  3. Einsteigerfragen
  4. Installation
  5. ioBroker Backup wieder einspielen
85 Beiträge 4 Kommentatoren 12.4k Aufrufe 3 Beobachtet
  • F federal
    @thomas-braun said in ioBroker Backup wieder einspielen:
    @federal
    Last login: Tue Apr  4 15:43:58 2023 from 100.75.198.95
    echad@chet:~ $ cd /opt/iobroker/
    echad@chet:/opt/iobroker $ npm ls buffer-equal-constant-time
    iobroker.inst@3.0.0 /opt/iobroker
    ├─┬ iobroker.backitup@2.6.16
    │ └─┬ google-auth-library@8.7.0
    │   └─┬ jws@4.0.0
    │     └─┬ jwa@2.0.0
    │       └── buffer-equal-constant-time@1.0.1
    └─┬ iobroker.js-controller@5.0.1-alpha.0-20230403-fd495c2e
      └─┬ jsonwebtoken@9.0.0
        └─┬ jws@3.2.2
          └─┬ jwa@1.4.1
            └── buffer-equal-constant-time@1.0.1 deduped
    Ich würde den js-controller nochmal installieren.
    wie mache ich das?
    @federal
    iob stop
    iob fix
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    iob start
    F 1 Antwort Letzte Antwort
      @federal
      iob stop
      iob fix
      cd /opt/iobroker
      iob start
      federal
      schrieb am zuletzt editiert von federal
      @federal
      iob stop
      iob fix
      cd /opt/iobroker
      iob start
      Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
      • F federal
        @federal
        iob stop
        iob fix
        cd /opt/iobroker
        iob start
        @federal
        Wie immer bei Linux:
        Warten bis wieder eine Eingabezeile erscheint, erst dann ist der Task erledigt.
          @federal
          federal
          @federal
            Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          pi@raspberrypi:~ $ cd /opt/iobroker
          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-contr                     oller
          npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now                      a built-in Node module. If you've depended on crypto, you should switch to the o                     ne that's built-in.
          npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provide                     s its own type definitions, so you do not need this installed.
          npm WARN deprecated request-promise-native@1.0.9: request-promise-native has bee                     n deprecated because it extends the now deprecated request package, see https://                     github.com/request/request/issues/3142
          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
          npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b                     ecause it extends the now deprecated request package, see https://github.com/req                     uest/request/issues/3142
          npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JS                     ON 3
          npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and                      does not need to be installed separately. It is now unmaintained.
          npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 hav                     e a low-severity ReDos regression when used in a Node.js environment. It is reco                     mmended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/iss                     ues/797)
          npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy.                      new code should use the URLSearchParams API instead.
          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v                     ersions may use Math.random() in certain circumstances, which is known to be pro                     blematic.  See https://v8.dev/blog/math-random for details.
          npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older v                     ersions may use Math.random() in certain circumstances, which is known to be pro                     blematic.  See https://v8.dev/blog/math-random for details.
          npm WARN deprecated request@2.88.2: request has been deprecated, see https://git                     hub.com/request/request/issues/3142
          npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21                     .1. For more information, see https://github.com/axios/axios/pull/3410
          (##################) ⠸ reify:aws-sdk: timing reifyNode:node_modules/typescript
          (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
          npm ERR! command failed
          npm ERR! signal SIGINT
          npm ERR! command sh -c -- node ./install/installTypings.js
          npm ERR! Installing NodeJS typings...
          npm ERR! latest @types: 18, installed node: 16
          npm ERR!     /home/iobroker/.npm/_logs/2023-04-04T16_30_22_609Z-debug-0.log
          pi@raspberrypi:/opt/iobroker $ iob start
          pi@raspberrypi:/opt/iobroker $ iob protokol
          node:internal/modules/cjs/loader:1024
            throw err;
          Error: Cannot find module 'buffer-equal-constant-time'
          Require stack:
          - /opt/iobroker/node_modules/jwa/index.js
          - /opt/iobroker/node_modules/jws/lib/sign-stream.js
          - /opt/iobroker/node_modules/jws/index.js
          - /opt/iobroker/node_modules/jsonwebtoken/decode.js
          - /opt/iobroker/node_modules/jsonwebtoken/index.js
          - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
          - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
          - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
          - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
              at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
              at Function.Module._load (node:internal/modules/cjs/loader:866:27)
              at Module.require (node:internal/modules/cjs/loader:1093:19)
              at require (node:internal/modules/cjs/helpers:108:18)
              at Object.<anonymous> (/opt/iobroker/node_modules/jwa/index.js:1:19)
              at Module._compile (node:internal/modules/cjs/loader:1191:14)
              at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
              at Module.load (node:internal/modules/cjs/loader:1069:32)
              at Function.Module._load (node:internal/modules/cjs/loader:904:12)
              at Module.require (node:internal/modules/cjs/loader:1093:19) {
            code: 'MODULE_NOT_FOUND',
            requireStack: [
              '/opt/iobroker/node_modules/jwa/index.js',
              '/opt/iobroker/node_modules/jws/lib/sign-stream.js',
              '/opt/iobroker/node_modules/jws/index.js',
              '/opt/iobroker/node_modules/jsonwebtoken/decode.js',
              '/opt/iobroker/node_modules/jsonwebtoken/index.js',
              '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
              '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
              '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
              '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          • F federal
            @federal
            iob stop
            iob fix
            cd /opt/iobroker
            iob start
            GlasfaserG Offline
            GlasfaserG Offline
            @federal
            Bitte dein Beitrag nicht Editieren ... das bringt alle durcheinander !!!
            • F federal
              @federal
                throw err;
              Require stack:
                requireStack: [
              @federal sagte in ioBroker Backup wieder einspielen:
              Geh mal auf nodejs 18.
                federal
                kann ich die Eingabe dazu haben?
                GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                • F federal
                  @federal
                    throw err;
                  Require stack:
                    requireStack: [
                  GlasfaserG Offline
                  GlasfaserG Offline
                  wo hast du denn diesen Befehl her !?
                  • GlasfaserG Glasfaser
                    federal
                    @glasfaser said in ioBroker Backup wieder einspielen:
                    sorry. Habe mit iobroker status verwechselt
                    • F federal
                      GlasfaserG Offline
                      GlasfaserG Offline
                      • F federal
                        Schau in meiner Signatur.
                          federal
                          Super! Danke.
                          V18 hat leider nichts gebracht
                          pi@raspberrypi:/opt/iobroker $ iobroker status
                          node:internal/modules/cjs/loader:1078
                            throw err;
                          Require stack:
                              at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
                              at Module._load (node:internal/modules/cjs/loader:920:27)
                              at Module.require (node:internal/modules/cjs/loader:1141:19)
                              at require (node:internal/modules/cjs/helpers:110:18)
                              at Module._compile (node:internal/modules/cjs/loader:1254:14)
                              at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
                              at Module.load (node:internal/modules/cjs/loader:1117:32)
                              at Module._load (node:internal/modules/cjs/loader:958:12)
                              at Module.require (node:internal/modules/cjs/loader:1141:19) {
                            requireStack: [
                          Node.js v18.15.0
                          • F federal
                            Super! Danke.
                              throw err;
                            Require stack:
                              requireStack: [
                            Node.js v18.15.0
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @federal
                            mache mal ein
                            npm prune
                            • F federal
                              Super! Danke.
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.15.0
                              @federal
                              Was spuckt
                              sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                              uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              aus?
                                @federal
                                mache mal ein
                                npm prune
                                federal
                                @federal
                                mache mal ein
                                npm prune
                                pi@raspberrypi:/opt/iobroker $ npm prune
                                npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in odule. If you've depended on crypto, you should switch to the one that's built-in.
                                npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own tfinitions, so you do not need this installed.
                                npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecateuse it extends the now deprecated request package, see https://github.com/request/request/i3142
                                npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it e the now deprecated request package, see https://github.com/request/request/issues/3142
                                npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not nebe installed separately. It is now unmaintained.
                                npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-sevReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.73.1. (https://github.com/visionmedia/debug/issues/797)
                                npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code suse the URLSearchParams API instead.
                                npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions mayath.random() in certain circumstances, which is known to be problematic.  See https://v8.de/math-random for details.
                                npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions mayath.random() in certain circumstances, which is known to be problematic.  See https://v8.de/math-random for details.
                                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/reqequest/issues/3142
                                npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For morrmation, see https://github.com/axios/axios/pull/3410
                                (##################) ⠴ reify:aws-sdk: timing reifyNode:node_modules/typescript Completed in
                                added 16 packages, removed 936 packages, and changed 1238 packages in 17m
                                175 packages are looking for funding
                                  run `npm fund` for details
                                habe plötzlich bei Telegram die Buttons angezeigt bekommen?
                                • GlasfaserG Offline
                                  GlasfaserG Offline
                                  #66
                                  Bitte das noch zeigen !!! :
                                  @thomas-braun sagte in ioBroker Backup wieder einspielen:
                                  @federal
                                  Was spuckt
                                  aus?
                                    @federal
                                    Was spuckt
                                    aus?
                                    federal
                                    #67
                                    pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                    pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node        -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE &        & pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                    armv7l
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    /usr/bin/npx
                                    v18.15.0
                                    v18.15.0
                                    9.5.0
                                    9.5.0
                                    4.0.24
                                    pi
                                    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g        pio i2c spi iobroker
                                    tty
                                    /home/pi
                                    OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                    OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                    OK:3 https://deb.nodesource.com/node_18.x buster InRelease
                                    Aktualisierung für 3 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, u        m sie anzuzeigen.
                                    nodejs:
                                      Installiert:           18.15.0-deb-1nodesource1
                                      Installationskandidat: 18.15.0-deb-1nodesource1
                                      Versionstabelle:
                                     *** 18.15.0-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                                         10.24.0~dfsg-1~deb10u3 500
                                    pi@raspberrypi:~ $
                                    pi@raspberrypi:~ $
                                    • F federal
                                      armv7l
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      /usr/bin/npx
                                      v18.15.0
                                      v18.15.0
                                      9.5.0
                                      9.5.0
                                      4.0.24
                                      pi
                                      tty
                                      /home/pi
                                      nodejs:
                                        Versionstabelle:
                                      pi@raspberrypi:~ $
                                      pi@raspberrypi:~ $
                                      #68
                                      buster
                                      Ist kürzlich dahingeschieden und muss duch 'bullseye' ersetzt werden.
                                        buster
                                        federal
                                        #69
                                        buster
                                        und wie mach ich das?
                                        • F federal
                                          buster
                                          #70
                                          @federal
                                          Hier hat das 'Abenteuer' mal einer protokoliert:
                                          https://forum.iobroker.net/topic/47214/upgrade-von-debian-10-buster-auf-11-bullseye
