  4. JavaScript
  5. Wie nutze ich eine custom class / npm Modul?
65 Beiträge 7 Kommentatoren 9.3k Aufrufe 5 Beobachtet
  • K Kentrath
    @wendy2702
    Das bringt leider keine Besserung. Hier der Log:
    host.IoBroker
    2023-02-21 13:24:03.679	info	Rebuild for adapter system.adapter.wizconnect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.IoBroker
    2023-02-21 13:24:03.679	error	instance system.adapter.wizconnect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: }
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.wizconnect/main.js' ]
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:904:12)
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1069:32)
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1191:14)
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.wizconnect/main.js:10:22)
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:108:18)
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1093:19)
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:866:27)
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.wizconnect/main.js
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: Require stack:
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: Error: Cannot find module '@apollon/iobroker-tools'
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: ^
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: throw err;
    host.IoBroker
    2023-02-21 13:24:03.679	error	Caught by controller[0]: node:internal/modules/cjs/loader:1024
    host.IoBroker
    2023-02-21 13:24:03.396	info	instance system.adapter.wizconnect.0 started with pid 868324
    Wenn ich im Installationsverzeichnis den npm install ausführe, kommt folgendes:
    root@IoBroker:/opt/iobroker/node_modules/iobroker.wizconnect# npm install --production
    npm WARN config production Use `--omit=dev` instead.
    added 3 packages, and audited 4 packages in 21s
    found 0 vulnerabilities
    wendy2702W Online
    wendy2702W Online
    @kentrath sagte in Wie nutze ich eine custom class / npm Modul?:
    root
    Wahrscheinlich durch nutzen des "root" users schon das System verbogen.
    Was ist das für ein System?
    lege dir, falls noch nicht vorhanden einen User an.
    adduser <dein User Name>
    usermod -aG sudo <dein User Name>
    als root ausloggen und als dein User weitermachen.
    iob stop
    iob fix
    iob start
    iob diag
    Bitte die Ausgaben der 4 iob Befehle zeigen
    • wendy2702W wendy2702
      root
      iob stop
      iob fix
      iob start
      iob diag
      Kentrath
      schrieb am zuletzt editiert von Kentrath
      @wendy2702
      von dem Fixer habe ich keine Kopie gemacht, da der diag Befehl das Terminal Fenster gelöscht hatte, kann ich bei Bedarf natürlich noch einmal nachreichen. stop und start war ohne Beanstandung.
      Mit dem root ist mir schon bekannt, eventuell setze ich die VM noch einmal komplett neu auf und ohne root.
      Vielen Dank erstmal 😳
      Skript v.2023-01-02
      *** BASE SYSTEM ***
      Architecture:   x86_64
      Docker:         false
      Virtualization: kvm
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       18:43:59 up 24 days,  3:22,  1 user,  load average: 0.33, 0.15, 0.11
      CPU threads: 8
      *** Time and Time Zones ***
      Tue Feb 21 17:43:59 UTC 2023
      Tue Feb 21 18:43:59 CET 2023
      CET +0100
      Europe/Berlin
      *** User and Groups ***
      alexander
      /home/alexander
      alexander cdrom floppy sudo audio dip video plugdev netdev
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:              9G        1.9G        3.7G         10M        4.4G        7.8G
      Swap:             0B          0B          0B
      Total:            9G        1.9G        3.7G
               9960 M total memory
               1879 M used memory
               1624 M active memory
               4018 M inactive memory
               3663 M free memory
                504 M buffer memory
               3914 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      udev           devtmpfs  4.9G     0  4.9G   0% /dev
      tmpfs          tmpfs     997M  856K  996M   1% /run
      /dev/sda1      ext4       63G   22G   38G  37% /
      tmpfs          tmpfs     4.9G     0  4.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      /dev/loop0     squashfs   64M   64M     0 100% /snap/core20/1778
      /dev/loop3     squashfs  117M  117M     0 100% /snap/core/14447
      /dev/loop4     squashfs   45M   45M     0 100% /snap/certbot/2618
      /dev/loop6     squashfs   64M   64M     0 100% /snap/core20/1822
      /dev/loop1     squashfs   44M   44M     0 100% /snap/certbot/2772
      /dev/loop2     squashfs  117M  117M     0 100% /snap/core/14784
      tmpfs          tmpfs     997M  4.0K  997M   1% /run/user/0
      Messages in dmesg:
      [Sat Jan 28 15:21:13 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [Sat Jan 28 15:21:13 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      TARGET               SOURCE     FSTYPE   OPTIONS
      /                    /dev/sda1  ext4     rw,relatime,errors=remount-ro
      |-/snap/certbot/2772 /dev/loop1 squashfs ro,nodev,relatime
      |-/snap/core20/1778  /dev/loop0 squashfs ro,nodev,relatime
      |-/snap/core/14447   /dev/loop3 squashfs ro,nodev,relatime
      |-/snap/certbot/2618 /dev/loop4 squashfs ro,nodev,relatime
      |-/snap/core/14784   /dev/loop2 squashfs ro,nodev,relatime
      `-/snap/core20/1822  /dev/loop6 squashfs ro,nodev,relatime
      /var:
      8.7G    /var/
      4.7G    /var/lib
      3.5G    /var/lib/docker/overlay2
      2.4G    /var/log/journal/15d3612335a04abe8c8234d7a2ed7176
      /opt/iobroker/backups:
      170M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      du: cannot read directory '/opt/iobroker/iobroker-data/letsencrypt/keys': Permission denied
      du: cannot read directory '/opt/iobroker/iobroker-data/letsencrypt/accounts/acme-v02.api.letsencrypt.org/directory': Permission denied
      834M    /opt/iobroker/iobroker-data/
      358M    /opt/iobroker/iobroker-data/files
      308M    /opt/iobroker/iobroker-data/sonosCache
      129M    /opt/iobroker/iobroker-data/backup-objects
      72M     /opt/iobroker/iobroker-data/files/telegram.admin
      find: Failed to change directory: /root: Permission denied
      find: '/opt/iobroker/iobroker-data/letsencrypt/keys': Permission denied
      find: '/opt/iobroker/iobroker-data/letsencrypt/accounts/acme-v02.api.letsencrypt.org/directory': Permission denied
      find: Failed to restore initial working directory: /root: Permission denied
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v16.19.1
      /usr/bin/node           v16.19.1
      /usr/bin/npm            8.19.3
      /usr/bin/npx            8.19.3
      nodejs:
        Installed: 16.19.1-deb-1nodesource1
        Candidate: 16.19.1-deb-1nodesource1
        Version table:
       *** 16.19.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 https://deb.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.5~dfsg-2~11u1 500
              500 https://deb.debian.org/debian bullseye/main amd64 Packages
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     6.1.4
      Adapters from github:   4
      Adapter State
        system.adapter.accuweather.0            : accuweather           : IoBroker                                 -  enabled
      + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.alexa2.0                 : alexa2                : IoBroker                                 - disabled
        system.adapter.alias-manager.0          : alias-manager         : IoBroker                                 -  enabled
        system.adapter.awattar.0                : awattar               : IoBroker                                 - disabled
        system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
        system.adapter.devices.0                : devices               : IoBroker                                 -  enabled
        system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : IoBroker                                 -  enabled
        system.adapter.echarts.0                : echarts               : IoBroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : IoBroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : IoBroker                                 - disabled
        system.adapter.go-e.0                   : go-e                  : IoBroker                                 -  enabled
        system.adapter.hass.0                   : hass                  : IoBroker                                 -  enabled, port: 8123
        system.adapter.icons-material-png.0     : icons-material-png    : IoBroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : IoBroker                                 -  enabled, port: 8086
        system.adapter.info.0                   : info                  : IoBroker                                 -  enabled
        system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
        system.adapter.iqontrol.0               : iqontrol              : IoBroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
        system.adapter.motionblinds.0           : motionblinds          : IoBroker                                 - disabled
      + system.adapter.mqtt.0                   : mqtt                  : IoBroker                                 -  enabled, port: 1886, bind: 192.168.178.5
        system.adapter.node-red.0               : node-red              : IoBroker                                 - disabled, port: 1880, bind: 0.0.0.0
        system.adapter.onkyo.0                  : onkyo                 : IoBroker                                 - disabled
        system.adapter.ping.0                   : ping                  : IoBroker                                 - disabled
        system.adapter.procon-ip.0              : procon-ip             : IoBroker                                 - disabled
        system.adapter.proxmox.0                : proxmox               : IoBroker                                 - disabled, port: 8006
      + system.adapter.pushover.0               : pushover              : IoBroker                                 -  enabled
        system.adapter.sayit.0                  : sayit                 : IoBroker                                 -  enabled
      + system.adapter.scenes.0                 : scenes                : IoBroker                                 -  enabled
        system.adapter.schoolfree.0             : schoolfree            : IoBroker                                 -  enabled
      + system.adapter.sonoff.0                 : sonoff                : IoBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : IoBroker                                 -  enabled
        system.adapter.spotify-premium.0        : spotify-premium       : IoBroker                                 -  enabled
        system.adapter.sql.0                    : sql                   : IoBroker                                 - disabled, port: 3306
      + system.adapter.telegram.0               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.text2command.0           : text2command          : IoBroker                                 -  enabled
        system.adapter.tibberconnect.0          : tibberconnect         : IoBroker                                 -  enabled
      + system.adapter.tr-064.0                 : tr-064                : IoBroker                                 -  enabled
        system.adapter.unifi.0                  : unifi                 : IoBroker                                 - disabled
        system.adapter.vis-bars.0               : vis-bars              : IoBroker                                 - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : IoBroker                                 -  enabled
        system.adapter.vis-history.0            : vis-history           : IoBroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IoBroker                                 - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IoBroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : IoBroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : IoBroker                                 - disabled
        system.adapter.vis.0                    : vis                   : IoBroker                                 -  enabled
        system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.wizconnect.0             : wizconnect            : IoBroker                                 -  enabled
        system.adapter.worx.0                   : worx                  : IoBroker                                 - disabled
      + system.adapter.zigbee.0                 : zigbee                : IoBroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_4edabfcdf6d8eb119f990815b9da5f8b-if00-port0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
      Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
      Adapter    "awattar"      : 1.0.6    , installed 1.0.6
      Adapter    "backitup"     : 2.5.12   , installed 2.5.12
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "devices"      : 1.1.2    , installed 1.1.2
      Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "echarts"      : 1.0.12   , installed 1.0.12
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
      Adapter    "go-e"         : 1.0.23   , installed 1.0.23
      Adapter    "hass"         : 1.3.0    , installed 1.3.0
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.14.2   , installed 1.14.2
      Adapter    "iqontrol"     : 2.1.0    , installed 2.1.0
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "node-red"     : 4.0.0    , installed 4.0.0
      Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
      Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "sayit"        : 1.12.3   , installed 1.12.3
      Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "sonos"        : 2.2.3    , installed 2.2.3
      Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
      Adapter    "text2command" : 2.3.0    , installed 2.3.0
      Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
      Adapter    "unifi"        : 0.5.10   , installed 0.5.10
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "worx"         : 2.0.3    , installed 2.0.3
      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
      Objects and States
      Objects:        13347
      States:         11513
      Hit:1 https://download.docker.com/linux/debian bullseye InRelease
      Hit:2 https://repos.influxdata.com/debian bullseye InRelease
      Hit:3 https://deb.debian.org/debian bullseye InRelease
      Hit:4 https://deb.debian.org/debian-security bullseye-security InRelease
      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
      Hit:6 https://deb.debian.org/debian bullseye-backports InRelease
      Hit:7 https://packages.grafana.com/enterprise/deb stable InRelease
      Hit:8 https://deb.debian.org/debian bullseye-updates InRelease
      Hit:9 https://packages.sury.org/php bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       64644705   1391244/iobroker.js
      tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      106        12029      560/mariadbd
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14049      547/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       64646596   1391378/io.sonoff.0
      tcp        0      0 0.0.0.0:8123            0.0.0.0:*               LISTEN      997        19357292   18019/python3.10
      tcp        0      0 192.168.178.5:1886      0.0.0.0:*               LISTEN      1001       64644046   1391444/io.mqtt.0
      tcp        0      0 192.168.178.5:1887      0.0.0.0:*               LISTEN      1001       64644047   1391444/io.mqtt.0
      tcp        0      0 192.168.178.5:40000     0.0.0.0:*               LISTEN      997        19357390   18019/python3.10
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       64644712   1391244/iobroker.js
      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       64646779   1391578/io.sonos.0
      tcp6       0      0 :::9999                 :::*                    LISTEN      0          890        579/apache2
      tcp6       0      0 :::80                   :::*                    LISTEN      0          886        579/apache2
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       64645781   1391265/io.admin.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      998        14304      456/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14060      547/sshd: /usr/sbin
      tcp6       0      0 :::3000                 :::*                    LISTEN      108        13226      648/grafana-server
      tcp6       0      0 :::8123                 :::*                    LISTEN      997        19357291   18019/python3.10
      tcp6       0      0 fe80::248c:5ff:fe:40000 :::*                    LISTEN      997        19360006   18019/python3.10
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          813        434/dhclient
      udp        0      0 0.0.0.0:50059           0.0.0.0:*                           997        19360004   18019/python3.10
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           997        19360003   18019/python3.10
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           997        19357378   18019/python3.10
      udp        0      0 0.0.0.0:36697           0.0.0.0:*                           997        19360002   18019/python3.10
      udp        0      0 192.168.178.5:5353      0.0.0.0:*                           997        19357376   18019/python3.10
      udp        0      0 0.0.0.0:55001           0.0.0.0:*                           997        19357382   18019/python3.10
      udp        0      0 0.0.0.0:38900           0.0.0.0:*                           997        19360264   18019/python3.10
      udp        0      0 0.0.0.0:32101           0.0.0.0:*                           997        19360402   18019/python3.10
      udp6       0      0 fe80::248c:5ff:fef2:546 :::*                                0          14405      770/dhclient
      udp6       0      0 :::33803                :::*                                997        19360018   18019/python3.10
      udp6       0      0 :::1900                 :::*                                997        19357381   18019/python3.10
      udp6       0      0 :::1900                 :::*                                997        19360014   18019/python3.10
      udp6       0      0 :::53031                :::*                                997        19360011   18019/python3.10
      udp6       0      0 :::5353                 :::*                                997        19357372   18019/python3.10
      udp6       0      0 fe80::248c:5ff:fef:5353 :::*                                997        19357377   18019/python3.10
      udp6       0      0 :::38636                :::*                                997        19357385   18019/python3.10
      2023-02-21 18:44:25.470  - info: mqtt.0 (1391444) Client [NSPanel_WZ] publishOnSubscribe send all known states
      2023-02-21 18:44:25.474  - info: sonoff.0 (1391378) Client [Heizung Ruth Bett] connected with secret 1677001465474_3560
      2023-02-21 18:44:25.526  - info: mqtt.0 (1391444) Client [NSPanel_BZ] publishOnSubscribe send all known states
      2023-02-21 18:44:25.527  - info: mqtt.0 (1391444) Client [NSPanel_BZ] publishOnSubscribe send all known states
      2023-02-21 18:44:25.528  - info: mqtt.0 (1391444) Client [NSPanel_BZ] publishOnSubscribe send all known states
      2023-02-21 18:44:25.624  - info: sonoff.0 (1391378) Client [Heizung OG TH] connected with secret 1677001465619_3105
      2023-02-21 18:44:25.650  - info: mqtt.0 (1391444) Client [NSPanel_SZ] connected with secret 1677001465648_1427
      2023-02-21 18:44:25.713  - info: sonoff.0 (1391378) Client [Kaffee Ecke] connected with secret 1677001465713_8012
      2023-02-21 18:44:25.716  - info: mqtt.0 (1391444) Client [NSPanel_SZ] subscribes on "SmartHome/NSPanel_SZ/cmnd/#" with regex /^SmartHome\.NSPanel_SZ\.cmnd(\..*)?/
      2023-02-21 18:44:25.716  - info: mqtt.0 (1391444) Client [NSPanel_SZ] subscribes on "SmartHome/NSPanel_SZ/cmnd/#"  with regex /^mqtt\.0\.SmartHome\.NSPanel_SZ\.cmnd(\..*)?/
      2023-02-21 18:44:25.716  - info: mqtt.0 (1391444) Client [NSPanel_SZ] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^SmartHome\.tasmotas\.cmnd(\..*)?/
      2023-02-21 18:44:25.716  - info: mqtt.0 (1391444) Client [NSPanel_SZ] subscribes on "SmartHome/tasmotas/cmnd/#"  with regex /^mqtt\.0\.SmartHome\.tasmotas\.cmnd(\..*)?/
      2023-02-21 18:44:25.717  - info: mqtt.0 (1391444) Client [NSPanel_SZ] subscribes on "cmnd/NSPanel_SZ_fb/#" with regex /^cmnd\.NSPanel_SZ_fb(\..*)?/
      2023-02-21 18:44:25.717  - info: mqtt.0 (1391444) Client [NSPanel_SZ] subscribes on "cmnd/NSPanel_SZ_fb/#"  with regex /^mqtt\.0\.cmnd\.NSPanel_SZ_fb(\..*)?/
      2023-02-21 18:44:25.724  - info: sonoff.0 (1391378) Client [Lampe grüner Sessel] connected with secret 1677001465716_5779
      2023-02-21 18:44:25.916  - info: mqtt.0 (1391444) Client [NSPanel_SZ] publishOnSubscribe send all known states
      2023-02-21 18:44:25.917  - info: mqtt.0 (1391444) Client [NSPanel_SZ] publishOnSubscribe send all known states
      2023-02-21 18:44:25.918  - info: sonoff.0 (1391378) Client [Wasserkocher] connected with secret 1677001465918_2838
      2023-02-21 18:44:25.919  - info: sonoff.0 (1391378) Client [Heizung OG Pow] connected with secret 1677001465918_2672
      2023-02-21 18:44:25.942  - info: sonoff.0 (1391378) Client [Lampe Waschbecken OG] connected with secret 1677001465940_6039
      2023-02-21 18:44:26.228  - info: sonoff.0 (1391378) Client [Heizung Arbeitszimmer] connected with secret 1677001466227_2974
      2023-02-21 18:44:26.242  - info: sonoff.0 (1391378) Client [Wäschetrockner] connected with secret 1677001466242_6251
      2023-02-21 18:44:27.434  - info: sonoff.0 (1391378) Client [Steuerung_Wärmepumpe] connected with secret 1677001467431_6290
      2023-02-21 18:44:27.635  - info: sonoff.0 (1391378) Client [Lampe KitchenAid] connected with secret 1677001467632_1074
                           v.2023-01-02
      Operatingsystem:        Debian GNU/Linux 11 (bullseye)
      Installation:           kvm
      Timezone:               Europe/Berlin
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                              /usr/bin/npm            8.19.3
                              /usr/bin/npx            8.19.3
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Status admin:
      Pending iob updates:    0
      Objects:                13347
      States:                 11513
      Size of iob-Database:
      • K Kentrath
        @wendy2702
        Skript v.2023-01-02
        *** BASE SYSTEM ***
        Docker:         false
        Virtualization: kvm
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 8
        CET +0100
        Europe/Berlin
        alexander
        /home/alexander
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:             0B          0B          0B
        Total:            9G        1.9G        3.7G
                 9960 M total memory
                 1879 M used memory
                 3663 M free memory
                  504 M buffer memory
                 3914 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        Messages in dmesg:
        /var:
        8.7G    /var/
        4.7G    /var/lib
        /usr/bin/npm            8.19.3
        /usr/bin/npx            8.19.3
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.3.5
        javascript:     6.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        13347
        States:         11513
        Pending Updates: 0
                             v.2023-01-02
        Installation:           kvm
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            8.19.3
                                /usr/bin/npx            8.19.3
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Status admin:
        Objects:                13347
        States:                 11513
        wendy2702W Online
        wendy2702W Online
        @kentrath
        Erst neuen User anlegen und die Befehle ausführen.
          @kentrath
          Kentrath
          @wendy2702
          Das habe ich als user alexander ausgeführt, nicht als root.
          • K Kentrath
            @wendy2702
            wendy2702W Online
            wendy2702W Online
            @kentrath Und als dieser auch den fix laufen lassen?
              Kentrath
              @wendy2702
              Ja, allerdings nicht im iob Verzeichnis, das sollte aber doch kein Problem sein oder?
              • K Kentrath
                @wendy2702
                wendy2702W Online
                wendy2702W Online
                @kentrath Dann jetzt mal die Instanz für WIZ…… auf Debug stellen, starten und das log zeigen.
                  Kentrath
                  @wendy2702
                  Ich habe jetzt mal einen ganz frischen lxc gestartet und iob installiert (als user nicht als root). Danach habe ich nur den wiz Adapter installiert. Es kommt eine identische Fehlermeldung:
                  host.ioBroker
                  2023-02-23 19:30:28.583	info	Rebuild for adapter system.adapter.wizconnect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                  host.ioBroker
                  2023-02-23 19:30:28.583	error	instance system.adapter.wizconnect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  host.ioBroker
                  2023-02-23 19:30:28.583	error	Caught by controller[0]: }
                  host.ioBroker
                  2023-02-23 19:30:28.583	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.wizconnect/main.js' ]
                  host.ioBroker
                  2023-02-23 19:30:28.583	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                  host.ioBroker
                  2023-02-23 19:30:28.583	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
                  host.ioBroker
                  2023-02-23 19:30:28.583	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:904:12)
                  host.ioBroker
                  2023-02-23 19:30:28.583	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1069:32)
                  host.ioBroker
                  2023-02-23 19:30:28.583	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
                  host.ioBroker
                  2023-02-23 19:30:28.583	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1191:14)
                  host.ioBroker
                  2023-02-23 19:30:28.583	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.wizconnect/main.js:10:22)
                  host.ioBroker
                  2023-02-23 19:30:28.582	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:108:18)
                  host.ioBroker
                  2023-02-23 19:30:28.582	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1093:19)
                  host.ioBroker
                  2023-02-23 19:30:28.582	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:866:27)
                  host.ioBroker
                  2023-02-23 19:30:28.582	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
                  host.ioBroker
                  2023-02-23 19:30:28.582	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.wizconnect/main.js
                  host.ioBroker
                  2023-02-23 19:30:28.581	error	Caught by controller[0]: Require stack:
                  host.ioBroker
                  2023-02-23 19:30:28.581	error	Caught by controller[0]: Error: Cannot find module '@apollon/iobroker-tools'
                  host.ioBroker
                  2023-02-23 19:30:28.581	error	Caught by controller[0]: ^
                  host.ioBroker
                  2023-02-23 19:30:28.580	error	Caught by controller[0]: throw err;
                  host.ioBroker
                  2023-02-23 19:30:28.580	error	Caught by controller[0]: node:internal/modules/cjs/loader:1024
                  host.ioBroker
                  2023-02-23 19:30:28.347	info	instance system.adapter.wizconnect.0 started with pid 13195
                  • K Kentrath
                    @wendy2702
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    wendy2702W Online
                    wendy2702W Online
                    Wie genau? Will das mal testen
                    EDIT: Läuft auch bei mir nicht. Denke da musst du dich am besten per Github an den Entwickler wenden wenn sonst niemandem etwas einfällt.
                    1Topf1 1 Antwort Letzte Antwort
                      1Topf1 Offline
                      1Topf1 Offline
                      1Topf
                      @wendy2702
                      Ich hab ihn erst letzte Woche installiert und lief sofort.
                        disaster123
                        Sieht für mich nach nem nodejs / npm Problem aus. Ich installiere ihn normal via GUI und er läuft.
                        • 1Topf1 1Topf
                          @wendy2702
                          wendy2702W Online
                          wendy2702W Online
                          @1topf sagte in Wie nutze ich eine custom class / npm Modul?:
                          @wendy2702
                          @disaster123 sagte in Wie nutze ich eine custom class / npm Modul?:
                          Welche Versionen habt ihr denn für Node/NPM ?
                          Und was bedeutet "normal via Gui" ?
                          Ich habe eine neue iobroker installation und befinde mich im latest:
                          oder im Stable
                          Nix "wiz" oder wie heisst der Adapter?
                            disaster123
                            Über die Katze im Menü und dann die URL: https://github.com/disaster123/ioBroker.wizconnect
                            • D disaster123
                              wendy2702W Online
                              wendy2702W Online
                              @disaster123 Und welche NPM/Node Version läuft bei dir?
                              Das, ist übrigens nicht "normal über Gui" sondern wie du selber schreibst per GIthub Link im Expertenmodus.
                                disaster123
                                Muss ich nachher mal gucken bitte das Original docker image von iobroker. Die Versionen sind da quasi fest.
                                  1Topf1 Offline
                                  1Topf1 Offline
                                  1Topf
                                  @wendy2702
                                  Bei mir node.js 16.19.0 und npm 8.19.3.
                                  • 1Topf1 1Topf
                                    @wendy2702
                                    Kentrath
                                    @1topf
                                    Bei mir ist es node 16.19.1
                                    • wendy2702W Online
                                      wendy2702W Online
                                      Könnt ihr mal die Ausgabe davon zeigen:
                                      cd/opt/iobroker/
                                      npm list
                                        disaster123
                                        Node.js:
                                        v16.19.0
                                        NPM:
                                        8.19.3
                                          cd/opt/iobroker/
                                          npm list
                                          1Topf1 Offline
                                          1Topf1 Offline
                                          1Topf
                                          @wendy2702 sagte in Wie nutze ich eine custom class / npm Modul?:
                                          cd/opt/iobroker/
                                          npm list
                                          iobroker@ioBroker:/opt/iobroker$ npm list
                                          iobroker.inst@3.0.0 /opt/iobroker
                                          ├── iobroker.admin@6.3.5
                                          ├── iobroker.alexa2@3.23.2
                                          ├── iobroker.backitup@2.5.12
                                          ├── iobroker.device-watcher@2.6.1
                                          ├── iobroker.discovery@3.1.0
                                          ├── iobroker.echarts@1.0.12
                                          ├── iobroker.enigma2@1.3.3 (git+ssh://git@github.com/Matten-Matten/ioBroker.enigma2.git#975e828ab4595b81333bcca5b32af3cbf3c287bc)
                                          ├── iobroker.flot@1.11.0
                                          ├── iobroker.fullcalendar@1.2.0
                                          ├── iobroker.habpanel@0.5.0
                                          ├── iobroker.hiob@0.0.30
                                          ├── iobroker.history@2.2.4
                                          ├── iobroker.hs100@2.1.3 (git+ssh://git@github.com/arteck/ioBroker.hs100.git#bc5e7c89fe24cd4da1376a3e749e133bb564c4f6)
                                          ├── iobroker.ical@1.13.2
                                          ├── iobroker.icons-addictive-flavour-png@0.1.0
                                          ├── iobroker.icons-fatcow-hosting@0.1.0
                                          ├── iobroker.icons-icons8@0.0.1
                                          ├── iobroker.icons-material-png@0.1.0
                                          ├── iobroker.icons-material-svg@0.1.0
                                          ├── iobroker.icons-mfd-png@1.1.0
                                          ├── iobroker.icons-mfd-svg@1.1.0
                                          ├── iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
                                          ├── iobroker.icons-ultimate-png@1.0.1
                                          ├── iobroker.info@1.9.19
                                          ├── iobroker.iot@1.14.2
                                          ├── iobroker.jarvis@3.1.2
                                          ├── iobroker.javascript@6.1.4
                                          ├── iobroker.js-controller@4.0.24
                                          ├── iobroker.lgtv@1.1.10
                                          ├── iobroker.linux-control@1.1.3
                                          ├── iobroker.minuvis@2.2.0
                                          ├── iobroker.moma@1.2.9
                                          ├── iobroker.mqtt@4.0.7
                                          ├── iobroker.net-tools@0.2.0
                                          ├── iobroker.onvif@1.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.onvif.git#a4cf207db3917eaa7f2f83bea79daf2b617d46a4)
                                          ├── iobroker.ping@1.5.3
                                          ├── iobroker.shelly@6.3.1
                                          ├── iobroker.signal-cmb@0.3.0
                                          ├── iobroker.smartstate@0.0.1
                                          ├── iobroker.sonoff@2.5.1
                                          ├── iobroker.statistics@2.3.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.statistics.git#b20bc874be5382f1eeaeeae4efa7f5dd23967e0b)
                                          ├── iobroker.tr-064@4.2.17
                                          ├── iobroker.tuya@3.13.1
                                          ├── iobroker.vis-2-widgets-energy@0.1.3
                                          ├── iobroker.vis-2-widgets-gauges@0.1.4
                                          ├── iobroker.vis-2-widgets-material@0.2.1
                                          ├── iobroker.vis-bars@0.1.4
                                          ├── iobroker.vis-canvas-gauges@1.0.1
                                          ├── iobroker.vis-colorpicker@1.2.0
                                          ├── iobroker.vis-fancyswitch@1.1.0
                                          ├── iobroker.vis-google-fonts@1.0.4
                                          ├── iobroker.vis-history@1.0.0
                                          ├── iobroker.vis-hqwidgets@1.3.0
                                          ├── iobroker.vis-icontwo@0.90.0
                                          ├── iobroker.vis-inventwo@3.3.1
                                          ├── iobroker.vis-jqui-mfd@1.0.12
                                          ├── iobroker.vis-justgage@1.0.2
                                          ├── iobroker.vis-lcars@1.0.4
                                          ├── iobroker.vis-material-advanced@1.7.2
                                          ├── iobroker.vis-metro@1.2.0
                                          ├── iobroker.vis-plumb@1.0.2
                                          ├── iobroker.vis-rgraph@0.0.2
                                          ├── iobroker.vis-timeandweather@1.2.2
                                          ├── iobroker.vis-weather@2.5.6
                                          ├── iobroker.vis@1.4.15
                                          ├── iobroker.web@4.3.0
                                          ├── iobroker.wizconnect@0.0.5 (git+ssh://git@github.com/disaster123/ioBroker.wizconnect.git#ad84f06e2e5e73de575ad53b91c9d7a24d8b9384)
                                          ├── iobroker.zigbee@1.8.10
                                          └── iobroker.zigbee2mqtt@2.7.3
