  4. ioBroker update führt zu GLIBCXX_3.4.26-Problem - GELÖST!
92 Beiträge 5 Kommentatoren 19.3k Aufrufe 4 Beobachtet
  • R. FraseR R. Frase
    @thomas-braun sagte in ioBroker update führt zu GLIBCXX_3.4.26-Problem:
    curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
    Jetzt hat das hier funktioniert:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     23:43:25 up  1:31,  1 user,  load average: 4.70, 3.45, 1.83
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=61.8'C
    volt=0.8625V
    *** Time and Time Zones ***
                   Local time: Wed 2023-06-21 23:43:36 CEST
               Universal time: Wed 2023-06-21 21:43:36 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           1.9G        124M        834M        8.0M        913M        1.6G
    Swap:           99M          0B         99M
    Total:         2.0G        124M        934M
             1872 M total memory
              124 M used memory
              238 M active memory
              726 M inactive memory
              834 M free memory
              272 M buffer memory
              641 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       29G  8.8G   20G  32% /
    devtmpfs       devtmpfs  776M     0  776M   0% /dev
    tmpfs          tmpfs     937M     0  937M   0% /dev/shm
    tmpfs          tmpfs     937M  8.6M  928M   1% /run
    tmpfs          tmpfs     937M     0  937M   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     188M     0  188M   0% /run/user/1000
    [Wed Jun 21 22:11:39 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:12:E3:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=8578e3fa-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait fsck.mode=force
    [Wed Jun 21 22:11:40 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Wed Jun 21 22:11:40 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Wed Jun 21 22:12:11 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    408M    /var/
    165M    /var/lib
    129M    /var/cache
    123M    /var/cache/apt
    69M     /var/lib/apt/lists
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    95M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    499M    /opt/iobroker/iobroker-data/
    341M    /opt/iobroker/iobroker-data/files
    96M     /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    28M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    12M     /opt/iobroker/iobroker-data/objects.json.migrated
    12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /home/pi/.nvm/versions/node/v16.13.0/bin/node           v16.13.0
    /home/pi/.nvm/versions/node/v16.13.0/bin/npm            8.1.0
    /home/pi/.nvm/versions/node/v16.13.0/bin/npx            8.1.0
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    find: '/opt/iobroker/node_modules': No such file or directory
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    node:internal/modules/cjs/loader:1078
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
        at Module._load (node:internal/modules/cjs/loader:920:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
        at node:internal/main/run_main_module:23:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Node.js v18.16.0
      throw err;
      requireStack: []
    Node.js v18.16.0
    Core adapters versions
      throw err;
      requireStack: []
    Node.js v18.16.0
    js-controller:
      throw err;
      requireStack: []
    Node.js v18.16.0
    admin:
      throw err;
      requireStack: []
    Node.js v18.16.0
    javascript:
    npm ERR! code ELSPROBLEMS
    npm ERR! missing: iobroker.accuweather@1.2.4, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.admin@6.3.5, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.alexa2@3.23.2, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.backitup@2.6.19, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.coronavirus-statistics@^0.8.7, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.cul@2.0.2, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.daswetter@3.1.8, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.deconz@1.3.21, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.discovery@3.1.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.dwd@2.8.3, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.feiertage@1.1.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.fhem@^1.6.3, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.firetv@1.0.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.fritzdect@2.2.6, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.fullybrowser@2.1.2, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.hue-extended@2.0.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.hue@3.7.1, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.ical@1.13.2, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.icons-addictive-flavour-png@0.1.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.icons-fatcow-hosting@0.1.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.icons-icons8@0.0.1, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.icons-material-png@0.1.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.icons-material-svg@0.1.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.icons-mfd-png@1.1.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.icons-mfd-svg@1.1.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.icons-open-icon-library-png@0.1.2, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.icons-ultimate-png@^1.0.1, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.iot@1.14.2, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.javascript@6.1.4, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.js-controller@4.0.24, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.mqtt@4.1.1, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.net-tools@0.2.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.octoprint@4.0.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.onvif@1.0.4, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.philips-tv@0.5.3, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.ping@1.5.3, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.plex@0.9.1, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.plexconnect@0.0.7, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.pollenflug@^1.0.6, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.scenes@2.3.9, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.simple-api@2.7.2, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.smartthings@0.0.4, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.socketio@4.2.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.spotify-premium@1.2.1, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.synology@2.1.13, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.tankerkoenig@^2.1.1, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.terminal@1.0.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.text2command@2.3.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.tr-064@4.2.18, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.trashschedule@2.2.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.tuya@3.14.2, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.upnp@1.0.21, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.virtualpowermeter@1.4.6, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.vis-bars@^0.1.4, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.vis-canvas-gauges@1.0.1, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.vis-colorpicker@1.2.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.vis-fancyswitch@1.1.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.vis-history@1.0.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.vis-hqwidgets@1.4.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.vis-icontwo@0.93.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.vis-inventwo@3.3.1, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.vis-jqui-mfd@1.0.12, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.vis-justgage@1.0.2, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.vis-material-advanced@1.7.2, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.vis-metro@1.2.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.vis-players@0.1.6, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.vis-rgraph@0.0.2, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.vis-timeandweather@1.2.2, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.vis@1.4.16, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.web@4.3.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.whatsapp-cmb@0.2.3, required by iobroker.inst@3.0.0
    npm ERR!     /home/pi/.npm/_logs/2023-06-21T21_43_48_180Z-debug.log
    Adapters from github:   0
    Adapter State
      throw err;
      requireStack: []
    Node.js v18.16.0
      throw err;
      requireStack: []
    Node.js v18.16.0
    ioBroker-Repositories
      throw err;
      requireStack: []
    Node.js v18.16.0
    Installed ioBroker-Instances
      throw err;
      requireStack: []
    Node.js v18.16.0
    Objects and States
    Objects:        0
    States:         0
    Hit:1 http://phoscon.de/apt/deconz buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 http://archive.raspberrypi.org/debian buster InRelease
    Hit:4 https://dl.yarnpkg.com/debian stable InRelease
    Reading package lists... Donecom/node_18.x buster InRelease
    Pending Updates: 0sts... 0%
    *** Listening Ports ***
    tcp        1      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       17991      361/deCONZ
    tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      999        19920      945/perl
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20894      864/sshd
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       18004      361/deCONZ
    tcp        0      0 0.0.0.0:7072            0.0.0.0:*               LISTEN      999        19921      945/perl
    tcp6       0      0 :::22                   :::*                    LISTEN      0          20896      864/sshd
    tcp6       0      0 :::3000                 :::*                    LISTEN      109        21378      815/grafana-server
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18020      813/dhcpcd
    udp        0      0 0.0.0.0:38564           0.0.0.0:*                           108        14951      352/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14949      352/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15209      361/deCONZ
    udp6       0      0 :::546                  :::*                                0          18039      813/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        14950      352/avahi-daemon: r
    udp6       0      0 :::49470                :::*                                108        14952      352/avahi-daemon: r
    2023-06-21 20:11:26.179  - info: host.ioBroker instance system.adapter.fhem.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-06-21 20:11:26.180  - info: host.ioBroker instance system.adapter.hue-extended.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-06-21 20:11:26.211  - info: host.ioBroker instance system.adapter.smartthings.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-06-21 20:11:27.076  - info: host.ioBroker instance system.adapter.trashschedule.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-06-21 20:11:27.078  - info: host.ioBroker instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-06-21 20:11:27.078  - warn: host.ioBroker instance system.adapter.whatsapp-cmb.0 terminated due to SIGTERM
    2023-06-21 20:11:27.078  - info: host.ioBroker instance system.adapter.whatsapp-cmb.0 terminated with code null ()
    2023-06-21 20:11:27.190  - warn: host.ioBroker instance system.adapter.mqtt.0 terminated due to SIGTERM
    2023-06-21 20:11:27.190  - info: host.ioBroker instance system.adapter.mqtt.0 terminated with code null ()
    2023-06-21 20:11:27.191  - warn: host.ioBroker instance system.adapter.ping.0 terminated due to SIGTERM
    2023-06-21 20:11:27.191  - info: host.ioBroker instance system.adapter.ping.0 terminated with code null ()
    2023-06-21 20:11:27.191  - warn: host.ioBroker instance system.adapter.hue.0 terminated due to SIGTERM
    2023-06-21 20:11:27.192  - info: host.ioBroker instance system.adapter.hue.0 terminated with code null ()
    2023-06-21 20:11:27.285  - warn: host.ioBroker instance system.adapter.text2command.0 terminated due to SIGTERM
    2023-06-21 20:11:27.286  - info: host.ioBroker instance system.adapter.text2command.0 terminated with code null ()
    2023-06-21 20:11:27.286  - warn: host.ioBroker instance system.adapter.web.0 terminated due to SIGTERM
    2023-06-21 20:11:27.286  - info: host.ioBroker instance system.adapter.web.0 terminated with code null ()
    2023-06-21 20:11:27.287  - warn: host.ioBroker instance system.adapter.tankerkoenig.0 terminated due to SIGTERM
    2023-06-21 20:11:27.287  - info: host.ioBroker instance system.adapter.tankerkoenig.0 terminated with code null ()
    2023-06-21 20:11:27.358  - warn: host.ioBroker instance system.adapter.net-tools.0 terminated due to SIGTERM
    2023-06-21 20:11:27.358  - info: host.ioBroker instance system.adapter.net-tools.0 terminated with code null ()
    2023-06-21 20:11:27.359  - info: host.ioBroker instance system.adapter.virtualpowermeter.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-06-21 20:11:28.046  - info: host.ioBroker instance system.adapter.tuya.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-06-21 20:11:28.047  - info: host.ioBroker All instances are stopped.
    2023-06-21 20:11:28.277  - info: host.ioBroker terminated
    iob diag has finished.
    Ich lese, dass der js-controller nicht zu lesen ist und die Adapter sind auch alle nicht erreichbar.
    Ach ja, die Zusammenfassung:
                         v.2023-04-16
    Operatingsystem:        Raspbian GNU/Linux 10 (buster)
    Kernel:                 5.10.103-v7l+
    Installation:           Native
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
      throw err;
      requireStack: []
    Node.js v18.16.0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:           1.9G        124M        859M        8.0M        887M        1.6G
    Swap:           99M          0B         99M
    Total:         2.0G        124M        959M
      throw err;
      requireStack: []
    Node.js v18.16.0
    Active iob-Instances:   0
      throw err;
      requireStack: []
    Node.js v18.16.0
      throw err;
      requireStack: []
    Node.js v18.16.0
    ioBroker Core:          js-controller
      throw err;
      requireStack: []
    Node.js v18.16.0
                            admin
      throw err;
      requireStack: []
    Node.js v18.16.0
    ioBroker Status:
      throw err;
      requireStack: []
    Node.js v18.16.0
    Objects:                0
    States:                 0
    Size of iob-Database:
    7.0M    /opt/iobroker/iobroker-data/states.jsonl
    2.8M    /opt/iobroker/iobroker-data/states.json.migrated
    2.8M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    @r-frase sagte in ioBroker update führt zu GLIBCXX_3.4.26-Problem:
    Lass die Finger von wirren Installationen via nvm oder sonstigem Kram.
    Softwarepakete werden ausschließlich via Paketmanager gehandhabt. Gerade wenn man sich nicht auskennt.
    Lösch den Mist:
    rm -rf /home/pi/.nvm/
    Schlecht...
    R. FraseR 1 Antwort Letzte Antwort
      Lösch den Mist:
      Schlecht...
      R. FraseR Offline
      R. FraseR Offline
      R. Frase
      Lösch den Mist:
      Schlecht...
      Lösch den Mist:
      okay... hab ich.
      Schlecht...
      das heißt ich hab ein echtes Problem?
        Lösch den Mist:
        Schlecht...
        Lösch den Mist:
        okay... hab ich.
        Schlecht...
        Möglicherweise.
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
        iob start
          Möglicherweise.
          cd /opt/iobroker
          iob start
          R. FraseR Offline
          R. FraseR Offline
          R. Frase
          Die Installation läuft gerade...
          Nebenbei: Der Ordner /opt/iobroker/node_modules_ existiert und ist gefüllt.
            Rühr da jetzt nicht drin rum!!
              R. FraseR Offline
              R. FraseR Offline
              R. Frase
              schrieb am zuletzt editiert von R. Frase
              Oh nein - ganz sicher nicht!!! 😨
              Die Installation bleibt bei 470k bis 540k ms... das dauert wohl eine Weile
                @r-frase
                Sooooo lange sollte das eigentlich auch nicht dauern.
                uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                sagt?
                  @r-frase
                  sagt?
                  R. FraseR Offline
                  R. FraseR Offline
                  R. Frase
                  Das sieht aus, als ob alle Module neu heruntergeladen und installiert werden.
                  Ich kann es leider nicht kopieren, weil das durch die aktualisierten ms-Zahlen verhindert wird.
                  unter anderem kamen einige npm WARN deprecated Warnungen.
                  darunter reify:localform und reify localforage bzgl. der Module.
                  Im Moment läuft die Schätzung auf über 900k ms und ich erhalte die nächste Eingabemöglichkeit bestimmt erst, wenn der Raspi fertig ist
                    Zweite Terminal-Session? Hat man i.d.R. eh mindestens zwei von offen.
                      R. FraseR Offline
                      R. FraseR Offline
                      R. Frase
                      Ich komme üblicherweise mit einer durchs Leben 😇 - aber okay, ich versuche es!
                      Die zweite Session reagiert nicht - der Raspi ist wohl zu beschäftigt 🙄
                      ... doch, ich konnte mich anmelden. Es dauert leider...
                      ich konnte
                      eben eingeben... der Raspi arbeitet gerade an der Antwort
                      Zumindest bremst es den Raspi so aus, dass ich aus der anderen Session eine Kopie extrahieren kann:
                      reify:iobroker.iot: timing reifyNode:node_modules/iobroker.vis-icontwo Completed in 1773824ms
                        ich konnte
                        Sind ganz normale Meldungen, wenn die Module neugebaut werden.
                          R. FraseR Offline
                          R. FraseR Offline
                          R. Frase
                          Ich habe Hoffnung!
                            Ich habe Hoffnung!
                            @r-frase
                            Wobei ich zugeben muss, dass es nicht die brillianteste Idee von mir war, auf einen 2GB-RAM Raspberry auch noch die ganzen apt aktionen parallel drauf zu werfen... Und das gleich im Doppeldecker...
                            Brauchst halt was Geduld jetzt. Kann sein das die Kiste die Nacht dazu braucht.
                              @r-frase
                              R. FraseR Offline
                              R. FraseR Offline
                              R. Frase
                              Ich kenne die Sprache nicht in der Du schreibst, weil es bei mir mit Turbo-Pascal aufgehört hat. Hinter mir liegt ein Buch zur Einführung in PERL, weil ich mich grundsätzlich gerne mit Dingen auseinandersetze die einen Anreiz haben. In groben Zügen verstehe ich das über die ersten 30 Seiten (ich hab auch erst angefangen...)
                              Sollte es die ganze Nacht dauern bin ich in jedem Fall schon sehr viel weiter als bevor ich mich hier gemeldet habe!
                              Ich kann mich also morgen wieder melden - dann bekommen wir alle auch etwas Schlaf. Vielen lieben Dank schonmal!
                                @r-frase
                                Knall den zweiten Prozess mal mit Strg-C weg.
                                sollte dann aber flugs durch laufen.
                                  @r-frase
                                  R. FraseR Offline
                                  R. FraseR Offline
                                  R. Frase
                                  @r-frase
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  /usr/bin/npx
                                  v18.16.0
                                  v18.16.0
                                  9.5.1
                                  9.5.1
                                    @r-frase
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    /usr/bin/npx
                                    v18.16.0
                                    v18.16.0
                                    9.5.1
                                    9.5.1
                                    @r-frase
                                    Ja, das sieht gut aus.
                                      @r-frase
                                      R. FraseR Offline
                                      R. FraseR Offline
                                      R. Frase
                                      @r-frase
                                      armv7l
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      /usr/bin/npx
                                      v18.16.0
                                      v18.16.0
                                      9.5.1
                                      9.5.1
                                      4.0.24
                                      pi
                                      /home/pi
                                      ^C
                                      ... das hat der Raspi bis dahin geschafft
                                        @r-frase
                                        armv7l
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        /usr/bin/npx
                                        v18.16.0
                                        v18.16.0
                                        9.5.1
                                        9.5.1
                                        4.0.24
                                        pi
                                        /home/pi
                                        ^C
                                        Und damit war das Kistlein dann überfordert:
                                        2x apt update ist bei 2GB RAM und parallel laufendem rebuild vom ioBroker ein wenig heftig. Hatte ich nicht dran gedacht...
                                        R. FraseR 2 Antworten Letzte Antwort
                                          R. FraseR Offline
                                          R. FraseR Offline
                                          R. Frase
                                          ich werde Dir in jedem Fall verzeihen!
