  5. Wie nutze ich eine custom class / npm Modul?
65 Beiträge 7 Kommentatoren 9.3k Aufrufe 5 Beobachtet
  • D disaster123
    @kentrath sagte in Wie nutze ich eine custom class / npm Modul?:
    @disaster123
    Tut mir leid, das Log war tatsächlich gefiltert. Habe ich nicht gesehen 😕
    wizconnect.0
    2023-01-27 10:14:30.312	warn	State "wizconnect.0.192_168_178_125.led.sceneId" has no existing object, this might lead to an error in future versions
    wizconnect.0
    2023-01-27 10:14:30.299	debug	Nachricht 83ff1daf-44df-48bf-86eb-9dca0cfde7ff gesendet -> 192.168.178.125 192.168.178.125 Versuch: 1
    wizconnect.0
    2023-01-27 10:14:00.339	warn	State "wizconnect.0.192_168_178_125.led.sceneId" has no existing object, this might lead to an error in future versions
    wizconnect.0
    2023-01-27 10:14:00.300	debug	Nachricht 03c2b39f-dcce-4b8c-8a89-62a38256ceb6 gesendet -> 192.168.178.125 192.168.178.125 Versuch: 1
    wizconnect.0
    2023-01-27 10:14:00.300	debug	Nachricht 286d0001-09e9-4305-9578-fed1a8d7e9ff gesendet -> 192.168.178.125 192.168.178.125 Versuch: 1
    wizconnect.0
    2023-01-27 10:14:00.299	debug	Nachricht f9922605-4af7-41c2-b87d-89d474ea3f41 gesendet -> 192.168.178.125 192.168.178.125 Versuch: 1
    wizconnect.0
    2023-01-27 10:14:00.186	debug	-> CREATE DeviceType: EVAL ESP17_SHTW9_01
    wizconnect.0
    2023-01-27 10:14:00.186	debug	-> CREATE DeviceType: ESP17_SHTW9_01
    wizconnect.0
    2023-01-27 10:14:00.179	debug	server error:Error: bind EADDRINUSE 0.0.0.0:38900 at node:dgram:359:20 at processTicksAndRejections (node:internal/process/task_queues:84:21)
    wizconnect.0
    2023-01-27 10:14:00.177	debug	-> CREATE Device: 192_168_178_125
    wizconnect.0
    2023-01-27 10:14:00.177	debug	__START -> WIZ__INIT_DEVICES [ 192.168.178.125 : Schlafzimmer ]
    wizconnect.0
    2023-01-27 10:14:00.176	info	config udpip: 192.168.178.5
    wizconnect.0
    2023-01-27 10:14:00.176	info	config udpmac: 26:8c:05:f2:0c:a9
    wizconnect.0
    2023-01-27 10:14:00.175	info	config bind_ip: 0.0.0.0
    wizconnect.0
    2023-01-27 10:14:00.161	info	starting. Version 0.0.5 (non-npm: disaster123/ioBroker.wizconnect#ad84f06e2e5e73de575ad53b91c9d7a24d8b9384) in /opt/iobroker/node_modules/iobroker.wizconnect, node: v16.19.0, js-controller: 4.0.24
    wizconnect.0
    2023-01-27 10:14:00.050	debug	States connected to redis: 127.0.0.1:9000
    wizconnect.0
    2023-01-27 10:13:59.991	debug	States create User PubSub Client
    wizconnect.0
    2023-01-27 10:13:59.991	debug	States create System PubSub Client
    wizconnect.0
    2023-01-27 10:13:59.982	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    wizconnect.0
    2023-01-27 10:13:59.966	debug	Objects connected to redis: 127.0.0.1:9001
    wizconnect.0
    2023-01-27 10:13:59.963	debug	Objects client initialize lua scripts
    wizconnect.0
    2023-01-27 10:13:59.935	debug	Objects create User PubSub Client
    wizconnect.0
    2023-01-27 10:13:59.934	debug	Objects create System PubSub Client
    wizconnect.0
    2023-01-27 10:13:59.934	debug	Objects client ready ... initialize now
    wizconnect.0
    2023-01-27 10:13:59.911	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    Sorry deine Antwort ist scheinbar untergegangern. Erstes Problem ist, dass laut Log bereits ein anderer Dienst an Port 38900 lauscht. Damit funktioniert der Adapter nicht richtig.
    Siehe:
    Kentrath
    #41
    @disaster123
    OK, jetzt gibt es aber ein anderes Problem, das vermutlich mit dem Update von node.js zusammen hängt. Der Adapter startet nach dem Hinzufügen eines weiteren Leuchtmittels gar nicht mehr. Auch ein löschen und neu installieren hilft nicht. Ich hätte wirklich gerne mehr Ahnung von der Materie, aber bin da (noch) völlig hilflos 😞
    Brauchst Du noch weitere Infos oder hilft das schon einmal? Node.js ist bei mir v16.19.0
    host.IoBroker
    2023-02-21 11:49:54.769	warn	adapter "wizconnect" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
    host.IoBroker
    2023-02-21 11:49:54.769	info	system.adapter.wizconnect.0 will be rebuilt
    host.IoBroker
    2023-02-21 11:49:54.769	info	Adapter system.adapter.wizconnect.0 needs rebuild and will be restarted afterwards.
    host.IoBroker
    2023-02-21 11:49:54.769	error	instance system.adapter.wizconnect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.IoBroker
    2023-02-21 11:49:54.769	error	Caught by controller[0]: }
    host.IoBroker
    2023-02-21 11:49:54.769	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.wizconnect/main.js' ]
    host.IoBroker
    2023-02-21 11:49:54.769	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.IoBroker
    2023-02-21 11:49:54.769	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
    host.IoBroker
    2023-02-21 11:49:54.769	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:904:12)
    host.IoBroker
    2023-02-21 11:49:54.769	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1069:32)
    host.IoBroker
    2023-02-21 11:49:54.769	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
    host.IoBroker
    2023-02-21 11:49:54.769	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1191:14)
    host.IoBroker
    2023-02-21 11:49:54.769	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.wizconnect/main.js:10:22)
    host.IoBroker
    2023-02-21 11:49:54.769	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:108:18)
    host.IoBroker
    2023-02-21 11:49:54.769	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1093:19)
    host.IoBroker
    2023-02-21 11:49:54.769	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:866:27)
    host.IoBroker
    2023-02-21 11:49:54.769	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
    host.IoBroker
    2023-02-21 11:49:54.769	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.wizconnect/main.js
    host.IoBroker
    2023-02-21 11:49:54.769	error	Caught by controller[0]: Require stack:
    host.IoBroker
    2023-02-21 11:49:54.769	error	Caught by controller[0]: Error: Cannot find module '@apollon/iobroker-tools'
    host.IoBroker
    2023-02-21 11:49:54.769	error	Caught by controller[0]: ^
    host.IoBroker
    2023-02-21 11:49:54.768	error	Caught by controller[0]: throw err;
    host.IoBroker
    2023-02-21 11:49:54.768	error	Caught by controller[0]: node:internal/modules/cjs/loader:1024
    • K Kentrath
      @disaster123
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      host.IoBroker
      wendy2702W Online
      wendy2702W Online
      wendy2702
      #42
      host.IoBroker
      host.IoBroker
      host.IoBroker
      Wie lange hast du das System, den Adapter, danach in Ruhe gelassen?
      K 1 Antwort Letzte Antwort
      • wendy2702W wendy2702
        host.IoBroker
        host.IoBroker
        host.IoBroker
        Kentrath
        #43
        @wendy2702
        Wie genau meinst Du das?
        Den Node.js habe ich vor einigen Tagen im Rahmen der täglichen Updates aktualisiert. Der Adapter lief vorher und nachher ohne Auffälligkeiten. Dann habe ich vorhin gesehen, dass wegen der laufenden Analyse nur eine Lampe im Adapter eingepflegt war und die anderen noch nicht. Also habe ich diese in die Liste eingetragen und der Adapter hat angefangen zu meckern. Daher habe ich ihn deinstalliert und neu installiert. Nach dem Hinzufügen einer Lampe kam es dann zu dem oben geposteten Log.
        • K Kentrath
          @wendy2702
          wendy2702W Online
          wendy2702W Online
          wendy2702
          #44
          @kentrath Naja,
          der Adapter war für eine NodeJS Version kompiliert. Jetzt versucht iob das neu zu bauen. Je nach System kann das schonmal dauern.
          Denke wenn du sicher sein willst:
          Instanz löschen
          Adapter löschen
          Dann neu installieren
          Allerdings würde mich das aktuelle Log vom Adapter neustart im Debug level interessieren.
            @kentrath Naja,
            Instanz löschen
            Adapter löschen
            Kentrath
            #45
            @wendy2702
            Das bringt leider keine Besserung. Hier der Log:
            host.IoBroker
            2023-02-21 13:24:03.679	info	Rebuild for adapter system.adapter.wizconnect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
            host.IoBroker
            2023-02-21 13:24:03.679	error	instance system.adapter.wizconnect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: }
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.wizconnect/main.js' ]
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:904:12)
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1069:32)
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1191:14)
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.wizconnect/main.js:10:22)
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:108:18)
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1093:19)
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:866:27)
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.wizconnect/main.js
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: Require stack:
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: Error: Cannot find module '@apollon/iobroker-tools'
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: ^
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: throw err;
            host.IoBroker
            2023-02-21 13:24:03.679	error	Caught by controller[0]: node:internal/modules/cjs/loader:1024
            host.IoBroker
            2023-02-21 13:24:03.396	info	instance system.adapter.wizconnect.0 started with pid 868324
            Wenn ich im Installationsverzeichnis den npm install ausführe, kommt folgendes:
            root@IoBroker:/opt/iobroker/node_modules/iobroker.wizconnect# npm install --production
            npm WARN config production Use `--omit=dev` instead.
            added 3 packages, and audited 4 packages in 21s
            found 0 vulnerabilities
            • K Kentrath
              @wendy2702
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              host.IoBroker
              wendy2702W Online
              wendy2702W Online
              wendy2702
              #46
              root
              Wahrscheinlich durch nutzen des "root" users schon das System verbogen.
              Was ist das für ein System?
              lege dir, falls noch nicht vorhanden einen User an.
              adduser <dein User Name>
              usermod -aG sudo <dein User Name>
              als root ausloggen und als dein User weitermachen.
              iob stop
              iob fix
              iob start
              iob diag
              Bitte die Ausgaben der 4 iob Befehle zeigen
                root
                iob stop
                iob fix
                iob start
                iob diag
                Kentrath
                schrieb am zuletzt editiert von Kentrath
                #47
                @wendy2702
                von dem Fixer habe ich keine Kopie gemacht, da der diag Befehl das Terminal Fenster gelöscht hatte, kann ich bei Bedarf natürlich noch einmal nachreichen. stop und start war ohne Beanstandung.
                Mit dem root ist mir schon bekannt, eventuell setze ich die VM noch einmal komplett neu auf und ohne root.
                Vielen Dank erstmal 😳
                Skript v.2023-01-02
                *** BASE SYSTEM ***
                Architecture:   x86_64
                Docker:         false
                Virtualization: kvm
                Distributor ID: Debian
                Description:    Debian GNU/Linux 11 (bullseye)
                Release:        11
                Codename:       bullseye
                PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                NAME="Debian GNU/Linux"
                VERSION_ID="11"
                VERSION="11 (bullseye)"
                VERSION_CODENAME=bullseye
                ID=debian
                HOME_URL="https://www.debian.org/"
                SUPPORT_URL="https://www.debian.org/support"
                BUG_REPORT_URL="https://bugs.debian.org/"
                Systemuptime and Load:
                 18:43:59 up 24 days,  3:22,  1 user,  load average: 0.33, 0.15, 0.11
                CPU threads: 8
                *** Time and Time Zones ***
                Tue Feb 21 17:43:59 UTC 2023
                Tue Feb 21 18:43:59 CET 2023
                CET +0100
                Europe/Berlin
                *** User and Groups ***
                alexander
                /home/alexander
                alexander cdrom floppy sudo audio dip video plugdev netdev
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:              9G        1.9G        3.7G         10M        4.4G        7.8G
                Swap:             0B          0B          0B
                Total:            9G        1.9G        3.7G
                         9960 M total memory
                         1879 M used memory
                         1624 M active memory
                         4018 M inactive memory
                         3663 M free memory
                          504 M buffer memory
                         3914 M swap cache
                            0 M total swap
                            0 M used swap
                            0 M free swap
                *** FILESYSTEM ***
                udev           devtmpfs  4.9G     0  4.9G   0% /dev
                tmpfs          tmpfs     997M  856K  996M   1% /run
                /dev/sda1      ext4       63G   22G   38G  37% /
                tmpfs          tmpfs     4.9G     0  4.9G   0% /dev/shm
                tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                /dev/loop0     squashfs   64M   64M     0 100% /snap/core20/1778
                /dev/loop3     squashfs  117M  117M     0 100% /snap/core/14447
                /dev/loop4     squashfs   45M   45M     0 100% /snap/certbot/2618
                /dev/loop6     squashfs   64M   64M     0 100% /snap/core20/1822
                /dev/loop1     squashfs   44M   44M     0 100% /snap/certbot/2772
                /dev/loop2     squashfs  117M  117M     0 100% /snap/core/14784
                tmpfs          tmpfs     997M  4.0K  997M   1% /run/user/0
                Messages in dmesg:
                [Sat Jan 28 15:21:13 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                [Sat Jan 28 15:21:13 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                Show mounted filesystems (real ones only):
                TARGET               SOURCE     FSTYPE   OPTIONS
                /                    /dev/sda1  ext4     rw,relatime,errors=remount-ro
                |-/snap/certbot/2772 /dev/loop1 squashfs ro,nodev,relatime
                |-/snap/core20/1778  /dev/loop0 squashfs ro,nodev,relatime
                |-/snap/core/14447   /dev/loop3 squashfs ro,nodev,relatime
                |-/snap/certbot/2618 /dev/loop4 squashfs ro,nodev,relatime
                |-/snap/core/14784   /dev/loop2 squashfs ro,nodev,relatime
                `-/snap/core20/1822  /dev/loop6 squashfs ro,nodev,relatime
                /var:
                8.7G    /var/
                4.7G    /var/lib
                3.5G    /var/lib/docker/overlay2
                2.4G    /var/log/journal/15d3612335a04abe8c8234d7a2ed7176
                /opt/iobroker/backups:
                170M    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                du: cannot read directory '/opt/iobroker/iobroker-data/letsencrypt/keys': Permission denied
                du: cannot read directory '/opt/iobroker/iobroker-data/letsencrypt/accounts/acme-v02.api.letsencrypt.org/directory': Permission denied
                834M    /opt/iobroker/iobroker-data/
                358M    /opt/iobroker/iobroker-data/files
                308M    /opt/iobroker/iobroker-data/sonosCache
                129M    /opt/iobroker/iobroker-data/backup-objects
                72M     /opt/iobroker/iobroker-data/files/telegram.admin
                find: Failed to change directory: /root: Permission denied
                find: '/opt/iobroker/iobroker-data/letsencrypt/keys': Permission denied
                find: '/opt/iobroker/iobroker-data/letsencrypt/accounts/acme-v02.api.letsencrypt.org/directory': Permission denied
                find: Failed to restore initial working directory: /root: Permission denied
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v16.19.1
                /usr/bin/node           v16.19.1
                /usr/bin/npm            8.19.3
                /usr/bin/npx            8.19.3
                nodejs:
                  Installed: 16.19.1-deb-1nodesource1
                  Candidate: 16.19.1-deb-1nodesource1
                  Version table:
                 *** 16.19.1-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                        100 /var/lib/dpkg/status
                     12.22.12~dfsg-1~deb11u3 500
                        500 https://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                     12.22.5~dfsg-2~11u1 500
                        500 https://deb.debian.org/debian bullseye/main amd64 Packages
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                admin:          6.3.5
                javascript:     6.1.4
                Adapters from github:   4
                Adapter State
                  system.adapter.accuweather.0            : accuweather           : IoBroker                                 -  enabled
                + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                  system.adapter.alexa2.0                 : alexa2                : IoBroker                                 - disabled
                  system.adapter.alias-manager.0          : alias-manager         : IoBroker                                 -  enabled
                  system.adapter.awattar.0                : awattar               : IoBroker                                 - disabled
                  system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
                  system.adapter.devices.0                : devices               : IoBroker                                 -  enabled
                  system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
                  system.adapter.dwd.0                    : dwd                   : IoBroker                                 -  enabled
                  system.adapter.echarts.0                : echarts               : IoBroker                                 -  enabled
                  system.adapter.feiertage.0              : feiertage             : IoBroker                                 -  enabled
                  system.adapter.flot.0                   : flot                  : IoBroker                                 - disabled
                  system.adapter.go-e.0                   : go-e                  : IoBroker                                 -  enabled
                  system.adapter.hass.0                   : hass                  : IoBroker                                 -  enabled, port: 8123
                  system.adapter.icons-material-png.0     : icons-material-png    : IoBroker                                 - disabled
                + system.adapter.influxdb.0               : influxdb              : IoBroker                                 -  enabled, port: 8086
                  system.adapter.info.0                   : info                  : IoBroker                                 -  enabled
                  system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
                  system.adapter.iqontrol.0               : iqontrol              : IoBroker                                 -  enabled
                + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
                  system.adapter.motionblinds.0           : motionblinds          : IoBroker                                 - disabled
                + system.adapter.mqtt.0                   : mqtt                  : IoBroker                                 -  enabled, port: 1886, bind: 192.168.178.5
                  system.adapter.node-red.0               : node-red              : IoBroker                                 - disabled, port: 1880, bind: 0.0.0.0
                  system.adapter.onkyo.0                  : onkyo                 : IoBroker                                 - disabled
                  system.adapter.ping.0                   : ping                  : IoBroker                                 - disabled
                  system.adapter.procon-ip.0              : procon-ip             : IoBroker                                 - disabled
                  system.adapter.proxmox.0                : proxmox               : IoBroker                                 - disabled, port: 8006
                + system.adapter.pushover.0               : pushover              : IoBroker                                 -  enabled
                  system.adapter.sayit.0                  : sayit                 : IoBroker                                 -  enabled
                + system.adapter.scenes.0                 : scenes                : IoBroker                                 -  enabled
                  system.adapter.schoolfree.0             : schoolfree            : IoBroker                                 -  enabled
                + system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                + system.adapter.sonos.0                  : sonos                 : IoBroker                                 -  enabled
                  system.adapter.spotify-premium.0        : spotify-premium       : IoBroker                                 -  enabled
                  system.adapter.sql.0                    : sql                   : IoBroker                                 - disabled, port: 3306
                + system.adapter.telegram.0               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  system.adapter.text2command.0           : text2command          : IoBroker                                 -  enabled
                  system.adapter.tibberconnect.0          : tibberconnect         : IoBroker                                 -  enabled
                + system.adapter.tr-064.0                 : tr-064                : IoBroker                                 -  enabled
                  system.adapter.unifi.0                  : unifi                 : IoBroker                                 - disabled
                  system.adapter.vis-bars.0               : vis-bars              : IoBroker                                 - disabled
                  system.adapter.vis-google-fonts.0       : vis-google-fonts      : IoBroker                                 -  enabled
                  system.adapter.vis-history.0            : vis-history           : IoBroker                                 - disabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IoBroker                                 - disabled
                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IoBroker                                 - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : IoBroker                                 - disabled
                  system.adapter.vis-weather.0            : vis-weather           : IoBroker                                 - disabled
                  system.adapter.vis.0                    : vis                   : IoBroker                                 -  enabled
                  system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                  system.adapter.wizconnect.0             : wizconnect            : IoBroker                                 -  enabled
                  system.adapter.worx.0                   : worx                  : IoBroker                                 - disabled
                + system.adapter.zigbee.0                 : zigbee                : IoBroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_4edabfcdf6d8eb119f990815b9da5f8b-if00-port0
                + instance is alive
                ioBroker-Repositories
                Stable (default): http://download.iobroker.net/sources-dist.json
                Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                Installed ioBroker-Instances
                Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
                Adapter    "admin"        : 6.3.5    , installed 6.3.5
                Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                Adapter    "alias-manager": 1.2.4    , installed 1.2.4
                Adapter    "awattar"      : 1.0.6    , installed 1.0.6
                Adapter    "backitup"     : 2.5.12   , installed 2.5.12
                Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                Adapter    "devices"      : 1.1.2    , installed 1.1.2
                Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
                Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                Adapter    "echarts"      : 1.0.12   , installed 1.0.12
                Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                Adapter    "flot"         : 1.11.0   , installed 1.11.0
                Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
                Adapter    "go-e"         : 1.0.23   , installed 1.0.23
                Adapter    "hass"         : 1.3.0    , installed 1.3.0
                Adapter    "icons-material-png": 0.1.0, installed 0.1.0
                Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                Adapter    "info"         : 1.9.19   , installed 1.9.19
                Adapter    "iot"          : 1.14.2   , installed 1.14.2
                Adapter    "iqontrol"     : 2.1.0    , installed 2.1.0
                Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                Controller "js-controller": 4.0.24   , installed 4.0.24
                Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                Adapter    "node-red"     : 4.0.0    , installed 4.0.0
                Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
                Adapter    "ping"         : 1.5.3    , installed 1.5.3
                Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
                Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                Adapter    "sayit"        : 1.12.3   , installed 1.12.3
                Adapter    "scenes"       : 2.3.9    , installed 2.3.9
                Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
                Adapter    "socketio"     : 4.2.0    , installed 4.2.0
                Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                Adapter    "sonos"        : 2.2.3    , installed 2.2.3
                Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
                Adapter    "sql"          : 2.2.0    , installed 2.2.0
                Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                Adapter    "text2command" : 2.3.0    , installed 2.3.0
                Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
                Adapter    "unifi"        : 0.5.10   , installed 0.5.10
                Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
                Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                Adapter    "web"          : 4.3.0    , installed 4.3.0
                Adapter    "worx"         : 2.0.3    , installed 2.0.3
                Adapter    "ws"           : 1.3.0    , installed 1.3.0
                Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                Objects and States
                Objects:        13347
                States:         11513
                Hit:1 https://download.docker.com/linux/debian bullseye InRelease
                Hit:2 https://repos.influxdata.com/debian bullseye InRelease
                Hit:3 https://deb.debian.org/debian bullseye InRelease
                Hit:4 https://deb.debian.org/debian-security bullseye-security InRelease
                Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                Hit:6 https://deb.debian.org/debian bullseye-backports InRelease
                Hit:7 https://packages.grafana.com/enterprise/deb stable InRelease
                Hit:8 https://deb.debian.org/debian bullseye-updates InRelease
                Hit:9 https://packages.sury.org/php bullseye InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       64644705   1391244/iobroker.js
                tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      106        12029      560/mariadbd
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14049      547/sshd: /usr/sbin
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       64646596   1391378/io.sonoff.0
                tcp        0      0 0.0.0.0:8123            0.0.0.0:*               LISTEN      997        19357292   18019/python3.10
                tcp        0      0 192.168.178.5:1886      0.0.0.0:*               LISTEN      1001       64644046   1391444/io.mqtt.0
                tcp        0      0 192.168.178.5:1887      0.0.0.0:*               LISTEN      1001       64644047   1391444/io.mqtt.0
                tcp        0      0 192.168.178.5:40000     0.0.0.0:*               LISTEN      997        19357390   18019/python3.10
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       64644712   1391244/iobroker.js
                tcp6       0      0 :::3500                 :::*                    LISTEN      1001       64646779   1391578/io.sonos.0
                tcp6       0      0 :::9999                 :::*                    LISTEN      0          890        579/apache2
                tcp6       0      0 :::80                   :::*                    LISTEN      0          886        579/apache2
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       64645781   1391265/io.admin.0
                tcp6       0      0 :::8086                 :::*                    LISTEN      998        14304      456/influxd
                tcp6       0      0 :::22                   :::*                    LISTEN      0          14060      547/sshd: /usr/sbin
                tcp6       0      0 :::3000                 :::*                    LISTEN      108        13226      648/grafana-server
                tcp6       0      0 :::8123                 :::*                    LISTEN      997        19357291   18019/python3.10
                tcp6       0      0 fe80::248c:5ff:fe:40000 :::*                    LISTEN      997        19360006   18019/python3.10
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          813        434/dhclient
                udp        0      0 0.0.0.0:50059           0.0.0.0:*                           997        19360004   18019/python3.10
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           997        19360003   18019/python3.10
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           997        19357378   18019/python3.10
                udp        0      0 0.0.0.0:36697           0.0.0.0:*                           997        19360002   18019/python3.10
                udp        0      0 192.168.178.5:5353      0.0.0.0:*                           997        19357376   18019/python3.10
                udp        0      0 0.0.0.0:55001           0.0.0.0:*                           997        19357382   18019/python3.10
                udp        0      0 0.0.0.0:38900           0.0.0.0:*                           997        19360264   18019/python3.10
                udp        0      0 0.0.0.0:32101           0.0.0.0:*                           997        19360402   18019/python3.10
                udp6       0      0 fe80::248c:5ff:fef2:546 :::*                                0          14405      770/dhclient
                udp6       0      0 :::33803                :::*                                997        19360018   18019/python3.10
                udp6       0      0 :::1900                 :::*                                997        19357381   18019/python3.10
                udp6       0      0 :::1900                 :::*                                997        19360014   18019/python3.10
                udp6       0      0 :::53031                :::*                                997        19360011   18019/python3.10
                udp6       0      0 :::5353                 :::*                                997        19357372   18019/python3.10
                udp6       0      0 fe80::248c:5ff:fef:5353 :::*                                997        19357377   18019/python3.10
                udp6       0      0 :::38636                :::*                                997        19357385   18019/python3.10
                2023-02-21 18:44:25.470  - info: mqtt.0 (1391444) Client [NSPanel_WZ] publishOnSubscribe send all known states
                2023-02-21 18:44:25.474  - info: sonoff.0 (1391378) Client [Heizung Ruth Bett] connected with secret 1677001465474_3560
                2023-02-21 18:44:25.526  - info: mqtt.0 (1391444) Client [NSPanel_BZ] publishOnSubscribe send all known states
                2023-02-21 18:44:25.527  - info: mqtt.0 (1391444) Client [NSPanel_BZ] publishOnSubscribe send all known states
                2023-02-21 18:44:25.528  - info: mqtt.0 (1391444) Client [NSPanel_BZ] publishOnSubscribe send all known states
                2023-02-21 18:44:25.624  - info: sonoff.0 (1391378) Client [Heizung OG TH] connected with secret 1677001465619_3105
                2023-02-21 18:44:25.650  - info: mqtt.0 (1391444) Client [NSPanel_SZ] connected with secret 1677001465648_1427
                2023-02-21 18:44:25.713  - info: sonoff.0 (1391378) Client [Kaffee Ecke] connected with secret 1677001465713_8012
                2023-02-21 18:44:25.716  - info: mqtt.0 (1391444) Client [NSPanel_SZ] subscribes on "SmartHome/NSPanel_SZ/cmnd/#" with regex /^SmartHome\.NSPanel_SZ\.cmnd(\..*)?/
                2023-02-21 18:44:25.716  - info: mqtt.0 (1391444) Client [NSPanel_SZ] subscribes on "SmartHome/NSPanel_SZ/cmnd/#"  with regex /^mqtt\.0\.SmartHome\.NSPanel_SZ\.cmnd(\..*)?/
                2023-02-21 18:44:25.716  - info: mqtt.0 (1391444) Client [NSPanel_SZ] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^SmartHome\.tasmotas\.cmnd(\..*)?/
                2023-02-21 18:44:25.716  - info: mqtt.0 (1391444) Client [NSPanel_SZ] subscribes on "SmartHome/tasmotas/cmnd/#"  with regex /^mqtt\.0\.SmartHome\.tasmotas\.cmnd(\..*)?/
                2023-02-21 18:44:25.717  - info: mqtt.0 (1391444) Client [NSPanel_SZ] subscribes on "cmnd/NSPanel_SZ_fb/#" with regex /^cmnd\.NSPanel_SZ_fb(\..*)?/
                2023-02-21 18:44:25.717  - info: mqtt.0 (1391444) Client [NSPanel_SZ] subscribes on "cmnd/NSPanel_SZ_fb/#"  with regex /^mqtt\.0\.cmnd\.NSPanel_SZ_fb(\..*)?/
                2023-02-21 18:44:25.724  - info: sonoff.0 (1391378) Client [Lampe grüner Sessel] connected with secret 1677001465716_5779
                2023-02-21 18:44:25.916  - info: mqtt.0 (1391444) Client [NSPanel_SZ] publishOnSubscribe send all known states
                2023-02-21 18:44:25.917  - info: mqtt.0 (1391444) Client [NSPanel_SZ] publishOnSubscribe send all known states
                2023-02-21 18:44:25.918  - info: sonoff.0 (1391378) Client [Wasserkocher] connected with secret 1677001465918_2838
                2023-02-21 18:44:25.919  - info: sonoff.0 (1391378) Client [Heizung OG Pow] connected with secret 1677001465918_2672
                2023-02-21 18:44:25.942  - info: sonoff.0 (1391378) Client [Lampe Waschbecken OG] connected with secret 1677001465940_6039
                2023-02-21 18:44:26.228  - info: sonoff.0 (1391378) Client [Heizung Arbeitszimmer] connected with secret 1677001466227_2974
                2023-02-21 18:44:26.242  - info: sonoff.0 (1391378) Client [Wäschetrockner] connected with secret 1677001466242_6251
                2023-02-21 18:44:27.434  - info: sonoff.0 (1391378) Client [Steuerung_Wärmepumpe] connected with secret 1677001467431_6290
                2023-02-21 18:44:27.635  - info: sonoff.0 (1391378) Client [Lampe KitchenAid] connected with secret 1677001467632_1074
                                     v.2023-01-02
                Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                Installation:           kvm
                Timezone:               Europe/Berlin
                User-ID:                1000
                X-Server:               false
                Pending OS-Updates:     0
                Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                                        /usr/bin/npm            8.19.3
                                        /usr/bin/npx            8.19.3
                ioBroker Core:          js-controller           4.0.24
                                        admin                   6.3.5
                Objects type: jsonl
                States  type: jsonl
                Status admin:
                Pending iob updates:    0
                Objects:                13347
                States:                 11513
                Size of iob-Database:
                • K Kentrath
                  @wendy2702
                  Skript v.2023-01-02
                  *** BASE SYSTEM ***
                  Docker:         false
                  Virtualization: kvm
                  Release:        11
                  Codename:       bullseye
                  VERSION_ID="11"
                  ID=debian
                  CPU threads: 8
                  CET +0100
                  Europe/Berlin
                  alexander
                  /home/alexander
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:             0B          0B          0B
                  Total:            9G        1.9G        3.7G
                           9960 M total memory
                           1879 M used memory
                           3663 M free memory
                            504 M buffer memory
                           3914 M swap cache
                              0 M total swap
                              0 M used swap
                              0 M free swap
                  *** FILESYSTEM ***
                  Messages in dmesg:
                  /var:
                  8.7G    /var/
                  4.7G    /var/lib
                  /usr/bin/npm            8.19.3
                  /usr/bin/npx            8.19.3
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.3.5
                  javascript:     6.1.4
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        13347
                  States:         11513
                  Pending Updates: 0
                                       v.2023-01-02
                  Installation:           kvm
                  User-ID:                1000
                  X-Server:               false
                                          /usr/bin/npm            8.19.3
                                          /usr/bin/npx            8.19.3
                                          admin                   6.3.5
                  Objects type: jsonl
                  States  type: jsonl
                  Status admin:
                  Objects:                13347
                  States:                 11513
                  wendy2702W Online
                  wendy2702W Online
                  wendy2702
                  #48
                  @kentrath
                  Erst neuen User anlegen und die Befehle ausführen.
                    @kentrath
                    Kentrath
                    #49
                    @wendy2702
                    Das habe ich als user alexander ausgeführt, nicht als root.
                    • K Kentrath
                      @wendy2702
                      wendy2702W Online
                      wendy2702W Online
                      wendy2702
                      #50
                      @kentrath Und als dieser auch den fix laufen lassen?
                        Kentrath
                        #51
                        @wendy2702
                        Ja, allerdings nicht im iob Verzeichnis, das sollte aber doch kein Problem sein oder?
                        • K Kentrath
                          @wendy2702
                          wendy2702W Online
                          wendy2702W Online
                          wendy2702
                          #52
                          @kentrath Dann jetzt mal die Instanz für WIZ…… auf Debug stellen, starten und das log zeigen.
                          • K Offline
                            Kentrath
                            #53
                            @wendy2702
                            Ich habe jetzt mal einen ganz frischen lxc gestartet und iob installiert (als user nicht als root). Danach habe ich nur den wiz Adapter installiert. Es kommt eine identische Fehlermeldung:
                            host.ioBroker
                            2023-02-23 19:30:28.583	info	Rebuild for adapter system.adapter.wizconnect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                            host.ioBroker
                            2023-02-23 19:30:28.583	error	instance system.adapter.wizconnect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.ioBroker
                            2023-02-23 19:30:28.583	error	Caught by controller[0]: }
                            host.ioBroker
                            2023-02-23 19:30:28.583	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.wizconnect/main.js' ]
                            host.ioBroker
                            2023-02-23 19:30:28.583	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                            host.ioBroker
                            2023-02-23 19:30:28.583	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
                            host.ioBroker
                            2023-02-23 19:30:28.583	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:904:12)
                            host.ioBroker
                            2023-02-23 19:30:28.583	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1069:32)
                            host.ioBroker
                            2023-02-23 19:30:28.583	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
                            host.ioBroker
                            2023-02-23 19:30:28.583	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1191:14)
                            host.ioBroker
                            2023-02-23 19:30:28.583	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.wizconnect/main.js:10:22)
                            host.ioBroker
                            2023-02-23 19:30:28.582	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:108:18)
                            host.ioBroker
                            2023-02-23 19:30:28.582	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1093:19)
                            host.ioBroker
                            2023-02-23 19:30:28.582	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:866:27)
                            host.ioBroker
                            2023-02-23 19:30:28.582	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
                            host.ioBroker
                            2023-02-23 19:30:28.582	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.wizconnect/main.js
                            host.ioBroker
                            2023-02-23 19:30:28.581	error	Caught by controller[0]: Require stack:
                            host.ioBroker
                            2023-02-23 19:30:28.581	error	Caught by controller[0]: Error: Cannot find module '@apollon/iobroker-tools'
                            host.ioBroker
                            2023-02-23 19:30:28.581	error	Caught by controller[0]: ^
                            host.ioBroker
                            2023-02-23 19:30:28.580	error	Caught by controller[0]: throw err;
                            host.ioBroker
                            2023-02-23 19:30:28.580	error	Caught by controller[0]: node:internal/modules/cjs/loader:1024
                            host.ioBroker
                            2023-02-23 19:30:28.347	info	instance system.adapter.wizconnect.0 started with pid 13195
                            • K Kentrath
                              @wendy2702
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              wendy2702W Online
                              wendy2702W Online
                              wendy2702
                              #54
                              Wie genau? Will das mal testen
                              EDIT: Läuft auch bei mir nicht. Denke da musst du dich am besten per Github an den Entwickler wenden wenn sonst niemandem etwas einfällt.
                              1Topf1 1 Antwort Letzte Antwort
                                1Topf1 Offline
                                1Topf1 Offline
                                1Topf
                                #55
                                @wendy2702
                                Ich hab ihn erst letzte Woche installiert und lief sofort.
                                  disaster123
                                  #56
                                  Sieht für mich nach nem nodejs / npm Problem aus. Ich installiere ihn normal via GUI und er läuft.
                                  • 1Topf1 1Topf
                                    @wendy2702
                                    wendy2702W Online
                                    wendy2702W Online
                                    wendy2702
                                    #57
                                    @1topf sagte in Wie nutze ich eine custom class / npm Modul?:
                                    @wendy2702
                                    @disaster123 sagte in Wie nutze ich eine custom class / npm Modul?:
                                    Welche Versionen habt ihr denn für Node/NPM ?
                                    Und was bedeutet "normal via Gui" ?
                                    Ich habe eine neue iobroker installation und befinde mich im latest:
                                    oder im Stable
                                    Nix "wiz" oder wie heisst der Adapter?
                                      disaster123
                                      #58
                                      Über die Katze im Menü und dann die URL: https://github.com/disaster123/ioBroker.wizconnect
                                      • D disaster123
                                        wendy2702W Online
                                        wendy2702W Online
                                        wendy2702
                                        #59
                                        @disaster123 Und welche NPM/Node Version läuft bei dir?
                                        Das, ist übrigens nicht "normal über Gui" sondern wie du selber schreibst per GIthub Link im Expertenmodus.
                                          disaster123
                                          #60
                                          Muss ich nachher mal gucken bitte das Original docker image von iobroker. Die Versionen sind da quasi fest.
