  3. Einsteigerfragen
  4. Installation
  5. ioBroker Backup wieder einspielen
Geplant Angeheftet Gesperrt Verschoben Installation
85 Beiträge 4 Kommentatoren 12.4k Aufrufe 3 Beobachtet
  • F federal
    @thomas-braun said in ioBroker Backup wieder einspielen:
    @federal sagte in ioBroker Backup wieder einspielen:
    npm ERR! latest @types: 18, installed node: 16
    Geh mal auf nodejs 18.
    kann ich die Eingabe dazu haben?
    #61
    Schau in meiner Signatur.
    • GlasfaserG Glasfaser
      federal
      #62
      @glasfaser said in ioBroker Backup wieder einspielen:
      Super! Danke.
      V18 hat leider nichts gebracht
      pi@raspberrypi:/opt/iobroker $ iob start
      pi@raspberrypi:/opt/iobroker $ iobroker status
      node:internal/modules/cjs/loader:1078
        throw err;
      Error: Cannot find module 'buffer-equal-constant-time'
      Require stack:
      - /opt/iobroker/node_modules/jwa/index.js
      - /opt/iobroker/node_modules/jws/lib/sign-stream.js
      - /opt/iobroker/node_modules/jws/index.js
      - /opt/iobroker/node_modules/jsonwebtoken/decode.js
      - /opt/iobroker/node_modules/jsonwebtoken/index.js
      - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
      - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
          at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
          at Module._load (node:internal/modules/cjs/loader:920:27)
          at Module.require (node:internal/modules/cjs/loader:1141:19)
          at require (node:internal/modules/cjs/helpers:110:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/jwa/index.js:1:19)
          at Module._compile (node:internal/modules/cjs/loader:1254:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
          at Module.load (node:internal/modules/cjs/loader:1117:32)
          at Module._load (node:internal/modules/cjs/loader:958:12)
          at Module.require (node:internal/modules/cjs/loader:1141:19) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/opt/iobroker/node_modules/jwa/index.js',
          '/opt/iobroker/node_modules/jws/lib/sign-stream.js',
          '/opt/iobroker/node_modules/jws/index.js',
          '/opt/iobroker/node_modules/jsonwebtoken/decode.js',
          '/opt/iobroker/node_modules/jsonwebtoken/index.js',
          '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
          '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
      Node.js v18.15.0
      GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
      • F federal
        Super! Danke.
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.15.0
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        #63
        @federal
        mache mal ein
        npm prune
        F 1 Antwort Letzte Antwort
        • F federal
          Super! Danke.
            throw err;
          Require stack:
            requireStack: [
          Node.js v18.15.0
          #64
          @federal
          Was spuckt
          sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
          uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          aus?
            @federal
            mache mal ein
            npm prune
            federal
            #65
            @federal
            mache mal ein
            npm prune
            pi@raspberrypi:/opt/iobroker $ npm prune
            npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in odule. If you've depended on crypto, you should switch to the one that's built-in.
            npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own tfinitions, so you do not need this installed.
            npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecateuse it extends the now deprecated request package, see https://github.com/request/request/i3142
            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
            npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it e the now deprecated request package, see https://github.com/request/request/issues/3142
            npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
            npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not nebe installed separately. It is now unmaintained.
            npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-sevReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.73.1. (https://github.com/visionmedia/debug/issues/797)
            npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code suse the URLSearchParams API instead.
            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions mayath.random() in certain circumstances, which is known to be problematic.  See https://v8.de/math-random for details.
            npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions mayath.random() in certain circumstances, which is known to be problematic.  See https://v8.de/math-random for details.
            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/reqequest/issues/3142
            npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For morrmation, see https://github.com/axios/axios/pull/3410
            (##################) ⠴ reify:aws-sdk: timing reifyNode:node_modules/typescript Completed in
            added 16 packages, removed 936 packages, and changed 1238 packages in 17m
            175 packages are looking for funding
              run `npm fund` for details
            habe plötzlich bei Telegram die Buttons angezeigt bekommen?
            • GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              #66
              Bitte das noch zeigen !!! :
              @thomas-braun sagte in ioBroker Backup wieder einspielen:
              @federal
              Was spuckt
              aus?
                @federal
                Was spuckt
                aus?
                federal
                #67
                pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node        -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE &        & pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                armv7l
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                /usr/bin/npx
                v18.15.0
                v18.15.0
                9.5.0
                9.5.0
                4.0.24
                pi
                pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g        pio i2c spi iobroker
                tty
                /home/pi
                OK:3 https://deb.nodesource.com/node_18.x buster InRelease
                Aktualisierung für 3 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, u        m sie anzuzeigen.
                nodejs:
                  Installiert:           18.15.0-deb-1nodesource1
                  Installationskandidat: 18.15.0-deb-1nodesource1
                  Versionstabelle:
                 *** 18.15.0-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                        100 /var/lib/dpkg/status
                     10.24.0~dfsg-1~deb10u3 500
                pi@raspberrypi:~ $
                pi@raspberrypi:~ $
                • F federal
                  armv7l
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  /usr/bin/npx
                  v18.15.0
                  v18.15.0
                  9.5.0
                  9.5.0
                  4.0.24
                  pi
                  tty
                  /home/pi
                  nodejs:
                    Versionstabelle:
                  pi@raspberrypi:~ $
                  pi@raspberrypi:~ $
                  #68
                  buster
                  Ist kürzlich dahingeschieden und muss duch 'bullseye' ersetzt werden.
                    buster
                    federal
                    #69
                    buster
                    und wie mach ich das?
                    • F federal
                      buster
                      #70
                      @federal
                      Hier hat das 'Abenteuer' mal einer protokoliert:
                      https://forum.iobroker.net/topic/47214/upgrade-von-debian-10-buster-auf-11-bullseye
                      • F federal
                        buster
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Glasfaser
                        #71
                        Gegenfrage , läuft jetzt ioBroker !?
                        denn :
                        Mehr kam nicht bei der letzten Antwort !
                          denn :
                          federal
                          #72
                          denn :
                          ich habe danach iob fix ausgeführt
                          jetzt habe ich folgendes
                          pi@raspberrypi:~ $ iobroker status
                          iobroker is not running on this host.
                          Objects type: jsonl
                          States  type: jsonl
                          • F federal
                            denn :
                            Objects type: jsonl
                            States  type: jsonl
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            #73
                            Ja ... und kommst du jetzt auf den Admin
                            iobroker start
                            F 2 Antworten Letzte Antwort
                              iobroker start
                              federal
                              #74
                              nein. Buttons gehen auch nicht mehr.
                                iobroker start
                                federal
                                #75
                                iobroker start
                                habe ich mehrmals probiert. Ohne Erfolg.
                                • F federal
                                  iobroker start
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  #76
                                  Jetzt sind wir schon bei >65 Beiträge ...
                                  @federal
                                  Setzte deine Kiste neu auf mit bullseye , ioBroker installieren ... dann eine Restore !
                                    @federal
                                    federal
                                    #77
                                    Hallo Leute. Ich habe die Kiste doch ohne zurücksetzen zum laufen gebracht. Habe erneut mit dem Tool von Elzershark repariert und es hat auf einmal funktioniert. Vor euren Verschlägen/Befehlen ging es nicht! Alles läuft auf dem aktuellen Stand. Vielen Danke für eure Unterstützung.
                                    HomoranH GlasfaserG 2 Antworten Letzte Antwort
                                    • F federal
                                      #78
                                      hattest du das "Tool" vorher schon genutzt?
                                      dann wundert mich nichts mehr.
                                      dann bleibt nur
                                      @glasfaser sagte in ioBroker Backup wieder einspielen:
                                      • F federal
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Glasfaser
                                        #79
                                        Erneut ... davon hast du nie was geschrieben ...
                                        Eher kaputt gemacht !!
                                          dann bleibt nur
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Glasfaser
                                          #80
                                          @federal
                                          @homoran sagte in ioBroker Backup wieder einspielen:
                                          Dito ...
                                          wenn du ein ioBroker System vernünftig laufen haben möchtest , dann installiere alles neu und nicht mit einem Dosenöffner-Werkzeug es instand setzen
                                          Edit :
                                          und zu :
                                          wenn du es von Anfang an uns geschrieben hättest , wären " wir " an deinem Problem ganz anders vorgegangen !
