  3. Einsteigerfragen
  4. Installation
  5. ioBroker Backup wieder einspielen
85 Beiträge 4 Kommentatoren 12.4k Aufrufe 3 Beobachtet
  • F federal
    @thomas-braun said in ioBroker Backup wieder einspielen:
    @federal
    Wie immer bei Linux:
    Warten bis wieder eine Eingabezeile erscheint, erst dann ist der Task erledigt.
      Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@raspberrypi:~ $ cd /opt/iobroker
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-contr                     oller
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now                      a built-in Node module. If you've depended on crypto, you should switch to the o                     ne that's built-in.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provide                     s its own type definitions, so you do not need this installed.
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has bee                     n deprecated because it extends the now deprecated request package, see https://                     github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b                     ecause it extends the now deprecated request package, see https://github.com/req                     uest/request/issues/3142
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JS                     ON 3
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and                      does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 hav                     e a low-severity ReDos regression when used in a Node.js environment. It is reco                     mmended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/iss                     ues/797)
    npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy.                      new code should use the URLSearchParams API instead.
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v                     ersions may use Math.random() in certain circumstances, which is known to be pro                     blematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older v                     ersions may use Math.random() in certain circumstances, which is known to be pro                     blematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://git                     hub.com/request/request/issues/3142
    npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21                     .1. For more information, see https://github.com/axios/axios/pull/3410
    (##################) ⠸ reify:aws-sdk: timing reifyNode:node_modules/typescript
    (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
    npm ERR! command failed
    npm ERR! signal SIGINT
    npm ERR! command sh -c -- node ./install/installTypings.js
    npm ERR! Installing NodeJS typings...
    npm ERR! latest @types: 18, installed node: 16
    npm ERR!     /home/iobroker/.npm/_logs/2023-04-04T16_30_22_609Z-debug-0.log
    pi@raspberrypi:/opt/iobroker $ iob start
    pi@raspberrypi:/opt/iobroker $ iob protokol
    node:internal/modules/cjs/loader:1024
      throw err;
    Error: Cannot find module 'buffer-equal-constant-time'
    Require stack:
    - /opt/iobroker/node_modules/jwa/index.js
    - /opt/iobroker/node_modules/jws/lib/sign-stream.js
    - /opt/iobroker/node_modules/jws/index.js
    - /opt/iobroker/node_modules/jsonwebtoken/decode.js
    - /opt/iobroker/node_modules/jsonwebtoken/index.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
        at Function.Module._load (node:internal/modules/cjs/loader:866:27)
        at Module.require (node:internal/modules/cjs/loader:1093:19)
        at require (node:internal/modules/cjs/helpers:108:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/jwa/index.js:1:19)
        at Module._compile (node:internal/modules/cjs/loader:1191:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
        at Module.load (node:internal/modules/cjs/loader:1069:32)
        at Function.Module._load (node:internal/modules/cjs/loader:904:12)
        at Module.require (node:internal/modules/cjs/loader:1093:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/jwa/index.js',
        '/opt/iobroker/node_modules/jws/lib/sign-stream.js',
        '/opt/iobroker/node_modules/jws/index.js',
        '/opt/iobroker/node_modules/jsonwebtoken/decode.js',
        '/opt/iobroker/node_modules/jsonwebtoken/index.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    GlasfaserG Offline
    GlasfaserG Offline
    @federal sagte in ioBroker Backup wieder einspielen:
    wo hast du denn diesen Befehl her !?
    F 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      federal
      @glasfaser said in ioBroker Backup wieder einspielen:
      sorry. Habe mit iobroker status verwechselt
      • F federal
        Geh mal auf nodejs 18.
        kann ich die Eingabe dazu haben?
        GlasfaserG Offline
        GlasfaserG Offline
        • F federal
          Schau in meiner Signatur.
            federal
            Super! Danke.
            V18 hat leider nichts gebracht
            pi@raspberrypi:/opt/iobroker $ iobroker status
            node:internal/modules/cjs/loader:1078
              throw err;
            Require stack:
                at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
                at Module._load (node:internal/modules/cjs/loader:920:27)
                at Module.require (node:internal/modules/cjs/loader:1141:19)
                at require (node:internal/modules/cjs/helpers:110:18)
                at Module._compile (node:internal/modules/cjs/loader:1254:14)
                at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
                at Module.load (node:internal/modules/cjs/loader:1117:32)
                at Module._load (node:internal/modules/cjs/loader:958:12)
                at Module.require (node:internal/modules/cjs/loader:1141:19) {
              requireStack: [
            Node.js v18.15.0
            GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
            • F federal
              Super! Danke.
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.15.0
              GlasfaserG Offline
              GlasfaserG Offline
              @federal
              mache mal ein
              npm prune
              • F federal
                Super! Danke.
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.15.0
                @federal
                Was spuckt
                sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                aus?
                  @federal
                  mache mal ein
                  npm prune
                  federal
                  @federal
                  mache mal ein
                  npm prune
                  pi@raspberrypi:/opt/iobroker $ npm prune
                  npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in odule. If you've depended on crypto, you should switch to the one that's built-in.
                  npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own tfinitions, so you do not need this installed.
                  npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecateuse it extends the now deprecated request package, see https://github.com/request/request/i3142
                  npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it e the now deprecated request package, see https://github.com/request/request/issues/3142
                  npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                  npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not nebe installed separately. It is now unmaintained.
                  npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-sevReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.73.1. (https://github.com/visionmedia/debug/issues/797)
                  npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code suse the URLSearchParams API instead.
                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions mayath.random() in certain circumstances, which is known to be problematic.  See https://v8.de/math-random for details.
                  npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions mayath.random() in certain circumstances, which is known to be problematic.  See https://v8.de/math-random for details.
                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/reqequest/issues/3142
                  npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For morrmation, see https://github.com/axios/axios/pull/3410
                  (##################) ⠴ reify:aws-sdk: timing reifyNode:node_modules/typescript Completed in
                  added 16 packages, removed 936 packages, and changed 1238 packages in 17m
                  175 packages are looking for funding
                    run `npm fund` for details
                  habe plötzlich bei Telegram die Buttons angezeigt bekommen?
                  • GlasfaserG Offline
                    GlasfaserG Offline
                    #66
                    Bitte das noch zeigen !!! :
                    @thomas-braun sagte in ioBroker Backup wieder einspielen:
                    @federal
                    Was spuckt
                    aus?
                      @federal
                      Was spuckt
                      aus?
                      federal
                      #67
                      pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                      pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node        -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE &        & pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      armv7l
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      /usr/bin/npx
                      v18.15.0
                      v18.15.0
                      9.5.0
                      9.5.0
                      4.0.24
                      pi
                      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g        pio i2c spi iobroker
                      tty
                      /home/pi
                      OK:1 http://archive.raspberrypi.org/debian buster InRelease
                      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      OK:3 https://deb.nodesource.com/node_18.x buster InRelease
                      Aktualisierung für 3 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, u        m sie anzuzeigen.
                      nodejs:
                        Installiert:           18.15.0-deb-1nodesource1
                        Installationskandidat: 18.15.0-deb-1nodesource1
                        Versionstabelle:
                       *** 18.15.0-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                           10.24.0~dfsg-1~deb10u3 500
                      pi@raspberrypi:~ $
                      pi@raspberrypi:~ $
                      • F federal
                        armv7l
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        /usr/bin/npx
                        v18.15.0
                        v18.15.0
                        9.5.0
                        9.5.0
                        4.0.24
                        pi
                        tty
                        /home/pi
                        nodejs:
                          Versionstabelle:
                        pi@raspberrypi:~ $
                        pi@raspberrypi:~ $
                        #68
                        buster
                        Ist kürzlich dahingeschieden und muss duch 'bullseye' ersetzt werden.
                          buster
                          federal
                          #69
                          buster
                          und wie mach ich das?
                          Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                          • F federal
                            buster
                            #70
                            @federal
                            Hier hat das 'Abenteuer' mal einer protokoliert:
                            https://forum.iobroker.net/topic/47214/upgrade-von-debian-10-buster-auf-11-bullseye
                            • F federal
                              buster
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #71
                              Gegenfrage , läuft jetzt ioBroker !?
                              denn :
                              Mehr kam nicht bei der letzten Antwort !
                                denn :
                                federal
                                #72
                                denn :
                                ich habe danach iob fix ausgeführt
                                jetzt habe ich folgendes
                                pi@raspberrypi:~ $ iobroker status
                                iobroker is not running on this host.
                                Objects type: jsonl
                                States  type: jsonl
                                • F federal
                                  denn :
                                  Objects type: jsonl
                                  States  type: jsonl
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  #73
                                  Ja ... und kommst du jetzt auf den Admin
                                  iobroker start
                                  F 2 Antworten Letzte Antwort
                                    iobroker start
                                    federal
                                    #74
                                    nein. Buttons gehen auch nicht mehr.
                                      iobroker start
                                      federal
                                      #75
                                      iobroker start
                                      habe ich mehrmals probiert. Ohne Erfolg.
                                      • F federal
                                        iobroker start
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        #76
                                        Jetzt sind wir schon bei >65 Beiträge ...
                                        @federal
                                        Setzte deine Kiste neu auf mit bullseye , ioBroker installieren ... dann eine Restore !
                                          @federal
                                          federal
                                          #77
                                          Hallo Leute. Ich habe die Kiste doch ohne zurücksetzen zum laufen gebracht. Habe erneut mit dem Tool von Elzershark repariert und es hat auf einmal funktioniert. Vor euren Verschlägen/Befehlen ging es nicht! Alles läuft auf dem aktuellen Stand. Vielen Danke für eure Unterstützung.
                                          HomoranH GlasfaserG 2 Antworten Letzte Antwort
