  4. Radar2 startet nicht
    5.3k
15 Beiträge 4 Kommentatoren 1.3k Aufrufe 4 Beobachtet
  • L Offline
    LarryXXL
    schrieb am zuletzt editiert von LarryXXL
    ======== Start marking the full check here =========
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : kvm
    Distributor ID: Ubuntu
    Description:    Ubuntu 22.04.2 LTS
    Release:        22.04
    Codename:       jammy
    PRETTY_NAME="Ubuntu 22.04.2 LTS"
    NAME="Ubuntu"
    VERSION_ID="22.04"
    VERSION="22.04.2 LTS (Jammy Jellyfish)"
    VERSION_CODENAME=jammy
    ID=ubuntu
    ID_LIKE=debian
    HOME_URL="https://www.ubuntu.com/"
    SUPPORT_URL="https://help.ubuntu.com/"
    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
    UBUNTU_CODENAME=jammy
    Systemuptime and Load:
     13:13:28 up 12 min,  4 users,  load average: 0.01, 0.08, 0.08
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Mon 2023-07-17 13:13:28 UTC
               Universal time: Mon 2023-07-17 13:13:28 UTC
                     RTC time: Mon 2023-07-17 13:13:28
                    Time zone: Etc/UTC (UTC, +0000)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            5.9G        1.5G        3.7G        0.0K        726M        4.2G
    Swap:             0B          0B          0B
    Total:          5.9G        1.5G        3.7G
             5921 M total memory
             1459 M used memory
              188 M active memory
             1710 M inactive memory
             3735 M free memory
               66 M buffer memory
              659 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    *** FILESYSTEM ***
    Filesystem                        Type   Size  Used Avail Use% Mounted on
    tmpfs                             tmpfs  593M  804K  592M   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv ext4    11G  4.1G  6.2G  40% /
    tmpfs                             tmpfs  2.9G     0  2.9G   0% /dev/shm
    tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
    /dev/sda2                         ext4   2.0G  130M  1.7G   8% /boot
    tmpfs                             tmpfs  593M  4.0K  593M   1% /run/user/0
    tmpfs                             tmpfs  593M  4.0K  593M   1% /run/user/1000
    [Mon Jul 17 13:01:10 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Mon Jul 17 13:01:10 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
    [Mon Jul 17 13:01:11 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    Show mounted filesystems (real ones only):
    TARGET  SOURCE                            FSTYPE OPTIONS
    /       /dev/mapper/ubuntu--vg-ubuntu--lv ext4   rw,relatime
    `-/boot /dev/sda2                         ext4   rw,relatime
    /var:
    436M    /var/
    239M    /var/cache
    231M    /var/cache/apt
    164M    /var/lib
    146M    /var/cache/apt/archives
    Archived and active journals take up 32.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    124M    /opt/iobroker/iobroker-data/
    90M     /opt/iobroker/iobroker-data/files
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    33M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    14M     /opt/iobroker/iobroker-data/objects.jsonl
    7.2M    /opt/iobroker/iobroker-data/files/ham.admin/static/js/main.8080bc0b.js.map
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/910.e1389bdb.chunk.js.map
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    5.3M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/472.d73f9bde.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.1
    /usr/bin/node           v18.16.1
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.1-deb-1nodesource1
      Candidate: 18.16.1-deb-1nodesource1
      Version table:
     *** 18.16.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
            100 /var/lib/dpkg/status
         12.22.9~dfsg-1ubuntu3 500
            500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    MULTIHOSTSERVICE/enabled: false
    Core adapters versions
    js-controller:  5.0.8
    admin:          6.6.0
    javascript:     7.1.1
    Adapters from github:   4
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : iob-server                               -  enabled
    + system.adapter.admin.0                  : admin                 : iob-server                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iob-server                               -  enabled
    + system.adapter.backitup.0               : backitup              : iob-server                               -  enabled
    + system.adapter.ble.0                    : ble                   : iob-server                               -  enabled
    + system.adapter.discovery.0              : discovery             : iob-server                               -  enabled
    + system.adapter.ham.0                    : ham                   : iob-server                               -  enabled
    + system.adapter.history.0                : history               : iob-server                               -  enabled
    + system.adapter.hue-extended.0           : hue-extended          : iob-server                               -  enabled
    + system.adapter.javascript.0             : javascript            : iob-server                               -  enabled
    + system.adapter.mihome.0                 : mihome                : iob-server                               -  enabled, port: 9898, bind: 0.0.0.0
    + system.adapter.nina.0                   : nina                  : iob-server                               -  enabled
      system.adapter.radar2.0                 : radar2                : iob-server                               -  enabled
    + system.adapter.tapo.0                   : tapo                  : iob-server                               -  enabled
    + system.adapter.tuya.0                   : tuya                  : iob-server                               -  enabled
    + system.adapter.yeelight-2.0             : yeelight-2            : iob-server                               -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iob-server                               -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
    Adapter    "admin"        : 6.6.0    , installed 6.6.0
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "ble"          : 0.13.4   , installed 0.13.4
    Adapter    "discovery"    : 3.2.0    , installed 3.2.0
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.1
    Adapter    "javascript"   : 7.1.1    , installed 7.1.1
    Controller "js-controller": 5.0.8    , installed 5.0.8
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "radar2"       : 2.0.7    , installed 2.0.7
    Adapter    "tapo"         : 0.0.8    , installed 0.0.8
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
    Adapter    "zigbee"       : 1.8.18   , installed 1.8.18
    Objects and States
    Objects:        6251
    States:         5556
    Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 https://deb.nodesource.com/node_18.x jammy InRelease
    Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
    Get:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease [108 kB]
    Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
    Fetched 108 kB in 1s (207 kB/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        20274      605/systemd-resolve
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17316      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20371      649/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:50157           0.0.0.0:*               LISTEN      109        29379      2071/rpc.statd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       28842      1835/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       26985      1835/iobroker.js-co
    tcp6       0      0 :::111                  :::*                    LISTEN      0          17318      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          20373      649/sshd: /usr/sbin
    tcp6       0      0 :::45869                :::*                    LISTEN      109        29383      2071/rpc.statd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       28883      1853/io.admin.0
    tcp6       0      0 :::36461                :::*                    LISTEN      1001       28101      1939/io.ham.0
    udp        0      0 127.0.0.1:975           0.0.0.0:*                           0          29373      2071/rpc.statd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       29830      1939/io.ham.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       28102      1939/io.ham.0
    udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       27145      1966/io.mihome.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       28143      1994/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       28144      1994/io.tuya.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        20273      605/systemd-resolve
    udp        0      0 192.168.1.166:68        0.0.0.0:*                           101        20254      603/systemd-network
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17317      1/init
    udp        0      0 0.0.0.0:45259           0.0.0.0:*                           109        29377      2071/rpc.statd
    udp6       0      0 :::52179                :::*                                109        29381      2071/rpc.statd
    udp6       0      0 :::111                  :::*                                0          17319      1/init
    udp6       0      0 fe80::4401:1ff:fe01:546 :::*                                101        20701      603/systemd-network
    2023-07-17 13:07:25.755  - info: radar2.0 (2504) Will try to scan BT devices: hci0      78:8A:86:1F:0B:8B
    2023-07-17 13:07:25.768  - warn: radar2.0 (2504) Uncaught Exception: spawn ping ENOENT
    2023-07-17 13:07:25.769  - error: radar2.0 (2504) uncaught exception: spawn ping ENOENT
    2023-07-17 13:07:25.769  - error: radar2.0 (2504) Error: spawn ping ENOENT
        at ChildProcess._handle.onexit (node:internal/child_process:283:19)
        at onErrorNT (node:internal/child_process:476:16)
        at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
    2023-07-17 13:07:25.769  - error: radar2.0 (2504) Exception-Code: ENOENT: spawn ping ENOENT
    2023-07-17 13:07:25.774  - info: radar2.0 (2504) Unload adapter now with null
    2023-07-17 13:07:25.774  - info: radar2.0 (2504) Adapter disconnected and stopped with dostop(null) and callback(true)
    2023-07-17 13:07:25.774  - info: radar2.0 (2504) terminating
    2023-07-17 13:07:25.775  - warn: radar2.0 (2504) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-07-17 13:07:25.775  - info: radar2.0 (2504) terminating
    2023-07-17 13:07:25.821  - info: radar2.0 (2504) debug: created State radar2.0.info.connection
    2023-07-17 13:07:26.273  - info: radar2.0 (2504) terminating
    2023-07-17 13:07:26.303  - error: host.iob-server instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-07-17 13:07:26.304  - info: host.iob-server Restart adapter system.adapter.radar2.0 because enabled
    2023-07-17 13:07:26.304  - warn: host.iob-server Do not restart adapter system.adapter.radar2.0 because restart loop detected
    2023-07-17 13:10:00.022  - warn: javascript.0 (1895) getState "radar2.0.Homework._here" not found (3)
    2023-07-17 13:10:00.023  - warn: javascript.0 (1895)     at Object.<anonymous> (script.js.common.Wohnung.Wohnzimmer_Licht_Automatic:5:63)
    2023-07-17 13:10:00.023  - warn: javascript.0 (1895)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1255:38)
    2023-07-17 13:10:00.023  - warn: javascript.0 (1895)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2023-07-17 13:10:00.023  - warn: javascript.0 (1895)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11082:62)
    2023-07-17 13:10:00.023  - warn: javascript.0 (1895)     at processImmediate (node:internal/timers:476:21)
    iob diag has finished.
    L 1 Antwort Letzte Antwort
    • L LarryXXL
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        22.04
      Codename:       jammy
      NAME="Ubuntu"
      VERSION_ID="22.04"
      ID=ubuntu
      ID_LIKE=debian
      CPU threads: 8
                    NTP service: active
                RTC in local TZ: no
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:             0B          0B          0B
               5921 M total memory
               1459 M used memory
                188 M active memory
               3735 M free memory
                 66 M buffer memory
                659 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /var:
      436M    /var/
      239M    /var/cache
      231M    /var/cache/apt
      164M    /var/lib
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.6.0
      javascript:     7.1.1
      Adapter State
      + instance is alive
      Objects and States
      Objects:        6251
      States:         5556
      Pending Updates: 0
      LarryXXL
      @larryxxl
      Radar 2 startet nicht.
      log
      host.iob-server
      2023-07-17 15:06:54.411	info	Restart adapter system.adapter.radar2.0 because enabled
      host.iob-server
      2023-07-17 15:06:54.411	error	instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      radar2.0
      2023-07-17 15:06:54.382	info	terminating
      radar2.0
      2023-07-17 15:06:53.933	info	debug: created State radar2.0.info.connection
      radar2.0
      2023-07-17 15:06:53.884	info	terminating
      radar2.0
      radar2.0
      2023-07-17 15:06:53.884	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      radar2.0
      2023-07-17 15:06:53.883	info	terminating
      radar2.0
      2023-07-17 15:06:53.883	info	Adapter disconnected and stopped with dostop(null) and callback(true)
      radar2.0
      2023-07-17 15:06:53.883	info	Unload adapter now with null
      radar2.0
      2023-07-17 15:06:53.878	error	Exception-Code: ENOENT: spawn ping ENOENT
      radar2.0
      2023-07-17 15:06:53.878	error	Error: spawn ping ENOENT at ChildProcess._handle.onexit (node:internal/child_process:283:19) at onErrorNT (node:internal/child_process:476:16) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
      radar2.0
      2023-07-17 15:06:53.878	error	uncaught exception: spawn ping ENOENT
      radar2.0
      2023-07-17 15:06:53.877	warn	Uncaught Exception: spawn ping ENOENT
      radar2.0
      2023-07-17 15:06:53.862	info	Will try to scan BT devices: hci0 78:8A:86:1F:0B:8B
      radar2.0
      2023-07-17 15:06:53.851	info	debug: Will 'not save' unknown BT devices and will 'save' unknown IP devices!
      radar2.0
      2023-07-17 15:06:53.850	info	debug: radar2 set to scan every 30 seconds and printers every 720 minutes.
      radar2.0
      2023-07-17 15:06:53.776	info	Connected with '0.0.0.0' for DHCP Scan
      radar2.0
      2023-07-17 15:06:53.769	info	arp-scan will use the following interfaces: [ 'ens18' ]
      radar2.0
      2023-07-17 15:06:53.769	info	debug: use known IP list: [ '192.168.178.10', '192.168.178.10' ]
      radar2.0
      2023-07-17 15:06:53.768	info	debug: use known BT list: [ '01:12:23:34:45:56' ]
      radar2.0
      2023-07-17 15:06:53.767	info	debug: radar2 set to flag items away if they are not seen for 3 minutes
      radar2.0
      2023-07-17 15:06:53.567	info	debug: started #3 hciconfig hci0 up
      radar2.0
      2023-07-17 15:06:53.448	info	debug: started #2 hciconfig hci0 down
      radar2.0
      2023-07-17 15:06:53.443	info	Will run hcitool-mode and not noble on device [ [Object] ]!
      radar2.0
      2023-07-17 15:06:53.425	info	debug: started #1 hcitool dev
      radar2.0
      2023-07-17 15:06:53.411	info	Will use l2Ping for BT scans.
      radar2.0
      2023-07-17 15:06:53.405	info	radar2 initialization started...
      radar2.0
      2023-07-17 15:06:53.404	info	debug: radar2 received 2 objects and 1 states, with config devices,scandelay,arp_scan_cmd,btadapterid,printerdelay,debug,knownIPs,knownBTs,external,delayaway,delayuwz,numuwz,hcionly,l2ponly,longuwz,suBT,suIP,lang,latitude,longitude,adapterConf,loglevel
      radar2.0
      2023-07-17 15:06:53.364	info	starting. Version 2.0.7 (non-npm: frankjoke/ioBroker.radar2) in /opt/iobroker/node_modules/iobroker.radar2, node: v18.16.1, js-controller: 5.0.8
      host.iob-server
      2023-07-17 15:06:52.579	info	instance system.adapter.radar2.0 started with pid 2469
      host.iob-server
      2023-07-17 13:06:22.554	info	Restart adapter system.adapter.radar2.0 because enabled
      host.iob-server
      2023-07-17 13:06:22.554	error	instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      radar2.0
      2023-07-17 13:06:22.523	info	terminating
      radar2.0
      2023-07-17 13:06:22.069	info	debug: created State radar2.0.info.connection
      radar2.0
      2023-07-17 13:06:22.024	info	terminating
      radar2.0
      2023-07-17 13:06:22.023	info	terminating
      radar2.0
      2023-07-17 13:06:22.023	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      radar2.0
      radar2.0
      2023-07-17 13:06:22.023	info	Adapter disconnected and stopped with dostop(null) and callback(true)
      radar2.0
      2023-07-17 13:06:22.022	info	Unload adapter now with null
      radar2.0
      2023-07-17 13:06:22.018	error	Exception-Code: ENOENT: spawn ping ENOENT
      radar2.0
      2023-07-17 13:06:22.018	error	Error: spawn ping ENOENT at ChildProcess._handle.onexit (node:internal/child_process:283:19) at onErrorNT (node:internal/child_process:476:16) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
      radar2.0
      2023-07-17 13:06:22.017	error	uncaught exception: spawn ping ENOENT
      radar2.0
      2023-07-17 13:06:22.017	warn	Uncaught Exception: spawn ping ENOENT
      radar2.0
      2023-07-17 13:06:22.002	info	Will try to scan BT devices: hci0 78:8A:86:1F:0B:8B
      radar2.0
      2023-07-17 13:06:21.991	info	debug: Will 'not save' unknown BT devices and will 'save' unknown IP devices!
      radar2.0
      2023-07-17 13:06:21.990	info	debug: radar2 set to scan every 30 seconds and printers every 720 minutes.
      radar2.0
      2023-07-17 13:06:21.918	info	Connected with '0.0.0.0' for DHCP Scan
      radar2.0
      2023-07-17 13:06:21.912	info	arp-scan will use the following interfaces: [ 'ens18' ]
      radar2.0
      2023-07-17 13:06:21.911	info	debug: use known IP list: [ '192.168.178.10', '192.168.178.10' ]
      radar2.0
      2023-07-17 13:06:21.911	info	debug: use known BT list: [ '01:12:23:34:45:56' ]
      radar2.0
      2023-07-17 13:06:21.910	info	debug: radar2 set to flag items away if they are not seen for 3 minutes
      radar2.0
      2023-07-17 13:06:21.723	info	debug: started #3 hciconfig hci0 up
      radar2.0
      2023-07-17 13:06:21.604	info	debug: started #2 hciconfig hci0 down
      radar2.0
      2023-07-17 13:06:21.600	info	Will run hcitool-mode and not noble on device [ [Object] ]!
      radar2.0
      2023-07-17 13:06:21.580	info	debug: started #1 hcitool dev
      radar2.0
      2023-07-17 13:06:21.566	info	Will use l2Ping for BT scans.
      radar2.0
      2023-07-17 13:06:21.560	info	radar2 initialization started...
      radar2.0
      2023-07-17 13:06:21.559	info	debug: radar2 received 2 objects and 1 states, with config devices,scandelay,arp_scan_cmd,btadapterid,printerdelay,debug,knownIPs,knownBTs,external,delayaway,delayuwz,numuwz,hcionly,l2ponly,longuwz,suBT,suIP,lang,latitude,longitude,adapterConf,loglevel
      radar2.0
      2023-07-17 13:06:21.512	info	starting. Version 2.0.7 (non-npm: frankjoke/ioBroker.radar2) in /opt/iobroker/node_modules/iobroker.radar2, node: v18.16.1, js-controller: 5.0.8
      radar2.0
      2023-07-17 13:06:21.426	debug	States connected to redis: 127.0.0.1:9000
      radar2.0
      2023-07-17 13:06:21.373	debug	States create User PubSub Client
      radar2.0
      2023-07-17 13:06:21.373	debug	States create System PubSub Client
      radar2.0
      2023-07-17 13:06:21.366	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      radar2.0
      2023-07-17 13:06:21.351	debug	Objects connected to redis: 127.0.0.1:9001
      radar2.0
      2023-07-17 13:06:21.347	debug	Objects client initialize lua scripts
      radar2.0
      2023-07-17 13:06:21.329	debug	Objects create User PubSub Client
      radar2.0
      2023-07-17 13:06:21.328	debug	Objects create System PubSub Client
      radar2.0
      2023-07-17 13:06:21.327	debug	Objects client ready ... initialize now
      radar2.0
      2023-07-17 13:06:21.309	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      host.iob-server
      2023-07-17 13:06:20.735	info	instance system.adapter.radar2.0 started with pid 2434
      die adapter Hilfe habe ich schon ausprobiert.
      Fehler verschwindet einfach nicht
      grrfieldG 1 Antwort Letzte Antwort
      • L LarryXXL
        @larryxxl
        log
        host.iob-server
        host.iob-server
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        host.iob-server
        host.iob-server
        host.iob-server
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        radar2.0
        host.iob-server
        grrfieldG Offline
        grrfieldG Offline
        grrfield
        @larryxxl Hast Du die Befehle unter https://github.com/iobroker-community-adapters/ioBroker.radar2#installation ausgeführt?
        • grrfieldG grrfield
          LarryXXL
          @grrfield
          ja habe die Befehle schon ausgeführt. Denke das in IOBroker alles ok ist. Aber etwas unter Ubuntu fehlt oder falsch installiert ist.
          Es laufen alle anderen Adapter bis auf den Radar2.
          Auch Bluetooth ist ok unter Proxmox und einer VM. Habe hierfür allerdings verschiedene M2 Wifi adapter ausprobieren müssen. Intel war ein Problem AX201,210. Realtek funktioniert aber.
          • L LarryXXL
            @grrfield
            @larryxxl
            Zeitzone ist nicht richtig gesetzt, du hampelst als root herum.
              @larryxxl
              LarryXXL
              Kann es sein das man als User "Pi" mit Sudo mehr rumhampelt als als "root" ?
              Und wenn eine falsche Zeitzone dem Radar2 Adapter beim Starten permanent abstürzen lässt sollte ich vielleicht doch noch Lotto spielen.😇
              • L LarryXXL
                @larryxxl sagte in Radar2 startet nicht:
                Nein.
                • L LarryXXL
                  Ist halt ein Indikator dafür daß das System nicht senkrecht eingerichtet ist. Vor allem in Kombination mit dem root.
                    LarryXXL
                    wo stelle ich die Zeitzone in IOBroker ein ?
                    • L LarryXXL
                      @larryxxl
                      Die Zeitzone in deinem OS ist falsch.
                        @larryxxl
                        LarryXXL
                        To restore this content, you can run the 'unminimize' command.
                        Last login: Mon Jul 17 14:26:06 2023 from 192.168.1.150
                        root@iob-server:~# su pi
                        pi@iob-server:/root$ sudo timedatectl set-timezone Europe/Berlin
                        [sudo] password for pi:
                                       Local time: Tue 2023-07-18 20:36:07 CEST
                                   Universal time: Tue 2023-07-18 18:36:07 UTC
                                         RTC time: Tue 2023-07-18 18:36:07
                                      NTP service: active
                                  RTC in local TZ: no
                        Das nächste Prolem war das wenn ich das aktuellen Beta Admin.adapter installiere iobroker gar nicht mehr startet. 6.6.0->6.6.1.
                        danach war ein Rollback nötig.
                        • L LarryXXL
                                        NTP service: active
                                    RTC in local TZ: no
                          Was soll ich sagen...
                          Hat es auf meinem System natürlich getan.
                            LarryXXL
                            Ubuntu neu installiert. kein root. iobroker neu installiert. Adapter neu installiert und eingerichtet. Zigbee Backup eingespielt.
                            alles gebrauchten Adapter sind nun grün und laufen.
                            Blockly Scripte mussten teilweise korrigiert werden weil jetzt die empfohlende node Version benutzt wird.
                            Alles soweit ok.
                            • L LarryXXL
                              Alles soweit ok.
                              @larryxxl
                              Also 'kaum macht man es ordentlich/richtig, schon funktioniert es?'
                              • L LarryXXL
                                Alles soweit ok.
                                crunchipC Offline
                                crunchipC Offline
                                Verstehe ich aber nicht ganz den Zusammenhang
