  4. MQTT Adapter - verliert Verbindung - MQTT und VIS?
    5.6k
19 Beiträge 5 Kommentatoren 3.5k Aufrufe
  • N Offline
    N Offline
    noxx
    Moin
    da ja leider mein ESP ohne MQTT nicht funktioniert, habe ich nun diesen
    installiert, dazu auch den MQTT Adapter. Aber ich verliere ständig die Verbindung,
    mehrmals pro Sekunde wird verbunden/verloren.
    Die Lampe unter Instanzen ist nur Grün/Gelb am flackern.
    mqtt.0	2017-07-03 13:45:44.908	info	Adapter is disabled => stop
    mqtt.0	2017-07-03 13:45:44.853	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:43.754	info	All states published
    mqtt.0	2017-07-03 13:45:43.655	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:43.637	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:43.618	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:43.601	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:43.592	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:43.575	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:43.567	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:43.550	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:43.542	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:43.524	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:43.515	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:43.493	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:43.486	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:43.468	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:43.462	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:43.443	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:43.437	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:43.420	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:43.411	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:43.390	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:43.382	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:43.364	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:43.358	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:43.338	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:43.332	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:43.317	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:42.506	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:42.482	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:41.516	info	All states published
    mqtt.0	2017-07-03 13:45:41.424	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:41.406	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:41.392	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:41.374	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:41.365	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:41.348	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:41.341	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:41.323	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:41.316	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:41.299	info	Disconnected from localhost
    mqtt.0	2017-07-03 13:45:41.293	info	Connected to localhost
    mqtt.0	2017-07-03 13:45:41.276	info	Disconnected from localhost
    • ThisoftT Offline
      ThisoftT Offline
      Thisoft
      Macht dein MQTT-Adapter das "Geflackere" auch wenn der ESP nicht an ist, also quasi "von sich aus" oder passiert das nur wenn sich der ESP-Client versucht zu verbinden?
      Im zweiten Fall wäre es interessant wenn Du das ESP-Script posten könntest…
      Achja - zum Testen vielleicht die beiden Haken in den Adaptereinstellungen mal rausnehmen. Ich hab die jedenfalls bei mir nicht drin.
      • N Offline
        N Offline
        noxx
        Teste ich, es läuft ESPeasy, letzte Version, auf dem ESP.
        Gesendet von meinem GT-I9195 mit Tapatalk
        • DutchmanD Offline
          DutchmanD Offline
          Dutchman
          @noxx:
          Gesendet von meinem GT-I9195 mit Tapatalk `
          du probierst einen MQTT client auf localhost zu connecten, hast du den einen MQTT server laufen oder moechtest du iObroker als server benutzen ?
          (dan stimmen deine settings nicht)
          Das geflakkeren kommt weil er probiert verbindung zu machen aber keinen response bekommt.
          ~Dutch
          • ThisoftT Offline
            ThisoftT Offline
            Thisoft
            Ja - natürlich. Dutchman hat Recht! Als erstes musst Du natürlich den MQTT-Adapter als Server konfigurieren wenn der ESP der Client ist (wovon ich mal ausgehe..)
            • ? Dieser Nutzer ist nicht in diesem Forum angemeldet.
              Gast
              Also brauche ich mosquitto nicht?
              • N Offline
                N Offline
                noxx
                mosquitto habe ich wie folgt installiert:
                sudo /etc/init.d/mosquitto stop
                sudo apt-get --purge remove mosquitto mosquitto-clients python-mosquitto
                wget http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key
                sudo apt-key add mosquitto-repo.gpg.key
                cd /etc/apt/sources.list.d/
                sudo wget http://repo.mosquitto.org/debian/mosquitto-jessie.list
                sudo apt-get update
                sudo apt-cache search mosquitto
                sudo apt-get install mosquitto
                sudo apt-get install mosquitto-clients
                sudo apt-get install phyton-mosquitto
                Verbindung kann ich testen mit
                mosquitto_sub -v -t \#
                /ESP04/Gaszaehler/Count 0.00
                Nun möchte ich die Werte auch im ioBroker.
                Stelle ich auf Server um, geht der Adapter nicht mehr auf Grün.
                mqtt.0	2017-07-03 18:10:26.750	error	exception by stop: server.destroy is not a function
                mqtt.0	2017-07-03 18:10:26.744	error	at Adapter. (/opt/iobroker/node_modules/iobroker.mqtt/main.js:50:24)
                mqtt.0	2017-07-03 18:10:26.744	error	at MQTTServer.destroy (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:25:20)
                mqtt.0	2017-07-03 18:10:26.744	error	at Object.destroy (/opt/iobroker/node_modules/iobroker.mqtt/lib/streamServer.js:141:19)
                mqtt.0	2017-07-03 18:10:26.744	error	at Object.mapSeries (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/async/dist/async.js:980:16)
                mqtt.0	2017-07-03 18:10:26.744	error	at /opt/iobroker/node_modules/iobroker.mqtt/node_modules/async/dist/async.js:1153:16
                mqtt.0	2017-07-03 18:10:26.744	error	at _asyncMap (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/async/dist/async.js:1067:5)
                mqtt.0	2017-07-03 18:10:26.744	error	at /opt/iobroker/node_modules/iobroker.mqtt/node_modules/async/dist/async.js:950:9
                mqtt.0	2017-07-03 18:10:26.744	error	at replenish (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/async/dist/async.js:946:17)
                mqtt.0	2017-07-03 18:10:26.744	error	at /opt/iobroker/node_modules/iobroker.mqtt/node_modules/async/dist/async.js:1069:9
                mqtt.0	2017-07-03 18:10:26.744	error	at /opt/iobroker/node_modules/iobroker.mqtt/lib/streamServer.js:146:24
                mqtt.0	2017-07-03 18:10:26.744	error	TypeError: server.destroy is not a function
                mqtt.0	2017-07-03 18:10:26.718	error	uncaught exception: server.destroy is not a function
                Gibt für denn Adapter eine Anleitung?
                • DutchmanD Offline
                  DutchmanD Offline
                  Dutchman
                  Nein du brauchst kein mosquitto dafür haben wir ja iobroker, der kan als MQTT Client und Server fungieren.
                  Ich stellen in 5 nin mal einen Screenshot nach wie mein MQTT Server in ioBroker eingerichtet ist.
                  Eventuell bei dir mal die MQTT Instanze löschen und neu installieren.
                  Also Basis ist:
                  • ioBroker ist der MQTT Server
                  • der muss richtig eingerichtet und freigegeben sein
                  • die Clients verbinden sich mit dem ioBroker MQTT Server und publishen da ihre stats
                  Bei mir so ähnlich gelöst
                  iObroker <> domoticz, ioBroker ist der Server und domoticz ein client
                  edit: ok hier die screens, einziger underschied ist das ich wohl einen username/pass verwende.
                  ergebnis, domoticz pusht seine werte in seinen eigenen channel:
                  ich empfehle dir sowieso die instanz mal zu loeschen und neu installieren deine fehlermeldung kommt mir komisch vor (eventueel bereits belegter port ?)
                  Den userguide findest du auf git (in iobroker auf das fragezeichen druecken bei dem adapter: https://github.com/ioBroker/ioBroker.mqtt
                  Send from mobile device
                  • N Offline
                    N Offline
                    noxx
                    danke, geht nun. Frage, warum werden die mqtt-IDs nicht unter VIS angezeigt?
                    Kannt leider keine Relais schalten.
                    • N Offline
                      N Offline
                      noxx
                      Habe mal ein paar Sachen probiert, aber irgendwie will er nicht
                      • DutchmanD Offline
                        DutchmanD Offline
                        Dutchman
                        Das mit vis lan sein bei neuen Werten eventuell Adapter Mal bei starten aber das hast du ja bereits selber gedixt :)
                        Stimmen die URL? Gehen diese wen du sie außerhalb vis im Browser probierst ?
                        • N Offline
                          N Offline
                          noxx
                          Im Browser gehen sie. Verstehe die Logik noch nicht so ganz
                          • C Offline
                            ccc.ggg73
                            @noxx:
                            Habe mal ein paar Sachen probiert, aber irgendwie will er nicht `
                            Hallo noxx,
                            Siehe dir dieser thread an:
                            http://forum.iobroker.net/viewtopic.php?t=6655
                            Gesendet von meinem SM-G950F mit Tapatalk
                            • N Offline
                              N Offline
                              noxx
                              danke, den hatte ich schon gefunden, bin aber nicht weitergekommen.
                              Habe schon diverse Sachen in vis probiert, aber leider schaltet der ESP nicht.
                              • ThisoftT Offline
                                ThisoftT Offline
                                Thisoft
                                um erstmal einzugrenzen ob die Ursache im VIS liegt oder schon vorher:
                                Kannst du denn den ESP schalten wenn du den entsprechenden Zustand direkt in der Adminoberfläche (Reiter "Objekte" oder "Zustände") änderst?
                                • N Offline
                                  N Offline
                                  noxx
                                  @Thisoft:
                                  MQTT1.jpg `
                                  Nein, geht nicht. Wert wird erst Grün, dann Rot, dann springt er auf den alten Wert zurück
                                  • ThisoftT Offline
                                    ThisoftT Offline
                                    Thisoft
                                    Da fällt mir auf, dass es bei dir einen "Get"- und einen "Set"-Zweig im MQTT-Ordner gibt. Ich befürchte, da liegt der Haken… wo wir gerade beim Haken sind - probiere mal ob's hilft wenn du in den Adaptereinstellungen den Haken bei "Unterschiedliche Namen für setzen und lesen" reinmachst.
                                    Ist aber nur eine Vermutung. Ich hab das noch nie probiert und ich kenne auch ESPEasy überhaupt nicht - ich programmiere meine ESP's und Arduinos selber...
                                    • N Offline
                                      N Offline
                                      noxx
                                      @Thisoft:
                                      Ist aber nur eine Vermutung. Ich hab das noch nie probiert und ich kenne auch ESPEasy überhaupt nicht - ich programmiere meine ESP's und Arduinos selber... `
                                      Hatte mich etwas an den Sonoff Thread gehalten, da wurden SET und GET definiert.
                                      Habe nun den MQTT nochmal neu aufgesetzt und auch ESPeasy neu installiert (ältere FW R147)
                                      Laufen tuts aber noch immer nicht, kann manuell nicht schalten. Setze ich auf 1 springt er zurück auf 0.
                                      EDIT
                                      Hier nochmal ne Liste von Fehler, betreffen aber nun den Sonoff. Mal geht der, dann wieder nicht.
                                      ESPClient13 = ESP03 (Screenshots)
                                      ESPClient1 = Sonoff
                                      mqtt.0	2017-07-04 14:09:10.298	warn	Cannot resolve topic name for ID: web.0.connected (object not found)
                                      mqtt.0	2017-07-04 14:09:10.297	warn	Cannot resolve topic name for ID: web.0.connected (object not found)
                                      mqtt.0	2017-07-04 14:09:10.289	warn	Cannot resolve topic name for ID: web.0.connected (object not found)
                                      mqtt.0	2017-07-04 14:09:08.987	warn	Cannot resolve topic name for ID: web.0.connected (object not found)
                                      mqtt.0	2017-07-04 14:09:08.986	warn	Cannot resolve topic name for ID: web.0.connected (object not found)
                                      mqtt.0	2017-07-04 14:08:36.231	info	publishOnSubscribe send all known states
                                      mqtt.0	2017-07-04 14:08:36.231	info	Client [ESPClient13] subscribes on "ESP03.#" with regex /^mqtt\.0\.ESP03\..*/
                                      mqtt.0	2017-07-04 14:08:36.230	info	Client [ESPClient13] subscribes on "ESP03.#" with regex /^ESP03\..*/
                                      mqtt.0	2017-07-04 14:08:36.202	info	Client [ESPClient13] connected
                                      mqtt.0	2017-07-04 14:08:35.575	warn	Cannot resolve topic name for ID: null (object not found)
                                      mqtt.0	2017-07-04 14:08:35.574	info	publishOnSubscribe
                                      mqtt.0	2017-07-04 14:08:35.574	info	Client [ESPClient0] subscribes on "null"
                                      mqtt.0	2017-07-04 14:08:35.552	info	Client [ESPClient0] connected
                                      mqtt.0	2017-07-04 14:08:20.191	warn	Cannot resolve topic name for ID: null (object not found)
                                      mqtt.0	2017-07-04 14:08:20.165	info	publishOnSubscribe
                                      mqtt.0	2017-07-04 14:08:20.164	info	Client [ESPClient1] subscribes on "null"
                                      mqtt.0	2017-07-04 14:08:19.761	info	Client [ESPClient1] connected
                                      mqtt.0	2017-07-04 14:08:09.244	info	Starting MQTT server on port 1883
                                      mqtt.0	2017-07-04 14:08:08.439	info	starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v6.11.0
                                      mqtt.0	2017-07-04 14:08:08.268	info	States connected to redis 127.0.0.1:6379
                                      mqtt.0	2017-07-04 14:08:03.244	info	terminating
                                      mqtt.0	2017-07-04 14:08:02.769	info	Client [ESPClient0] closed
                                      mqtt.0	2017-07-04 14:08:02.765	info	Client [ESPClient13] closed
                                      mqtt.0	2017-07-04 14:08:02.762	info	Client [ESPClient1] closed
                                      mqtt.0	2017-07-04 14:04:51.117	info	Client [ESPClient1] closed
                                      mqtt.0	2017-07-04 14:04:51.079	info	Client [ESPClient1] connected
                                      mqtt.0	2017-07-04 14:04:40.158	info	publishOnSubscribe
                                      mqtt.0	2017-07-04 14:04:40.157	info	Client [ESPClient1] subscribes on "mqtt.0.Sonoff1.Set.GPIO.12"
                                      mqtt.0	2017-07-04 14:04:40.140	info	Client [ESPClient1] connected
                                      mqtt.0	2017-07-04 14:04:36.147	info	publishOnSubscribe send all known states
                                      mqtt.0	2017-07-04 14:04:36.147	info	Client [ESPClient13] subscribes on "ESP03.#" with regex /^mqtt\.0\.ESP03\..*/
                                      mqtt.0	2017-07-04 14:04:36.144	info	Client [ESPClient13] subscribes on "ESP03.#" with regex /^ESP03\..*/
                                      mqtt.0	2017-07-04 14:04:36.122	info	Client [ESPClient13] connected
                                      mqtt.0	2017-07-04 14:04:35.877	warn	Cannot resolve topic name for ID: null (object not found)
                                      • DutchmanD Offline
                                        DutchmanD Offline
                                        Dutchman
                                        Der MQTT hat einen get und einen Set.
                                        Get = was reinkommt
                                        Set = schalten
                                        Also Variable ändern in den hetbobject wird nicht bringen, überschreibt MQTT logischer Weise.
                                        Die musst den richtigen Wert bei Set übermitteln
