  4. Zigbee Adapter Fehlermeldungen
    5.3k
17 Beiträge 5 Kommentatoren 2.2k Aufrufe 5 Beobachtet
    shellyrulestheworld
    Kann mir jemand einen Hinweis geben?
    Debian 11 unter Proxmox im LXC Container. Der "Fehler" taucht regelmäßig im Log aus, alle 10 min ungefähr
    host.iobroker
    2023-06-28 18:26:15.096	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.iobroker
    2023-06-28 18:26:15.096	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:699:22
    host.iobroker
    2023-06-28 18:26:15.096	error	Caught by controller[0]: at Zigbee.filterError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:142:18)
    host.iobroker
    2023-06-28 18:26:15.096	error	Caught by controller[0]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
    host.iobroker
    2023-06-28 18:26:15.096	error	Caught by controller[0]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
    host.iobroker
    2023-06-28 18:26:15.096	error	Caught by controller[0]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
    host.iobroker
    2023-06-28 18:26:15.096	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
    host.iobroker
    2023-06-28 18:26:15.096	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'Error')
    host.iobroker
    2023-06-28 18:26:15.095	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    zigbee.0
    2023-06-28 18:26:14.541	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    2023-06-28 18:26:14.540	info	terminating
    zigbee.0
    2023-06-28 18:26:14.430	info	Zigbee: disabling joining new devices.
    zigbee.0
    2023-06-28 18:26:14.388	info	cleaned everything up...
    zigbee.0
    2023-06-28 18:26:14.375	error	Cannot read properties of undefined (reading 'Error')
    zigbee.0
    2023-06-28 18:26:14.375	error	TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.filterError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:142:18) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:699:22
    zigbee.0
    2023-06-28 18:26:14.350	error	unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
    zigbee.0
    2023-06-28 18:26:14.350	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    2023-06-28 18:26:14.349	error	Send command to 0x9035eafffee1c47c failed with no error code (no response received)
    • S shellyrulestheworld
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      @shellyrulestheworld
      Beta-testest du js-controller5?
      Dann dürfte dir nicht entgangen sein, dass es ein bekannter Fehler ist.
      Schalt Sentry für den Adapter mal temporär aus.
        shellyrulestheworld
        @thomas-braun vielen Dank für deine Antwort. Ich habe vor ein paar Tagen den iob neu aufgesetzt und die Backups eingespielt. Ich habe den jscontroller nicht auf Beta umgestellt. Wie kann ich die Version prüfen?
          Steht neben anderen interessanten Dingen in
          iob diag
          drin.
            iob diag
            drin.
            shellyrulestheworld
            @thomas-braun Danke.
            ======== Start marking the full check here =========
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Architecture    : x86_64
            Docker          : false
            Virtualization  : lxc
            Distributor ID: Debian
            Description:    Debian GNU/Linux 11 (bullseye)
            Release:        11
            Codename:       bullseye
            PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
            NAME="Debian GNU/Linux"
            VERSION_ID="11"
            VERSION="11 (bullseye)"
            VERSION_CODENAME=bullseye
            ID=debian
            HOME_URL="https://www.debian.org/"
            SUPPORT_URL="https://www.debian.org/support"
            BUG_REPORT_URL="https://bugs.debian.org/"
            Systemuptime and Load:
             20:20:13 up  2:01,  1 user,  load average: 1.06, 0.89, 0.91
            CPU threads: 4
            *** Time and Time Zones ***
                           Local time: Wed 2023-06-28 20:20:13 CEST
                       Universal time: Wed 2023-06-28 18:20:13 UTC
                             RTC time: n/a
                          NTP service: inactive
                      RTC in local TZ: no
            *** User and Groups ***
            root
            /root
            root
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:
            *** MEMORY ***
            Mem:            4.1G        2.3G        1.4G        0.0K        325M        1.7G
            Swap:           512M          0B        512M
            Total:          4.6G        2.3G        1.9G
                     4096 M total memory
                     2347 M used memory
                      141 M active memory
                     2387 M inactive memory
                     1423 M free memory
                        0 M buffer memory
                      325 M swap cache
                      512 M total swap
                        0 M used swap
                      512 M free swap
            *** FILESYSTEM ***
            Filesystem                       Type      Size  Used Avail Use% Mounted on
            /dev/mapper/pve-vm--203--disk--0 ext4      7.8G  3.6G  3.9G  49% /
            none                             tmpfs     492K  4.0K  488K   1% /dev
            /dev/mapper/pve-root             ext4       94G  9.3G   80G  11% /dev/ttyACM0
            udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
            tmpfs                            tmpfs     7.7G     0  7.7G   0% /dev/shm
            tmpfs                            tmpfs     3.1G  104K  3.1G   1% /run
            tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
            dmesg: read kernel buffer failed: Operation not permitted
            Show mounted filesystems (real ones only):
            TARGET         SOURCE                                                 FSTYPE OPTIONS
            /              /dev/mapper/pve-vm--203--disk--0                       ext4   rw,relatime,stripe=16
            `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/203/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
            /var:
            392M    /var/
            229M    /var/cache
            223M    /var/cache/apt
            155M    /var/cache/apt/archives
            144M    /var/lib
            Archived and active journals take up 16.0M in the file system.
            /opt/iobroker/backups:
            129M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            418M    /opt/iobroker/iobroker-data/
            290M    /opt/iobroker/iobroker-data/files
            85M     /opt/iobroker/iobroker-data/backup-objects
            52M     /opt/iobroker/iobroker-data/files/javascript.admin
            48M     /opt/iobroker/iobroker-data/files/telegram.admin
            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
            21M     /opt/iobroker/iobroker-data/states.jsonl
            21M     /opt/iobroker/iobroker-data/objects.jsonl
            19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
            18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.16.1
            /usr/bin/node           v18.16.1
            /usr/bin/npm            9.5.1
            /usr/bin/npx            9.5.1
            nodejs:
              Installed: 18.16.1-deb-1nodesource1
              Candidate: 18.16.1-deb-1nodesource1
              Version table:
             *** 18.16.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                    100 /var/lib/dpkg/status
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://security.debian.org bullseye-security/main amd64 Packages
                 12.22.12~dfsg-1~deb11u3 500
                    500 http://ftp.debian.org/debian bullseye/main amd64 Packages
            No problems detected
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            MULTIHOSTSERVICE/enabled: false
            Core adapters versions
            js-controller:  4.0.24
            admin:          6.3.5
            javascript:     7.0.3
            Adapters from github:   1
            Adapter State
            + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
              system.adapter.alarm.0                  : alarm                 : iobroker                                 - disabled
            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
              system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
              system.adapter.devices.0                : devices               : iobroker                                 - disabled
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            + system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
              system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
            + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
            + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
            + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
            + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
              system.adapter.history.0                : history               : iobroker                                 - disabled
            + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
            + system.adapter.hs100.0                  : hs100                 : iobroker                                 -  enabled
              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
              system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
            + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
            + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
            + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
              system.adapter.philips-air.0            : philips-air           : iobroker                                 - disabled
            + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
            + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
            + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              system.adapter.smartthings.0            : smartthings           : iobroker                                 - disabled
            + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
            + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
            + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
            + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
            + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
              system.adapter.uv-protect.0             : uv-protect            : iobroker                                 -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.3.5    , installed 6.3.5
            Adapter    "alarm"        : 3.3.11   , installed 3.3.11
            Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
            Adapter    "backitup"     : 2.6.23   , installed 2.6.23
            Adapter    "cloud"        : 4.4.1    , installed 4.4.1
            Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
            Adapter    "devices"      : 1.1.5    , installed 1.1.5
            Adapter    "discovery"    : 3.1.0    , installed 3.1.0
            Adapter    "dwd"          : 2.8.3    , installed 2.8.3
            Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
            Adapter    "fritzdect"    : 2.3.1    , installed 2.2.6  [Updatable]
            Adapter    "fronius"      : 1.1.3    , installed 1.1.3
            Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
            Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
            Adapter    "history"      : 2.2.4    , installed 2.2.4
            Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
            Adapter    "hs100"        : 2.1.2    , installed 2.1.2
            Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
            Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
            Adapter    "info"         : 1.9.26   , installed 1.9.26
            Adapter    "iot"          : 1.14.5   , installed 1.14.5
            Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
            Adapter    "javascript"   : 7.0.3    , installed 7.0.3
            Controller "js-controller": 4.0.24   , installed 4.0.24
            Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
            Adapter    "philips-air"  : 1.0.3    , installed 1.0.3
            Adapter    "ping"         : 1.5.3    , installed 1.5.3
            Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
            Adapter    "proxmox"      : 1.3.5    , installed 1.3.4  [Updatable]
            Adapter    "shelly"       : 6.4.1    , installed 6.4.1
            Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
            Adapter    "socketio"     : 4.2.0    , installed 4.2.0
            Adapter    "synology"     : 2.1.13   , installed 2.1.13
            Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
            Adapter    "telegram"     : 1.15.6   , installed 1.15.6
            Adapter    "terminal"     : 1.0.0    , installed 1.0.0
            Adapter    "text2command" : 3.0.2    , installed 3.0.2
            Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
            Adapter    "trashschedule": 2.2.0    , installed 2.2.0
            Adapter    "upnp"         : 1.0.21   , installed 1.0.21
            Adapter    "uv-protect"   : 0.4.0    , installed 0.4.0
            Adapter    "vis"          : 1.4.16   , installed 1.4.16
            Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
            Adapter    "web"          : 4.3.0    , installed 4.3.0
            Adapter    "ws"           : 1.3.0    , installed 1.3.0
            Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
            Thomas BraunT R 2 Antworten Letzte Antwort
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Docker          : false
              Release:        11
              Codename:       bullseye
              VERSION_ID="11"
              ID=debian
              CPU threads: 4
                               RTC time: n/a
                        RTC in local TZ: no
              root
              /root
              root
              X-Server:       false
              Desktop:
              Terminal:
              *** MEMORY ***
              Swap:           512M          0B        512M
                       4096 M total memory
                       2347 M used memory
                        141 M active memory
                       1423 M free memory
                          0 M buffer memory
                        325 M swap cache
                        512 M total swap
                          0 M used swap
                        512 M free swap
              *** FILESYSTEM ***
              /var:
              392M    /var/
              229M    /var/cache
              223M    /var/cache/apt
              144M    /var/lib
              /usr/bin/npm            9.5.1
              /usr/bin/npx            9.5.1
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.3.5
              javascript:     7.0.3
              Adapter State
              + instance is alive
              Zunächst: Hampel nicht als root durch den Container.
              Leg dir einen user dafür an.
              Zieh die drei Adapter auf einen aktuellen Stand.
              Ansonsten soweit okay, schalt sentry für den Adapter aus. Geht glaube ich nur im Experten-Modus.
                shellyrulestheworld
                @thomas-braun herzlichen Dank für deine Hilfe
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Docker          : false
                  Release:        11
                  Codename:       bullseye
                  VERSION_ID="11"
                  ID=debian
                  CPU threads: 4
                                   RTC time: n/a
                            RTC in local TZ: no
                  root
                  /root
                  root
                  X-Server:       false
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Swap:           512M          0B        512M
                           4096 M total memory
                           2347 M used memory
                            141 M active memory
                           1423 M free memory
                              0 M buffer memory
                            325 M swap cache
                            512 M total swap
                              0 M used swap
                            512 M free swap
                  *** FILESYSTEM ***
                  /var:
                  392M    /var/
                  229M    /var/cache
                  223M    /var/cache/apt
                  144M    /var/lib
                  /usr/bin/npm            9.5.1
                  /usr/bin/npx            9.5.1
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.3.5
                  javascript:     7.0.3
                  Adapter State
                  + instance is alive
                  Rolf_A
                  @shellyrulestheworld Entschuldige meine "doofe" Frage, wo finde ich die Einstellung sentry?
                  crunchipC XsevX 2 Antworten Letzte Antwort
                  • R Rolf_A
                    crunchipC Offline
                    crunchipC Offline
                    @rolf_a system.adapter.zigbee.0.plugins.sentry
                    • R Rolf_A
                      XsevX Offline
                      XsevX Offline
                      Xsev
                      @rolf_a Du kannst es auch im Admin unter Instanzen (Expertenansicht aktiv!!) auf der rechten Seite (grünes Symbol) für den jeweiligen Adapter deaktivieren.
                      R 1 Antwort Letzte Antwort
                      • XsevX Xsev
                        Rolf_A
                        @xsev uund @crunchip habe es gefunden. Vielen Dank. Nur Leider startet der Adapter im Minutentakt immer wieder neu. Hat er bis ich in "udev-Falle" getappt bin meiner Meinung nach nicht gemacht. Zigbee funktioniert soweit aber.
                        • R Rolf_A
                          crunchipC Offline
                          crunchipC Offline
                          @rolf_a was ist 0x9035eafffee1c47c für ein Gerät?
                            Rolf_A
                            @crunchip Oh, jetzt steh ich auf dem Schlauch. Ich versteh die Frage nicht. Ich hab doch keine Geräte ins Spiel gebracht? Oder ist das ein Test? Bin Leider ein Silberrücken der sich die Dinge nur anließt und deshalb manchmal aus dem "Mus-Topf" kommt.
                            • crunchipC Offline
                              crunchipC Offline
                              @rolf_a sorry, hatte ich oben verwechselt, hatte nicht auf den user geachtet
                              @rolf_a sagte in Zigbee Adapter Fehlermeldungen:
                              Logmeldung
                                Logmeldung
                                Rolf_A
                                schrieb am zuletzt editiert von Rolf_A
                                zigbee.0
                                	2023-06-30 15:39:04.277	info	Zigbee started
                                zigbee.0
                                	2023-06-30 15:39:04.277	info	0x00124b000c9d2126 (addr 15856): CC2530.ROUTER - Custom devices (DiY) [CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/) (Router)
                                zigbee.0
                                	2023-06-30 15:39:04.277	info	0x00158d000895981f (addr 17956): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                zigbee.0
                                	2023-06-30 15:39:04.276	info	0x00158d0008ce65bc (addr 32859): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                	2023-06-30 15:39:04.276	info	0xa4c13884fc8a572b (addr 52850): TS0601_human_presence_sensor - TuYa Human presence sensor Zigbee (Router)
                                zigbee.0
                                	2023-06-30 15:39:04.275	info	0xa4c138f48de4d9e4 (addr 49435): TS0601_human_presence_sensor - TuYa Human presence sensor Zigbee (Router)
                                zigbee.0
                                	2023-06-30 15:39:04.275	info	0x00158d0008913fdd (addr 17754): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                	2023-06-30 15:39:04.274	info	0xa4c1387775e9933e (addr 48189): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                                zigbee.0
                                	2023-06-30 15:39:04.274	info	0xa4c138e286d3f8fc (addr 23116): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                                zigbee.0
                                	2023-06-30 15:39:04.267	info	Currently 8 devices are joined:
                                zigbee.0
                                	2023-06-30 15:39:04.221	info	--> transmitPower : high
                                zigbee.0
                                	2023-06-30 15:39:04.216	info	Unable to disable LED, unsupported function.
                                zigbee.0
                                	2023-06-30 15:39:04.211	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
                                zigbee.0
                                	2023-06-30 15:39:03.661	info	Installed Version: iobroker.zigbee@1.8.10
                                zigbee.0
                                	2023-06-30 15:39:03.456	info	Starting Zigbee npm ...
                                zigbee.0
                                	2023-06-30 15:39:03.455	info	delete old Backup files. keep only last 10
                                zigbee.0
                                	2023-06-30 15:39:03.371	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
                                host.iobroker
                                	2023-06-30 15:39:02.086	info	instance system.adapter.zigbee.0 started with pid 1949548
                                host.iobroker
                                	2023-06-30 15:39:01.048	info	Restart adapter system.adapter.zigbee.0 because enabled
                                host.iobroker
                                	2023-06-30 15:39:01.047	info	instance system.adapter.zigbee.0 scheduled normal terminated and will be restarted on schedule.
                                hm-rega.0
                                	2023-06-30 15:39:00.731	info	pollingTrigger
                                zigbee.0
                                	2023-06-30 15:39:00.508	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                zigbee.0
                                	2023-06-30 15:39:00.507	info	terminating
                                zigbee.0
                                	2023-06-30 15:39:00.015	info	Zigbee: disabling joining new devices.
                                zigbee.0
                                	2023-06-30 15:39:00.005	info	cleaned everything up...
                                zigbee.0
                                	2023-06-30 15:39:00.005	info	Scheduled restart.
                                hm-rega.0
                                	2023-06-30 15:38:52.115	info	pollingTrigger
                                zigbee.0
                                	2023-06-30 15:38:04.147	info	Zigbee started
                                zigbee.0
                                	2023-06-30 15:38:04.146	info	0x00124b000c9d2126 (addr 15856): CC2530.ROUTER - Custom devices (DiY) [CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/) (Router)
                                zigbee.0
                                	2023-06-30 15:38:04.146	info	0x00158d000895981f (addr 17956): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                zigbee.0
                                	2023-06-30 15:38:04.146	info	0x00158d0008ce65bc (addr 32859): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                	2023-06-30 15:38:04.145	info	0xa4c13884fc8a572b (addr 52850): TS0601_human_presence_sensor - TuYa Human presence sensor Zigbee (Router)
                                zigbee.0
                                	2023-06-30 15:38:04.145	info	0xa4c138f48de4d9e4 (addr 49435): TS0601_human_presence_sensor - TuYa Human presence sensor Zigbee (Router)
                                zigbee.0
                                	2023-06-30 15:38:04.144	info	0x00158d0008913fdd (addr 17754): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                	2023-06-30 15:38:04.144	info	0xa4c1387775e9933e (addr 48189): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                                zigbee.0
                                	2023-06-30 15:38:04.143	info	0xa4c138e286d3f8fc (addr 23116): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                                zigbee.0
                                	2023-06-30 15:38:04.137	info	Currently 8 devices are joined:
                                zigbee.0
                                	2023-06-30 15:38:04.133	info	--> transmitPower : high
                                zigbee.0
                                	2023-06-30 15:38:04.128	info	Unable to disable LED, unsupported function.
                                zigbee.0
                                	2023-06-30 15:38:04.122	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
                                zigbee.0
                                	2023-06-30 15:38:03.555	info	Installed Version: iobroker.zigbee@1.8.10
                                zigbee.0
                                	2023-06-30 15:38:03.375	info	Starting Zigbee npm ...
                                zigbee.0
                                	2023-06-30 15:38:03.374	info	delete old Backup files. keep only last 10
                                zigbee.0
                                	2023-06-30 15:38:03.306	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
                                host.iobroker
                                	2023-06-30 15:38:02.084	info	instance system.adapter.zigbee.0 started with pid 1948417
                                host.iobroker
                                	2023-06-30 15:38:01.051	info	Restart adapter system.adapter.zigbee.0 because enabled
                                host.iobroker
                                	2023-06-30 15:38:01.051	info	instance system.adapter.zigbee.0 scheduled normal terminated and will be restarted on schedule.
                                zigbee.0
                                	2023-06-30 15:38:00.510	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                zigbee.0
                                	2023-06-30 15:38:00.510	info	terminating
                                zigbee.0
                                	2023-06-30 15:38:00.015	info	Zigbee: disabling joining new devices.
                                zigbee.0
                                	2023-06-30 15:38:00.008	info	cleaned everything up...
                                zigbee.0
                                	2023-06-30 15:38:00.007	info	Scheduled restart.
                                hm-rega.0
                                	2023-06-30 15:37:52.116	info	pollingTrigger
                                • R Rolf_A
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  host.iobroker
                                  host.iobroker
                                  host.iobroker
                                  hm-rega.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  hm-rega.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  host.iobroker
                                  host.iobroker
                                  host.iobroker
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  hm-rega.0
                                  crunchipC Offline
                                  crunchipC Offline
                                  Scheduled restart.
                                  hast du da vllt. versehentlich etwas eingestellt?
                                    Scheduled restart.
                                    Rolf_A
                                    @crunchip Danke, das wars! Stand auf einer Minute. Ich streu Asche über mein Haupt. Ja, der DAU sitzt immer vorm Bildschirm! Wie ich es gemacht habe weiß ich leider nicht.
                                    Vielen Dank!
                                    Gruß Rolf
