  4. Javascript Fehler mit unleserlichem Log
    5.6k
33 Beiträge 5 Kommentatoren 3.9k Aufrufe 3 Beobachtet
  • apollon77A apollon77
    Ok, wenn Du jetzt leserliche Fehler bekommst ist das ja cool ... jetzt bitte aber vollständig posten :-)
    Da gibts definit v mehr als die 2 Zeilen die Du gepostet hast
    Joshude
    @apollon77 said in Javascript Fehler mit unleserlichem Log:
    Leider weiterhin der gleiche Kauderwelsch... Hab die Zeilen, die was lesbares beinhalten aber mal beibehalten.
    info	Restart adapter system.adapter.javascript.0 because enabled
    error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    error	Caught by controller[1]: at processImmediate (node:internal/timers:468:21)
    error	Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:7439:39)
    error	Caught by controller[1]: at Object.formatAliasValue (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2479:19)
    error	Caught by controller[1]: (z�'X�.�!A��Zc�����@ ����Px�('ڎM/8�A$�H�=�)��y��u��@ �S�8� 9�JzPE-'Ҍg�(>�iMG4���4�0i��SwP���=���朌AȠ 0du��a2�22Z�(�#N�k<d��VT���*�����'
    [... Viel Müll ... ]
    error	Caught by controller[1]:  (1#%(:3=<9387@H\N@DWE78PmQW_bghg>Mqypdx\egc��C//cB8Bcccccccccccccccccccccccccccccccccccccccccccccccccc���
    error	Caught by controller[1]: TypeError: Cannot create property 'val' on string '����JFIF����h�!��C
    error	Caught by controller[0]: Failed to load definitions for node: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node/clientreport/index.d.ts'
    error	TypeError: Cannot create property 'val' on string '����JFIF����h�!...
    error	Error: Cannot create property 'val' on string '����JFIF����h�!...
    error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
    info	instance system.adapter.javascript.0 started with pid 24881
    • J Joshude
      @homoran said in Javascript Fehler mit unleserlichem Log:
      Ein Restore eines "Images" (was auch immer das sein soll) ist auch keine Lösung, wenn etwas an der Installation faul ist.
      Meine letzte Neuinstallation ist etwas her, da hab ich das Image hier genommen:
      https://forum.iobroker.net/topic/41520/raspberry-os-lite-image-for-with-iobroker
      Da hilft nur ein aktuelles Raspberry PI OS lite zu nehmen, ioBroker und das korrekte node mit zugehörigem npm mit dem Einzeiler Installieren, Backup wiederherstellen und gut ist.
      Genau das möchte ich aus den oben genannten Gründen ja vermeiden.
      Ist da jedoch ein Amok laufendes Skript am Werk nutzt es auch nicht den Adapter neu zu installieren!
      Tja, nur leider wüsste ich nicht welches, da ich im Adapter alle Skripte deaktiviert habe. Irgendwas muss da also abseits Amok laufen, die Logs lesen sich aber so, als wäre es JS.
      host.iobroker 2022-11-26 22:52:06.525	error	Caught by controller[0]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:7439:39)
      host.iobroker 2022-11-26 22:52:06.524	error	Caught by controller[0]: at Object.formatAliasValue (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2479:19)
      und
      host.iobroker
      2022-11-30 17:59:09.630	error	Caught by controller[0]: Failed to load definitions for node: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node/clientreport/index.d.ts'
      @thomas-braun said in Javascript Fehler mit unleserlichem Log:
      @joshude sagte in Javascript Fehler mit unleserlichem Log:
      Aktualisierung für 294 Pakete verfügbar.
      Und in den sources.list Dateien ist auch der Wurm drin.
      Die Anleitung die du da gegriffen hast hat den Teil 'ThirdParty-Repos' elegant ausgelassen, das knallt dir jetzt auf die Füße.
      Wie sollte die im Idealfall aussehen? Ich kann mich nicht erinnern die angefasst zu haben, vielleicht aber damals für nen Upgrade von NodeJS? Muss aber lange her sein.
      Ist das jetzt ein Bullseye oder ein Buster da bei dir?
      lsb_release -a
      sagt?
      pi@iobroker:~ $ lsb_release -a
      No LSB modules are available.
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      Ein Upgrade geht richtiger so:
      https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
      Schade, ich hab nach Buster to bullseye upgrade bei Google gesucht, die Anleitung ist dabei nicht aufgetaucht.
      Das Problem ist ja auch, dass du die Repos von Dritten eben nicht angefasst hast. Deswegen steht da auch noch 'buster' drin und nicht 'bullseye'.
      Hast du das jetzt korrigiert?
      J 1 Antwort Letzte Antwort
        Joshude
        Sieht besser aus, oder?
        pi@iobroker:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
        uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        armv7l
        Kein Docker
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.18.1
        v16.18.1
        8.19.2
        4.0.23
        pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        /home/pi
        OK:1 http://phoscon.de/apt/deconz bullseye InRelease
        OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
        OK:4 https://repos.influxdata.com/debian bullseye InRelease
        OK:5 https://deb.nodesource.com/node_14.x bullseye InRelease
        OK:6 https://deb.nodesource.com/node_16.x bullseye InRelease
        Alle Pakete sind aktuell.
        nodejs:
          Installiert:           16.18.1-deb-1nodesource1
          Installationskandidat: 16.18.1-deb-1nodesource1
          Versionstabelle:
         *** 16.18.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                100 /var/lib/dpkg/status
             14.21.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
             12.22.12~dfsg-1~deb11u1 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        • J Joshude
          armv7l
          Kein Docker
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.18.1
          v16.18.1
          8.19.2
          4.0.23
          pi
          /home/pi
          nodejs:
            Versionstabelle:
          @joshude
          Ja, sieht jetzt passend aus.
          • J Joshude
            armv7l
            Kein Docker
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v16.18.1
            v16.18.1
            8.19.2
            4.0.23
            pi
            /home/pi
            nodejs:
              Versionstabelle:
            @joshude
            Der 'Müll' aus der Meldung dürfte ein JPEG-Bild sein. Hantierst du da in irgendwelchen Skripten mit herum?
              @joshude
              Joshude
              Die Frage wäre, welche Skripte das betrifft. Aktuell sind in der Skript-Seite alle Skripte deaktiviert, auch dann kommen die Fehler. Das oben gezeigte ist wirklich nur ein kleiner Ausschnitt, das komplette Log ist etwas länger
              Es laufen auf dem Pi an sich noch weitere Skripte, aber die haben mit dem iobroker nichts zu tun und die laufen einfach per crontab als Shell-Skripte.
              • J Joshude
                apollon77A Online
                apollon77A Online
                Ok die Fehlemeldungen sind jetzt klarer aber immer nochKaputter text ... jetzt ists aber deutlich so das scheinbatr dein ioBroker DB File oder irgendwe anderen Dateien in node_modules beschädigt sind.
                Solche Beschädigungen kommen an sich immer von Filesystem problemen ... also ich würde meinem System an der Stelle nicht mehr vertrauen (bzw dem Speichermedium) ... Fixbar in meinen Augen nur durch komplette Neuinstallation des ganzen systems mit format und fs check und zurückspielen eines iobroker Backups was hoffentlich von davor und sauber ist ...
                ich bin mir nicht sicher welchen Sinn es hat hier weiter auf die Suche nach den kaputten Inhalten zu gehen ... kann überall und alles auf dem rechner sein (ok in dem Fall am ehestens in /opt/iobroker/ ... aber da ist genug drin
                • J Offline
                  Joshude
                  Tut mir leid, dass ich jetzt noch mal schreiben muss. Habe eben auf die aktuelle Version vom js Controller aktualisiert und jetzt geht das wieder los.
                  Hatte meinen kompletten raspberry neu aufgesetzt.
                  Direkt nach dem js Update nun wieder der Fehler, ich möchte hier jetzt eigentlich nen Dateisystem Fehler ausschließen
                  • J Joshude
                    apollon77A Online
                    apollon77A Online
                    @joshude Neu aufgesetzt aus einem Backup oder komplett neu?
                      Joshude
                      @apollon77 aus nem Backup.
                      Also, nen raspbian sauber aifgesetzt, iobroker per Skript neu installiert und dann das Backup wieder eingespielt.
                      Das lief wunderbar bis zum Upgrade des JS-Controller. Nach dem anschließenden Reboot wieder das gleiche wie letztes Mal, ebenfalls nach dem Update.
                      • J Joshude
                        apollon77A Online
                        apollon77A Online
                        @joshude Naja jetzt kannste mal zB einen text von da oben "JFIF" nehmen und in /opt/iobroker/iobroker-data ein grep "JFIF" * ausführen ... kommt da was?
                          Joshude
                          schrieb am zuletzt editiert von Joshude
                          @apollon77
                          Da kommt so einiges, das sind - wie schon vorher vermutet wurde - Pfade zu jpg-Dateien, aber ein Ergebnis fällt aus dem Raster, hier mal im Kontext zu ein paar "normalen"...
                          grep: iobroker-data/files/hue.admin/hue.jpeg: binary file matches
                          grep: iobroker-data/files/tesla-motors.admin/url.jpg: binary file matches
                          grep: iobroker-data/files/jarvis.admin/zefau.jpg: binary file matches
                          iobroker-data/states.jsonl:{"k":"ring.0.doorbell_96739257.Snapshot.jpg","v":"����\u0000\u0010JFIF\u0000\u0001\u0001\u0000\u0000\u0001\u0000\u0001\u0000\u0000��\u0000\u0007\u0000\u0000\u0000\u0000\u0000��\u0000\u0011\b\u0001h\u0002�\u0003\u0001!\u0000\u0002\u0011\u0001\u0003\u0011\u0001��\u0000C\u0000\u0010\u000b\f\u000e\f\n\u0010\u000e\r\u000e\u0012\u0011\u0010\u0013\u0018(\u001a\u0018\u0016\u0016\u00181#%\u001d(:3=<9387@H\\N@DWE78PmQW_bghg>Mqypdx\\egc��\u0000C\u0001\u0011\u0012\u0012\u0018\u0015\u0018/\u001a\u001a/cB8Bcccccccccccccccccccccccccccccccccccccccccccccccccc��\u0001�\u0000\u0000\u0001\u0005\u0001\u0001\u0001\u0001\u0001\u0001\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0001\u0002\u0003\u0004\u0005\u0006\u0007\b\t\n\u000b\u0001\u0000\u0003\u0001\u0001\u0001\u0001\u0001\u0001\u0001\u0001\u0001\u0000\u0000\u0000\u0000\u0000\u0000\u0001\u0002\u0003\u0004\u0005\u0006\u0007\b\t\n\u000b\u0010\u0000\u0002\u0001\u0003\u0003\u0002\u0004\u0003\u0005\u0005\u0004\u0004\u0000\u0000\u0001}\u0001\u0002\u0003\u0000\u0004\u0011\u0005\u0012!1A\u0006\u0013Qa\u0007\"q\u00142���\b#B��\u0015R��$3br�\t\n\u0016\u0017\u0018\u0019\u001a%&'()*456789:CDEFGHIJSTUVWXYZcdefghijstuvwxyz�������������������������������������������������������������������������\u0011\u0000\u0002\u0001\u0002\u0004\u0004\u0003\u0004\u0007\u0005\u0004\u0004\u0000\u0001\u0002w\u0000\u0001\u0002\u0003\u0011\u0004\u0005!1\u0006\u0012AQ\u0007aq\u0013\"2�\b\u0014B����\t#3R�\u0015br�\n\u0016$4�%�\u0017\u0018\u0019\u001a&'()*56789:CDEFGHIJSTUVWXYZcdefghijstuvwxyz��������������������������������������������������������������������������\u0000\f\u0003\u0001\u0000\u0002\u0011\u0003\u0011\u0000?\u0000��ɨ�\u0000��\n(\u0000��\nZ\u0000(�\u0002��\u0001K@\u0005-\u0000\u0014�\u0000Q@\u0005-\u0000\u0014P\u0002�@\u0005-\u0000\u0014P\u0001K@\u000bE\u0000\u0014P\u0002�@\u0005%\u0000\u0014P\u0001E\u0000\u0014P\u0001E\u0000--\u0000\u0014�\u0000Q@\u0005-\u0000\u0014P\u0002�@\u000bK@\u000bE\u00008R�\u0000x�\u0001@\u000f\u0002���$\u0000T�E\u0000H�5v���#\u0003�\u0000۷���Alf�q��mC�\u0000�nY�I�-��Z\u0000���\n(\u0000��\u0016�\u0000(�\u0002�\u00003K@\u0005-\u0000\u0014�\u0000R�\u0001E\u0000-\u0014\u0000Q@\u000bE\u0000\u0014P\u0002�@\u000bE\u0000\u0014P\u0002�@\u000bE\u0000%\u0014\u0000Q@\u0005\u0014\u0000Q@\u0005-\u0000\u0014�\u0000R�\u0001E\u0000\u0014P\u0002�@\u000bK@\u000bE\u0000(��\u00008\np�\u0007\np�\u0007�x4\u0000���F�x�\r+[.��CΎ�x�\nW\u0017��x��Rh\u0000\u0012R�(\u0003���\u0004��\nZ\u0000(�\u0002�\u0000)(\u0001E\u0014\u0000���\nZ\u0000)h\u0000��\u0002�\u0000(�\u0005��\n(\u0000��\u0002��\n(\u0001h�\u0002�\u0000(�\u0004��\u0002�\u0000(�\u0002��\nZ\u0000(�\u0005��\u0005��\nZ\u0000ZZ\u0000ZQ@\n)h\u0001iE\u00008S�\u00008\u001az�M\u0000\\��g<�Ԇ\u0018�\\�f�\u001b5�Q�Y�\\\u0017=h\u0002=�n�\u0005\rF�\u0000�(�\u0002�\u0000Z(\u0000��\u0002�\u0000(�\u0002�4\u0000\nZ\u0000\u0005:�\nZ\u0000(�\u0005��\nZ\u0000(�\u0002�\u0000)h\u0000��\u0004��\u0002��\n(\u0001(�\u0002��\n(\u0000��\u0016�\u0000)h\u0000��\u0016�\u0000JZ\u0000)h\u0001E-\u0000(��\u0005��\u0005\u0014��\u001c)�&�2�Z\u0016��yj\u0000�eH�\u0005U���\u0001M�,i��\u0000�J\u001a�\u0017u\u001b�\u0003���\u0002�@\u0005-\u0000%\u0014\u0000Q@\u0005\u0014\u0000�P\u0001E\u0000-.h\u0001ih\u0000��\u0004��\u0002��\n(\u0000��\nZ\u0000(�\u0005��\nZ\u0000)(\u0000��\n(\u0001h�\u0002��\n(\u0001h�\u0002�\u0000ZJ\u0000)h\u0000��\u0005�\u0014\u0000���\u0016��\u0014R�\u0003�f�AnX�@\u0017�D�d�Is�h\u0002��Oz��h\u0001��4\u0000��\u0006�\fѺ�0)(\u0000�P\u0002�@\t�(\u0000�P\u0002�P\u0002�@\u000bE\u0000\u0014P\u0003�-\u0000\u0014P\u0001K@\u0005\u0014\u0000��\u0000�P\u0001K@\u0005\u0014\u0000�P\u0001E\u0000\u0014P\u0001E\u0000\u0014�\u0000Q@\u0005-\u0000\u0014�\u0000Q@\u0005\u0014\u0000R�\u0001E\u0000\u0014�\u0000�P\u0002Ҋ\u0000u-\u0000(�#���P\u0005�m�ɩ�D�{�\u0005I.K\u001fj��M\u0000&�L�\u0001�\\�\u0001�3@\u000b�3@\u0018X��\u0002��\u0016�\u0000)(\u0000�Q@\u000bI@\u0005-\u0000\u0014P\u0002�\u0000Z\\�\u0001K@\u000bE\u0000\u0014P\u0001E\u0000-\u0014\u0000R�\u0001E\u0000-\u0014\u0000Q@\u0005\u0014\u0000Q@\u0005-\u0000\u0014P\u0001K@\u0005-\u0000\u0014P\u0001E\u0000\u0014P\u0001K@\u0005\u0014\u0000���\u0016�P\u0003�(\u0019�\u000b\u0010�[�^�\u00161@\f��/\u000bT�BǓ@\f�\u0019�\u0005�\u0019�\u00034�\u0000Q�\u0000\\њ\u0000Ƥ�\u0002�\u0000(�\u0002��\u0016�\u0000J(\u0001E\u0014\u0000Q@\u0005\u0014\u0000���\nZ\u0000\u0005.h\u0001E\u0014\u0000R�\u0001E\u0000\u0014P\u0002�@\u000bE\u0000\u0014P\u0001E\u0000-\u0014\u0000��\u0000R�\u0001E\u0000-\u0014\u0000R�\u0002Ph\u0000��\u0001E\u0000-\u0014\u0000��\u0000��P\u0003�I5n(@��\u0004��1U�-��\b\u000bRf�\nZ\u0000(�\u0005\u0014f�\u0016��\u0002f��\u0006Y\u0014��\u0004�\u0014\u0000RP\u0001E\u0000\u0014P\u0001I@\u000bE\u0000\u0014P\u0001K@\u0005-\u0000\u0014�\u0000R�\u0001K@\u0005\u0014\u0000�P\u0001E\u0000-\u0014\u0000�P\u0001E\u0000\u0014P\u0001K@\tK@\u0005-\u0000\u0014P\u0002�@\u000bI@\u0005\u0014\u0000Q@\u000bI@\u000bE\u0000(��\u0005\u0015,q�@\u0016�B�\u001e`�\u0002�+���74\u0000���\u0002��\n(\u0001h�\u0000\u0014P\u0001E\u0000Pe�3\u0014\u0000���\u0004��\u0005��\u0002�\u0000JZ\u0000(�\u0002��\n(\u0000��\u0002�\u0000Z(\u0001i\u0019�~�\u0001�4\u0000�t_�:<���t\u0000y��\u0000�E��|���t\u0000y��\u0000�E����\u0000����\u0001�E�\u0000=\u0017�+��k\u0003�C@\u000e��\u0002�\u0000(�\u0002��\u0012��\n(\u0001h�\u0005��\u0016�\u0000)(\u0000��\u0016�\u0000JZ\u0000QNU�\u0000N�Թ\n(\u00027�=*\"s@\u0006h�\u0002��\nZ\u0000(�\u0005��\u0016�\u0000(�\n�-BE\u00007\u0014��\u0004�h�\u0000%\u0014\u0000Q@\tE\u0000\u0014P\u0002�@\u0005\u0014\u0000�P\u0001E\u0000\u0014�\u0000�R��~4\u0001V�\u0000(�\u0002�\u0000*���\u0000\n\u0000�E\u0000\u0014P\u0001E\u0000\u0014�\u0000Q@\u0005\u0014\u0000�P\u0001K@\u000bK@\tI@\u0005\u0014\u0000R�\u0002\np\u0014\u0000�Z�\u0014\n\u0000qp�����\u0000nh�\u0002��\u0014R�\u0001E\u0000\u0014�\u0000Q@\u000bK@\u0005\u0014\u0001P�i\u0019�\u0006\u0011HE\u0000%!�\u0004��\u0012�\u0000CE\u0000\u0014�\u0000Q@\u0005-\u0000\u0014P\u0001E\u0000-\u0014\u0000U[���\u0005Z(\u0000��\n(\u0000�G�(\u0002�\u0014\u0000Q@\u0005\u0014\u0000�P\u0001E\u0000\u0014P\u0002�@\u0005-\u0000--\u0000\u0006�@\u0005-\u0000\u0014P\u0002�OU�\t\u0000�#?�\u000034�\u0000Q@\u000bE\u0000--\u0000\u0014P\u0002��\u0001E\u0000--\u0000(\u0014๠\f�i{P\u0002\u001ai�\u00044�@\u0006)(\u0001)h\u0001���\n(\u0000��\u0016�\u0000(�\u0002�\u0000Z(\u0000���S�\n�P\u0001E\u0000\u0014P\u0001Wt���P\u0005�(\u0000��\u0002�\u0000(�\u0002�\u0000(�\u0005��\nZ\u0000QK@\u0005%\u0000%-\u0000\u0014��\u001e���(\u0001��M4\u0000�P\u0002�@\u0005-\u0000-\u0014\u0000�P\u0002��\u0001K@\u0005-\u0000H����tƽ�T8U�X�\u0000��\u001cP\u0003NA�ϭ\u00004�A@\ni�\u0000��\u0000�P\u0001K@\u0005\u0014\u0000Q@\u0005\u0014\u0000Q@\u000bE\u0000-T�ꟍ\u0000U��\n(\u0000��\n�����\u000b�P\u0002�@\u0005\u0014\u0000Q@\u0005\u0014\u0000Q@\u000bE\u0000\u0014�\u0000R�\u0002�\u001a\u0000JZ\u0000P)�P\u0002�\u0014��\u0002Q@\u0005-\u0000\u0014P\u0001K@\u0005-\u0000-\u0014\u0000�\n\u0000ZZ\u0000Zr�=(\u0002x�����T�r��\u001c}(\u0003\r\u0000�iX�\u0002r:�\u0018�\u0000e;�(\u0001���\nJ\u0000(�\u0002��\n(\u0000��\n(\u0000��\u0002�\u0000QU/���@\u0015h�\u0002�\u0000(�\u0002���$�(\u0002�\u0014\u0000�P\u0001E\u0000\u0014P\u0001E\u0000\u0014P\u0002�@\u0005-\u0000-\u0014\u0000R�\u0002R�@\u000e\u001cPM\u0000%%\u0000\u0014�\u0000�P\u0001E\u0000-\u0014\u0000R�\u0002�@\u000b@�\u0007S�I�\u0007�U�2v\u001c\n\u0000@is@\u001\u0010���dޣ�\u0000��~T�u)�?*\u0000>�/����T���\u0003�R��ʏ���?*\u0000>�'����L���\u0004�L����L���\u0003�2z�ʏ���?*\u0000>�'����L���\u0003�2��ʏ���?*\u0000>�'����L���\u0003�2��ʏ���?*\u0000>�/����L���\u0003�R��ʙ$�&7\u001e�\u0000�(\u0000��\n(\u0000�\"���Ì�P\u0004�l��~T}�oQ�P\u0001�ɽG�G�&�\u001f�\u0000\u001fl��~T}�oQ�P\u0001�ɽG�G�&�\u001f�\u0000\u001fm��~T}�oQ�P\u0001�ٽG�G�f�\u001f�\u0000\u001fm��~T}�oQ�P\u0001�ٽG�G�f�\u001f�\u0000\u001fm�������\u0000x~T\u0000�n��~T}�\u000fʀ\u000f�O���Q���\u0000�?*\u0000>�?���Gۧ����\u0000�t�\u0000�\u001f�\u001fn����\u0003���\u0000x~T}�\u000fʀ\u000f�����R��\u000fʀ\u000f�x~T}�����\u0003�B�����B����\u0003�B�����B����\u0003�F�����Ѹ����\u0000�Ѹ�����ѹ���\u0000�4\u0000�S�\u001fĿ��/�������\u0014\u0000�S�?�?�?�����\u0000\u001f�w_�_���K��/��@\u0014�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000(�\u0002�\u0000����\u0000�6���<��Ϳ*\u0000>�7��oʏ\"_��ߕ\u0000\u001eD���%�\u0000�m@\u0007�/�\r\u001eD��j\u0000<��y\u0012�\u0000q�\u0000�%��Q�K�Ơ\u0003ȗ��G�/�\u001a�\u000f\"_�5\u001eD��j\u0000<��y\u0012�\u0000q�\u0000�%��Q�K�Ơ\u0003ȗ��G�/�\u001a�\u000f\"_�5\u001eD��j\u0000<�~Ty\u0012�\u0000q�\u0000�%�\u0000�m�Q�K�\u0000<ڀ\u000f\"_���y\u0012�\u0000�6��\u0000�%�\u0000�m�Q��~T\u0000}�_��ߕ\u001fg��y��@\u0007���\u0000�m�R��o��ߕ\u0000\u001fg��y��G���\u0000�m�P\u0001�y��~T}�o��ߕ\u0000\u001ff��y��G٦�\u0000�m�P\u0001�i��~T}�o��ߕ\u0000\u001ff��y��G٦�\u0000�m�P\u0001�i��~T}�o��ߕ\u0000\u001ff��y��G٦�\u0000�m�P\u0001�i��~T}�o��ߕ\u0000\u001ff��y��G٧�\u0000�M�P\u0001�i�\u0000�~T}��ߕ\u0000\u001ff��y7�G٧�\u0000�M�P\u0001�Y�\u0000�~T�e��y7�@\u0007�g�\u0000�M�Q�Y�\u0000�~T\u0000}��ߕ\u001fe��y7�@\u0007�.?�~T}���x��@\u000b�;����\u0000�\u001fc��\u0000�/�P\u0001�;����\u0000�\u001fb��\u0000�/�P\u0001�+����\u0000�/�n���T\u0000}���x?�K�\u000b��ʀ\u000f��������>��}���\u000���Oʗ�2��}d��\u000�o���K�\u0000|���\u0000>��T\u0001z�4\u0000\u0013Hh\u00013E\u0000!�4\u0000��\u0000��\u0000b�P\u0001�0h\u0000�.(\u0000�&(\u0001qE\u0000\u0014P\u0001E\u0000.(�\u0000\u0014�\u0000R�\u0001F(\u0001qF(\u0000�\u0018�\u0005��\nZ\u0000(�\u0000\u0014P\u0002�P\u0001E\u0000\u0014P\u0001J:\u001a\u0000(�\u0002�\u0000)h\u0000��\u0016�P\u0002�p�\u0005\u0014��\u0014R�\u0000p�\u0001@\u000e\u0002�\u0005\u00008\n�S4\u0001*��L�\u000f�3@\u0013G\u0013��j�-���G\u0014\u0001��4\u0000Q@\u0005\u0018�\u0004\"�h\u0000��\u0014Ҋ\u0000\\\u000fZ]�J\u00006�6�J\u00001F(\u0001qE\u0000\u0018�\u0014\u0000�E&�\u0000]�m�\u0003e.�\u00006Ѷ�\u0017m\u001bh\u0000�K��\r��h\u0001vѶ�\u0017m\u001b(\u0001vQ��\r��`�\u0003`�e\u0000\u001b(�(\u0000��F��@\u0006��F�\u00006ю�\u0000b�P\u0001�1@\u0006(�\u0000.(�\u0000\u0002��\u0000P)@�\u0005�8\n\u0000\\R�\u0014\nx\u0014\u0000�*EZ\u0000�\u0001O_j\u0000�Fj�s��\r�,�~_,\u0007\u001d���)c#`���@\u001eS�E\u0000\u0014P\u0001K@\u0005.(\u0000�(�@\u0006�I��\u0001�E\u0000\u0019��}h\u0001w\u001a7\u001a\u0000]��n\u001e�\u0000�\u0014dP\u0002�KǨ�\u0000c֝�\u0000\u001cR�\u0001K�\u0000\u0000�.(\u0000�\u0018�\u0005�\u0018�\u0003\u0014b�\u0017\u0014b�\fR�\f{R��P\u0001�F(\u0000�\u0018�\u0014\u0000`zъ\u00000=h���\u0004;}i��\u0000-%\u0000-\u0014\u0000Q�P\u0001�\\�\u0000=�rh\u0001A�\u0006�\u001e)�P\u0002�J\u0005\u00008-<-\u00008\nx�\u0007��S\"z�\u0004ȣҮAo,�\u0005F9��\r�>�A�H\u001b���U��1�In�4\u0001�\u0014P\u0001E\u0000%-\u0000.iA\u0014\u0000���\r��\u0004$�J\u0000\\Q�\u0000(�\u0000.(�\u0002�\u0014\u0000Q@\u0006)q@\u0005-\u0000/>�d��\u0002�}ir}M\u0000\u0019>�d��\u0002�>���\u0000\u001b��\u001b�\u0000.��F��@\u0006O��>�\u0017>��h\u0000�\u0014\u0000~tP\u0001F(\u0001F;�\u000e��\u0000��\u0014\u0000���\u0000\u0018��}(\u0001v7�\u001b\u000f�\u0000/�}i|�@\u0006�P��\u001d�R�\u0014\u0000�R�@\u000e\u0002�\u0005\u0000(�\u0001@\u000f\u000bR*�\u0000�{\n�T�\u0004�\u000f�h�^K\u0003\f1+�\u001a\u0000׵�i�!�\u0001�Kwn�\u001e0E\u0000y\u0015\u0014\u0000�d�\u001bX�J\u0000JZ\u0000(�\u0002��\fQ@\u0006)h\u0000�\u0018�\u0003\u0014��\u0003\u0014��\u0003\u0014��\u0003\u0014b�\fR�@\u0006(�\u0000.(�\u0000.(�\u0000.�^(���\u0014\u0000��\u0000dѕ\u001dA�\u0005\u0000\u001e���\u0000b��\u0012�\u0014\u0000b�P\u0003�A<��C=�\u0001|��h�ހ\u000f({Ӽ�}�\u0001<���!�s��\u0005\b��K�z\n\u0000]�Ҍ\u0001@\u0006=�q@\t�1@\u0006)(\u0001v��\n8�\u0005ȥϵ\u0000(&�\u0003@\u000f\u000bO\u001cP\u0003�5\"�\u0000�@�V�$\\��\u0013�\u0000j�\t��\u0014p;�Z���E\u0000x�.)(\u0001�w\u001e��ɠ\u0004��\u0016�\u0000)h\u0000��\u0017\u0014b�\nZ\u0000)h\u0000�\u0018�\u0005�\u0018�\u0005�\u0014\u0000b�\u0014\u0000��\u0014\u0000b�\u0014\u0000b��s@\n�X�9H\u0003�\"�\u0017r���\u001f,0\u0017�\u0004D\tԂ}(4\u0000��\u0014\u0000��\u0014\u0000b�P\u0002��\ba�\u0000]�7^8�\u0004�>��\u0000���\u0000Q�\u0000�\u0005�4m�\u0003o�!8�@\bXRn\u0014\u0000n\u001e�n��\u0003&���\u0001����@\u000b�P�\u0001 ZQ@\u000f\u0002�\u0016�$\u0002���%E��b�%Q�V��Y?աlzv�\r;K�O�O�#�j6X6A�=(\u0003ɮb\b\u0000Q�9��'oN��\u001b*�@�j=�\u0003ހ\u0010�S�0h�\u0003\u0014b�\u0016�P\u0001�\\P\u0001�\\P\u0001�1@\u000b�1@\u000b�1@\u000b�1@\u000b�1@\u0006)q@\u0006)q@\u0006)q@\u0006)q@\u000e�˜��Q��@\u0006O�\u0014\u0000b�\u00001F(\u0001qF(\u0000�\u0018�\u0003\u0014��\t���!u4\u0000��\u001f�jM��h\u0001\u000b�P\u001bր\u001�.��@\t��h˷\u0003&�\u0010�\u0018�\u0003\u0014b�\u0014\n\\P\u0002�\u0007\u0018�\u001cpy�\u001eY=\u0006h\u0001LX\u001f�H\u0017ր\u001e8�N\u001e�\u0000�J\u0005\u0000H�R�\u0005\u0000H�*\n\u0000��Ml�p��\t��\u0012}웃~�*M\u001ep�~\u0014\u0001�^J7�@�e��TQ�sҀ)].$ t���QG��h\u0001ι���\u001dj\n\u0000)h\u0000��\u0000\u0014b�\u0017\u0014b�\fR�\u0002ъ\u00001K�\u0000\\Q�\u0000\\Q�\u0000\\Q�\u0000\\Q�\u00001K�\u00001E\u0000-\u0018�\u0005�\u0018�\u0005�\u0018�\u0003\u0014b�\u0017\u0014b�\fQ�\u0000\\Q�\u00001K�\u0000LR�\f\u001a1@\u0006)q@\t�wӊ\u0000LQ�\u0000\\Q�\u0000\\R�\u0000P9杁�\u000eh\u0001z\nxn:�\u0001��)��`�\u0000@9柁@\u000f\u0018���\u001a\u0000P=*EZ\u0000�EL��.[\u0012�\u0018u\u0015�\u0015�2�0}\u0000�\u000b\u0018\f9\u001f�G*\u000e\b\u0018ǥ\u0000y�<~4�3\u001fj\u0000[���m\u0011���5�墶�NI袀\u0012��\u001d�A�\u00001F(\u0001qF(\u0001qF(\u0000�.(\u0000\u0002�\u0014\u0000�c�h�\u0003\u0014��\u0005�\u0014\u0000b�\u0014\u0000��\u0014\u0000b�\u0014\u0000R�\u0001�\\P\u0001�1@\u000b�1@\u000b�(\u0000�\u0014\u0000��\u0014\u0000�(�@\u0006(�\u0000\u0014b�\u0017\u0014cހ\n1@\u0006(�\u0000.(\u0002�\u0014�:Ѷ�\fR�\u001d����&(\u0001�\u0018�J\u0000p\u000b��S�\u000eNJ\u0000~\u0014w��\"�\u0012�0h\u0001@���\u0007��\u0016�&AS��\t�\u0019���8^�\u0001�\u0018*�1ɡ�b�<�&\u0005���K�d㩠\u0006�\u001e_'#8����(\u0013F��\u0000>�\u0001E�yY����UfR\r\u0000&(�\u0000.(�\u0000\u0018��\u0003\u0014b�\u0017\u0014b�\u0017\u0014b�\u0016�\u0000\\Q�\u0000ZZ\u00001K�\u00001K�\u00001K�\u00001F(\u0001qF(\u0001qE\u0000(\u0004�\u0005\u0018�\u0005\nH�\u0018�\u0004�\u0014\u0000��\u0014\u0000b�P\u0002�\u001fJ\u00001I@\u000b�1@\u0001\u0014P\u0002�@\u00069��\u0002�@4\u0000⣱�\n\u0000P�8�)�\u0016��\u001c���\rE�P\u0001N\u0014\u0000�)�~4\u0000�O\u0014\u0000�\u0014P\u0004�S�\u0000Y��-P\u00120y�\r\u0001Ҋ\u0000��#\u0000ӥ'\u0019\u001dh\u0001��\u0000����ۻ�\u0000\u000f\u0014\u00018X�W�B1��UkS\u0019e*=��?J\u0000�,+���«��@\u000b�1@\u0006(�\u0000.(�\u0000-\u0018�\u0003\u0014��\u0017\u0014b�\fR�\fR�@\u000b�1@\u000e�(\u0003�\u0002�P\u0002�P\u0002�\u00001N\u0018�#�\u0000)1@\n(�\u0003\u0014b�\u0016�\u0014\u0000��P\u0002�ڌP\u0000\u0005\u001f�\u0000\u0014��s��\u0000��q@\u0005\u0014\u0000�;RP\u0002�@\u000e\u0004�J\u0018�&�\u001c\u001c�zR��\u0000nh�\u0000.)E\u00008S�\u00008T�(\u0001�R-\u0000L�2P\u0005����m<u�\u000b�#0�ڔP\u0007�\u00061���[4\u0000�=O\u0004S\u0011\u0019\u0001;�Ͽ4\u0001*�\u0004\u001c�\u0000���)l�\u0003\u001d\u0000�\tR����\u000b�U���\u0001�\u0000=?�(��3��#{�\n��7��}�\u00003\u0018��\u0014}(�\u0003\u0014��\u0002�P\u0002�@\n)q@\u0005.(\u0001�c�C@\u0005-\u0000\u0014P\u0002�P\u0002��\fR�\u0002R�\u0001K�\u0000J\\�\u0000@)q@\u000bF(\u0000\u0014b�\fQ@\u000b֓\u0014\u0000b��\fQ�\u00001K�\u0000(\u0014\u0000�R��\u0000\u0014�\u0000�S�\u0007ڀ\u0003�)\u0005\u0000(��\u00008\u001a�h\u0001�Z\u0000�ML��\u00012��X���@\u001a��!��T���\u0000y���\u0015~���T�(\u0002F+��j\u001e�3�\u00009��p\t\u0003ڮ�Y�p�(\u0000wc�@\u001b�X�\n/��a�\u0005I ܍\u0018\u0001U�0(\u0003���i`\u0014\u0002���5C\u0014\u0000\u001aJ\u0000\\Q@\u0005-\u0000\u0014�\u0000b��\u0017\u0014P\u0001�\\P\u0002ъ\u0000\\qE\u0000\u0014��\u0005\u0002�\u001a\u0000Z(\u0000��\u0016�{P\u0001A�\u0003\u0014�P\u0001�Z\u0000)q@\u0000\u001c���@\tE\u0000\u0018��\nB1@\n)h\u0000�(�\u0003\u0014`P\u0001�R�.{P\u0001K�\u0000(�\u0007sF(\u0001�(\u0001�(\u0002E�\u0016�%\r���h\u0001��*>(\u0003F��!���?�hy����P\u0007���U�\u000f�����\u001eXdv\u0014\u0000�3\u0002\u000bU�-:k�$!\u0003ր6m4�-�\\\t\u001fߐ*�Q\u0019\u0018U\u000b�(\u0002u#n��S\b�\u000eo^��t\\ta��=h\u0000�\u0018�\u0003\u0014�N3�(\u0000��\n\\P\u0002�\u0000ZZ\u00001K�\u00001F(\u0001qE\u00008\u001cv��\u0003\u0014�\u0000���\u0000(�\u0002��P\u0000\u0006iqҀ\n1@\u0007�.(\u0000�\u0014P\u0002�@\u0005\u0014\u0000Q�\u0000\r\u0018�\u0000\u0000Q@\u000bE\u0000(��G^ؠ\u0003\u0014�\u0000R�\u0000\u00014��\u0005\u0014�\u0000��\n\u0000p��\u0000H)��\u0003�ӃP\u0003�S��\u0004�\u0012�\u0014u5�q'�j�\u000e\t�\u000e.5b\u001d�R0)>��d�@\u001a�u�*7J��j��C{P\u0004�Ӻ�P\u0001\u001f\u000e�z\u001e3O#\u0019S�P\u0006^�\u0007�i�\u001c��Q�\u0007\u0014\u0000�P\u0002��x����@�@\u0011��\u0002�(\u0001h�\u0005��\u0014\u0000Q@\u000bE\u0000-\u0014\u0000�b�\u0016��\fQ�\u00001F(\u0001qK@\b\u0007\u0014��\n\u0005\u0000\u0006�\u0014\u0000\u0001�\u0018�\u0005\u0014P\u0001FM\u0000\u001cҐH�\u0004��@\u000bE\u0000\u0014P\u0002�@\u0005\u0014\u0000Q@\u000e^\u000f�\u0007��\u0000���\u0016�P\u0003�8\u001a\u0000x4�h\u0001��Nݚ\u0000\u0001���\r\r-7ͻ�ѩO��h</\u0014\u0001�b�<\u0001�wg\u0004g�I!ݐ\u0006\u0007a@\u0016��B7�*�.W�\u0000\"9_�I�\u001a\u0000w_js\u001d�[�C@\f�5�&F��\u0015�]Fb��� �!�;\u001aLP\u0001E\u0000\u0014�\u0000R�\u0000)h\u0000���`2\u0017��\u0002�m8�\u000fқ@\u000eQ��RP\u0002�@\n=h�\u0005��\u0014P(\u0000��\u000e�P\u0001Gq@\u000bIӊ\u0000SҖ�\u000e���\u0004�J=E\u0000\u0019��\r��\u0014P\u0002R�}h\u0001\u0005\u001fJ\u0000ZN�\u0000���\u0002�\u0000)�\u0007��\u0000%\u0014\u0000��\u0000��@\n)E\u00008\u001a\\�\u0001�p4\u0000��Cs@\u001bP0��.~��u��]�'�@\u0019�{�]��kJ�\\c��\u000b\u0011\fŊ���\u0014\u0000���\u001d��>�\u0000��\u0007*h\u0000'#5�x��l�P8n�Z\u0000��HNh\u0000��\u0016�\u0000ZZ\u0000)h\u0000��\u0002��\nZ\u0000)h\u0000\u0014�\u0000�����\u0012��\u0003E\u0000-!\u001c\u001a\u0000Z1Ƞ\u0005�&9�\u0005�P\u0000i�\u0000\u000e�\u001czP\u0001E\u0000\u0007�Oz\u0000p�y4�\u001d�\u0000��)2s@\u00061�\u0014\u0000��(\u0000��\u0017�(\u0001h�\u0002��\u0016�P\u0002��\f��\u0002��\u0000d՛(�Ө�(\u0002�8,������}\r\u0000fFLs��J%�\u000fq@\u0016�?(���$\u001a\u0000Gl�\u000e)P�t\u0001\"��sڀ\u001d��\u001d�\"��py���|Ñ@\u001c��\u0018�LP\u0002b�\u0000p\\�J1@\u000bF(\u0001h�\u0005��\u0016��\u0000\u0002��\n\\P\u0002⎔\u0000R�\u0001ޖ�\u0012�\u0000QҖ�\fQ��\u0000�\u0011��\u0000.:s�Aހ\np\u0003\u001c�\u001a\u0000CE\u0000\u0019�\u0014��\u0004�ފ\u0000\u0000�\u0014��\u0004�(#<�@\t�^�\u0000Q@\u000fF\n~e\rD���E��(\u0001���\u0005\u0014�\u0000��\u0000�P\u0002Ҩ��\u00008�QȤ\r�\u0000Bsӊ(\u0001�g�i�\u0001ml�7Z\u0000ϑ̌X�M74\u0001Pa�8��O�(h\u0003b\u0016�Ԥ�>�\u0000��\r���\t�q�P]_�h���죩�\f�5�g�\u001ea�g���n��P\u00071�.\u0018\u0001�Eg�\u0014\u0000R��\u00001A�\u0002��\nvr\u0007�\u0000%-\u0000--\u0000\u0014�\u0000R�\u0001E\u0000\u0002��\u0000Q�(�ր\n\u000fJ\u0000\\PGJ\u00001J(\u0000�\u001c�\u0002�t4\u0000��\u0003�4\u0000�\u0014q@\u0005'Q@\u000b��h\u001c�\u0000)q@\bF9��\u0010�њ\u0000(�\u0005#\u001di(\u0000�4�\u0000�R�@\u0005\u001c\n\u0000ZC��\u0005�8�\u0005.��4��\u0001A�4\u00015�fYB���ͷ\u0010\u000e�9�\n\u0005�8��Z\u0000�i.\u001ba�h�\u0018�\u000e:P\u0006̈́�H�]�E\u0000=:cҜ�v�2�u�-LP\u0010�wn°d�䐴�Y�Rh\u0001��9\u001dk���Ų���\u0006�\u0019�[�������W2A�(\u0000�NW�\u0002�\u001d���R1�ր\u001aE\u0014\u0000���\u0007c�J\u0000)h\u0000��\u0005��\u0014��Q@\u000b�\r\u0000\u0014\u001e�\u0000�w\u0002�\u0015T\u0011�qF(\u0000�Ҁ\nq�\u0000JC�P\u0003��\u0000\u0014t4\u0000P(\u0001�\u001e���\u0014\u0000f��\u0000\u0014�Ҁ\u0017�ZL{qڀ\fR�z}(\u0001@��8�\u0014]�7>�\u0000�z�@\u0005\u0019�\u00034P\u0001A�\u00034�h\u0001)�3@\u000e��)�\u0018�\r\u001b0-�i[���.�ǩ4\u0001\u0016\u000e3R\f�@\u0019'(�\u0015u1q\u0007=h\u0000��0M�J�S��\u0000V�!]�6\u0005b�:�\\\u0006�,��\f6'<҃@\u000eW\"��k�&�)8V�:�\u0019py\u0004W-�[\u001b{�^ݾ�\u0001L\nZ\u0000QOa�\u001e��\u0001�P\u0001�p�\u0005��\u0012��\u0000-*��x�\u0007\u0015\u0000d�@yȠ\u0005f,y�\u0014\u0000�\n\u0000(\u001fz�'X�.�!A��Zc�����@\r���\u000f��\u0014\u0000Px�\u0000('ڎM\u0000/8�A$\f�\u0001H�=�\u0000)\u0007��y��\u0014u��@\t�S�8\u001f�\u0000 9�JzP\u0003E-\u0000'Ҍg�\u0000(>�iM\u0000\u001dG4��\u0018�4\u0000\u0002\b�0i\b�\u0004�SwP\u0002��\u0004�\u0013=��\b\u0019�\u0006朌AȠ\t0\u0018du��a2�22\u0007Z\u0000(�#N�k<d�\u0018�\u000b\u001eVT���*���\u0007��"}
                          grep: iobroker-data/jarvis/0/hikk.jpg: binary file matches
                          grep: log/iobroker.2022-12-31.log: binary file matches
                          grep: node_modules/iobroker.feiertage/img/SettingScreenshot.jpg: binary file matches
                          Bekomm ich den einen Eintrag da irgendwie separat aus den States gelöscht? Vielleicht liegt da ja schon der Fehler.
                          €: Ich hab den Ring-Adapter mal komplett gelöscht, jetzt scheint es zu gehen. Vielleicht muss ich mir mal den passenden Thread zum Adapter suchen und mal hierher verlinken. Irgendwas scheint da ja im Busch zu sein
                          • J Joshude
                            @apollon77
                            apollon77A Online
                            apollon77A Online
                            @joshude ooookkkkk ... Jtt wird so einiges klarer. Kann es sein das Du einen Alias auf diesesn (Binary) State gelegt hatst? Das darf man nicht ... Das ist die Ursache. prüfe mal deine Aliase
