  4. Flot Diagramm - history nicht wählbar
73 Beiträge 5 Kommentatoren 2.9k Aufrufe 4 Beobachtet
    @muttileinchen-0 sieht alles gut aus.
    18000 flot und 28000 history Nutzer haben bisher noch nichts gemeldet.
    letzte Hoffnung: iob diag bitte
    Muttileinchen 0
    schrieb am zuletzt editiert von Muttileinchen 0
    ======== Start marking the full check here =========
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Architecture:   x86_64
    Docker:         false
    Virtualization: lxc
    Distributor ID: Ubuntu
    Description:    Ubuntu 22.04.1 LTS
    Release:        22.04
    Codename:       jammy
    PRETTY_NAME="Ubuntu 22.04.1 LTS"
    NAME="Ubuntu"
    VERSION_ID="22.04"
    VERSION="22.04.1 LTS (Jammy Jellyfish)"
    VERSION_CODENAME=jammy
    ID=ubuntu
    ID_LIKE=debian
    HOME_URL="https://www.ubuntu.com/"
    SUPPORT_URL="https://help.ubuntu.com/"
    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
    UBUNTU_CODENAME=jammy
    Systemuptime and Load:
     19:56:30 up  1:18,  2 users,  load average: 0.38, 0.40, 0.57
    CPU threads: 2
    *** Time and Time Zones ***
    Wed Mar  1 19:56:30 UTC 2023
    UTC +0000
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            2.0G        1.5G         49M        0.0K        540M        589M
    Swap:           2.0G        266M        1.8G
    Total:          4.1G        1.7G        1.8G
             2048 M total memory
             1458 M used memory
              602 M active memory
             1302 M inactive memory
               49 M free memory
                0 M buffer memory
              540 M swap cache
             2048 M total swap
              266 M used swap
             1781 M free swap
    *** FILESYSTEM ***
    Filesystem     Type   Size  Used Avail Use% Mounted on
    /dev/loop0     ext4   7.8G  2.9G  4.5G  39% /
    none           tmpfs  492K  4.0K  488K   1% /dev
    tmpfs          tmpfs  1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs  739M   96K  739M   1% /run
    tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
    Messages in dmesg:
    dmesg: read kernel buffer failed: Operation not permitted
    Show mounted filesystems (real ones only):
    TARGET SOURCE     FSTYPE OPTIONS
    /      /dev/loop0 ext4   rw,relatime
    /var:
    562M    /var/
    233M    /var/cache
    231M    /var/lib
    227M    /var/cache/apt
    142M    /var/cache/apt/archives
    /opt/iobroker/backups:
    239M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    245M    /opt/iobroker/iobroker-data/
    171M    /opt/iobroker/iobroker-data/files
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    36M     /opt/iobroker/iobroker-data/backup-objects
    32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    24M     /opt/iobroker/iobroker-data/states.jsonl
    11M     /opt/iobroker/iobroker-data/objects.jsonl
    8.5M    /opt/iobroker/iobroker-data/files/vis.0/vis/vis-views.json
    7.7M    /opt/iobroker/iobroker-data/files/vis.0/neu/vis-views.json
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.14.2
    /usr/bin/node           v18.14.2
    /usr/bin/npm            9.5.0
    /usr/bin/npx            9.5.0
    nodejs:
      Installed: 18.14.2-deb-1nodesource1
      Candidate: 18.14.2-deb-1nodesource1
      Version table:
     *** 18.14.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
            100 /var/lib/dpkg/status
         12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   1
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : IOBroker-Uli                             -  enabled
    + system.adapter.admin.0                  : admin                 : IOBroker-Uli                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : IOBroker-Uli                             -  enabled
      system.adapter.daswetter.0              : daswetter             : IOBroker-Uli                             -  enabled
    + system.adapter.discovery.0              : discovery             : IOBroker-Uli                             -  enabled
      system.adapter.dwd.0                    : dwd                   : IOBroker-Uli                             -  enabled
      system.adapter.flot.0                   : flot                  : IOBroker-Uli                             -  enabled
    + system.adapter.followthesun.0           : followthesun          : IOBroker-Uli                             -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : IOBroker-Uli                             - disabled
    + system.adapter.garmin.0                 : garmin                : IOBroker-Uli                             -  enabled
    + system.adapter.history.0                : history               : IOBroker-Uli                             -  enabled
      system.adapter.ical.0                   : ical                  : IOBroker-Uli                             -  enabled
      system.adapter.ical.1                   : ical                  : IOBroker-Uli                             -  enabled
      system.adapter.ical.2                   : ical                  : IOBroker-Uli                             -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : IOBroker-Uli                             -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IOBroker-Uli                             -  enabled
      system.adapter.imow.0                   : imow                  : IOBroker-Uli                             - disabled
    + system.adapter.javascript.0             : javascript            : IOBroker-Uli                             -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : IOBroker-Uli                             -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.ping.0                   : ping                  : IOBroker-Uli                             -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : IOBroker-Uli                             -  enabled
    + system.adapter.shelly.0                 : shelly                : IOBroker-Uli                             -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : IOBroker-Uli                             -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : IOBroker-Uli                             -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : IOBroker-Uli                             -  enabled
    + system.adapter.trashschedule.1          : trashschedule         : IOBroker-Uli                             -  enabled
      system.adapter.vis-bars.0               : vis-bars              : IOBroker-Uli                             -  enabled
      system.adapter.vis-history.0            : vis-history           : IOBroker-Uli                             -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IOBroker-Uli                             -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : IOBroker-Uli                             -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : IOBroker-Uli                             -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IOBroker-Uli                             -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : IOBroker-Uli                             -  enabled
      system.adapter.vis-metro.0              : vis-metro             : IOBroker-Uli                             -  enabled
      system.adapter.vis-players.0            : vis-players           : IOBroker-Uli                             -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : IOBroker-Uli                             -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : IOBroker-Uli                             -  enabled
      system.adapter.vis.0                    : vis                   : IOBroker-Uli                             -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : IOBroker-Uli                             -  enabled
    + system.adapter.web.0                    : web                   : IOBroker-Uli                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.ws.0                     : ws                    : IOBroker-Uli                             -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
    Adapter    "admin"        : 6.3.5    , installed 6.3.5
    Adapter    "backitup"     : 2.5.12   , installed 2.5.12
    Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "followthesun" : 0.4.1    , installed 0.4.1
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "garmin"       : 0.0.3    , installed 0.0.3
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "ical"         : 1.13.2   , installed 1.13.2
    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
    Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
    Adapter    "imow"         : 0.0.2    , installed 0.0.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
    Adapter    "ping"         : 1.5.3    , installed 1.5.3
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "socketio"     : 4.2.0    , installed 4.2.0
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "vw-connect"   : 0.0.62   , installed 0.0.62
    Adapter    "web"          : 4.3.0    , installed 4.3.0
    Adapter    "ws"           : 1.3.0    , installed 1.3.0
    Objects and States
    Objects:        14656
    States:         13324
    Hit:1 https://deb.nodesource.com/node_18.x jammy InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
    Reading package lists...
    Pending Updates: 92
    *** Listening Ports ***
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        27796      99/systemd-resolved
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          27202      1/init
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       28882      116/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       28889      116/iobroker.js-con
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          32760      707/master
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       29070      207/io.mqtt.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          27509      1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          27204      1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          32761      707/master
    tcp6       0      0 :::8084                 :::*                    LISTEN      1000       32198      426/io.ws.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       28621      381/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       28129      158/io.admin.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       29194      245/io.shelly.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        27795      99/systemd-resolved
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          27203      1/init
    udp6       0      0 :::111                  :::*                                0          27205      1/init
    2023-03-01 19:55:40.971  - error: garmin.0 (547) TypeError: Cannot convert undefined or null to object
    2023-03-01 19:55:40.973  - error: garmin.0 (547) Cannot extract array dailystress.bodyBatteryValuesArray169
    2023-03-01 19:55:40.974  - error: garmin.0 (547) TypeError: Cannot convert undefined or null to object
    2023-03-01 19:55:40.976  - error: garmin.0 (547) Cannot extract array dailystress.bodyBatteryValuesArray170
    2023-03-01 19:55:40.976  - error: garmin.0 (547) TypeError: Cannot convert undefined or null to object
    2023-03-01 19:55:40.980  - error: garmin.0 (547) Cannot extract array dailystress.bodyBatteryValuesArray171
    2023-03-01 19:55:40.980  - error: garmin.0 (547) TypeError: Cannot convert undefined or null to object
    2023-03-01 19:55:40.983  - error: garmin.0 (547) Cannot extract array dailystress.bodyBatteryValuesArray172
    2023-03-01 19:55:40.983  - error: garmin.0 (547) TypeError: Cannot convert undefined or null to object
    2023-03-01 19:55:40.985  - error: garmin.0 (547) Cannot extract array dailystress.bodyBatteryValuesArray173
    2023-03-01 19:55:40.986  - error: garmin.0 (547) TypeError: Cannot convert undefined or null to object
    2023-03-01 19:55:40.988  - error: garmin.0 (547) Cannot extract array dailystress.bodyBatteryValuesArray174
    2023-03-01 19:55:40.988  - error: garmin.0 (547) TypeError: Cannot convert undefined or null to object
    2023-03-01 19:55:40.991  - error: garmin.0 (547) Cannot extract array dailystress.bodyBatteryValuesArray175
    2023-03-01 19:55:40.991  - error: garmin.0 (547) TypeError: Cannot convert undefined or null to object
    2023-03-01 19:55:40.994  - error: garmin.0 (547) Cannot extract array dailystress.bodyBatteryValuesArray176
    2023-03-01 19:55:40.994  - error: garmin.0 (547) TypeError: Cannot convert undefined or null to object
    2023-03-01 19:55:40.997  - error: garmin.0 (547) Cannot extract array dailystress.bodyBatteryValuesArray177
    2023-03-01 19:55:40.997  - error: garmin.0 (547) TypeError: Cannot convert undefined or null to object
    2023-03-01 19:55:41.043  - error: garmin.0 (547) Cannot extract array dailystress.bodyBatteryValuesArray178
    2023-03-01 19:55:41.043  - error: garmin.0 (547) TypeError: Cannot convert undefined or null to object
    2023-03-01 19:55:41.050  - error: garmin.0 (547) Cannot extract array dailystress.bodyBatteryValuesArray179
    2023-03-01 19:55:41.050  - error: garmin.0 (547) TypeError: Cannot convert undefined or null to object
    2023-03-01 19:55:41.094  - error: garmin.0 (547) Cannot extract array dailystress.bodyBatteryValuesArray180
    2023-03-01 19:55:41.095  - error: garmin.0 (547) TypeError: Cannot convert undefined or null to object
      Muttileinchen 0
                           v.2023-01-02
      Operatingsystem:        Ubuntu 22.04.1 LTS
      Installation:           lxc
      Timezone:               Etc/UTC
      User-ID:                0
      X-Server:               false
      Pending OS-Updates:     92
      Nodejs-Installation:    /usr/bin/nodejs         v18.14.2
                              /usr/bin/npm            9.5.0
                              /usr/bin/npx            9.5.0
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Status admin:
      Pending iob updates:    0
      Objects:                14656
      States:                 13324
      Size of iob-Database:
      • M Muttileinchen 0
                             v.2023-01-02
        Installation:           lxc
        Timezone:               Etc/UTC
        User-ID:                0
        X-Server:               false
                                /usr/bin/npm            9.5.0
                                /usr/bin/npx            9.5.0
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Status admin:
        Objects:                14656
        States:                 13324
        @muttileinchen-0 Danke!
        auf die Schnelle 3 Dinge die mir nicht gefallen
        • Container
        • Ubuntu (kenn ich persönlicj nur als Troublemaker, insbesondere mit node)
        • npm v9
        ob da die gesamte Installation sauber ist hab ich jetzt nicht geprüft.
        Da wäre @thomas-braun sowieso der bessere Ansprechpartner.
          • Container
          • npm v9
          Muttileinchen 0
          @homoran gut, bis hierhin herzlichen Dank. Wenn nicht Ubuntu direkte Gegenfrage, welche Du stattdessen empfehlen würdest. Danke.
          • M Muttileinchen 0
            @muttileinchen-0 sagte in Flot Diagramm - history nicht wählbar:
            Wenn nicht Ubuntu
            Die Mutter Debian
              Wenn nicht Ubuntu
              Die Mutter Debian
              Muttileinchen 0
              @homoran Danke. In dem Fall Debian 11?
              Interessant ist dabei, dass alles andere ja läuft. Wirklich bis auf Flot gar keine Probleme bisher. Hm...
              HomoranH bahnuhrB 2 Antworten Letzte Antwort
              • M Muttileinchen 0
                alles andere ja läuft... bisher.
                wann hast du npm upgegradet?
                npm9 läuft nicht unbedingt
                • M Muttileinchen 0
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  Dein log
                  sagt was anderes.
                  Danke.
                  • bahnuhrB bahnuhr
                    Dein log
                    sagt was anderes.
                    Muttileinchen 0
                    @bahnuhr Seit heute.
                      Muttileinchen 0
                      @homoran vor 3 Tagen erst. Flot lief schon vorher nicht. gibt es einen workaround für ein downgrade?
                      • M Muttileinchen 0
                        boah ey ;-) und das von mir.
                        ja, gibt es aber da müsste ich auch suchen. irgendwas wie sudo apt reinstall nodejs
                        nur ob das die korrekte Syntax ist weiss ich nicht
                        • M Muttileinchen 0
                          @muttileinchen-0
                          Deine Systemzeit stimmt auch nicht.
                          Von nodejs@18 ganz abgesehen.
                          Und 92 Updates in der Pipeline.
                          root shell....
                            @muttileinchen-0
                            root shell....
                            Muttileinchen 0
                            Hallo Thomas,
                            danke für Deinen Kommentar.
                            Leider kann ich nicht alles deuten, daher erhelle mich bitte:
                            • Systemzeit Einstellung muss ich noch finden, bekomme ich aber hin.
                            • Was ist falsch an Node18?
                            • 92 Updates mittlerweile behoben, null Auswirkung
                            • was ist Der Hinweis mit root shell?
                            Bin ein Linux noob, und ich weiß das es anstrengend ist Usern hier das 1x1 beizubringen. Habe aber nicht auf alles Antworten finden können, daher wäre es schön vollständige Antworten zu bekommen anstatt eine Aufzählung was offensichtlich "falsch" ist, ohne zu verstehen warum...
                            Danke vorab.
                            Thomas BraunT HomoranH 5 Antworten Letzte Antwort
                            • M Muttileinchen 0
                              Hallo Thomas,
                              Danke vorab.
                              Die vorgesehene Version ist per heute node@16
                              Regelmäßig machen.
                              Man hampelt nicht als root durch das System. Im iob auf proxmox-HowTo wird es richtig gemacht. Lies dir das an.
                              • M Muttileinchen 0
                                Hallo Thomas,
                                Danke vorab.
                                ich fürchte nach der ganzen Predigerei warum man nicht als root agieren soll muss ich wohl tatsächlich dazu noch einen Thread aufmachen jnd anpinnen.
                                Das wichtigste ist, dass Dinge, die der user root gemacht hat, möglicherweise durch den Systemuser iobroker nicht genutzt wrden können
                                • M Muttileinchen 0
                                  Hallo Thomas,
                                  Danke vorab.
                                  ist noch nicht 100% iobroker kompatibel, npm v9 schon gar nicht
                                  • M Muttileinchen 0
                                    Hallo Thomas,
                                    Danke vorab.
                                    in Zusammenhang mit der Nutzung des root, jetzt bitte iobroker fix durchführen.
                                    Wenn der Root nicht etwas zu sehr verbogen hat richtet der Fixer das Rechtegefüge wieder
                                      Wobei die aktuellste nodeJS@18 npm@9 im Gepäck hat. Das passt also hier schon zusammen, ist aber insgesamt halt zu hoch versioniert.
                                      • M Muttileinchen 0
                                        Hallo Thomas,
                                        Danke vorab.
                                        null Auswirkung
                                        Wenn wegen falscher Laufzeitumgebung (nodejs/npm) etwas nicht korrekt installiert wurde, nutzen Änderungen daran oder Updates erst beim nächsten Install etwas
                                          Muttileinchen 0
                                          @homoran Mache ich.
                                          Quintessenz für mich:
                                          • anstatt root einen user erstellen (Anleitung suche ich noch)
                                          • npm auf Version 8 reduzieren (wie nur?)
                                          • iobroker fix durchführen, wobei ich das schon gemacht hatte.
