  4. Node-Red
  5. Node Red Modbus
    1.0k
Node Red Modbus
26 Beiträge 3 Kommentatoren 5.5k Aufrufe 2 Beobachtet
  • mickymM mickym
    @homoran ja ich bin sicher. Hatte ich unten schon mal geschrieben.
    Hier habe ich die Konvertierung hin und zurück gemacht:
    Und hier hatte ich das mit dem unsigned Int schon mal erwähnt: https://forum.iobroker.net/post/989556 und hier als ich es ausprobiert hatte: https://forum.iobroker.net/post/989554
           "id": "b2a1f09de6d12e90",
           "type": "inject",
           "z": "385f4b8d434f6005",
           "name": "",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "100.00",
           "payloadType": "num",
           "x": 170,
           "y": 2620,
           "wires": [
                   "1c12b45aa6c4adca"
           "id": "9bc9a74d1f455065",
           "type": "buffer-maker",
           "name": "",
           "specification": "spec",
           "specificationType": "ui",
           "items": [
                   "name": "item1",
                   "type": "floatbe",
                   "length": 1,
                   "dataType": "msg",
                   "data": "payload"
           "swap1": "",
           "swap2": "",
           "swap3": "",
           "swap1Type": "swap",
           "swap2Type": "swap",
           "swap3Type": "swap",
           "msgProperty": "payload",
           "msgPropertyType": "str",
           "x": 390,
           "y": 2600,
           "wires": [
                   "faea83afe6fa1bba",
                   "c39e4fa3f88efaed"
           "id": "c5411af36dbc6206",
           "type": "debug",
           "name": "Neues Array",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": true,
           "complete": "payload",
           "targetType": "msg",
           "statusVal": "payload",
           "statusType": "auto",
           "x": 770,
           "y": 2600,
           "wires": []
           "id": "7d49268d76c118b3",
           "type": "inject",
           "name": "",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "-100.00",
           "x": 170,
           "y": 2580,
           "wires": [
                   "1c12b45aa6c4adca"
           "id": "faea83afe6fa1bba",
           "type": "buffer-parser",
           "name": "",
           "data": "payload",
           "dataType": "msg",
           "items": [
                   "type": "uint16be",
                   "name": "item1",
                   "offset": 0,
                   "length": 1,
                   "offsetbit": 0,
                   "scale": "1",
                   "mask": ""
                   "type": "uint16be",
                   "name": "item2",
                   "offset": 2,
                   "length": 1,
                   "offsetbit": 0,
                   "scale": "1",
                   "mask": ""
           "swap1": "",
           "swap2": "",
           "swap3": "",
           "resultType": "value",
           "resultTypeType": "return",
           "multipleResult": false,
           "fanOutMultipleResult": false,
           "setTopic": true,
           "outputs": 1,
           "x": 570,
           "y": 2600,
           "wires": [
                   "c5411af36dbc6206",
                   "28e7d3b028dcf2ba"
           "id": "c310b522d6b2bc18",
           "type": "inject",
           "name": "",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "-1234.00",
           "x": 160,
           "y": 2700,
           "wires": [
                   "1c12b45aa6c4adca"
           "id": "c39e4fa3f88efaed",
           "type": "debug",
           "name": "buffer",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 550,
           "y": 2540,
           "wires": []
           "id": "31e68b28d89b17db",
           "type": "inject",
           "name": "",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "68001",
           "x": 170,
           "y": 2660,
           "wires": [
                   "1c12b45aa6c4adca"
           "id": "28e7d3b028dcf2ba",
           "name": "",
           "items": [
                   "name": "item1",
                   "type": "uint16be",
                   "length": 2,
                   "dataType": "msg",
                   "data": "payload"
           "swap1": "",
           "swap2": "",
           "swap3": "",
           "x": 770,
           "y": 2680,
           "wires": [
                   "423d2ba998b44648"
           "id": "d23882e23c0fe50c",
           "type": "debug",
           "name": "Rückkonvertierung",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 1150,
           "y": 2680,
           "wires": []
           "id": "423d2ba998b44648",
           "name": "",
           "data": "payload",
           "dataType": "msg",
           "items": [
                   "type": "floatbe",
                   "name": "item1",
                   "offset": 0,
                   "length": 1,
                   "offsetbit": 0,
                   "scale": "1",
                   "mask": ""
           "swap1": "",
           "swap2": "",
           "swap3": "",
           "multipleResult": true,
           "setTopic": false,
           "outputs": 1,
           "x": 950,
           "y": 2680,
           "wires": [
                   "d23882e23c0fe50c"
           "id": "9c99b46399646127",
           "type": "debug",
           "name": "Float- Eingabe",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 400,
           "y": 2660,
           "wires": []
           "id": "1c12b45aa6c4adca",
           "type": "junction",
           "x": 280,
           "y": 2620,
           "wires": [
                   "9bc9a74d1f455065",
                   "9c99b46399646127"
    Garf
    schrieb am zuletzt editiert von Garf
    @mickym
    Kein Problem. Ist doch schnell umgestellt. Und das Ergebnis auch schnell zu sehen.
    Jetzt fällt es mir auch wieder ein. Ja dass hattest Du auch schon mal geschrieben, du Fuchs. 👍
    Jetzt passt es und die drei Varianten laufen auch bei Minuswerten im Gleichschritt. Super Danke nochmal dafür.
    • mickymM mickym
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "x": 170,
             "y": 2620,
             "wires": [
                     "1c12b45aa6c4adca"
             "name": "",
             "items": [
                     "name": "item1",
                     "type": "floatbe",
                     "length": 1,
                     "dataType": "msg",
                     "data": "payload"
             "swap1": "",
             "swap2": "",
             "swap3": "",
             "x": 390,
             "y": 2600,
             "wires": [
                     "faea83afe6fa1bba",
                     "c39e4fa3f88efaed"
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": true,
             "x": 770,
             "y": 2600,
             "wires": []
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "x": 170,
             "y": 2580,
             "wires": [
                     "1c12b45aa6c4adca"
             "name": "",
             "data": "payload",
             "dataType": "msg",
             "items": [
                     "type": "uint16be",
                     "name": "item1",
                     "offset": 0,
                     "length": 1,
                     "offsetbit": 0,
                     "scale": "1",
                     "mask": ""
                     "type": "uint16be",
                     "name": "item2",
                     "offset": 2,
                     "length": 1,
                     "offsetbit": 0,
                     "scale": "1",
                     "mask": ""
             "swap1": "",
             "swap2": "",
             "swap3": "",
             "setTopic": true,
             "outputs": 1,
             "x": 570,
             "y": 2600,
             "wires": [
                     "c5411af36dbc6206",
                     "28e7d3b028dcf2ba"
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "x": 160,
             "y": 2700,
             "wires": [
                     "1c12b45aa6c4adca"
             "type": "debug",
             "name": "buffer",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 550,
             "y": 2540,
             "wires": []
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "68001",
             "x": 170,
             "y": 2660,
             "wires": [
                     "1c12b45aa6c4adca"
             "name": "",
             "items": [
                     "name": "item1",
                     "type": "uint16be",
                     "length": 2,
                     "dataType": "msg",
                     "data": "payload"
             "swap1": "",
             "swap2": "",
             "swap3": "",
             "x": 770,
             "y": 2680,
             "wires": [
                     "423d2ba998b44648"
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 1150,
             "y": 2680,
             "wires": []
             "name": "",
             "data": "payload",
             "dataType": "msg",
             "items": [
                     "type": "floatbe",
                     "name": "item1",
                     "offset": 0,
                     "length": 1,
                     "offsetbit": 0,
                     "scale": "1",
                     "mask": ""
             "swap1": "",
             "swap2": "",
             "swap3": "",
             "setTopic": false,
             "outputs": 1,
             "x": 950,
             "y": 2680,
             "wires": [
                     "d23882e23c0fe50c"
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 400,
             "y": 2660,
             "wires": []
             "type": "junction",
             "x": 280,
             "y": 2620,
             "wires": [
                     "9bc9a74d1f455065",
                     "9c99b46399646127"
      Garf
      @mickym
      Ich schon wieder. Heute wieder eine neue Herausforderung. Und wieder der buffer parser, der mich zur Verzweiflung bringt.
      Jetzt gilt es die signed Integerwerte an den Regler zu senden. Also erst einmal wieder die Werte vom Regler in drei Modbusregister schreiben lassen.
      0 = 0
      1 = 1
      -1 = 65535
      Gut die ersten beiden Zahlen soweit kein Problem. Bei der -1 geht das Gedöns wieder los. Kriege es mit dem buffer parser wieder nicht hin. Rechne ich mit der Formel von Steve und fasse die Werte aus dem Buffer Maker zusamen, kommt der Wert 65535 raus.
      Klar jetzt könnte man aus der -1 einfach eine 2 machen und schon hätte man die Aufgabe elegant umgangen. Aber einfach kann jeder. Außerdem so lernt man ja nichts.
      Ich bin schon wieder auf deine Antwort gespannt. Vielleicht kapiere ich es dann auch irgendwann noch mal.
      Ach ja, mit den Werten -1, 0, 1 beschreibt der WR seinen Betriebszustand, Ausgeschaltet, Standby, Betrieb.
      • G Garf
        @mickym
        0 = 0
        1 = 1
        -1 = 65535
        mickymM Online
        mickymM Online
        mickym
        @garf Hier kann ich 2 Anmerkungen machen.
        1. Wenn Du bereits Integer hast, kannst Du der Parser-Node einfach ein signed Integer-Array übergeben und musst nicht über den Umweg eines Buffers gehen (mit Einzelbytes).
        Siehst Du in der Hilfe zur Parser Node:
        Das heißt bei signed Integer musst Du nicht über den Buffer Maker gehen. Du musst Deinen signed Integer nur in ein Array packen.
        Das ist der untere Weg.
        Für Dein Modbus Array - gibst Du IMMER - egal ob Du einen Buffer hast oder eine 16bint Integer-Array hast - einen unsigned 16bit Integer aus bzw. ein Array von unsigned 16bit Integers.
        1. Wenn Du keinen signed Integer hast, dann musst Du erst über einen Buffer gehen (hier ist es optional). Und hier (und nicht im Parser) gibst Du vor ,wie die Eingabe zu interpretieren ist.
          Sprich hier gibst Du ein, dass die Eingabe als signed 16 Bit Integer ist.
        Sprich Deine Modbus-Register (Array) werden IMMER mit UNISIGNED 16 Bit Integer beschrieben. Das gilt für 1 und 2.
        Da der BufferParser grundsätzlich mit Int16 gefüttert werden kann, musst bei der Rückkonvertierung Du dann nur wieder angeben, wie diese unsigned Modbus Integers zu interpretieren sind.
               "id": "89afe07090940215",
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "1",
               "x": 190,
               "y": 3760,
               "wires": [
                       "a1295e30a331a22d"
               "id": "6428a78309e813d1",
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "0",
               "x": 190,
               "y": 3800,
               "wires": [
                       "a1295e30a331a22d"
               "id": "4361c6fff1762f7e",
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "-1",
               "x": 190,
               "y": 3840,
               "wires": [
                       "a1295e30a331a22d"
               "id": "7d908abdaa064e7f",
               "name": "",
               "data": "payload",
               "dataType": "msg",
               "items": [
                       "type": "uint16be",
                       "name": "item1",
                       "offset": 0,
                       "length": 1,
                       "offsetbit": 0,
                       "scale": "1",
                       "mask": ""
               "swap1": "",
               "swap2": "",
               "swap3": "",
               "setTopic": true,
               "outputs": 1,
               "x": 690,
               "y": 3760,
               "wires": [
                       "d873a81aa9cad9b5",
                       "fda789d44003c305"
               "id": "8d7bb8c0118236d3",
               "type": "debug",
               "name": "Buffer - Bytes",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 640,
               "y": 3700,
               "wires": []
               "id": "d873a81aa9cad9b5",
               "type": "debug",
               "name": "Modbus Array",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 900,
               "y": 3760,
               "wires": []
               "id": "fdca5ae4d2a60dab",
               "name": "",
               "items": [
                       "name": "item1",
                       "type": "int16be",
                       "length": 1,
                       "dataType": "msg",
                       "data": "payload"
               "swap1": "",
               "swap2": "",
               "swap3": "",
               "x": 430,
               "y": 3760,
               "wires": [
                       "8d7bb8c0118236d3",
                       "7d908abdaa064e7f"
               "id": "abe958f5c004a703",
               "type": "change",
               "name": "integer Array",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "[payload]",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 410,
               "y": 3820,
               "wires": [
                       "786c6ec3bee5b1a5",
                       "7d908abdaa064e7f"
               "id": "786c6ec3bee5b1a5",
               "type": "debug",
               "name": "Integer Array",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 650,
               "y": 3860,
               "wires": []
               "id": "fda789d44003c305",
               "name": "",
               "data": "payload",
               "dataType": "msg",
               "items": [
                       "type": "int16be",
                       "name": "item1",
                       "offset": 0,
                       "length": 1,
                       "offsetbit": 0,
                       "scale": "1",
                       "mask": ""
               "swap1": "",
               "swap2": "",
               "swap3": "",
               "setTopic": true,
               "outputs": 1,
               "x": 890,
               "y": 3820,
               "wires": [
                       "3a36bcb61c95bba4"
               "id": "3a36bcb61c95bba4",
               "type": "debug",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1110,
               "y": 3820,
               "wires": []
               "id": "a1295e30a331a22d",
               "type": "junction",
               "x": 300,
               "y": 3800,
               "wires": [
                       "fdca5ae4d2a60dab",
                       "abe958f5c004a703"
        Zum Verständnis - wie ein Computer negative Werte abbildet. Es wird das erste Bit auf 1 (bzw das Bit 7 - du zählst ja von rechts nach links) gesetzt und dann die restlichen Bits (umgedreht).
               "id": "65392663801b7347",
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "-2",
               "x": 190,
               "y": 2420,
               "wires": [
                       "e1b02064d9fdd3a2"
               "id": "652134c61c9e5717",
               "name": "",
               "items": [
                       "name": "item1",
                       "type": "int8",
                       "length": 1,
                       "dataType": "msg",
                       "data": "payload"
               "swap1": "",
               "swap2": "",
               "swap3": "",
               "x": 390,
               "y": 2420,
               "wires": [
                       "95bd1a00f43c3a41",
                       "1f0f6998b2fe22bd"
               "id": "95bd1a00f43c3a41",
               "type": "debug",
               "name": "buffer maker",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 570,
               "y": 2380,
               "wires": []
               "id": "1f0f6998b2fe22bd",
               "name": "",
               "data": "payload",
               "dataType": "msg",
               "items": [
                       "type": "8bit",
                       "name": "item1",
                       "offset": 0,
                       "length": 1,
                       "offsetbit": 0,
                       "scale": "1",
                       "mask": ""
               "swap1": "",
               "swap2": "",
               "swap3": "",
               "setTopic": true,
               "outputs": 1,
               "x": 570,
               "y": 2420,
               "wires": [
                       "0d6994be085f2354",
                       "e2ed4381ba501491"
               "id": "0d6994be085f2354",
               "type": "debug",
               "name": "buffer parser",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 750,
               "y": 2420,
               "wires": []
               "id": "abae5fcc0b245338",
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "-3",
               "x": 190,
               "y": 2460,
               "wires": [
                       "e1b02064d9fdd3a2"
               "id": "e2ed4381ba501491",
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "[[payload[0][0].bits]]",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 695,
               "y": 2480,
               "wires": [
                       "5574ff5ac8d119b9",
                       "10d57305e25d5ffb"
               "l": false
               "id": "10d57305e25d5ffb",
               "type": "debug",
               "name": "8bit Array",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 840,
               "y": 2460,
               "wires": []
               "id": "5574ff5ac8d119b9",
               "name": "",
               "items": [
                       "name": "item1",
                       "type": "8bit",
                       "length": 1,
                       "dataType": "msg",
                       "data": "payload"
               "swap1": "",
               "swap2": "",
               "swap3": "",
               "x": 850,
               "y": 2500,
               "wires": [
                       "a8bc2f0c740651b7",
                       "bc288c3fca11aefa"
               "id": "a8bc2f0c740651b7",
               "type": "debug",
               "name": "buffer maker 2",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1040,
               "y": 2460,
               "wires": []
               "id": "bc288c3fca11aefa",
               "name": "",
               "data": "payload",
               "dataType": "msg",
               "items": [
                       "type": "int8",
                       "name": "item1",
                       "offset": 0,
                       "length": 1,
                       "offsetbit": 0,
                       "scale": "1",
                       "mask": ""
               "swap1": "",
               "swap2": "",
               "swap3": "",
               "setTopic": false,
               "outputs": 1,
               "x": 1030,
               "y": 2500,
               "wires": [
                       "177efcba05d60d49"
               "id": "177efcba05d60d49",
               "type": "debug",
               "name": "buffer parser 2",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1220,
               "y": 2500,
               "wires": []
               "id": "21fe0484881084c7",
               "type": "debug",
               "name": "int 8 - Eíngabe",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 400,
               "y": 2480,
               "wires": []
               "id": "39d7dcbddba73a69",
               "type": "comment",
               "name": "int8 in bits and vice versa",
               "info": "",
               "x": 250,
               "y": 2320,
               "wires": []
               "id": "e1b02064d9fdd3a2",
               "type": "junction",
               "x": 280,
               "y": 2440,
               "wires": [
                       "652134c61c9e5717",
                       "21fe0484881084c7"
        Ich hoffe ich konnte etwas zur Klarstellung beitragen.
        G 2 Antworten Letzte Antwort
        • mickymM mickym
                 "type": "inject",
                 "name": "",
                 "props": [
                         "p": "payload"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "payload": "1",
                 "x": 190,
                 "y": 3760,
                 "wires": [
                         "a1295e30a331a22d"
                 "type": "inject",
                 "name": "",
                 "props": [
                         "p": "payload"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "payload": "0",
                 "x": 190,
                 "y": 3800,
                 "wires": [
                         "a1295e30a331a22d"
                 "type": "inject",
                 "name": "",
                 "props": [
                         "p": "payload"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "payload": "-1",
                 "x": 190,
                 "y": 3840,
                 "wires": [
                         "a1295e30a331a22d"
                 "name": "",
                 "data": "payload",
                 "dataType": "msg",
                 "items": [
                         "type": "uint16be",
                         "name": "item1",
                         "offset": 0,
                         "length": 1,
                         "offsetbit": 0,
                         "scale": "1",
                         "mask": ""
                 "swap1": "",
                 "swap2": "",
                 "swap3": "",
                 "setTopic": true,
                 "outputs": 1,
                 "x": 690,
                 "y": 3760,
                 "wires": [
                         "d873a81aa9cad9b5",
                         "fda789d44003c305"
                 "type": "debug",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 640,
                 "y": 3700,
                 "wires": []
                 "type": "debug",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 900,
                 "y": 3760,
                 "wires": []
                 "name": "",
                 "items": [
                         "name": "item1",
                         "type": "int16be",
                         "length": 1,
                         "dataType": "msg",
                         "data": "payload"
                 "swap1": "",
                 "swap2": "",
                 "swap3": "",
                 "x": 430,
                 "y": 3760,
                 "wires": [
                         "8d7bb8c0118236d3",
                         "7d908abdaa064e7f"
                 "type": "change",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "to": "[payload]",
                         "tot": "jsonata"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 410,
                 "y": 3820,
                 "wires": [
                         "786c6ec3bee5b1a5",
                         "7d908abdaa064e7f"
                 "type": "debug",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 650,
                 "y": 3860,
                 "wires": []
                 "name": "",
                 "data": "payload",
                 "dataType": "msg",
                 "items": [
                         "type": "int16be",
                         "name": "item1",
                         "offset": 0,
                         "length": 1,
                         "offsetbit": 0,
                         "scale": "1",
                         "mask": ""
                 "swap1": "",
                 "swap2": "",
                 "swap3": "",
                 "setTopic": true,
                 "outputs": 1,
                 "x": 890,
                 "y": 3820,
                 "wires": [
                         "3a36bcb61c95bba4"
                 "type": "debug",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 1110,
                 "y": 3820,
                 "wires": []
                 "type": "junction",
                 "x": 300,
                 "y": 3800,
                 "wires": [
                         "fdca5ae4d2a60dab",
                         "abe958f5c004a703"
                 "type": "inject",
                 "name": "",
                 "props": [
                         "p": "payload"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "payload": "-2",
                 "x": 190,
                 "y": 2420,
                 "wires": [
                         "e1b02064d9fdd3a2"
                 "name": "",
                 "items": [
                         "name": "item1",
                         "type": "int8",
                         "length": 1,
                         "dataType": "msg",
                         "data": "payload"
                 "swap1": "",
                 "swap2": "",
                 "swap3": "",
                 "x": 390,
                 "y": 2420,
                 "wires": [
                         "95bd1a00f43c3a41",
                         "1f0f6998b2fe22bd"
                 "type": "debug",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 570,
                 "y": 2380,
                 "wires": []
                 "name": "",
                 "data": "payload",
                 "dataType": "msg",
                 "items": [
                         "type": "8bit",
                         "name": "item1",
                         "offset": 0,
                         "length": 1,
                         "offsetbit": 0,
                         "scale": "1",
                         "mask": ""
                 "swap1": "",
                 "swap2": "",
                 "swap3": "",
                 "setTopic": true,
                 "outputs": 1,
                 "x": 570,
                 "y": 2420,
                 "wires": [
                         "0d6994be085f2354",
                         "e2ed4381ba501491"
                 "type": "debug",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 750,
                 "y": 2420,
                 "wires": []
                 "type": "inject",
                 "name": "",
                 "props": [
                         "p": "payload"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "payload": "-3",
                 "x": 190,
                 "y": 2460,
                 "wires": [
                         "e1b02064d9fdd3a2"
                 "type": "change",
                 "name": "",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "tot": "jsonata"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 695,
                 "y": 2480,
                 "wires": [
                         "5574ff5ac8d119b9",
                         "10d57305e25d5ffb"
                 "l": false
                 "type": "debug",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 840,
                 "y": 2460,
                 "wires": []
                 "name": "",
                 "items": [
                         "name": "item1",
                         "type": "8bit",
                         "length": 1,
                         "dataType": "msg",
                         "data": "payload"
                 "swap1": "",
                 "swap2": "",
                 "swap3": "",
                 "x": 850,
                 "y": 2500,
                 "wires": [
                         "a8bc2f0c740651b7",
                         "bc288c3fca11aefa"
                 "type": "debug",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 1040,
                 "y": 2460,
                 "wires": []
                 "name": "",
                 "data": "payload",
                 "dataType": "msg",
                 "items": [
                         "type": "int8",
                         "name": "item1",
                         "offset": 0,
                         "length": 1,
                         "offsetbit": 0,
                         "scale": "1",
                         "mask": ""
                 "swap1": "",
                 "swap2": "",
                 "swap3": "",
                 "setTopic": false,
                 "outputs": 1,
                 "x": 1030,
                 "y": 2500,
                 "wires": [
                         "177efcba05d60d49"
                 "type": "debug",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 1220,
                 "y": 2500,
                 "wires": []
                 "type": "debug",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 400,
                 "y": 2480,
                 "wires": []
                 "type": "comment",
                 "info": "",
                 "x": 250,
                 "y": 2320,
                 "wires": []
                 "type": "junction",
                 "x": 280,
                 "y": 2440,
                 "wires": [
                         "652134c61c9e5717",
                         "21fe0484881084c7"
          Garf
          @mickym sagte in Node Red Modbus:
          Ja konntest Du. Danke dafür. War wieder viel Neues dabei. Lohnt sich mit der Materie auseinander zu setzen, statt sich vorbei zu mogeln.
          Danke nochmals.
          • mickymM mickym
                   "type": "inject",
                   "name": "",
                   "props": [
                           "p": "payload"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "payload": "1",
                   "x": 190,
                   "y": 3760,
                   "wires": [
                           "a1295e30a331a22d"
                   "type": "inject",
                   "name": "",
                   "props": [
                           "p": "payload"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "payload": "0",
                   "x": 190,
                   "y": 3800,
                   "wires": [
                           "a1295e30a331a22d"
                   "type": "inject",
                   "name": "",
                   "props": [
                           "p": "payload"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "payload": "-1",
                   "x": 190,
                   "y": 3840,
                   "wires": [
                           "a1295e30a331a22d"
                   "name": "",
                   "data": "payload",
                   "dataType": "msg",
                   "items": [
                           "type": "uint16be",
                           "name": "item1",
                           "offset": 0,
                           "length": 1,
                           "offsetbit": 0,
                           "scale": "1",
                           "mask": ""
                   "swap1": "",
                   "swap2": "",
                   "swap3": "",
                   "setTopic": true,
                   "outputs": 1,
                   "x": 690,
                   "y": 3760,
                   "wires": [
                           "d873a81aa9cad9b5",
                           "fda789d44003c305"
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 640,
                   "y": 3700,
                   "wires": []
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 900,
                   "y": 3760,
                   "wires": []
                   "name": "",
                   "items": [
                           "name": "item1",
                           "type": "int16be",
                           "length": 1,
                           "dataType": "msg",
                           "data": "payload"
                   "swap1": "",
                   "swap2": "",
                   "swap3": "",
                   "x": 430,
                   "y": 3760,
                   "wires": [
                           "8d7bb8c0118236d3",
                           "7d908abdaa064e7f"
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "[payload]",
                           "tot": "jsonata"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 410,
                   "y": 3820,
                   "wires": [
                           "786c6ec3bee5b1a5",
                           "7d908abdaa064e7f"
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 650,
                   "y": 3860,
                   "wires": []
                   "name": "",
                   "data": "payload",
                   "dataType": "msg",
                   "items": [
                           "type": "int16be",
                           "name": "item1",
                           "offset": 0,
                           "length": 1,
                           "offsetbit": 0,
                           "scale": "1",
                           "mask": ""
                   "swap1": "",
                   "swap2": "",
                   "swap3": "",
                   "setTopic": true,
                   "outputs": 1,
                   "x": 890,
                   "y": 3820,
                   "wires": [
                           "3a36bcb61c95bba4"
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 1110,
                   "y": 3820,
                   "wires": []
                   "type": "junction",
                   "x": 300,
                   "y": 3800,
                   "wires": [
                           "fdca5ae4d2a60dab",
                           "abe958f5c004a703"
                   "type": "inject",
                   "name": "",
                   "props": [
                           "p": "payload"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "payload": "-2",
                   "x": 190,
                   "y": 2420,
                   "wires": [
                           "e1b02064d9fdd3a2"
                   "name": "",
                   "items": [
                           "name": "item1",
                           "type": "int8",
                           "length": 1,
                           "dataType": "msg",
                           "data": "payload"
                   "swap1": "",
                   "swap2": "",
                   "swap3": "",
                   "x": 390,
                   "y": 2420,
                   "wires": [
                           "95bd1a00f43c3a41",
                           "1f0f6998b2fe22bd"
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 570,
                   "y": 2380,
                   "wires": []
                   "name": "",
                   "data": "payload",
                   "dataType": "msg",
                   "items": [
                           "type": "8bit",
                           "name": "item1",
                           "offset": 0,
                           "length": 1,
                           "offsetbit": 0,
                           "scale": "1",
                           "mask": ""
                   "swap1": "",
                   "swap2": "",
                   "swap3": "",
                   "setTopic": true,
                   "outputs": 1,
                   "x": 570,
                   "y": 2420,
                   "wires": [
                           "0d6994be085f2354",
                           "e2ed4381ba501491"
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 750,
                   "y": 2420,
                   "wires": []
                   "type": "inject",
                   "name": "",
                   "props": [
                           "p": "payload"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "payload": "-3",
                   "x": 190,
                   "y": 2460,
                   "wires": [
                           "e1b02064d9fdd3a2"
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "jsonata"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 695,
                   "y": 2480,
                   "wires": [
                           "5574ff5ac8d119b9",
                           "10d57305e25d5ffb"
                   "l": false
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 840,
                   "y": 2460,
                   "wires": []
                   "name": "",
                   "items": [
                           "name": "item1",
                           "type": "8bit",
                           "length": 1,
                           "dataType": "msg",
                           "data": "payload"
                   "swap1": "",
                   "swap2": "",
                   "swap3": "",
                   "x": 850,
                   "y": 2500,
                   "wires": [
                           "a8bc2f0c740651b7",
                           "bc288c3fca11aefa"
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 1040,
                   "y": 2460,
                   "wires": []
                   "name": "",
                   "data": "payload",
                   "dataType": "msg",
                   "items": [
                           "type": "int8",
                           "name": "item1",
                           "offset": 0,
                           "length": 1,
                           "offsetbit": 0,
                           "scale": "1",
                           "mask": ""
                   "swap1": "",
                   "swap2": "",
                   "swap3": "",
                   "setTopic": false,
                   "outputs": 1,
                   "x": 1030,
                   "y": 2500,
                   "wires": [
                           "177efcba05d60d49"
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 1220,
                   "y": 2500,
                   "wires": []
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 400,
                   "y": 2480,
                   "wires": []
                   "type": "comment",
                   "info": "",
                   "x": 250,
                   "y": 2320,
                   "wires": []
                   "type": "junction",
                   "x": 280,
                   "y": 2440,
                   "wires": [
                           "652134c61c9e5717",
                           "21fe0484881084c7"
            Garf
            @mickym
            Ich möchte aktuell den SDM630 Stromzähler auslesen. Funktioniert soweit echt gut mit dem BufferParser. Die Ausgabe mit den vielen Nachkommastellen gefallen mir jedoch so ganz und gar nicht. Leider finde ich keine Möglichkeit im BufferParser die Ausgabe direkt auf zwei Nachkommastellen zu begrenzen. Habe ich etwas übersehen, oder nicht richtig verstanden?
            Die Ausgabewerte im Nachgang zu bearbeiten wäre natürlich kein Problem.
            Vielleicht kennst Du im Parser noch eine direkte Einstellung um die gewünschte Formatierung einzustellen.
            • G Garf
              @mickym
              mickymM Online
              mickymM Online
              mickym
              @garf Nein - bei Floats musst Du zur mathematisch korrekten Rundung die Werte im Nachgang bearbeiten. Also kenn auch keine andere Möglichkeit.
