  4. IR Lesekopf/NodeMCU per MQTT einbinden [gelöst ...]
79 Beiträge 7 Kommentatoren 10.8k Aufrufe 3 Beobachtet
    @wilfried_2 schneid mal nur das Blockly aus.
    dann kann ich es auch erkennen und man sieht nicht das ganze drumherum
    Außerdem wäre ein Output des debugs in code-tags hilfreich
    wenn ich das richtig entziffern kann, hast dub3 Blöcke außerhalb des Triggerbausteins. Die müssen da rein.
    W Offline
    W Offline
    Wilfried_2
    #61
    @homoran ```
    Das bekomme ich via Tasmota von meinem Zähler "ISKRA MT175"
    20:32:50.123 MQT: %Topic%/%Stromzaehler%/SENSOR = {"Time":"2023-02-04T20:32:50","MT175":{"P":392.00}}
    20:32:51.958 MQT: %Topic%/%Stromzaehler%/SENSOR = {"Time":"2023-02-04T20:32:51","MT175":{"P":393.00}}
    20:32:53.783 MQT: %Topic%/%Stromzaehler%/SENSOR = {"Time":"2023-02-04T20:32:53","MT175":{"P":393.00}}
    20:32:55.610 MQT: %Topic%/%Stromzaehler%/SENSOR = {"Time":"2023-02-04T20:32:55","MT175":{"P":393.00}}
    20:32:57.443 MQT: %Topic%/%Stromzaehler%/SENSOR = {"Time":"2023-02-04T20:32:57","MT175":{"P":393.00}}
    20:32:59.256 MQT: %Topic%/%Stromzaehler%/SENSOR = {"Time":"2023-02-04T20:32:59","MT175":{"P":393.00}}
    20:33:01.033 MQT: %Topic%/%Stromzaehler%/SENSOR = {"Time":"2023-02-04T20:33:01","MT175":{"P":397.00}}
    20:33:01.967 MQT: %Topic%/%Stromzaehler%/STATE = {"Time":"2023-02-04T20:33:01","Uptime":"0T04:00:21","UptimeSec":14421,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":25,"MqttCount":2,"Wifi":{"AP":1,"SSId":"01Speed22","BSSId":"C8:99:B2:5D:1C:5E","Channel":1,"Mode":"11n","RSSI":76,"Signal":-62,"LinkCount":1,"Downtime":"0T00:00:05"}}
    20:33:01.975 MQT: %Topic%/%Stromzaehler%/SENSOR = {"Time":"2023-02-04T20:33:01","MT175":{"E_in":7636.9,"P":397.00,"Server_ID":"090149534b000484fb20"}}
    20:33:02.820 MQT: %Topic%/%Stromzaehler%/SENSOR = {"Time":"2023-02-04T20:33:02","MT175":{"P":399.00}}
    20:33:04.620 MQT: %Topic%/%Stromzaehler%/SENSOR = {"Time":"2023-02-04T20:33:04","MT175":{"P":399.00}}
    20:33:06.426 MQT: %Topic%/%Stromzaehler%/SENSOR = {"Time":"2023-02-04T20:33:06","MT175":{"P":403.00}}
    20:33:08.201 MQT: %Topic%/%Stromzaehler%/SENSOR = {"Time":"2023-02-04T20:33:08","MT175":{"P":403.00}}
    20:33:10.007 MQT: %Topic%/%Stromzaehler%/SENSOR = {"Time":"2023-02-04T20:33:10","MT175":{"P":403.00}}
    20:33:11.751 MQT: %Topic%/%Stromzaehler%/SENSOR = {"Time":"2023-02-04T20:33:11","MT175":{"P":404.00}}
    20:33:13.560 MQT: %Topic%/%Stromzaehler%/SENSOR = {"Time":"2023-02-04T20:33:13","MT175":{"P":404.00}}
    20:33:15.356 MQT: %Topic%/%Stromzaehler%/SENSOR = {"Time":"2023-02-04T20:33:15","MT175":{"P":401.00}}
    20:33:17.148 MQT: %Topic%/%Stromzaehler%/SENSOR = {"Time":"2023-02-04T20:33:17","MT175":{"P":399.00}}
    In mqtt.0 sieht das so aus
      "Time": "2023-02-04T19:11:06",
      "MT175": {
        "P": 477
    Da fehlt meines erachtens schon mal der ges. Zählerstand. Ich habe herausgefunden, dass Zählerstand nur einmal pro Min. gesendet wird (Telemetry Period: 60).
    Das Blockly habe ich geändert und jetzt wird schonmal der "Aktuell"-Wert angezeigt. Der Gesamtverbrauch aber nicht.
    <variables>
    <variable id="o^VE=q/EJxRCU@p=Nq({">Verbrauch</variable>
    <variable id="yK^u+S#}N~|IeJsi~VAh">aktuell</variable>
    </variables>
    <block type="create" id="swB_9{Mg2QcF?v|UMaP#" x="-512" y="-62">
    <field name="NAME">0_userdata.0.Stromzähler.Verbrauch</field>
    <value name="VALUE">
    <block type="math_number" id="Z+;(EE9+ht]r5cCHBr1"> <field name="NUM">0</field> </block> </value> <value name="COMMON"> <block type="text" id="zn9[(J+$[cPEt,=~Ahf">
    <field name="TEXT">{"name": "Stromzähler.Verbrauch","type": "number","write": false}</field>
    </block>
    </value>
    <next>
    <block type="create" id="q9KBLu?K}gL2bnrM^kE">
    <field name="NAME">0_userdata.0.Stromzähler.Aktuell</field>
    <block type="math_number" id="ujd+dCs:F$C6dY^TE-Y#">
    </block>
    </value>
    <block type="text" id="i4dWZV|-U8
    %Q?EA(iJt">
    <field name="TEXT">{"name": "Stromzähler.Aktuell","type": "number","write": false}</field>
    </block>
    </value>
    <next>
    <block type="on_ext" id="p~c_9Fq1{DWv5J%;1?1H">
    <value name="OID0">
    <shadow type="field_oid" id="?g1f{w5n!;pGTzeI_1Fs">
    </shadow>
    <block type="field_oid" id="z=GDvQkiX8NSAqoo#H=w">
    <field name="oid">mqtt.0.%Topic%.%Stromzaehler%.SENSOR</field>
    </block>
    </value>
    <statement name="STATEMENT">
    <block type="variables_set" id="h|nP.?B6J~AHedSv8W,">
    <field name="VAR" id="o^VE=q/EJxRCU@p=Nq({">Verbrauch</field>
    <block type="get_attr" id="z:S4j%{$(p.V2z~;jxIk">
    <value name="PATH">
    <shadow type="text" id="3q5lsf*K
    :RzQ50%;Gtr">
    <field name="TEXT">MT175.E_in</field>
    </shadow>
    </value>
    <value name="OBJECT">
    <block type="on_source" id="MpJ$Vt{.;lSjqx%E^ds$">
    </block>
    </value>
    </block>
    </value>
    <next>
    <block type="variables_set" id="LkJtt}83K:V=*Q*oZln"> <field name="VAR" id="yK^u+S#}N~|IeJsi~VAh">aktuell</field> <value name="VALUE"> <block type="get_attr" id="*ovm[7(U%[}E=x^YeUgS"> <value name="PATH"> <shadow type="text" id="ao+m:*3H=8Pj(%2N$d-O"> <field name="TEXT">MT175.P</field> </shadow> </value> <value name="OBJECT"> <block type="on_source" id="v8$PYhv_^cHXK%EqZ]/E"> <field name="ATTR">state.val</field> </block> </value> </block> </value> <next> <block type="debug" id="(vG/K[#x+!Yx-14uihw">
    <value name="TEXT">
    <shadow type="text" id="MAp?W)hbI1Ne[[Ac;F7#">
    </shadow>
    <block type="text_join" id="q1~t(B|Y()[K{E(5XU%c">
    <mutation items="4"></mutation>
    <value name="ADD0">
    <block type="text" id="m=;?FK(d/O~Gn5NJv$J1">
    <field name="TEXT">Verbrauch: </field>
    </block>
    </value>
    <value name="ADD1">
    <block type="variables_get" id="*LYJsz5::!Lj,C}RecMB">
    </block>
    </value>
    <value name="ADD2">
    <block type="text" id="h2W^qqx{8[wl3|/JO|OX">
    <field name="TEXT">aktuell:</field>
    </block>
    </value>
    <value name="ADD3">
    <block type="variables_get" id="B0Vh]vU2LxerJvTd])f#">
    </block>
    </value>
    </block>
    </value>
    <next>
    <block type="update" id="vjeAJCkDo4LC=cG}Pp|1">
    <field name="OID">0_userdata.0.Stromzähler.Verbrauch</field>
    <block type="variables_get" id="ZO@m6Igkuar$n2kv!)4I">
    </block>
    </value>
    <next>
    <block type="update" id="J{{TRb8Hbkwqn{GzXpS9">
    <field name="OID">0_userdata.0.Stromzähler.Aktuell</field>
    <block type="variables_get" id="7Xn;#P#@kY?Qep9!SRrN">
    </block>
    </value>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </statement>
    </block>
    </next>
    </block>
    </next>
    </block>
    </xml>
    Das Script -Log gibt das aus :
    19:48:05.022	info	javascript.0 (1032) script.js.meine_scripte.Zaehler2: Verbrauch: aktuell:383
    19:48:05.023	info	javascript.0 (1032) script.js.meine_scripte.Zaehler2: setForeignState(id=0_userdata.0.Stromzähler.Verbrauch, state={"val":{"ack":true},"ack":true,"ts":1675536485023,"q":0,"from":"system.adapter.javascript.0","lc":1675536485023,"c":"script.js.meine_scripte.Zaehler2"})
    19:48:05.024	info	javascript.0 (1032) script.js.meine_scripte.Zaehler2: setForeignState(id=0_userdata.0.Stromzähler.Aktuell, state={"val":383,"ack":true,"ts":1675536485024,"q":0,"from":"system.adapter.javascript.0","lc":1675536483160,"c":"script.js.meine_scripte.Zaehler2"})
    Wieso aber der Verbrauch aber in mqtt.o nicht erscheint kann ich mir nicht erklären
    HomoranH T 2 Antworten Letzte Antwort
    • W Wilfried_2
      @homoran ```
        "MT175": {
          "P": 477
      <variables>
      </variables>
      </block>
      </value>
      <next>
      </block>
      </value>
      %Q?EA(iJt">
      </block>
      </value>
      <next>
      <value name="OID0">
      </shadow>
      </block>
      </value>
      <value name="PATH">
      :RzQ50%;Gtr">
      </shadow>
      </value>
      </block>
      </value>
      </block>
      </value>
      <next>
      <value name="TEXT">
      </shadow>
      <value name="ADD0">
      </block>
      </value>
      <value name="ADD1">
      </block>
      </value>
      <value name="ADD2">
      </block>
      </value>
      <value name="ADD3">
      </block>
      </value>
      </block>
      </value>
      <next>
      </block>
      </value>
      <next>
      </block>
      </value>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </statement>
      </block>
      </next>
      </block>
      </next>
      </block>
      </xml>
      #62
      @wilfried_2 sagte in IR Lesekopf/NodeMCU per MQTT einbinden [gelöst ...]:
      dann kann das Blockly auch nur E_in ausbdem JSON auslesen, wenn es auch drin ist.
      im Protokoll siehst du dassxes nur um 20:33:01 dabei ist
      • W Wilfried_2
        @homoran ```
          "MT175": {
            "P": 477
        <variables>
        </variables>
        </block>
        </value>
        <next>
        </block>
        </value>
        %Q?EA(iJt">
        </block>
        </value>
        <next>
        <value name="OID0">
        </shadow>
        </block>
        </value>
        <value name="PATH">
        :RzQ50%;Gtr">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        </block>
        </value>
        <value name="ADD3">
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </xml>
        TT-Tom
        #63
        @wilfried_2
        Werte bekommst du ja schon.
        Was mir aufgefallen ist, dass dein MQTT in Tasmota komische Einstellungen hat für den Full Topic.
        Hast du dein Zähler per Pin freigeschaltet? Sind mir zu wenig Daten.
        Zeige bitte mal die MQTT Einstellung von Tasmota und das Script in Tasmota zum auslesen des Zähler. Des Weiteren die Ordner vom MQTT.0, sind vermutlich wegen dem komischen Full Topic ach verteilt.
        Gruß Tom
        Public Transport
        NSPanel Adapter Wiki
        W 1 Antwort Letzte Antwort
        • W Offline
          W Offline
          Wilfried_2
          #64
          @tt-tom
          Hallo Tom,
          Ja der Zähler ist per PIN freigeschaltet. Aber die Werte für L1,L2,L3 werden nicht freigegeben. Ich habe die entsprechenden Zeilen im Script gelöcht.
          • T TT-Tom
            @wilfried_2
            W Offline
            W Offline
            Wilfried_2
            #65
            @tt-tom
            hier noch die Datenpunkte:
            • W Wilfried_2
              @tt-tom
              Hallo Tom,
              TT-Tom
              #66
              @tt-tom
              Hallo Tom,
              Um mehr Daten zu bekommen, musst du eventuell noch die Info auf „on“ setzen. Hast du eine Beschreibung zur Hand vom Zähler, dann suche mal nach erweiterter Datensatz oder so.
              Damit das sauber aussieht schreibe bei Topic: Stromzähler und bei Full Topic: %topic%/%prefix%/ rein.
              Danach musst du im Script den Datenpunkt nochmal anpassen.
              Kannst du mal in Tasmota in der Konsole „Sensor53 d1“ starten und die Ausgabe posten, ich möchte mal die Daten sehen die der Zähler ausspuckt.
              Gruß Tom
              Public Transport
              W 2 Antworten Letzte Antwort
              • T TT-Tom
                @tt-tom
                Hallo Tom,
                W Offline
                W Offline
                Wilfried_2
                #67
                @tt-tom
                Moin Tom,
                Das ist was der Zähler ausgibt.
                09:55:36.670 : 77 07 81 81 c7 82 05 ff 01 01 01 01 83 02 da 3d 3d 6b c3 b5 f5 a2 b9 de 94 5a c4 8e b6 de c4 b0 ea 7c 73 74 ff a1 2a 52
                09:55:36.673 : 77 01 0b 09 01 49 53 4b 00 04 84 fb 20 07 01 00 62 0a ff ff 72 62 01 65 04 c0 ce a6 7a
                09:55:36.719 : 77 07 81 81 c7 82 03 ff 01 01 01 01 04 49 53 4b 01
                09:55:36.722 : 77 07 01 00 00 00 09 ff 01 01 01 01 0b 09 01 49 53 4b 00 04 84 fb 20 01
                09:55:36.769 : 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 04 8d ba a6 01
                09:55:36.771 : 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 04 8d ba a6 01
                09:55:36.819 : 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01
                09:55:36.821 : 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01
                09:55:36.869 : 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01
                09:55:36.872 : 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01
                09:55:36.919 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 a7 01
                • W Wilfried_2
                  @tt-tom
                  Moin Tom,
                  TT-Tom
                  #68
                  @wilfried_2
                  Hallo hier mal ein Link, damit kannst du sehen was die Ausgabe bedeutet in Klartext. gleichzeitig bekommst du auch ein Vorschlag für das Script in Tasmota.
                  SML Decoder
                  hast du dein Topic angepasst?
                  Gruß Tom
                  Public Transport
                  • T TT-Tom
                    @tt-tom
                    Hallo Tom,
                    W Offline
                    W Offline
                    Wilfried_2
                    #69
                    @tt-tom
                    Was ich auch nicht so richtig verstehe ist, dass die Gesamtleistung nur einmal entsprechend des eingestellten Zeitintervalls ausgegeben wird die momentale Leistung alle paar Sekunden.
                    Mein Zähler speichert auch Werte für 1Tag, 7Tage, u.s.w. die ich auch am Zähler über ein blaue mechn. Taste abrufen kann aber übertragen werden diese Daten offensichtlicht nicht.
                    In der Bedienungsanleitung finde ich auch keinen Hinweis dafür ob oder wie man diese Funktion einschalten kann.
                    Gruß Wilfried
                    • T TT-Tom
                      @wilfried_2
                      SML Decoder
                      W Offline
                      W Offline
                      Wilfried_2
                      #70
                      @tt-tom
                      Ja Tom Topic habe ich angepaßt.
                      Kann man das empfolende Script 1-zu-1 in Tasmota einfühgen?
                      • W Wilfried_2
                        @tt-tom
                        Gruß Wilfried
                        TT-Tom
                        #71
                        @wilfried_2
                        1,77070100100700FF@1,aktuelle Wirkleistung,W,aktuelle_wirkleistung,0
                        die Letzte Zahl gibt den Intervall an, der über MQTT gesendet wird. Damit kannst du es steuern.
                        TelePeriod: See current value and force publish STATE and SENSOR message
                        0 = disable telemetry messages
                        1 = reset telemetry period to firmware default (TELE_PERIOD)
                        10..3600 = set telemetry period in seconds (default = 300)
                        Hier kannst du nochmal nachlesen.
                        Script Parameter
                        Tasmota Doku
                        Gruß Tom
                        Public Transport
                        • T TT-Tom
                          @wilfried_2
                          SML Decoder
                          W Offline
                          W Offline
                          Wilfried_2
                          #72
                          @tt-tom
                          Hallo Tom, dein Hinweis auf den SML Dekoder war glaube ich der "Bringer". Ich war mutig und habe das empfehlende Script so wie es war in die Tasmota Konfiguration eingefügt und siehe da, es hat auf Anhieb funktioniert. Es funktioniert jetzt auch das eingestellte Zeitintervall.
                          Nachdem ich auch das Blockly angepaßt habe bekomme ich jetzt auch korrekte Werte in den Datenpunkten.
                          Was leider immer noch nicht übertragen wird sind die erweiterten Daten vom Zähler.
                          aber damit kann ich leben wenn es dafür keine Lösung gibt.
                          ich werden jetzt alles noch ein bischen schön machen und kann mich dann um die Visualisierung kümmern.
                          Gruß Wilfried
                          T HomoranH 2 Antworten Letzte Antwort
                          • W Wilfried_2
                            @tt-tom
                            Gruß Wilfried
                            TT-Tom
                            #73
                            @wilfried_2
                            Wenn du auf die Blaue Taste drückst um durch das Menü zu laufen, Kommt da irgendwann der Text Info OFF.? Wenn Ja dann noch mal Kurz Drücken bis da ON steht. dann sollten auch die anderen Daten zur Verfügung stehen. Ist aber Sache des Messstellenbetreiber, was er an Daten freischaltet.
                            Gruß Tom
                            Public Transport
                            W S 2 Antworten Letzte Antwort
                            • T TT-Tom
                              @wilfried_2
                              W Offline
                              W Offline
                              Wilfried_2
                              #74
                              @tt-tom
                              Ok, das muß ich nochmal probieren. bis dahin erstmal vielen Dank für deine Hilfe.
                              • T TT-Tom
                                @wilfried_2
                                S Online
                                S Online
                                schweiger2
                                #75
                                @tt-tom
                                Ich habe diesen Thread aufmerksam gelesen und nachgestellt und bin sehr weit damit gekommen. Vielen Dank erst einmal dafür.
                                Ich nutze:
                                • MQTT Adapter als Broker/Client
                                • Tasmota auf NodeMCU mit IR-Lesekopf (Volkszähler)
                                An einem Punkt hänge ich noch: der Datenpunkt, der den Inhalt des Attributs abbilden soll, um den Wert an anderer Stelle (iQontrol) weiter nutzen zu können, enthält nur {"ack":true} anstelle eines Wertes.
                                Unter /tele/sensor wird der Eintrag {"Time": ...} laufend alle 10 sek. aktualisiert, das erkenne ich am sich ständig ändernden Zeiteintrag:
                                  "Time": "2023-03-07T11:35:15",
                                  "SML": {
                                    "Total_in": 39231.6,
                                    "Total_out": 0,
                                    "Power_curr": 457.7
                                Hier das Blockly, welches ich benutze:
                                Wo habe ich einen Span im Kopf ? Falls weitere Informationen benötigt werden, liefere ich diese gern.
                                Vielen Dank für deine bzw. eure Hilfe.
                                • W Wilfried_2
                                  @tt-tom
                                  Gruß Wilfried
                                  #76
                                  HistorischenDaten sind kein Bestandteil des OBIS Pflichtenhefts für die Kundenschnittstelle und werden daher nur ganz selten über diese zur Verfügung gestellt.
                                  • S schweiger2
                                    @tt-tom
                                    Ich nutze:
                                      "SML": {
                                        "Total_out": 0,
                                        "Power_curr": 457.7
                                    TT-Tom
                                    #77
                                    @schweiger2
                                    Schreibe mal „SML.Total_in“ und „SML.Power_curr“
                                    Dann sollten Werte ankommen.
                                    Gruß Tom
                                    Public Transport
                                    • T TT-Tom
                                      @schweiger2
                                      S Online
                                      S Online
                                      schweiger2
                                      #78
                                      @tt-tom
                                      Super, vielen vielen Dank. Funktioniert jetzt.
                                      • S schweiger2
                                        @tt-tom
                                        CodierknechtC Offline
                                        Codierknecht
                                        #79
                                        @schweiger2
                                        Das geht übrigens auch völlig ohne Programmierung mit einem Alias:
                                        HmIP|ZigBee|Tasmota|Unifi
                                        Zabbix Certified Specialist
