  4. Philipps Hue stürzt andauernd ab
    6.7k
17 Beiträge 10 Kommentatoren 2.3k Aufrufe 6 Beobachtet
  • G Offline
    GreySkoda91
    Re: Hue Adapter hängt sich auf
    Bei mir das selbe Problem, keine Verbindung mehr und der Adapter stürzt nur noch ab, sentry ist schon deaktiviert worden
    2023-07-30 11:50:35.500 - info: hue.0 (15400) starting. Version 3.9.3 in /opt/iobroker/node_modules/iobroker.hue, node: v16.19.0, js-controller: 4.0.24
    2023-07-30 11:50:35.512 - warn: hue.0 (15400) No bridge configured yet - please configure the adapter first
    2023-07-30 11:50:50.470 - info: hue.0 (15400) created new User: 96iLx5jjbAEi8EWDiJmEtpNWUPmN6yLDaQmTfuEM
    2023-07-30 11:50:53.530 - info: host.ioBroker stopInstance system.adapter.hue.0 (force=false, process=true)
    2023-07-30 11:50:53.532 - info: hue.0 (15400) Got terminate signal TERMINATE_YOURSELF
    2023-07-30 11:50:53.533 - info: hue.0 (15400) terminating
    2023-07-30 11:50:53.533 - info: hue.0 (15400) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-30 11:50:53.575 - info: host.ioBroker stopInstance system.adapter.hue.0 send kill signal
    2023-07-30 11:50:53.664 - info: admin.0 (303) <== Disconnect system.user.admin from ::ffff:192.168.1.232
    2023-07-30 11:50:54.068 - info: host.ioBroker instance system.adapter.hue.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-30 11:50:56.614 - info: host.ioBroker instance system.adapter.hue.0 started with pid 15555
    2023-07-30 11:50:57.438 - info: hue.0 (15555) starting. Version 3.9.3 in /opt/iobroker/node_modules/iobroker.hue, node: v16.19.0, js-controller: 4.0.24
    2023-07-30 11:50:57.944 - info: hue.0 (15555) Push connection established
    2023-07-30 11:50:58.373 - warn: hue.0 (15555) Could not get configuration from HUE bridge (192.168.1.21:443)
    2023-07-30 11:50:58.893 - error: hue.0 (15555) Could not poll all: Cannot convert undefined or null to object
    2023-07-30 11:51:04.014 - info: hue.0 (15555) Push connection established
    2023-07-30 11:51:04.218 - warn: hue.0 (15555) Could not get configuration from HUE bridge (192.168.1.21:443)
    2023-07-30 11:51:09.110 - error: hue.0 (15555) Could not poll all: Cannot convert undefined or null to object
    2023-07-30 11:51:09.971 - info: hue.0 (15555) Push connection established
    2023-07-30 11:51:10.034 - warn: hue.0 (15555) Could not get configuration from HUE bridge (192.168.1.21:443)
    2023-07-30 11:51:15.452 - error: hue.0 (15555) Error
    2023-07-30 11:51:15.453 - warn: hue.0 (15555) Could not get configuration from HUE bridge (192.168.1.21:443)
    2023-07-30 11:51:15.453 - info: hue.0 (15555) Push connection established
    2023-07-30 11:51:15.468 - error: hue.0 (15555) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-07-30 11:51:15.468 - error: hue.0 (15555) unhandled promise rejection: Unexpected token < in JSON at position 0
    2023-07-30 11:51:15.470 - error: hue.0 (15555) SyntaxError: Unexpected token < in JSON at position 0
    at JSON.parse ()
    at uuidResourceParser (/opt/iobroker/node_modules/hue-push-client/dist/index.js:94:21)
    at IncomingMessage. (/opt/iobroker/node_modules/hue-push-client/dist/index.js:43:36)
    at IncomingMessage.emit (node:events:525:35)
    at IncomingMessage.emit (node:domain:489:12)
    at endReadableNT (node:internal/streams/readable:1358:12)
    at processTicksAndRejections (node:internal/process/task_queues:83:21)
    2023-07-30 11:51:15.470 - error: hue.0 (15555) Unexpected token < in JSON at position 0
    2023-07-30 11:51:15.524 - info: hue.0 (15555) cleaned everything up...
    2023-07-30 11:51:15.524 - info: hue.0 (15555) terminating
    2023-07-30 11:51:15.524 - warn: hue.0 (15555) Terminated (UNCAUGHT_EXCEPTION): Without reason
    hier mal mein Log, habe schon versucht einen neuen Benutzer anzulegen, die API ist über die Seite der Bridge aber ohne Probleme anzusprechen und zu nutzen.
    habe das poblem bei SSL und keinem SSL
    hängt das eventuell damit zusammen das die Developer Seite von hue nicht erreichbar ist? Bad Gateway 502.
    arteckA sigi234S 2 Antworten Letzte Antwort
    • G GreySkoda91
      at JSON.parse ()
      arteckA Offline
      arteckA Offline
      arteck
      @greyskoda91 sagte in Philipps Hue stürzt andauernd ab:
      node: v16.19.0,
      im ernst ??????
      • arteckA arteck
        node: v16.19.0,
        im ernst ??????
        haselchenH Offline
        haselchenH Offline
        haselchen
        @arteck sagte in Philipps Hue stürzt andauernd ab:
        node: v16.19.0,
        im ernst ??????
        Wo da jetzt das Problem liegt, wüsste ich dann auch gerne.
        • NegaleinN Offline
          NegaleinN Offline
          Negalein
          bei mir das selbe Problem.
          host.ioBroker 2023-07-31 09:48:17.306	error	instance system.adapter.hue.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          host.ioBroker 2023-07-31 09:48:17.306	error	Caught by controller[0]: at IncomingMessage.emit (node:domain:489:12)
          host.ioBroker 2023-07-31 09:48:17.306	error	Caught by controller[0]: at IncomingMessage.emit (node:events:513:28)
          host.ioBroker 2023-07-31 09:48:17.306	error	Caught by controller[0]: at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/eventsource/lib/eventsource.js:259:11)
          host.ioBroker 2023-07-31 09:48:17.306	error	Caught by controller[0]: at parseEventStreamLine (/opt/iobroker/node_modules/eventsource/lib/eventsource.js:302:9)
          host.ioBroker 2023-07-31 09:48:17.306	error	Caught by controller[0]: at _emit (/opt/iobroker/node_modules/eventsource/lib/eventsource.js:287:17)
          host.ioBroker 2023-07-31 09:48:17.306	error	Caught by controller[0]: at HuePushClient.emit (node:domain:489:12)
          host.ioBroker 2023-07-31 09:48:17.306	error	Caught by controller[0]: at HuePushClient.emit (node:events:513:28)
          host.ioBroker 2023-07-31 09:48:17.306	error	Caught by controller[0]: at HuePushClient.<anonymous> (/opt/iobroker/node_modules/iobroker.hue/src/main.ts:1087:30)
          host.ioBroker 2023-07-31 09:48:17.306	error	Caught by controller[0]: at Hue.handleUpdate (/opt/iobroker/node_modules/iobroker.hue/src/main.ts:1122:18)
          host.ioBroker 2023-07-31 09:48:17.306	error	Caught by controller[0]: at Hue.handleSensorUpdate (/opt/iobroker/node_modules/iobroker.hue/src/main.ts:1164:27)
          host.ioBroker 2023-07-31 09:48:17.306	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'button_report')
          host.ioBroker 2023-07-31 09:48:17.306	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          hue.0 2023-07-31 09:48:16.588	error	Cannot read properties of undefined (reading 'button_report')
          hue.0 2023-07-31 09:48:16.588	error	TypeError: Cannot read properties of undefined (reading 'button_report') at Hue.handleSensorUpdate (/opt/iobroker/node_modules/iobroker.hue/src/main.ts:1164:27) at Hue.handleUpdate (/opt/iobroker/node_modules/iobroker.hue/src/main.ts:1122:18) at HuePushClient.<anonymous> (/opt/iobroker/node_modules/iobroker.hue/src/main.ts:1087:30) at HuePushClient.emit (node:events:513:28) at HuePushClient.emit (node:domain:489:12) at _emit (/opt/iobroker/node_modules/eventsource/lib/eventsource.js:287:17) at parseEventStreamLine (/opt/iobroker/node_modules/eventsource/lib/eventsource.js:302:9) at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/eventsource/lib/eventsource.js:259:11) at IncomingMessage.emit (node:events:513:28) at IncomingMessage.emit (node:domain:489:12)
          hue.0 2023-07-31 09:48:16.540	error	unhandled promise rejection: Cannot read properties of undefined (reading 'button_report')
          hue.0 2023-07-31 09:48:16.540	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          host.ioBroker 2023-07-31 09:47:32.091	error	instance system.adapter.hue.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          host.ioBroker 2023-07-31 09:47:32.091	error	Caught by controller[0]: at IncomingMessage.emit (node:domain:489:12)
          2023-07-31 03:05:58.071  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Schlafzimmer.on as we have a switch available
          2023-07-31 03:06:05.405  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Schlafzimmer.level as we have a switch available
          2023-07-31 03:06:05.406  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Schlafzimmer.on as we have a switch available
          2023-07-31 03:06:16.431  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Schlafzimmer.level as we have a switch available
          2023-07-31 03:06:16.433  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Schlafzimmer.on as we have a switch available
          2023-07-31 03:06:44.552  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Schlafzimmer.level as we have a switch available
          2023-07-31 03:06:44.555  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Schlafzimmer.on as we have a switch available
          2023-07-31 03:06:49.927  - info: iot.0 (1406) State value to set for "hue.0.Schlafzimmer.alert" has to be type "string" but received type "boolean"
          2023-07-31 03:06:49.928  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Schlafzimmer.b as we have a switch available
          2023-07-31 03:06:49.931  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Schlafzimmer.g as we have a switch available
          2023-07-31 03:06:49.932  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Schlafzimmer.r as we have a switch available
          2023-07-31 03:06:49.934  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Schlafzimmer_1.level as we have a switch available
          2023-07-31 03:06:49.936  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Schlafzimmer_1.on as we have a switch available
          2023-07-31 03:06:49.937  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Schlafzimmer_2.level as we have a switch available
          2023-07-31 03:06:49.940  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Schlafzimmer_2.on as we have a switch available
          2023-07-31 03:07:30.834  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Schlafzimmer.level as we have a switch available
          2023-07-31 03:07:30.837  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Schlafzimmer.on as we have a switch available
          2023-07-31 03:08:38.346  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Schlafzimmer.level as we have a switch available
          2023-07-31 03:08:38.347  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Schlafzimmer.on as we have a switch available
          2023-07-31 06:56:36.086  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Kinderzimmer.ct as we have a switch available
          2023-07-31 06:56:36.088  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Kinderzimmer.hue as we have a switch available
          2023-07-31 06:56:36.091  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Kinderzimmer.on as we have a switch available
          2023-07-31 06:56:36.092  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Kinderzimmer.sat as we have a switch available
          2023-07-31 06:57:16.578  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Kinderzimmer.ct as we have a switch available
          2023-07-31 06:57:16.581  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Kinderzimmer.hue as we have a switch available
          2023-07-31 06:57:16.582  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Kinderzimmer.on as we have a switch available
          2023-07-31 06:57:16.583  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Kinderzimmer.sat as we have a switch available
          2023-07-31 06:57:21.536  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Kinderzimmer.ct as we have a switch available
          2023-07-31 06:57:21.539  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Kinderzimmer.hue as we have a switch available
          2023-07-31 06:57:21.540  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Kinderzimmer.on as we have a switch available
          2023-07-31 06:57:21.541  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Kinderzimmer.sat as we have a switch available
          2023-07-31 06:57:28.275  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Kinderzimmer.ct as we have a switch available
          2023-07-31 06:57:28.278  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Kinderzimmer.hue as we have a switch available
          2023-07-31 06:57:28.280  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Kinderzimmer.on as we have a switch available
          2023-07-31 06:57:28.284  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff: Error: Won't control hue.0.Kinderzimmer.sat as we have a switch available
          2023-07-31 07:56:59.667  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Kinderzimmer.ct as we have a switch available
          2023-07-31 07:56:59.669  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Kinderzimmer.hue as we have a switch available
          2023-07-31 07:56:59.670  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Kinderzimmer.on as we have a switch available
          2023-07-31 07:56:59.671  - warn: iot.1 (1429) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Kinderzimmer.sat as we have a switch available
          2023-07-31 09:43:38.591  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Wohnzimmer.ct as we have a switch available
          2023-07-31 09:43:38.595  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Wohnzimmer.hue as we have a switch available
          2023-07-31 09:43:38.596  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Wohnzimmer.on as we have a switch available
          2023-07-31 09:43:38.597  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Wohnzimmer.sat as we have a switch available
          2023-07-31 09:43:50.872  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Wohnzimmer.ct as we have a switch available
          2023-07-31 09:43:50.874  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Wohnzimmer.hue as we have a switch available
          2023-07-31 09:43:50.875  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Wohnzimmer.on as we have a switch available
          2023-07-31 09:43:50.876  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Wohnzimmer.sat as we have a switch available
          2023-07-31 09:44:38.828  - info: host.ioBroker instance system.adapter.hue.0 started with pid 393851
          2023-07-31 09:44:40.530  - info: hue.0 (393851) starting. Version 3.9.4 in /opt/iobroker/node_modules/iobroker.hue, node: v16.20.1, js-controller: 4.0.24
          2023-07-31 09:44:40.977  - info: hue.0 (393851) Push connection established
          2023-07-31 09:44:40.981  - info: hue.0 (393851) skip switch: Daylight.configured
          2023-07-31 09:44:40.981  - info: hue.0 (393851) skip switch: Daylight.sunriseoffset
          2023-07-31 09:44:40.981  - info: hue.0 (393851) skip switch: Daylight.sunsetoffset
          2023-07-31 09:44:40.984  - info: hue.0 (393851) skip switch: Hue temperature sensor 1.alert
          2023-07-31 09:44:40.984  - info: hue.0 (393851) skip switch: Hue temperature sensor 1.ledindication
          2023-07-31 09:44:40.984  - info: hue.0 (393851) skip switch: Hue temperature sensor 1.usertest
          2023-07-31 09:44:40.992  - info: hue.0 (393851) skip switch: Kinderzimmer Motionsensor.alert
          2023-07-31 09:44:40.992  - info: hue.0 (393851) skip switch: Kinderzimmer Motionsensor.ledindication
          2023-07-31 09:44:40.992  - info: hue.0 (393851) skip switch: Kinderzimmer Motionsensor.usertest
          2023-07-31 09:44:40.992  - info: hue.0 (393851) skip switch: Kinderzimmer Motionsensor.sensitivity
          2023-07-31 09:44:40.993  - info: hue.0 (393851) skip switch: Kinderzimmer Motionsensor.sensitivitymax
          2023-07-31 09:44:40.997  - info: hue.0 (393851) skip switch: Hue ambient light sensor 1.alert
          2023-07-31 09:44:40.998  - info: hue.0 (393851) skip switch: Hue ambient light sensor 1.tholddark
          2023-07-31 09:44:40.998  - info: hue.0 (393851) skip switch: Hue ambient light sensor 1.tholdoffset
          2023-07-31 09:44:40.998  - info: hue.0 (393851) skip switch: Hue ambient light sensor 1.ledindication
          2023-07-31 09:44:40.998  - info: hue.0 (393851) skip switch: Hue ambient light sensor 1.usertest
          2023-07-31 09:44:41.003  - info: hue.0 (393851) skip switch: Hue wall switch WiGa.devicemode
          2023-07-31 09:44:41.003  - info: hue.0 (393851) skip switch: Hue wall switch WiGa.devicemodevalues
          2023-07-31 09:44:41.005  - info: hue.0 (393851) skip switch: Hue wall switch Bad.devicemode
          2023-07-31 09:44:41.005  - info: hue.0 (393851) skip switch: Hue wall switch Bad.devicemodevalues
          2023-07-31 09:44:41.007  - info: hue.0 (393851) skip switch: Hue wall switch KiZi.devicemode
          2023-07-31 09:44:41.008  - info: hue.0 (393851) skip switch: Hue wall switch KiZi.devicemodevalues
          2023-07-31 09:44:41.011  - info: hue.0 (393851) skip switch: Hue wall switch SchlaZi.devicemode
          2023-07-31 09:44:41.011  - info: hue.0 (393851) skip switch: Hue wall switch SchlaZi.devicemodevalues
          2023-07-31 09:44:41.013  - info: hue.0 (393851) skip switch: Hue Wall Switch Küche.devicemode
          2023-07-31 09:44:41.013  - info: hue.0 (393851) skip switch: Hue Wall Switch Küche.devicemodevalues
          2023-07-31 09:44:41.013  - info: hue.0 (393851) created/updated 11 sensor channels
          2023-07-31 09:44:41.565  - info: hue.0 (393851) created/updated 18 light channels
          2023-07-31 09:44:41.572  - warn: hue.0 (393851) channel "Custom_group_for_$leftGroup" already exists, using "Custom_group_for_$leftGroup_LightGroup" for group 12
          2023-07-31 09:44:41.574  - warn: hue.0 (393851) channel "Custom_group_for_$leftGroup" already exists, using "Custom_group_for_$leftGroup_LightGroup" for group 14
          2023-07-31 09:44:41.576  - warn: hue.0 (393851) channel "Custom_group_for_$leftGroup" already exists, using "Custom_group_for_$leftGroup_LightGroup" for group 15
          2023-07-31 09:44:41.577  - warn: hue.0 (393851) channel "Custom_group_for_$leftGroup" already exists, using "Custom_group_for_$leftGroup_LightGroup" for group 16
          2023-07-31 09:44:41.578  - warn: hue.0 (393851) channel "Custom_group_for_$lights" already exists, using "Custom_group_for_$lights_LightGroup" for group 17
          2023-07-31 09:44:41.581  - warn: hue.0 (393851) channel "Garten" already exists, using "Garten_Room" for group 81
          2023-07-31 09:44:41.582  - info: hue.0 (393851) created/updated 19 groups channels
          2023-07-31 09:44:41.584  - info: hue.0 (393851) created/updated 96 scenes
          2023-07-31 09:44:41.584  - info: hue.0 (393851) creating/updating bridge device
          2023-07-31 09:44:49.362  - debug: telegram-menu.0 (383588) else "hue.0.Wohnzimmer.on"
          2023-07-31 09:44:51.217  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Wohnzimmer.ct as we have a switch available
          2023-07-31 09:44:51.221  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Wohnzimmer.hue as we have a switch available
          2023-07-31 09:44:51.223  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Wohnzimmer.on as we have a switch available
          2023-07-31 09:44:51.274  - warn: iot.0 (1406) [ALEXA] Cannot controlOnOff Error: Won't control hue.0.Wohnzimmer.sat as we have a switch available
          2023-07-31 09:44:51.529  - debug: telegram-menu.0 (383588) else "hue.0.Wohnzimmer.on"
          2023-07-31 09:44:52.493  - debug: telegram-menu.0 (383588) else "hue.0.Wohnzimmer.on"
          Node.js: 16.20.1
          NPM: 8.19.4
          Admin: 6.6.4
          JS-Controller: 4.0.24
          ° Fixer ---> iob fix
          • BBTownB Offline
            BBTownB Offline
            BBTown
            Ich kann das für den neuen HUE-Adapter der Version 3.9.4 bei mir ebenfalls bestätigen
            Meine Umgebung:
            Node.js: 18.17.0
            NPM: 9.6.7
            Admin: 6.6.4
            JS-Controller: 5.0.11
            Debian Bookworm
            VM auf Proxmox v8.0.3
            ioBroker auf NUC (VM debian v13 (Trixie ), node v22.22.0 npm v10.9.4, js-controller v7.2.2 jsonl/jsonl / HomeMatic CCU-2 (Wired und Funk) / Philips HUE / echo.DOT / Broadlink RM pro / SONOS
            • BBTownB BBTown
              Meine Umgebung:
              Node.js: 18.17.0
              NPM: 9.6.7
              Admin: 6.6.4
              Debian Bookworm
              sigi234S Online
              sigi234S Online
              sigi234
              @bbtown sagte in Philipps Hue stürzt andauernd ab:
              Dito
              EDIT:
              Bin zurück auf Version: 3.9.3
              Keine Probleme mehr, liegt also an der Neuen Version 3.9.4
              Immer Daten sichern!
              WinniW NegaleinN 2 Antworten Letzte Antwort
              • DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                Habe diesen Adapter zwar nicht aber könnte es u.U. an der Betaadminversion liegen?
                Ich würde zum Testen mal empfehlen auf die Adminversion 6.6.1 zu gehen.
                Könnte ja helfen.
                Lehrling seit 1975 !!!
                • arteckA Offline
                  arteckA Offline
                  arteck
                  @haselchen @Negalein
                  node 16 .. langsam solltet ihr umsteigen.. aum min Node 18.. die Probleme werden sich sonst heufen
                  • sigi234S sigi234
                    Dito
                    EDIT:
                    WinniW Offline
                    WinniW Offline
                    Winni
                    @sigi234 sagte in Philipps Hue stürzt andauernd ab:
                    @bbtown ...
                    Bei mir das gleiche, habe Node.js v18.17.0.
                    Es gibt nicht Gutes. Außer man tut es. Erich Kästner
                    • arteckA arteck
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      ja, in nächster Zeit mal.
                      Aber Node 16 hat nichts mit dem Hue Problem zu tun.
                      Denn auch mit V18 gibt es die.
                      • WinniW Winni
                        @bbtown ...
                        BBTownB Offline
                        BBTownB Offline
                        BBTown
                        Dito 👍
                        • NegaleinN Negalein
                          @negalein sagte in Philipps Hue stürzt andauernd ab:
                          Ich sehe nie das Problem mit zwei Zeilen im Terminal und einer kleinen Anpassung in der nodesource.list innerhalb von max. 5 Minuten auf die empfohlene Version zu wechseln.
                          • sigi234S sigi234
                            Dito
                            EDIT:
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            Dito
                            • Ro75R Offline
                              Ro75R Offline
                              Ro75
                              Ich hatte das Problem mit 3.9.3 und nodejs 16.20.0 ebefalls. Ich habe "sentry" abgeschalten und seither trat das Problem nicht mehr auf.
                              • G GreySkoda91
                                at JSON.parse ()
                                sigi234S Online
                                sigi234S Online
                                sigi234
                                @greyskoda91
                                Mit Version 3.9.5 behoben!
                                WinniW G 2 Antworten Letzte Antwort
                                • sigi234S sigi234
                                  @greyskoda91
                                  WinniW Offline
                                  WinniW Offline
                                  Winni
                                  @greyskoda91
                                  Läuft bei mir 👍
                                  • sigi234S sigi234
                                    @greyskoda91
                                    GreySkoda91
                                    @sigi234 said in Philipps Hue stürzt andauernd ab:
                                    @greyskoda91
                                    ne, bei mir läufts immer noch nicht.
