  4. RPI 4 Update auf ?
    6.3k
RPI 4 Update auf ?
146 Beiträge 13 Kommentatoren 23.2k Aufrufe 9 Beobachtet
  • B bob der 1.
    @oliverio ```
    ======== Start marking the full check here =========
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     11:50:26 up 22:39,  1 user,  load average: 4.50, 3.39, 2.37
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=65.7'C
    volt=0.9460V
    *** Time and Time Zones ***
                   Local time: Wed 2023-08-16 11:50:26 CEST
               Universal time: Wed 2023-08-16 09:50:26 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.8G        3.3G        1.7G        1.0M        2.9G        4.4G
    Swap:            99M          0B         99M
    Total:          7.9G        3.3G        1.8G
             7811 M total memory
             3260 M used memory
             3375 M active memory
             2432 M inactive memory
             1671 M free memory
              139 M buffer memory
             2739 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FILESYSTEM ***
    /dev/root      ext4      110G  4.9G  101G   5% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
    /dev/sda1      vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
    [Tue Aug 15 13:10:38 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:E2:27:44 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=818b53ba-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Aug 15 13:10:42 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Aug 15 13:10:42 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Tue Aug 15 13:10:45 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    Show mounted filesystems (real ones only):
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    598M    /var/
    262M    /var/cache
    257M    /var/cache/apt
    156M    /var/cache/apt/archives
    148M    /var/lib
    Archived and active journals take up 80.0M in the file system.
    /opt/iobroker/backups:
    89M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    680M    /opt/iobroker/iobroker-data/
    423M    /opt/iobroker/iobroker-data/files
    144M    /opt/iobroker/iobroker-data/backup-objects
    88M     /opt/iobroker/iobroker-data/files/echarts.admin
    57M     /opt/iobroker/iobroker-data/files/echarts
    70M     /opt/iobroker/iobroker-data/objects.jsonl
    44M     /opt/iobroker/iobroker-data/states.jsonl
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    MULTIHOSTSERVICE/enabled: false
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    Adapters from github:   4
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 7777, bind: 192.168.178.70, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              - disabled
      system.adapter.bydbatt.0                : bydbatt               : raspberrypi                              - disabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
    + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
    + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
    + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
    + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
      system.adapter.enigma2.0                : enigma2               : raspberrypi                              - disabled
      system.adapter.enigma2.1                : enigma2               : raspberrypi                              - disabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : raspberrypi                              - disabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              - disabled
      system.adapter.homekit-controller.0     : homekit-controller    : raspberrypi                              - disabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
    + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
    + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
    + system.adapter.linux-control.0          : linux-control         : raspberrypi                              -  enabled
      system.adapter.mihome-cloud.0           : mihome-cloud          : raspberrypi                              - disabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
      system.adapter.mihome.0                 : mihome                : raspberrypi                              - disabled, port: 9898, bind: 192.168.178.70
    + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1889, bind: 0.0.0.0
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi                              -  enabled
    + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
      system.adapter.parcel.0                 : parcel                : raspberrypi                              - disabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      system.adapter.plex.0                   : plex                  : raspberrypi                              - disabled
    + system.adapter.ring.0                   : ring                  : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1888, bind: 192.168.178.70
    + system.adapter.signal-cmb.0             : signal-cmb            : raspberrypi                              -  enabled
    + system.adapter.sma-em.0                 : sma-em                : raspberrypi                              -  enabled
    + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: raspberrypi                              - disabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              - disabled
      system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              - disabled
      system.adapter.vis-material.0           : vis-material          : raspberrypi                              - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
    + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    live-stable   : http://iobroker.live/repo/sources-dist.json
    live-beta     : http://iobroker.live/repo/sources-dist-latest.json
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.3.5    , installed 6.3.5
    Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
    Adapter    "alias-manager": 1.2.4    , installed 1.2.6
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "bydbatt"      : 1.0.8    , installed 1.0.8
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "discovery"    : 3.1.0    , installed 3.2.0
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "homekit-controller": 0.5.8, installed 0.5.8
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
    Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "info"         : 1.9.26   , installed 1.9.26
    Adapter    "iot"          : 1.14.5   , installed 2.0.11
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
    Adapter    "lgtv"         : 1.1.10   , installed 1.1.12
    Adapter    "linux-control": 1.1.3    , installed 1.1.5
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-cloud" : 0.1.0    , installed 0.1.0
    Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "openweathermap": 0.3.9   , installed 0.3.11
    Adapter    "parcel"       : 0.0.27   , installed 0.0.32
    Adapter    "ping"         : 1.5.3    , installed 1.6.2
    Adapter    "plex"         : 0.9.1    , installed 0.9.1
    Adapter    "ring"         : 3.2.2    , installed 3.4.0
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "sma-em"       : 0.7.0    , installed 0.7.0
    Adapter    "socketio"     : 4.2.0    , installed 6.4.0
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.7
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "web"          : 4.3.0    , installed 6.0.3
    Adapter    "wled"         : 0.6.7    , installed 0.7.0
    Adapter    "ws"           : 1.3.0    , installed 2.4.0
    Objects and States
    Objects:        23872
    States:         21213
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.70:7777     0.0.0.0:*               LISTEN      1001       17959      1219/io.admin.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       3636       515/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16290      515/iobroker.js-con
    tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       21072230   3843853/io.mqtt.0
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       21070792   3846107/node-red
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       21067522   3844764/io.sonoff.0
    tcp        0      0 192.168.178.70:1888     0.0.0.0:*               LISTEN      1001       21072476   3844491/io.shelly.1
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3468       541/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       434743     83164/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21071009   3844612/io.socketio
    tcp6       0      0 :::22                   :::*                    LISTEN      0          3470       541/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       21062284   3845218/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        3429       399/avahi-daemon: r
    udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1001       21069400   3844522/io.sma-em.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21076098   3844456/io.shelly.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       21073534   3845067/io.upnp.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       21016026   3835468/io.deconz.0
    udp        0      0 0.0.0.0:40470           0.0.0.0:*                           1001       21067342   3845067/io.upnp.0
    udp        0      0 0.0.0.0:36921           0.0.0.0:*                           108        3431       399/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14688      1046/dhcpcd
    udp6       0      0 :::546                  :::*                                0          14753      1046/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        3430       399/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       21016028   3835468/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       21016027   3835468/io.deconz.0
    udp6       0      0 :::51624                :::*                                108        3432       399/avahi-daemon: r
    2023-08-16 11:50:28.242  - info: openweathermap.0 (3844037) Terminated (NO_ERROR): Without reason
    2023-08-16 11:50:29.049  - info: host.raspberrypi instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
    2023-08-16 11:50:30.846  - info: tr-064.0 (3844816) forEachConfiguredDevice: in GetSpecificHostEntry 59(WDMyCloud/00:14:EE:0C:32:F1) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-08-16 11:50:41.728  - info: tr-064.0 (3844816) forEachConfiguredDevice: in GetSpecificHostEntry 0(HUAWEI-Luca/A8:E5:44:AB:F6:F9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-08-16 11:50:43.329  - info: tr-064.0 (3844816) forEachConfiguredDevice: in GetSpecificHostEntry 11(Boss-PC/50:E5:49:5B:E8:DD) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-08-16 11:50:43.749  - info: alexa2.0 (3841818) Unknown Device, but enabling commands, Try it and report back if commands work.
    2023-08-16 11:50:43.749  - info: alexa2.0 (3841818) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
    2023-08-16 11:50:43.751  - info: alexa2.0 (3841818)     Device-type:A3I1LR45Q7T74C - Markus's Newton (Newton) (DEREGISTER_DEVICE,TUNE_IN,SET_TIME_ZONE,DEEZER,SLEEP,TIDAL,REMINDERS,MULTI_WAKEWORDS_SUPPORTED,CUSTOM_ALARM_TONE,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,MUSIC_SKILL,SUPPORTS_LOCALE,APPLE_MUSIC,ADAPTIVE_LISTENING,I_HEART_RADIO,SET_LOCALE,SPEECH_RECOGNIZER_USS,VOLUME_SETTING,MICROPHONE,CHANGE_NAME,AUDIBLE,GOLDFISH,SOUND_SETTINGS,HANDS_FREE,DREAM_TRAINING,AMAZON_MUSIC,SIRIUSXM,TOUCH_INITIATED,KINDLE_BOOKS,AUDIO_PLAYER,TIMERS_AND_ALARMS,PERSISTENT_CONNECTION,EARCONS)
    2023-08-16 11:50:44.544  - info: tr-064.0 (3844816) forEachConfiguredDevice: in GetSpecificHostEntry 17(Android-3/74:D4:23:02:D7:3A) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-08-16 11:50:51.378  - info: tr-064.0 (3844816) forEachConfiguredDevice: in GetSpecificHostEntry 59(WDMyCloud/00:14:EE:0C:32:F1) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-08-16 11:51:02.611  - info: tr-064.0 (3844816) forEachConfiguredDevice: in GetSpecificHostEntry 0(HUAWEI-Luca/A8:E5:44:AB:F6:F9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-08-16 11:51:04.403  - info: tr-064.0 (3844816) forEachConfiguredDevice: in GetSpecificHostEntry 11(Boss-PC/50:E5:49:5B:E8:DD) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-08-16 11:51:05.769  - info: tr-064.0 (3844816) forEachConfiguredDevice: in GetSpecificHostEntry 17(Android-3/74:D4:23:02:D7:3A) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-08-16 11:51:12.549  - info: tr-064.0 (3844816) forEachConfiguredDevice: in GetSpecificHostEntry 59(WDMyCloud/00:14:EE:0C:32:F1) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-08-16 11:51:16.821  - info: fb-checkpresence.0 (3842563) createFbDeviceObjects finished successfully
    2023-08-16 11:51:16.828  - info: fb-checkpresence.0 (3842563) states successfully subscribed
    2023-08-16 11:51:16.830  - info: fb-checkpresence.0 (3842563) loop successfully started
    2023-08-16 11:51:24.147  - info: tr-064.0 (3844816) forEachConfiguredDevice: in GetSpecificHostEntry 0(HUAWEI-Luca/A8:E5:44:AB:F6:F9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-08-16 11:51:26.051  - info: tr-064.0 (3844816) forEachConfiguredDevice: in GetSpecificHostEntry 11(Boss-PC/50:E5:49:5B:E8:DD) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-08-16 11:51:27.289  - info: tr-064.0 (3844816) forEachConfiguredDevice: in GetSpecificHostEntry 17(Android-3/74:D4:23:02:D7:3A) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-08-16 11:51:34.231  - info: tr-064.0 (3844816) forEachConfiguredDevice: in GetSpecificHostEntry 59(WDMyCloud/00:14:EE:0C:32:F1) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-08-16 11:51:45.157  - info: tr-064.0 (3844816) forEachConfiguredDevice: in GetSpecificHostEntry 0(HUAWEI-Luca/A8:E5:44:AB:F6:F9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-08-16 11:51:46.920  - info: tr-064.0 (3844816) forEachConfiguredDevice: in GetSpecificHostEntry 11(Boss-PC/50:E5:49:5B:E8:DD) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-08-16 11:51:48.358  - info: tr-064.0 (3844816) forEachConfiguredDevice: in GetSpecificHostEntry 17(Android-3/74:D4:23:02:D7:3A) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-08-16 11:51:55.893  - info: tr-064.0 (3844816) forEachConfiguredDevice: in GetSpecificHostEntry 59(WDMyCloud/00:14:EE:0C:32:F1) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    iob diag has finished.
    Press any key for a summary
    #61
    @bob-der-1 sagte in RPI 4 Update auf ?:
    da läuft noch irgendwas.
    ein pi4 8gb sollte nicht so hoch ausgelastet sein.
    • B bob der 1.
      @djmarc75
      weil auf 8081 was anderes rennt!
      Phyton3 ist für das Status display OLED am Pi für das System.
      aber erst seit 3 Tagen...
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      #62
      ich seh da nichts auf 8081 laufen 🤔
      Lehrling seit 1975 !!!
      B 1 Antwort Letzte Antwort
      • DJMarc75D DJMarc75
        bob der 1.
        schrieb am zuletzt editiert von bob der 1.
        #63
        @djmarc75 sagte in RPI 4 Update auf ?:
        Ja klar siehst du nichts!
        Dieser Port ist mit etwas anderem belegt,ausserhalb von IoBroker...
        Ich weis auch nicht warum du dich daran so festhängst?
        Der Port hat nichts damit zu tun bzw.frag ich mich warum ich alle Ports und Ip hier posten sollte
        ...also nee unverändert,du weist achon welchen schabernack man mit Ports,falla offen anstellen könnte.Da das alles nach aussen geschlossen ist würde ich dennoch gerne mal wissen wonach du suchst
        HomoranH DJMarc75D 3 Antworten Letzte Antwort
        • B bob der 1.
          #64
          ja und?
          der scan zeigt ja alle belgten Ports an, und 8081 ist nicht dabei.
          irgendetwas bremst deinen Pi erheblich aus.
          Die Suche danach muss und hat natürlich alles beinhalten was auf dem Pi läuft.
            ja und?
            bob der 1.
            #65
            Physisch ist dieser Port NICHT auf diesem PI.
            In meinem Netzwerk ist dieser Port von einem anderen Gerät belegt.
            Umd wenn man es genau wissen will eine Dreambox ist das....
            • B bob der 1.
              #66
              @bob-der-1 bitte nichts nachträglich editieten, schon gar nicht ohne Kennzeichnung!
              es geht doch nicht um nach außen offene Ports im Router, sondern um ggf. doppelt belegte Ports auf deinem Server, die dann zu Problemen führen.
              B crunchipC 2 Antworten Letzte Antwort
                bob der 1.
                #67
                @homoran sagte in RPI 4 Update auf ?:
                @ homoran
                Ich weis das schon.....
                Aber wie gesagt....anderes Gerät eben
                • B bob der 1.
                  #68
                  ja und. Die hat aber hoffentlich eine andere IP.
                  Hausnummern gibt es in der Stadt auch mehrfach. Erst in Verbindung mit dem Straßennamen wird es eindeutig.
                  Nur die Ports pro IP sind intetessant
                    bob der 1.
                    #69
                    Ja ist es....Die TV Box hat eine andere IP wie der Iob Pi.
                    Also da weis ich schon was ich mache....es ging mir darum das ich eben UNGERNE HIER Ports zeige die man eventuell von aussen mal angreifen könnte....wenn ich sage der ist anderwetig vergeben....und man sieht ihm eben beim Log des Pis nicht...liegt es ja nahe das ein anderes Gerät ist der den braucht/nutzt
                    ? 1 Antwort Letzte Antwort
                      crunchipC Offline
                      crunchipC Offline
                      #70
                      weiß aber nicht ob das normal ist
                        bob der 1.
                        #71
                        @crunchip sagte in RPI 4 Update auf ?:
                        ich hab den Adapter ( upnp der ist port 1900 )mal alleine auf Stop genommen gefühlt schon wirklich besser!!!
                        wenn ich richtige sehe ist deconz auf Port 1900 mitgelaufen, nur wie ändere ich das.
                        der Bridgeport ist ja auf 80.
                        • B bob der 1.
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          #72
                          Hier suche ich nix mehr.
                          Sind mir zu viele wiederholende Satzzeichen.
                          • B bob der 1.
                            crunchipC Offline
                            crunchipC Offline
                            #73
                            @bob-der-1 kann ich dir nicht sagen was die beiden default nutzen
                            • B bob der 1.
                              #74
                              Moin,
                              das ist sorry Unfug, wenn da jemand wirklich Deinen Rechner angreifen will, dann nutzt der einen Portscanner, der sucht die 65k an möglichen Ports in Sekunden durch, da spielt, dass überhaupt keine Rolle, ob Du hier einen Port zeigst oder nicht, Du würdest nur das Helfen erschweren.
                              Hier mal das was auf Wikipedia zu Ports steht https://de.wikipedia.org/wiki/Liste_der_standardisierten_Ports
                              Zu 1900 ist für UDP ein Port den KleinWeich nutzt, ich Meine den sollte man lieber nicht nehmen, auch wenn TSP nicht genutzt wird.
                              Port TCP UDP Beschreibung Status
                              1900 – UDP Microsoft SSDP – Ermöglicht das Auffinden von UPnP-Geräten offiziell
                              VG
                              Bernd
                                Moin,
                                VG
                                Bernd
                                bob der 1.
                                #75
                                Zumimdest ist es ein klein wenig flotter geworden, seitdem ich den Upnp Adapter auf Stop stehen habe.
                                @Homoran du hast geschrieben das der Pi zu hoch ausgelastet ist.
                                JavaSkript und FB checkpresent haben wir ja soweit durch.Macht es Sinn mal eine nackte IoB installation zu testen, wie hoch hier die Grundlast des Pi ist.
                                • B bob der 1.
                                  crunchipC Offline
                                  crunchipC Offline
                                  #76
                                  zeig jetzt mal die Ausgabe von top
                                    bob der 1.
                                    #77
                                    @crunchip
                                    In welchen Zustand?
                                    Upnp aus oder an,sorry aber ich möchte eben schon das "liefern" was Ihr benötigt.
                                    Kanns aber erst heute Abend bzw.morgen früh posten,da ich Kundentermine habe und sicher nicht vor 20:00 daheim bin.
                                    • B bob der 1.
                                      @crunchip
                                      In welchen Zustand?
                                      crunchipC Offline
                                      crunchipC Offline
                                      #78
                                      @bob-der-1 so wie es aktuell und auch am besten schon ne Weile läuft, also ohne Neustart zuvor
                                        bob der 1.
                                        #79
                                        @crunchip
                                        aktuell:
                                        Tasks: 187 total,   1 running, 186 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):  6.6 us,  6.2 sy,  0.0 ni, 87.0 id,  0.0 wa,  0.0 hi,  0.3 si,  0.0 st
                                        MiB Mem :   7811.3 total,   1278.3 free,   3851.0 used,   2682.0 buff/cache
                                        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3837.5 avail Mem
                                            PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                                            515 iobroker  20   0 1783888 953720  42260 S  11.3  11.9   1085:23 iobroker.js-con
                                            528 root      20   0   31036  17180   7796 D   6.0   0.2 228:54.27 python3
                                        3843853 iobroker  20   0  806112 208288  36468 S   2.6   2.6  96:25.00 io.mqtt.0
                                        3844816 iobroker  20   0  699368 102564  42040 S   2.6   1.3  39:47.88 io.tr-064.0
                                        3843235 iobroker  20   0  970164 289440  36504 S   2.0   3.6  98:51.23 io.javascript.0
                                        3844764 iobroker  20   0  761912 148088  36612 S   1.3   1.9  29:24.34 io.sonoff.0
                                        3843809 iobroker  20   0  695344  86924  36624 S   1.0   1.1  19:00.18 io.modbus.0
                                        2895421 pi        20   0   10040   3408   2804 R   0.7   0.0   0:00.07 top
                                        3844456 iobroker  20   0  745064 189080  36648 S   0.7   2.4 167:18.97 io.shelly.0
                                        3844522 iobroker  20   0  696676  86888  36468 S   0.7   1.1  45:40.37 io.sma-em.0
                                        3844829 iobroker  20   0  688164  84788  36956 S   0.7   1.1   2:23.81 io.trashschedul
                                             14 root      20   0       0      0      0 S   0.3   0.0   2:22.96 ksoftirqd/0
                                             15 root      20   0       0      0      0 I   0.3   0.0  10:11.39 rcu_preempt
                                             30 root      20   0       0      0      0 S   0.3   0.0   0:59.44 ksoftirqd/3
                                            100 root     -51   0       0      0      0 S   0.3   0.0   7:54.82 irq/37-mmc0
                                            399 avahi     20   0    7320   3484   2808 S   0.3   0.0   5:41.79 avahi-daemon
                                        2815816 root      20   0       0      0      0 I   0.3   0.0   0:02.89 kworker/0:2-events_power_efficient
                                        2894445 pi        20   0   16068   4776   3532 S   0.3   0.1   0:00.01 sshd
                                        3842206 iobroker  20   0  686980  75304  36396 S   0.3   0.9   2:03.70 io.echarts.0
                                        3843356 iobroker  20   0 2795588  96176  38180 S   0.3   1.2   4:11.72 io.linux-contro
                                        3843895 iobroker  20   0  686040  85444  36488 S   0.3   1.1   2:11.61 io.node-red.0
                                        3844799 iobroker  20   0 1091116 323096  38120 S   0.3   4.0   4:41.83 io.tankerkoenig
                                              1 root      20   0  165224  10140   7376 S   0.0   0.1   2:04.78 systemd
                                              2 root      20   0       0      0      0 S   0.0   0.0   0:00.35 kthreadd
                                              3 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_gp
                                              4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_par_gp
                                              5 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 slub_flushwq
                                              6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 netns
                                              8 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/0:0H-kblockd
                                             10 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 mm_percpu_wq
                                             11 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_kthread
                                             12 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_rude_kthread
                                             13 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_trace_kthread
                                             16 root      rt   0       0      0      0 S   0.0   0.0   0:02.30 migration/0
                                             17 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/0
                                             18 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/1
                                             19 root      rt   0       0      0      0 S   0.0   0.0   0:02.02 migration/1
                                             20 root      20   0       0      0      0 S   0.0   0.0   1:00.49 ksoftirqd/1
                                             22 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/1:0H-events_highpri
                                             23 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/2
                                             24 root      rt   0       0      0      0 S   0.0   0.0   0:02.03 migration/2
                                             25 root      20   0       0      0      0 S   0.0   0.0   1:00.79 ksoftirqd/2
                                             27 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/2:0H-kblockd
                                             28 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/3
                                             29 root      rt   0       0      0      0 S   0.0   0.0   0:02.02 migration/3
                                             32 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/3:0H-kblockd
                                             33 root      20   0       0      0      0 S   0.0   0.0   0:00.01 kdevtmpfs
                                             34 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 inet_frag_wq
                                             36 root      20   0       0      0      0 S   0.0   0.0   0:00.00 kauditd
                                             38 root      20   0       0      0      0 S   0.0   0.0   0:00.28 khungtaskd
                                             40 root      20   0       0      0      0 S   0.0   0.0   0:00.00 oom_reaper
                                             41 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 writeback
                                             42 root      20   0       0      0      0 S   0.0   0.0   0:11.94 kcompactd0
                                             43 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kintegrityd
                                             44 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kblockd
                                             45 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 blkcg_punt_bio
                                        nur den Admin laufen
                                        top - 07:30:51 up 2 days, 18:20,  1 user,  load average: 1.21, 1.39, 1.30
                                        Tasks: 154 total,   1 running, 153 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):  2.5 us,  5.8 sy,  0.0 ni, 91.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :   7811.3 total,   3881.4 free,   1263.8 used,   2666.2 buff/cache
                                        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6424.7 avail Mem
                                            528 root      20   0   31036  17180   7796 S   6.6   0.2 229:00.94 python3
                                            515 iobroker  20   0 1780396 969296  42260 S   0.7  12.1   1085:56 iobroker.js-con
                                             15 root      20   0       0      0      0 I   0.3   0.0  10:11.67 rcu_preempt
                                            100 root     -51   0       0      0      0 S   0.3   0.0   7:55.05 irq/37-mmc0
                                        2868244 root      20   0       0      0      0 I   0.3   0.0   0:01.81 kworker/0:1-events_power_efficient
                                        2868441 root      20   0       0      0      0 I   0.3   0.0   0:00.13 kworker/2:3-events
                                        2901254 pi        20   0    9868   3268   2732 R   0.3   0.0   0:00.04 top
                                        2901388 root      20   0    9716   3120   2720 S   0.3   0.0   0:00.01 top
                                              1 root      20   0  165224  10140   7376 S   0.0   0.1   2:04.84 systemd
                                             14 root      20   0       0      0      0 S   0.0   0.0   2:23.02 ksoftirqd/0
                                             20 root      20   0       0      0      0 S   0.0   0.0   1:00.51 ksoftirqd/1
                                             25 root      20   0       0      0      0 S   0.0   0.0   1:00.82 ksoftirqd/2
                                             30 root      20   0       0      0      0 S   0.0   0.0   0:59.46 ksoftirqd/3
                                             46 root     -51   0       0      0      0 S   0.0   0.0   0:00.00 watchdogd
                                             50 root       0 -20       0      0      0 I   0.0   0.0   0:10.46 kworker/1:1H-kblockd
                                             51 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rpciod
                                             52 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 xprtiod
                                             55 root      20   0       0      0      0 S   0.0   0.0   0:00.40 kswapd0
                                             56 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 nfsiod
                                             57 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kthrotld
                                             65 root      20   0       0      0      0 S   0.0   0.0   0:00.12 hwrng
                                             66 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 iscsi_conn_clea
                                             67 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 nvme-wq
                                             68 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 nvme-reset-wq
                                             69 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 nvme-delete-wq
                                        danach alle die ich brauche wieder an ,also Stress für den Pi weil ich alle zeitgleich anschalte
                                        top - 07:35:07 up 2 days, 18:24,  1 user,  load average: 4.47, 2.60, 1.77
                                        Tasks: 192 total,   9 running, 183 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s): 55.1 us,  9.7 sy,  0.0 ni, 34.2 id,  0.0 wa,  0.0 hi,  1.0 si,  0.0 st
                                        MiB Mem :   7811.3 total,   1946.1 free,   3173.3 used,   2691.9 buff/cache
                                        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   4467.4 avail Mem
                                            515 iobroker  20   0 1817276 982.7m  42260 R  86.7  12.6   1088:09 iobroker.js-con
                                        2909830 iobroker  20   0  691756 120428  36500 R  44.5   1.5   0:10.18 io.shelly.0
                                        2909078 iobroker  20   0  744748  73020  37680 S  20.3   0.9   0:04.51 io.openweatherm
                                        2908285 iobroker  20   0  986752 286224  36460 R  11.3   3.6   0:24.79 io.javascript.0
                                        2909300 iobroker  20   0 5166712  98184  38956 R  11.3   1.2   0:08.06 io.ring.0
                                        2910379 iobroker  20   0  683544  80572  36440 R  11.0   1.0   0:04.41 io.sonoff.0
                                        2911473 iobroker  20   0  678068  70568  36480 S   8.3   0.9   0:03.97 io.web.0
                                        2910875 iobroker  20   0  690676  92952  36672 S   6.6   1.2   0:06.99 io.tr-064.0
                                            528 root      20   0   31036  17180   7796 S   6.0   0.2 229:16.52 python3
                                        2910506 iobroker  20   0  743384  70172  36472 S   4.3   0.9   0:04.38 io.tankerkoenig
                                        2904436 iobroker  20   0  673944  67664  36396 R   3.7   0.8   0:04.58 io.energiefluss
                                        2912925 iobroker  20   0  675876  87556  36248 S   3.3   1.1   0:03.04 node
                                        2908691 iobroker  20   0  677004  70816  36620 S   3.0   0.9   0:05.09 io.modbus.0
                                        2910275 iobroker  20   0  673100  83136  36376 R   3.0   1.0   0:03.51 io.sma-em.0
                                        2911206 iobroker  20   0  680108  79464  42212 S   2.7   1.0   0:04.88 io.upnp.0
                                        2909186 iobroker  20   0  675308  69416  36384 S   2.3   0.9   0:04.29 io.ping.0
                                           1219 iobroker  20   0 1089780 243704  43060 S   2.0   3.0  11:19.36 io.admin.0
                                        2904659 iobroker  20   0 5008256  84484  38288 S   1.0   1.1   0:18.54 io.fb-checkpres
                                        2889378 root      20   0       0      0      0 I   0.7   0.0   0:00.88 kworker/0:0-events
                                        2908022 iobroker  20   0  673060  66712  36480 S   0.7   0.8   0:03.99 io.history.0
                                        2908143 iobroker  20   0  812988  78348  37604 S   0.7   1.0   0:05.27 io.info.0
                                        2908353 iobroker  20   0  672920  67772  36544 S   0.7   0.8   0:03.62 io.lgtv.0
                                        2911182 iobroker  20   0  676368  77868  36816 R   0.7   1.0   0:04.15 io.trashschedul
                                        2911424 iobroker  20   0  675840  88488  36368 S   0.7   1.1   0:03.56 io.weatherunder
                                             15 root      20   0       0      0      0 I   0.3   0.0  10:12.56 rcu_preempt
                                            100 root     -51   0       0      0      0 S   0.3   0.0   7:55.66 irq/37-mmc0
                                            105 root      20   0       0      0      0 S   0.3   0.0   3:31.67 usb-storage
                                        2904707 iobroker  20   0  673980  69884  37152 S   0.3   0.9   0:06.35 io.fritzdect.0
                                        2904758 iobroker  20   0  673012  67672  36616 S   0.3   0.8   0:06.12 io.fullybrowser
                                        2909519 iobroker  20   0  691672  82260  36464 S   0.3   1.0   0:04.98 io.shelly.1
                                        2909550 iobroker  20   0  676372  70204  36424 S   0.3   0.9   0:03.48 io.signal-cmb.0
                                        2913083 pi        20   0    9992   3536   2760 R   0.3   0.0   0:00.04 top
                                        2913210 root      20   0    9848   3092   2688 S   0.3   0.0   0:00.01 top
                                              1 root      20   0  165224  10140   7376 S   0.0   0.1   2:04.94 systemd
                                             14 root      20   0       0      0      0 S   0.0   0.0   2:23.16 ksoftirqd/0
                                             16 root      rt   0       0      0      0 S   0.0   0.0   0:02.31 migration/0
                                             20 root      20   0       0      0      0 S   0.0   0.0   1:00.59 ksoftirqd/1
                                             24 root      rt   0       0      0      0 S   0.0   0.0   0:02.04 migration/2
                                             25 root      20   0       0      0      0 S   0.0   0.0   1:00.90 ksoftirqd/2
                                        • B bob der 1.
                                          @crunchip
                                          aktuell:
                                          crunchipC Offline
                                          crunchipC Offline
                                          #80
                                          aktuell
                                          fehlt die erste Zeile
                                          logisch, sollte sich aber wieder legen, daher wäre das aktuell laufende, was du zuerst gepostet hast, Interessant
                                          B 2 Antworten Letzte Antwort
