  4. Fehler bei Installation i2c Adapter
    3.1k
    3.1k
58 Beiträge 4 Kommentatoren 5.5k Aufrufe 3 Beobachtet
  • C Chris_B
    @wendy2702
    here it is:
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     18:03:09 up 40 min,  1 user,  load average: 1.54, 1.01, 0.64
    CPU threads: 4
    *** Time and Time Zones ***
    Sat Feb 11 17:03:09 UTC 2023
    Sat Feb 11 18:03:09 CET 2023
    CET +0100
    Europe/Zurich
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker pijuice
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        980M        2.3G         24M        560M        2.9G
    Swap:           99M          0B         99M
    Total:         3.9G        980M        2.4G
             3838 M total memory
              980 M used memory
              335 M active memory
             1046 M inactive memory
             2297 M free memory
              127 M buffer memory
              433 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       15G  4.6G  9.2G  34% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     1.9G   25M  1.9G   2% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    Messages in dmesg:
    [Sat Feb 11 17:22:11 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:A8:12:03 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=cd3e8f54-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Sat Feb 11 17:22:13 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Feb 11 17:22:13 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sat Feb 11 17:22:16 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Show mounted filesystems (real ones only):
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    502M    /var/
    294M    /var/cache
    288M    /var/cache/apt
    229M    /var/cache/apt/archives
    92M     /var/lib
    /opt/iobroker/backups:
    21M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    222M    /opt/iobroker/iobroker-data/
    105M    /opt/iobroker/iobroker-data/files
    94M     /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    7.6M    /opt/iobroker/iobroker-data/objects.jsonl
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    6.2M    /opt/iobroker/iobroker-data/objects.json.migrated
    6.2M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.0
    /usr/bin/node           v16.19.0
    /usr/bin/npm            8.19.3
    /usr/bin/npx            8.19.3
    nodejs:
      Installed: 16.19.0-deb-1nodesource1
      Candidate: 16.19.0-deb-1nodesource1
      Version table:
     *** 16.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
            100 /var/lib/dpkg/status
         10.24.0~dfsg-1~deb10u2 500
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.backitup.0               : backitup              : raspberrypi4-iob                         -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi4-iob                         -  enabled
    + system.adapter.denon.0                  : denon                 : raspberrypi4-iob                         -  enabled
    + system.adapter.denon.1                  : denon                 : raspberrypi4-iob                         -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi4-iob                         -  enabled
      system.adapter.flot.0                   : flot                  : raspberrypi4-iob                         - disabled
    + system.adapter.heos.0                   : heos                  : raspberrypi4-iob                         -  enabled
    + system.adapter.history.0                : history               : raspberrypi4-iob                         -  enabled
    + system.adapter.hue.0                    : hue                   : raspberrypi4-iob                         -  enabled, port: 80
    + system.adapter.hue.1                    : hue                   : raspberrypi4-iob                         -  enabled, port: 80
    + system.adapter.info.0                   : info                  : raspberrypi4-iob                         -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi4-iob                         -  enabled
    + system.adapter.netatmo.0                : netatmo               : raspberrypi4-iob                         -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi4-iob                         -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4-iob                         -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspberrypi4-iob                         -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : raspberrypi4-iob                         -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4-iob                         - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi4-iob                         -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi4-iob                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : raspberrypi4-iob                         -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.3.5    , installed 6.3.5
    Adapter    "backitup"     : 2.5.12   , installed 2.5.12
    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
    Adapter    "denon"        : 1.13.4   , installed 1.13.4
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "email"        : 1.1.4    , installed 1.1.4
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "heos"         : 1.10.0   , installed 1.10.0
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "homekit-controller": 0.5.1, installed 0.5.1
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
    Adapter    "ping"         : 1.5.3    , installed 1.5.3
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "socketio"     : 4.2.0    , installed 4.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "web"          : 4.3.0    , installed 4.3.0
    Adapter    "ws"           : 1.3.0    , installed 1.3.0
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    Objects and States
    Objects:        3093
    States:         2599
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 https://phoscon.de/apt/deconz buster InRelease
    Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
    Hit:4 http://archive.raspberrypi.org/debian buster InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17590      585/sshd
    tcp        0      0 127.0.0.1:43801         0.0.0.0:*               LISTEN      1001       191843     21588/io.yahka.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       187068     20468/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       187061     20468/iobroker.js-c
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       189559     20489/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       191294     21389/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       191171     21098/io.socketio.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17592      585/sshd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       190525     20863/io.simple-api
    tcp6       0      0 :::34381                :::*                    LISTEN      1001       193677     21588/io.yahka.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16640      573/dhcpcd
    udp        0      0 0.0.0.0:42135           0.0.0.0:*                           1001       188978     20815/io.heos.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       193678     21588/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12814      377/avahi-daemon: r
    udp        0      0 0.0.0.0:41800           0.0.0.0:*                           108        12816      377/avahi-daemon: r
    udp6       0      0 :::38941                :::*                                108        12817      377/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          16653      573/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        12815      377/avahi-daemon: r
    2023-02-11 18:02:07.466  - info: cloud.0 (20724) Trying to connect as system.user.admin to cloud
    2023-02-11 18:02:07.601  - info: cloud.0 (20724) Connection changed: connect
    2023-02-11 18:02:08.580  - info: vis.0 (21336) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.24
    2023-02-11 18:02:08.791  - info: vis.0 (21336) vis license is OK.
    2023-02-11 18:02:09.456  - info: vis.0 (21336) Terminated (NO_ERROR): Without reason
    2023-02-11 18:02:10.134  - info: host.raspberrypi4-iob instance system.adapter.vis.0 terminated while should be started once
    2023-02-11 18:02:10.923  - info: host.raspberrypi4-iob instance system.adapter.web.0 started with pid 21389
    2023-02-11 18:02:14.861  - info: host.raspberrypi4-iob instance system.adapter.yahka.0 started with pid 21588
    2023-02-11 18:02:17.276  - info: yahka.0 (21588) starting. Version 0.13.1 in /opt/iobroker/node_modules/iobroker.yahka, node: v16.19.0, js-controller: 4.0.24
    2023-02-11 18:02:17.314  - info: yahka.0 (21588) adapter ready, checking config
    2023-02-11 18:02:17.329  - info: yahka.0 (21588) adding Wasser Höfli 1A with UUID: 10c354a6-9830-470f-9a77-a332861ef8a9
    2023-02-11 18:02:17.342  - info: yahka.0 (21588) adding Wasser Höfli 2A with UUID: e801a2ae-6c62-44d0-870f-a7a316e4a4b6
    2023-02-11 18:02:17.346  - info: yahka.0 (21588) adding Wasser Garten 3A with UUID: e7a975c7-14b7-4db6-93c9-a5c06b0f0906
    2023-02-11 18:02:17.350  - info: yahka.0 (21588) adding Wasser Garten 4A with UUID: b19d1566-51f7-4dbf-a436-f10b00d4d3bf
    2023-02-11 18:02:17.354  - info: yahka.0 (21588) adding Wasser Garten 5A with UUID: cfba9462-495d-445e-bdaf-92d89e5d323c
    2023-02-11 18:02:17.358  - info: yahka.0 (21588) adding Wasser Feedback 1 with UUID: 80efd4c4-8f76-48b0-b794-663ac97d7d2a
    2023-02-11 18:02:17.362  - info: yahka.0 (21588) adding Wasser Feedback 2 with UUID: c7c1a3fe-b438-43eb-a479-bbda51d1d6c8
    2023-02-11 18:02:17.366  - info: yahka.0 (21588) adding Wasser Feedback 3 with UUID: 3270564c-f984-4208-88ed-bcafad48b3e3
    2023-02-11 18:02:17.370  - info: yahka.0 (21588) adding Wasser Feedback 4 with UUID: 94316748-7b8a-456d-9813-e1529df2ff42
    2023-02-11 18:02:17.375  - info: yahka.0 (21588) adding Wasser Feedback 5 with UUID: 192619c5-90be-4580-8af2-9cdd5282fc7a
    2023-02-11 18:02:17.379  - info: yahka.0 (21588) adding Wasser Feedback 6 with UUID: 442ced11-b93a-4a60-9eaf-d6b789ce2e54
    2023-02-11 18:02:17.382  - info: yahka.0 (21588) adding Wasser Garten 6A with UUID: 5356872a-1195-47ad-a30c-62d253157baf
    2023-02-11 18:02:17.386  - info: yahka.0 (21588) adding Motion Cat1 with UUID: 01ba38ce-6b34-4467-8989-7af6f0774eeb
    2023-02-11 18:02:17.389  - info: yahka.0 (21588) adding Motion Cat2 with UUID: 9122c6a7-6598-4298-84f5-ecc8c2598e8d
    2023-02-11 18:02:17.392  - info: yahka.0 (21588) publishing bridge Yahka-0 on 0.0.0.0 using ciao
    und Teil2:
                         v.2023-01-02
    Operatingsystem:        Raspbian GNU/Linux 10 (buster)
    Installation:           Native
    Timezone:               Europe/Zurich
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                            /usr/bin/npm            8.19.3
                            /usr/bin/npx            8.19.3
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Status admin:
    Pending iob updates:    0
    Objects:                3093
    States:                 2599
    Size of iob-Database:
    1.8M    /opt/iobroker/iobroker-data/states.jsonl
    684K    /opt/iobroker/iobroker-data/states.json.migrated
    684K    /opt/iobroker/iobroker-data/states.json.bak.migrated
    wendy2702W Online
    wendy2702W Online
    wendy2702
    @chris_b Log vom fixer ?
    C 1 Antwort Letzte Antwort
    • wendy2702W wendy2702
      Chris_B
      @wendy2702 Sorry muss jetzt weg, liefere ich später nach. fixer läuft aus meiner Sicht problemlos durch. Ich poste es später nochmals.
      wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
      • C Chris_B
        wendy2702W Online
        wendy2702W Online
        wendy2702
        @chris_b Kein Stress bin auch gleich weg
        • C Chris_B
          @chris_b
          Bring dein System auf Debian11/Bullseye.
            Chris_B
            @wendy2702 Hier nun das log vom fixer (aber da sehe ich auch keine wesentliche Info, die auf ein potentielles Problem hindeutet):
            library: loaded
            Library version=2022-12-09
                Welcome to the ioBroker installation fixer!
                Script version: 2022-12-22
                You might need to enter your password a couple of times.
                Installing prerequisites (1/4)
            Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
            OK:2 http://archive.raspberrypi.org/debian buster InRelease
            OK:3 https://deb.nodesource.com/node_16.x buster InRelease
            OK:4 https://phoscon.de/apt/deconz buster InRelease
            Es wurden 15.0 kB in 1 s geholt (10.2 kB/s).
            Installed gcc-c++
                Checking ioBroker user and directory permissions (2/4)
            Created /etc/sudoers.d/iobroker
                Database maintenance (3/4)
            Checking for uncompressed JSONL databases... This might take a while!
            Compressing /opt/iobroker/iobroker-data/states.jsonl
            Compressing /opt/iobroker/iobroker-data/objects.jsonl
            Compressed 2 JSONL files. Done
                Checking autostart (4/4)
            Enabling autostart...
            Autostart enabled!
            • C Chris_B
              library: loaded
              Installed gcc-c++
              Autostart enabled!
              @chris_b
                @chris_b
                Chris_B
                @thomas-braun Ich höre Dich klar und deutlich, Thomas. Ich war nur so freundlich die Frage von wendy2702 zu beantworten. Danke.
                • C Chris_B
                  @chris_b
                  Ist halt die Frage welche Baustelle man zuerst angeht. Das Betriebssystem ist dringlicher.
                    @chris_b
                    Chris_B
                    @thomas-braun Ich habe mir nun Zeit genommen mein OS auf Bullseye upzudaten. Vielen Dank für Deine Anleitung
                    https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                    Update ist gelungen, ich bin jetzt auf Bullseye mit Node.js: v16.19.1 und NPM: v8.19.3.
                    iobroker läuft wieder ohne Probleme.
                    Der Versuch den i2c Adapter zu installieren endet im Wesentlichen mit der gleichen Fehlermeldung. Hat in dieser Sache also noch keinen Fortschritt gebracht.
                    • C Chris_B
                      @chris_b
                      Dann kannst du ja mit aktuellem OS nochmal
                      iob diag
                      ausführen und bzgl. der Installation auch die vollständigen Rückmeldungen aus dem logfile oder dem Terminal bekannt geben.
                        @chris_b
                        iob diag
                        Chris_B
                        @thomas-braun Hier die Infos:
                        Aus iob diag
                        Skript v.2023-01-02
                        *** BASE SYSTEM ***
                        Docker:         false
                        Description:    Raspbian GNU/Linux 11 (bullseye)
                        Release:        11
                        Codename:       bullseye
                        PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                        VERSION_ID="11"
                        VERSION="11 (bullseye)"
                        VERSION_CODENAME=bullseye
                        ID=raspbian
                        ID_LIKE=debian
                         15:50:10 up 43 min,  1 user,  load average: 0.35, 0.25, 0.31
                        CPU threads: 4
                        Sat Feb 18 14:50:10 UTC 2023
                        Sat Feb 18 15:50:10 CET 2023
                        CET +0100
                        Europe/Zurich
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            3.8G        1.1G        2.4G        0.0K        312M        2.9G
                        Swap:            99M          0B         99M
                        Total:          3.9G        1.1G        2.5G
                                 3838 M total memory
                                 1105 M used memory
                                  184 M active memory
                                 1127 M inactive memory
                                 2420 M free memory
                                   50 M buffer memory
                                  262 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        *** FILESYSTEM ***
                        /dev/root      ext4       15G  4.8G  9.0G  35% /
                        tmpfs          tmpfs     768M  688K  768M   1% /run
                        /dev/mmcblk0p1 vfat      253M   50M  203M  20% /boot
                        Messages in dmesg:
                        [Sat Feb 18 15:06:39 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:A8:12:03 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=cd3e8f54-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                        [Sat Feb 18 15:06:42 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                        [Sat Feb 18 15:06:42 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Sat Feb 18 15:06:44 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                        /var:
                        548M    /var/
                        299M    /var/cache
                        294M    /var/cache/apt
                        95M     /var/lib
                        234M    /opt/iobroker/iobroker-data/
                        20M     /opt/iobroker/iobroker-data/objects.jsonl
                        /usr/bin/nodejs         v16.19.1
                        /usr/bin/node           v16.19.1
                        /usr/bin/npm            8.19.3
                        /usr/bin/npx            8.19.3
                        nodejs:
                          Installed: 16.19.1-deb-1nodesource1
                          Candidate: 16.19.1-deb-1nodesource1
                          Version table:
                         *** 16.19.1-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                             12.22.12~dfsg-1~deb11u3 500
                                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.3.5
                        javascript:     6.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        3096
                        States:         2594
                        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                        Hit:4 https://phoscon.de/apt/deconz bullseye InRelease
                        Pending Updates: 0
                        tcp        0      0 127.0.0.1:44821         0.0.0.0:*               LISTEN      1001       56591      13999/io.yahka.0
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       52502      12844/iobroker.js-c
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       52495      12844/iobroker.js-c
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          10727      483/sshd: /usr/sbin
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       56445      13795/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       51533      12879/io.admin.0
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       53094      13274/io.simple-api
                        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       52191      13449/io.socketio.0
                        tcp6       0      0 :::39029                :::*                    LISTEN      1001       56583      13999/io.yahka.0
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          10729      483/sshd: /usr/sbin
                        udp        0      0 0.0.0.0:49190           0.0.0.0:*                           1001       51872      13217/io.heos.0
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14614      645/dhcpcd
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       56584      13999/io.yahka.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11680      363/avahi-daemon: r
                        udp        0      0 0.0.0.0:53498           0.0.0.0:*                           108        11682      363/avahi-daemon: r
                        udp6       0      0 :::546                  :::*                                0          14642      645/dhcpcd
                        udp6       0      0 :::5353                 :::*                                108        11681      363/avahi-daemon: r
                        udp6       0      0 :::52971                :::*                                108        11683      363/avahi-daemon: r
                        2023-02-18 15:17:24.642  - info: yahka.0 (13999) adding Wasser Höfli 2A with UUID: e801a2ae-6c62-44d0-870f-a7a316e4a4b6
                        2023-02-18 15:17:24.646  - info: yahka.0 (13999) adding Wasser Garten 3A with UUID: e7a975c7-14b7-4db6-93c9-a5c06b0f0906
                        2023-02-18 15:17:24.651  - info: yahka.0 (13999) adding Wasser Garten 4A with UUID: b19d1566-51f7-4dbf-a436-f10b00d4d3bf
                        2023-02-18 15:17:24.654  - info: yahka.0 (13999) adding Wasser Garten 5A with UUID: cfba9462-495d-445e-bdaf-92d89e5d323c
                        2023-02-18 15:17:24.659  - info: yahka.0 (13999) adding Wasser Feedback 1 with UUID: 80efd4c4-8f76-48b0-b794-663ac97d7d2a
                        2023-02-18 15:17:24.662  - info: yahka.0 (13999) adding Wasser Feedback 2 with UUID: c7c1a3fe-b438-43eb-a479-bbda51d1d6c8
                        2023-02-18 15:17:24.666  - info: yahka.0 (13999) adding Wasser Feedback 3 with UUID: 3270564c-f984-4208-88ed-bcafad48b3e3
                        2023-02-18 15:17:24.671  - info: yahka.0 (13999) adding Wasser Feedback 4 with UUID: 94316748-7b8a-456d-9813-e1529df2ff42
                        2023-02-18 15:17:24.675  - info: yahka.0 (13999) adding Wasser Feedback 5 with UUID: 192619c5-90be-4580-8af2-9cdd5282fc7a
                        2023-02-18 15:17:24.678  - info: yahka.0 (13999) adding Wasser Feedback 6 with UUID: 442ced11-b93a-4a60-9eaf-d6b789ce2e54
                        2023-02-18 15:17:24.682  - info: yahka.0 (13999) adding Wasser Garten 6A with UUID: 5356872a-1195-47ad-a30c-62d253157baf
                        2023-02-18 15:17:24.686  - info: yahka.0 (13999) adding Motion Cat1 with UUID: 01ba38ce-6b34-4467-8989-7af6f0774eeb
                        2023-02-18 15:17:24.689  - info: yahka.0 (13999) adding Motion Cat2 with UUID: 9122c6a7-6598-4298-84f5-ecc8c2598e8d
                        2023-02-18 15:17:24.692  - info: yahka.0 (13999) publishing bridge Yahka-0 on 0.0.0.0 using ciao
                        2023-02-18 15:19:16.604  - info: admin.0 (12879) ==> Connected system.user.admin from ::ffff:192.168.1.137
                        2023-02-18 15:21:14.629  - info: host.raspberrypi4-iob iobroker add i2c auto --host raspberrypi4-iob --debug
                        2023-02-18 15:21:18.476  - info: host.raspberrypi4-iob iobroker NPM version: 8.19.3
                        2023-02-18 15:21:18.480  - info: host.raspberrypi4-iob iobroker Installing iobroker.i2c@1.2.1... (System call)
                        2023-02-18 15:21:27.131  - info: host.raspberrypi4-iob iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/i2c-bus
                        2023-02-18 15:21:27.137  - info: host.raspberrypi4-iob iobroker npm ERR! command failed
                        2023-02-18 15:21:27.138  - info: host.raspberrypi4-iob iobroker npm ERR! command sh -c -- node-gyp rebuildnpm ERR! node:internal/modules/cjs/loader:1024npm ERR!   throw err;npm ERR!   ^npm ERR! npm ERR! Error: Cannot find module 'object-assign'npm ERR! Require stack:npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js
                        2023-02-18 15:21:27.148  - info: host.raspberrypi4-iob iobroker npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:866:27)npm ERR!     at Module.require (node:internal/modules/cjs/loader:1093:19)npm ERR!     at require (node:internal/modules/cjs/helpers:108:18)npm ERR!     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js:4:20)npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1191:14)npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)npm ERR!     at Module.load (node:internal/modules/cjs/loader:1069:32)npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:904:12)npm ERR!     at Module.require (node:internal/modules/cjs/loader:1093:19) {npm ERR!   code: 'MODULE_NOT_FOUND',npm ERR!   requireStack: [npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js',npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js',npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js',npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js',npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js',npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js'npm ERR!   ]npm ERR! }npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2023-02-18T14_21_19_654Z-debug-0.log
                        2023-02-18 15:21:27.176  - error: host.raspberrypi4-iob iobroker host.raspberrypi4-iob Cannot install iobroker.i2c@1.2.1: 1
                        2023-02-18 15:21:28.217  - info: host.raspberrypi4-iob iobroker exit 25
                        2023-02-18 15:28:25.784  - info: admin.0 (12879) <== Disconnect system.user.admin from ::ffff:192.168.1.137 admin
                                             v.2023-01-02
                        Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
                        User-ID:                1000
                        X-Server:               false
                        Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                                                /usr/bin/npm            8.19.3
                                                /usr/bin/npx            8.19.3
                                                admin                   6.3.5
                        Objects type: jsonl
                        States  type: jsonl
                        Status admin:
                        Objects:                3096
                        States:                 2594
                        2.1M    /opt/iobroker/iobroker-data/states.jsonl
                        Und hier noch das log (wieder diese superlangen Zeilen):
                        	2023-02-18 15:21:28.217	info	iobroker exit 25
                        	2023-02-18 15:21:27.176	error	iobroker host.raspberrypi4-iob Cannot install iobroker.i2c@1.2.1: 1
                        	2023-02-18 15:21:27.148	info	iobroker npm ERR! at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:866:27)npm ERR! at Module.require (node:internal/modules/cjs/loader:1093:19)npm ERR! at require (node:internal/modules/cjs/helpers:108:18)npm ERR! at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js:4:20)npm ERR! at Module._compile (node:internal/modules/cjs/loader:1191:14)npm ERR! at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)npm ERR! at Module.load (node:internal/modules/cjs/loader:1069:32)npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:904:12)npm ERR! at Module.require (node:internal/modules/cjs/loader:1093:19) {npm ERR! code: 'MODULE_NOT_FOUND',npm ERR! requireStack: [npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js'npm ERR! ]npm ERR! }npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-02-18T14_21_19_654Z-debug-0.log
                        	2023-02-18 15:21:27.138	info	iobroker npm ERR! command sh -c -- node-gyp rebuildnpm ERR! node:internal/modules/cjs/loader:1024npm ERR! throw err;npm ERR! ^npm ERR! npm ERR! Error: Cannot find module 'object-assign'npm ERR! Require stack:npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js
                        	2023-02-18 15:21:27.137	info	iobroker npm ERR! command failed
                        	2023-02-18 15:21:27.131	info	iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/i2c-bus
                        	2023-02-18 15:21:18.480	info	iobroker Installing iobroker.i2c@1.2.1... (System call)
                        Die alternative Lösung ist, dass ich mein i2c Gerät anders ansteuere (über python oder ein C++ Programm) und die Daten dann an iobroker übergebe.
                        • C Chris_B
                          Aus iob diag
                          Skript v.2023-01-02
                          *** BASE SYSTEM ***
                          Docker:         false
                          Release:        11
                          Codename:       bullseye
                          VERSION_ID="11"
                          ID=raspbian
                          ID_LIKE=debian
                          CPU threads: 4
                          CET +0100
                          Europe/Zurich
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            99M          0B         99M
                                   3838 M total memory
                                   1105 M used memory
                                    184 M active memory
                                   2420 M free memory
                                     50 M buffer memory
                                    262 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          *** FILESYSTEM ***
                          Messages in dmesg:
                          /var:
                          548M    /var/
                          299M    /var/cache
                          294M    /var/cache/apt
                          95M     /var/lib
                          /usr/bin/npm            8.19.3
                          /usr/bin/npx            8.19.3
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.3.5
                          javascript:     6.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        3096
                          States:         2594
                          Pending Updates: 0
                                               v.2023-01-02
                          User-ID:                1000
                          X-Server:               false
                                                  /usr/bin/npm            8.19.3
                                                  /usr/bin/npx            8.19.3
                                                  admin                   6.3.5
                          Objects type: jsonl
                          States  type: jsonl
                          Status admin:
                          Objects:                3096
                          States:                 2594
                          @chris_b
                          Warum hast du nicht die 64bit-Version genommen?
                            @chris_b
                            Chris_B
                            @thomas-braun Ja, das ist mir auch aufgefallen. Ich habe den Update nach Deiner Anleitung durchgeführt, und das ursprüngliche System war eben noch 32-bit. Der Update bleibt auf dieser Variante, so wie ich das verstehe. 64-bit würde eine komplette Neuinstallation bedeuten, korrekt?
                            • C Chris_B
                              @chris_b
                              Ja, richtig.
                              • C Chris_B
                                @chris_b
                                cd /opt/iobroker
                                npm ls
                                npm ls object-assign
                                  @chris_b
                                  cd /opt/iobroker
                                  npm ls
                                  Chris_B
                                  @thomas-braun So sieht es aus:
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  ├── @types/caseless@0.12.2 extraneous
                                  ├── @types/request@2.48.8 extraneous
                                  ├── @types/tough-cookie@4.0.2 extraneous
                                  ├── coffeescript@1.12.7 extraneous
                                  ├── iobroker.admin@6.3.5
                                  ├── iobroker.backitup@2.5.12
                                  ├── iobroker.cloud@4.3.0
                                  ├── iobroker.denon@1.13.4
                                  ├── iobroker.discovery@3.1.0
                                  ├── iobroker.email@1.1.4
                                  ├── iobroker.flot@1.11.0
                                  ├── iobroker.heos@1.10.0
                                  ├── iobroker.history@2.2.4
                                  ├── iobroker.homekit-controller@0.5.1
                                  ├── iobroker.hue@3.7.1
                                  ├── iobroker.info@1.9.19
                                  ├── iobroker.javascript@6.1.4
                                  ├── iobroker.js-controller@4.0.24
                                  ├── iobroker.netatmo@2.0.5
                                  ├── iobroker.ping@1.5.3
                                  ├── iobroker.rpi2@1.3.2
                                  ├── iobroker.simple-api@2.7.2
                                  ├── iobroker.socketio@4.2.0
                                  ├── iobroker.vis-hqwidgets@1.3.0
                                  ├── iobroker.vis@1.4.15
                                  ├── iobroker.web@4.3.0
                                  ├── iobroker.yahka@0.13.1
                                  ├── jsonata@1.8.6 extraneous
                                  ├── node-inspect@2.0.0 extraneous
                                  ├── picocolors@1.0.0 extraneous
                                  ├── suncalc2@1.8.1 extraneous
                                  ├── typescript@4.8.2 extraneous
                                  ├── virtual-tsc@0.6.2 extraneous
                                  └── wake_on_lan@1.0.0 extraneous
                                  └─┬ iobroker.homekit-controller@0.5.1
                                    └─┬ hap-controller@0.8.1
                                      └─┬ @abandonware/noble@1.9.2-15
                                        └─┬ @abandonware/bluetooth-hci-socket@0.5.3-8
                                          └─┬ @mapbox/node-pre-gyp@1.0.9
                                            └─┬ npmlog@5.0.1
                                              └─┬ gauge@3.0.2
                                                └── object-assign@4.1.1
                                  • C Chris_B
                                              └─┬ npmlog@5.0.1
                                                └─┬ gauge@3.0.2
                                    @chris_b
                                    cd /opt/iobroker
                                    npm cache clear --force
                                    iobroker add i2c --debug
                                    Bitte immer vollständig aus der Konsole kopieren, inkl. log in prompt usw.
                                    C 2 Antworten Letzte Antwort
                                      @chris_b
                                      cd /opt/iobroker
                                      Chris_B
                                      @thomas-braun Das löschen des Caches scheint auch nichts zu bringen.
                                      pi@raspberrypi4-iob:/opt/iobroker $ npm cache clear --force
                                      npm WARN using --force Recommended protections disabled.
                                      pi@raspberrypi4-iob:/opt/iobroker $ iobroker add i2c auto --debug
                                      NPM version: 8.19.3
                                      npm ERR! code 1
                                      npm ERR!   throw err;
                                      npm ERR!   ^
                                      npm ERR!
                                      npm ERR!     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/r    ender-template.js:4:20)
                                      npm ERR!   ]
                                      npm ERR! }
                                      npm ERR!     /home/iobroker/.npm/_logs/2023-02-18T15_54_49_210Z-debug-0.log
                                        @chris_b
                                        cd /opt/iobroker
                                        Chris_B
                                        @thomas-braun Bemerkung dazu: Ich habe davor iobroker nicht gestoppt. Ist das korrekt?
                                        • C Chris_B
                                          @chris_b
                                          apt policy npm node-gyp nodejs
