  4. Vis-2(.0) - Neuer Adapter als Beta
    5.2k
691 Beiträge 101 Kommentatoren 277.5k Aufrufe 115 Beobachtet
  • AgrippinenserA Agrippinenser
    @eisbaer721
    vielleicht habe ich die Frage falsch verstanden.
    Foto: Material - Widgets
    Frage: bezieht sich auf: Material Design Widgets
    versuche das mal so :
        "tpl": "tplMaterial2Switches",
        "data": {
          "bindings": [],
          "count": 2,
          "g_common": true,
          "type": "lines",
          "allSwitch": true,
          "orientation": "horizontal",
          "buttonsWidth": 120,
          "buttonsHeight": 80,
          "oid1": "0_userdata.0.test.bool",
          "type1": "auto",
          "noIcon1": null,
          "icon1": null,
          "iconSmall1": null,
          "iconEnabled1": null,
          "iconEnabledSmall1": null,
          "color1": "rgba(236,20,20,1)",
          "colorEnabled1": "rgba(15,164,45,1)",
          "title1": null,
          "unit1": null,
          "step1": null,
          "hideChart1": null,
          "chartPeriod1": 60,
          "buttonText1": null,
          "buttonIcon1": null,
          "buttonImage1": null,
          "buttonIconActive1": null,
          "buttonImageActive1": null,
          "infoInactiveText1": null,
          "infoActiveText1": null,
          "infoInactiveIcon1": null,
          "infoActiveIcon1": null,
          "infoInactiveImage1": null,
          "infoActiveImage1": null,
          "infoInactiveColor1": null,
          "infoActiveColor1": null,
          "widget1": null,
          "height1": null,
          "position1": null,
          "hide1": null,
          "actual1": null,
          "boost1": null,
          "party1": null,
          "switch1": null,
          "brightness1": null,
          "rgbType1": null,
          "red1": null,
          "green1": null,
          "blue1": null,
          "white1": null,
          "color_temperature1": null,
          "ct_min1": null,
          "ct_max1": null,
          "hue1": null,
          "saturation1": null,
          "luminance1": null,
          "hideBrightness1": null,
          "whiteMode1": null,
          "noRgbPalette1": null,
          "open1": null,
          "working1": null,
          "sensor1": null,
          "pincode1": null,
          "oid-pincode1": null,
          "doNotConfirm1": null,
          "noLockAnimation1": null,
          "lockColor1": null,
          "pincodeReturnButton1": "submit",
          "timeout1": 500,
          "vacuum-status-oid1": null,
          "vacuum-battery-oid1": null,
          "vacuum-is-charging-oid1": null,
          "vacuum-fan-speed-oid1": null,
          "vacuum-sensors-left-oid1": null,
          "vacuum-filter-left-oid1": null,
          "vacuum-main-brush-left-oid1": null,
          "vacuum-side-brush-left-oid1": null,
          "vacuum-cleaning-count-oid1": null,
          "vacuum-use-rooms1": null,
          "vacuum-map64-oid1": null,
          "vacuum-use-default-picture1": true,
          "vacuum-own-image1": null,
          "vacuum-start-oid1": null,
          "vacuum-home-oid1": null,
          "vacuum-pause-oid1": null,
          "g_switch-1": true
        "style": {
          "bindings": [],
          "left": 547,
          "top": 273,
          "width": "165px",
          "height": "120px",
          "position": "absolute"
        "widgetSet": "vis-2-widgets-material",
        "_id": "i000001"
    Eisbaer721
    #581
    @agrippinenser Das habe ich probiert. Das ist das was Sigi schon geschrieben hat. Stellt man dieses Widget auf
    Typ : Reihen dann ändert es die Farben. Leider bei Typ Taster klappt es nicht.Screenshot 2023-12-07 220358.png
    AgrippinenserA 2 Antworten Letzte Antwort
    • E Eisbaer721
      AgrippinenserA Offline
      Agrippinenser
      #582
      @eisbaer721
      wir sprechen hier über Material Design Widgets ODER über Material - Widgets
      Grüße vom Rhein @Colonia Claudia Ara Agrippinensium
      E 1 Antwort Letzte Antwort
        @eisbaer721
        Eisbaer721
        #583
        @agrippinenser Ups. Hast recht. über Material Widget.
        AgrippinenserA 1 Antwort Letzte Antwort
        • E Eisbaer721
          Agrippinenser
          #584
          @eisbaer721 sagte in Vis-2(.0) - Neuer Adapter als Beta:
          .. muss mich bwzüglich "Material" selbst immer ordnen. Geht es denn so?
          • E Eisbaer721
            Agrippinenser
            schrieb am zuletzt editiert von Agrippinenser
            #585
            ich habe früher nur Mechatronikern über die Schulter geguckt :-)
            Ein Taster-Signal liegt ja auch nur ganz kurz an. Nach meinem Verständnis wird der Datenpunkt nur "kurz" invertiert. (0 zu 1 oder 1 zu 0 ) je nach Ausgangszustand des Datenpunkts.
            EDIT: getestet: Zustand des Datenpunkts wird von 0 zu 1, nicht aber zurück geändert.
            • I intruder7
              @agrippinenser wie ich schon bei git geschrieben habe, liegt es bei Influx wohl eher an der Instanz. denn Instanz 0 geht bei mir auch. Eine Instanz 2 z.B. nicht
              Agrippinenser
              #586
              @intruder7 sagte in Vis-2(.0) - Neuer Adapter als Beta:
              Vermutlich guckt das Widget auf die Instanz, die unter "Basiseinstellungen > Standard-Historie" gewählt wurde.
              Dann wäre es kein Bug sondern ein Feature 🤗
              • werner2000xW Offline
                werner2000x
                #587
                Ich habe ein Problem mit VIS2:
                Im Editor Modus wird erst die Seite mit Inhalt geladen und nach wenigen Sekunden habe ich nur noch eine leere Webseite.
                Mit F12 im Browser wird folgendes angezeigt:
                console.ts:40 TypeError: Cannot add property signals-count, object is not extensible
                    at $.recalculateFields (index.jsx:684:32)
                    at $.<anonymous> (index.jsx:548:73)
                    at Do (react-dom.production.min.js:144:189)
                    at xl (react-dom.production.min.js:261:422)
                    at Hl (react-dom.production.min.js:260:446)
                    at Ml (react-dom.production.min.js:259:431)
                    at react-dom.production.min.js:283:96
                    at Vi (react-dom.production.min.js:281:398)
                    at ii (react-dom.production.min.js:273:439)
                    at Nn (react-dom.production.min.js:127:105)
                    at react-dom.production.min.js:283:470
                    at oi (react-dom.production.min.js:270:269)
                    at V (scheduler.production.min.js:13:203)
                    at MessagePort.T (scheduler.production.min.js:14:128)
                (anonym) @ console.ts:40
                react-dom.production.min.js:127 Uncaught TypeError: Cannot add property signals-count, object is not extensible
                Gibt es dafür eine Lösung?
                Raspi4 8 GB mit Aqara Zigbee USB, iob
                Innogy Smarthome
                Bosch Bridge 2
                HUE Bridge
                OpenWB Wallbox mit EVU Kit
                Google Nest Pro Hub
                HA auf uGreen dxp4800
                • sigi234S sigi234
                  @sandy sagte in Vis-2(.0) - Neuer Adapter als Beta:
                  Heizungssteuerung mit Vis2 gebaut
                  Jäger Design, aber da brauchst du eine Lizenz
                  Sandy
                  #588
                  @sigi234 said in Vis-2(.0) - Neuer Adapter als Beta:
                  kannst du vielleicht mal den Export der Heizungsteuerung hier rein setzen oder mir schicken ? Oder wie komme ich da dran.
                  LG Sandy
                  • S Sandy
                    LG Sandy
                    sigi234S Online
                    sigi234S Online
                    sigi234
                    #589
                    Schauen wir mal ob das funktioniert.
                        "tpl": "tplJaegerDesignThermostat",
                        "data": {
                          "bindings": [],
                          "step": 1,
                          "g_common": true,
                          "unit": "°C",
                          "oid-temperature-set": "hm-rpc.1.000A1D8997CC3E.1.SET_POINT_TEMPERATURE",
                          "oid_button1": "hm-rpc.1.000A1D8997CC3E.1.PARTY_MODE",
                          "label_button1": "Party",
                          "iconSmall_button1": "data:image/svg+xml;base64,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",
                          "oid_button2": "hm-rpc.1.000A1D8997CC3E.1.SET_POINT_MODE",
                          "variant_button2": "outlined",
                          "oid-temperature": "hm-rpc.1.000A1D8997CC3E.1.ACTUAL_TEMPERATURE",
                          "oid_button3": "hm-rpc.1.000A1D8997CC3E.1.BOOST_MODE",
                          "label_button3": "Schub",
                          "iconSmall_button3": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xMSAxNWgydjJoLTJ6bTAtOGgydjZoLTJ6bS45OS01QzYuNDcgMiAyIDYuNDggMiAxMnM0LjQ3IDEwIDkuOTkgMTBDMTcuNTIgMjIgMjIgMTcuNTIgMjIgMTJTMTcuNTIgMiAxMS45OSAyek0xMiAyMGMtNC40MiAwLTgtMy41OC04LThzMy41OC04IDgtOHM4IDMuNTggOCA4cy0zLjU4IDgtOCA4eiIvPjwvc3ZnPg==",
                          "count": 3,
                          "showActualTemperature": true,
                          "showDesiredTemperature": true,
                          "title": "BAD",
                          "oid-humidity": "hm-rpc.0.OEQ0670648.1.HUMIDITY",
                          "oid-valve": "hm-rpc.1.000A1D8997CC3E.1.LEVEL",
                          "iconSize": 40,
                          "g_css_background": true
                        "style": {
                          "bindings": [],
                          "left": "154px",
                          "top": "88px",
                          "width": "100%",
                          "height": "100px",
                          "position": "relative",
                          "absoluteWidth": 44,
                          "z-index": 4,
                          "background": "#066083",
                          "background-color": "rgba(6,96,131,1)",
                          "background-image": null,
                          "background-repeat": null,
                          "background-attachment": null,
                          "background-position": null,
                          "background-size": null,
                          "background-clip": null,
                          "background-origin": null
                        "widgetSet": "vis-2-widgets-jaeger-design",
                        "_id": "i000001"
                    Immer Daten sichern!
                    • sigi234S sigi234
                          "data": {
                            "bindings": [],
                            "step": 1,
                            "g_common": true,
                            "unit": "°C",
                            "count": 3,
                            "title": "BAD",
                            "iconSize": 40,
                          "style": {
                            "bindings": [],
                            "left": "154px",
                            "top": "88px",
                            "width": "100%",
                            "height": "100px",
                            "z-index": 4,
                          "_id": "i000001"
                      Sandy
                      schrieb am zuletzt editiert von Sandy
                      #590
                      @sigi234
                      ne ich glaube nicht :-(
                      oder muss ich bei dem "iobroker.vis-2-widgets-jaeger-design" noch was installieren ? bei den Adaptern habe ich nichts gefunden außer den hier.
                      • S Sandy
                        @sigi234
                        sigi234S Online
                        sigi234S Online
                        sigi234
                        #591
                        @sandy
                        Klicke mal auf die grüne Fläche
                        In der Runtime
                        • sigi234S sigi234
                          @sandy
                          In der Runtime
                          Sandy
                          #592
                          @sandy
                          In der Runtime
                          ja jetzt erscheint es in der Mitte vom Bildschirm. :-) gibt es auch ne Möglichkeit das alle Heizkörper gleich sichtbar sind ohne das man erst drauf drücken muss ?
                          So sah das bei mir vorher aus.
                          • S Sandy
                            @sandy
                            In der Runtime
                            sigi234S Online
                            sigi234S Online
                            sigi234
                            #593
                            ja jetzt erscheint es in der Mitte vom Bildschirm. gibt es auch ne Möglichkeit das alle Heizkörper gleich sichtbar sind ohne das man erst drauf drücken muss ?
                            Da musst du den Entwickler fragen.
                            @Bluefox
                              Sandy
                              #594
                              @Bluefox
                              Hallo. Erstmal danke für deine tolle Arbeit :-)
                              Gibt es eine Möglichkeit mit dem "iobroker.vis-2-widgets-jaeger-design" die Heizungssteuerung so sichtbar zu machen das sie dauerhaft zu sehen ist wie bei meinem Beispielbild ? Also nicht erst drauf drücken das sich die Steuerung öffnet. Das wäre super :-)
                              LG Sandy
                              • S Sandy
                                @Bluefox
                                LG Sandy
                                FeuersturmF Offline
                                FeuersturmF Offline
                                Feuersturm
                                #595
                                @sandy bluefox ist hier im thread nicht aktiv.erstelle für solche wünsche bitte ein issue, dann können sie bewertet und bearbeitet werden. Hier im thread wird dein Wunsch untergehen.
                                • BananaJoeB Offline
                                  BananaJoeB Offline
                                  BananaJoe
                                  #596
                                  Gibt es eine Quelle oder könnte mir einer den Adapter iobroker.vis-2-widgets-jaeger-design mehr Erklären? Immerhin soll der 50 Euro kosten. Was ich gerne bereit wäre zu zahlen, auch um das Projekt zu unterstützen.
                                  Aber wenn ich mir das auf Github ansehe könnte man den Eindruck bekommen das man damit RSS Feeds einbinden kann. (Punkt!)
                                  sigi234S N 2 Antworten Letzte Antwort
                                  • BananaJoeB BananaJoe
                                    sigi234S Online
                                    sigi234S Online
                                    sigi234
                                    #597
                                    @bananajoe
                                    Ja, bevor ich die Lizenz kaufe möchte ich schon eine Beschreibung was es so kann. Widgets sind ja nicht viele dabei. 50 Euro ist nicht gerade wenig. Mir fehlt auch ein Ansprechpartner. Getestet habe ich schon, da gibt es auch ein paar Wünsche.
                                      N Offline
                                      N Offline
                                      neo862
                                      #598
                                      @bananajoe @sigi234
                                      So wie ich das verstehe sind die Widgets frei verfügbar zum testen bzw. für privaten gebrauch. Die Lizenzgebühr scheint nur bei gewerblicher Nutzung anzufallen, also eigentlich genau so wie bei vis/vis2.
                                      Unter iobroker.net -> Lizenzen -> neue Lizenz bestellen findet man die jaeger-design widgets nur unter kommerzielle Lizenzen.
                                      Man möge mich korrigieren wenn ich Mist erzähle.
                                      Grüße
                                      neo
                                      • N neo862
                                        @bananajoe @sigi234
                                        Grüße
                                        neo
                                        Agrippinenser
                                        #599
                                        mit diesem Widget rufe ich eine unter Dialog beschrieben Seite auf.
                                        Ich verstehe aber die Beschreibung unter Allgemein nicht. "Verwende das erste Widget mit der Option.... "
                                        Welches ist das ?
                                        • sigi234S sigi234
                                          @bananajoe
                                          #600
                                          @sigi234 sagte in Vis-2(.0) - Neuer Adapter als Beta:
                                          müsste @marcj sein.
                                          (nur Vermutung! )
