  4. Folder anlegen unter mqtt.1.
    3.2k
77 Beiträge 6 Kommentatoren 11.0k Aufrufe 4 Beobachtet
  • Sven SchumacherS Sven Schumacher
    @marc-berg
    Ich habe jetzt alles wieder auf Werkseinstellungen stehen. Also ohne das DTU vorne dran. Ich benutze die Instanz ja ausschließlich für den Wechselrichter und da muss ich das nicht unbedingt komplizierter machen.
    Das Logfile sagt:
    mqtt.1
    2023-06-01 09:10:12.501	info	Client [OpenDTU-11820156] subscribes on "/+/cmd/restart" with regex /mqtt\.1\.[^.]*\.cmd\.restart/
    mqtt.1
    2023-06-01 09:10:12.500	info	Client [OpenDTU-11820156] subscribes on "/+/cmd/restart" with regex /^[^\.]*\.cmd\.restart/
    mqtt.1
    2023-06-01 09:10:12.498	info	Client [OpenDTU-11820156] subscribes on "/+/cmd/power" with regex /mqtt\.1\.[^.]*\.cmd\.power/
    mqtt.1
    2023-06-01 09:10:12.497	info	Client [OpenDTU-11820156] subscribes on "/+/cmd/power" with regex /^[^\.]*\.cmd\.power/
    mqtt.1
    2023-06-01 09:10:12.491	info	Client [OpenDTU-11820156] subscribes on "/+/cmd/limit_nonpersistent_absolute" with regex /mqtt\.1\.[^.]*\.cmd\.limit_nonpersistent_absolute/
    mqtt.1
    2023-06-01 09:10:12.490	info	Client [OpenDTU-11820156] subscribes on "/+/cmd/limit_nonpersistent_absolute" with regex /^[^\.]*\.cmd\.limit_nonpersistent_absolute/
    mqtt.1
    2023-06-01 09:10:12.488	info	Client [OpenDTU-11820156] subscribes on "/+/cmd/limit_nonpersistent_relative" with regex /mqtt\.1\.[^.]*\.cmd\.limit_nonpersistent_relative/
    mqtt.1
    2023-06-01 09:10:12.487	info	Client [OpenDTU-11820156] subscribes on "/+/cmd/limit_nonpersistent_relative" with regex /^[^\.]*\.cmd\.limit_nonpersistent_relative/
    mqtt.1
    2023-06-01 09:10:12.484	info	Client [OpenDTU-11820156] subscribes on "/+/cmd/limit_persistent_absolute" with regex /mqtt\.1\.[^.]*\.cmd\.limit_persistent_absolute/
    mqtt.1
    2023-06-01 09:10:12.482	info	Client [OpenDTU-11820156] subscribes on "/+/cmd/limit_persistent_absolute" with regex /^[^\.]*\.cmd\.limit_persistent_absolute/
    mqtt.1
    2023-06-01 09:10:12.478	info	Client [OpenDTU-11820156] subscribes on "/+/cmd/limit_persistent_relative" with regex /mqtt\.1\.[^.]*\.cmd\.limit_persistent_relative/
    mqtt.1
    2023-06-01 09:10:12.477	info	Client [OpenDTU-11820156] subscribes on "/+/cmd/limit_persistent_relative" with regex /^[^\.]*\.cmd\.limit_persistent_relative/
    Und angelegt ist eben [seriennummer]/cmd/...
    Was ich nicht sehen kann ist, ob die Abfrage aus dem Logfile funktioniert.
    subscribes on "/+/cmd/limit_nonpersistent_absolute" with regex /mqtt.1.[^.]*.cmd.limit_nonpersistent_absolute/
    Wo könnte ich testweise so etwas eingeben um zu sehen ob ich das Topic dann bekomme?
    Marc BergM Offline
    Marc BergM Offline
    Marc Berg
    #61
    @sven-schumacher sagte in Folder anlegen unter mqtt.1.:
    Das sieht für mich irgenwdie falsch aus mit dem führenden "/", kann es aber gerade nicht belegen.
    Sven SchumacherS 1 Antwort Letzte Antwort
    • Marc BergM Marc Berg
      Sven SchumacherS Offline
      Sven Schumacher
      #62
      @marc-berg an dem Request kann ich aber auch nichts ändern.
      Wenn der wirklich falsch ist, dann muss das über eine neue Firmware repariert werden.
      Ich teste weiter und melde mich.
        Marc BergM Offline
        Marc BergM Offline
        Marc Berg
        #63
        @sven-schumacher
        Noch ein anderer Ansatz: In einem Issue steht vom Entwickler:
        Angenommen, es wurden mal (oder werden noch) Werte mit "retained" Flag durch den MQTT Adapter erzeugt, dann KÖNNTE das auch eine Ursache sein. Aber wenn du sagst, du hast alles auf Werkseinstellungen, dann ist das auch unwahrscheinlich.
          @sven-schumacher
          Sven Schumacher
          #64
          @marc-berg Ich sende nichts retained...
          Aber ich habe jetzt noch ein Phänomen unter MQQT-Explorer:
          Dort sind die Werte der openDTU nicht unter mqqt.1.* zu finden, sondern unter DTU.*
          Im Objektbaum stehen sie aber unter mqtt.1.*
          Ich hab da einfach noch ein Durcheinander. Ich werde die Instanz und die Datenobjekte auch noch einmal löschen und neu anlegen. An dem vermurksten Kram weiter zu basteln verschwendet sonst meine und eure Zeit.
          Wenn ich alle neu angelegt habe, mit Default-Werten, melde ich mich. Das wird heute aber nichts mehr.
            Marc BergM Offline
            Marc BergM Offline
            Marc Berg
            #65
            Ne, das passt schon. Die MQTT Topics fangen unterhalb der Instanz "mqtt.1." an.
            Aber "alles löschen und neu machen" wäre jetzt auch mein Gedanke.
              Sven Schumacher
              #66
              @marc-berg
              Hat mir keine Ruhe gelassen.
              die Werte werden jetzt in die richtigen Topics geschrieben. Rechts sieht man das beim MQTT-Explorer.
              Juckt aber weiterhin niemanden am anderen Ende.
              Samson71S Marc BergM 2 Antworten Letzte Antwort
                @marc-berg
                Samson71S Offline
                Samson71S Offline
                Samson71
                #67
                @sven-schumacher
                Was ist mit den MQTT-Einstellungen in der GUI von OpenDTU?
                Markus
                Bitte beachten:
                • Samson71S Samson71
                  @sven-schumacher
                  Sven Schumacher
                  #68
                    @marc-berg
                    Marc BergM Offline
                    Marc BergM Offline
                    Marc Berg
                    #69
                    @sven-schumacher
                    mqtt.1
                    Das ist jetzt aber ohne "Base-Topic", richtig? Wenn ich das in meiner Umgebung mal so teste ("/+/topic"), dann bekomme ich keine Topics angezeigt. Ich würde sagen, ohne Base-Topic funktioniert die Subscription nicht. Sondern nur im Format "xx/+/yy"
                      @sven-schumacher
                      mqtt.1
                      Sven Schumacher
                      #70
                      @marc-berg Das ist eben default.
                      Nirgendwo steht, dass man ein basetopic braucht.
                      Jedenfalls nicht in der FAQ/WIKI zu openDTU
                      wenn ich ein basetopic anlege, dann fragt openDTU nach
                      "/basetopic/+/topic" also auch wieder mit führendem "/"
                        Marc BergM Offline
                        Marc BergM Offline
                        Marc Berg
                        #71
                        Mit führendem "/" bekomme ich keine funktionierende Subscription hin. Aber ich glaube, an der Stelle wart ihr schon, oder?
                          Samson71S Offline
                          Samson71S Offline
                          Samson71
                          #72
                          @marc-berg sagte in Folder anlegen unter mqtt.1.:
                          Stimmt. Und ich glaube auch immer noch, dass das nicht richtig/sauber ist.
                          Warum sehe ich dann in Deinem Screenshot das?
                          Markus
                          Bitte beachten:
                            Marc BergM Offline
                            Marc BergM Offline
                            Marc Berg
                            #73
                            In deinem Log steht aber was anderes:
                              Sven Schumacher
                              #74
                              @samson71 Das ist das alte log. Da hatte ich den / vorne noch nicht dran
                              Ohne den / legt die DTU die Toppics NICHT mit dem Basetopic an. Aber sie vergibt die Namen.
                              Wenn ich den / davor mache, stimmen die Namen UND das Topic.
                              es müsste ja nur EINEN geben, bei dem es geht und der mal was von sich posten kann.
                              Dann ließe sich das sicher sofort lösen, das Problem.
                                Marc BergM Offline
                                Marc BergM Offline
                                Marc Berg
                                #75
                                Dann mach ein Issue bei Github auf, da wird es sicher genug Experten zu dem Thema geben.
                                Eine schräge Idee habe ich noch: Gib' mal ein Basetopic (ohne führende oder angehängte /) an, dass nicht "DTU" heißt.
                                  Sven Schumacher
                                  #76
                                  @marc-berg
                                  Also ich habe es gerade noch Mal getestet:
                                  Basetopic "/" ist default. Dann legt er die Ordner direkt unter mqtt.1.* ab
                                  Basetopic "DTU/" kann ich anlegen. Dann legt er weiter die Ordner direkt unter mqtt.1.* ab, aber der Topic-Name enthält "DTU/" am Anfang.
                                  Basetopic "/DTU/" kann ich auch anlegen. Dann legt er die Ordner unter mqtt.1.DTU.* ab, aber der Topic-Name enthält ebenfalls "/DTU/" am Anfang.
                                  Mit allen drei Methoden habe ich dann den State für das limit angelegt. Keiner hat funktioniert. im MQTT-Explorer sehe ich aber, wenn ich Werte schreibe.
                                  Die openDTU legt selbst durchaus Werte mit Retain (Voreinstellung) ab, Aber ICH darf so keine Werte in Richtung DTU schicken. Das ist deren Privileg.
                                    Sven Schumacher
                                    #77
                                    @marc-berg Abschließend MUSS ein / sein.
                                    Habs eben mit "garten/" versucht und "/garten/" ... gleicher effekt.
