  5. Datenquelle ermitteln
26 Beiträge 4 Kommentatoren 3.1k Aufrufe 3 Beobachtet
  • mickymM Offline
    mickymM Offline
    mickym
    Ok hier nun meine NodeRed Lösung.
    Ich habe mal folgende Testdatenpunkte angelegt, damit das in etwa Deiner Struktur gleich kommt.
    Ich habe also die Enums genommen, die im System verankert sind. ;)
    Du siehst einmal ist der Raum Wohnzimmer, dann Bad.
           "id": "2df53e5d19a0cb01",
           "type": "ioBroker list",
           "z": "7e6af0015415146d",
           "name": "",
           "topic": "",
           "objType": "",
           "regex": "",
           "asArray": "false",
           "onlyIDs": "false",
           "withValues": "false",
           "x": 810,
           "y": 3180,
           "wires": [
                   "f8e6aad5dbd578ac"
           "id": "87bcd684e308ef6e",
           "type": "debug",
           "name": "Raum",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "payload",
           "targetType": "msg",
           "statusVal": "",
           "statusType": "auto",
           "x": 1170,
           "y": 3180,
           "wires": []
           "id": "f8e6aad5dbd578ac",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "$each(payload.enums,function($v, $k) {$contains($k,\"rooms\") ? $v})",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 990,
           "y": 3180,
           "wires": [
                   "87bcd684e308ef6e"
           "id": "ca329680d55789a4",
           "type": "ioBroker in",
           "name": "",
           "topic": "0_userdata.0.Test.Temperaturen.*.Temperatur",
           "payloadType": "value",
           "onlyack": "",
           "func": "all",
           "gap": "",
           "fireOnStart": "false",
           "outFormat": "MQTT",
           "x": 210,
           "y": 3180,
           "wires": [
                   "d81ce08693b81463"
           "id": "d81ce08693b81463",
           "type": "switch",
           "name": "",
           "property": "max",
           "propertyType": "flow",
           "rules": [
                   "t": "lt",
                   "v": "payload",
                   "vt": "msg"
                   "t": "null"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 470,
           "y": 3180,
           "wires": [
                   "6db8ef90a96693aa"
                   "6db8ef90a96693aa"
           "id": "6db8ef90a96693aa",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "max",
                   "pt": "flow",
                   "to": "payload",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 640,
           "y": 3180,
           "wires": [
                   "2df53e5d19a0cb01"
           "id": "1869413e4e017020",
           "type": "inject",
           "name": "reset",
           "props": [
                   "p": "reset",
                   "v": "true",
                   "vt": "bool"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "x": 470,
           "y": 3240,
           "wires": [
                   "e98b2e244eb334ee"
           "id": "e98b2e244eb334ee",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "delete",
                   "p": "max",
                   "pt": "flow"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 650,
           "y": 3240,
           "wires": [
    • mickymM Offline
      mickymM Offline
      mickym
      Ok und hier nun meine Blockly Lösung - mit JS - ermittelt den Raum aus der Objekt ID
       <variables>
         <variable id="ALTyF=LZs}rPzBcD(1^(">ID</variable>
         <variable id="b1|*w2/IBSZtltFBq[mt">Max</variable>
       </variables>
       <block type="procedures_defcustomreturn" id="9M;cS2116}Q=Cw,Bj614" x="87" y="-363">
         <mutation statements="false">
           <arg name="ID" varid="ALTyF=LZs}rPzBcD(1^("></arg>
         </mutation>
         <field name="NAME">getRoom</field>
         <field name="SCRIPT">dmFyIG9iaiA9IHt9Ow0Kb2JqLnNlYXJjaCA9IElEOw0Kb2JqLnJvb21zID0gZ2V0RW51bXMoJ3Jvb21zJyk7DQpyZXR1cm4gYXdhaXQganNvbmF0YUV4cHJlc3Npb24ob2JqLCIkLnJvb21zWyQkLnNlYXJjaCBpbiBtZW1iZXJzXS5uYW1lIik7</field>
       </block>
       <block type="variables_set" id="hT|PTjDQZc|bKu:?[[zb" x="87" y="-287">
         <field name="VAR" id="b1|*w2/IBSZtltFBq[mt">Max</field>
         <value name="VALUE">
           <block type="math_number" id="F05G|j80GCJgv+,@tW_@">
             <field name="NUM">-30</field>
           </block>
         </value>
         <next>
           <block type="on_ext" id="4}3oeeat{mVDhPWIv#$@">
             <mutation xmlns="http://www.w3.org/1999/xhtml" items="2"></mutation>
             <value name="OID0">
               <shadow type="field_oid" id="O_Hiq6qP6{;ZCo,39k`U">
                 <field name="oid">0_userdata.0.Test.Temperaturen.Bad.Temperatur</field>
               </shadow>
             </value>
             <value name="OID1">
               <shadow type="field_oid" id="0@$.bMAo[1#1/2mYKs8T">
                 <field name="oid">0_userdata.0.Test.Temperaturen.Wohnzimmer.Temperatur</field>
               </shadow>
             </value>
             <statement name="STATEMENT">
               <block type="controls_if" id="`yyEGE6E{M?~Pe}kF4YB">
                 <value name="IF0">
                   <block type="logic_compare" id="El:P_-DP4vlJJY={Fd/(">
                     <field name="OP">GT</field>
                     <value name="A">
                       <block type="on_source" id="FM-hrz1fFe+I2YfRZWY:">
                       </block>
                     </value>
                     <value name="B">
                       <block type="variables_get" id="zb(D$R30?UAw~A{O76r9">
                       </block>
                     </value>
                   </block>
                 </value>
                 <statement name="DO0">
                   <block type="variables_set" id="ipx(~jBY#t{IEa/1Mr@Z">
                       <block type="on_source" id="%G0r$1HCsZ3#[r!yrL4a">
                       </block>
                     </value>
                     <next>
                       <block type="debug" id="Wg8Ay#ioly{/fkOTH:_R">
                         <value name="TEXT">
                           <shadow type="text" id="!VL#h,d@zxcAl#6!0ut+">
                           </shadow>
                           <block type="procedures_callcustomreturn" id="YmgZHu$By;yP{|d}$XSE">
                             <mutation name="getRoom">
                               <arg name="ID"></arg>
                             </mutation>
                             <value name="ARG0">
                               <block type="on_source" id="UzY1~8w~z7.Xs#x9v;l1">
                                 <field name="ATTR">id</field>
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </next>
                   </block>
                 </statement>
               </block>
             </statement>
           </block>
         </next>
       </block>
      </xml>
      Der Reset wird momentan durch Neustart des Skripts gemacht. Aber das sollte ja kein Problem sein, das Maximum entsprechend zu setzen. Wenn ein Datenpunkt 2 Räumen zugeordnet ist, dann kommt ein Array mit beiden Räumen raus. ;)
      • mickymM Offline
        mickymM Offline
        mickym
        In beiden Lösungen habe ich auf Arrays und Listen verzichtet, da es ja nur darum geht, ob es ein neues Maximum gibt und das wird einmal in der Variablen gespeichert. ggf. könnte man das Maximum auch in einem Datenpunkt festhalten. Die Werte, die kein Maximum darstellen sind mE unwichtig.
        Das zyklische Auslesen aller Werte und speichern in Arrays kann man machen Ich bin davon kein Anhänger.
         <variables>
           <variable id="c|3E03D|}2G4$KV$KDcI">idsTemp</variable>
         </variables>
         <block type="procedures_defcustomreturn" id="9M;cS2116}Q=Cw,Bj614" x="-12" y="-362">
           </mutation>
         </block>
         <block type="variables_set" id="lsecKayOZ4=Vf/5EgJCm" x="-13" y="-288">
             <block type="math_number" id="e{A/ctXs0!;RsQl_8CBU">
             </block>
           </value>
           <next>
             <block type="variables_set" id="e|oEG20j1v?9MN[Ekgls">
               <field name="VAR" id="c|3E03D|}2G4$KV$KDcI">idsTemp</field>
                 <block type="lists_create_with" id="s/k[)5H$IS*+,-X`C.vj">
                   <value name="ADD0">
                     <block type="field_oid" id="59TZ(Xip0eevyJ+Nz#W[">
                     </block>
                   </value>
                   <value name="ADD1">
                     <block type="field_oid" id="QE7RX_:Zn@LO7PuoNdD*">
                     </block>
                   </value>
                 </block>
               </value>
               <next>
                 <block type="on_ext" id="a;ViTG!bb-pX.jTorvJ8">
                   <value name="OID0">
                     <shadow type="field_oid" id="i%1xDs6.nZ9wnp2aj.MM">
                     </shadow>
                     <block type="variables_get" id="E@Gr[#Bwaf=tinJNsv+T">
                     </block>
                   </value>
                     <block type="controls_forEach" id="8_xK-^laWl]^P}j::7mO">
                       <field name="VAR" id="ALTyF=LZs}rPzBcD(1^(">ID</field>
                       <value name="LIST">
                         <block type="variables_get" id="c/y];d@:x;IgX3T?fOR3">
                         </block>
                       </value>
                       <statement name="DO">
                           <value name="IF0">
                               <value name="A">
                                 <block type="get_value_var" id="@@uymSTw|kZqu.WZ:fs.">
                                   <value name="OID">
                                     <shadow type="text" id="`Gc7SE*~nsYba%DD$D`D">
                                       <field name="TEXT"></field>
                                     </shadow>
                                     <block type="variables_get" id="-!Y0v9V:jSN{KYT#),!m">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                 </block>
                               </value>
                             </block>
                           </value>
                                 <block type="get_value_var" id="Va7]-8]?5(d/GAUyT{!,">
                                   <value name="OID">
                                     <shadow type="text">
                                     </shadow>
                                     <block type="variables_get" id="j!GI7IU|Ri0M`gV`*tpg">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                 <block type="debug" id="M%1)Q#tj4Zn(,C`Na^Y_">
                                   <value name="TEXT">
                                     <shadow type="text" id=":@[;Kk#l)s]su?JioeuF">
                                     </shadow>
                                     <block type="variables_get" id="/vI;M`yL[0/o4jJa1153">
                                     </block>
                                   </value>
                                   <next>
                                       <value name="TEXT">
                                         </shadow>
                                           </mutation>
                                           <value name="ARG0">
                                             <block type="variables_get" id="U)I)Dcvbv7mJ%eMupUi=">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
           </next>
         </block>
        </xml>
        Wie gesagt ich präferiere die Lösung ohne Listen und damit das Ermitteln des Maximums mit den jeweils aktuell eintrudelnden Werten.
        L 2 Antworten Letzte Antwort
        • mickymM mickym
           <variables>
           </variables>
             </mutation>
           </block>
               </block>
             </value>
             <next>
                     <value name="ADD0">
                       </block>
                     </value>
                     <value name="ADD1">
                       </block>
                     </value>
                   </block>
                 </value>
                 <next>
                     <value name="OID0">
                       </shadow>
                       </block>
                     </value>
                         <value name="LIST">
                           </block>
                         </value>
                             <value name="IF0">
                                 <value name="A">
                                     <value name="OID">
                                       </shadow>
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <value name="B">
                                   </block>
                                 </value>
                               </block>
                             </value>
                                     <value name="OID">
                                       </shadow>
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <next>
                                     <value name="TEXT">
                                       </shadow>
                                       </block>
                                     </value>
                                     <next>
                                         <value name="TEXT">
                                           </shadow>
                                             </mutation>
                                             <value name="ARG0">
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                           </block>
                         </statement>
                       </block>
                     </statement>
                   </block>
                 </next>
               </block>
             </next>
           </block>
          </xml>
          Linedancer
          @mickym
          Auch dir vielen Dank für deine Lösungsvorschläge. Schau ich mir an.
          Ciao, Gerhard
          • mickymM mickym
             <variables>
             </variables>
               </mutation>
             </block>
                 </block>
               </value>
               <next>
                       <value name="ADD0">
                         </block>
                       </value>
                       <value name="ADD1">
                         </block>
                       </value>
                     </block>
                   </value>
                   <next>
                       <value name="OID0">
                         </shadow>
                         </block>
                       </value>
                           <value name="LIST">
                             </block>
                           </value>
                               <value name="IF0">
                                   <value name="A">
                                       <value name="OID">
                                         </shadow>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                                       <value name="OID">
                                         </shadow>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <next>
                                       <value name="TEXT">
                                         </shadow>
                                         </block>
                                       </value>
                                       <next>
                                           <value name="TEXT">
                                             </shadow>
                                               </mutation>
                                               <value name="ARG0">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </statement>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
            </xml>
            Linedancer
            So, die Lösung von @paul53 hab ich umgesetzt. Funktioniert so wie ich es mir vorgestellt habe. Danke dafür.
            Die Node Red Lösung von @mickym hab ich mir angeschaut, aber da ich (leider) immernoch kein wirkliche Erfahrung mit JavaScript habe, ist mir die reine Blockly Lösung näher. Trotzdem auch dir danke für deine Hilfe.
            Ciao, Gerhard
            • L Linedancer
              mickymM Offline
              mickymM Offline
              mickym
              @linedancer Na meine Blockly-Lösungen greifen halt auf den Raum zu, den Du direkt im Admin eingegeben hast und nicht über eigene Zuordnungen. Und ich dachte das war Dein Hauptziel. Deswegen hab ich halt das Blockly entsprechend mit einer JS Funktion erweitert.
