  3. Off Topic
  4. Backup and Restore auf neuem Raspberry
    1.0k
    6.1k
58 Beiträge 7 Kommentatoren 6.5k Aufrufe 3 Beobachtet
    @loverz
    Dann knall es hier nochmal frisch rein.
    loverz
    iob diag:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     19:34:23 up 4 days,  7:16,  1 user,  load average: 0.09, 0.05, 0.01
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=49.6'C
    volt=0.8563V
    *** Time and Time Zones ***
                   Local time: Mon 2023-07-31 19:34:23 CEST
               Universal time: Mon 2023-07-31 17:34:23 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            1.8G        762M        527M        1.0M        559M        1.1G
    Swap:            99M          0B         99M
    Total:          1.9G        762M        627M
             1849 M total memory
              762 M used memory
              897 M active memory
              307 M inactive memory
              527 M free memory
               57 M buffer memory
              502 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FILESYSTEM ***
    /dev/root      ext4      117G  3.9G  109G   4% /
    devtmpfs       devtmpfs  667M     0  667M   0% /dev
    tmpfs          tmpfs     925M     0  925M   0% /dev/shm
    tmpfs          tmpfs     370M  1.1M  369M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
    [Thu Jul 27 12:18:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:43:7C:47 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f60dec51-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Thu Jul 27 12:18:17 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Thu Jul 27 12:18:17 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Jul 27 12:18:19 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems (real ones only):
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    654M    /var/
    257M    /var/cache
    251M    /var/cache/apt
    171M    /var/lib
    151M    /var/cache/apt/archives
    Archived and active journals take up 120.0M in the file system.
    /opt/iobroker/backups:
    175M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    225M    /opt/iobroker/iobroker-data/
    98M     /opt/iobroker/iobroker-data/files
    92M     /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/states.jsonl
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    5.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/44.59b48e42.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.1
    /usr/bin/node           v18.16.1
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.1-deb-1nodesource1
      Candidate: 18.16.1-deb-1nodesource1
      Version table:
     *** 18.16.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    MULTIHOSTSERVICE/enabled: false
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : Eck29-ioBroker                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : Eck29-ioBroker                           - disabled
    + system.adapter.backitup.0               : backitup              : Eck29-ioBroker                           -  enabled
      system.adapter.daswetter.0              : daswetter             : Eck29-ioBroker                           - disabled
      system.adapter.deconz.0                 : deconz                : Eck29-ioBroker                           - disabled, port: 80
      system.adapter.easee.0                  : easee                 : Eck29-ioBroker                           - disabled
      system.adapter.ems-esp.0                : ems-esp               : Eck29-ioBroker                           - disabled
      system.adapter.hmip.0                   : hmip                  : Eck29-ioBroker                           - disabled
      system.adapter.hs100.0                  : hs100                 : Eck29-ioBroker                           - disabled
      system.adapter.hue.0                    : hue                   : Eck29-ioBroker                           - disabled, port: 443
    + system.adapter.influxdb.0               : influxdb              : Eck29-ioBroker                           -  enabled, port: 8086
      system.adapter.info.0                   : info                  : Eck29-ioBroker                           - disabled
      system.adapter.javascript.0             : javascript            : Eck29-ioBroker                           - disabled
      system.adapter.km200.0                  : km200                 : Eck29-ioBroker                           - disabled
      system.adapter.knx.0                    : knx                   : Eck29-ioBroker                           - disabled, bind: 192.168.1.166
      system.adapter.mydlink.0                : mydlink               : Eck29-ioBroker                           - disabled
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : Eck29-ioBroker                           - disabled
      system.adapter.philips-tv.0             : philips-tv            : Eck29-ioBroker                           - disabled
      system.adapter.ping.0                   : ping                  : Eck29-ioBroker                           - disabled
      system.adapter.rpi2.0                   : rpi2                  : Eck29-ioBroker                           - disabled
      system.adapter.shelly.0                 : shelly                : Eck29-ioBroker                           - disabled, port: 1882, bind: 192.168.1.166
      system.adapter.solarmanpv.0             : solarmanpv            : Eck29-ioBroker                           - disabled
      system.adapter.telegram.0               : telegram              : Eck29-ioBroker                           - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.telegram.1               : telegram              : Eck29-ioBroker                           - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.yahka.0                  : yahka                 : Eck29-ioBroker                           - disabled
      system.adapter.yahka.3                  : yahka                 : Eck29-ioBroker                           - disabled
      system.adapter.yeelight-2.0             : yeelight-2            : Eck29-ioBroker                           - disabled
    + instance is alive
    ioBroker-Repositories
    latest        : http://iobroker.live/repo/sources-dist-latest.json
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.3.5    , installed 6.3.5
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "easee"        : 1.0.7    , installed 1.0.7
    Adapter    "ems-esp"      : 1.30.0   , installed 1.30.0
    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
    Adapter    "hs100"        : 2.1.2    , installed 2.1.2
    Adapter    "hue"          : 3.9.3    , installed 3.9.3
    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
    Adapter    "info"         : 1.9.26   , installed 1.9.26
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Adapter    "km200"        : 2.0.3    , installed 2.0.3
    Adapter    "knx"          : 2.0.17   , installed 2.0.18
    Adapter    "mydlink"      : 1.3.1    , installed 1.3.1
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
    Adapter    "ping"         : 1.5.3    , installed 1.5.3
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "solarmanpv"   : 0.5.0    , installed 0.5.0
    Adapter    "telegram"     : 1.16.0   , installed 1.15.6 [Updatable]
    Adapter    "yahka"        : 0.17.0   , installed 1.0.3
    Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
    Objects and States
    Objects:        10841
    States:         8900
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:6 https://packages.grafana.com/oss/deb stable InRelease
    Hit:7 https://repos.influxdata.com/debian stable InRelease
    Reading package lists...
    Pending Updates: 6
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13935      846/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15177      846/iobroker.js-con
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        12803      761/influxd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13723      502/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12656      502/sshd: /usr/sbin
    tcp6       0      0 :::8086                 :::*                    LISTEN      110        15141      761/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12912      916/io.admin.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      111        12051      845/grafana
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11872      757/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11774      366/avahi-daemon: r
    udp        0      0 0.0.0.0:60657           0.0.0.0:*                           108        11776      366/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        11775      366/avahi-daemon: r
    udp6       0      0 :::47582                :::*                                108        11777      366/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          16491      757/dhcpcd
    2023-07-31 02:18:43.539  - info: host.Eck29-ioBroker Delete log file iobroker.2023-07-23.log.gz
    2023-07-31 12:18:56.392  - info: admin.0 (916) Adapter rating updated
    2023-07-31 12:19:19.714  - info: admin.0 (916) Request actual repository...
    2023-07-31 12:19:20.485  - info: host.Eck29-ioBroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-07-31 12:19:24.886  - info: admin.0 (916) Repository received successfully.
    2023-07-31 19:33:22.295  - info: admin.0 (916) ==> Connected system.user.admin from ::ffff:192.168.1.152
    apt policy grafana
    apt policy influxdb*
    grafana:
      Installed: 10.0.2
      Candidate: 10.0.3
      Version table:
         10.0.3 500
            500 https://packages.grafana.com/oss/deb stable/main arm64 Packages
     *** 10.0.2 500
         10.0.1 500
         10.0.0 500
         9.5.7 500
         9.5.6 500
         9.5.5 500
         9.5.3 500
         9.5.2 500
         9.5.1 500
         9.5.0 500
         9.4.13 500
         9.4.12 500
         9.4.10 500
         9.4.9 500
         9.4.7 500
         9.4.3 500
         9.4.2 500
         9.4.1 500
         9.4.0 500
         9.3.16 500
         9.3.15 500
         9.3.14 500
         9.3.13 500
         9.3.11 500
         9.3.8 500
         9.3.6 500
         9.3.4 500
         9.3.2 500
         9.3.1 500
         9.3.0 500
         9.2.20 500
         9.2.19 500
         9.2.18 500
         9.2.17 500
         9.2.15 500
         9.2.13 500
         9.2.10 500
         9.2.8 500
         9.2.7 500
         9.2.6 500
         9.2.5 500
         9.2.4 500
         9.2.3 500
         9.2.2 500
         9.2.1 500
         9.2.0 500
         9.1.8 500
         9.1.7 500
         9.1.6 500
         9.1.5 500
         9.1.4 500
         9.1.3 500
         9.1.2 500
         9.1.1 500
         9.1.0 500
         9.0.9 500
         9.0.8 500
         9.0.7 500
         9.0.6 500
         9.0.5 500
         9.0.4 500
         9.0.3 500
         9.0.2 500
         9.0.1 500
         9.0.0 500
         8.5.27 500
         8.5.26 500
         8.5.25 500
         8.5.24 500
         8.5.22 500
         8.5.21 500
         8.5.20 500
         8.5.16 500
         8.5.15 500
         8.5.14 500
         8.5.13 500
         8.5.12 500
         8.5.10 500
         8.5.9 500
         8.5.6 500
         8.5.5 500
         8.5.4 500
         8.5.3 500
         8.5.2 500
         8.5.1 500
         8.5.0 500
         8.4.11 500
         8.4.10 500
         8.4.7 500
         8.4.6 500
         8.4.5 500
         8.4.4 500
         8.4.3 500
         8.4.2 500
         8.4.1 500
         8.4.0 500
         8.3.11 500
         8.3.10 500
         8.3.7 500
         8.3.6 500
         8.3.5 500
         8.3.4 500
         8.3.3 500
         8.3.2 500
         8.3.1 500
         8.3.0 500
         8.2.7 500
         8.2.6 500
         8.2.5 500
         8.2.4 500
         8.2.3 500
         8.2.2 500
         8.2.1 500
         8.2.0 500
         8.1.8 500
         8.1.7 500
         8.1.6 500
         8.1.5 500
         8.1.4 500
         8.1.3 500
         8.1.2 500
         8.1.1 500
         8.1.0 500
         8.0.7 500
         8.0.6 500
         8.0.5 500
         8.0.4 500
         8.0.3 500
         8.0.2 500
         8.0.1 500
         8.0.0 500
         7.5.16 500
         7.5.15 500
         7.5.13 500
         7.5.12 500
         7.5.11 500
         7.5.10 500
         7.5.9 500
         7.5.8 500
         7.5.7 500
         7.5.6 500
         7.5.5 500
         7.5.4 500
         7.5.3 500
         7.5.2 500
         7.5.1 500
         7.5.0 500
         7.4.5 500
         7.4.3 500
         7.4.2 500
         7.4.1 500
         7.4.0 500
         7.3.10 500
         7.3.7 500
         7.3.6 500
         7.3.5 500
         7.3.4 500
         7.3.3 500
         7.3.2 500
         7.3.1 500
         7.3.0 500
         7.2.2 500
         7.2.1 500
         7.2.0 500
         7.1.5 500
         7.1.4 500
         7.1.3 500
         7.1.2 500
         7.1.1 500
         7.1.0 500
         7.0.6 500
         7.0.5 500
         7.0.4 500
         7.0.3 500
         7.0.2 500
         7.0.1 500
         7.0.0 500
         6.7.6 500
         6.7.5 500
         6.7.4 500
         6.7.3 500
         6.7.2 500
         6.7.1 500
         6.7.0 500
         6.6.2 500
         6.6.1 500
         6.6.0 500
         6.5.3 500
         6.5.2 500
         6.5.1 500
         6.5.0 500
         6.4.5 500
         6.4.4 500
         6.4.3 500
         6.4.2 500
         6.4.1 500
         6.4.0 500
         6.3.7 500
         6.3.6 500
         6.3.5 500
         6.3.4 500
         6.3.3 500
         6.3.2 500
         6.3.1 500
         6.3.0 500
         6.2.5 500
         6.2.4 500
         6.2.3 500
         6.2.2 500
         6.2.1 500
         6.2.0 500
         6.1.6 500
         6.1.5 500
         6.1.4 500
         6.1.3 500
         6.1.2 500
         6.1.1 500
         6.1.0 500
         6.0.2 500
         6.0.1 500
         6.0.0 500
         5.4.5 500
         5.4.4 500
         5.4.3 500
         5.4.2 500
         5.4.1 500
         5.4.0 500
         5.3.4 500
         5.3.3 500
         5.3.2 500
         5.3.1 500
         5.3.0 500
         5.2.5 500
         5.2.4 500
         5.2.3 500
         5.2.2 500
         5.2.1 500
         5.2.0 500
         0.0.0~test 500
    influxdb2-cli:
      Installed: (none)
      Candidate: 2.7.3-1
      Version table:
         2.7.3-1 500
            500 https://repos.influxdata.com/debian stable/main arm64 Packages
         2.7.1-2 500
         2.6.1 500
         2.6.0 500
         2.5.0 500
         2.4.0 500
         2.3.0 500
    influxdb-client:
      Installed: (none)
      Candidate: 1.6.7~rc0-1+b5
      Version table:
         1.6.7~rc0-1+b5 500
    influxdb-dev:
      Installed: (none)
      Candidate: (none)
      Version table:
    influxdb2-client:
      Installed: (none)
      Candidate: 2.7.1-1
      Version table:
         2.7.1-1 500
    influxdb:
      Installed: 1.8.10-1
      Candidate: 1.8.10-1
      Version table:
     *** 1.8.10-1 500
         1.6.7~rc0-1+b5 500
    influxdb2:
      Installed: (none)
      Candidate: 2.7.1-1
      Version table:
         2.7.1-1 500
         2.7.0-1 500
         2.6.1-1 500
         2.6.0-1 500
         2.5.1-1 500
         2.4.0-1 500
         2.3.0-1 500
         2.2.0 500
    • L loverz
      iob diag:
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=49.6'C
      volt=0.8563V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               1849 M total memory
                762 M used memory
                897 M active memory
                527 M free memory
                 57 M buffer memory
                502 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      654M    /var/
      257M    /var/cache
      251M    /var/cache/apt
      171M    /var/lib
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     7.0.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        10841
      States:         8900
      Pending Updates: 6
      apt policy grafana
      grafana:
        Installed: 10.0.2
        Candidate: 10.0.3
        Version table:
           10.0.3 500
       *** 10.0.2 500
           10.0.1 500
           10.0.0 500
           9.5.7 500
           9.5.6 500
           9.5.5 500
           9.5.3 500
           9.5.2 500
           9.5.1 500
           9.5.0 500
           9.4.13 500
           9.4.12 500
           9.4.10 500
           9.4.9 500
           9.4.7 500
           9.4.3 500
           9.4.2 500
           9.4.1 500
           9.4.0 500
           9.3.16 500
           9.3.15 500
           9.3.14 500
           9.3.13 500
           9.3.11 500
           9.3.8 500
           9.3.6 500
           9.3.4 500
           9.3.2 500
           9.3.1 500
           9.3.0 500
           9.2.20 500
           9.2.19 500
           9.2.18 500
           9.2.17 500
           9.2.15 500
           9.2.13 500
           9.2.10 500
           9.2.8 500
           9.2.7 500
           9.2.6 500
           9.2.5 500
           9.2.4 500
           9.2.3 500
           9.2.2 500
           9.2.1 500
           9.2.0 500
           9.1.8 500
           9.1.7 500
           9.1.6 500
           9.1.5 500
           9.1.4 500
           9.1.3 500
           9.1.2 500
           9.1.1 500
           9.1.0 500
           9.0.9 500
           9.0.8 500
           9.0.7 500
           9.0.6 500
           9.0.5 500
           9.0.4 500
           9.0.3 500
           9.0.2 500
           9.0.1 500
           9.0.0 500
           8.5.27 500
           8.5.26 500
           8.5.25 500
           8.5.24 500
           8.5.22 500
           8.5.21 500
           8.5.20 500
           8.5.16 500
           8.5.15 500
           8.5.14 500
           8.5.13 500
           8.5.12 500
           8.5.10 500
           8.5.9 500
           8.5.6 500
           8.5.5 500
           8.5.4 500
           8.5.3 500
           8.5.2 500
           8.5.1 500
           8.5.0 500
           8.4.11 500
           8.4.10 500
           8.4.7 500
           8.4.6 500
           8.4.5 500
           8.4.4 500
           8.4.3 500
           8.4.2 500
           8.4.1 500
           8.4.0 500
           8.3.11 500
           8.3.10 500
           8.3.7 500
           8.3.6 500
           8.3.5 500
           8.3.4 500
           8.3.3 500
           8.3.2 500
           8.3.1 500
           8.3.0 500
           8.2.7 500
           8.2.6 500
           8.2.5 500
           8.2.4 500
           8.2.3 500
           8.2.2 500
           8.2.1 500
           8.2.0 500
           8.1.8 500
           8.1.7 500
           8.1.6 500
           8.1.5 500
           8.1.4 500
           8.1.3 500
           8.1.2 500
           8.1.1 500
           8.1.0 500
           8.0.7 500
           8.0.6 500
           8.0.5 500
           8.0.4 500
           8.0.3 500
           8.0.2 500
           8.0.1 500
           8.0.0 500
           7.5.16 500
           7.5.15 500
           7.5.13 500
           7.5.12 500
           7.5.11 500
           7.5.10 500
           7.5.9 500
           7.5.8 500
           7.5.7 500
           7.5.6 500
           7.5.5 500
           7.5.4 500
           7.5.3 500
           7.5.2 500
           7.5.1 500
           7.5.0 500
           7.4.5 500
           7.4.3 500
           7.4.2 500
           7.4.1 500
           7.4.0 500
           7.3.10 500
           7.3.7 500
           7.3.6 500
           7.3.5 500
           7.3.4 500
           7.3.3 500
           7.3.2 500
           7.3.1 500
           7.3.0 500
           7.2.2 500
           7.2.1 500
           7.2.0 500
           7.1.5 500
           7.1.4 500
           7.1.3 500
           7.1.2 500
           7.1.1 500
           7.1.0 500
           7.0.6 500
           7.0.5 500
           7.0.4 500
           7.0.3 500
           7.0.2 500
           7.0.1 500
           7.0.0 500
           6.7.6 500
           6.7.5 500
           6.7.4 500
           6.7.3 500
           6.7.2 500
           6.7.1 500
           6.7.0 500
           6.6.2 500
           6.6.1 500
           6.6.0 500
           6.5.3 500
           6.5.2 500
           6.5.1 500
           6.5.0 500
           6.4.5 500
           6.4.4 500
           6.4.3 500
           6.4.2 500
           6.4.1 500
           6.4.0 500
           6.3.7 500
           6.3.6 500
           6.3.5 500
           6.3.4 500
           6.3.3 500
           6.3.2 500
           6.3.1 500
           6.3.0 500
           6.2.5 500
           6.2.4 500
           6.2.3 500
           6.2.2 500
           6.2.1 500
           6.2.0 500
           6.1.6 500
           6.1.5 500
           6.1.4 500
           6.1.3 500
           6.1.2 500
           6.1.1 500
           6.1.0 500
           6.0.2 500
           6.0.1 500
           6.0.0 500
           5.4.5 500
           5.4.4 500
           5.4.3 500
           5.4.2 500
           5.4.1 500
           5.4.0 500
           5.3.4 500
           5.3.3 500
           5.3.2 500
           5.3.1 500
           5.3.0 500
           5.2.5 500
           5.2.4 500
           5.2.3 500
           5.2.2 500
           5.2.1 500
           5.2.0 500
           0.0.0~test 500
      influxdb2-cli:
        Installed: (none)
        Candidate: 2.7.3-1
        Version table:
           2.7.3-1 500
           2.7.1-2 500
           2.6.1 500
           2.6.0 500
           2.5.0 500
           2.4.0 500
           2.3.0 500
      influxdb-client:
        Installed: (none)
        Version table:
           1.6.7~rc0-1+b5 500
      influxdb-dev:
        Installed: (none)
        Candidate: (none)
        Version table:
      influxdb2-client:
        Installed: (none)
        Candidate: 2.7.1-1
        Version table:
           2.7.1-1 500
      influxdb:
        Installed: 1.8.10-1
        Candidate: 1.8.10-1
        Version table:
       *** 1.8.10-1 500
           1.6.7~rc0-1+b5 500
      influxdb2:
        Installed: (none)
        Candidate: 2.7.1-1
        Version table:
           2.7.1-1 500
           2.7.0-1 500
           2.6.1-1 500
           2.6.0-1 500
           2.5.1-1 500
           2.4.0-1 500
           2.3.0-1 500
           2.2.0 500
      @loverz
      Soweit keine Schnitzer drin.
      Aktualisier die 6 Pakete des OS noch.
      L 1 Antwort Letzte Antwort
        @loverz
        loverz
        @thomas-braun die Frage ist, wieso meine inluxDB Werte nicht zurückkommen :(
        • L loverz
          @loverz
          Zumindest hängt es nicht grundsätzlich an der Installation.
          Das Backup spuckt welche Meldungen aus?
            @loverz
            loverz
            Started restore ...
            [DEBUG] [influxDB] - Created tmp directory
            [DEBUG] [influxDB] - Start infuxDB Restore ...
            [DEBUG] [influxDB] - influxdb.0 is stopped
            [ERROR] [influxDB] - 2023/07/31 19:57:48 error updating meta: DB metadata not changed. database may already exist
            restore: DB metadata not changed. database may already exist
            [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
            [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
            [DEBUG] [influxDB] - infuxDB Restore completed successfully
            [EXIT] influxDB restore done
            [DEBUG] [influxDB] - influxdb.0 started
            auffällig ist, dass backitup immer 2 Backups anlegt:
            Thomas BraunT simatecS 2 Antworten Letzte Antwort
            • L loverz
              Started restore ...
              @loverz
              Muss sich jemand mit influx-Ahnung anschauen.
              • L Offline
                loverz
                schrieb am zuletzt editiert von loverz
                @simatec kanns du mir sagen, wieso das influxDB Restore nicht klappt?
                Und wieso macht dein Adapter immer 2 Backups? Ein kleines und ein großes.
                • Marc BergM Offline
                  Marc BergM Offline
                  Marc Berg
                  @loverz sagte in Backup and Restore auf neuem Raspberry:
                  In den Fehlermeldungen kann man sehen, warum der Restore nicht funktioniert. Da deine Datenpunkte schon fleißig Daten schreiben, gibt es die Datenbank schon. Der Restore funktioniert nur, wenn die DB noch nicht existiert. Also in der Instanz die Daten löschen und danach, bevor wieder neue Daten geschrieben werden, erneut den Restore starten. Am besten nach dem Löschen die Instanz beenden, damit die DB nicht sofort wieder angelegt wird.
                  Warum du zwei Backups hast, weiß ich nicht. Habe ich so noch nicht gesehen.
                  • L loverz
                    simatecS Offline
                    simatecS Offline
                    simatec
                    Was soll ich mit dieser Frage anfangen? Bitte einen Debuglog posten...
                    Auch mit dieser Frage kann ich nichts anfangen...
                    Bitte die Ausgabe von folgenden Befehlen zusätzlich posten
                    ls -lah /opt/iobroker/backups
                    iob diag
                    • Besuche meine Github Seite
                    • HowTo Restore ioBroker
                    • L loverz
                      Started restore ...
                      simatecS Offline
                      simatecS Offline
                      simatec
                      @loverz Zeige bitte die Config von Backitup
                      • Marc BergM Marc Berg
                        loverz
                        @marc-berg danke für die Info.
                        Wie kann ich die Datenbank löschen bzw. die Daten in der Instanz?
                        • L loverz
                          Marc BergM Offline
                          Marc BergM Offline
                          Marc Berg
                          • simatecS simatec
                            loverz
                            Ich sehe da unten ist ein Haken "alte influxDB vor dem Restore löschen" hab den am neuen System an, am alten aus.
                            Muss ich den beim alten an machen und das Backup mit diesem Haken erstellen?
                              loverz
                              @marc-berg jetzt geht es...
                              Hatte die Instanz direkt nach dem Löschen aus gelassen.
                              Started restore ...
                              @simatec dann funktioniert aber doch der oben genannte Haken nicht oder?
                              Außerdem weiß ich noch nicht, wieso 2 Backups angelegt werden. Bei Grafana übrigens auch.
                              • L Offline
                                loverz
                                der Grafana Restore sieht so aus:
                                Started restore ...
                                [DEBUG] [grafana] - Start Grafana Restore ...
                                [DEBUG] [grafana] - filename for restore: /opt/iobroker/backups/grafana_2023_07_31-03_31_57_Eck29_backupiobroker.tar.gz
                                [DEBUG] [grafana] - Grafana tmp directory created: /opt/iobroker/backups/grafana_tmp
                                [DEBUG] [grafana] - start decompress
                                [DEBUG] [grafana] - Grafana request started
                                [DEBUG] [grafana] - Grafana is available ... Status: 200
                                [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB.json
                                [DEBUG] [grafana] - cannot restore datasource "InfluxDB": "data source with the same name already exists"
                                [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/energieverbrauch.json
                                [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/general-alerting.json
                                [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/heizungsanlage.json
                                [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/wetterdaten.json
                                [DEBUG] [grafana] - dashboard restore for "general-alerting" finish: {"id":2,"slug":"general-alerting","status":"success","uid":"XflZZbZRz","url":"/d/XflZZbZRz/general-alerting","version":4}
                                [DEBUG] [grafana] - dashboard restore for "wetterdaten" finish: {"id":1,"slug":"wetterdaten","status":"success","uid":"MyXZDlggk","url":"/d/MyXZDlggk/wetterdaten","version":4}
                                [DEBUG] [grafana] - dashboard restore for "energieverbrauch" finish: {"id":4,"slug":"energieverbrauch","status":"success","uid":"QJpROlgRk","url":"/d/QJpROlgRk/energieverbrauch","version":4}
                                [DEBUG] [grafana] - dashboard restore for "heizungsanlage" finish: {"id":3,"slug":"heizungsanlage","status":"success","uid":"BJK6AugRk","url":"/d/BJK6AugRk/heizungsanlage","version":4}
                                [DEBUG] [grafana] - Grafana request ended
                                [DEBUG] [grafana] - Try deleting the Grafana tmp directory
                                [DEBUG] [grafana] - Grafana tmp directory was successfully deleted
                                [DEBUG] [grafana] - Grafana Restore completed successfully
                                [EXIT] Grafana restore done
                                Leider sind aber meine Dashboards hinterher nicht da...
                                @Marc-Berg hast du hier auch eine Idee?
                                • L loverz
                                  Started restore ...
                                  Marc BergM Offline
                                  Marc BergM Offline
                                  Marc Berg
                                  Hast du "General" mal aufgeklappt?
                                    loverz
                                    @marc-berg .... das wars. Ich schäme mich gerade xD
                                    hatte aber auch deshalb nicht daran geglaubt, da sie nicht wie gewohnt auf der Startseite waren. Muss sie dort wohl noch manuell als favorit hinzufügen...
                                    • L loverz
                                      Marc BergM Offline
                                      Marc BergM Offline
                                      Marc Berg
                                      @loverz
                                      Es fehlen noch die Logs, um die @simatec dich gebeten hat, wegen des Backups
                                      • simatecS simatec
                                        iob diag
                                        loverz
                                        @simatec ist zu lang, passt hier nicht rein. Auch einzeln nicht.
                                        • L loverz
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          @loverz Nein das ist nicht zu lang …
                                          Zeige mal bitte deine Debuglogs gefiltert von Backitup
