  3. Off Topic
  4. Backup and Restore auf neuem Raspberry
    1.0k
    6.1k
58 Beiträge 7 Kommentatoren 6.5k Aufrufe 3 Beobachtet
  • Thomas BraunT Online
    @loverz
    Wie bist du denn da unterwegs?
    iob diag
    In der Langfassung, zusätzlich danach
    apt policy grafana
    apt policy influxdb*
    L 1 Antwort Letzte Antwort
      @loverz
      iob diag
      apt policy grafana
      loverz
      @thomas-braun den iob diag hatte ich bereits im verlinkten Thread gepostet.
      Führe es aber nachher gerne nochmal aus.
      • L loverz
        @loverz
        Dann knall es hier nochmal frisch rein.
          @loverz
          loverz
          iob diag:
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Model           : Raspberry Pi 4 Model B Rev 1.1
          Architecture    : aarch64
          Docker          : false
          Virtualization  : none
          Distributor ID: Debian
          Description:    Debian GNU/Linux 11 (bullseye)
          Release:        11
          Codename:       bullseye
          PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
          NAME="Debian GNU/Linux"
          VERSION_ID="11"
          VERSION="11 (bullseye)"
          VERSION_CODENAME=bullseye
          ID=debian
          HOME_URL="https://www.debian.org/"
          SUPPORT_URL="https://www.debian.org/support"
          BUG_REPORT_URL="https://bugs.debian.org/"
          Systemuptime and Load:
           19:34:23 up 4 days,  7:16,  1 user,  load average: 0.09, 0.05, 0.01
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          Other values than 0x0 hint to temperature/voltage problems
          temp=49.6'C
          volt=0.8563V
          *** Time and Time Zones ***
                         Local time: Mon 2023-07-31 19:34:23 CEST
                     Universal time: Mon 2023-07-31 17:34:23 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            1.8G        762M        527M        1.0M        559M        1.1G
          Swap:            99M          0B         99M
          Total:          1.9G        762M        627M
                   1849 M total memory
                    762 M used memory
                    897 M active memory
                    307 M inactive memory
                    527 M free memory
                     57 M buffer memory
                    502 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /dev/root      ext4      117G  3.9G  109G   4% /
          devtmpfs       devtmpfs  667M     0  667M   0% /dev
          tmpfs          tmpfs     925M     0  925M   0% /dev/shm
          tmpfs          tmpfs     370M  1.1M  369M   1% /run
          /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
          tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
          [Thu Jul 27 12:18:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:43:7C:47 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f60dec51-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Thu Jul 27 12:18:17 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Thu Jul 27 12:18:17 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Thu Jul 27 12:18:19 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          654M    /var/
          257M    /var/cache
          251M    /var/cache/apt
          171M    /var/lib
          151M    /var/cache/apt/archives
          Archived and active journals take up 120.0M in the file system.
          /opt/iobroker/backups:
          175M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          225M    /opt/iobroker/iobroker-data/
          98M     /opt/iobroker/iobroker-data/files
          92M     /opt/iobroker/iobroker-data/backup-objects
          52M     /opt/iobroker/iobroker-data/files/javascript.admin
          34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
          25M     /opt/iobroker/iobroker-data/objects.jsonl
          12M     /opt/iobroker/iobroker-data/states.jsonl
          6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
          6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
          5.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/44.59b48e42.chunk.js.map
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.16.1
          /usr/bin/node           v18.16.1
          /usr/bin/npm            9.5.1
          /usr/bin/npx            9.5.1
          nodejs:
            Installed: 18.16.1-deb-1nodesource1
            Candidate: 18.16.1-deb-1nodesource1
            Version table:
           *** 18.16.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
               12.22.12~dfsg-1~deb11u4 500
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
               12.22.12~dfsg-1~deb11u3 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
          No problems detected
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  4.0.24
          admin:          6.3.5
          javascript:     7.0.3
          Adapters from github:   0
          Adapter State
          + system.adapter.admin.0                  : admin                 : Eck29-ioBroker                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.alexa2.0                 : alexa2                : Eck29-ioBroker                           - disabled
          + system.adapter.backitup.0               : backitup              : Eck29-ioBroker                           -  enabled
            system.adapter.daswetter.0              : daswetter             : Eck29-ioBroker                           - disabled
            system.adapter.deconz.0                 : deconz                : Eck29-ioBroker                           - disabled, port: 80
            system.adapter.easee.0                  : easee                 : Eck29-ioBroker                           - disabled
            system.adapter.ems-esp.0                : ems-esp               : Eck29-ioBroker                           - disabled
            system.adapter.hmip.0                   : hmip                  : Eck29-ioBroker                           - disabled
            system.adapter.hs100.0                  : hs100                 : Eck29-ioBroker                           - disabled
            system.adapter.hue.0                    : hue                   : Eck29-ioBroker                           - disabled, port: 443
          + system.adapter.influxdb.0               : influxdb              : Eck29-ioBroker                           -  enabled, port: 8086
            system.adapter.info.0                   : info                  : Eck29-ioBroker                           - disabled
            system.adapter.javascript.0             : javascript            : Eck29-ioBroker                           - disabled
            system.adapter.km200.0                  : km200                 : Eck29-ioBroker                           - disabled
            system.adapter.knx.0                    : knx                   : Eck29-ioBroker                           - disabled, bind: 192.168.1.166
            system.adapter.mydlink.0                : mydlink               : Eck29-ioBroker                           - disabled
            system.adapter.netatmo-crawler.0        : netatmo-crawler       : Eck29-ioBroker                           - disabled
            system.adapter.philips-tv.0             : philips-tv            : Eck29-ioBroker                           - disabled
            system.adapter.ping.0                   : ping                  : Eck29-ioBroker                           - disabled
            system.adapter.rpi2.0                   : rpi2                  : Eck29-ioBroker                           - disabled
            system.adapter.shelly.0                 : shelly                : Eck29-ioBroker                           - disabled, port: 1882, bind: 192.168.1.166
            system.adapter.solarmanpv.0             : solarmanpv            : Eck29-ioBroker                           - disabled
            system.adapter.telegram.0               : telegram              : Eck29-ioBroker                           - disabled, port: 8443, bind: 0.0.0.0
            system.adapter.telegram.1               : telegram              : Eck29-ioBroker                           - disabled, port: 8443, bind: 0.0.0.0
            system.adapter.yahka.0                  : yahka                 : Eck29-ioBroker                           - disabled
            system.adapter.yahka.3                  : yahka                 : Eck29-ioBroker                           - disabled
            system.adapter.yeelight-2.0             : yeelight-2            : Eck29-ioBroker                           - disabled
          + instance is alive
          ioBroker-Repositories
          latest        : http://iobroker.live/repo/sources-dist-latest.json
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
          Adapter    "backitup"     : 2.6.23   , installed 2.6.23
          Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
          Adapter    "deconz"       : 1.3.21   , installed 1.3.21
          Adapter    "easee"        : 1.0.7    , installed 1.0.7
          Adapter    "ems-esp"      : 1.30.0   , installed 1.30.0
          Adapter    "hmip"         : 1.20.0   , installed 1.20.0
          Adapter    "hs100"        : 2.1.2    , installed 2.1.2
          Adapter    "hue"          : 3.9.3    , installed 3.9.3
          Adapter    "javascript"   : 7.0.3    , installed 7.0.3
          Adapter    "km200"        : 2.0.3    , installed 2.0.3
          Adapter    "knx"          : 2.0.17   , installed 2.0.18
          Adapter    "mydlink"      : 1.3.1    , installed 1.3.1
          Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
          Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
          Adapter    "shelly"       : 6.4.1    , installed 6.4.1
          Adapter    "solarmanpv"   : 0.5.0    , installed 0.5.0
          Adapter    "telegram"     : 1.16.0   , installed 1.15.6 [Updatable]
          Adapter    "yahka"        : 0.17.0   , installed 1.0.3
          Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
          Objects and States
          Objects:        10841
          States:         8900
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
          Hit:6 https://packages.grafana.com/oss/deb stable InRelease
          Hit:7 https://repos.influxdata.com/debian stable InRelease
          Reading package lists...
          Pending Updates: 6
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13935      846/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15177      846/iobroker.js-con
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        12803      761/influxd
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13723      502/sshd: /usr/sbin
          tcp6       0      0 :::22                   :::*                    LISTEN      0          12656      502/sshd: /usr/sbin
          tcp6       0      0 :::8086                 :::*                    LISTEN      110        15141      761/influxd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12912      916/io.admin.0
          tcp6       0      0 :::3000                 :::*                    LISTEN      111        12051      845/grafana
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11872      757/dhcpcd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11774      366/avahi-daemon: r
          udp        0      0 0.0.0.0:60657           0.0.0.0:*                           108        11776      366/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        11775      366/avahi-daemon: r
          udp6       0      0 :::47582                :::*                                108        11777      366/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          16491      757/dhcpcd
          2023-07-31 02:18:43.539  - info: host.Eck29-ioBroker Delete log file iobroker.2023-07-23.log.gz
          2023-07-31 12:18:56.392  - info: admin.0 (916) Adapter rating updated
          2023-07-31 12:19:19.714  - info: admin.0 (916) Request actual repository...
          2023-07-31 12:19:20.485  - info: host.Eck29-ioBroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
          2023-07-31 12:19:24.886  - info: admin.0 (916) Repository received successfully.
          2023-07-31 19:33:22.295  - info: admin.0 (916) ==> Connected system.user.admin from ::ffff:192.168.1.152
          apt policy grafana
          grafana:
            Installed: 10.0.2
            Candidate: 10.0.3
            Version table:
               10.0.3 500
                  500 https://packages.grafana.com/oss/deb stable/main arm64 Packages
           *** 10.0.2 500
               10.0.1 500
               10.0.0 500
               9.5.7 500
               9.5.6 500
               9.5.5 500
               9.5.3 500
               9.5.2 500
               9.5.1 500
               9.5.0 500
               9.4.13 500
               9.4.12 500
               9.4.10 500
               9.4.9 500
               9.4.7 500
               9.4.3 500
               9.4.2 500
               9.4.1 500
               9.4.0 500
               9.3.16 500
               9.3.15 500
               9.3.14 500
               9.3.13 500
               9.3.11 500
               9.3.8 500
               9.3.6 500
               9.3.4 500
               9.3.2 500
               9.3.1 500
               9.3.0 500
               9.2.20 500
               9.2.19 500
               9.2.18 500
               9.2.17 500
               9.2.15 500
               9.2.13 500
               9.2.10 500
               9.2.8 500
               9.2.7 500
               9.2.6 500
               9.2.5 500
               9.2.4 500
               9.2.3 500
               9.2.2 500
               9.2.1 500
               9.2.0 500
               9.1.8 500
               9.1.7 500
               9.1.6 500
               9.1.5 500
               9.1.4 500
               9.1.3 500
               9.1.2 500
               9.1.1 500
               9.1.0 500
               9.0.9 500
               9.0.8 500
               9.0.7 500
               9.0.6 500
               9.0.5 500
               9.0.4 500
               9.0.3 500
               9.0.2 500
               9.0.1 500
               9.0.0 500
               8.5.27 500
               8.5.26 500
               8.5.25 500
               8.5.24 500
               8.5.22 500
               8.5.21 500
               8.5.20 500
               8.5.16 500
               8.5.15 500
               8.5.14 500
               8.5.13 500
               8.5.12 500
               8.5.10 500
               8.5.9 500
               8.5.6 500
               8.5.5 500
               8.5.4 500
               8.5.3 500
               8.5.2 500
               8.5.1 500
               8.5.0 500
               8.4.11 500
               8.4.10 500
               8.4.7 500
               8.4.6 500
               8.4.5 500
               8.4.4 500
               8.4.3 500
               8.4.2 500
               8.4.1 500
               8.4.0 500
               8.3.11 500
               8.3.10 500
               8.3.7 500
               8.3.6 500
               8.3.5 500
               8.3.4 500
               8.3.3 500
               8.3.2 500
               8.3.1 500
               8.3.0 500
               8.2.7 500
               8.2.6 500
               8.2.5 500
               8.2.4 500
               8.2.3 500
               8.2.2 500
               8.2.1 500
               8.2.0 500
               8.1.8 500
               8.1.7 500
               8.1.6 500
               8.1.5 500
               8.1.4 500
               8.1.3 500
               8.1.2 500
               8.1.1 500
               8.1.0 500
               8.0.7 500
               8.0.6 500
               8.0.5 500
               8.0.4 500
               8.0.3 500
               8.0.2 500
               8.0.1 500
               8.0.0 500
               7.5.16 500
               7.5.15 500
               7.5.13 500
               7.5.12 500
               7.5.11 500
               7.5.10 500
               7.5.9 500
               7.5.8 500
               7.5.7 500
               7.5.6 500
               7.5.5 500
               7.5.4 500
               7.5.3 500
               7.5.2 500
               7.5.1 500
               7.5.0 500
               7.4.5 500
               7.4.3 500
               7.4.2 500
               7.4.1 500
               7.4.0 500
               7.3.10 500
               7.3.7 500
               7.3.6 500
               7.3.5 500
               7.3.4 500
               7.3.3 500
               7.3.2 500
               7.3.1 500
               7.3.0 500
               7.2.2 500
               7.2.1 500
               7.2.0 500
               7.1.5 500
               7.1.4 500
               7.1.3 500
               7.1.2 500
               7.1.1 500
               7.1.0 500
               7.0.6 500
               7.0.5 500
               7.0.4 500
               7.0.3 500
               7.0.2 500
               7.0.1 500
               7.0.0 500
               6.7.6 500
               6.7.5 500
               6.7.4 500
               6.7.3 500
               6.7.2 500
               6.7.1 500
               6.7.0 500
               6.6.2 500
               6.6.1 500
               6.6.0 500
               6.5.3 500
               6.5.2 500
               6.5.1 500
               6.5.0 500
               6.4.5 500
               6.4.4 500
               6.4.3 500
               6.4.2 500
               6.4.1 500
               6.4.0 500
               6.3.7 500
               6.3.6 500
               6.3.5 500
               6.3.4 500
               6.3.3 500
               6.3.2 500
               6.3.1 500
               6.3.0 500
               6.2.5 500
               6.2.4 500
               6.2.3 500
               6.2.2 500
               6.2.1 500
               6.2.0 500
               6.1.6 500
               6.1.5 500
               6.1.4 500
               6.1.3 500
               6.1.2 500
               6.1.1 500
               6.1.0 500
               6.0.2 500
               6.0.1 500
               6.0.0 500
               5.4.5 500
               5.4.4 500
               5.4.3 500
               5.4.2 500
               5.4.1 500
               5.4.0 500
               5.3.4 500
               5.3.3 500
               5.3.2 500
               5.3.1 500
               5.3.0 500
               5.2.5 500
               5.2.4 500
               5.2.3 500
               5.2.2 500
               5.2.1 500
               5.2.0 500
               0.0.0~test 500
          influxdb2-cli:
            Installed: (none)
            Candidate: 2.7.3-1
            Version table:
               2.7.3-1 500
                  500 https://repos.influxdata.com/debian stable/main arm64 Packages
               2.7.1-2 500
               2.6.1 500
               2.6.0 500
               2.5.0 500
               2.4.0 500
               2.3.0 500
          influxdb-client:
            Installed: (none)
            Candidate: 1.6.7~rc0-1+b5
            Version table:
               1.6.7~rc0-1+b5 500
          influxdb-dev:
            Installed: (none)
            Candidate: (none)
            Version table:
          influxdb2-client:
            Installed: (none)
            Candidate: 2.7.1-1
            Version table:
               2.7.1-1 500
          influxdb:
            Installed: 1.8.10-1
            Candidate: 1.8.10-1
            Version table:
           *** 1.8.10-1 500
               1.6.7~rc0-1+b5 500
          influxdb2:
            Installed: (none)
            Candidate: 2.7.1-1
            Version table:
               2.7.1-1 500
               2.7.0-1 500
               2.6.1-1 500
               2.6.0-1 500
               2.5.1-1 500
               2.4.0-1 500
               2.3.0-1 500
               2.2.0 500
          • L loverz
            iob diag:
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Docker          : false
            Release:        11
            Codename:       bullseye
            VERSION_ID="11"
            ID=debian
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            temp=49.6'C
            volt=0.8563V
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     1849 M total memory
                      762 M used memory
                      897 M active memory
                      527 M free memory
                       57 M buffer memory
                      502 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            654M    /var/
            257M    /var/cache
            251M    /var/cache/apt
            171M    /var/lib
            /usr/bin/npm            9.5.1
            /usr/bin/npx            9.5.1
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.5
            javascript:     7.0.3
            Adapter State
            + instance is alive
            Objects and States
            Objects:        10841
            States:         8900
            Pending Updates: 6
            apt policy grafana
            grafana:
              Installed: 10.0.2
              Candidate: 10.0.3
              Version table:
                 10.0.3 500
             *** 10.0.2 500
                 10.0.1 500
                 10.0.0 500
                 9.5.7 500
                 9.5.6 500
                 9.5.5 500
                 9.5.3 500
                 9.5.2 500
                 9.5.1 500
                 9.5.0 500
                 9.4.13 500
                 9.4.12 500
                 9.4.10 500
                 9.4.9 500
                 9.4.7 500
                 9.4.3 500
                 9.4.2 500
                 9.4.1 500
                 9.4.0 500
                 9.3.16 500
                 9.3.15 500
                 9.3.14 500
                 9.3.13 500
                 9.3.11 500
                 9.3.8 500
                 9.3.6 500
                 9.3.4 500
                 9.3.2 500
                 9.3.1 500
                 9.3.0 500
                 9.2.20 500
                 9.2.19 500
                 9.2.18 500
                 9.2.17 500
                 9.2.15 500
                 9.2.13 500
                 9.2.10 500
                 9.2.8 500
                 9.2.7 500
                 9.2.6 500
                 9.2.5 500
                 9.2.4 500
                 9.2.3 500
                 9.2.2 500
                 9.2.1 500
                 9.2.0 500
                 9.1.8 500
                 9.1.7 500
                 9.1.6 500
                 9.1.5 500
                 9.1.4 500
                 9.1.3 500
                 9.1.2 500
                 9.1.1 500
                 9.1.0 500
                 9.0.9 500
                 9.0.8 500
                 9.0.7 500
                 9.0.6 500
                 9.0.5 500
                 9.0.4 500
                 9.0.3 500
                 9.0.2 500
                 9.0.1 500
                 9.0.0 500
                 8.5.27 500
                 8.5.26 500
                 8.5.25 500
                 8.5.24 500
                 8.5.22 500
                 8.5.21 500
                 8.5.20 500
                 8.5.16 500
                 8.5.15 500
                 8.5.14 500
                 8.5.13 500
                 8.5.12 500
                 8.5.10 500
                 8.5.9 500
                 8.5.6 500
                 8.5.5 500
                 8.5.4 500
                 8.5.3 500
                 8.5.2 500
                 8.5.1 500
                 8.5.0 500
                 8.4.11 500
                 8.4.10 500
                 8.4.7 500
                 8.4.6 500
                 8.4.5 500
                 8.4.4 500
                 8.4.3 500
                 8.4.2 500
                 8.4.1 500
                 8.4.0 500
                 8.3.11 500
                 8.3.10 500
                 8.3.7 500
                 8.3.6 500
                 8.3.5 500
                 8.3.4 500
                 8.3.3 500
                 8.3.2 500
                 8.3.1 500
                 8.3.0 500
                 8.2.7 500
                 8.2.6 500
                 8.2.5 500
                 8.2.4 500
                 8.2.3 500
                 8.2.2 500
                 8.2.1 500
                 8.2.0 500
                 8.1.8 500
                 8.1.7 500
                 8.1.6 500
                 8.1.5 500
                 8.1.4 500
                 8.1.3 500
                 8.1.2 500
                 8.1.1 500
                 8.1.0 500
                 8.0.7 500
                 8.0.6 500
                 8.0.5 500
                 8.0.4 500
                 8.0.3 500
                 8.0.2 500
                 8.0.1 500
                 8.0.0 500
                 7.5.16 500
                 7.5.15 500
                 7.5.13 500
                 7.5.12 500
                 7.5.11 500
                 7.5.10 500
                 7.5.9 500
                 7.5.8 500
                 7.5.7 500
                 7.5.6 500
                 7.5.5 500
                 7.5.4 500
                 7.5.3 500
                 7.5.2 500
                 7.5.1 500
                 7.5.0 500
                 7.4.5 500
                 7.4.3 500
                 7.4.2 500
                 7.4.1 500
                 7.4.0 500
                 7.3.10 500
                 7.3.7 500
                 7.3.6 500
                 7.3.5 500
                 7.3.4 500
                 7.3.3 500
                 7.3.2 500
                 7.3.1 500
                 7.3.0 500
                 7.2.2 500
                 7.2.1 500
                 7.2.0 500
                 7.1.5 500
                 7.1.4 500
                 7.1.3 500
                 7.1.2 500
                 7.1.1 500
                 7.1.0 500
                 7.0.6 500
                 7.0.5 500
                 7.0.4 500
                 7.0.3 500
                 7.0.2 500
                 7.0.1 500
                 7.0.0 500
                 6.7.6 500
                 6.7.5 500
                 6.7.4 500
                 6.7.3 500
                 6.7.2 500
                 6.7.1 500
                 6.7.0 500
                 6.6.2 500
                 6.6.1 500
                 6.6.0 500
                 6.5.3 500
                 6.5.2 500
                 6.5.1 500
                 6.5.0 500
                 6.4.5 500
                 6.4.4 500
                 6.4.3 500
                 6.4.2 500
                 6.4.1 500
                 6.4.0 500
                 6.3.7 500
                 6.3.6 500
                 6.3.5 500
                 6.3.4 500
                 6.3.3 500
                 6.3.2 500
                 6.3.1 500
                 6.3.0 500
                 6.2.5 500
                 6.2.4 500
                 6.2.3 500
                 6.2.2 500
                 6.2.1 500
                 6.2.0 500
                 6.1.6 500
                 6.1.5 500
                 6.1.4 500
                 6.1.3 500
                 6.1.2 500
                 6.1.1 500
                 6.1.0 500
                 6.0.2 500
                 6.0.1 500
                 6.0.0 500
                 5.4.5 500
                 5.4.4 500
                 5.4.3 500
                 5.4.2 500
                 5.4.1 500
                 5.4.0 500
                 5.3.4 500
                 5.3.3 500
                 5.3.2 500
                 5.3.1 500
                 5.3.0 500
                 5.2.5 500
                 5.2.4 500
                 5.2.3 500
                 5.2.2 500
                 5.2.1 500
                 5.2.0 500
                 0.0.0~test 500
            influxdb2-cli:
              Installed: (none)
              Candidate: 2.7.3-1
              Version table:
                 2.7.3-1 500
                 2.7.1-2 500
                 2.6.1 500
                 2.6.0 500
                 2.5.0 500
                 2.4.0 500
                 2.3.0 500
            influxdb-client:
              Installed: (none)
              Version table:
                 1.6.7~rc0-1+b5 500
            influxdb-dev:
              Installed: (none)
              Candidate: (none)
              Version table:
            influxdb2-client:
              Installed: (none)
              Candidate: 2.7.1-1
              Version table:
                 2.7.1-1 500
            influxdb:
              Installed: 1.8.10-1
              Candidate: 1.8.10-1
              Version table:
             *** 1.8.10-1 500
                 1.6.7~rc0-1+b5 500
            influxdb2:
              Installed: (none)
              Candidate: 2.7.1-1
              Version table:
                 2.7.1-1 500
                 2.7.0-1 500
                 2.6.1-1 500
                 2.6.0-1 500
                 2.5.1-1 500
                 2.4.0-1 500
                 2.3.0-1 500
                 2.2.0 500
            @loverz
            Soweit keine Schnitzer drin.
            Aktualisier die 6 Pakete des OS noch.
              @loverz
              loverz
              @thomas-braun die Frage ist, wieso meine inluxDB Werte nicht zurückkommen :(
              • L loverz
                @loverz
                Zumindest hängt es nicht grundsätzlich an der Installation.
                Das Backup spuckt welche Meldungen aus?
                  @loverz
                  loverz
                  Started restore ...
                  [DEBUG] [influxDB] - Created tmp directory
                  [DEBUG] [influxDB] - Start infuxDB Restore ...
                  [DEBUG] [influxDB] - influxdb.0 is stopped
                  [ERROR] [influxDB] - 2023/07/31 19:57:48 error updating meta: DB metadata not changed. database may already exist
                  restore: DB metadata not changed. database may already exist
                  [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
                  [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
                  [DEBUG] [influxDB] - infuxDB Restore completed successfully
                  [EXIT] influxDB restore done
                  [DEBUG] [influxDB] - influxdb.0 started
                  auffällig ist, dass backitup immer 2 Backups anlegt:
                  Thomas BraunT simatecS 2 Antworten Letzte Antwort
                  • L loverz
                    Started restore ...
                    @loverz
                    Muss sich jemand mit influx-Ahnung anschauen.
                    • L Offline
                      loverz
                      schrieb am zuletzt editiert von loverz
                      @simatec kanns du mir sagen, wieso das influxDB Restore nicht klappt?
                      Und wieso macht dein Adapter immer 2 Backups? Ein kleines und ein großes.
                      • Marc BergM Offline
                        Marc BergM Offline
                        Marc Berg
                        @loverz sagte in Backup and Restore auf neuem Raspberry:
                        In den Fehlermeldungen kann man sehen, warum der Restore nicht funktioniert. Da deine Datenpunkte schon fleißig Daten schreiben, gibt es die Datenbank schon. Der Restore funktioniert nur, wenn die DB noch nicht existiert. Also in der Instanz die Daten löschen und danach, bevor wieder neue Daten geschrieben werden, erneut den Restore starten. Am besten nach dem Löschen die Instanz beenden, damit die DB nicht sofort wieder angelegt wird.
                        Warum du zwei Backups hast, weiß ich nicht. Habe ich so noch nicht gesehen.
                        • L loverz
                          simatecS Offline
                          simatecS Offline
                          simatec
                          Was soll ich mit dieser Frage anfangen? Bitte einen Debuglog posten...
                          Auch mit dieser Frage kann ich nichts anfangen...
                          Bitte die Ausgabe von folgenden Befehlen zusätzlich posten
                          ls -lah /opt/iobroker/backups
                          iob diag
                          • Besuche meine Github Seite
                          • HowTo Restore ioBroker
                          • L loverz
                            Started restore ...
                            simatecS Offline
                            simatecS Offline
                            simatec
                            @loverz Zeige bitte die Config von Backitup
                            • Marc BergM Marc Berg
                              loverz
                              @marc-berg danke für die Info.
                              Wie kann ich die Datenbank löschen bzw. die Daten in der Instanz?
                              • L loverz
                                Marc BergM Offline
                                Marc BergM Offline
                                Marc Berg
                                • simatecS simatec
                                  loverz
                                  Ich sehe da unten ist ein Haken "alte influxDB vor dem Restore löschen" hab den am neuen System an, am alten aus.
                                  Muss ich den beim alten an machen und das Backup mit diesem Haken erstellen?
                                    loverz
                                    @marc-berg jetzt geht es...
                                    Hatte die Instanz direkt nach dem Löschen aus gelassen.
                                    Started restore ...
                                    @simatec dann funktioniert aber doch der oben genannte Haken nicht oder?
                                    Außerdem weiß ich noch nicht, wieso 2 Backups angelegt werden. Bei Grafana übrigens auch.
                                    • L Offline
                                      loverz
                                      der Grafana Restore sieht so aus:
                                      Started restore ...
                                      [DEBUG] [grafana] - Start Grafana Restore ...
                                      [DEBUG] [grafana] - filename for restore: /opt/iobroker/backups/grafana_2023_07_31-03_31_57_Eck29_backupiobroker.tar.gz
                                      [DEBUG] [grafana] - Grafana tmp directory created: /opt/iobroker/backups/grafana_tmp
                                      [DEBUG] [grafana] - start decompress
                                      [DEBUG] [grafana] - Grafana request started
                                      [DEBUG] [grafana] - Grafana is available ... Status: 200
                                      [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB.json
                                      [DEBUG] [grafana] - cannot restore datasource "InfluxDB": "data source with the same name already exists"
                                      [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/energieverbrauch.json
                                      [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/general-alerting.json
                                      [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/heizungsanlage.json
                                      [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/wetterdaten.json
                                      [DEBUG] [grafana] - dashboard restore for "general-alerting" finish: {"id":2,"slug":"general-alerting","status":"success","uid":"XflZZbZRz","url":"/d/XflZZbZRz/general-alerting","version":4}
                                      [DEBUG] [grafana] - dashboard restore for "wetterdaten" finish: {"id":1,"slug":"wetterdaten","status":"success","uid":"MyXZDlggk","url":"/d/MyXZDlggk/wetterdaten","version":4}
                                      [DEBUG] [grafana] - dashboard restore for "energieverbrauch" finish: {"id":4,"slug":"energieverbrauch","status":"success","uid":"QJpROlgRk","url":"/d/QJpROlgRk/energieverbrauch","version":4}
                                      [DEBUG] [grafana] - dashboard restore for "heizungsanlage" finish: {"id":3,"slug":"heizungsanlage","status":"success","uid":"BJK6AugRk","url":"/d/BJK6AugRk/heizungsanlage","version":4}
                                      [DEBUG] [grafana] - Grafana request ended
                                      [DEBUG] [grafana] - Try deleting the Grafana tmp directory
                                      [DEBUG] [grafana] - Grafana tmp directory was successfully deleted
                                      [DEBUG] [grafana] - Grafana Restore completed successfully
                                      [EXIT] Grafana restore done
                                      Leider sind aber meine Dashboards hinterher nicht da...
                                      @Marc-Berg hast du hier auch eine Idee?
                                      • L loverz
                                        Started restore ...
                                        Marc BergM Offline
                                        Marc BergM Offline
                                        Marc Berg
                                        Hast du "General" mal aufgeklappt?
                                          loverz
                                          @marc-berg .... das wars. Ich schäme mich gerade xD
                                          hatte aber auch deshalb nicht daran geglaubt, da sie nicht wie gewohnt auf der Startseite waren. Muss sie dort wohl noch manuell als favorit hinzufügen...
