  4. [Neuer Adapter] mediola-gateway
    2.8k
    4.9k
    4.1k
136 Beiträge 20 Kommentatoren 30.0k Aufrufe 18 Beobachtet
  • A acidsubway
    @oelison
    mediola-gateway.0
    	2025-02-14 17:49:37.760	debug	out RECEIVED: 192.168.0.41:1901 - DHCP:TRUE HWV:EA VER:1.2.8 VID:FFFF NAME:AIO GATEWAY V5+ IP:192.168.0.41 PT:80 SN:255.255.255.0 GW:192.168.0.1 DNS:192.168.0.1 MAC:40-66-7A-00-3C-EE TMP_ID:9b7a6a5c |end
    mediola-gateway.0
    	2025-02-14 17:49:37.761	debug	DHCP:TRUE
    mediola-gateway.0
    	2025-02-14 17:49:37.761	debug	HWV:EA
    mediola-gateway.0
    	2025-02-14 17:49:37.762	debug	VER:1.2.8
    mediola-gateway.0
    	2025-02-14 17:49:37.762	debug	VID:FFFF
    mediola-gateway.0
    	2025-02-14 17:49:37.763	debug	NAME:AIO GATEWAY V5+
    mediola-gateway.0
    	2025-02-14 17:49:37.763	debug	IP:192.168.0.41
    mediola-gateway.0
    	2025-02-14 17:49:37.764	debug	PT:80
    mediola-gateway.0
    	2025-02-14 17:49:37.764	debug	SN:255.255.255.0
    mediola-gateway.0
    	2025-02-14 17:49:37.765	debug	GW:192.168.0.1
    mediola-gateway.0
    	2025-02-14 17:49:37.765	debug	DNS:192.168.0.1
    mediola-gateway.0
    	2025-02-14 17:49:37.765	debug	MAC:40-66-7A-00-3C-EE
    mediola-gateway.0
    	2025-02-14 17:49:37.766	debug	TMP_ID:9b7a6a5c
    mediola-gateway.0
    mediola-gateway.0
    	2025-02-14 17:49:37.767	info	Mediola connected with ip:192.168.0.41 and mac:40-66-7A-00-3C-EE
    mediola-gateway.0
    	2025-02-14 17:49:37.768	debug	validMediola: true sysvarInti: false timerRead: false cmd false pull false
    mediola-gateway.0
    	2025-02-14 17:49:37.768	debug	http://192.168.0.41/command?XC_USER=user&XC_PASS=pass&XC_FNC=getstates
    mediola-gateway.0
    	2025-02-14 17:49:37.794	debug	Source: onReady
    mediola-gateway.0
    	2025-02-14 17:49:38.369	debug	{"XC_ERR":{"code":"000007","msg":"access denied"}}
    mediola-gateway.0
    	2025-02-14 17:49:38.370	error	mediola device rejected the request: [object Object]
    er macht das mit der falschen URL
    acidsubway
    schrieb am zuletzt editiert von acidsubway
    #121
    wie stell ich ein das er mit dieser URL das abfrägt?
    http://192.168.0.41/cmd?XC_FNC=GetStates&auth=pass
    hab ja eine V5 Plus die hat keinen user da geht nur die URL von oben im Browser
    • oelisonO oelison
      @nicoloma Die Nobily Rolläden werden leider nicht automatisch erkannt. Bitte mal das ergebnis dieses Aufrufs hier posten.
      http://ip.der.mediola/cmd?XC_FNC=GetStates&auth=passwort
      Ich stelle gerade auf dieses Kommando um für Mediolas ab V5 und neuer. Vielleicht sind da die Nobily Rolläden bei.
      Wenn nicht, müssen die Seriennummer durch Netzwerksniffen oder im debug tool der Mediola app rausgesucht werden und dann als datenpunkt im experten modus im ioBroker im adapter unter action angelegt werden. Das klappt nur wenn die Seriennummern mit NY oder DY anfangen und danach 8 Ziffern haben.
      acidsubway
      #122
      @oelison wo stellt man das um???
      A 1 Antwort Letzte Antwort
      • A acidsubway
        acidsubway
        #123
        Hab das mal zusammen gefast, setze ich den Haken bei den Einstellungen unter "Versuchen Sie, den Befehl cmd und nicht den Befehl command zu verwenden." dann ist das die LOG
        mediola-gateway.0
        	2025-02-14 23:02:04.141	debug	UDP socket listening on 0.0.0.0:1902
        mediola-gateway.0
        	2025-02-14 23:02:04.453	debug	out RECEIVED: 192.168.0.41:1901 - DHCP:TRUE HWV:EA VER:1.2.8 VID:FFFF NAME:AIO GATEWAY V5+ IP:192.168.0.41 PT:80 SN:255.255.255.0 GW:192.168.0.1 DNS:192.168.0.1 MAC:40-66-7A-00-3C-EE TMP_ID:09ed11b32 |end
        mediola-gateway.0
        	2025-02-14 23:02:04.453	debug	DHCP:TRUE
        mediola-gateway.0
        	2025-02-14 23:02:04.454	debug	HWV:EA
        mediola-gateway.0
        	2025-02-14 23:02:04.454	debug	VER:1.2.8
        mediola-gateway.0
        	2025-02-14 23:02:04.455	debug	VID:FFFF
        mediola-gateway.0
        	2025-02-14 23:02:04.455	debug	NAME:AIO GATEWAY V5+
        mediola-gateway.0
        	2025-02-14 23:02:04.456	debug	IP:192.168.0.41
        mediola-gateway.0
        	2025-02-14 23:02:04.456	debug	PT:80
        mediola-gateway.0
        	2025-02-14 23:02:04.456	debug	SN:255.255.255.0
        mediola-gateway.0
        	2025-02-14 23:02:04.456	debug	GW:192.168.0.1
        mediola-gateway.0
        	2025-02-14 23:02:04.456	debug	DNS:192.168.0.1
        mediola-gateway.0
        	2025-02-14 23:02:04.457	debug	MAC:10-66-8A-00-3C-EE
        mediola-gateway.0
        	2025-02-14 23:02:04.457	debug	TMP_ID:09ed11b32
        mediola-gateway.0
        aber ich sehe garnichts
        wenn ich aber diesen Befehl sende kommt alles im Browser
        oelisonO 1 Antwort Letzte Antwort
        • A acidsubway
          mediola-gateway.0
          mediola-gateway.0
          mediola-gateway.0
          mediola-gateway.0
          mediola-gateway.0
          mediola-gateway.0
          mediola-gateway.0
          mediola-gateway.0
          mediola-gateway.0
          mediola-gateway.0
          mediola-gateway.0
          mediola-gateway.0
          mediola-gateway.0
          mediola-gateway.0
          mediola-gateway.0
          oelisonO Offline
          oelisonO Offline
          oelison
          schrieb am zuletzt editiert von oelison
          #124
          @acidsubway
          Hier musst Du den key angeben:
          Und den Hacken für cmd setzen. Und user muss leer sein. Also auch kein space oder so.
          I like Rust. ioBroker-Adapter: matrix, mediola-gateway, support for reolink
          • oelisonO oelison
            @acidsubway
            acidsubway
            #125
            @oelison
            Das will irgendwie nicht, er verbindet sich nicht.
            Ich habe alles versucht, mit Passwort und Authentifizierungsschlüssel (was beides mein Passwort ist) auch einzeln in den Feldern. Der Adapter startet nicht er bleibt auf gelb.
            Mit haken am "Versuchen Sie, den Befehl cmd und nicht den Befehl command zu verwenden" oder ohne gleiche Ergebniss
            mediola-gateway.0
            	2025-02-15 10:56:31.327	info	Got terminate signal TERMINATE_YOURSELF
            mediola-gateway.0
            	2025-02-15 10:56:31.329	info	terminating
            mediola-gateway.0
            	2025-02-15 10:56:31.330	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            mediola-gateway.0
            	2025-02-15 10:56:37.170	info	starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.mediola-gateway, node: v20.18.2, js-controller: 7.0.6
            mediola-gateway.0
            	2025-02-15 10:56:37.198	info	auto detection: false
            mediola-gateway.0
            	2025-02-15 10:56:37.199	info	find by mac: false
            mediola-gateway.0
            	2025-02-15 10:56:37.200	info	find by ip: false
            mediola-gateway.0
            	2025-02-15 10:56:37.201	error	no valid detection method defined
            mediola-gateway.0
            	2025-02-15 10:56:37.207	debug	UDP socket listening on 0.0.0.0:1902
            mediola-gateway.0
            	2025-02-15 10:56:37.530	debug	out RECEIVED: 192.168.0.41:1901 - DHCP:TRUE HWV:EA VER:1.2.8 VID:FFFF NAME:AIO GATEWAY V5+ IP:192.168.0.41 PT:80 SN:255.255.255.0 GW:192.168.0.1 DNS:192.168.0.1 MAC:40-66-7A-00-3C-EE TMP_ID:XXXXXXX |end
            mediola-gateway.0
            	2025-02-15 10:56:37.530	debug	DHCP:TRUE
            mediola-gateway.0
            	2025-02-15 10:56:37.530	debug	HWV:EA
            mediola-gateway.0
            	2025-02-15 10:56:37.531	debug	VER:1.2.8
            mediola-gateway.0
            	2025-02-15 10:56:37.531	debug	VID:FFFF
            mediola-gateway.0
            	2025-02-15 10:56:37.532	debug	NAME:AIO GATEWAY V5+
            mediola-gateway.0
            	2025-02-15 10:56:37.532	debug	IP:192.168.0.41
            mediola-gateway.0
            	2025-02-15 10:56:37.532	debug	PT:80
            mediola-gateway.0
            	2025-02-15 10:56:37.532	debug	SN:255.255.255.0
            mediola-gateway.0
            	2025-02-15 10:56:37.532	debug	GW:192.168.0.1
            mediola-gateway.0
            	2025-02-15 10:56:37.533	debug	DNS:192.168.0.1
            mediola-gateway.0
            	2025-02-15 10:56:37.533	debug	MAC:XXXXXXXXX
            mediola-gateway.0
            	2025-02-15 10:56:37.533	debug	TMP_IDXXXXXXX
            mediola-gateway.0
            • A acidsubway
              @oelison
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              mediola-gateway.0
              oelisonO Offline
              oelisonO Offline
              oelison
              #126
              @acidsubway Warum ist Autodetection false?
              A 2 Antworten Letzte Antwort
              • oelisonO oelison
                acidsubway
                #127
                @oelison
                wo stell ich das ein " info auto detection: false "
                mediola-gateway.0
                	2025-02-15 11:14:51.007	info	terminating
                mediola-gateway.0
                	2025-02-15 11:14:51.009	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                mediola-gateway.0
                	2025-02-15 11:14:56.844	info	starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.mediola-gateway, node: v20.18.3, js-controller: 7.0.6
                mediola-gateway.0
                	2025-02-15 11:14:56.864	info	auto detection: false
                mediola-gateway.0
                	2025-02-15 11:14:56.865	info	find by mac: true
                mediola-gateway.0
                	2025-02-15 11:14:56.865	info	with mac address: xxxxxx
                mediola-gateway.0
                	2025-02-15 11:14:56.870	debug	UDP socket listening on 0.0.0.0:1902
                mediola-gateway.0
                	2025-02-15 11:14:57.234	debug	out RECEIVED: 192.168.0.41:1901 - DHCP:TRUE HWV:EA VER:1.2.8 VID:FFFF NAME:AIO GATEWAY V5+ IP:192.168.0.41 PT:80 SN:255.255.255.0 GW:192.168.0.1 DNS:192.168.0.1 MAC:40-66-7A-00-3C-EE TMP_ID:fxxxxx |end
                mediola-gateway.0
                	2025-02-15 11:14:57.235	debug	DHCP:TRUE
                mediola-gateway.0
                	2025-02-15 11:14:57.235	debug	HWV:EA
                mediola-gateway.0
                	2025-02-15 11:14:57.235	debug	VER:1.2.8
                mediola-gateway.0
                	2025-02-15 11:14:57.236	debug	VID:FFFF
                mediola-gateway.0
                	2025-02-15 11:14:57.236	debug	NAME:AIO GATEWAY V5+
                mediola-gateway.0
                	2025-02-15 11:14:57.237	debug	IP:192.168.0.41
                mediola-gateway.0
                	2025-02-15 11:14:57.237	debug	PT:80
                mediola-gateway.0
                	2025-02-15 11:14:57.238	debug	SN:255.255.255.0
                mediola-gateway.0
                	2025-02-15 11:14:57.238	debug	GW:192.168.0.1
                mediola-gateway.0
                	2025-02-15 11:14:57.239	debug	DNS:192.168.0.1
                mediola-gateway.0
                	2025-02-15 11:14:57.239	debug	MAC:40-66-7A-00-3C-EE
                mediola-gateway.0
                	2025-02-15 11:14:57.240	debug	TMP_ID:xxxxxx
                mediola-gateway.0
                • oelisonO oelison
                  acidsubway
                  #128
                  @oelison SORRY
                  DANKE, DANKE, DANKE war auf einem kleinem Bildschirm sah oben nicht das Auto Kästchen
                  ediola-gateway.0
                  	2025-02-15 11:17:03.088	info	Mediola connected with ip:192.168.0.41 and mac:40-66-7A-00-3C-EE
                  mediola-gateway.0
                  	2025-02-15 11:17:03.089	debug	validMediola: true sysvarInti: false timerRead: false cmd true pull false
                  mediola-gateway.0
                  	2025-02-15 11:17:03.089	debug	http://192.168.0.41/cmd?auth=pussypopper1&XC_FNC=getstates
                  mediola-gateway.0
                  	2025-02-15 11:17:03.115	debug	Source: onReady
                  mediola-gateway.0
                  	2025-02-15 11:17:03.767	debug	{"XC_SUC":[{"type":"HM","adr":"HM-R
                  • A acidsubway
                    @oelison SORRY
                    ediola-gateway.0
                    mediola-gateway.0
                    mediola-gateway.0
                    mediola-gateway.0
                    mediola-gateway.0
                    oelisonO Offline
                    oelisonO Offline
                    oelison
                    #129
                    @acidsubway Super, freut mich. Nicht vergessen wieder auf Info zu stellen.
                    • oelisonO oelison
                      acidsubway
                      #130
                      @oelison Vielen Dank, habs gemacht :) freut mich das das nun geht :)
                      • L Offline
                        line
                        schrieb am zuletzt editiert von line
                        #131
                        ich habe bisher den Mediola Adapter ohne Probleme verwendet. Doch seit einiger Zeit ist mir aufgefallen, dass er keine Verbindung mehr hat.
                        Hat es hier eine Änderung evt. von Seiten Mediola gegeben, da mein Adapter seither nicht mehr geht. Ist hier irgendwas bekannt?
                        • L line
                          oelisonO Offline
                          oelisonO Offline
                          oelison
                          #132
                          @line Mir ist leider nichts bekannt. Bei mir geht alles wie immer. Ein update ist mir auch nicht aufgefallen.
                          • oelisonO oelison
                            ToK
                            #133
                            möchte Funk Elero Rollladenantriebe über ein Gateway in den ioBroker einbinden.
                            Dieses Gateway soll ausschließlich zur Kommunikation zwischen Elero Funkantrieben und dem ioBroker dienen.
                            Welche Mindestanforderung vom Mediola Gateways "V6 mini" oder "V6" oder "V6+" sind hierzu wirklich erforderlich. Weitere Frage: ist hierzu eine weitere Lizenz erforderlich?
                            Die Integration in den ioBroker soll ja mit Hilfe diesem Mediola-Adapter sehr gut funktionieren.
                            • B Online
                              B Online
                              babl
                              schrieb am zuletzt editiert von babl
                              #134
                              hallo habe mir ne mediola v5+ von eBay geholt und einen Schwenkwickler eW930-F von Wir Elektronik, den Adapter installiert, wird auch grün aber wenn ich in iobroker z.B 1 rein schreibe dann tut sich am Wickler gar nichts. Was muss ich da noch machen, kann jemand helfen?
                                "mediola-gateway.0.action": {
                                  "type": "folder",
                                  "common": {
                                    "name": "action"
                                  "from": "system.adapter.mediola-gateway.0",
                                  "user": "system.user.admin",
                                  "ts": 1765095568744,
                                  "_id": "mediola-gateway.0.action",
                                  "acl": {
                                    "object": 1636,
                                    "owner": "system.user.admin",
                                "mediola-gateway.0.action.WR1B284D01": {
                                  "type": "state",
                                  "common": {
                                    "name": "WIR 1B284D01 1=up, 2=down, 3=stop",
                                    "type": "string",
                                    "role": "text",
                                    "read": true,
                                    "write": true
                                  "native": {},
                                  "ts": 1765036293388,
                                  "_id": "mediola-gateway.0.action.WR1B284D01",
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                  "val": "1",
                                  "ack": false
                                "mediola-gateway.0.info": {
                                  "_id": "mediola-gateway.0.info",
                                  "type": "channel",
                                  "common": {
                                    "name": "Information"
                                  "native": {},
                                  "ts": 1765095568638,
                                  "acl": {
                                    "object": 1636,
                                "mediola-gateway.0.info.connection": {
                                  "_id": "mediola-gateway.0.info.connection",
                                  "type": "state",
                                  "common": {
                                    "role": "indicator.connected",
                                    "name": "Device or service connected",
                                    "type": "boolean",
                                    "read": true,
                                    "write": false,
                                    "def": false
                                  "native": {},
                                  "ts": 1765095568706,
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                  "val": true,
                                  "ack": true
                                "mediola-gateway.0.receivedIrData": {
                                  "type": "state",
                                  "common": {
                                    "name": "receivedIrData",
                                    "type": "string",
                                    "role": "text",
                                    "read": true,
                                    "write": false
                                  "native": {},
                                  "ts": 1765031419920,
                                  "_id": "mediola-gateway.0.receivedIrData",
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                "mediola-gateway.0.sendIrData": {
                                  "type": "state",
                                  "common": {
                                    "name": "sendIrData",
                                    "type": "string",
                                    "role": "text",
                                    "read": true,
                                    "write": true
                                  "native": {},
                                  "ts": 1765031419934,
                                  "_id": "mediola-gateway.0.sendIrData",
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                "mediola-gateway.0.sendRfData": {
                                  "type": "state",
                                  "common": {
                                    "name": "sendRfData",
                                    "type": "string",
                                    "role": "text",
                                    "read": true,
                                    "write": true
                                  "native": {},
                                  "ts": 1765031419942,
                                  "_id": "mediola-gateway.0.sendRfData",
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                "mediola-gateway.0.state.WR1B284D01": {
                                  "type": "state",
                                  "common": {
                                    "name": "WIR 1B284D01",
                                    "type": "number",
                                    "role": "text",
                                    "read": true,
                                    "write": false
                                  "native": {},
                                  "ts": 1765036293380,
                                  "_id": "mediola-gateway.0.state.WR1B284D01",
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                  "val": 0,
                                  "ack": true
                                "mediola-gateway.0.sysvars": {
                                  "type": "folder",
                                  "common": {
                                    "name": "sysvars"
                                  "ts": 1765095568750,
                                  "_id": "mediola-gateway.0.sysvars",
                                  "acl": {
                                    "object": 1636,
                                "mediola-gateway.admin": {
                                  "type": "meta",
                                  "common": {
                                    "name": "admin",
                                    "type": "admin"
                                  "from": "system.host.iobroker.cli",
                                  "ts": 1765031411050,
                                  "native": {},
                                  "_id": "mediola-gateway.admin",
                                  "acl": {
                                    "object": 1636,
                              • Sven RoweS Offline
                                Sven RoweS Offline
                                Sven Rowe
                                #135
                                Ich versuche den Adapter in einer 2. Instanz zu starten. Abwechselnd bekomme ich beide Instanzen zum laufen. Die 2. Instanz meldet mir folgendes:
                                mediola-gateway.1
                                2026-01-20 18:05:19.876	info	terminating
                                mediola-gateway.1
                                2026-01-20 18:05:19.374	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                mediola-gateway.1
                                2026-01-20 18:05:19.373	info	terminating
                                mediola-gateway.1
                                2026-01-20 18:05:19.372	error	Exception-Code: EADDRINUSE: bind EADDRINUSE 0.0.0.0:1902
                                mediola-gateway.1
                                2026-01-20 18:05:19.372	error	Error: bind EADDRINUSE 0.0.0.0:1902 at node:dgram:397:20 at process.processTicksAndRejections (node:internal/process/task_queues:91:21)
                                mediola-gateway.1
                                2026-01-20 18:05:19.371	error	uncaught exception: bind EADDRINUSE 0.0.0.0:1902
                                mediola-gateway.1
                                2026-01-20 18:05:19.370	info	with ip: 192.168.178.20
                                mediola-gateway.1
                                2026-01-20 18:05:19.328	error	mediola device not reached by getting sys vars
                                mediola-gateway.1
                                2026-01-20 18:05:19.328	error	Unexpected end of JSON input
                                mediola-gateway.1
                                2026-01-20 18:05:19.327	debug	"{XC_SUC}"
                                mediola-gateway.1
                                2026-01-20 18:05:19.320	debug	Source: onReady
                                mediola-gateway.1
                                2026-01-20 18:05:19.312	debug	http://192.168.178.20/command?XC_USER=user&XC_PASS=2347&XC_FNC=getstates
                                mediola-gateway.1
                                2026-01-20 18:05:19.312	debug	validMediola: true sysvarInti: false timerRead: false cmd false pull false
                                mediola-gateway.1
                                2026-01-20 18:05:19.312	info	find by ip: true
                                mediola-gateway.1
                                2026-01-20 18:05:19.312	info	find by mac: undefined
                                mediola-gateway.1
                                2026-01-20 18:05:19.312	info	auto detection: false
                                mediola-gateway.1
                                2026-01-20 18:05:19.282	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.mediola-gateway, node: v22.22.0, js-controller: 7.0.7
                                mediola-gateway.1
                                2026-01-20 18:05:19.169	debug	States connected to redis: 127.0.0.1:9000
                                mediola-gateway.1
                                2026-01-20 18:05:19.093	debug	States create User PubSub Client
                                mediola-gateway.1
                                2026-01-20 18:05:19.092	debug	States create System PubSub Client
                                mediola-gateway.1
                                2026-01-20 18:05:19.075	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                mediola-gateway.1
                                2026-01-20 18:05:19.053	debug	Objects connected to redis: 127.0.0.1:9001
                                mediola-gateway.1
                                2026-01-20 18:05:19.051	debug	Objects client initialize lua scripts
                                mediola-gateway.1
                                2026-01-20 18:05:19.006	debug	Objects create User PubSub Client
                                mediola-gateway.1
                                2026-01-20 18:05:19.006	debug	Objects create System PubSub Client
                                mediola-gateway.1
                                2026-01-20 18:05:18.964	debug	Objects client ready ... initialize now
                                mediola-gateway.1
                                2026-01-20 18:05:18.941	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                • Sven RoweS Sven Rowe
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  mediola-gateway.1
                                  oelisonO Offline
                                  oelisonO Offline
                                  oelison
                                  #136
                                  @Sven-Rowe Hallo!
                                  Der Adapter versucht eine Mediola automatisch zu finden. Wahrscheinlich finden beide Adapter die gleiche Mediola. Dafür kann über die IP-Adresse oder die MAC-Addresse eingeschränkt werden. Einfach mal in den Einstellungen stöbern. Bin gerade nicht am Rechner.
