  4. ioBroker update führt zu GLIBCXX_3.4.26-Problem - GELÖST!
92 Beiträge 5 Kommentatoren 19.3k Aufrufe 4 Beobachtet
  • R. FraseR R. Frase
    Oh, Verzeihung...
    sudo apt-get purge nodejs
    @r-frase
    Jein. Man passt seine Quelle an, in dem Fall die /etc/apt/sources.list.d/nodesource.list
    Trag da statt 20 eine 18 ein.
    Dann
    sudo apt update
    sudo apt install nodejs=18.16.0-deb-1nodesource1
    R. FraseR 1 Antwort Letzte Antwort
      @r-frase
      Dann
      sudo apt update
      R. FraseR Offline
      R. FraseR Offline
      R. Frase
      ... ich bin gerade dran... kleinen Moment bitte
        @r-frase
        curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
        R. FraseR Offline
        R. FraseR Offline
        R. Frase
        schrieb am zuletzt editiert von R. Frase
        @thomas-braun sagte in ioBroker update führt zu GLIBCXX_3.4.26-Problem:
        Jetzt hat das hier funktioniert:
        ======== Start marking the full check here =========
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Model           : Raspberry Pi 4 Model B Rev 1.1
        Architecture    : armv7l
        Docker          : false
        Virtualization  : none
        Distributor ID: Raspbian
        Description:    Raspbian GNU/Linux 10 (buster)
        Release:        10
        Codename:       buster
        PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="10"
        VERSION="10 (buster)"
        VERSION_CODENAME=buster
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        Systemuptime and Load:
         23:43:25 up  1:31,  1 user,  load average: 4.70, 3.45, 1.83
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        Other values than 0x0 hint to temperature/voltage problems
        temp=61.8'C
        volt=0.8625V
        *** Time and Time Zones ***
                       Local time: Wed 2023-06-21 23:43:36 CEST
                   Universal time: Wed 2023-06-21 21:43:36 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           1.9G        124M        834M        8.0M        913M        1.6G
        Swap:           99M          0B         99M
        Total:         2.0G        124M        934M
                 1872 M total memory
                  124 M used memory
                  238 M active memory
                  726 M inactive memory
                  834 M free memory
                  272 M buffer memory
                  641 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        lifetime oom required: 0 Mbytes
        total time in oom handler: 0 ms
        max time spent in oom handler: 0 ms
        *** FILESYSTEM ***
        /dev/root      ext4       29G  8.8G   20G  32% /
        devtmpfs       devtmpfs  776M     0  776M   0% /dev
        tmpfs          tmpfs     937M     0  937M   0% /dev/shm
        tmpfs          tmpfs     937M  8.6M  928M   1% /run
        tmpfs          tmpfs     937M     0  937M   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     188M     0  188M   0% /run/user/1000
        [Wed Jun 21 22:11:39 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:12:E3:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=8578e3fa-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait fsck.mode=force
        [Wed Jun 21 22:11:40 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Wed Jun 21 22:11:40 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Wed Jun 21 22:12:11 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        Show mounted filesystems (real ones only):
        TARGET        SOURCE         FSTYPE OPTIONS
        /             /dev/mmcblk0p2 ext4   rw,noatime
        |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
        `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        408M    /var/
        165M    /var/lib
        129M    /var/cache
        123M    /var/cache/apt
        69M     /var/lib/apt/lists
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        95M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        499M    /opt/iobroker/iobroker-data/
        341M    /opt/iobroker/iobroker-data/files
        96M     /opt/iobroker/iobroker-data/backup-objects
        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        51M     /opt/iobroker/iobroker-data/files/javascript.admin
        28M     /opt/iobroker/iobroker-data/objects.jsonl
        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
        12M     /opt/iobroker/iobroker-data/objects.json.migrated
        12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.16.0
        /home/pi/.nvm/versions/node/v16.13.0/bin/node           v16.13.0
        /home/pi/.nvm/versions/node/v16.13.0/bin/npm            8.1.0
        /home/pi/.nvm/versions/node/v16.13.0/bin/npx            8.1.0
        *** nodejs is NOT correctly installed ***
        nodejs:
          Installed: 18.16.0-deb-1nodesource1
          Candidate: 18.16.0-deb-1nodesource1
          Version table:
         *** 18.16.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u3 500
        find: '/opt/iobroker/node_modules': No such file or directory
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        node:internal/modules/cjs/loader:1078
          throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
            at Module._load (node:internal/modules/cjs/loader:920:27)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
            at node:internal/main/run_main_module:23:47 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
        Node.js v18.16.0
          throw err;
          requireStack: []
        Node.js v18.16.0
        Core adapters versions
          throw err;
          requireStack: []
        Node.js v18.16.0
        js-controller:
          throw err;
          requireStack: []
        Node.js v18.16.0
        admin:
          throw err;
          requireStack: []
        Node.js v18.16.0
        javascript:
        npm ERR! code ELSPROBLEMS
        npm ERR! missing: iobroker.accuweather@1.2.4, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.admin@6.3.5, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.alexa2@3.23.2, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.backitup@2.6.19, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.coronavirus-statistics@^0.8.7, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.cul@2.0.2, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.daswetter@3.1.8, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.deconz@1.3.21, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.discovery@3.1.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.dwd@2.8.3, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.feiertage@1.1.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.fhem@^1.6.3, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.firetv@1.0.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.fritzdect@2.2.6, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.fullybrowser@2.1.2, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.hue-extended@2.0.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.hue@3.7.1, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.ical@1.13.2, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.icons-addictive-flavour-png@0.1.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.icons-fatcow-hosting@0.1.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.icons-icons8@0.0.1, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.icons-material-png@0.1.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.icons-material-svg@0.1.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.icons-mfd-png@1.1.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.icons-mfd-svg@1.1.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.icons-open-icon-library-png@0.1.2, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.icons-ultimate-png@^1.0.1, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.iot@1.14.2, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.javascript@6.1.4, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.js-controller@4.0.24, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.mqtt@4.1.1, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.net-tools@0.2.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.octoprint@4.0.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.onvif@1.0.4, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.philips-tv@0.5.3, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.ping@1.5.3, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.plex@0.9.1, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.plexconnect@0.0.7, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.pollenflug@^1.0.6, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.scenes@2.3.9, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.simple-api@2.7.2, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.smartthings@0.0.4, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.socketio@4.2.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.spotify-premium@1.2.1, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.synology@2.1.13, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.tankerkoenig@^2.1.1, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.terminal@1.0.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.text2command@2.3.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.tr-064@4.2.18, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.trashschedule@2.2.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.tuya@3.14.2, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.upnp@1.0.21, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.virtualpowermeter@1.4.6, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.vis-bars@^0.1.4, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.vis-canvas-gauges@1.0.1, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.vis-colorpicker@1.2.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.vis-fancyswitch@1.1.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.vis-history@1.0.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.vis-hqwidgets@1.4.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.vis-icontwo@0.93.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.vis-inventwo@3.3.1, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.vis-jqui-mfd@1.0.12, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.vis-justgage@1.0.2, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.vis-material-advanced@1.7.2, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.vis-metro@1.2.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.vis-players@0.1.6, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.vis-rgraph@0.0.2, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.vis-timeandweather@1.2.2, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.vis@1.4.16, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.web@4.3.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.whatsapp-cmb@0.2.3, required by iobroker.inst@3.0.0
        npm ERR!     /home/pi/.npm/_logs/2023-06-21T21_43_48_180Z-debug.log
        Adapters from github:   0
        Adapter State
          throw err;
          requireStack: []
        Node.js v18.16.0
          throw err;
          requireStack: []
        Node.js v18.16.0
        ioBroker-Repositories
          throw err;
          requireStack: []
        Node.js v18.16.0
        Installed ioBroker-Instances
          throw err;
          requireStack: []
        Node.js v18.16.0
        Objects and States
        Objects:        0
        States:         0
        Hit:1 http://phoscon.de/apt/deconz buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 http://archive.raspberrypi.org/debian buster InRelease
        Hit:4 https://dl.yarnpkg.com/debian stable InRelease
        Reading package lists... Donecom/node_18.x buster InRelease
        Pending Updates: 0sts... 0%
        *** Listening Ports ***
        tcp        1      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       17991      361/deCONZ
        tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      999        19920      945/perl
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20894      864/sshd
        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       18004      361/deCONZ
        tcp        0      0 0.0.0.0:7072            0.0.0.0:*               LISTEN      999        19921      945/perl
        tcp6       0      0 :::22                   :::*                    LISTEN      0          20896      864/sshd
        tcp6       0      0 :::3000                 :::*                    LISTEN      109        21378      815/grafana-server
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18020      813/dhcpcd
        udp        0      0 0.0.0.0:38564           0.0.0.0:*                           108        14951      352/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14949      352/avahi-daemon: r
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15209      361/deCONZ
        udp6       0      0 :::546                  :::*                                0          18039      813/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        14950      352/avahi-daemon: r
        udp6       0      0 :::49470                :::*                                108        14952      352/avahi-daemon: r
        2023-06-21 20:11:26.179  - info: host.ioBroker instance system.adapter.fhem.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2023-06-21 20:11:26.180  - info: host.ioBroker instance system.adapter.hue-extended.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2023-06-21 20:11:26.211  - info: host.ioBroker instance system.adapter.smartthings.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2023-06-21 20:11:27.076  - info: host.ioBroker instance system.adapter.trashschedule.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2023-06-21 20:11:27.078  - info: host.ioBroker instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2023-06-21 20:11:27.078  - warn: host.ioBroker instance system.adapter.whatsapp-cmb.0 terminated due to SIGTERM
        2023-06-21 20:11:27.078  - info: host.ioBroker instance system.adapter.whatsapp-cmb.0 terminated with code null ()
        2023-06-21 20:11:27.190  - warn: host.ioBroker instance system.adapter.mqtt.0 terminated due to SIGTERM
        2023-06-21 20:11:27.190  - info: host.ioBroker instance system.adapter.mqtt.0 terminated with code null ()
        2023-06-21 20:11:27.191  - warn: host.ioBroker instance system.adapter.ping.0 terminated due to SIGTERM
        2023-06-21 20:11:27.191  - info: host.ioBroker instance system.adapter.ping.0 terminated with code null ()
        2023-06-21 20:11:27.191  - warn: host.ioBroker instance system.adapter.hue.0 terminated due to SIGTERM
        2023-06-21 20:11:27.192  - info: host.ioBroker instance system.adapter.hue.0 terminated with code null ()
        2023-06-21 20:11:27.285  - warn: host.ioBroker instance system.adapter.text2command.0 terminated due to SIGTERM
        2023-06-21 20:11:27.286  - info: host.ioBroker instance system.adapter.text2command.0 terminated with code null ()
        2023-06-21 20:11:27.286  - warn: host.ioBroker instance system.adapter.web.0 terminated due to SIGTERM
        2023-06-21 20:11:27.286  - info: host.ioBroker instance system.adapter.web.0 terminated with code null ()
        2023-06-21 20:11:27.287  - warn: host.ioBroker instance system.adapter.tankerkoenig.0 terminated due to SIGTERM
        2023-06-21 20:11:27.287  - info: host.ioBroker instance system.adapter.tankerkoenig.0 terminated with code null ()
        2023-06-21 20:11:27.358  - warn: host.ioBroker instance system.adapter.net-tools.0 terminated due to SIGTERM
        2023-06-21 20:11:27.358  - info: host.ioBroker instance system.adapter.net-tools.0 terminated with code null ()
        2023-06-21 20:11:27.359  - info: host.ioBroker instance system.adapter.virtualpowermeter.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2023-06-21 20:11:28.046  - info: host.ioBroker instance system.adapter.tuya.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2023-06-21 20:11:28.047  - info: host.ioBroker All instances are stopped.
        2023-06-21 20:11:28.277  - info: host.ioBroker terminated
        iob diag has finished.
        Ich lese, dass der js-controller nicht zu lesen ist und die Adapter sind auch alle nicht erreichbar.
        Ach ja, die Zusammenfassung:
                             v.2023-04-16
        Operatingsystem:        Raspbian GNU/Linux 10 (buster)
        Kernel:                 5.10.103-v7l+
        Installation:           Native
        Timezone:               Europe/Berlin (CEST, +0200)
        User-ID:                1000
        X-Server:               false
        Pending OS-Updates:     0
          throw err;
          requireStack: []
        Node.js v18.16.0
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:           1.9G        124M        859M        8.0M        887M        1.6G
        Swap:           99M          0B         99M
        Total:         2.0G        124M        959M
          throw err;
          requireStack: []
        Node.js v18.16.0
        Active iob-Instances:   0
          throw err;
          requireStack: []
        Node.js v18.16.0
          throw err;
          requireStack: []
        Node.js v18.16.0
        ioBroker Core:          js-controller
          throw err;
          requireStack: []
        Node.js v18.16.0
                                admin
          throw err;
          requireStack: []
        Node.js v18.16.0
        ioBroker Status:
          throw err;
          requireStack: []
        Node.js v18.16.0
        Objects:                0
        States:                 0
        Size of iob-Database:
        7.0M    /opt/iobroker/iobroker-data/states.jsonl
        2.8M    /opt/iobroker/iobroker-data/states.json.migrated
        2.8M    /opt/iobroker/iobroker-data/states.json.bak.migrated
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        10
          Codename:       buster
          VERSION_ID="10"
          ID=raspbian
          ID_LIKE=debian
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          temp=61.8'C
          volt=0.8625V
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           99M          0B         99M
                   1872 M total memory
                    124 M used memory
                    238 M active memory
                    834 M free memory
                    272 M buffer memory
                    641 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          408M    /var/
          165M    /var/lib
          129M    /var/cache
          123M    /var/cache/apt
          nodejs:
            Version table:
          ioBroker Status
            throw err;
            requireStack: []
          Node.js v18.16.0
            throw err;
            requireStack: []
          Node.js v18.16.0
            throw err;
            requireStack: []
          Node.js v18.16.0
          js-controller:
            throw err;
            requireStack: []
          Node.js v18.16.0
          admin:
            throw err;
            requireStack: []
          Node.js v18.16.0
          javascript:
          Adapter State
            throw err;
            requireStack: []
          Node.js v18.16.0
            throw err;
            requireStack: []
          Node.js v18.16.0
            throw err;
            requireStack: []
          Node.js v18.16.0
            throw err;
            requireStack: []
          Node.js v18.16.0
          Objects and States
          Objects:        0
          States:         0
                               v.2023-04-16
          User-ID:                1000
          X-Server:               false
            throw err;
            requireStack: []
          Node.js v18.16.0
          MEMORY:
          Swap:           99M          0B         99M
            throw err;
            requireStack: []
          Node.js v18.16.0
            throw err;
            requireStack: []
          Node.js v18.16.0
            throw err;
            requireStack: []
          Node.js v18.16.0
            throw err;
            requireStack: []
          Node.js v18.16.0
                                  admin
            throw err;
            requireStack: []
          Node.js v18.16.0
          ioBroker Status:
            throw err;
            requireStack: []
          Node.js v18.16.0
          Objects:                0
          States:                 0
          @r-frase sagte in ioBroker update führt zu GLIBCXX_3.4.26-Problem:
          Lass die Finger von wirren Installationen via nvm oder sonstigem Kram.
          Softwarepakete werden ausschließlich via Paketmanager gehandhabt. Gerade wenn man sich nicht auskennt.
          Lösch den Mist:
          rm -rf /home/pi/.nvm/
          Schlecht...
            Lösch den Mist:
            Schlecht...
            R. FraseR Offline
            R. FraseR Offline
            R. Frase
            Lösch den Mist:
            Schlecht...
            Lösch den Mist:
            okay... hab ich.
            Schlecht...
            das heißt ich hab ein echtes Problem?
              Lösch den Mist:
              Schlecht...
              Lösch den Mist:
              okay... hab ich.
              Schlecht...
              Möglicherweise.
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller
              iob start
                Möglicherweise.
                cd /opt/iobroker
                iob start
                R. FraseR Offline
                R. FraseR Offline
                R. Frase
                Die Installation läuft gerade...
                Nebenbei: Der Ordner /opt/iobroker/node_modules_ existiert und ist gefüllt.
                  Rühr da jetzt nicht drin rum!!
                    R. FraseR Offline
                    R. FraseR Offline
                    R. Frase
                    Oh nein - ganz sicher nicht!!! 😨
                    Die Installation bleibt bei 470k bis 540k ms... das dauert wohl eine Weile
                      @r-frase
                      Sooooo lange sollte das eigentlich auch nicht dauern.
                      uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      sagt?
                        @r-frase
                        sagt?
                        R. FraseR Offline
                        R. FraseR Offline
                        R. Frase
                        Das sieht aus, als ob alle Module neu heruntergeladen und installiert werden.
                        Ich kann es leider nicht kopieren, weil das durch die aktualisierten ms-Zahlen verhindert wird.
                        unter anderem kamen einige npm WARN deprecated Warnungen.
                        darunter reify:localform und reify localforage bzgl. der Module.
                        Im Moment läuft die Schätzung auf über 900k ms und ich erhalte die nächste Eingabemöglichkeit bestimmt erst, wenn der Raspi fertig ist
                          Zweite Terminal-Session? Hat man i.d.R. eh mindestens zwei von offen.
                            R. FraseR Offline
                            R. FraseR Offline
                            R. Frase
                            Ich komme üblicherweise mit einer durchs Leben 😇 - aber okay, ich versuche es!
                            Die zweite Session reagiert nicht - der Raspi ist wohl zu beschäftigt 🙄
                            ... doch, ich konnte mich anmelden. Es dauert leider...
                            ich konnte
                            eben eingeben... der Raspi arbeitet gerade an der Antwort
                            Zumindest bremst es den Raspi so aus, dass ich aus der anderen Session eine Kopie extrahieren kann:
                            reify:iobroker.iot: timing reifyNode:node_modules/iobroker.vis-icontwo Completed in 1773824ms
                              ich konnte
                              Sind ganz normale Meldungen, wenn die Module neugebaut werden.
                                R. FraseR Offline
                                R. FraseR Offline
                                R. Frase
                                Ich habe Hoffnung!
                                  Ich habe Hoffnung!
                                  @r-frase
                                  Wobei ich zugeben muss, dass es nicht die brillianteste Idee von mir war, auf einen 2GB-RAM Raspberry auch noch die ganzen apt aktionen parallel drauf zu werfen... Und das gleich im Doppeldecker...
                                  Brauchst halt was Geduld jetzt. Kann sein das die Kiste die Nacht dazu braucht.
                                    @r-frase
                                    R. FraseR Offline
                                    R. FraseR Offline
                                    R. Frase
                                    Ich kenne die Sprache nicht in der Du schreibst, weil es bei mir mit Turbo-Pascal aufgehört hat. Hinter mir liegt ein Buch zur Einführung in PERL, weil ich mich grundsätzlich gerne mit Dingen auseinandersetze die einen Anreiz haben. In groben Zügen verstehe ich das über die ersten 30 Seiten (ich hab auch erst angefangen...)
                                    Sollte es die ganze Nacht dauern bin ich in jedem Fall schon sehr viel weiter als bevor ich mich hier gemeldet habe!
                                    Ich kann mich also morgen wieder melden - dann bekommen wir alle auch etwas Schlaf. Vielen lieben Dank schonmal!
                                      @r-frase
                                      Knall den zweiten Prozess mal mit Strg-C weg.
                                      sollte dann aber flugs durch laufen.
                                        @r-frase
                                        R. FraseR Offline
                                        R. FraseR Offline
                                        R. Frase
                                        @r-frase
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        /usr/bin/npx
                                        v18.16.0
                                        v18.16.0
                                        9.5.1
                                        9.5.1
                                          @r-frase
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          /usr/bin/npx
                                          v18.16.0
                                          v18.16.0
                                          9.5.1
                                          9.5.1
                                          @r-frase
                                          Ja, das sieht gut aus.
