  4. [gelöst]Problemsuche error node-gyp ble adapter
ble adaptergyp errornode errorpython
44 Beiträge 4 Kommentatoren 6.0k Aufrufe 2 Beobachtet
    @thomas-braun hab ich umbenannt und danach ble versucht
    Would you like to upgrade ble from @0.13.3 to @0.13.4 now? [(y)es, (n)o]: y
    Update ble from @0.13.3 to @0.13.4
    NPM version: 9.6.7
    Installing iobroker.ble@0.13.4... (System call)
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
    npm ERR! command failed
    npm ERR! command sh -c node-gyp-build
    npm ERR! gyp info it worked if it ends with ok
    npm ERR! gyp info using node-gyp@7.1.2
    npm ERR! gyp info using node@18.17.0 | linux | x64
    npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
    npm ERR! (node:352773) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
    npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
    npm ERR! gyp info spawn /usr/bin/python3
    npm ERR! gyp info spawn args [
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
    npm ERR! gyp info spawn args   'binding.gyp',
    npm ERR! gyp info spawn args   '-f',
    npm ERR! gyp info spawn args   'make',
    npm ERR! gyp info spawn args   '-I',
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build/config.gypi',
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
    npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.17.0/include/node/common.gypi',
    npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
    npm ERR! gyp info spawn args   '-Dvisibility=default',
    npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.17.0',
    npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
    npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.17.0/<(target_arch)/node.lib',
    npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble',
    npm ERR! gyp info spawn args   '-Dnode_engine=v8',
    npm ERR! gyp info spawn args   '--depth=.',
    npm ERR! gyp info spawn args   '--no-parallel',
    npm ERR! gyp info spawn args   '--generator-output',
    npm ERR! gyp info spawn args   'build',
    npm ERR! gyp info spawn args   '-Goutput_dir=.'
    npm ERR! gyp info spawn args ]
    npm ERR! Traceback (most recent call last):
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
    npm ERR!     sys.exit(gyp.script_main())
    npm ERR!              ^^^^^^^^^^^^^^^^^
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
    npm ERR!     return main(sys.argv[1:])
    npm ERR!            ^^^^^^^^^^^^^^^^^^
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
    npm ERR!     return gyp_main(args)
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
    npm ERR!     [generator, flat_list, targets, data] = Load(
    npm ERR!                                             ^^^^^
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
    npm ERR!     result = gyp.input.Load(
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
    npm ERR!     LoadTargetBuildFile(
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
    npm ERR!     build_file_data = LoadOneBuildFile(
    npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
    npm ERR!     build_file_contents = open(build_file_path, "rU").read()
    npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
    npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gyp
    npm ERR! gyp ERR! configure error
    npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
    npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
    npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)
    npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)
    npm ERR! gyp ERR! System Linux 6.1.0-10-amd64
    npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
    npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
    npm ERR! gyp ERR! node -v v18.17.0
    npm ERR! gyp ERR! node-gyp -v v7.1.2
    npm ERR! gyp ERR! not ok
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-07-28T22_04_18_690Z-debug-0.log
    upload [5] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/.eslintrc.js .eslintrc.js application/javascript
    upload [4] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/ble.png ble.png image/png
    upload [3] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js build/index.js application/javascript
    upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js.map build/index.js.map application/json
    upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index_m.html index_m.html text/html
    upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/style.css style.css text/css
    #41
    @crunchip
    Dann schau in das genannte Log rein.
    Hier schaut's auch nach einem Ansatz 'dirty workaround' aus:
    https://stackoverflow.com/questions/74715990/node-gyp-err-invalid-mode-ru-while-trying-to-load-binding-gyp
    crunchipC 2 Antworten Letzte Antwort
      @crunchip
      crunchipC Abwesend
      crunchipC Abwesend
      #42
      @thomas-braun sagte in Problemsuche error node-gyp ble adapter:
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@9.6.7
      2 info using node@v18.17.0
      3 timing npm:load:whichnode Completed in 3ms
      4 timing config:load:defaults Completed in 4ms
      5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 1ms
      6 timing config:load:builtin Completed in 1ms
      7 timing config:load:cli Completed in 5ms
      8 timing config:load:env Completed in 0ms
      9 timing config:load:file:/opt/iobroker/.npmrc Completed in 4ms
      10 timing config:load:project Completed in 6ms
      11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
      12 timing config:load:user Completed in 1ms
      13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
      14 timing config:load:global Completed in 1ms
      15 timing config:load:setEnvs Completed in 2ms
      16 timing config:load Completed in 23ms
      17 timing npm:load:configload Completed in 23ms
      18 timing npm:load:mkdirpcache Completed in 0ms
      19 timing npm:load:mkdirplogs Completed in 0ms
      20 verbose title npm install iobroker.admin@6.6.4
      21 verbose argv "install" "--save-exact" "iobroker.admin@6.6.4"
      22 timing npm:load:setTitle Completed in 3ms
      23 timing config:load:flatten Completed in 10ms
      24 timing npm:load:display Completed in 12ms
      25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-07-28T22_14_54_602Z-
      26 verbose logfile /home/iobroker/.npm/_logs/2023-07-28T22_14_54_602Z-debug-0.log
      27 timing npm:load:logFile Completed in 22ms
      28 timing npm:load:timers Completed in 0ms
      29 timing npm:load:configScope Completed in 0ms
      30 timing npm:load Completed in 68ms
      31 timing arborist:ctor Completed in 1ms
      32 silly logfile start cleaning logs, removing 2 files
      33 silly logfile done cleaning log files
      34 timing idealTree:init Completed in 5625ms
      35 timing idealTree:userRequests Completed in 6ms
      36 silly idealTree buildDeps
      37 silly fetch manifest iobroker.admin@6.6.4
      38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.vis-2-widgets-energy
      39 http fetch GET 200 https://registry.npmjs.org/iobroker.admin 5916ms (cache updated)
      40 silly placeDep ROOT iobroker.admin@6.6.4 REPLACE for: iobroker.inst@3.0.0 want: 6.6.4
      41 timing idealTree:#root Completed in 6017ms
      42 timing idealTree:node_modules/iobroker.admin Completed in 0ms
      43 timing idealTree:buildDeps Completed in 6020ms
      44 timing idealTree:fixDepFlags Completed in 65ms
      45 timing idealTree Completed in 11794ms
      46 timing reify:loadTrees Completed in 11795ms
      47 timing reify:diffTrees Completed in 115ms
      48 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.admin' ]
      49 silly reify moves {
      49 silly reify   '/opt/iobroker/node_modules/iobroker.admin': '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk'
      49 silly reify }
      50 timing reify:retireShallow Completed in 6ms
      51 timing reify:createSparse Completed in 4ms
      52 timing reify:loadBundles Completed in 0ms
      53 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
      54 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
      55 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
      56 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
      57 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffprobe-installer/win32-x64
      58 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffprobe-installer/win32-x64' ]
      59 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffprobe-installer/win32-ia32
      60 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffprobe-installer/win32-ia32' ]
      61 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffprobe-installer/linux-ia32
      62 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffprobe-installer/linux-ia32' ]
      63 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffprobe-installer/linux-arm64
      64 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffprobe-installer/linux-arm64' ]
      65 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffprobe-installer/linux-arm
      66 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffprobe-installer/linux-arm' ]
      67 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffprobe-installer/darwin-x64
      68 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffprobe-installer/darwin-x64' ]
      69 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffprobe-installer/darwin-arm64
      70 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffprobe-installer/darwin-arm64' ]
      71 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffmpeg-installer/win32-x64
      72 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffmpeg-installer/win32-x64' ]
      73 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffmpeg-installer/win32-ia32
      74 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffmpeg-installer/win32-ia32' ]
      75 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffmpeg-installer/linux-ia32
      76 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffmpeg-installer/linux-ia32' ]
      77 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffmpeg-installer/linux-arm64
      78 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffmpeg-installer/linux-arm64' ]
      79 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffmpeg-installer/linux-arm
      80 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffmpeg-installer/linux-arm' ]
      81 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffmpeg-installer/darwin-x64
      82 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffmpeg-installer/darwin-x64' ]
      83 verbose reify failed optional dependency /opt/iobroker/node_modules/@ffmpeg-installer/darwin-arm64
      84 silly reify mark deleted [ '/opt/iobroker/node_modules/@ffmpeg-installer/darwin-arm64' ]
      85 timing reifyNode:node_modules/osx-temperature-sensor Completed in 17ms
      86 timing reifyNode:node_modules/fsevents Completed in 16ms
      87 timing reifyNode:node_modules/@ffprobe-installer/win32-x64 Completed in 16ms
      88 timing reifyNode:node_modules/@ffprobe-installer/win32-ia32 Completed in 15ms
      89 timing reifyNode:node_modules/@ffprobe-installer/linux-ia32 Completed in 15ms
      90 timing reifyNode:node_modules/@ffprobe-installer/linux-arm64 Completed in 16ms
      91 timing reifyNode:node_modules/@ffprobe-installer/linux-arm Completed in 16ms
      92 timing reifyNode:node_modules/@ffprobe-installer/darwin-x64 Completed in 16ms
      93 timing reifyNode:node_modules/@ffprobe-installer/darwin-arm64 Completed in 16ms
      94 timing reifyNode:node_modules/@ffmpeg-installer/win32-x64 Completed in 15ms
      95 timing reifyNode:node_modules/@ffmpeg-installer/win32-ia32 Completed in 15ms
      96 timing reifyNode:node_modules/@ffmpeg-installer/linux-ia32 Completed in 15ms
      97 timing reifyNode:node_modules/@ffmpeg-installer/linux-arm64 Completed in 16ms
      98 timing reifyNode:node_modules/@ffmpeg-installer/linux-arm Completed in 16ms
      99 timing reifyNode:node_modules/@ffmpeg-installer/darwin-x64 Completed in 16ms
      100 timing reifyNode:node_modules/@ffmpeg-installer/darwin-arm64 Completed in 16ms
      101 silly tarball no local data for iobroker.admin@https://registry.npmjs.org/iobroker.admin/-/iobroker.admin-6.6.4.tgz. Extracting by manifest.
      102 timing reifyNode:node_modules/buildcheck Completed in 109ms
      103 timing reifyNode:node_modules/cpu-features Completed in 612ms
      104 http fetch GET 200 https://registry.npmjs.org/iobroker.admin/-/iobroker.admin-6.6.4.tgz 4871ms (cache miss)
      105 timing reifyNode:node_modules/iobroker.admin Completed in 4897ms
      106 timing reify:unpack Completed in 4900ms
      107 timing reify:unretire Completed in 19ms
      108 timing build:queue Completed in 4ms
      109 info run cpu-features@0.0.8 install node_modules/cpu-features node buildcheck.js > buildcheck.gypi && node-gyp rebuild
      110 info run cpu-features@0.0.8 install { code: 1, signal: null }
      111 verbose reify failed optional dependency /opt/iobroker/node_modules/cpu-features
      112 silly reify mark deleted [ '/opt/iobroker/node_modules/cpu-features' ]
      113 verbose reify failed optional dependency /opt/iobroker/node_modules/buildcheck
      114 silly reify mark deleted [ '/opt/iobroker/node_modules/buildcheck' ]
      115 timing build:run:install:node_modules/cpu-features Completed in 1175ms
      116 timing build:run:install Completed in 1177ms
      117 timing build:deps Completed in 1181ms
      118 timing build Completed in 1182ms
      119 timing reify:build Completed in 1184ms
      120 timing reify:trash Completed in 132ms
      121 timing reify:save Completed in 2140ms
      122 timing reify Completed in 21181ms
      123 silly ADD
      124 silly ADD
      125 silly ADD
      126 silly ADD
      127 silly ADD
      128 silly ADD
      129 silly ADD
      130 silly ADD
      131 silly ADD
      132 silly ADD
      133 silly ADD
      134 silly ADD
      135 silly ADD
      136 silly ADD
      137 silly ADD
      138 silly ADD
      139 silly ADD
      140 silly ADD
      141 silly CHANGE node_modules/iobroker.admin
      142 timing command:install Completed in 21211ms
      143 verbose exit 0
      144 timing npm Completed in 21766ms
      145 info ok
        @crunchip
        crunchipC Abwesend
        crunchipC Abwesend
        #43
        'dirty workaround'
        morgen in aller frische, bevor ich heut noch etwas kaputt mach
        nach einem Ansatz
        https://github.com/nodejs/node-gyp/issues/2219
          NPM version: 9.6.7
          npm ERR! code 1
          npm ERR!                                             ^^^^^
          crunchipC Abwesend
          crunchipC Abwesend
          #44
          @crunchip sagte in Problemsuche error node-gyp ble adapter:
          hab ich angepasst, von
          else:
          auf
          else:
                      build_file_contents = open(build_file_path, "r").read()
          update lief jetzt durch
