  4. Fehler bei Installation i2c Adapter
    5.5k
58 Beiträge 4 Kommentatoren 5.7k Aufrufe 3 Beobachtet
    @chris_b
    Dann kannst du ja mit aktuellem OS nochmal
    iob diag
    ausführen und bzgl. der Installation auch die vollständigen Rückmeldungen aus dem logfile oder dem Terminal bekannt geben.
    Chris_B
    @thomas-braun Hier die Infos:
    Aus iob diag
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     15:50:10 up 43 min,  1 user,  load average: 0.35, 0.25, 0.31
    CPU threads: 4
    *** Time and Time Zones ***
    Sat Feb 18 14:50:10 UTC 2023
    Sat Feb 18 15:50:10 CET 2023
    CET +0100
    Europe/Zurich
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker pijuice
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        1.1G        2.4G        0.0K        312M        2.9G
    Swap:            99M          0B         99M
    Total:          3.9G        1.1G        2.5G
             3838 M total memory
             1105 M used memory
              184 M active memory
             1127 M inactive memory
             2420 M free memory
               50 M buffer memory
              262 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       15G  4.8G  9.0G  35% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     768M  688K  768M   1% /run
    /dev/mmcblk0p1 vfat      253M   50M  203M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    Messages in dmesg:
    [Sat Feb 18 15:06:39 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:A8:12:03 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=cd3e8f54-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Sat Feb 18 15:06:42 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Sat Feb 18 15:06:42 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sat Feb 18 15:06:44 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    548M    /var/
    299M    /var/cache
    294M    /var/cache/apt
    229M    /var/cache/apt/archives
    95M     /var/lib
    /opt/iobroker/backups:
    21M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    234M    /opt/iobroker/iobroker-data/
    105M    /opt/iobroker/iobroker-data/files
    94M     /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    20M     /opt/iobroker/iobroker-data/objects.jsonl
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    6.2M    /opt/iobroker/iobroker-data/objects.json.migrated
    6.2M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.1
    /usr/bin/node           v16.19.1
    /usr/bin/npm            8.19.3
    /usr/bin/npx            8.19.3
    nodejs:
      Installed: 16.19.1-deb-1nodesource1
      Candidate: 16.19.1-deb-1nodesource1
      Version table:
     *** 16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u3 500
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.backitup.0               : backitup              : raspberrypi4-iob                         -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi4-iob                         -  enabled
    + system.adapter.denon.0                  : denon                 : raspberrypi4-iob                         -  enabled
    + system.adapter.denon.1                  : denon                 : raspberrypi4-iob                         -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi4-iob                         -  enabled
      system.adapter.flot.0                   : flot                  : raspberrypi4-iob                         - disabled
    + system.adapter.heos.0                   : heos                  : raspberrypi4-iob                         -  enabled
    + system.adapter.history.0                : history               : raspberrypi4-iob                         -  enabled
    + system.adapter.hue.0                    : hue                   : raspberrypi4-iob                         -  enabled, port: 80
    + system.adapter.hue.1                    : hue                   : raspberrypi4-iob                         -  enabled, port: 80
    + system.adapter.info.0                   : info                  : raspberrypi4-iob                         -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi4-iob                         -  enabled
    + system.adapter.netatmo.0                : netatmo               : raspberrypi4-iob                         -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi4-iob                         -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4-iob                         -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspberrypi4-iob                         -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : raspberrypi4-iob                         -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4-iob                         - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi4-iob                         -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi4-iob                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : raspberrypi4-iob                         -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.5.12   , installed 2.5.12
    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
    Adapter    "denon"        : 1.13.4   , installed 1.13.4
    Adapter    "email"        : 1.1.4    , installed 1.1.4
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "heos"         : 1.10.0   , installed 1.10.0
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "homekit-controller": 0.5.1, installed 0.5.1
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    Objects and States
    Objects:        3096
    States:         2594
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:4 https://phoscon.de/apt/deconz bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:44821         0.0.0.0:*               LISTEN      1001       56591      13999/io.yahka.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       52502      12844/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       52495      12844/iobroker.js-c
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          10727      483/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       56445      13795/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       51533      12879/io.admin.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       53094      13274/io.simple-api
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       52191      13449/io.socketio.0
    tcp6       0      0 :::39029                :::*                    LISTEN      1001       56583      13999/io.yahka.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          10729      483/sshd: /usr/sbin
    udp        0      0 0.0.0.0:49190           0.0.0.0:*                           1001       51872      13217/io.heos.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14614      645/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       56584      13999/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11680      363/avahi-daemon: r
    udp        0      0 0.0.0.0:53498           0.0.0.0:*                           108        11682      363/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          14642      645/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        11681      363/avahi-daemon: r
    udp6       0      0 :::52971                :::*                                108        11683      363/avahi-daemon: r
    2023-02-18 15:17:24.642  - info: yahka.0 (13999) adding Wasser Höfli 2A with UUID: e801a2ae-6c62-44d0-870f-a7a316e4a4b6
    2023-02-18 15:17:24.646  - info: yahka.0 (13999) adding Wasser Garten 3A with UUID: e7a975c7-14b7-4db6-93c9-a5c06b0f0906
    2023-02-18 15:17:24.651  - info: yahka.0 (13999) adding Wasser Garten 4A with UUID: b19d1566-51f7-4dbf-a436-f10b00d4d3bf
    2023-02-18 15:17:24.654  - info: yahka.0 (13999) adding Wasser Garten 5A with UUID: cfba9462-495d-445e-bdaf-92d89e5d323c
    2023-02-18 15:17:24.659  - info: yahka.0 (13999) adding Wasser Feedback 1 with UUID: 80efd4c4-8f76-48b0-b794-663ac97d7d2a
    2023-02-18 15:17:24.662  - info: yahka.0 (13999) adding Wasser Feedback 2 with UUID: c7c1a3fe-b438-43eb-a479-bbda51d1d6c8
    2023-02-18 15:17:24.666  - info: yahka.0 (13999) adding Wasser Feedback 3 with UUID: 3270564c-f984-4208-88ed-bcafad48b3e3
    2023-02-18 15:17:24.671  - info: yahka.0 (13999) adding Wasser Feedback 4 with UUID: 94316748-7b8a-456d-9813-e1529df2ff42
    2023-02-18 15:17:24.675  - info: yahka.0 (13999) adding Wasser Feedback 5 with UUID: 192619c5-90be-4580-8af2-9cdd5282fc7a
    2023-02-18 15:17:24.678  - info: yahka.0 (13999) adding Wasser Feedback 6 with UUID: 442ced11-b93a-4a60-9eaf-d6b789ce2e54
    2023-02-18 15:17:24.682  - info: yahka.0 (13999) adding Wasser Garten 6A with UUID: 5356872a-1195-47ad-a30c-62d253157baf
    2023-02-18 15:17:24.686  - info: yahka.0 (13999) adding Motion Cat1 with UUID: 01ba38ce-6b34-4467-8989-7af6f0774eeb
    2023-02-18 15:17:24.689  - info: yahka.0 (13999) adding Motion Cat2 with UUID: 9122c6a7-6598-4298-84f5-ecc8c2598e8d
    2023-02-18 15:17:24.692  - info: yahka.0 (13999) publishing bridge Yahka-0 on 0.0.0.0 using ciao
    2023-02-18 15:19:16.604  - info: admin.0 (12879) ==> Connected system.user.admin from ::ffff:192.168.1.137
    2023-02-18 15:21:14.629  - info: host.raspberrypi4-iob iobroker add i2c auto --host raspberrypi4-iob --debug
    2023-02-18 15:21:18.476  - info: host.raspberrypi4-iob iobroker NPM version: 8.19.3
    2023-02-18 15:21:18.480  - info: host.raspberrypi4-iob iobroker Installing iobroker.i2c@1.2.1... (System call)
    2023-02-18 15:21:27.131  - info: host.raspberrypi4-iob iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/i2c-bus
    2023-02-18 15:21:27.137  - info: host.raspberrypi4-iob iobroker npm ERR! command failed
    2023-02-18 15:21:27.138  - info: host.raspberrypi4-iob iobroker npm ERR! command sh -c -- node-gyp rebuildnpm ERR! node:internal/modules/cjs/loader:1024npm ERR!   throw err;npm ERR!   ^npm ERR! npm ERR! Error: Cannot find module 'object-assign'npm ERR! Require stack:npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js
    2023-02-18 15:21:27.148  - info: host.raspberrypi4-iob iobroker npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:866:27)npm ERR!     at Module.require (node:internal/modules/cjs/loader:1093:19)npm ERR!     at require (node:internal/modules/cjs/helpers:108:18)npm ERR!     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js:4:20)npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1191:14)npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)npm ERR!     at Module.load (node:internal/modules/cjs/loader:1069:32)npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:904:12)npm ERR!     at Module.require (node:internal/modules/cjs/loader:1093:19) {npm ERR!   code: 'MODULE_NOT_FOUND',npm ERR!   requireStack: [npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js',npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js',npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js',npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js',npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js',npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js'npm ERR!   ]npm ERR! }npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2023-02-18T14_21_19_654Z-debug-0.log
    2023-02-18 15:21:27.176  - error: host.raspberrypi4-iob iobroker host.raspberrypi4-iob Cannot install iobroker.i2c@1.2.1: 1
    2023-02-18 15:21:28.217  - info: host.raspberrypi4-iob iobroker exit 25
    2023-02-18 15:28:25.784  - info: admin.0 (12879) <== Disconnect system.user.admin from ::ffff:192.168.1.137 admin
                         v.2023-01-02
    Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
    Installation:           Native
    Timezone:               Europe/Zurich
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                            /usr/bin/npm            8.19.3
                            /usr/bin/npx            8.19.3
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Status admin:
    Pending iob updates:    0
    Objects:                3096
    States:                 2594
    Size of iob-Database:
    2.1M    /opt/iobroker/iobroker-data/states.jsonl
    684K    /opt/iobroker/iobroker-data/states.json.migrated
    684K    /opt/iobroker/iobroker-data/states.json.bak.migrated
    Und hier noch das log (wieder diese superlangen Zeilen):
    	2023-02-18 15:21:28.217	info	iobroker exit 25
    	2023-02-18 15:21:27.176	error	iobroker host.raspberrypi4-iob Cannot install iobroker.i2c@1.2.1: 1
    	2023-02-18 15:21:27.148	info	iobroker npm ERR! at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:866:27)npm ERR! at Module.require (node:internal/modules/cjs/loader:1093:19)npm ERR! at require (node:internal/modules/cjs/helpers:108:18)npm ERR! at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js:4:20)npm ERR! at Module._compile (node:internal/modules/cjs/loader:1191:14)npm ERR! at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)npm ERR! at Module.load (node:internal/modules/cjs/loader:1069:32)npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:904:12)npm ERR! at Module.require (node:internal/modules/cjs/loader:1093:19) {npm ERR! code: 'MODULE_NOT_FOUND',npm ERR! requireStack: [npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js'npm ERR! ]npm ERR! }npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-02-18T14_21_19_654Z-debug-0.log
    	2023-02-18 15:21:27.138	info	iobroker npm ERR! command sh -c -- node-gyp rebuildnpm ERR! node:internal/modules/cjs/loader:1024npm ERR! throw err;npm ERR! ^npm ERR! npm ERR! Error: Cannot find module 'object-assign'npm ERR! Require stack:npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js
    	2023-02-18 15:21:27.137	info	iobroker npm ERR! command failed
    	2023-02-18 15:21:27.131	info	iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/i2c-bus
    	2023-02-18 15:21:18.480	info	iobroker Installing iobroker.i2c@1.2.1... (System call)
    Die alternative Lösung ist, dass ich mein i2c Gerät anders ansteuere (über python oder ein C++ Programm) und die Daten dann an iobroker übergebe.
    • C Chris_B
      Aus iob diag
      Skript v.2023-01-02
      *** BASE SYSTEM ***
      Docker:         false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      CET +0100
      Europe/Zurich
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               3838 M total memory
               1105 M used memory
                184 M active memory
               2420 M free memory
                 50 M buffer memory
                262 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      Messages in dmesg:
      /var:
      548M    /var/
      299M    /var/cache
      294M    /var/cache/apt
      95M     /var/lib
      /usr/bin/npm            8.19.3
      /usr/bin/npx            8.19.3
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        3096
      States:         2594
      Pending Updates: 0
                           v.2023-01-02
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            8.19.3
                              /usr/bin/npx            8.19.3
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Status admin:
      Objects:                3096
      States:                 2594
      @chris_b
      Warum hast du nicht die 64bit-Version genommen?
      C 1 Antwort Letzte Antwort
        @chris_b
        Chris_B
        @thomas-braun Ja, das ist mir auch aufgefallen. Ich habe den Update nach Deiner Anleitung durchgeführt, und das ursprüngliche System war eben noch 32-bit. Der Update bleibt auf dieser Variante, so wie ich das verstehe. 64-bit würde eine komplette Neuinstallation bedeuten, korrekt?
        • C Chris_B
          @chris_b
          Ja, richtig.
          • C Chris_B
            @chris_b
            cd /opt/iobroker
            npm ls
            npm ls object-assign
              @chris_b
              cd /opt/iobroker
              npm ls
              Chris_B
              @thomas-braun So sieht es aus:
              iobroker.inst@3.0.0 /opt/iobroker
              ├── @types/caseless@0.12.2 extraneous
              ├── @types/request@2.48.8 extraneous
              ├── @types/tough-cookie@4.0.2 extraneous
              ├── coffeescript@1.12.7 extraneous
              ├── iobroker.admin@6.3.5
              ├── iobroker.backitup@2.5.12
              ├── iobroker.cloud@4.3.0
              ├── iobroker.denon@1.13.4
              ├── iobroker.discovery@3.1.0
              ├── iobroker.email@1.1.4
              ├── iobroker.flot@1.11.0
              ├── iobroker.heos@1.10.0
              ├── iobroker.history@2.2.4
              ├── iobroker.homekit-controller@0.5.1
              ├── iobroker.hue@3.7.1
              ├── iobroker.info@1.9.19
              ├── iobroker.javascript@6.1.4
              ├── iobroker.js-controller@4.0.24
              ├── iobroker.netatmo@2.0.5
              ├── iobroker.ping@1.5.3
              ├── iobroker.rpi2@1.3.2
              ├── iobroker.simple-api@2.7.2
              ├── iobroker.socketio@4.2.0
              ├── iobroker.vis-hqwidgets@1.3.0
              ├── iobroker.vis@1.4.15
              ├── iobroker.web@4.3.0
              ├── iobroker.yahka@0.13.1
              ├── jsonata@1.8.6 extraneous
              ├── node-inspect@2.0.0 extraneous
              ├── picocolors@1.0.0 extraneous
              ├── suncalc2@1.8.1 extraneous
              ├── typescript@4.8.2 extraneous
              ├── virtual-tsc@0.6.2 extraneous
              └── wake_on_lan@1.0.0 extraneous
              └─┬ iobroker.homekit-controller@0.5.1
                └─┬ hap-controller@0.8.1
                  └─┬ @abandonware/noble@1.9.2-15
                    └─┬ @abandonware/bluetooth-hci-socket@0.5.3-8
                      └─┬ @mapbox/node-pre-gyp@1.0.9
                        └─┬ npmlog@5.0.1
                          └─┬ gauge@3.0.2
                            └── object-assign@4.1.1
              • C Chris_B
                          └─┬ npmlog@5.0.1
                            └─┬ gauge@3.0.2
                @chris_b
                cd /opt/iobroker
                npm cache clear --force
                iobroker add i2c --debug
                Bitte immer vollständig aus der Konsole kopieren, inkl. log in prompt usw.
                C 2 Antworten Letzte Antwort
                  @chris_b
                  cd /opt/iobroker
                  Chris_B
                  @thomas-braun Das löschen des Caches scheint auch nichts zu bringen.
                  pi@raspberrypi4-iob:/opt/iobroker $ npm cache clear --force
                  npm WARN using --force Recommended protections disabled.
                  pi@raspberrypi4-iob:/opt/iobroker $ iobroker add i2c auto --debug
                  NPM version: 8.19.3
                  npm ERR! code 1
                  npm ERR!   throw err;
                  npm ERR!   ^
                  npm ERR!
                  npm ERR!     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/r    ender-template.js:4:20)
                  npm ERR!   ]
                  npm ERR! }
                  npm ERR!     /home/iobroker/.npm/_logs/2023-02-18T15_54_49_210Z-debug-0.log
                    @chris_b
                    cd /opt/iobroker
                    Chris_B
                    @thomas-braun Bemerkung dazu: Ich habe davor iobroker nicht gestoppt. Ist das korrekt?
                    • C Chris_B
                      @chris_b
                      apt policy npm node-gyp nodejs
                      • C Chris_B
                        @chris_b sagte in Fehler bei Installation i2c Adapter:
                        Das ist wurscht.
                          Das ist wurscht.
                          Chris_B
                          npm:
                            Installiert:           (keine)
                            Installationskandidat: 7.5.2+ds-2
                            Versionstabelle:
                               7.5.2+ds-2 500
                          node-gyp:
                            Installationskandidat: 7.1.2-4
                            Versionstabelle:
                               7.1.2-4 500
                          nodejs:
                            Installiert:           16.19.1-deb-1nodesource1
                            Installationskandidat: 16.19.1-deb-1nodesource1
                            Versionstabelle:
                          • C Chris_B
                            npm:
                              Versionstabelle:
                                 7.5.2+ds-2 500
                            node-gyp:
                              Versionstabelle:
                                 7.1.2-4 500
                            nodejs:
                              Versionstabelle:
                            @chris_b
                              @chris_b
                              Chris_B
                              @thomas-braun Sorry, eigentlich war das bis auf die Kommandozeile und die Zeile danach vollständig. Hier nochmals mit den zusätzlichen 2 Zeilen:
                              pi@raspberrypi4-iob:~ $ apt policy npm node-gyp nodejs
                              npm:
                                Versionstabelle:
                                   7.5.2+ds-2 500
                              node-gyp:
                                Versionstabelle:
                                   7.1.2-4 500
                              nodejs:
                                Versionstabelle:
                              • C Chris_B
                                npm:
                                  Versionstabelle:
                                     7.5.2+ds-2 500
                                node-gyp:
                                  Versionstabelle:
                                     7.1.2-4 500
                                nodejs:
                                  Versionstabelle:
                                @chris_b
                                iob stop
                                sudo apt install --reinstall nodejs
                                iob start
                                • C Chris_B
                                  npm:
                                    Versionstabelle:
                                       7.5.2+ds-2 500
                                  node-gyp:
                                    Versionstabelle:
                                       7.1.2-4 500
                                  nodejs:
                                    Versionstabelle:
                                  Und die fehlten halt. Anhand der Zeilen kann man viel besser sehen wo du da wie unterwegs bist und ob das vollständig ist.
                                    @chris_b
                                    iob stop
                                    iob start
                                    Chris_B
                                    pi@raspberrypi4-iob:~ $ iob stop
                                    pi@raspberrypi4-iob:~ $ sudo apt install --reinstall nodejs
                                    Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                                      bsdmainutils g++-8 geoip-database libbind9-161 libcroco3 libdns1104 libdns1110 libevent-2.1-6 libfl2
                                      libgdk-pixbuf2.0-0 libgeoip1 libicu63 libisc1100 libisc1105 libisccc161 libisccfg163 libisl19
                                      libjim0.77 libjsoncpp1 liblwres161 libmpdec2 libncursesw5 libperl5.28 libpython2-dev
                                      libpython2-stdlib libpython2.7 libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib
                                      libpython3.7 libpython3.7-minimal libpython3.7-stdlib libstdc++-8-dev perl-modules-5.28 python2
                                      python2-dev python2-minimal python2.7 python2.7-dev python2.7-minimal python3.7-minimal raspinfo
                                      rpi.gpio-common usb.ids
                                    Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                                    0 aktualisiert, 0 neu installiert, 1 erneut installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                    Es müssen 24.2 MB an Archiven heruntergeladen werden.
                                    Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
                                    Holen:1 https://deb.nodesource.com/node_16.x bullseye/main armhf nodejs armhf 16.19.1-deb-1nodesource1 [24.2 MB]
                                    Es wurden 24.2 MB in 2 s geholt (15.2 MB/s).
                                    (Lese Datenbank ... 57038 Dateien und Verzeichnisse sind derzeit installiert.)
                                    Vorbereitung zum Entpacken von .../nodejs_16.19.1-deb-1nodesource1_armhf.deb ...
                                    Entpacken von nodejs (16.19.1-deb-1nodesource1) über (16.19.1-deb-1nodesource1) ...
                                    nodejs (16.19.1-deb-1nodesource1) wird eingerichtet ...
                                    Trigger für man-db (2.9.4-2) werden verarbeitet ...
                                    pi@raspberrypi4-iob:~ $ iob start
                                      Chris_B
                                      @thomas-braun Und jetzt noch einmal über die Kommandozeile den i2c Adapter installieren versuchen?
                                      • C Chris_B
                                        @chris_b
                                        Versuch nochmal
                                          @chris_b
                                          Versuch nochmal
                                          Chris_B
                                          @thomas-braun Irgend etwas ist mit dem Adapter nicht OK. Ich glaube nicht, dass es an meinem System liegt.
                                          pi@raspberrypi4-iob:~ $ iobroker add i2c --debug
                                          NPM version: 8.19.3
                                          npm ERR! code 1
                                          npm ERR!   throw err;
                                          npm ERR!   ^
                                          npm ERR!
                                          npm ERR!   ]
                                          npm ERR! }
                                          npm ERR!     /home/iobroker/.npm/_logs/2023-02-18T16_18_11_324Z-debug-0.log
