level:
                • J JoergH
                  Hab was:
                  JoergH
                  #148
                  @joergh
                  Datenpunkte hat er nur für einen angelegt, beim zweiten nur den Channel...werde mal den ioBroker neu starten, die Instanz bringt nix....
                  • J JoergH
                    @joergh
                    JoergH
                    #149
                    @joergh Datenpunkte hat er nun auch angelegt, nach dem restart. Jetzt meldet er zwar noch bei einem
                    "Failure: 'device unauthorized.This adb server's $ADB_VENDOR_KEYS is not setTry 'adb kill-server' if that seems wrong.Otherwise check for a confirmation dialog on your device.'"
                    und beim anderen er sei offline (was nicht stimmt), aber immerhin hat er sie wohl mal kontaktiert...
                    • J JoergH
                      #150
                      @joergh Die Meldung mit dem vendorkey kommt bei mir auch schon mal. Einfach nicht weiter beachten, wenn es ansonsten funktioniert.
                      Zum zweiten Stick fällt mir aber nix ein. Hab nur einen hier aktiv.
                        JoergH
                        #151
                        Sind beides FireTV4K V2 und V3. Anbei noch einmal das Logfile...wirft immer noch einiges an Fehlern aus....Was hat er denn mit dem smartsocketlistener und dem daemon den er nicht starten kann?
                        2021-05-11 22:21:43.473  - debug: firetv.0 (1297) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        2021-05-11 22:21:43.570  - debug: firetv.0 (1297) Objects client ready ... initialize now
                        2021-05-11 22:21:43.667  - debug: firetv.0 (1297) Objects create System PubSub Client
                        2021-05-11 22:21:43.669  - debug: firetv.0 (1297) Objects create User PubSub Client
                        2021-05-11 22:21:43.672  - debug: firetv.0 (1297) Objects client initialize lua scripts
                        2021-05-11 22:21:43.750  - debug: firetv.0 (1297) Objects connected to redis: 127.0.0.1:9001
                        2021-05-11 22:21:43.755  - silly: firetv.0 (1297) redis psubscribe cfg.o.system.user.*
                        2021-05-11 22:21:43.763  - debug: firetv.0 (1297) objectDB connected
                        2021-05-11 22:21:43.767  - debug: firetv.0 (1297) Redis States: Use Redis connection: 127.0.0.1:9000
                        2021-05-11 22:21:43.780  - debug: firetv.0 (1297) States create System PubSub Client
                        2021-05-11 22:21:43.782  - debug: firetv.0 (1297) States create User PubSub Client
                        2021-05-11 22:21:43.799  - debug: firetv.0 (1297) States connected to redis: 127.0.0.1:9000
                        2021-05-11 22:21:43.800  - debug: firetv.0 (1297) statesDB connected
                        2021-05-11 22:21:44.232  - info: firetv.0 (1297) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.firetv, node: v12.22.1, js-controller: 3.2.16
                        2021-05-11 22:21:44.305  - silly: firetv.0 (1297) States system redis pmessage system.adapter.firetv.0.logLevel/system.adapter.firetv.0.logLevel:{"val":"silly","ack":true,"ts":1620764504277,"q":0,"from":"system.adapter.firetv.0","lc":1620762006338}
                        2021-05-11 22:21:44.390  - debug: firetv.0 (1297) FireTV: 192.168.178.27
                        2021-05-11 22:21:44.395  - debug: firetv.0 (1297) FireTV: 192.168.178.128
                        2021-05-11 22:21:44.562  - debug: firetv.0 (1297) Device 192.168.178.128:5555 + type=unauthorized was plugged in
                        2021-05-11 22:21:44.563  - debug: firetv.0 (1297) Connected to 192.168.178.128 id=192.168.178.128:5555
                        2021-05-11 22:21:44.566  - error: firetv.0 (1297) ID: 192.168.178.128 Error=Failure: 'device unauthorized.
                        2021-05-11 22:21:44.589  - silly: firetv.0 (1297) States user redis pmessage firetv.0.*/firetv.0.192_168_178_128.error:{"val":"Failure: 'device unauthorized.\nThis adb server's $ADB_VENDOR_KEYS is not set\nTry 'adb kill-server' if that seems wrong.\nOtherwise check for a confirmation dialog on your device.'","ack":true,"ts":1620764504586,"q":0,"from":"system.adapter.firetv.0","user":"system.user.admin","lc":1620764504586}
                        2021-05-11 22:21:44.616  - debug: firetv.0 (1297) 5.1.1
                        2021-05-11 22:21:44.631  - silly: firetv.0 (1297) States user redis pmessage firetv.0.*/firetv.0.192_168_178_128.result:{"val":"5.1.1","ack":true,"ts":1620764504625,"q":0,"from":"system.adapter.firetv.0","user":"system.user.admin","lc":1620764504625}
                        2021-05-11 22:21:44.644  - debug: firetv.0 (1297) 22
                        2021-05-11 22:21:44.649  - info: firetv.0 (1297) 192.168.178.128: ADB version: 39, Android Version: 5.1.1, API Level: 22
                        2021-05-11 22:21:44.660  - silly: firetv.0 (1297) States user redis pmessage firetv.0.*/firetv.0.192_168_178_128.result:{"val":"22","ack":true,"ts":1620764504656,"q":0,"from":"system.adapter.firetv.0","user":"system.user.admin","lc":1620764504656}
                        2021-05-11 22:21:44.998  - error: firetv.0 (1297) can not connect to 192.168.178.27 Error=Command failed: /usr/lib/android-sdk/platform-tools/adb start-server
                        * daemon not running; starting now at tcp:5037
                        ADB server didn't ACK
                        Full server startup log: /tmp/adb.1001.log
                        Server had pid: 1317
                        --- adb starting (pid 1317) ---
                        adb I 05-11 22:21:44  1317  1317 main.cpp:57] Android Debug Bridge version 1.0.39
                        adb I 05-11 22:21:44  1317  1317 main.cpp:57] Version 1:8.1.0+r23-5
                        adb I 05-11 22:21:44  1317  1317 main.cpp:57] Installed as /usr/lib/android-sdk/platform-tools/adb
                        adb I 05-11 22:21:44  1315  1315 adb_auth_host.cpp:467] Calling send_auth_response
                        error: could not install *smartsocket* listener: Address already in use
                        * failed to start daemon
                        error: cannot connect to daemon
                          RkcCorian
                          #152
                          Hallo Zusammen,
                          inzw. habe ich einen Fire TV Cube und den Adapter nach Installation von "sudo apt-get install android-tools-adb android-tools-fastboot" auf meine Docker ioBroker zum Laufen gebracht. Ich kann so jeder Taste unter "keys" steuern. Soweit so gut. Ebenso kann ich über "reboot" de Fire TV Cube neu starten. Was ich aber nicht kann, bzw. er geht bei mir nicht:
                          1. Den Einschaltzustand sehen. Ich vermute mal es sollte der DP "on" sein, der ist jedoch immer "false". Daher klappt das nicht
                          2. Den Fire TV Cube über ioBroker ein-/ausschalten. Vermute mal das sollte über den DP "swapPower" gehen. Leider kann ich den DP auf "false" oder "true" setzen, es ändern jedoch nichts
                          Weiß hier jemand Rat? #1 und #2 wären mir eigentlich am wichtigsten. Vielen Dank im Voraus!
                          padrinoP 1 Antwort Letzte Antwort
                          • R RkcCorian
                            Hallo Zusammen,
                            padrinoP Online
                            padrinoP Online
                            padrino
                            schrieb am zuletzt editiert von padrino
                            #153
                            @markus-2
                            Kann Dir nur sagen, geht hier mit FireTV Stick auch nicht.
                            Also, vermutlich "normal". 🤷
                            R 1 Antwort Letzte Antwort
                            • padrinoP padrino
                              @markus-2
                              RkcCorian
                              #154
                              @padrino Ohhh jeee. Gibt es einen Workaround über den Alexa2 Adapter o.ä.?
                              padrinoP 2 Antworten Letzte Antwort
                              • R RkcCorian
                                padrinoP Online
                                padrinoP Online
                                padrino
                                #155
                                @markus-2
                                Über Alexa2 wird da wohl leider nix gehen...
                                Weiß auch nicht, wie das mit "aus" beim Cube ist...
                                Der Stick hat ja nur einen "Ruhemodus", den erreicht man ja über das "lange home drücken"-Menü.
                                Dahin kommt man zumindest mit einem Eintrag bei "shell"
                                input keyevent --longpress 3
                                • R RkcCorian
                                  padrinoP Online
                                  padrinoP Online
                                  padrino
                                  #156
                                  @markus-2
                                  Hat mich jetzt alles irgendwie neugierig gemacht... ;)
                                  Guck mal hier
                                  https://www.reddit.com/r/fireTV/comments/9d0v0a/standbysleeppower_off_from_adb/
                                  Status abfragen geht beim Stick hier, keyevent 26 leider nicht...
                                  • padrinoP padrino
                                    @markus-2
                                    Guck mal hier
                                    RkcCorian
                                    #157
                                    @padrino Interessant! Wie nutze ich das in ioBroker? Geht das über einen Datenpunkt, bzw. für das Ergebnis der Anfrage zwei Datenpunkte, vom Adapter? Oder muss ich das irgendwie in Javascript schreiben?
                                    • R RkcCorian
                                      padrinoP Online
                                      padrinoP Online
                                      padrino
                                      #158
                                      @markus-2
                                      Also, Du kannst natürlich die Datenpunkte des FireTV Adapters nutzen und diese dann (wie gewohnt) verarbeiten, also Blockly, JavaScript...
                                      in
                                      firetv.0.xxx_xxx_xxx_xxx.shell
                                      scheibste
                                      dumpsys activity | grep -c "mWakefulness=Asleep"
                                      und in
                                      firetv.0.xxx_xxx_xxx_xxx.result
                                      prüfst Du, ob danach "0" oder "1" drin steht.
                                      • padrinoP padrino
                                        @markus-2
                                        in
                                        scheibste
                                        und in
                                        padrinoP Online
                                        padrinoP Online
                                        padrino
                                        #159
                                        Übrigens, der DP "online" gibt wohl an, ob der Adapter eine Verbindung zum Stick hat (egal, ob dieser im Ruhemodus ist oder nicht).
                                        Wenn dieser auf "false" geht ist ein Neustart des Adapters nötig...
                                        • padrinoP padrino
                                          RkcCorian
                                          schrieb am zuletzt editiert von RkcCorian
                                          #160
                                          @padrino
                                          Vielen Dank! Hab's gerade probiert (shell+result). Leider keine Reaktion. Was ich erfolgreich getestet habe:
                                          • Alle Datenpunkte unter "keys"
                                          • "reboot" und der Status "online" (Adapterverbindung)
                                          • "startApp", "stopApp"
                                          Das ist schonmal gut. Keine Reaktion (nicht einmal eine Fehlermeldung, Instanz läuft auf "debug") sehe ich für:
                                          • "on" (Einschaltstatus)
                                          • "swapPower" (Ein-/Ausschalten)
                                          • "shell" und "result"
                                          Ich brauche am Besten "on" um den Status zu bekommen und "shell", wenn ich damit explizit Ein-, bzw. Ausschalten kann. "swapPower" wäre auch möglich, ist halt immer so ne Sache, wenn der angenommene Zustand nicht stimmt. :-)
                                          Gibt es einen Entwickler der Zeit hat sich diese 4 Datenpunkte explizit anzuschauen? Ich wäre super Dankbar!!! :-)
