  4. E-INK Display OpenEPaperLink - Displayanzeige mit Batterie
1.0k Beiträge 49 Kommentatoren 442.2k Aufrufe 52 Beobachtet
  • B Beowolf
    Hier noch einmal die Meldung die kommt, wenn sich der Adapter Aufhängt.
    host.raspberrypi
    	2024-05-10 14:00:33.724	error	instance system.adapter.open-epaper-link.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    open-epaper-link.0
    	2024-05-10 14:00:32.953	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    open-epaper-link.0
    	2024-05-10 14:00:32.952	info	terminating
    open-epaper-link.0
    	2024-05-10 14:00:32.948	error	Cannot read properties of undefined (reading 'mac')
    open-epaper-link.0
    	2024-05-10 14:00:32.948	error	TypeError: Cannot read properties of undefined (reading 'mac') at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.open-epaper-link/build/main.js:124:102) at WebSocket.emit (node:events:517:28) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/ws/lib/websocket.js:1209:20) at Receiver.emit (node:events:517:28) at /opt/iobroker/node_modules/ws/lib/receiver.js:608:16 at node:internal/process/task_queues:140:7 at AsyncResource.runInAsyncScope (node:async_hooks:203:9) at AsyncResource.runMicrotask (node:internal/process/task_queues:137:8) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    open-epaper-link.0
    	2024-05-10 14:00:32.947	error	uncaught exception: Cannot read properties of undefined (reading 'mac')
    bimmi
    #501
    @beowolf sagte in EPS E-INK Display Ansteuerung -> Statusdisplay für 2€:
    host.raspberrypi 2024-05-10 14:00:33.724 error instance system.adapter.open-epaper-link.0 terminated with code 6 (UNCAUGHT_EXCEPTION) open-epaper-link.0 2024-05-10 14:00:32.953 warn Terminated (UNCAUGHT_EXCEPTION): Without reason open-epaper-link.0 2024-05-10 14:00:32.952 info terminating open-epaper-link.0 2024-05-10 14:00:32.948 error Cannot read properties of undefined (reading 'mac') open-epaper-link.0 2024-05-10 14:00:32.948 error TypeError: Cannot read properties of undefined (reading 'mac') at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.open-epaper-link/build/main.js:124:102) at WebSocket.emit (node:events:517:28) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/ws/lib/websocket.js:1209:20) at Receiver.emit (node:events:517:28) at /opt/iobroker/node_modules/ws/lib/receiver.js:608:16 at node:internal/process/task_queues:140:7 at AsyncResource.runInAsyncScope (node:async_hooks:203:9) at AsyncResource.runMicrotask (node:internal/process/task_queues:137:8) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) open-epaper-link.0 2024-05-10 14:00:32.947 error uncaught exception: Cannot read properties of undefined (reading 'mac')
    kannst du mal das script hier testen:
    const WebSocket = require('websocket').w3cwebsocket;
    // Funktion zum Behandeln der WebSocket-Verbindung für EPS
    function handleEPSWebSocket(deviceIP) {
        const ws = new WebSocket(deviceIP);
        // Ereignishandler, wenn die WebSocket-Verbindung geöffnet wird
        ws.onopen = () => {
            console.log(`Verbindung zu ${deviceIP} erfolgreich hergestellt.`);
        // Fehlerbehandlung für die WebSocket-Verbindung
        ws.onerror = (error) => {
            console.error(`WebSocket-Fehler: ${error.message}`);
        // Behandlung der Schließung der WebSocket-Verbindung
        ws.onclose = (event) => {
            console.log(`WebSocket-Verbindung geschlossen: Code=${event.code}, Grund=${event.reason}`);
        // Datenempfang über WebSocket
        ws.onmessage = (event) => {
            const data = event.data.toString();
            console.log(`Empfangene Daten von EPS (${deviceIP}): ${data}`);
            try {
                const jsonData = JSON.parse(data);
                console.log('JSON-Daten:', jsonData); // Ausgabe der empfangenen Daten für Überprüfung
                // Sicherstellen, dass das 'tags' Array existiert und mindestens ein Element enthält
                if (jsonData.tags && jsonData.tags.length > 0) {
                    const tag = jsonData.tags[0];
                    // Überprüfen, ob die notwendigen Eigenschaften vorhanden sind
                    if (tag && tag.wakeupReason && tag.mac) {
                        console.log(`Wakeup Reason erhalten: ${tag.wakeupReason}`);
                        console.log(`MAC erhalten: ${tag.mac}`);
                        // Schreibe den aktuellen Wert von Mac und wakeupReason in den Datenpunkt
                        setState('0_userdata.0.EPS.Websocket', `${tag.mac}_${tag.wakeupReason}`, true);
                        console.log(`Aktueller Wert von Wakeup Reason (${tag.wakeupReason}) und MAC (${tag.mac}) in Datenpunkt geschrieben.`);
                    } else {
                        console.log('Notwendige Eigenschaften `wakeupReason` oder `mac` fehlen in den Daten.');
                } else {
                    console.log('Keine oder leere Tags im JSON-Datenobjekt vorhanden.');
            } catch (error) {
                console.error(`Fehler beim Verarbeiten der empfangenen Daten: ${error}`);
    // Verbindung zum EPS WebSocket-Server herstellen und behandeln
    handleEPSWebSocket('ws://192.168.1.70/ws');
    Gruß Bimmi
    iobroker in einer Proxmox Umgebung auf einem ausrangierten DELL OptiPlex 3080 24GB i5 in der VM auf SSD. Nutze den slaeh zigbee Router mit Tür- und Temperatursensoren von Aqara, viele Tasmota Devices, Unifi AP, Sprinklecontrol, günstige E-INK Displays, Adguard und noch vieles mehr 😬
      Beowolf
      #502
      Kommt direkt das
      10.5.2024, 22:56:34.853	[warn ]: javascript.0 (10472)     at W3CWebSocket.ws.onmessage (script.js.common.EPaper-Displays.Erdgeschoss.button:42:21)
      10.5.2024, 22:56:34.857	[warn ]: javascript.0 (10472)     at W3CWebSocket.ws.onmessage (script.js.common.EPaper-Displays.Erdgeschoss.button:41:21)
      10.5.2024, 22:56:34.860	[warn ]: javascript.0 (10472)     at W3CWebSocket.ws.onmessage (script.js.common.EPaper-Displays.Erdgeschoss.button:42:21)
      Die Natur braucht nicht unseren Schutz, sie braucht unsere Abwesenheit.
      B 1 Antwort Letzte Antwort
      • B Beowolf
        Kommt direkt das
        bimmi
        #503
        @beowolf ich schau dieses Wochenende nochmal drüber 👍
        Gruß Bimmi
          bimmi
          schrieb am zuletzt editiert von bimmi
          #504
          So, hab mich mal ein bisschen bemüht und dann ist folgendes herausgekommen:
          https://github.com/slimline33/OpenEPaperLink-IOBROKER-JavaScript
          Bitte testen.
          "javascript.0 (1401318) script.js.EPS.Websocket2_Test: Object "0_userdata.0.OpenEPaperLink.4467090B10421125" can't be copied: {}"
          Den Fehler bekomm ich noch nicht weg, ändert aber nichts an der Funktion!
          Gruß Bimmi
          ? B 2 Antworten Letzte Antwort
          • B bimmi
            Bitte testen.
            #505
            @bimmi
            super, laeuft einwandfrei!
            Hat n bisschen gedauert, bis alle Datenpunkte angelegt wurden, und man das im Admin gesehen hat.. aber ich glaube das war noch ein Bug im Admin 6.17.3... die neueren Versionen geiern ja ab, wenn man was aendert..
            Aber super, so habe ich alle Datenpunkte mit Mac etc drin und darauf zieh ich mir dann die Daten fuer die Scripte..
            • Walter.O.W Walter.O.
              Hallo, gibt es hier einen Link zu einer seite für mich als Anfänger im E-Paperbereich .?
              Schön wäre eine schritt für schritt anleitung für den Einstieg.
              Walter.O.W Offline
              Walter.O.W Offline
              Walter.O.
              #506
              Wollte jetzt mal OpenEPaperLink instalieren bekomme aber diese Fehlermeldung
              $ iobroker url https://github.com/jjwbruijn/OpenEPaperLink.git --host Mini-pc-Master --debug
              install jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c
              NPM version: 10.5.0Installing jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c... (System call)
              npm WARN tarball tarball data for github:jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c (null) seems to be corrupted. Trying again.
              npm ERR! syscall open
              npm ERR! errno -2
              npm ERR! enoent ENOENT: no such file or directory, open '/home/iobroker/.npm/_cacache/tmp/git-cloneZ4T6jc/package.json'
              npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-11T15_15_08_501Z-debug-0.log
              npm WARN tarball tarball data for github:jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c (null) seems to be corrupted. Trying again.npm WARN tarball tarball data for github:jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c (null) seems to be corrupted. Trying again.npm ERR! code ENOENTnpm ERR! syscall opennpm ERR! path /home/iobroker/.npm/_cacache/tmp/git-cloneZ4T6jc/package.jsonnpm ERR! errno -2npm ERR! enoent ENOENT: no such file or directory, open '/home/iobroker/.npm/_cacache/tmp/git-cloneZ4T6jc/package.json'npm ERR! enoent This is related to npm not being able to find a file.npm ERR! enoent npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-11T15_15_08_501Z-debug-0.log
              host.Mini-pc-Master Cannot install jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c: 254
              ERROR: Process exited with code 25
              Was muss ich denn da jetzt machen, blicke da jetzt mal gar nicht durch.
              Thomas BraunT B ? 3 Antworten Letzte Antwort
                npm ERR! errno -2
                #507
                @walter-o
                Da kannst du gar nix machen, die Dateien sind im Moment wohl defekt.
                Bei mir kommt das auch so um die Ecke:
                $ iobroker url https://github.com/jjwbruijn/OpenEPaperLink --host chet --debug
                NPM version: 10.7.0
                npm warn tarball tarball data for github:jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c (null) seems to be corrupted. Trying again.
                npm error code ENOENT
                npm error path /home/iobroker/.npm/_cacache/tmp/git-cloneXXXXXXZkFV1r/package.jsonnpm error errno -2
                npm error enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/iobroker/.npm/_cacache/tmp/git-cloneXXXXXXZkFV1r/package.json'
                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-11T15_24_06_313Z-debug-0.log
                npm warn tarball tarball data for github:jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c (null) seems to be corrupted. Trying again.npm warn tarball tarball data for github:jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c (null) seems to be corrupted. Trying again.npm error code ENOENTnpm error syscall opennpm error path /home/iobroker/.npm/_cacache/tmp/git-cloneXXXXXXZkFV1r/package.jsonnpm error errno -2npm error enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/iobroker/.npm/_cacache/tmp/git-cloneXXXXXXZkFV1r/package.json'npm error enoent This is related to npm not being able to find a file.npm error enoentnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-11T15_24_06_313Z-debug-0.log
                host.chet Cannot install jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c: 254
                Walter.O.W B 2 Antworten Letzte Antwort
                  @walter-o
                  NPM version: 10.7.0
                  Walter.O.W Offline
                  Walter.O.W Offline
                  Walter.O.
                  #508
                  @thomas-braun Okay,Danke dir
                    npm ERR! errno -2
                    bimmi
                    #509
                    @walter-o was genau willst du installieren? Der OpenEPaperLink Adapter wird nicht weiter entwickelt.
                    Den Access Point am besten über www.openepaperlink.de installieren.
                    Gruß Bimmi
                      @walter-o
                      NPM version: 10.7.0
                      bimmi
                      #510
                      @thomas-braun sagte in EPS E-INK Display Ansteuerung -> Statusdisplay für 2€:
                      @walter-o
                      NPM version: 10.7.0
                      Man könnte auch diesen fork nutzen. Der ist aktueller :
                      https://github.com/jonasniesner/OpenEPaperLink
                      Jedoch würde ich wie gesagt über openepaperlink.de gehen.
                      Aber: mit der aktuellsten Version geht gar nichts im Moment. Auch der zigbee Teil ist defekt.
                      Gruß Bimmi
                      • B bimmi
                        Bitte testen.
                        Beowolf
                        #511
                        @bimmi sagte in EPS E-INK Display Ansteuerung -> Statusdisplay für 2€:
                        Bitte testen.
                        Super. Vielen Dank dafür.
                        Der löpp ja richtig gut. Die Buttonabfrage funktioniert auch top. 👍 👍 👍 👍 👍
                          bimmi
                          #512
                          Jetzt noch json push einbauen und fertig ist der Adapter 😅🤣
                          Gruß Bimmi
                            npm ERR! errno -2
                            #513
                            @walter-o @Thomas-Braun
                            was macht ihr da denn? Das ist doch kein iobroker Adapter... tss.. :-)
                            OpenEpaperlink flasht man auf einen entsprechenden Accesspoint, meist ein ESP32 mit zigbee Modul... auch hier, wie bei Tasmota, einfach das Webinterface nehmen. Oder einfach mal die Anleitung lesen (mach ich auch erst, wenn nix geht.. :-) )
                              #514
                              @ilovegym sagte in EPS E-INK Display Ansteuerung -> Statusdisplay für 2€:
                              :-) Hatte nur den github-Link aus dem ersten Beitrag genommen. Und erst danach gesehen, das es kein Adapter ist.
                                bimmi
                                #515
                                Ich hab mein Script etwas angepasst.
                                folgende Sachen kommen jetzt über websocket / tag.json mit
                                • hwType / Alias (Display Bezeichnung)
                                • height in px
                                • widht in px
                                • colors
                                • colortable (json um die richten Farben zu setzen für rot, schwarz, grau usw)
                                ein kleiner Fehler ist noch drin, aber das ändere ich evtl. heute Abend. Wäre schön wenn Ihr testen würdet und mir entsprechend ein issue auf github öffnen würdet!
                                Gruß Bimmi
                                • B bimmi
                                  • height in px
                                  • widht in px
                                  • colors
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  #516
                                  @bimmi
                                  Sollte, glaube ich, in einer der letzten Versionen implementiert worden sein: Update Anzeige.
                                  Find ich es nicht oder wie muss das eingestellt werden?
                                  Möchte gerne , vornehmlich oben rechts , angezeigt bekommen wann der Tag zuletzt aktualisiert worden ist .
                                  • haselchenH haselchen
                                    @bimmi
                                    bimmi
                                    #517
                                    @haselchen Es wird der timestamp im unix Format angezeigt. Musst du entsprechend umrechnen. Ich könnte das auch mit machen im Script
                                    Gruß Bimmi
                                    • B bimmi
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      #518
                                      @bimmi
                                      Da ich die Voreinstellungen nehme ( Wetter, Kalender…) , wie kriege ich das da mit rein ? 🤔
                                        @bimmi
                                        bimmi
                                        #519
                                        @haselchen das ist unabhängig von iobroker und wird ja über den ap gestellt.
                                        Das Skript ist nur zum Daten holen vom AP.
                                        Gruß Bimmi
                                        • B bimmi
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          #520
                                          @bimmi
                                          Wir wäre dann die Vorgehensweise für mein Vorhaben?
