  4. zigbee2mqtt mit LAN/TCP port CC2652P
    5.6k
26 Beiträge 5 Kommentatoren 2.9k Aufrufe 5 Beobachtet
  • liv-in-skyL Offline
    liv-in-skyL Offline
    liv-in-sky
    @dimaiv
    ich wollte das ganze nun mit zigbee2mqtt installieren
    meine configuration.yaml sieht so aus:
    homeassistant: false
    permit_join: true
    frontend:
       port: 8080
       host: 0.0.0.0
    mqtt:
       base_topic: zigbee2mqtt
       server: mqtt://192.168.178.59:1890
    serial:
       port: 'tcp://192.168.178.141:6638'
    advanced:
       pan_id: 0x1A79
       ext_pan_id: [0xDD, 0xDD, 0xDD, 0xDD, 0xAA, 0xAD, 0xDD, 0xDD]
       channel: 14
       network_key: [0x01, 0x03, 0x05, 0x07, 0x09, 0x0B, 0x0D, 0x0F, 0x00, 0x02, 0x04, 0x06, 0x08, 0x0A>
       last_seen: ISO_8601_local
       homeassistant_legacy_entity_attributes: false
       legacy_api: false
       legacy_availability_payload: false
       output: json
       transmit_power: 20
       log_level: warn
    device_options:
       legacy: false
    availability: true
    beim aufruf des servers kommt aber:
    $ npm start
    > zigbee2mqtt@1.28.2 start
    > node index.js
    Zigbee2MQTT:info  2022-11-20 08:33:09: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2022-11-20.08-33-09' filename: log.txt
    Zigbee2MQTT:info  2022-11-20 08:33:09: Starting Zigbee2MQTT version 1.28.2 (commit #e66fe85)
    Zigbee2MQTT:info  2022-11-20 08:33:09: Starting zigbee-herdsman (0.14.68)
    Zigbee2MQTT:error 2022-11-20 08:33:09: Error while starting zigbee-herdsman
    Zigbee2MQTT:error 2022-11-20 08:33:09: Failed to start zigbee
    Zigbee2MQTT:error 2022-11-20 08:33:09: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
    Zigbee2MQTT:error 2022-11-20 08:33:09: Exiting...
    Zigbee2MQTT:error 2022-11-20 08:33:09: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
        at SerialPort.<anonymous> (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:146:28)
        at SerialPort._error (/opt/zigbee2mqtt/node_modules/@serialport/stream/lib/index.js:198:14)
        at /opt/zigbee2mqtt/node_modules/@serialport/stream/lib/index.js:242:12
    irgendwie will er /dev/ttyACM0 - ist aber anders konfiguriert - hättest du eine idee für mich
      liv-in-skyL Offline
      liv-in-sky
      @crunchip
      werd mal deine install methode testen
        liv-in-skyL Offline
        liv-in-sky
        na super - jetzt habe ich diesen fehler - weiß nicht , ob das ein schritt weiter oder zurück ist
        > node index.js
        Zigbee2MQTT:error 2022-11-20 08:49:12: Error while starting zigbee-herdsman
        Zigbee2MQTT:error 2022-11-20 08:49:12: Failed to start zigbee
        Zigbee2MQTT:error 2022-11-20 08:49:12: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
        Zigbee2MQTT:error 2022-11-20 08:49:12: Exiting...
        Zigbee2MQTT:error 2022-11-20 08:49:12: Error: network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby
            at ZnpAdapterManager.beginCommissioning (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:347:23)
            at ZnpAdapterManager.start (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:92:17)
            at Controller.start (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
            at Zigbee.start (/opt/zigbee2mqtt/lib/zigbee.ts:58:27)
            at Controller.start (/opt/zigbee2mqtt/lib/controller.ts:101:27)
            at start (/opt/zigbee2mqtt/index.js:109:5)
        root@zig2mqtt:/opt/zigbee2mqtt#
        @IdleBit
        ich habe die anleitung versucht zu befolgen https://github.com/o0shojo0o/ioBroker.zigbee2mqtt/blob/main/docs/DE/DE_get-started_move.md
        der zigbee adapter ist abgeschalten - aber der stick dafür ist noch im usb port - kann das ein problem sein
        crunchipC BananaJoeB D 3 Antworten Letzte Antwort
        • liv-in-skyL liv-in-sky
          > node index.js
          @IdleBit
          crunchipC Offline
          crunchipC Offline
          @liv-in-sky der LXC läuft jetzt? siehst du dort deine Geräte?
            > node index.js
            @IdleBit
            BananaJoeB Online
            BananaJoeB Online
            BananaJoe
            @liv-in-sky ich könnte mir vorstellen das der ZigBee Stick in USB noch kommuniziert (im ZigBee LAN) auch wenn keiner zuhört.
            Du nutzt die gleichen panId und/oder extendedPanId ?
            Das steht da ja als Fehler
              liv-in-skyL Offline
              liv-in-skyL Offline
              liv-in-sky
              @crunchip was meinst du für geräte - der lxc läuft und beim starten von zig2mqtt gibt es den fehler - wo soll ich den welche geräte sehen ?
              • BananaJoeB BananaJoe
                liv-in-skyL Offline
                liv-in-skyL Offline
                liv-in-sky
                @bananajoe habe ich mittlerweile entfernt - dachte mir auch, der könnte ja noch senden und empfangen
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  liv-in-sky
                  @bananajoe
                  muss ich alle device abschalten - vielleicht agiert eines der devices als eine art sender
                  /empfänger ?????
                    crunchipC Offline
                    crunchipC Offline
                    @liv-in-sky hatt mich verguckt, dachte das ist der Fehler aus dem Adapter, auf z2m kannst ja (wenn funktioniert) auf die Gui zugreifen
                      @bananajoe
                      /empfänger ?????
                      crunchipC Offline
                      crunchipC Offline
                      @liv-in-sky sagte in zigbee2mqtt mit LAN/TCP port CC2652P:
                      @bananajoe
                      /empfänger ?????
                      eigentlich nur deinen alten Coordinator
                        @bananajoe
                        /empfänger ?????
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        liv-in-sky
                        @crunchip
                        hast du auch von zigbee auf zig2mqtt umgestellt oder alles neu angelernt
                          > node index.js
                          @IdleBit
                          dimaiv
                          @liv-in-sky
                          Wenn du dein Netz komplett neu aufbauen möchtest, muss du ein anderes PANID nehmen, oder erst alle Strombetriebene Geräte vom Strom nehmen, oder die resetten.
                          ioBroker- NUC8i3 / Proxmox / VM
                          Node.js v22.21.0
                          NPM v10.9.4
                          JS controller 7.1.0
                          Admin 7.7.20
                          ZigBee Adapter 3.3.1alpha.0
                          Zigbee LAN Gateway CC2652P
                          Zigbee Firmware 20250321
                          • D dimaiv
                            @liv-in-sky
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            liv-in-sky
                            @dimaiv ich habe alle zigbee-geräte vom strom genommen - der iobroker hat keinen coordinator stick mehr und iob startet gerade neu
                            dann versuche ich es nochmal
                            ich wollte eigentlich nicht alle anlernen - aber wenn es sein muss - im moment weiß ich ja nicht mal, ob alles bei meiner zg2mqtt installation in ordnung ist
                              liv-in-skyL Offline
                              liv-in-sky
                              ok - einen schritt weiter
                              Zigbee2MQTT:warn  2022-11-20 09:47:25: `permit_join` set to  `true` in configuration.yaml.
                              Zigbee2MQTT:warn  2022-11-20 09:47:25: Allowing new devices to join.
                              Zigbee2MQTT:warn  2022-11-20 09:47:25: Set `permit_join` to `false` once you joined all devices.
                              Zigbee2MQTT:error 2022-11-20 09:47:25: MQTT error: connect ECONNREFUSED 192.168.178.59:1890
                              Zigbee2MQTT:error 2022-11-20 09:47:25: MQTT failed to connect, exiting...
                              RangeError: offset is out of bounds
                                  at Buffer.set (<anonymous>)
                                  at AdapterNvMemory.readItem (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-nv-memory.ts:68:20)
                                  at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                  at AdapterBackup.createBackup (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-backup.ts:87:29)
                                  at Controller.backup (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:328:28)
                                  at Controller.stop (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:308:9)
                                  at Zigbee.stop (/opt/zigbee2mqtt/lib/zigbee.ts:200:9)
                                  at Controller.start (/opt/zigbee2mqtt/lib/controller.ts:148:13)
                              jetzt muss ich mal den adapter starten, weil dort doch der mqtt server sein sollte
                                @crunchip
                                crunchipC Offline
                                crunchipC Offline
                                @liv-in-sky ich hab mein ti-board am Lan mit dem zigbee Adapter genutzt, vor paar Tagen umgestellt auf zigbee2mqtt.
                                zigbee Adapter gestoppt
                                lxc erstellt, die shepard.db rein kopiert, yaml angepasst, lxc gestartet, Adapter konfiguriert, fertig
                                nix neu angelernt
                                  liv-in-skyL Offline
                                  liv-in-sky
                                  schön langsam:
                                  und
                                  dann werd ich mal ein gerät/device wieder einschalten
                                    schön langsam:
                                    und
                                    crunchipC Offline
                                    crunchipC Offline
                                    @liv-in-sky na also, geht doch😁
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      liv-in-sky
                                      @crunchip
                                      leider kommen keine geräte, wenn ich sie einstecke(wieder an strom hänge)
                                      IdleBitI 1 Antwort Letzte Antwort
                                        @crunchip
                                        IdleBitI Offline
                                        IdleBitI Offline
                                        IdleBit
                                        schrieb am zuletzt editiert von IdleBit
                                        @liv-in-sky Moin, dann wurde deine DB nicht übernommen, selbst wenn alle Device aus sind werden diese Offline im Zigbee2Mqtt dargestellt.
                                        • IdleBitI IdleBit
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          liv-in-sky
                                          @idlebit
                                          zum glück habe ich nicht viele und jetzt - da alle neu angelernt sieht e so aus:
                                          und
                                          von daher
                                          danke an euch alle
                                          ps:
                                          @crunchip der installationslink ist echt gut - da hat sich jmd viel arbeit gemacht :-)
                                          @dimaiv echt super service - der stick war schneller da als ich ihn bei dir bestellt habe
